[U-Boot] [PATCH 1/2] PCI: Add newlines to debug prints in pci_auto_common.c
All of the debug output from this file is squished to one line. Fix it.
Signed-off-by: Tuomas Tynkkynen tuomas.tynkkynen@iki.fi --- drivers/pci/pci_auto_common.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/pci/pci_auto_common.c b/drivers/pci/pci_auto_common.c index 1d202ae2ef..d90dbcf91a 100644 --- a/drivers/pci/pci_auto_common.c +++ b/drivers/pci/pci_auto_common.c @@ -37,7 +37,7 @@ int pciauto_region_allocate(struct pci_region *res, pci_size_t size, pci_addr_t addr;
if (!res) { - debug("No resource"); + debug("No resource\n"); goto error; }
@@ -50,7 +50,7 @@ int pciauto_region_allocate(struct pci_region *res, pci_size_t size,
res->bus_lower = addr + size;
- debug("address=0x%llx bus_lower=0x%llx", (unsigned long long)addr, + debug("address=0x%llx bus_lower=0x%llx\n", (unsigned long long)addr, (unsigned long long)res->bus_lower);
*bar = addr;
Currently, if we happen to allocate an address requiring 64 bits to a device only supporting 32-bit BARs, the address eventually gets silently truncated to 32 bits. Avoid this by adding a new flag to pciauto_region_allocate() to bail out in such situations.
Signed-off-by: Tuomas Tynkkynen tuomas.tynkkynen@iki.fi --- drivers/pci/pci_auto.c | 6 ++++-- drivers/pci/pci_auto_common.c | 7 ++++++- drivers/pci/pci_auto_old.c | 5 +++-- include/pci.h | 2 +- 4 files changed, 14 insertions(+), 6 deletions(-)
diff --git a/drivers/pci/pci_auto.c b/drivers/pci/pci_auto.c index d1feb503a0..d7237f6eee 100644 --- a/drivers/pci/pci_auto.c +++ b/drivers/pci/pci_auto.c @@ -98,7 +98,8 @@ void dm_pciauto_setup_device(struct udevice *dev, int bars_num, }
if (!enum_only && pciauto_region_allocate(bar_res, bar_size, - &bar_value) == 0) { + &bar_value, + found_mem64) == 0) { /* Write it out and update our limit */ dm_pci_write_config32(dev, bar, (u32)bar_value);
@@ -140,7 +141,8 @@ void dm_pciauto_setup_device(struct udevice *dev, int bars_num, debug("PCI Autoconfig: ROM, size=%#x, ", (unsigned int)bar_size); if (pciauto_region_allocate(mem, bar_size, - &bar_value) == 0) { + &bar_value, + false) == 0) { dm_pci_write_config32(dev, rom_addr, bar_value); } diff --git a/drivers/pci/pci_auto_common.c b/drivers/pci/pci_auto_common.c index d90dbcf91a..183787333e 100644 --- a/drivers/pci/pci_auto_common.c +++ b/drivers/pci/pci_auto_common.c @@ -32,7 +32,7 @@ void pciauto_region_align(struct pci_region *res, pci_size_t size) }
int pciauto_region_allocate(struct pci_region *res, pci_size_t size, - pci_addr_t *bar) + pci_addr_t *bar, bool supports_64bit) { pci_addr_t addr;
@@ -48,6 +48,11 @@ int pciauto_region_allocate(struct pci_region *res, pci_size_t size, goto error; }
+ if (upper_32_bits(addr) && !supports_64bit) { + debug("Cannot assign 64-bit address to 32-bit-only resource\n"); + goto error; + } + res->bus_lower = addr + size;
debug("address=0x%llx bus_lower=0x%llx\n", (unsigned long long)addr, diff --git a/drivers/pci/pci_auto_old.c b/drivers/pci/pci_auto_old.c index bc119fba87..e705a3072e 100644 --- a/drivers/pci/pci_auto_old.c +++ b/drivers/pci/pci_auto_old.c @@ -108,7 +108,8 @@ void pciauto_setup_device(struct pci_controller *hose, }
#ifndef CONFIG_PCI_ENUM_ONLY - if (pciauto_region_allocate(bar_res, bar_size, &bar_value) == 0) { + if (pciauto_region_allocate(bar_res, bar_size, + &bar_value, found_mem64) == 0) { /* Write it out and update our limit */ pci_hose_write_config_dword(hose, dev, bar, (u32)bar_value);
@@ -150,7 +151,7 @@ void pciauto_setup_device(struct pci_controller *hose, debug("PCI Autoconfig: ROM, size=%#x, ", (unsigned int)bar_size); if (pciauto_region_allocate(mem, bar_size, - &bar_value) == 0) { + &bar_value, false) == 0) { pci_hose_write_config_dword(hose, dev, rom_addr, bar_value); } diff --git a/include/pci.h b/include/pci.h index cda6907688..127d3c6a6f 100644 --- a/include/pci.h +++ b/include/pci.h @@ -681,7 +681,7 @@ void pciauto_region_init(struct pci_region *res); void pciauto_region_align(struct pci_region *res, pci_size_t size); void pciauto_config_init(struct pci_controller *hose); int pciauto_region_allocate(struct pci_region *res, pci_size_t size, - pci_addr_t *bar); + pci_addr_t *bar, bool supports_64bit);
#if !defined(CONFIG_DM_PCI) || defined(CONFIG_DM_PCI_COMPAT) extern int pci_hose_read_config_byte_via_dword(struct pci_controller *hose,
Hi Tuomas,
Please can you add a function comment to pciauto_region_allocate()?
Signed-off-by: Tuomas Tynkkynen tuomas.tynkkynen@iki.fi Reviewed-by: Simon Glass sjg@chromium.org
Tuomas Tynkkynen
