[PATCH v3 0/2] Add support for Cool Pi GenBook
Support for Cool Pi GenBook is landing Linux 6.12-rc1, so also add the support for u-boot here.
Changes in v3: - Remove upstreamed dt in genbook-u-boot.dtsi - Remove MMC releated config as there is no SD-card on this machine - Enable LED config - Enable rk8xx pmic - rename defconfig to coolpi-cm5-genbook-rk3588_defconfig - redefine BOOT_TARGETS
Changes in v2: - Cherry pick it from https://git.kernel.org/pub/scm/linux/kernel/git/devicetree/devicetree-rebasi... - split the dts to a separate commit - rename to genbook_cm5_rk3588 - move readme to doc/board, and write as reStructuredText format - alphabetically reorder - update doc/board/rockchip
Andy Yan (2): arm64: dts: rockchip: Add support for rk3588 based Cool Pi CM5 GenBook board: rockchip: Add support for rk3588 GenBook
.../dts/rk3588-coolpi-cm5-genbook-u-boot.dtsi | 20 + arch/arm/mach-rockchip/rk3588/Kconfig | 19 + board/coolpi/genbook_cm5_rk3588/Kconfig | 12 + board/coolpi/genbook_cm5_rk3588/MAINTAINERS | 7 + configs/coolpi-cm5-genbook-rk3588_defconfig | 101 +++++ doc/board/coolpi/genbook_cm5_rk3588.rst | 68 ++++ doc/board/coolpi/index.rst | 9 + doc/board/rockchip/rockchip.rst | 1 + .../rockchip/rk3588-coolpi-cm5-genbook.dts | 349 ++++++++++++++++++ include/configs/genbook-cm5-rk3588.h | 31 ++ 10 files changed, 617 insertions(+) create mode 100644 arch/arm/dts/rk3588-coolpi-cm5-genbook-u-boot.dtsi create mode 100644 board/coolpi/genbook_cm5_rk3588/Kconfig create mode 100644 board/coolpi/genbook_cm5_rk3588/MAINTAINERS create mode 100644 configs/coolpi-cm5-genbook-rk3588_defconfig create mode 100644 doc/board/coolpi/genbook_cm5_rk3588.rst create mode 100644 doc/board/coolpi/index.rst create mode 100644 dts/upstream/src/arm64/rockchip/rk3588-coolpi-cm5-genbook.dts create mode 100644 include/configs/genbook-cm5-rk3588.h
Cool Pi CM5 GenBook works as a carrier board connect with CM5 [0].
Specification: - Rockchip RK3588 - LPDDR5X 8/32 GB - eMMC 64 GB - HDMI Type A out x 1 - USB 3.0 Host x 1 - USB-C 3.0 with DisplayPort AltMode - PCIE M.2 E Key for RTL8852BE Wireless connection - PCIE M.2 M Key for NVME connection - eDP panel with 1920x1080
This patch add basic support to bringup eMMC/USB HOST/WiFi/TouchPad/ Battery/PCIE NVME, and can also drive a HDMI output with out of tree hdmi patches.
[0] https://www.crowdsupply.com/shenzhen-tianmao-technology-co-ltd/genbook-rk358...
Signed-off-by: Andy Yan andyshrk@163.com Link: https://lore.kernel.org/r/20240730102433.540260-3-andyshrk@163.com Signed-off-by: Heiko Stuebner heiko@sntech.de
[ upstream commit: 4a8c1161b843c366776fc872a6fe45b743b2983e ]
(cherry picked from commit dc6316da23734d9321e09f8c8a7669f4b4cb9f75)
(no changes since v2)
.../rockchip/rk3588-coolpi-cm5-genbook.dts | 349 ++++++++++++++++++ 1 file changed, 349 insertions(+) create mode 100644 dts/upstream/src/arm64/rockchip/rk3588-coolpi-cm5-genbook.dts
diff --git a/dts/upstream/src/arm64/rockchip/rk3588-coolpi-cm5-genbook.dts b/dts/upstream/src/arm64/rockchip/rk3588-coolpi-cm5-genbook.dts new file mode 100644 index 00000000000..6418286efe4 --- /dev/null +++ b/dts/upstream/src/arm64/rockchip/rk3588-coolpi-cm5-genbook.dts @@ -0,0 +1,349 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2024 Rockchip Electronics Co., Ltd. + * + */ + +/dts-v1/; + +#include <dt-bindings/leds/common.h> +#include "rk3588-coolpi-cm5.dtsi" + +/ { + model = "CoolPi CM5 GenBook"; + compatible = "coolpi,pi-cm5-genbook", "coolpi,pi-cm5", "rockchip,rk3588"; + + backlight: backlight { + compatible = "pwm-backlight"; + enable-gpios = <&gpio4 RK_PA3 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&bl_en>; + power-supply = <&vcc12v_dcin>; + pwms = <&pwm6 0 25000 0>; + }; + + battery: battery { + compatible = "simple-battery"; + charge-full-design-microamp-hours = <9800000>; + voltage-max-design-microvolt = <4350000>; + voltage-min-design-microvolt = <3000000>; + }; + + charger: dc-charger { + compatible = "gpio-charger"; + charger-type = "mains"; + gpios = <&gpio1 RK_PC0 GPIO_ACTIVE_LOW>; + }; + + leds: leds { + compatible = "gpio-leds"; + + heartbeat_led: led-0 { + color = <LED_COLOR_ID_GREEN>; + function = LED_FUNCTION_STATUS; + gpios = <&gpio1 RK_PB0 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "heartbeat"; + }; + + wlan_led: led-1 { + color = <LED_COLOR_ID_GREEN>; + function = LED_FUNCTION_WLAN; + gpios = <&gpio0 RK_PC5 GPIO_ACTIVE_HIGH>; + }; + + charging_red: led-2 { + function = LED_FUNCTION_CHARGING; + color = <LED_COLOR_ID_RED>; + gpios = <&gpio3 RK_PD2 GPIO_ACTIVE_HIGH>; + }; + }; + + vcc12v_dcin: vcc12v-dcin-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc12v_dcin"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + }; + + vcc_sys: vcc-sys-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <7000000>; + regulator-max-microvolt = <7000000>; + vin-supply = <&vcc12v_dcin>; + }; + + vcc5v0_sys: vcc5v0-sys-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <7000000>; + regulator-max-microvolt = <7000000>; + vin-supply = <&vcc_sys>; + }; + + vcc3v3_sys: vcc3v3-sys-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vcc5v0_sys>; + }; + + vcc3v3_lcd: vcc3v3-lcd-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3_lcd"; + enable-active-high; + gpio = <&gpio1 RK_PC4 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&lcdpwr_en>; + vin-supply = <&vcc3v3_sys>; + }; + + vcc5v0_usb: vcc5v0-usb-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_usb"; + regulator-boot-on; + regulator-always-on; + enable-active-high; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + gpio = <&gpio1 RK_PD5 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&usb_pwren>; + vin-supply = <&vcc_sys>; + }; + + vcc5v0_usb_host0: vcc5v0_usb30_host: vcc5v0-usb-host-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_host"; + regulator-boot-on; + regulator-always-on; + enable-active-high; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + gpio = <&gpio1 RK_PA7 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&usb_host_pwren>; + vin-supply = <&vcc5v0_usb>; + }; +}; + +&i2c4 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&i2c4m3_xfer>; + + cw2015@62 { + compatible = "cellwise,cw2015"; + reg = <0x62>; + + cellwise,battery-profile = /bits/ 8 < + 0x17 0x67 0x69 0x63 0x63 0x62 0x62 0x5F + 0x52 0x73 0x4C 0x5A 0x5B 0x4B 0x42 0x3A + 0x33 0x2D 0x29 0x28 0x2E 0x31 0x3C 0x49 + 0x2C 0x2C 0x0C 0xCD 0x30 0x51 0x50 0x66 + 0x74 0x74 0x75 0x78 0x41 0x1B 0x84 0x5F + 0x0B 0x34 0x1C 0x45 0x89 0x92 0xA0 0x13 + 0x2C 0x55 0xAB 0xCB 0x80 0x5E 0x7B 0xCB + 0x2F 0x00 0x64 0xA5 0xB5 0x10 0x18 0x21 + >; + + cellwise,monitor-interval-ms = <3000>; + monitored-battery = <&battery>; + power-supplies = <&charger>; + }; +}; + +&i2c5 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&i2c5m3_xfer>; + + touchpad: touchpad@2c { + compatible = "hid-over-i2c"; + reg = <0x2c>; + interrupt-parent = <&gpio1>; + interrupts = <RK_PD6 IRQ_TYPE_LEVEL_LOW>; + hid-descr-addr = <0x0020>; + }; +}; + +&gmac0 { + status = "disabled"; +}; + +/* M.2 E-Key */ +&pcie2x1l0 { + reset-gpios = <&gpio4 RK_PA2 GPIO_ACTIVE_HIGH>; + vpcie3v3-supply = <&vcc3v3_sys>; + pinctrl-names = "default"; + pinctrl-0 = <&pcie_clkreq &pcie_wake &pcie_rst &wifi_pwron &bt_pwron>; + status = "okay"; +}; + +&pcie2x1l2 { + status = "disabled"; +}; + +&pcie30phy { + status = "okay"; +}; + +/* M.2 M-Key ssd */ +&pcie3x4 { + reset-gpios = <&gpio4 RK_PB6 GPIO_ACTIVE_HIGH>; + vpcie3v3-supply = <&vcc3v3_sys>; + status = "okay"; +}; + +&pinctrl { + lcd { + lcdpwr_en: lcdpwr-en { + rockchip,pins = <1 RK_PC4 RK_FUNC_GPIO &pcfg_pull_down>; + }; + + bl_en: bl-en { + rockchip,pins = <4 RK_PA3 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + usb { + usb_pwren: usb-pwren { + rockchip,pins = <1 RK_PD5 RK_FUNC_GPIO &pcfg_pull_up>; + }; + + usb_otg_pwren: usb-otg-pwren { + rockchip,pins = <0 RK_PA0 RK_FUNC_GPIO &pcfg_pull_up>; + }; + + usb_host_pwren: usb-host-pwren { + rockchip,pins = <1 RK_PA7 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + wifi { + bt_pwron: bt-pwron { + rockchip,pins = <3 RK_PA6 RK_FUNC_GPIO &pcfg_pull_up>; + }; + + pcie_clkreq: pcie-clkreq { + rockchip,pins = <4 RK_PA0 RK_FUNC_GPIO &pcfg_pull_up>; + }; + + pcie_rst: pcie-rst { + rockchip,pins = <4 RK_PA2 RK_FUNC_GPIO &pcfg_pull_up>; + }; + + wifi_pwron: wifi-pwron { + rockchip,pins = <3 RK_PB1 RK_FUNC_GPIO &pcfg_pull_up>; + }; + + pcie_wake: pcie-wake { + rockchip,pins = <4 RK_PA1 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; +}; + +&pwm6 { + pinctrl-0 = <&pwm6m1_pins>; + status = "okay"; +}; + +&sdmmc { + status = "disabled"; +}; + +&sfc { + pinctrl-names = "default"; + pinctrl-0 = <&fspim2_pins>; + status = "okay"; + + flash@0 { + compatible = "jedec,spi-nor"; + reg = <0x0>; + spi-max-frequency = <100000000>; + spi-rx-bus-width = <4>; + spi-tx-bus-width = <1>; + }; +}; + +&u2phy0 { + status = "okay"; +}; + +&u2phy0_otg { + status = "okay"; +}; + +&usbdp_phy0 { + status = "okay"; +}; + +&u2phy1 { + status = "okay"; +}; + +&u2phy1_otg { + status = "okay"; +}; + +&u2phy2 { + status = "okay"; +}; + +&u2phy3 { + status = "okay"; +}; + +&u2phy2_host { + phy-supply = <&vcc5v0_usb_host0>; + status = "okay"; +}; + +&u2phy3_host { + phy-supply = <&vcc5v0_usb>; + status = "okay"; +}; + +&usbdp_phy1 { + status = "okay"; +}; + +/* For Keypad */ +&usb_host0_ehci { + status = "okay"; +}; + +&usb_host0_ohci { + status = "okay"; +}; + +/* Type C port */ +&usb_host0_xhci { + dr_mode = "peripheral"; + maximum-speed = "high-speed"; + status = "okay"; +}; + +/* connected to a HUB for camera and BT */ +&usb_host1_ehci { + status = "okay"; +}; + +&usb_host1_ohci { + status = "okay"; +}; + +/* USB A out */ +&usb_host1_xhci { + dr_mode = "host"; + status = "okay"; +};
Specification:
- Rockchip RK3588
- LPDDR5X 8/32 GB
- eMMC 64 GB
- USB 3.0 Host x 1
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
Changes in v2:
- Copyright (c) 2024 Rockchip Electronics Co., Ltd.
+/dts-v1/;
- model = "CoolPi CM5 GenBook";
- compatible = "coolpi,pi-cm5-genbook", "coolpi,pi-cm5", "rockchip,rk3588";
- backlight: backlight {
- battery: battery {
- charger: dc-charger {
- leds: leds {
wlan_led: led-1 {
- vcc12v_dcin: vcc12v-dcin-regulator {
regulator-boot-on;
- vcc_sys: vcc-sys-regulator {
regulator-boot-on;
- vcc5v0_sys: vcc5v0-sys-regulator {
regulator-boot-on;
- vcc3v3_sys: vcc3v3-sys-regulator {
regulator-boot-on;
- vcc3v3_lcd: vcc3v3-lcd-regulator {
enable-active-high;
- vcc5v0_usb: vcc5v0-usb-regulator {
regulator-boot-on;
enable-active-high;
- vcc5v0_usb_host0: vcc5v0_usb30_host: vcc5v0-usb-host-regulator {
regulator-boot-on;
enable-active-high;
+&i2c4 {
- status = "okay";
- pinctrl-names = "default";
- pinctrl-0 = <&i2c4m3_xfer>;
- cw2015@62 {
reg = <0x62>;
+&i2c5 {
- status = "okay";
- pinctrl-0 = <&i2c5m3_xfer>;
- touchpad: touchpad@2c {
reg = <0x2c>;
+&gmac0 {
- status = "disabled";
- reset-gpios = <&gpio4 RK_PA2 GPIO_ACTIVE_HIGH>;
- vpcie3v3-supply = <&vcc3v3_sys>;
- pinctrl-0 = <&pcie_clkreq &pcie_wake &pcie_rst &wifi_pwron &bt_pwron>;
- status = "okay";
+&pcie2x1l2 {
+&pcie30phy {
- status = "okay";
- reset-gpios = <&gpio4 RK_PB6 GPIO_ACTIVE_HIGH>;
- status = "okay";
+&pinctrl {
- lcd {
bl_en: bl-en {
- usb {
- wifi {
+&pwm6 {
- pinctrl-0 = <&pwm6m1_pins>;
- status = "okay";
+&sdmmc {
+&sfc {
- pinctrl-0 = <&fspim2_pins>;
- status = "okay";
- flash@0 {
reg = <0x0>;
+&u2phy0 {
- status = "okay";
+&u2phy0_otg {
- status = "okay";
+&usbdp_phy0 {
- status = "okay";
+&u2phy1 {
- status = "okay";
+&u2phy1_otg {
- status = "okay";
+&u2phy2 {
- status = "okay";
+&u2phy3 {
- status = "okay";
+&u2phy2_host {
- phy-supply = <&vcc5v0_usb_host0>;
- status = "okay";
+&u2phy3_host {
- phy-supply = <&vcc5v0_usb>;
- status = "okay";
+&usbdp_phy1 {
- status = "okay";
- status = "okay";
+&usb_host0_ohci {
- status = "okay";
- dr_mode = "peripheral";
- maximum-speed = "high-speed";
- status = "okay";
- status = "okay";
+&usb_host1_ohci {
- status = "okay";
- dr_mode = "host";
- status = "okay";
Add support for Cool Pi GenBook, it works as a carrier board connect with CM5 SOM.
Tested by Armbian boot on USB disk.
Changes in v2: - split the dts to a separate commit - rename to genbook_cm5_rk3588 - move readme to doc/board, and write as reStructuredText format - alphabetically reorder - update doc/board/rockchip
.../dts/rk3588-coolpi-cm5-genbook-u-boot.dtsi | 20 ++++ arch/arm/mach-rockchip/rk3588/Kconfig | 19 ++++ board/coolpi/genbook_cm5_rk3588/Kconfig | 12 +++ board/coolpi/genbook_cm5_rk3588/MAINTAINERS | 7 ++ configs/coolpi-cm5-genbook-rk3588_defconfig | 101 ++++++++++++++++++ doc/board/coolpi/genbook_cm5_rk3588.rst | 68 ++++++++++++ doc/board/coolpi/index.rst | 9 ++ doc/board/rockchip/rockchip.rst | 1 + include/configs/genbook-cm5-rk3588.h | 31 ++++++ 9 files changed, 268 insertions(+) create mode 100644 arch/arm/dts/rk3588-coolpi-cm5-genbook-u-boot.dtsi create mode 100644 board/coolpi/genbook_cm5_rk3588/Kconfig create mode 100644 board/coolpi/genbook_cm5_rk3588/MAINTAINERS create mode 100644 configs/coolpi-cm5-genbook-rk3588_defconfig create mode 100644 doc/board/coolpi/genbook_cm5_rk3588.rst create mode 100644 doc/board/coolpi/index.rst create mode 100644 include/configs/genbook-cm5-rk3588.h
diff --git a/arch/arm/dts/rk3588-coolpi-cm5-genbook-u-boot.dtsi b/arch/arm/dts/rk3588-coolpi-cm5-genbook-u-boot.dtsi new file mode 100644 index 00000000000..5a3073d6e7f --- /dev/null +++ b/arch/arm/dts/rk3588-coolpi-cm5-genbook-u-boot.dtsi @@ -0,0 +1,20 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) + +#include "rk3588-u-boot.dtsi" + +&fspim2_pins { + bootph-pre-ram; + bootph-some-ram; +}; + +&sfc { + flash@0 { + bootph-pre-ram; + bootph-some-ram; + }; +}; + +/* USB A out */ +&usb_host1_xhci { + snps,dis_u3_susphy_quirk; +}; diff --git a/arch/arm/mach-rockchip/rk3588/Kconfig b/arch/arm/mach-rockchip/rk3588/Kconfig index a76a470cc98..c53f6bb926e 100644 --- a/arch/arm/mach-rockchip/rk3588/Kconfig +++ b/arch/arm/mach-rockchip/rk3588/Kconfig @@ -29,6 +29,24 @@ config TARGET_CM3588_NAS_RK3588 - 3.5mm Headphone out, 2.0mm PH-2A Mic in - 5V Fan connector, PWM beeper, IR receiver, RTC battery connector
+config TARGET_GENBOOK_CM5_RK3588 + bool "Cool Pi CM5 GenBook" + select BOARD_LATE_INIT + help + GeenBook is a notebook based on Rockchip RK3588, and works as a carrier + board connect with CM5 SOM. + + Specification: + - Rockchip RK3588 + - LPDDR5X 8/32 GB + - eMMC 64 GB + - HDMI Type A out x 1 + - USB 3.0 Host x 1 + - USB-C 3.0 with DisplayPort AltMode + - PCIE M.2 E Key for RTL8852BE Wireless connection + - PCIE M.2 M Key for NVME connection + - eDP panel with 1920x1080 + config TARGET_JAGUAR_RK3588 bool "Theobroma Systems SBC-RK3588-AMR (Jaguar)" select BOARD_LATE_INIT @@ -361,6 +379,7 @@ config TEXT_BASE default 0x00a00000
source "board/armsom/sige7-rk3588/Kconfig" +source "board/coolpi/genbook_cm5_rk3588/Kconfig" source "board/edgeble/neural-compute-module-6/Kconfig" source "board/friendlyelec/cm3588-nas-rk3588/Kconfig" source "board/friendlyelec/nanopc-t6-rk3588/Kconfig" diff --git a/board/coolpi/genbook_cm5_rk3588/Kconfig b/board/coolpi/genbook_cm5_rk3588/Kconfig new file mode 100644 index 00000000000..67086ea6297 --- /dev/null +++ b/board/coolpi/genbook_cm5_rk3588/Kconfig @@ -0,0 +1,12 @@ +if TARGET_GENBOOK_CM5_RK3588 + +config SYS_BOARD + default "genbook_cm5_rk3588" + +config SYS_VENDOR + default "coolpi" + +config SYS_CONFIG_NAME + default "genbook-cm5-rk3588" + +endif diff --git a/board/coolpi/genbook_cm5_rk3588/MAINTAINERS b/board/coolpi/genbook_cm5_rk3588/MAINTAINERS new file mode 100644 index 00000000000..0496cc93b59 --- /dev/null +++ b/board/coolpi/genbook_cm5_rk3588/MAINTAINERS @@ -0,0 +1,7 @@ +GENBOOK-CM5-RK3588 +M: Andy Yan andyshrk@163.com +S: Maintained +F: board/coolpi/genbook-cm5-rk3588 +F: include/configs/genbook-cm5-rk3588.h +F: configs/coolpi-cm5-genbook-rk3588_defconfig +F: arch/arm/dts/rk3588-coolpi-cm5-genbook-u-boot.dtsi diff --git a/configs/coolpi-cm5-genbook-rk3588_defconfig b/configs/coolpi-cm5-genbook-rk3588_defconfig new file mode 100644 index 00000000000..3eb5dc968af --- /dev/null +++ b/configs/coolpi-cm5-genbook-rk3588_defconfig @@ -0,0 +1,101 @@ +CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_COUNTER_FREQUENCY=24000000 +CONFIG_ARCH_ROCKCHIP=y +CONFIG_SF_DEFAULT_SPEED=24000000 +CONFIG_SF_DEFAULT_MODE=0x2000 +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3588-coolpi-cm5-genbook" +CONFIG_ROCKCHIP_RK3588=y +CONFIG_ROCKCHIP_SPI_IMAGE=y +CONFIG_SPL_SERIAL=y +CONFIG_TARGET_GENBOOK_CM5_RK3588=y +CONFIG_SYS_LOAD_ADDR=0xc00800 +CONFIG_SF_DEFAULT_BUS=5 +CONFIG_DEBUG_UART_BASE=0xFEB50000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SPL_SPI_FLASH_SUPPORT=y +CONFIG_SPL_SPI=y +CONFIG_PCI=y +CONFIG_DEBUG_UART=y +CONFIG_AHCI=y +# CONFIG_ANDROID_BOOT_IMAGE is not set +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_SPL_FIT_SIGNATURE=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_LEGACY_IMAGE_FORMAT=y +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3588-coolpi-cm5-genbook.dtb" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x40000 +CONFIG_SPL_PAD_TO=0x7f8000 +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x60000 +CONFIG_SPL_ATF=y +# CONFIG_CMD_BIND is not set +# CONFIG_CMD_FASTBOOT is not set +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_REGULATOR=y +# CONFIG_SPL_DOS_PARTITION is not set +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_LIVE=y +CONFIG_OF_SPL_REMOVE_PROPS="clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_SPL_REGMAP=y +CONFIG_SPL_SYSCON=y +CONFIG_AHCI_PCI=y +CONFIG_DWC_AHCI=y +CONFIG_SPL_CLK=y +CONFIG_FASTBOOT_BUF_ADDR=0x800800 +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_LED=y +CONFIG_LED_GPIO=y +CONFIG_MISC=y +CONFIG_SUPPORT_EMMC_RPMB=y +CONFIG_MMC_HS400_ES_SUPPORT=y +CONFIG_SPL_MMC_HS400_ES_SUPPORT=y +CONFIG_MMC_HS400_SUPPORT=y +CONFIG_SPL_MMC_HS400_SUPPORT=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_SDMA=y +CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_SPI_FLASH_SFDP_SUPPORT=y +CONFIG_SPI_FLASH_XMC=y +CONFIG_SPI_FLASH_XTX=y +CONFIG_NVME_PCI=y +CONFIG_PCIE_DW_ROCKCHIP=y +CONFIG_PHY_ROCKCHIP_INNO_USB2=y +CONFIG_PHY_ROCKCHIP_NANENG_COMBOPHY=y +CONFIG_PHY_ROCKCHIP_USBDP=y +CONFIG_SPL_PINCTRL=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_RK8XX=y +CONFIG_REGULATOR_RK8XX=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_SPL_RAM=y +CONFIG_SCSI=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYS_NS16550_MEM32=y +CONFIG_ROCKCHIP_SFC=y +CONFIG_ROCKCHIP_SPI=y +CONFIG_SYSRESET=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_OHCI_HCD=y +CONFIG_USB_OHCI_GENERIC=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y +CONFIG_USB_GADGET=y +CONFIG_ERRNO_STR=y diff --git a/doc/board/coolpi/genbook_cm5_rk3588.rst b/doc/board/coolpi/genbook_cm5_rk3588.rst new file mode 100644 index 00000000000..b0ddc786314 --- /dev/null +++ b/doc/board/coolpi/genbook_cm5_rk3588.rst @@ -0,0 +1,68 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +GenBook +===================== +Cool Pi GenBook is a laptop powered by RK3588, it works with a +carrier board connect with CM5. + +Specification: +* Rockchip RK3588 +* LPDDR5X 8/32 GB +* eMMC 64 GB +* SPI Nor 8 MB +* HDMI Type A out x 1 +* USB 3.0 Host x 1 +* USB-C 3.0 with DisplayPort AltMode +* PCIE M.2 E Key for RTL8852BE Wireless connection +* PCIE M.2 M Key for NVME connection +* eDP panel with 1920x1080 + +Here is the step-by-step to compile and boot to U-Boot on GenBook. + +Get the TF-A and DDR init (TPL) binaries +---------------------------------------- + +.. prompt:: bash + + > cd u-boot + > export ROCKCHIP_TPL=../rkbin/bin/rk35/rk3588_ddr_lp4_2112MHz_lp5_2400MHz_v1.17.bin + > export BL31=../rkbin/bin/rk35/rk3588_bl31_v1.46.elf + > make coolpi-genbook-cm5-rk3588_defconfig + > make CROSS_COMPILE=aarch64-linux-gnu- + +This will build ``u-boot-rockchip.bin`` for eMMC and ``u-boot-rockchip-spi.bin`` for SPI Nor. + +Write u-boot to eMMC or SPI Nor from a Linux system on the laptop +--------------- + +Copy ``u-boot-rockchip.bin`` and ``u-boot-rockchip-spi.bin`` to the laptop. + +eMMC +~~~~~~~ + +.. prompt:: bash + + dd if=u-boot-rockchip.bin of=/dev/mmcblk0 bs=512 seek=64 + +SPI Nor +~~~~ + +.. prompt:: bash + + dd if=u-boot-rockchip-spi.bin of=/dev/mtdblock0 + +``upgrade_tool`` allows to flash the on-board SPI Nor via the USB TypeC interface +with help of the Rockchip loader binary. + +To enter the USB flashing mode, connect the laptop and your HOST PC with a USB-C +cable, reset the laptop with ``Loader Key`` pressed. +On your PC, check with ``lsusb -d 2207:350b``). + +To flash U-Boot on the SPI Nor with ``upgrade_tool``: + +.. prompt:: bash + + upgrade_tool db rk3588/MiniLoaderAll.bin + upgrade_tool ssd // Input 5 for SPINOR download mode + upgrade_tool wl 0 u-boot-rockchip-spi.bin + upgrade_tool rd diff --git a/doc/board/coolpi/index.rst b/doc/board/coolpi/index.rst new file mode 100644 index 00000000000..9c9593fd6aa --- /dev/null +++ b/doc/board/coolpi/index.rst @@ -0,0 +1,9 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +Cool Pi +================= + +.. toctree:: + :maxdepth: 2 + + genbook_cm5_rk3588 diff --git a/doc/board/rockchip/rockchip.rst b/doc/board/rockchip/rockchip.rst index 86d83befb5b..2d6593cba75 100644 --- a/doc/board/rockchip/rockchip.rst +++ b/doc/board/rockchip/rockchip.rst @@ -145,6 +145,7 @@ List of mainline supported Rockchip boards: - Xunlong Orange Pi 5 Plus (orangepi-5-plus-rk3588) - Yanyi Tech CoolPi 4 Model B (coolpi-4b-rk3588s) - Yanyi Tech CoolPi CM5 EVB (coolpi-cm5-evb-rk3588) + - Yanyi Tech CoolPi CM5 GenBook (coolpi-cm5-genbook-rk3588)
* rv1108 - Rockchip Evb-rv1108 (evb-rv1108) diff --git a/include/configs/genbook-cm5-rk3588.h b/include/configs/genbook-cm5-rk3588.h new file mode 100644 index 00000000000..f71f735b113 --- /dev/null +++ b/include/configs/genbook-cm5-rk3588.h @@ -0,0 +1,31 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + */ + +#ifndef __GENBOOK_CM5_RK3588_H +#define __GENBOOK_CM5_RK3588_H + +#define ROCKCHIP_DEVICE_SETTINGS \ + "stdout=serial,vidconsole\0" \ + "stderr=serial,vidconsole\0" + +#include <configs/rk3588_common.h> + +#undef BOOT_TARGETS +#define BOOT_TARGETS "usb mmc0" + +#undef CFG_EXTRA_ENV_SETTINGS + +/* + * As a laptop, there is no sdmmc, and we want to + * set usb the highest boot priority for third-part + * os installation. + */ +#define CFG_EXTRA_ENV_SETTINGS \ + "fdtfile=" CONFIG_DEFAULT_FDT_FILE "\0" \ + "partitions=" PARTS_DEFAULT \ + ENV_MEM_LAYOUT_SETTINGS \ + ROCKCHIP_DEVICE_SETTINGS \ + "boot_targets=" BOOT_TARGETS "\0" + +#endif /* __GENBOOK_CM5_RK3588_H */
Specification:
- Rockchip RK3588
- LPDDR5X 8/32 GB
- eMMC 64 GB
- USB 3.0 Host x 1
Thanks, - Kever
Changes in v3:
- Enable LED config
- Enable rk8xx pmic
Changes in v2:
+&fspim2_pins {
- bootph-pre-ram;
- bootph-some-ram;
+&sfc {
- flash@0 {
bootph-pre-ram;
bootph-some-ram;
- snps,dis_u3_susphy_quirk;
- bool "Cool Pi CM5 GenBook"
- select BOARD_LATE_INIT
- help
Specification:
- Rockchip RK3588
- LPDDR5X 8/32 GB
- eMMC 64 GB
- USB 3.0 Host x 1
- config TARGET_JAGUAR_RK3588 bool "Theobroma Systems SBC-RK3588-AMR (Jaguar)" select BOARD_LATE_INIT
+config SYS_BOARD
- default "genbook_cm5_rk3588"
+config SYS_VENDOR
- default "coolpi"
- default "genbook-cm5-rk3588"
+.. prompt:: bash
cd u-boot export ROCKCHIP_TPL=../rkbin/bin/rk35/rk3588_ddr_lp4_2112MHz_lp5_2400MHz_v1.17.bin export BL31=../rkbin/bin/rk35/rk3588_bl31_v1.46.elf make coolpi-genbook-cm5-rk3588_defconfig make CROSS_COMPILE=aarch64-linux-gnu-+This will build ``u-boot-rockchip.bin`` for eMMC and ``u-boot-rockchip-spi.bin`` for SPI Nor.
+eMMC +~~~~~~~
+.. prompt:: bash
- dd if=u-boot-rockchip.bin of=/dev/mmcblk0 bs=512 seek=64
+SPI Nor +~~~~
+.. prompt:: bash
- dd if=u-boot-rockchip-spi.bin of=/dev/mtdblock0
+.. prompt:: bash
- upgrade_tool db rk3588/MiniLoaderAll.bin
- upgrade_tool ssd // Input 5 for SPINOR download mode
- upgrade_tool wl 0 u-boot-rockchip-spi.bin
- upgrade_tool rd
+.. toctree::
- :maxdepth: 2
- genbook_cm5_rk3588
- rv1108
- As a laptop, there is no sdmmc, and we want to
- set usb the highest boot priority for third-part
- os installation.
- "fdtfile=" CONFIG_DEFAULT_FDT_FILE "\0" \
- "partitions=" PARTS_DEFAULT \
- ENV_MEM_LAYOUT_SETTINGS \
- ROCKCHIP_DEVICE_SETTINGS \
- "boot_targets=" BOOT_TARGETS "\0"
Hi Andy,
Specification:
- Rockchip RK3588
- LPDDR5X 8/32 GB
- eMMC 64 GB
- USB 3.0 Host x 1
Changes in v3:
- Enable LED config
- Enable rk8xx pmic
Changes in v2:
Error report from ci:
https://source.denx.de/u-boot/custodians/u-boot-rockchip/-/jobs/936455
Warning, treated as error: /builds/u-boot/custodians/u-boot-rockchip/doc/board/coolpi/genbook_cm5_rk3588.rst:36:Title underline too short. Write u-boot to eMMC or SPI Nor from a Linux system on the laptop --------------- make[1]: *** [doc/Makefile:70: htmldocs] Error 2 make: *** [Makefile:2445: htmldocs] Error 2
Thanks,
- Kever
+&fspim2_pins {
- bootph-pre-ram;
- bootph-some-ram;
+&sfc {
- flash@0 {
bootph-pre-ram;
bootph-some-ram;
- help
Specification:
- Rockchip RK3588
- LPDDR5X 8/32 GB
- eMMC 64 GB
- USB 3.0 Host x 1
+config SYS_BOARD
+config SYS_VENDOR
- default "coolpi"
+.. prompt:: bash
+eMMC +~~~~~~~
+.. prompt:: bash
+SPI Nor +~~~~
+.. prompt:: bash
+.. prompt:: bash
- upgrade_tool rd
+.. toctree::
- :maxdepth: 2
- rv1108
- os installation.
Andy Yan
Kever Yang
