[U-Boot] [PATCH v3] Enabled support for Rev 1.3 SPD for DDR2 DIMMs
SPD has minor change from Rev 1.2 to 1.3. This patch enables Rev 1.3. The difference has ben examined and the code is compatible. Speed bins is not verified on hardware for CL7 at this moment.
This patch also enables SPD Rev 1.x where x is up to "F". According to SPD spec, the lower nibble is optionally used to determine which additinal bytes or attribute bits have been defined. Software can safely use defaults. However, the upper nibble should always be checked.
Signed-off-by: York Sun yorksun@freescale.com --- arch/powerpc/cpu/mpc8xxx/ddr/ddr2_dimm_params.c | 4 ++-- common/ddr_spd.c | 6 +++++- 2 files changed, 7 insertions(+), 3 deletions(-)
diff --git a/arch/powerpc/cpu/mpc8xxx/ddr/ddr2_dimm_params.c b/arch/powerpc/cpu/mpc8xxx/ddr/ddr2_dimm_params.c index d9d0fa7..dcb37ce 100644 --- a/arch/powerpc/cpu/mpc8xxx/ddr/ddr2_dimm_params.c +++ b/arch/powerpc/cpu/mpc8xxx/ddr/ddr2_dimm_params.c @@ -175,8 +175,8 @@ determine_refresh_rate_ps(const unsigned int spd_refresh) * ordinal 2, ddr2_speed_bins[1] contains tCK for CL=3 * Not certain if any good value exists for CL=2 */ - /* CL2 CL3 CL4 CL5 CL6 */ -unsigned short ddr2_speed_bins[] = { 0, 5000, 3750, 3000, 2500 }; + /* CL2 CL3 CL4 CL5 CL6 CL7*/ +unsigned short ddr2_speed_bins[] = { 0, 5000, 3750, 3000, 2500, 1875 };
unsigned int compute_derated_DDR2_CAS_latency(unsigned int mclk_ps) diff --git a/common/ddr_spd.c b/common/ddr_spd.c index c058e4f..a7a30de 100644 --- a/common/ddr_spd.c +++ b/common/ddr_spd.c @@ -20,11 +20,15 @@ spd_check(const u8 *buf, u8 spd_rev, u8 spd_cksum) * Check SPD revision supported * Rev 1.2 or less supported by this code */ - if (spd_rev > 0x12) { + if (spd_rev >= 0x20) { printf("SPD revision %02X not supported by this code\n", spd_rev); return 1; } + if (spd_rev > 0x13) { + printf("SPD revision %02X not verified by this code\n", + spd_rev); + }
/* * Calculate checksum
Wolfgang,
I'm intended to pick this up for this release as we are having memories show up that dont work w/u-boot because of this issue on the revision check.
- k
applied to 85xx
- k
Kumar Gala
York Sun
