[U-Boot] [PATCH] usb:udc:samsung Add functions for storing private gadget data in UDC driver
This commit adds support for storing private data to Samsung's UDC driver. This data is afterward used by usb gadget.
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Marek Vasut marex@denx.de --- drivers/usb/gadget/s3c_udc_otg.c | 12 ++++++++++++ 1 files changed, 12 insertions(+), 0 deletions(-)
diff --git a/drivers/usb/gadget/s3c_udc_otg.c b/drivers/usb/gadget/s3c_udc_otg.c index f7f7b54..cb4916c 100644 --- a/drivers/usb/gadget/s3c_udc_otg.c +++ b/drivers/usb/gadget/s3c_udc_otg.c @@ -133,6 +133,18 @@ static void nuke(struct s3c_ep *ep, int status); static int s3c_udc_set_halt(struct usb_ep *_ep, int value); static void s3c_udc_set_nak(struct s3c_ep *ep);
+void set_udc_gadget_private_data(void *p) +{ + printf("%s: the_controller: 0x%p, p: 0x%p\n", __func__, + the_controller, p); + the_controller->gadget.dev.device_data = p; +} + +void *get_udc_gadget_private_data(struct usb_gadget *gadget) +{ + return gadget->dev.device_data; +} + static struct usb_ep_ops s3c_ep_ops = { .enable = s3c_ep_enable, .disable = s3c_ep_disable,
Dear Lukasz Majewski,
- printf("%s: the_controller: 0x%p, p: 0x%p\n", __func__,
the_controller, p);
- the_controller->gadget.dev.device_data = p;
- return gadget->dev.device_data;
Is this part of some bigger patchset or are you simply adding dead code?
Best regards, Marek Vasut
Hi Marek Vasut,
the_controller, p);
Yes, this is the part of a bigger patchset :-) - the composite gadget (g_dnl) requires this change.
e.g.
http://patchwork.ozlabs.org/patch/151989/
Hi Marek Vasut,
the_controller, p);
e.g.
Can you please make it into a patchset then? You know -- so we all know what this is part of.
In message 1334214969-19664-1-git-send-email-l.majewski@samsung.com you wrote:
s/printf/debug/ ??
Lukasz Majewski
