[U-Boot] [PATCH 2/2] ARM: OMAP4/5: Remove dead code against CONFIG_SYS_ENABLE_PADS_ALL
The commit f3f98bb0 : "ARM: OMAP4/5: Do not configure non essential pads, clocks, dplls" removed the config option aimed towards moving that stuff into kernel, which renders some code unreachable. Remove that code.
Signed-off-by: Jassi Brar jaswinder.singh@linaro.org --- arch/arm/cpu/armv7/omap-common/hwinit-common.c | 6 - arch/arm/include/asm/arch-omap4/sys_proto.h | 1 - arch/arm/include/asm/arch-omap5/sys_proto.h | 1 - board/ti/omap5_evm/evm.c | 11 - board/ti/omap5_evm/mux_data.h | 234 ------------------------ board/ti/panda/panda.c | 28 --- board/ti/panda/panda_mux_data.h | 186 ------------------- board/ti/sdp4430/sdp.c | 18 -- board/ti/sdp4430/sdp4430_mux_data.h | 197 -------------------- 9 files changed, 0 insertions(+), 682 deletions(-)
diff --git a/arch/arm/cpu/armv7/omap-common/hwinit-common.c b/arch/arm/cpu/armv7/omap-common/hwinit-common.c index 459ebb5..077fc27 100644 --- a/arch/arm/cpu/armv7/omap-common/hwinit-common.c +++ b/arch/arm/cpu/armv7/omap-common/hwinit-common.c @@ -51,16 +51,10 @@ static void set_mux_conf_regs(void) set_muxconf_regs_essential(); break; case OMAP_INIT_CONTEXT_UBOOT_AFTER_SPL: -#ifdef CONFIG_SYS_ENABLE_PADS_ALL - set_muxconf_regs_non_essential(); -#endif break; case OMAP_INIT_CONTEXT_UBOOT_FROM_NOR: case OMAP_INIT_CONTEXT_UBOOT_AFTER_CH: set_muxconf_regs_essential(); -#ifdef CONFIG_SYS_ENABLE_PADS_ALL - set_muxconf_regs_non_essential(); -#endif break; } } diff --git a/arch/arm/include/asm/arch-omap4/sys_proto.h b/arch/arm/include/asm/arch-omap4/sys_proto.h index d633573..90befa1 100644 --- a/arch/arm/include/asm/arch-omap4/sys_proto.h +++ b/arch/arm/include/asm/arch-omap4/sys_proto.h @@ -37,7 +37,6 @@ void watchdog_init(void); u32 get_device_type(void); void do_set_mux(u32 base, struct pad_conf_entry const *array, int size); void set_muxconf_regs_essential(void); -void set_muxconf_regs_non_essential(void); void sr32(void *, u32, u32, u32); u32 wait_on_value(u32, u32, void *, u32); void sdelay(unsigned long); diff --git a/arch/arm/include/asm/arch-omap5/sys_proto.h b/arch/arm/include/asm/arch-omap5/sys_proto.h index 74feb90..9a49393 100644 --- a/arch/arm/include/asm/arch-omap5/sys_proto.h +++ b/arch/arm/include/asm/arch-omap5/sys_proto.h @@ -38,7 +38,6 @@ void watchdog_init(void); u32 get_device_type(void); void do_set_mux(u32 base, struct pad_conf_entry const *array, int size); void set_muxconf_regs_essential(void); -void set_muxconf_regs_non_essential(void); void sr32(void *, u32, u32, u32); u32 wait_on_value(u32, u32, void *, u32); void sdelay(unsigned long); diff --git a/board/ti/omap5_evm/evm.c b/board/ti/omap5_evm/evm.c index c8dfdf8..4b61819 100644 --- a/board/ti/omap5_evm/evm.c +++ b/board/ti/omap5_evm/evm.c @@ -80,17 +80,6 @@ void set_muxconf_regs_essential(void) sizeof(struct pad_conf_entry)); }
-void set_muxconf_regs_non_essential(void) -{ - do_set_mux(CONTROL_PADCONF_CORE, core_padconf_array_non_essential, - sizeof(core_padconf_array_non_essential) / - sizeof(struct pad_conf_entry)); - - do_set_mux(CONTROL_PADCONF_WKUP, wkup_padconf_array_non_essential, - sizeof(wkup_padconf_array_non_essential) / - sizeof(struct pad_conf_entry)); -} - #if !defined(CONFIG_SPL_BUILD) && defined(CONFIG_GENERIC_MMC) int board_mmc_init(bd_t *bis) { diff --git a/board/ti/omap5_evm/mux_data.h b/board/ti/omap5_evm/mux_data.h index a82795d..c5af6cd 100644 --- a/board/ti/omap5_evm/mux_data.h +++ b/board/ti/omap5_evm/mux_data.h @@ -67,238 +67,4 @@ const struct pad_conf_entry wkup_padconf_array_essential[] = {
-const struct pad_conf_entry core_padconf_array_non_essential[] = { - - {C2C_DATAIN0, (IEN | M0)}, /* C2C_DATAIN0 */ - {C2C_DATAIN1, (IEN | M0)}, /* C2C_DATAIN1 */ - {C2C_DATAIN2, (IEN | M0)}, /* C2C_DATAIN2 */ - {C2C_DATAIN3, (IEN | M0)}, /* C2C_DATAIN3 */ - {C2C_DATAIN4, (IEN | M0)}, /* C2C_DATAIN4 */ - {C2C_DATAIN5, (IEN | M0)}, /* C2C_DATAIN5 */ - {C2C_DATAIN6, (IEN | M0)}, /* C2C_DATAIN6 */ - {C2C_DATAIN7, (IEN | M0)}, /* C2C_DATAIN7 */ - {C2C_CLKIN1, (IEN | M0)}, /* C2C_CLKIN1 */ - {C2C_CLKIN0, (IEN | M0)}, /* C2C_CLKIN0 */ - {C2C_CLKOUT0, (M0)}, /* C2C_CLKOUT0 */ - {C2C_CLKOUT1, (M0)}, /* C2C_CLKOUT1 */ - {C2C_DATAOUT0, (M0)}, /* C2C_DATAOUT0 */ - {C2C_DATAOUT1, (M0)}, /* C2C_DATAOUT1 */ - {C2C_DATAOUT2, (M0)}, /* C2C_DATAOUT2 */ - {C2C_DATAOUT3, (M0)}, /* C2C_DATAOUT3 */ - {C2C_DATAOUT4, (M0)}, /* C2C_DATAOUT4 */ - {C2C_DATAOUT5, (M0)}, /* C2C_DATAOUT5 */ - {C2C_DATAOUT6, (M0)}, /* C2C_DATAOUT6 */ - {C2C_DATAOUT7, (M0)}, /* C2C_DATAOUT7 */ - {C2C_DATA8, (IEN | M0)}, /* C2C_DATA8 */ - {C2C_DATA9, (IEN | M0)}, /* C2C_DATA9 */ - {C2C_DATA10, (IEN | M0)}, /* C2C_DATA10 */ - {C2C_DATA11, (IEN | M0)}, /* C2C_DATA11 */ - {C2C_DATA12, (IEN | M0)}, /* C2C_DATA12 */ - {C2C_DATA13, (IEN | M0)}, /* C2C_DATA13 */ - {C2C_DATA14, (IEN | M0)}, /* C2C_DATA14 */ - {C2C_DATA15, (IEN | M0)}, /* C2C_DATA15 */ - {LLIB_WAKEREQOUT, (PTU | IEN | M6)}, /* GPIO2_32 */ - {LLIA_WAKEREQOUT, (M1)}, /* C2C_WAKEREQOUT */ - {HSI1_ACREADY, (PTD | M6)}, /* GPIO3_64 */ - {HSI1_CAREADY, (PTD | M6)}, /* GPIO3_65 */ - {HSI1_ACWAKE, (PTD | IEN | M6)}, /* GPIO3_66 */ - {HSI1_CAWAKE, (PTU | IEN | M6)}, /* GPIO3_67 */ - {HSI1_ACFLAG, (PTD | IEN | M6)}, /* GPIO3_68 */ - {HSI1_ACDATA, (PTD | M6)}, /* GPIO3_69 */ - {HSI1_CAFLAG, (M6)}, /* GPIO3_70 */ - {HSI1_CADATA, (M6)}, /* GPIO3_71 */ - {UART1_TX, (M0)}, /* UART1_TX */ - {UART1_CTS, (PTU | IEN | M0)}, /* UART1_CTS */ - {UART1_RX, (PTU | IEN | M0)}, /* UART1_RX */ - {UART1_RTS, (M0)}, /* UART1_RTS */ - {HSI2_CAREADY, (IEN | M0)}, /* HSI2_CAREADY */ - {HSI2_ACREADY, (OFF_EN | M0)}, /* HSI2_ACREADY */ - {HSI2_CAWAKE, (IEN | PTD | M0)}, /* HSI2_CAWAKE */ - {HSI2_ACWAKE, (M0)}, /* HSI2_ACWAKE */ - {HSI2_CAFLAG, (IEN | PTD | M0)}, /* HSI2_CAFLAG */ - {HSI2_CADATA, (IEN | PTD | M0)}, /* HSI2_CADATA */ - {HSI2_ACFLAG, (M0)}, /* HSI2_ACFLAG */ - {HSI2_ACDATA, (M0)}, /* HSI2_ACDATA */ - {UART2_RTS, (IEN | M1)}, /* MCSPI3_SOMI */ - {UART2_CTS, (IEN | M1)}, /* MCSPI3_CS0 */ - {UART2_RX, (IEN | M1)}, /* MCSPI3_SIMO */ - {UART2_TX, (IEN | M1)}, /* MCSPI3_CLK */ - {TIMER10_PWM_EVT, (IEN | M0)}, /* TIMER10_PWM_EVT */ - {DSIPORTA_TE0, (IEN | M0)}, /* DSIPORTA_TE0 */ - {DSIPORTA_LANE0X, (IEN | M0)}, /* DSIPORTA_LANE0X */ - {DSIPORTA_LANE0Y, (IEN | M0)}, /* DSIPORTA_LANE0Y */ - {DSIPORTA_LANE1X, (IEN | M0)}, /* DSIPORTA_LANE1X */ - {DSIPORTA_LANE1Y, (IEN | M0)}, /* DSIPORTA_LANE1Y */ - {DSIPORTA_LANE2X, (IEN | M0)}, /* DSIPORTA_LANE2X */ - {DSIPORTA_LANE2Y, (IEN | M0)}, /* DSIPORTA_LANE2Y */ - {DSIPORTA_LANE3X, (IEN | M0)}, /* DSIPORTA_LANE3X */ - {DSIPORTA_LANE3Y, (IEN | M0)}, /* DSIPORTA_LANE3Y */ - {DSIPORTA_LANE4X, (IEN | M0)}, /* DSIPORTA_LANE4X */ - {DSIPORTA_LANE4Y, (IEN | M0)}, /* DSIPORTA_LANE4Y */ - {TIMER9_PWM_EVT, (IEN | M0)}, /* TIMER9_PWM_EVT */ - {DSIPORTC_TE0, (IEN | M0)}, /* DSIPORTC_TE0 */ - {DSIPORTC_LANE0X, (IEN | M0)}, /* DSIPORTC_LANE0X */ - {DSIPORTC_LANE0Y, (IEN | M0)}, /* DSIPORTC_LANE0Y */ - {DSIPORTC_LANE1X, (IEN | M0)}, /* DSIPORTC_LANE1X */ - {DSIPORTC_LANE1Y, (IEN | M0)}, /* DSIPORTC_LANE1Y */ - {DSIPORTC_LANE2X, (IEN | M0)}, /* DSIPORTC_LANE2X */ - {DSIPORTC_LANE2Y, (IEN | M0)}, /* DSIPORTC_LANE2Y */ - {DSIPORTC_LANE3X, (IEN | M0)}, /* DSIPORTC_LANE3X */ - {DSIPORTC_LANE3Y, (IEN | M0)}, /* DSIPORTC_LANE3Y */ - {DSIPORTC_LANE4X, (IEN | M0)}, /* DSIPORTC_LANE4X */ - {DSIPORTC_LANE4Y, (IEN | M0)}, /* DSIPORTC_LANE4Y */ - {RFBI_HSYNC0, (M4)}, /* KBD_COL5 */ - {RFBI_TE_VSYNC0, (PTD | M6)}, /* GPIO6_161 */ - {RFBI_RE, (M4)}, /* KBD_COL4 */ - {RFBI_A0, (PTD | IEN | M6)}, /* GPIO6_165 */ - {RFBI_DATA8, (M4)}, /* KBD_COL3 */ - {RFBI_DATA9, (PTD | M6)}, /* GPIO6_175 */ - {RFBI_DATA10, (PTD | M6)}, /* GPIO6_176 */ - {RFBI_DATA11, (PTD | M6)}, /* GPIO6_177 */ - {RFBI_DATA12, (PTD | M6)}, /* GPIO6_178 */ - {RFBI_DATA13, (PTU | IEN | M6)}, /* GPIO6_179 */ - {RFBI_DATA14, (M4)}, /* KBD_COL7 */ - {RFBI_DATA15, (M4)}, /* KBD_COL6 */ - {GPIO6_182, (M6)}, /* GPIO6_182 */ - {GPIO6_183, (PTD | M6)}, /* GPIO6_183 */ - {GPIO6_184, (M4)}, /* KBD_COL2 */ - {GPIO6_185, (PTD | IEN | M6)}, /* GPIO6_185 */ - {GPIO6_186, (PTD | M6)}, /* GPIO6_186 */ - {GPIO6_187, (PTU | IEN | M4)}, /* KBD_ROW2 */ - {RFBI_DATA0, (PTD | M6)}, /* GPIO6_166 */ - {RFBI_DATA1, (PTD | M6)}, /* GPIO6_167 */ - {RFBI_DATA2, (PTD | M6)}, /* GPIO6_168 */ - {RFBI_DATA3, (PTD | IEN | M6)}, /* GPIO6_169 */ - {RFBI_DATA4, (IEN | M6)}, /* GPIO6_170 */ - {RFBI_DATA5, (IEN | M6)}, /* GPIO6_171 */ - {RFBI_DATA6, (PTD | M6)}, /* GPIO6_172 */ - {RFBI_DATA7, (PTD | M6)}, /* GPIO6_173 */ - {RFBI_CS0, (PTD | IEN | M6)}, /* GPIO6_163 */ - {RFBI_WE, (PTD | M6)}, /* GPIO6_162 */ - {MCSPI2_CS0, (M0)}, /* MCSPI2_CS0 */ - {MCSPI2_CLK, (IEN | M0)}, /* MCSPI2_CLK */ - {MCSPI2_SIMO, (IEN | M0)}, /* MCSPI2_SIMO*/ - {MCSPI2_SOMI, (PTU | IEN | M0)}, /* MCSPI2_SOMI*/ - {I2C4_SCL, (IEN | M0)}, /* I2C4_SCL */ - {I2C4_SDA, (IEN | M0)}, /* I2C4_SDA */ - {HDMI_CEC, (IEN | M0)}, /* HDMI_CEC */ - {HDMI_HPD, (PTD | IEN | M0)}, /* HDMI_HPD */ - {HDMI_DDC_SCL, (IEN | M0)}, /* HDMI_DDC_SCL */ - {HDMI_DDC_SDA, (IEN | M0)}, /* HDMI_DDC_SDA */ - {CSIPORTA_LANE0X, (IEN | M0)}, /* CSIPORTA_LANE0X */ - {CSIPORTA_LANE0Y, (IEN | M0)}, /* CSIPORTA_LANE0Y */ - {CSIPORTA_LANE1Y, (IEN | M0)}, /* CSIPORTA_LANE1Y */ - {CSIPORTA_LANE1X, (IEN | M0)}, /* CSIPORTA_LANE1X */ - {CSIPORTA_LANE2Y, (IEN | M0)}, /* CSIPORTA_LANE2Y */ - {CSIPORTA_LANE2X, (IEN | M0)}, /* CSIPORTA_LANE2X */ - {CSIPORTA_LANE3X, (IEN | M0)}, /* CSIPORTA_LANE3X */ - {CSIPORTA_LANE3Y, (IEN | M0)}, /* CSIPORTA_LANE3Y */ - {CSIPORTA_LANE4X, (IEN | M0)}, /* CSIPORTA_LANE4X */ - {CSIPORTA_LANE4Y, (IEN | M0)}, /* CSIPORTA_LANE4Y */ - {CSIPORTB_LANE0X, (IEN | M0)}, /* CSIPORTB_LANE0X */ - {CSIPORTB_LANE0Y, (IEN | M0)}, /* CSIPORTB_LANE0Y */ - {CSIPORTB_LANE1Y, (IEN | M0)}, /* CSIPORTB_LANE1Y */ - {CSIPORTB_LANE1X, (IEN | M0)}, /* CSIPORTB_LANE1X */ - {CSIPORTB_LANE2Y, (IEN | M0)}, /* CSIPORTB_LANE2Y */ - {CSIPORTB_LANE2X, (IEN | M0)}, /* CSIPORTB_LANE2X */ - {CSIPORTC_LANE0Y, (IEN | M0)}, /* CSIPORTC_LANE0Y */ - {CSIPORTC_LANE0X, (IEN | M0)}, /* CSIPORTC_LANE0X */ - {CSIPORTC_LANE1Y, (IEN | M0)}, /* CSIPORTC_LANE1Y */ - {CSIPORTC_LANE1X, (IEN | M0)}, /* CSIPORTC_LANE1X */ - {CAM_SHUTTER, (M0)}, /* CAM_SHUTTER */ - {CAM_STROBE, (M0)}, /* CAM_STROBE */ - {CAM_GLOBALRESET, (IEN | M0)}, /* CAM_GLOBALRESET */ - {TIMER11_PWM_EVT, (PTD | M6)}, /* GPIO8_227 */ - {TIMER5_PWM_EVT, (PTD | M6)}, /* GPIO8_228 */ - {TIMER6_PWM_EVT, (PTD | M6)}, /* GPIO8_229 */ - {TIMER8_PWM_EVT, (PTU | M6)}, /* GPIO8_230 */ - {I2C3_SCL, (IEN | M0)}, /* I2C3_SCL */ - {I2C3_SDA, (IEN | M0)}, /* I2C3_SDA */ - {GPIO8_233, (IEN | M2)}, /* TIMER8_PWM_EVT */ - {ABE_CLKS, (IEN | M0)}, /* ABE_CLKS */ - {ABEDMIC_DIN1, (IEN | M0)}, /* ABEDMIC_DIN1 */ - {ABEDMIC_DIN2, (IEN | M0)}, /* ABEDMIC_DIN2 */ - {ABEDMIC_DIN3, (IEN | M0)}, /* ABEDMIC_DIN3 */ - {ABEDMIC_CLK1, (M0)}, /* ABEDMIC_CLK1 */ - {ABEDMIC_CLK2, (IEN | M1)}, /* ABEMCBSP1_FSX */ - {ABEDMIC_CLK3, (M1)}, /* ABEMCBSP1_DX */ - {ABESLIMBUS1_CLOCK, (IEN | M1)}, /* ABEMCBSP1_CLKX */ - {ABESLIMBUS1_DATA, (IEN | M1)}, /* ABEMCBSP1_DR */ - {ABEMCBSP2_DR, (IEN | M0)}, /* ABEMCBSP2_DR */ - {ABEMCBSP2_DX, (M0)}, /* ABEMCBSP2_DX */ - {ABEMCBSP2_FSX, (IEN | M0)}, /* ABEMCBSP2_FSX */ - {ABEMCBSP2_CLKX, (IEN | M0)}, /* ABEMCBSP2_CLKX */ - {ABEMCPDM_UL_DATA, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* ABEMCPDM_UL_DATA */ - {ABEMCPDM_DL_DATA, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* ABEMCPDM_DL_DATA */ - {ABEMCPDM_FRAME, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* ABEMCPDM_FRAME */ - {ABEMCPDM_LB_CLK, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* ABEMCPDM_LB_CLK */ - {WLSDIO_CLK, (PTU | IEN | M0)}, /* WLSDIO_CLK */ - {WLSDIO_CMD, (PTU | IEN | M0)}, /* WLSDIO_CMD */ - {WLSDIO_DATA0, (PTU | IEN | M0)}, /* WLSDIO_DATA0*/ - {WLSDIO_DATA1, (PTU | IEN | M0)}, /* WLSDIO_DATA1*/ - {WLSDIO_DATA2, (PTU | IEN | M0)}, /* WLSDIO_DATA2*/ - {WLSDIO_DATA3, (PTU | IEN | M0)}, /* WLSDIO_DATA3*/ - {UART5_RX, (PTU | IEN | M0)}, /* UART5_RX */ - {UART5_TX, (M0)}, /* UART5_TX */ - {UART5_CTS, (PTU | IEN | M0)}, /* UART5_CTS */ - {UART5_RTS, (M0)}, /* UART5_RTS */ - {I2C2_SCL, (IEN | M0)}, /* I2C2_SCL */ - {I2C2_SDA, (IEN | M0)}, /* I2C2_SDA */ - {MCSPI1_CLK, (M6)}, /* GPIO5_140 */ - {MCSPI1_SOMI, (IEN | M6)}, /* GPIO5_141 */ - {MCSPI1_SIMO, (PTD | M6)}, /* GPIO5_142 */ - {MCSPI1_CS0, (PTD | M6)}, /* GPIO5_143 */ - {MCSPI1_CS1, (PTD | IEN | M6)}, /* GPIO5_144 */ - {I2C5_SCL, (IEN | M0)}, /* I2C5_SCL */ - {I2C5_SDA, (IEN | M0)}, /* I2C5_SDA */ - {PERSLIMBUS2_CLOCK, (PTD | M6)}, /* GPIO5_145 */ - {PERSLIMBUS2_DATA, (PTD | IEN | M6)}, /* GPIO5_146 */ - {UART6_TX, (PTU | IEN | M6)}, /* GPIO5_149 */ - {UART6_RX, (PTU | IEN | M6)}, /* GPIO5_150 */ - {UART6_CTS, (PTU | IEN | M6)}, /* GPIO5_151 */ - {UART6_RTS, (PTU | M0)}, /* UART6_RTS */ - {UART3_CTS_RCTX, (PTU | IEN | M6)}, /* GPIO5_153 */ - {UART3_RTS_IRSD, (PTU | IEN | M1)}, /* HDQ_SIO */ - {I2C1_PMIC_SCL, (PTU | IEN | M0)}, /* I2C1_PMIC_SCL */ - {I2C1_PMIC_SDA, (PTU | IEN | M0)}, /* I2C1_PMIC_SDA */ - -}; - -const struct pad_conf_entry wkup_padconf_array_non_essential[] = { - -/* - * This pad keeps C2C Module always enabled. - * Putting this in safe mode do not cause the issue. - * C2C driver could enable this mux setting if needed. - */ - {LLIA_WAKEREQIN, (M7)}, /* SAFE MODE */ - {LLIB_WAKEREQIN, (M7)}, /* SAFE MODE */ - {DRM_EMU0, (PTU | IEN | M0)}, /* DRM_EMU0 */ - {DRM_EMU1, (PTU | IEN | M0)}, /* DRM_EMU1 */ - {JTAG_NTRST, (IEN | M0)}, /* JTAG_NTRST */ - {JTAG_TCK, (IEN | M0)}, /* JTAG_TCK */ - {JTAG_RTCK, (M0)}, /* JTAG_RTCK */ - {JTAG_TMSC, (IEN | M0)}, /* JTAG_TMSC */ - {JTAG_TDI, (IEN | M0)}, /* JTAG_TDI */ - {JTAG_TDO, (M0)}, /* JTAG_TDO */ - {FREF_CLK_IOREQ, (IEN | M0)}, /* FREF_CLK_IOREQ */ - {FREF_CLK0_OUT, (M0)}, /* FREF_CLK0_OUT */ - {FREF_CLK1_OUT, (M0)}, /* FREF_CLK1_OUT */ - {FREF_CLK2_OUT, (M0)}, /* FREF_CLK2_OUT */ - {FREF_CLK2_REQ, (PTU | IEN | M6)}, /* GPIO1_WK9 */ - {FREF_CLK1_REQ, (PTD | IEN | M6)}, /* GPIO1_WK8 */ - {SYS_NRESPWRON, (IEN | M0)}, /* SYS_NRESPWRON */ - {SYS_NRESWARM, (PTU | IEN | M0)}, /* SYS_NRESWARM */ - {SYS_PWR_REQ, (M0)}, /* SYS_PWR_REQ */ - {SYS_NIRQ1, (PTU | IEN | M0)}, /* SYS_NIRQ1 */ - {SYS_NIRQ2, (PTU | IEN | M0)}, /* SYS_NIRQ2 */ - {SYS_BOOT0, (IEN | M0)}, /* SYS_BOOT0 */ - {SYS_BOOT1, (IEN | M0)}, /* SYS_BOOT1 */ - {SYS_BOOT2, (IEN | M0)}, /* SYS_BOOT2 */ - {SYS_BOOT3, (IEN | M0)}, /* SYS_BOOT3 */ - {SYS_BOOT4, (IEN | M0)}, /* SYS_BOOT4 */ - {SYS_BOOT5, (IEN | M0)}, /* SYS_BOOT5 */ - -}; - #endif /* _EVM4430_MUX_DATA_H */ diff --git a/board/ti/panda/panda.c b/board/ti/panda/panda.c index ee82771..25cbc7c 100644 --- a/board/ti/panda/panda.c +++ b/board/ti/panda/panda.c @@ -148,34 +148,6 @@ void set_muxconf_regs_essential(void) sizeof(struct pad_conf_entry)); }
-void set_muxconf_regs_non_essential(void) -{ - do_set_mux(CONTROL_PADCONF_CORE, core_padconf_array_non_essential, - sizeof(core_padconf_array_non_essential) / - sizeof(struct pad_conf_entry)); - - if (omap_revision() < OMAP4460_ES1_0) - do_set_mux(CONTROL_PADCONF_CORE, - core_padconf_array_non_essential_4430, - sizeof(core_padconf_array_non_essential_4430) / - sizeof(struct pad_conf_entry)); - else - do_set_mux(CONTROL_PADCONF_CORE, - core_padconf_array_non_essential_4460, - sizeof(core_padconf_array_non_essential_4460) / - sizeof(struct pad_conf_entry)); - - do_set_mux(CONTROL_PADCONF_WKUP, wkup_padconf_array_non_essential, - sizeof(wkup_padconf_array_non_essential) / - sizeof(struct pad_conf_entry)); - - if (omap_revision() < OMAP4460_ES1_0) - do_set_mux(CONTROL_PADCONF_WKUP, - wkup_padconf_array_non_essential_4430, - sizeof(wkup_padconf_array_non_essential_4430) / - sizeof(struct pad_conf_entry)); -} - #if !defined(CONFIG_SPL_BUILD) && defined(CONFIG_GENERIC_MMC) int board_mmc_init(bd_t *bis) { diff --git a/board/ti/panda/panda_mux_data.h b/board/ti/panda/panda_mux_data.h index 5939257..4300401 100644 --- a/board/ti/panda/panda_mux_data.h +++ b/board/ti/panda/panda_mux_data.h @@ -100,190 +100,4 @@ const struct pad_conf_entry wkup_padconf_array_essential_4460[] = {
-const struct pad_conf_entry core_padconf_array_non_essential[] = { - {GPMC_AD8, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M3)}, /* gpio_32 */ - {GPMC_AD9, (PTU | IEN | M3)}, /* gpio_33 */ - {GPMC_AD10, (PTU | IEN | M3)}, /* gpio_34 */ - {GPMC_AD11, (PTU | IEN | M3)}, /* gpio_35 */ - {GPMC_AD12, (PTU | IEN | M3)}, /* gpio_36 */ - {GPMC_AD13, (PTD | OFF_EN | OFF_PD | OFF_OUT_PTD | M3)}, /* gpio_37 */ - {GPMC_AD14, (PTD | OFF_EN | OFF_PD | OFF_OUT_PTD | M3)}, /* gpio_38 */ - {GPMC_AD15, (PTD | OFF_EN | OFF_PD | OFF_OUT_PTD | M3)}, /* gpio_39 */ - {GPMC_A16, (M3)}, /* gpio_40 */ - {GPMC_A17, (PTD | M3)}, /* gpio_41 */ - {GPMC_A18, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_row6 */ - {GPMC_A19, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_row7 */ - {GPMC_A20, (IEN | M3)}, /* gpio_44 */ - {GPMC_A21, (M3)}, /* gpio_45 */ - {GPMC_A22, (M3)}, /* gpio_46 */ - {GPMC_A23, (OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_col7 */ - {GPMC_A24, (PTD | M3)}, /* gpio_48 */ - {GPMC_A25, (PTD | M3)}, /* gpio_49 */ - {GPMC_NCS0, (M3)}, /* gpio_50 */ - {GPMC_NCS1, (IEN | M3)}, /* gpio_51 */ - {GPMC_NCS2, (IEN | M3)}, /* gpio_52 */ - {GPMC_NCS3, (IEN | M3)}, /* gpio_53 */ - {GPMC_NWP, (M3)}, /* gpio_54 */ - {GPMC_CLK, (PTD | M3)}, /* gpio_55 */ - {GPMC_NADV_ALE, (M3)}, /* gpio_56 */ - {GPMC_NBE0_CLE, (M3)}, /* gpio_59 */ - {GPMC_NBE1, (PTD | M3)}, /* gpio_60 */ - {GPMC_WAIT0, (PTU | IEN | M3)}, /* gpio_61 */ - {C2C_DATA11, (PTD | M3)}, /* gpio_100 */ - {C2C_DATA12, (PTU | IEN | M3)}, /* gpio_101 */ - {C2C_DATA13, (PTD | M3)}, /* gpio_102 */ - {C2C_DATA14, (M1)}, /* dsi2_te0 */ - {C2C_DATA15, (PTD | M3)}, /* gpio_104 */ - {HDMI_HPD, (M0)}, /* hdmi_hpd */ - {HDMI_CEC, (M0)}, /* hdmi_cec */ - {HDMI_DDC_SCL, (PTU | M0)}, /* hdmi_ddc_scl */ - {HDMI_DDC_SDA, (PTU | IEN | M0)}, /* hdmi_ddc_sda */ - {CSI21_DX0, (IEN | M0)}, /* csi21_dx0 */ - {CSI21_DY0, (IEN | M0)}, /* csi21_dy0 */ - {CSI21_DX1, (IEN | M0)}, /* csi21_dx1 */ - {CSI21_DY1, (IEN | M0)}, /* csi21_dy1 */ - {CSI21_DX2, (IEN | M0)}, /* csi21_dx2 */ - {CSI21_DY2, (IEN | M0)}, /* csi21_dy2 */ - {CSI21_DX3, (PTD | M7)}, /* csi21_dx3 */ - {CSI21_DY3, (PTD | M7)}, /* csi21_dy3 */ - {CSI21_DX4, (PTD | OFF_EN | OFF_PD | OFF_IN | M7)}, /* csi21_dx4 */ - {CSI21_DY4, (PTD | OFF_EN | OFF_PD | OFF_IN | M7)}, /* csi21_dy4 */ - {CSI22_DX0, (IEN | M0)}, /* csi22_dx0 */ - {CSI22_DY0, (IEN | M0)}, /* csi22_dy0 */ - {CSI22_DX1, (IEN | M0)}, /* csi22_dx1 */ - {CSI22_DY1, (IEN | M0)}, /* csi22_dy1 */ - {CAM_SHUTTER, (OFF_EN | OFF_PD | OFF_OUT_PTD | M0)}, /* cam_shutter */ - {CAM_STROBE, (OFF_EN | OFF_PD | OFF_OUT_PTD | M0)}, /* cam_strobe */ - {CAM_GLOBALRESET, (PTD | OFF_EN | OFF_PD | OFF_OUT_PTD | M3)}, /* gpio_83 */ - {ABE_MCBSP2_DR, (IEN | OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp2_dr */ - {ABE_MCBSP2_DX, (OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp2_dx */ - {ABE_MCBSP2_FSX, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_mcbsp2_fsx */ - {ABE_MCBSP1_CLKX, (IEN | M0)}, /* abe_mcbsp1_clkx */ - {ABE_MCBSP1_DR, (IEN | M0)}, /* abe_mcbsp1_dr */ - {ABE_MCBSP1_DX, (OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp1_dx */ - {ABE_MCBSP1_FSX, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_mcbsp1_fsx */ - {ABE_PDM_UL_DATA, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_pdm_ul_data */ - {ABE_PDM_DL_DATA, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_pdm_dl_data */ - {ABE_PDM_FRAME, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_pdm_frame */ - {ABE_PDM_LB_CLK, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_pdm_lb_clk */ - {ABE_CLKS, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_clks */ - {ABE_DMIC_CLK1, (M0)}, /* abe_dmic_clk1 */ - {ABE_DMIC_DIN1, (IEN | M0)}, /* abe_dmic_din1 */ - {ABE_DMIC_DIN2, (PTU | IEN | M3)}, /* gpio_121 */ - {ABE_DMIC_DIN3, (IEN | M0)}, /* abe_dmic_din3 */ - {UART2_CTS, (PTU | IEN | M7)}, /* uart2_cts */ - {UART2_RTS, (M7)}, /* uart2_rts */ - {UART2_RX, (PTU | IEN | M7)}, /* uart2_rx */ - {UART2_TX, (M7)}, /* uart2_tx */ - {HDQ_SIO, (M3)}, /* gpio_127 */ - {MCSPI1_CLK, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi1_clk */ - {MCSPI1_SOMI, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi1_somi */ - {MCSPI1_SIMO, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi1_simo */ - {MCSPI1_CS0, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi1_cs0 */ - {MCSPI1_CS1, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M3)}, /* mcspi1_cs1 */ - {MCSPI1_CS2, (PTU | OFF_EN | OFF_OUT_PTU | M3)}, /* gpio_139 */ - {MCSPI1_CS3, (PTU | IEN | M3)}, /* gpio_140 */ - {SDMMC5_CLK, (PTU | IEN | OFF_EN | OFF_OUT_PTD | M0)}, /* sdmmc5_clk */ - {SDMMC5_CMD, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc5_cmd */ - {SDMMC5_DAT0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc5_dat0 */ - {SDMMC5_DAT1, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc5_dat1 */ - {SDMMC5_DAT2, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc5_dat2 */ - {SDMMC5_DAT3, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc5_dat3 */ - {MCSPI4_CLK, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi4_clk */ - {MCSPI4_SIMO, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi4_simo */ - {MCSPI4_SOMI, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi4_somi */ - {MCSPI4_CS0, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi4_cs0 */ - {UART4_RX, (IEN | M0)}, /* uart4_rx */ - {UART4_TX, (M0)}, /* uart4_tx */ - {USBB2_ULPITLL_CLK, (IEN | M3)}, /* gpio_157 */ - {USBB2_ULPITLL_STP, (IEN | M5)}, /* dispc2_data23 */ - {USBB2_ULPITLL_DIR, (IEN | M5)}, /* dispc2_data22 */ - {USBB2_ULPITLL_NXT, (IEN | M5)}, /* dispc2_data21 */ - {USBB2_ULPITLL_DAT0, (IEN | M5)}, /* dispc2_data20 */ - {USBB2_ULPITLL_DAT1, (IEN | M5)}, /* dispc2_data19 */ - {USBB2_ULPITLL_DAT2, (IEN | M5)}, /* dispc2_data18 */ - {USBB2_ULPITLL_DAT3, (IEN | M5)}, /* dispc2_data15 */ - {USBB2_ULPITLL_DAT4, (IEN | M5)}, /* dispc2_data14 */ - {USBB2_ULPITLL_DAT5, (IEN | M5)}, /* dispc2_data13 */ - {USBB2_ULPITLL_DAT6, (IEN | M5)}, /* dispc2_data12 */ - {USBB2_ULPITLL_DAT7, (IEN | M5)}, /* dispc2_data11 */ - {USBB2_HSIC_DATA, (PTD | OFF_EN | OFF_OUT_PTU | M3)}, /* gpio_169 */ - {USBB2_HSIC_STROBE, (PTD | OFF_EN | OFF_OUT_PTU | M3)}, /* gpio_170 */ - {UNIPRO_TX0, (PTD | IEN | M3)}, /* gpio_171 */ - {UNIPRO_TY0, (OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_col1 */ - {UNIPRO_TX1, (OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_col2 */ - {UNIPRO_TY1, (OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_col3 */ - {UNIPRO_TX2, (PTU | IEN | M3)}, /* gpio_0 */ - {UNIPRO_RX0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_row0 */ - {UNIPRO_RY0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_row1 */ - {UNIPRO_RX1, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_row2 */ - {UNIPRO_RY1, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_row3 */ - {UNIPRO_RX2, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_row4 */ - {UNIPRO_RY2, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_row5 */ - {USBA0_OTG_CE, (PTD | OFF_EN | OFF_PD | OFF_OUT_PTD | M0)}, /* usba0_otg_ce */ - {USBA0_OTG_DP, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* usba0_otg_dp */ - {USBA0_OTG_DM, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* usba0_otg_dm */ - {FREF_CLK1_OUT, (M0)}, /* fref_clk1_out */ - {SYS_NIRQ1, (PTU | IEN | M0)}, /* sys_nirq1 */ - {SYS_NIRQ2, (PTU | IEN | M0)}, /* sys_nirq2 */ - {SYS_BOOT0, (PTU | IEN | M3)}, /* gpio_184 */ - {SYS_BOOT1, (M3)}, /* gpio_185 */ - {SYS_BOOT2, (PTD | IEN | M3)}, /* gpio_186 */ - {SYS_BOOT3, (M3)}, /* gpio_187 */ - {SYS_BOOT4, (M3)}, /* gpio_188 */ - {SYS_BOOT5, (PTD | IEN | M3)}, /* gpio_189 */ - {DPM_EMU0, (IEN | M0)}, /* dpm_emu0 */ - {DPM_EMU1, (IEN | M0)}, /* dpm_emu1 */ - {DPM_EMU2, (IEN | M0)}, /* dpm_emu2 */ - {DPM_EMU3, (IEN | M5)}, /* dispc2_data10 */ - {DPM_EMU4, (IEN | M5)}, /* dispc2_data9 */ - {DPM_EMU5, (IEN | M5)}, /* dispc2_data16 */ - {DPM_EMU6, (IEN | M5)}, /* dispc2_data17 */ - {DPM_EMU7, (IEN | M5)}, /* dispc2_hsync */ - {DPM_EMU8, (IEN | M5)}, /* dispc2_pclk */ - {DPM_EMU9, (IEN | M5)}, /* dispc2_vsync */ - {DPM_EMU10, (IEN | M5)}, /* dispc2_de */ - {DPM_EMU11, (IEN | M5)}, /* dispc2_data8 */ - {DPM_EMU12, (IEN | M5)}, /* dispc2_data7 */ - {DPM_EMU13, (IEN | M5)}, /* dispc2_data6 */ - {DPM_EMU14, (IEN | M5)}, /* dispc2_data5 */ - {DPM_EMU15, (IEN | M5)}, /* dispc2_data4 */ - {DPM_EMU16, (M3)}, /* gpio_27 */ - {DPM_EMU17, (IEN | M5)}, /* dispc2_data2 */ - {DPM_EMU18, (IEN | M5)}, /* dispc2_data1 */ - {DPM_EMU19, (IEN | M5)}, /* dispc2_data0 */ -}; - -const struct pad_conf_entry core_padconf_array_non_essential_4430[] = { - {ABE_MCBSP2_CLKX, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_mcbsp2_clkx */ -}; - -const struct pad_conf_entry core_padconf_array_non_essential_4460[] = { - {ABE_MCBSP2_CLKX, (PTU | OFF_EN | OFF_OUT_PTU | M3)}, /* led status_1 */ -}; - -const struct pad_conf_entry wkup_padconf_array_non_essential[] = { - {PAD0_SIM_IO, (IEN | M0)}, /* sim_io */ - {PAD1_SIM_CLK, (M0)}, /* sim_clk */ - {PAD0_SIM_RESET, (M0)}, /* sim_reset */ - {PAD1_SIM_CD, (PTU | IEN | M0)}, /* sim_cd */ - {PAD0_SIM_PWRCTRL, (M0)}, /* sim_pwrctrl */ - {PAD1_FREF_XTAL_IN, (M0)}, /* # */ - {PAD0_FREF_SLICER_IN, (M0)}, /* fref_slicer_in */ - {PAD1_FREF_CLK_IOREQ, (M0)}, /* fref_clk_ioreq */ - {PAD0_FREF_CLK0_OUT, (M2)}, /* sys_drm_msecure */ - {PAD1_FREF_CLK3_REQ, M7}, /* safe mode */ - {PAD0_FREF_CLK4_OUT, (PTU | M3)}, /* led status_2 */ - {PAD0_SYS_NRESPWRON, (M0)}, /* sys_nrespwron */ - {PAD1_SYS_NRESWARM, (M0)}, /* sys_nreswarm */ - {PAD0_SYS_PWR_REQ, (PTU | M0)}, /* sys_pwr_req */ - {PAD1_SYS_PWRON_RESET, (M3)}, /* gpio_wk29 */ - {PAD0_SYS_BOOT6, (IEN | M3)}, /* gpio_wk9 */ - {PAD1_SYS_BOOT7, (IEN | M3)}, /* gpio_wk10 */ -}; - -const struct pad_conf_entry wkup_padconf_array_non_essential_4430[] = { - {PAD1_FREF_CLK4_REQ, (PTU | M3)}, /* led status_1 */ -}; - #endif /* _PANDA_MUX_DATA_H_ */ diff --git a/board/ti/sdp4430/sdp.c b/board/ti/sdp4430/sdp.c index 982c771..4d31dac 100644 --- a/board/ti/sdp4430/sdp.c +++ b/board/ti/sdp4430/sdp.c @@ -87,24 +87,6 @@ void set_muxconf_regs_essential(void) sizeof(struct pad_conf_entry)); }
-void set_muxconf_regs_non_essential(void) -{ - do_set_mux(CONTROL_PADCONF_CORE, core_padconf_array_non_essential, - sizeof(core_padconf_array_non_essential) / - sizeof(struct pad_conf_entry)); - - do_set_mux(CONTROL_PADCONF_WKUP, wkup_padconf_array_non_essential, - sizeof(wkup_padconf_array_non_essential) / - sizeof(struct pad_conf_entry)); - - if (omap_revision() < OMAP4460_ES1_0) { - do_set_mux(CONTROL_PADCONF_WKUP, - wkup_padconf_array_non_essential_4430, - sizeof(wkup_padconf_array_non_essential_4430) / - sizeof(struct pad_conf_entry)); - } -} - #if !defined(CONFIG_SPL_BUILD) && defined(CONFIG_GENERIC_MMC) int board_mmc_init(bd_t *bis) { diff --git a/board/ti/sdp4430/sdp4430_mux_data.h b/board/ti/sdp4430/sdp4430_mux_data.h index 0760dad..76a9331 100644 --- a/board/ti/sdp4430/sdp4430_mux_data.h +++ b/board/ti/sdp4430/sdp4430_mux_data.h @@ -81,201 +81,4 @@ const struct pad_conf_entry wkup_padconf_array_essential_4460[] = {
-const struct pad_conf_entry core_padconf_array_non_essential[] = { - {GPMC_AD8, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M3)}, /* gpio_32 */ - {GPMC_AD9, (PTU | IEN | M3)}, /* gpio_33 */ - {GPMC_AD10, (PTU | IEN | M3)}, /* gpio_34 */ - {GPMC_AD11, (PTU | IEN | M3)}, /* gpio_35 */ - {GPMC_AD12, (PTU | IEN | M3)}, /* gpio_36 */ - {GPMC_AD13, (PTD | OFF_EN | OFF_PD | OFF_OUT_PTD | M3)}, /* gpio_37 */ - {GPMC_AD14, (PTD | OFF_EN | OFF_PD | OFF_OUT_PTD | M3)}, /* gpio_38 */ - {GPMC_AD15, (PTD | OFF_EN | OFF_PD | OFF_OUT_PTD | M3)}, /* gpio_39 */ - {GPMC_A16, (M3)}, /* gpio_40 */ - {GPMC_A17, (PTD | M3)}, /* gpio_41 */ - {GPMC_A18, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_row6 */ - {GPMC_A19, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_row7 */ - {GPMC_A20, (IEN | M3)}, /* gpio_44 */ - {GPMC_A21, (M3)}, /* gpio_45 */ - {GPMC_A22, (OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_col6 */ - {GPMC_A23, (OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_col7 */ - {GPMC_A24, (PTD | M3)}, /* gpio_48 */ - {GPMC_A25, (PTD | M3)}, /* gpio_49 */ - {GPMC_NCS0, (M3)}, /* gpio_50 */ - {GPMC_NCS1, (IEN | M3)}, /* gpio_51 */ - {GPMC_NCS2, (IEN | M3)}, /* gpio_52 */ - {GPMC_NCS3, (IEN | M3)}, /* gpio_53 */ - {GPMC_NWP, (M3)}, /* gpio_54 */ - {GPMC_CLK, (PTD | M3)}, /* gpio_55 */ - {GPMC_NADV_ALE, (M3)}, /* gpio_56 */ - {GPMC_NBE0_CLE, (M3)}, /* gpio_59 */ - {GPMC_NBE1, (PTD | M3)}, /* gpio_60 */ - {GPMC_WAIT0, (PTU | IEN | M3)}, /* gpio_61 */ - {GPMC_WAIT1, (IEN | M3)}, /* gpio_62 */ - {C2C_DATA11, (PTD | M3)}, /* gpio_100 */ - {C2C_DATA12, (M1)}, /* dsi1_te0 */ - {C2C_DATA13, (PTD | M3)}, /* gpio_102 */ - {C2C_DATA14, (M1)}, /* dsi2_te0 */ - {C2C_DATA15, (PTD | M3)}, /* gpio_104 */ - {HDMI_HPD, (M0)}, /* hdmi_hpd */ - {HDMI_CEC, (M0)}, /* hdmi_cec */ - {HDMI_DDC_SCL, (PTU | M0)}, /* hdmi_ddc_scl */ - {HDMI_DDC_SDA, (PTU | IEN | M0)}, /* hdmi_ddc_sda */ - {CSI21_DX0, (IEN | M0)}, /* csi21_dx0 */ - {CSI21_DY0, (IEN | M0)}, /* csi21_dy0 */ - {CSI21_DX1, (IEN | M0)}, /* csi21_dx1 */ - {CSI21_DY1, (IEN | M0)}, /* csi21_dy1 */ - {CSI21_DX2, (IEN | M0)}, /* csi21_dx2 */ - {CSI21_DY2, (IEN | M0)}, /* csi21_dy2 */ - {CSI21_DX3, (PTD | M7)}, /* csi21_dx3 */ - {CSI21_DY3, (PTD | M7)}, /* csi21_dy3 */ - {CSI21_DX4, (PTD | OFF_EN | OFF_PD | OFF_IN | M7)}, /* csi21_dx4 */ - {CSI21_DY4, (PTD | OFF_EN | OFF_PD | OFF_IN | M7)}, /* csi21_dy4 */ - {CSI22_DX0, (IEN | M0)}, /* csi22_dx0 */ - {CSI22_DY0, (IEN | M0)}, /* csi22_dy0 */ - {CSI22_DX1, (IEN | M0)}, /* csi22_dx1 */ - {CSI22_DY1, (IEN | M0)}, /* csi22_dy1 */ - {CAM_SHUTTER, (OFF_EN | OFF_PD | OFF_OUT_PTD | M0)}, /* cam_shutter */ - {CAM_STROBE, (OFF_EN | OFF_PD | OFF_OUT_PTD | M0)}, /* cam_strobe */ - {CAM_GLOBALRESET, (PTD | OFF_EN | OFF_PD | OFF_OUT_PTD | M3)}, /* gpio_83 */ - {USBB1_ULPITLL_CLK, (IEN | OFF_EN | OFF_IN | M1)}, /* hsi1_cawake */ - {USBB1_ULPITLL_STP, (IEN | OFF_EN | OFF_IN | M1)}, /* hsi1_cadata */ - {USBB1_ULPITLL_DIR, (IEN | OFF_EN | OFF_IN | M1)}, /* hsi1_caflag */ - {USBB1_ULPITLL_NXT, (OFF_EN | M1)}, /* hsi1_acready */ - {USBB1_ULPITLL_DAT0, (OFF_EN | M1)}, /* hsi1_acwake */ - {USBB1_ULPITLL_DAT1, (OFF_EN | M1)}, /* hsi1_acdata */ - {USBB1_ULPITLL_DAT2, (OFF_EN | M1)}, /* hsi1_acflag */ - {USBB1_ULPITLL_DAT3, (IEN | OFF_EN | OFF_IN | M1)}, /* hsi1_caready */ - {ABE_MCBSP2_CLKX, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_mcbsp2_clkx */ - {ABE_MCBSP2_DR, (IEN | OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp2_dr */ - {ABE_MCBSP2_DX, (OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp2_dx */ - {ABE_MCBSP2_FSX, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_mcbsp2_fsx */ - {ABE_MCBSP1_CLKX, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_mcbsp1_clkx */ - {ABE_MCBSP1_DR, (IEN | OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp1_dr */ - {ABE_MCBSP1_DX, (OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp1_dx */ - {ABE_MCBSP1_FSX, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_mcbsp1_fsx */ - {ABE_PDM_UL_DATA, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_pdm_ul_data */ - {ABE_PDM_DL_DATA, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_pdm_dl_data */ - {ABE_PDM_FRAME, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_pdm_frame */ - {ABE_PDM_LB_CLK, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_pdm_lb_clk */ - {ABE_CLKS, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_clks */ - {ABE_DMIC_CLK1, (M0)}, /* abe_dmic_clk1 */ - {ABE_DMIC_DIN1, (IEN | M0)}, /* abe_dmic_din1 */ - {ABE_DMIC_DIN2, (IEN | M0)}, /* abe_dmic_din2 */ - {ABE_DMIC_DIN3, (IEN | M0)}, /* abe_dmic_din3 */ - {UART2_CTS, (PTU | IEN | M0)}, /* uart2_cts */ - {UART2_RTS, (M0)}, /* uart2_rts */ - {UART2_RX, (PTU | IEN | M0)}, /* uart2_rx */ - {UART2_TX, (M0)}, /* uart2_tx */ - {HDQ_SIO, (M3)}, /* gpio_127 */ - {MCSPI1_CLK, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi1_clk */ - {MCSPI1_SOMI, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi1_somi */ - {MCSPI1_SIMO, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi1_simo */ - {MCSPI1_CS0, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi1_cs0 */ - {MCSPI1_CS1, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M3)}, /* mcspi1_cs1 */ - {MCSPI1_CS2, (PTU | OFF_EN | OFF_OUT_PTU | M3)}, /* gpio_139 */ - {MCSPI1_CS3, (PTU | IEN | M3)}, /* gpio_140 */ - {SDMMC5_CLK, (PTU | IEN | OFF_EN | OFF_OUT_PTD | M0)}, /* sdmmc5_clk */ - {SDMMC5_CMD, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc5_cmd */ - {SDMMC5_DAT0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc5_dat0 */ - {SDMMC5_DAT1, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc5_dat1 */ - {SDMMC5_DAT2, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc5_dat2 */ - {SDMMC5_DAT3, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc5_dat3 */ - {MCSPI4_CLK, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi4_clk */ - {MCSPI4_SIMO, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi4_simo */ - {MCSPI4_SOMI, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi4_somi */ - {MCSPI4_CS0, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi4_cs0 */ - {UART4_RX, (IEN | M0)}, /* uart4_rx */ - {UART4_TX, (M0)}, /* uart4_tx */ - {USBB2_ULPITLL_CLK, (PTD | IEN | M3)}, /* gpio_157 */ - {USBB2_ULPITLL_STP, (IEN | M5)}, /* dispc2_data23 */ - {USBB2_ULPITLL_DIR, (IEN | M5)}, /* dispc2_data22 */ - {USBB2_ULPITLL_NXT, (IEN | M5)}, /* dispc2_data21 */ - {USBB2_ULPITLL_DAT0, (IEN | M5)}, /* dispc2_data20 */ - {USBB2_ULPITLL_DAT1, (IEN | M5)}, /* dispc2_data19 */ - {USBB2_ULPITLL_DAT2, (IEN | M5)}, /* dispc2_data18 */ - {USBB2_ULPITLL_DAT3, (IEN | M5)}, /* dispc2_data15 */ - {USBB2_ULPITLL_DAT4, (IEN | M5)}, /* dispc2_data14 */ - {USBB2_ULPITLL_DAT5, (IEN | M5)}, /* dispc2_data13 */ - {USBB2_ULPITLL_DAT6, (IEN | M5)}, /* dispc2_data12 */ - {USBB2_ULPITLL_DAT7, (IEN | M5)}, /* dispc2_data11 */ - {USBB2_HSIC_DATA, (PTD | OFF_EN | OFF_OUT_PTU | M3)}, /* gpio_169 */ - {USBB2_HSIC_STROBE, (PTD | OFF_EN | OFF_OUT_PTU | M3)}, /* gpio_170 */ - {UNIPRO_TX0, (OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_col0 */ - {UNIPRO_TY0, (OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_col1 */ - {UNIPRO_TX1, (OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_col2 */ - {UNIPRO_TY1, (OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_col3 */ - {UNIPRO_TX2, (OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_col4 */ - {UNIPRO_TY2, (OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_col5 */ - {UNIPRO_RX0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_row0 */ - {UNIPRO_RY0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_row1 */ - {UNIPRO_RX1, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_row2 */ - {UNIPRO_RY1, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_row3 */ - {UNIPRO_RX2, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_row4 */ - {UNIPRO_RY2, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_row5 */ - {FREF_CLK1_OUT, (M0)}, /* fref_clk1_out */ - {FREF_CLK2_OUT, (M0)}, /* fref_clk2_out */ - {SYS_NIRQ1, (PTU | IEN | M0)}, /* sys_nirq1 */ - {SYS_NIRQ2, (M7)}, /* sys_nirq2 */ - {SYS_BOOT0, (PTU | IEN | M3)}, /* gpio_184 */ - {SYS_BOOT1, (M3)}, /* gpio_185 */ - {SYS_BOOT2, (PTD | IEN | M3)}, /* gpio_186 */ - {SYS_BOOT3, (PTD | IEN | M3)}, /* gpio_187 */ - {SYS_BOOT4, (M3)}, /* gpio_188 */ - {SYS_BOOT5, (PTD | IEN | M3)}, /* gpio_189 */ - {DPM_EMU0, (IEN | M0)}, /* dpm_emu0 */ - {DPM_EMU1, (IEN | M0)}, /* dpm_emu1 */ - {DPM_EMU2, (IEN | M0)}, /* dpm_emu2 */ - {DPM_EMU3, (IEN | M5)}, /* dispc2_data10 */ - {DPM_EMU4, (IEN | M5)}, /* dispc2_data9 */ - {DPM_EMU5, (IEN | M5)}, /* dispc2_data16 */ - {DPM_EMU6, (IEN | M5)}, /* dispc2_data17 */ - {DPM_EMU7, (IEN | M5)}, /* dispc2_hsync */ - {DPM_EMU8, (IEN | M5)}, /* dispc2_pclk */ - {DPM_EMU9, (IEN | M5)}, /* dispc2_vsync */ - {DPM_EMU10, (IEN | M5)}, /* dispc2_de */ - {DPM_EMU11, (IEN | M5)}, /* dispc2_data8 */ - {DPM_EMU12, (IEN | M5)}, /* dispc2_data7 */ - {DPM_EMU13, (IEN | M5)}, /* dispc2_data6 */ - {DPM_EMU14, (IEN | M5)}, /* dispc2_data5 */ - {DPM_EMU15, (IEN | M5)}, /* dispc2_data4 */ - {DPM_EMU16, (M3)}, /* gpio_27 */ - {DPM_EMU17, (IEN | M5)}, /* dispc2_data2 */ - {DPM_EMU18, (IEN | M5)}, /* dispc2_data1 */ - {DPM_EMU19, (IEN | M5)}, /* dispc2_data0 */ - {I2C1_SCL, (PTU | IEN | M0)}, /* i2c1_scl */ - {I2C1_SDA, (PTU | IEN | M0)}, /* i2c1_sda */ - {I2C2_SCL, (PTU | IEN | M0)}, /* i2c2_scl */ - {I2C2_SDA, (PTU | IEN | M0)}, /* i2c2_sda */ - {I2C3_SCL, (PTU | IEN | M0)}, /* i2c3_scl */ - {I2C3_SDA, (PTU | IEN | M0)}, /* i2c3_sda */ - {I2C4_SCL, (PTU | IEN | M0)}, /* i2c4_scl */ - {I2C4_SDA, (PTU | IEN | M0)} /* i2c4_sda */ - -}; - -const struct pad_conf_entry wkup_padconf_array_non_essential[] = { - {PAD0_SIM_IO, (IEN | M0)}, /* sim_io */ - {PAD1_SIM_CLK, (M0)}, /* sim_clk */ - {PAD0_SIM_RESET, (M0)}, /* sim_reset */ - {PAD1_SIM_CD, (PTU | IEN | M0)}, /* sim_cd */ - {PAD0_SIM_PWRCTRL, (M0)}, /* sim_pwrctrl */ - {PAD1_FREF_XTAL_IN, (M0)}, /* # */ - {PAD0_FREF_SLICER_IN, (M0)}, /* fref_slicer_in */ - {PAD1_FREF_CLK_IOREQ, (M0)}, /* fref_clk_ioreq */ - {PAD0_FREF_CLK0_OUT, (M2)}, /* sys_drm_msecure */ - {PAD1_FREF_CLK3_REQ, (M3)}, /* gpio_wk30 - Debug led-1 */ - {PAD0_FREF_CLK3_OUT, (M0)}, /* fref_clk3_out */ - {PAD0_FREF_CLK4_OUT, (M3)}, /* gpio_wk8 - Debug led-3 */ - {PAD0_SYS_NRESPWRON, (M0)}, /* sys_nrespwron */ - {PAD1_SYS_NRESWARM, (M0)}, /* sys_nreswarm */ - {PAD0_SYS_PWR_REQ, (PTU | M0)}, /* sys_pwr_req */ - {PAD1_SYS_PWRON_RESET, (M3)}, /* gpio_wk29 */ - {PAD0_SYS_BOOT6, (IEN | M3)}, /* gpio_wk9 */ - {PAD1_SYS_BOOT7, (IEN | M3)}, /* gpio_wk10 */ -}; - -const struct pad_conf_entry wkup_padconf_array_non_essential_4430[] = { - {PAD1_FREF_CLK4_REQ, (M3)} /* gpio_wk7 - Debug led-2 */ -}; - #endif /* _SDP4430_MUX_DATA_H */
With logical changes to apply again, applied to u-boot-ti/master, thanks!
Jassi Brar
