[U-Boot] [PATCH] Convert CONFIG_NAND_OMAP_GPMC et al to Kconfig
This converts the following to Kconfig: CONFIG_NAND_OMAP_GPMC CONFIG_NAND_OMAP_GPMC_PREFETCH CONFIG_NAND_OMAP_ELM CONFIG_SYS_NAND_BUSWIDTH_16BIT CONFIG_SPL_NAND_AM33XX_BCH CONFIG_SPL_NAND_SIMPLE
Signed-off-by: Adam Ford aford173@gmail.com --- README | 4 --- arch/arm/mach-omap2/Kconfig | 18 +++++++++++++ configs/am335x_baltos_defconfig | 2 +- configs/am335x_evm_defconfig | 1 + configs/am335x_evm_nor_defconfig | 1 + configs/am335x_evm_usbspl_defconfig | 1 + configs/am335x_hs_evm_defconfig | 1 + configs/am3517_crane_defconfig | 1 + configs/am3517_evm_defconfig | 2 ++ configs/chiliboard_defconfig | 2 +- configs/devkit8000_defconfig | 1 + configs/eco5pk_defconfig | 2 ++ configs/igep0020_defconfig | 1 + configs/igep0030_defconfig | 1 + configs/igep0032_defconfig | 1 + configs/ipam390_defconfig | 1 + configs/mcx_defconfig | 2 ++ configs/mt_ventoux_defconfig | 2 ++ configs/omap3_beagle_defconfig | 1 + configs/omap3_evm_defconfig | 1 + configs/omap3_ha_defconfig | 1 + configs/omap3_logic_defconfig | 1 + configs/omap3_overo_defconfig | 1 + configs/omap3_pandora_defconfig | 1 + configs/omap3_zoom1_defconfig | 1 + configs/omapl138_lcdk_defconfig | 1 + configs/tao3530_defconfig | 1 + configs/ti816x_evm_defconfig | 2 ++ configs/twister_defconfig | 2 ++ drivers/mtd/nand/Kconfig | 47 +++++++++++++++++++++++++++++++++- include/configs/am335x_evm.h | 6 ----- include/configs/am335x_igep003x.h | 1 - include/configs/am3517_crane.h | 3 --- include/configs/am3517_evm.h | 4 --- include/configs/am43xx_evm.h | 5 ---- include/configs/apf27.h | 1 - include/configs/baltos.h | 3 --- include/configs/bav335x.h | 5 ---- include/configs/brppt1.h | 3 --- include/configs/chiliboard.h | 6 ----- include/configs/cm_t35.h | 2 -- include/configs/cm_t3517.h | 1 - include/configs/cm_t43.h | 1 - include/configs/da850evm.h | 1 - include/configs/devkit3250.h | 1 - include/configs/devkit8000.h | 1 - include/configs/dra7xx_evm.h | 6 ----- include/configs/ipam390.h | 1 - include/configs/mcx.h | 4 --- include/configs/omap3_beagle.h | 2 -- include/configs/omap3_cairo.h | 1 - include/configs/omap3_evm.h | 3 --- include/configs/omap3_igep00x0.h | 2 -- include/configs/omap3_logic.h | 3 --- include/configs/omap3_overo.h | 1 - include/configs/omap3_pandora.h | 1 - include/configs/omap3_zoom1.h | 1 - include/configs/omapl138_lcdk.h | 2 -- include/configs/pengwyn.h | 2 -- include/configs/siemens-am33x-common.h | 3 --- include/configs/tam3517-common.h | 4 --- include/configs/tao3530.h | 3 --- include/configs/tegra-common.h | 1 - include/configs/ti816x_evm.h | 5 ---- include/configs/ti_am335x_common.h | 4 --- include/configs/ti_armv7_omap.h | 1 - include/configs/ti_omap3_common.h | 1 - include/configs/ti_omap4_common.h | 4 --- include/configs/ti_omap5_common.h | 4 --- include/configs/tricorder.h | 2 -- scripts/config_whitelist.txt | 5 ---- 71 files changed, 97 insertions(+), 117 deletions(-)
diff --git a/README b/README index 3735916..dbbca43 100644 --- a/README +++ b/README @@ -2985,10 +2985,6 @@ FIT uImage format: CONFIG_SPL_NAND_ECC Include standard software ECC in the SPL
- CONFIG_SPL_NAND_SIMPLE - Support for NAND boot using simple NAND drivers that - expose the cmd_ctrl() interface. - CONFIG_SPL_UBI Support for a lightweight UBI (fastmap) scanner and loader diff --git a/arch/arm/mach-omap2/Kconfig b/arch/arm/mach-omap2/Kconfig index 89c91d1..eb3124f 100644 --- a/arch/arm/mach-omap2/Kconfig +++ b/arch/arm/mach-omap2/Kconfig @@ -11,6 +11,7 @@ config OMAP34XX select ARM_ERRATA_621766 select ARM_ERRATA_725233 select USE_TINY_PRINTF + imply NAND_OMAP_GPMC imply SPL_EXT_SUPPORT imply SPL_FAT_SUPPORT imply SPL_GPIO_SUPPORT @@ -19,6 +20,7 @@ config OMAP34XX imply SPL_LIBDISK_SUPPORT imply SPL_LIBGENERIC_SUPPORT imply SPL_MMC_SUPPORT + imply SPL_NAND_SIMPLE imply SPL_NAND_SUPPORT imply SPL_POWER_SUPPORT imply SPL_SERIAL_SUPPORT @@ -29,6 +31,8 @@ config OMAP34XX config OMAP44XX bool "OMAP44XX SoC" select USE_TINY_PRINTF + imply NAND_OMAP_ELM + imply NAND_OMAP_GPMC imply SPL_DISPLAY_PRINT imply SPL_EXT_SUPPORT imply SPL_FAT_SUPPORT @@ -38,6 +42,7 @@ config OMAP44XX imply SPL_LIBDISK_SUPPORT imply SPL_LIBGENERIC_SUPPORT imply SPL_MMC_SUPPORT + imply SPL_NAND_AM33XX_BCH imply SPL_NAND_SUPPORT imply SPL_POWER_SUPPORT imply SPL_SERIAL_SUPPORT @@ -48,6 +53,8 @@ config OMAP54XX bool "OMAP54XX SoC" select ARM_ERRATA_798870 select SYS_THUMB_BUILD + imply NAND_OMAP_ELM + imply NAND_OMAP_GPMC imply SPL_DISPLAY_PRINT imply SPL_ENV_SUPPORT imply SPL_EXT_SUPPORT @@ -58,6 +65,7 @@ config OMAP54XX imply SPL_LIBDISK_SUPPORT imply SPL_LIBGENERIC_SUPPORT imply SPL_MMC_SUPPORT + imply SPL_NAND_AM33XX_BCH imply SPL_NAND_SUPPORT imply SPL_POWER_SUPPORT imply SPL_SERIAL_SUPPORT @@ -72,6 +80,8 @@ config TI814X
config TI816X bool "TI816X SoC" + imply NAND_OMAP_ELM + imply NAND_OMAP_GPMC help Support for AM335x SOC from Texas Instruments. The AM335x high performance SOC features a Cortex-A8 @@ -79,8 +89,12 @@ config TI816X
config AM43XX bool "AM43XX SoC" + imply NAND_OMAP_ELM + imply NAND_OMAP_GPMC imply SPL_DM imply SPL_DM_SEQ_ALIAS + imply SPL_NAND_AM33XX_BCH + imply SPL_NAND_SUPPORT imply SPL_OF_CONTROL imply SPL_OF_TRANSLATE imply SPL_SEPARATE_BSS @@ -96,6 +110,10 @@ config AM43XX
config AM33XX bool "AM33XX SoC" + imply NAND_OMAP_ELM + imply NAND_OMAP_GPMC + imply SPL_NAND_AM33XX_BCH + imply SPL_NAND_SUPPORT imply SYS_I2C_OMAP24XX imply SYS_THUMB_BUILD imply USE_TINY_PRINTF diff --git a/configs/am335x_baltos_defconfig b/configs/am335x_baltos_defconfig index 180268e..2df7ac7 100644 --- a/configs/am335x_baltos_defconfig +++ b/configs/am335x_baltos_defconfig @@ -8,7 +8,6 @@ CONFIG_TARGET_AM335X_BALTOS=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_LIBDISK_SUPPORT=y -CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_SPL_STACK_R_ADDR=0x82000000 CONFIG_SPL_FAT_SUPPORT=y @@ -52,6 +51,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y CONFIG_ISO_PARTITION=y CONFIG_MMC_OMAP_HS=y +CONFIG_NAND_OMAP_GPMC_PREFETCH=y CONFIG_PHYLIB=y CONFIG_SYS_NS16550=y CONFIG_USB=y diff --git a/configs/am335x_evm_defconfig b/configs/am335x_evm_defconfig index 82d5a97..046ee68 100644 --- a/configs/am335x_evm_defconfig +++ b/configs/am335x_evm_defconfig @@ -34,6 +34,7 @@ CONFIG_DM_I2C=y CONFIG_MISC=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y +CONFIG_NAND_OMAP_GPMC_PREFETCH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_PHYLIB=y diff --git a/configs/am335x_evm_nor_defconfig b/configs/am335x_evm_nor_defconfig index 3fb220a..6b94f73 100644 --- a/configs/am335x_evm_nor_defconfig +++ b/configs/am335x_evm_nor_defconfig @@ -27,6 +27,7 @@ CONFIG_DFU_NAND=y CONFIG_DFU_RAM=y CONFIG_MMC_OMAP_HS=y CONFIG_MTD_NOR_FLASH=y +CONFIG_NAND_OMAP_GPMC_PREFETCH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_PHYLIB=y diff --git a/configs/am335x_evm_usbspl_defconfig b/configs/am335x_evm_usbspl_defconfig index 55c13da..d899d79 100644 --- a/configs/am335x_evm_usbspl_defconfig +++ b/configs/am335x_evm_usbspl_defconfig @@ -30,6 +30,7 @@ CONFIG_DFU_MMC=y CONFIG_DFU_NAND=y CONFIG_DFU_RAM=y CONFIG_MMC_OMAP_HS=y +CONFIG_NAND_OMAP_GPMC_PREFETCH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_PHYLIB=y diff --git a/configs/am335x_hs_evm_defconfig b/configs/am335x_hs_evm_defconfig index 59306ba..5d88c87 100644 --- a/configs/am335x_hs_evm_defconfig +++ b/configs/am335x_hs_evm_defconfig @@ -37,6 +37,7 @@ CONFIG_DM_I2C=y CONFIG_MISC=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y +CONFIG_NAND_OMAP_GPMC_PREFETCH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_PHYLIB=y diff --git a/configs/am3517_crane_defconfig b/configs/am3517_crane_defconfig index 396aadd..f9bbe0e 100644 --- a/configs/am3517_crane_defconfig +++ b/configs/am3517_crane_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_JFFS2=y CONFIG_MMC_OMAP_HS=y +CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/am3517_evm_defconfig b/configs/am3517_evm_defconfig index 1d07f1b..4e4aadb 100644 --- a/configs/am3517_evm_defconfig +++ b/configs/am3517_evm_defconfig @@ -37,6 +37,8 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y CONFIG_SPL_PARTITION_UUIDS=y CONFIG_MMC_OMAP_HS=y +CONFIG_NAND_OMAP_GPMC_PREFETCH=y +CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/chiliboard_defconfig b/configs/chiliboard_defconfig index 5257d70..b7e8b0c 100644 --- a/configs/chiliboard_defconfig +++ b/configs/chiliboard_defconfig @@ -7,7 +7,6 @@ CONFIG_TARGET_CHILIBOARD=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_LIBDISK_SUPPORT=y -CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_SPL_STACK_R_ADDR=0x82000000 CONFIG_SPL_FAT_SUPPORT=y @@ -40,6 +39,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_MTDPARTS=y CONFIG_DM_GPIO=y CONFIG_MMC_OMAP_HS=y +CONFIG_NAND_OMAP_GPMC_PREFETCH=y CONFIG_PHYLIB=y CONFIG_SYS_NS16550=y CONFIG_USB=y diff --git a/configs/devkit8000_defconfig b/configs/devkit8000_defconfig index 9afc2ce..897bc80 100644 --- a/configs/devkit8000_defconfig +++ b/configs/devkit8000_defconfig @@ -28,5 +28,6 @@ CONFIG_CMD_MTDPARTS=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y CONFIG_MMC_OMAP_HS=y +CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/eco5pk_defconfig b/configs/eco5pk_defconfig index 00261dd..f3c16fd 100644 --- a/configs/eco5pk_defconfig +++ b/configs/eco5pk_defconfig @@ -25,6 +25,8 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y CONFIG_MMC_OMAP_HS=y +CONFIG_NAND_OMAP_GPMC_PREFETCH=y +CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/igep0020_defconfig b/configs/igep0020_defconfig index 8ca5a84..745d6f6 100644 --- a/configs/igep0020_defconfig +++ b/configs/igep0020_defconfig @@ -37,6 +37,7 @@ CONFIG_LED_STATUS_STATE=2 CONFIG_LED_STATUS_BOOT_ENABLE=y CONFIG_LED_STATUS_BOOT=0 CONFIG_MMC_OMAP_HS=y +CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_MTD_UBI_FASTMAP=y CONFIG_SYS_NS16550=y CONFIG_FAT_WRITE=y diff --git a/configs/igep0030_defconfig b/configs/igep0030_defconfig index 8af6dd5..48b80ae 100644 --- a/configs/igep0030_defconfig +++ b/configs/igep0030_defconfig @@ -37,6 +37,7 @@ CONFIG_LED_STATUS_STATE=2 CONFIG_LED_STATUS_BOOT_ENABLE=y CONFIG_LED_STATUS_BOOT=0 CONFIG_MMC_OMAP_HS=y +CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SYS_NS16550=y CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/igep0032_defconfig b/configs/igep0032_defconfig index dd43330..8ecd6a5 100644 --- a/configs/igep0032_defconfig +++ b/configs/igep0032_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_UBI=y # CONFIG_CMD_UBIFS is not set CONFIG_NET_RANDOM_ETHADDR=y CONFIG_MMC_OMAP_HS=y +CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SYS_NS16550=y CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/ipam390_defconfig b/configs/ipam390_defconfig index 0337afa..2686e9e 100644 --- a/configs/ipam390_defconfig +++ b/configs/ipam390_defconfig @@ -29,4 +29,5 @@ CONFIG_CMD_PING=y CONFIG_CMD_DIAG=y CONFIG_CMD_UBI=y # CONFIG_MMC is not set +CONFIG_SPL_NAND_SIMPLE=y CONFIG_SYS_NS16550=y diff --git a/configs/mcx_defconfig b/configs/mcx_defconfig index 0b65b73..6ed3a1a 100644 --- a/configs/mcx_defconfig +++ b/configs/mcx_defconfig @@ -34,6 +34,8 @@ CONFIG_CMD_FAT=y CONFIG_CMD_JFFS2=y CONFIG_CMD_UBI=y CONFIG_MMC_OMAP_HS=y +CONFIG_NAND_OMAP_GPMC_PREFETCH=y +CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/mt_ventoux_defconfig b/configs/mt_ventoux_defconfig index 2a46c19..a387d8b 100644 --- a/configs/mt_ventoux_defconfig +++ b/configs/mt_ventoux_defconfig @@ -31,6 +31,8 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y CONFIG_MMC_OMAP_HS=y +CONFIG_NAND_OMAP_GPMC_PREFETCH=y +CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/omap3_beagle_defconfig b/configs/omap3_beagle_defconfig index 1a134df..9f20999 100644 --- a/configs/omap3_beagle_defconfig +++ b/configs/omap3_beagle_defconfig @@ -35,6 +35,7 @@ CONFIG_LED_STATUS_GREEN_ENABLE=y CONFIG_LED_STATUS_GREEN=2 CONFIG_LED_STATUS_CMD=y CONFIG_MMC_OMAP_HS=y +CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/omap3_evm_defconfig b/configs/omap3_evm_defconfig index 620148c..b34cb28 100644 --- a/configs/omap3_evm_defconfig +++ b/configs/omap3_evm_defconfig @@ -28,6 +28,7 @@ CONFIG_EFI_PARTITION=y # CONFIG_PARTITION_UUIDS is not set # CONFIG_SPL_PARTITION_UUIDS is not set CONFIG_MMC_OMAP_HS=y +CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/omap3_ha_defconfig b/configs/omap3_ha_defconfig index f88c2e1..1672f39 100644 --- a/configs/omap3_ha_defconfig +++ b/configs/omap3_ha_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_MTDPARTS=y CONFIG_MMC_OMAP_HS=y +CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/omap3_logic_defconfig b/configs/omap3_logic_defconfig index 1eb1ff8..959c71f 100644 --- a/configs/omap3_logic_defconfig +++ b/configs/omap3_logic_defconfig @@ -34,6 +34,7 @@ CONFIG_DM_I2C=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y CONFIG_MMC_OMAP36XX_PINS=y +CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_MUSB_GADGET=y diff --git a/configs/omap3_overo_defconfig b/configs/omap3_overo_defconfig index 1a1dfcf..cc30836 100644 --- a/configs/omap3_overo_defconfig +++ b/configs/omap3_overo_defconfig @@ -41,6 +41,7 @@ CONFIG_CMD_UBI=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y CONFIG_MMC_OMAP_HS=y +CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/omap3_pandora_defconfig b/configs/omap3_pandora_defconfig index 8a2e0ae..78a6bb3 100644 --- a/configs/omap3_pandora_defconfig +++ b/configs/omap3_pandora_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_UBI=y CONFIG_MMC_OMAP_HS=y +CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SYS_NS16550=y CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/omap3_zoom1_defconfig b/configs/omap3_zoom1_defconfig index c6e2924..43bfde5 100644 --- a/configs/omap3_zoom1_defconfig +++ b/configs/omap3_zoom1_defconfig @@ -32,6 +32,7 @@ CONFIG_CMD_MTDPARTS=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y CONFIG_MMC_OMAP_HS=y +CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SYS_NS16550=y CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y diff --git a/configs/omapl138_lcdk_defconfig b/configs/omapl138_lcdk_defconfig index d10c540..f7181b7 100644 --- a/configs/omapl138_lcdk_defconfig +++ b/configs/omapl138_lcdk_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_UBI=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y CONFIG_SYS_NAND_U_BOOT_OFFS=0x28000 +CONFIG_SPL_NAND_SIMPLE=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y diff --git a/configs/tao3530_defconfig b/configs/tao3530_defconfig index e6c7e60..92b8f34 100644 --- a/configs/tao3530_defconfig +++ b/configs/tao3530_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_MTDPARTS=y CONFIG_MMC_OMAP_HS=y +CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/ti816x_evm_defconfig b/configs/ti816x_evm_defconfig index 9d4be2a..fe40939 100644 --- a/configs/ti816x_evm_defconfig +++ b/configs/ti816x_evm_defconfig @@ -41,5 +41,7 @@ CONFIG_DM_GPIO=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_OMAP24XX=y CONFIG_MMC_OMAP_HS=y +CONFIG_NAND_OMAP_GPMC_PREFETCH=y +CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SYS_NS16550=y # CONFIG_USE_PRIVATE_LIBGCC is not set diff --git a/configs/twister_defconfig b/configs/twister_defconfig index 61132ee..e80e055 100644 --- a/configs/twister_defconfig +++ b/configs/twister_defconfig @@ -27,6 +27,8 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y CONFIG_MMC_OMAP_HS=y +CONFIG_NAND_OMAP_GPMC_PREFETCH=y +CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/drivers/mtd/nand/Kconfig b/drivers/mtd/nand/Kconfig index 3508c62..3a76ebd 100644 --- a/drivers/mtd/nand/Kconfig +++ b/drivers/mtd/nand/Kconfig @@ -33,6 +33,34 @@ config NAND_DENALI_SPARE_AREA_SKIP_BYTES of OOB area before last ECC sector data starts. This is potentially used to preserve the bad block marker in the OOB area.
+config NAND_OMAP_GPMC + bool "Support OMAP GPMC NAND controller" + depends on ARCH_OMAP2PLUS + help + Enables omap_gpmc.c driver for OMAPx and AMxxxx platforms. + GPMC controller is used for parallel NAND flash devices, and can + do ECC calculation (not ECC error detection) for HAM1, BCH4, BCH8 + and BCH16 ECC algorithms. + +config NAND_OMAP_GPMC_PREFETCH + bool "Enable GPMC Prefetch" + depends on NAND_OMAP_GPMC + help + On OMAP platforms that use the GPMC controller + (CONFIG_NAND_OMAP_GPMC_PREFETCH), this options enables the code that + uses the prefetch mode to speed up read operations. + +config NAND_OMAP_ELM + bool "Enable ELM driver for OMAPxx and AMxx platforms." + depends on NAND_OMAP_GPMC && !OMAP34XX + help + ELM controller is used for ECC error detection (not ECC calculation) + of BCH4, BCH8 and BCH16 ECC algorithms. + Some legacy platforms like OMAP3xx do not have in-built ELM h/w engine, + thus such SoC platforms need to depend on software library for ECC error + detection. However ECC calculation on such plaforms would still be + done by GPMC controller. + config NAND_VF610_NFC bool "Support for Freescale NFC for VF610" select SYS_NAND_SELF_INIT @@ -124,7 +152,7 @@ comment "Generic NAND options" # option (mxc_nand, ndfc, omap_gpmc). config SYS_NAND_BUSWIDTH_16BIT bool "Use 16-bit NAND interface" - depends on NAND_VF610_NFC + depends on NAND_VF610_NFC || NAND_OMAP_GPMC help Indicates that NAND device has 16-bit wide data-bus. In absence of this config, bus-width of NAND device is assumed to be either 8-bit and later @@ -165,12 +193,29 @@ config SYS_NAND_U_BOOT_OFFS_REDUND Set the offset from the start of the nand where the redundant u-boot should be loaded from.
+config SPL_NAND_AM33XX_BCH + bool "Enables SPL-NAND driver which supports ELM based" + depends on NAND_OMAP_GPMC && !OMAP34XX + default y + help + Hardware ECC correction. This is useful for platforms which have ELM + hardware engine and use NAND boot mode. + Some legacy platforms like OMAP3xx do not have in-built ELM h/w engine, + so those platforms should use CONFIG_SPL_NAND_SIMPLE for enabling + SPL-NAND driver with software ECC correction support. + config SPL_NAND_DENALI bool "Support Denali NAND controller for SPL" help This is a small implementation of the Denali NAND controller for use on SPL.
+config SPL_NAND_SIMPLE + bool "Use simple SPL NAND driver" + depends on !SPL_NAND_AM33XX_BCH + help + Support for NAND boot using simple NAND drivers that + expose the cmd_ctrl() interface. endif
endmenu diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index fbab610..19f66af 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -204,9 +204,6 @@ #define CONFIG_SYS_NAND_OOBSIZE 64 #define CONFIG_SYS_NAND_BLOCK_SIZE (128*1024) /* NAND: driver related configs */ -#define CONFIG_NAND_OMAP_GPMC -#define CONFIG_NAND_OMAP_GPMC_PREFETCH -#define CONFIG_NAND_OMAP_ELM #define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ 10, 11, 12, 13, 14, 15, 16, 17, \ @@ -234,9 +231,6 @@ "-(NAND.file-system)" #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x000c0000 /* NAND: SPL related configs */ -#ifdef CONFIG_SPL_NAND_SUPPORT -#define CONFIG_SPL_NAND_AM33XX_BCH -#endif #ifdef CONFIG_SPL_OS_BOOT #define CONFIG_CMD_SPL_NAND_OFS 0x00080000 /* os parameters */ #define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x00200000 /* kernel offset */ diff --git a/include/configs/am335x_igep003x.h b/include/configs/am335x_igep003x.h index 3d3d5e7..6bf24a6 100644 --- a/include/configs/am335x_igep003x.h +++ b/include/configs/am335x_igep003x.h @@ -114,7 +114,6 @@ #define CONFIG_PHY_SMSC
/* NAND support */ -#define CONFIG_NAND_OMAP_ELM #define CONFIG_SYS_NAND_ONFI_DETECTION 1
#define CONFIG_MTD_PARTITIONS diff --git a/include/configs/am3517_crane.h b/include/configs/am3517_crane.h index aeba61e..7289fa4 100644 --- a/include/configs/am3517_crane.h +++ b/include/configs/am3517_crane.h @@ -212,7 +212,6 @@ /* Monitor at start of flash */ #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE
-#define CONFIG_NAND_OMAP_GPMC #define SMNAND_ENV_OFFSET 0x260000 /* environment starts here */
#define CONFIG_SYS_ENV_SECT_SIZE (128 << 10) /* 128 KiB sector */ @@ -243,7 +242,6 @@
/* Defines for SPL */ #define CONFIG_SPL_FRAMEWORK -#define CONFIG_SPL_NAND_SIMPLE #define CONFIG_SPL_TEXT_BASE 0x40200800 #define CONFIG_SPL_MAX_SIZE (SRAM_SCRATCH_SPACE_ADDR - \ CONFIG_SPL_TEXT_BASE) @@ -260,7 +258,6 @@ #define CONFIG_SPL_LDSCRIPT "arch/arm/mach-omap2/u-boot-spl.lds"
/* NAND boot config */ -#define CONFIG_SYS_NAND_BUSWIDTH_16BIT #define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_PAGE_COUNT 64 #define CONFIG_SYS_NAND_PAGE_SIZE 2048 diff --git a/include/configs/am3517_evm.h b/include/configs/am3517_evm.h index 60460c8..65b6af3 100644 --- a/include/configs/am3517_evm.h +++ b/include/configs/am3517_evm.h @@ -104,8 +104,6 @@
/* Board NAND Info. */ #ifdef CONFIG_NAND -#define CONFIG_NAND_OMAP_GPMC -#define CONFIG_NAND_OMAP_GPMC_PREFETCH #define CONFIG_BCH #define CONFIG_SYS_NAND_ADDR NAND_BASE /* physical address */ /* to access nand */ @@ -114,7 +112,6 @@ /* nand at CS0 */ #define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of */ /* NAND devices */ -#define CONFIG_SYS_NAND_BUSWIDTH_16BIT #define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_PAGE_COUNT 64 #define CONFIG_SYS_NAND_PAGE_SIZE 2048 @@ -291,7 +288,6 @@
/* Defines for SPL */ #define CONFIG_SPL_FRAMEWORK -#define CONFIG_SPL_NAND_SIMPLE #define CONFIG_SPL_TEXT_BASE 0x40200000 #define CONFIG_SPL_MAX_SIZE (SRAM_SCRATCH_SPACE_ADDR - \ CONFIG_SPL_TEXT_BASE) diff --git a/include/configs/am43xx_evm.h b/include/configs/am43xx_evm.h index 4f3b605..4076cb2 100644 --- a/include/configs/am43xx_evm.h +++ b/include/configs/am43xx_evm.h @@ -259,8 +259,6 @@ CONFIG_SYS_NAND_PAGE_SIZE) #define CONFIG_SYS_NAND_5_ADDR_CYCLE /* NAND: driver related configs */ -#define CONFIG_NAND_OMAP_GPMC -#define CONFIG_NAND_OMAP_ELM #define CONFIG_SYS_NAND_ONFI_DETECTION #define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH16_CODE_HW #define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS @@ -302,9 +300,6 @@ "-(NAND.file-system)" #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x00180000 /* NAND: SPL related configs */ -#ifdef CONFIG_SPL_NAND_SUPPORT -#define CONFIG_SPL_NAND_AM33XX_BCH -#endif /* NAND: SPL falcon mode configs */ #ifdef CONFIG_SPL_OS_BOOT #define CONFIG_CMD_SPL_NAND_OFS 0x00100000 /* os parameters */ diff --git a/include/configs/apf27.h b/include/configs/apf27.h index 29cbbab..7e9d9c9 100644 --- a/include/configs/apf27.h +++ b/include/configs/apf27.h @@ -208,7 +208,6 @@
#define CONFIG_MXC_NAND_HWECC #define CONFIG_SYS_NAND_LARGEPAGE -#define CONFIG_SYS_NAND_BUSWIDTH_16BIT #define CONFIG_SYS_NAND_PAGE_SIZE 2048 #define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) #define CONFIG_SYS_NAND_PAGE_COUNT CONFIG_SYS_NAND_BLOCK_SIZE / \ diff --git a/include/configs/baltos.h b/include/configs/baltos.h index 598352b..f5c22da 100644 --- a/include/configs/baltos.h +++ b/include/configs/baltos.h @@ -246,9 +246,6 @@ #define CONFIG_SPL_LDSCRIPT "arch/arm/mach-omap2/u-boot-spl.lds"
#ifdef CONFIG_NAND -#define CONFIG_NAND_OMAP_GPMC -#define CONFIG_NAND_OMAP_GPMC_PREFETCH -#define CONFIG_NAND_OMAP_ELM #define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ CONFIG_SYS_NAND_PAGE_SIZE) diff --git a/include/configs/bav335x.h b/include/configs/bav335x.h index 6beb347..6817fab 100644 --- a/include/configs/bav335x.h +++ b/include/configs/bav335x.h @@ -357,8 +357,6 @@ DEFAULT_LINUX_BOOT_ENV \ #define CONFIG_SYS_NAND_OOBSIZE 64 #define CONFIG_SYS_NAND_BLOCK_SIZE (128*1024) /* NAND: driver related configs */ -#define CONFIG_NAND_OMAP_GPMC -#define CONFIG_NAND_OMAP_ELM #define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCPOS { \ 2, 3, 4, 5, 6, 7, 8, 9, \ @@ -391,9 +389,6 @@ DEFAULT_LINUX_BOOT_ENV \ #define CONFIG_ENV_OFFSET_REDUND 0x001e0000 #define CONFIG_SYS_ENV_SECT_SIZE CONFIG_SYS_NAND_BLOCK_SIZE /* NAND: SPL related configs */ -#ifdef CONFIG_SPL_NAND_SUPPORT -#define CONFIG_SPL_NAND_AM33XX_BCH -#endif #ifdef CONFIG_SPL_OS_BOOT #define CONFIG_CMD_SPL_NAND_OFS 0x00080000 /* os parameters */ #define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x00200000 /* kernel offset */ diff --git a/include/configs/brppt1.h b/include/configs/brppt1.h index 9688c4a..6620c9d 100644 --- a/include/configs/brppt1.h +++ b/include/configs/brppt1.h @@ -73,7 +73,6 @@ #endif /* CONFIG_SPL_OS_BOOT */
#ifdef CONFIG_NAND -#define CONFIG_SPL_NAND_AM33XX_BCH /* OMAP4 and later ELM support */ #define CONFIG_SPL_NAND_BASE #define CONFIG_SPL_NAND_DRIVERS #define CONFIG_SPL_NAND_ECC @@ -186,9 +185,7 @@ MMCARGS */ #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_BASE 0x8000000 -#define CONFIG_NAND_OMAP_GPMC /* don't change OMAP_ELM, ECCSCHEME. ROM code only supports this */ -#define CONFIG_NAND_OMAP_ELM #define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH8_CODE_HW #define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_BLOCK_SIZE (128*1024) diff --git a/include/configs/chiliboard.h b/include/configs/chiliboard.h index 581ab7c..5d2bb98 100644 --- a/include/configs/chiliboard.h +++ b/include/configs/chiliboard.h @@ -139,9 +139,6 @@ #define CONFIG_SYS_NAND_OOBSIZE 64 #define CONFIG_SYS_NAND_BLOCK_SIZE (128*1024) /* NAND: driver related configs */ -#define CONFIG_NAND_OMAP_GPMC -#define CONFIG_NAND_OMAP_GPMC_PREFETCH -#define CONFIG_NAND_OMAP_ELM #define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ 10, 11, 12, 13, 14, 15, 16, 17, \ @@ -169,9 +166,6 @@ "-(NAND.file-system)" #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x000c0000 /* NAND: SPL related configs */ -#ifdef CONFIG_SPL_NAND_SUPPORT -#define CONFIG_SPL_NAND_AM33XX_BCH -#endif
/* USB configuration */ #define CONFIG_USB_MUSB_DSPS diff --git a/include/configs/cm_t35.h b/include/configs/cm_t35.h index f8f3c92..b3f5283 100644 --- a/include/configs/cm_t35.h +++ b/include/configs/cm_t35.h @@ -106,7 +106,6 @@ /* * Board NAND Info. */ -#define CONFIG_NAND_OMAP_GPMC #define CONFIG_SYS_NAND_ADDR NAND_BASE /* physical address */ /* to access nand */ #define CONFIG_SYS_NAND_BASE NAND_BASE /* physical address */ @@ -252,7 +251,6 @@
#define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" diff --git a/include/configs/cm_t3517.h b/include/configs/cm_t3517.h index 5821183..6eb413d 100644 --- a/include/configs/cm_t3517.h +++ b/include/configs/cm_t3517.h @@ -109,7 +109,6 @@ /* * Board NAND Info. */ -#define CONFIG_NAND_OMAP_GPMC #define CONFIG_SYS_NAND_ADDR NAND_BASE /* physical address */ /* to access nand */ #define CONFIG_SYS_NAND_BASE NAND_BASE /* physical address */ diff --git a/include/configs/cm_t43.h b/include/configs/cm_t43.h index 4c261f8..cc1453a 100644 --- a/include/configs/cm_t43.h +++ b/include/configs/cm_t43.h @@ -26,7 +26,6 @@
/* NAND support */ #define CONFIG_NAND -#define CONFIG_NAND_OMAP_ELM #define CONFIG_SYS_NAND_ONFI_DETECTION #define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_PAGE_SIZE 2048 diff --git a/include/configs/da850evm.h b/include/configs/da850evm.h index 695f3f6..7c348f0 100644 --- a/include/configs/da850evm.h +++ b/include/configs/da850evm.h @@ -200,7 +200,6 @@ #define CONFIG_SPL_NAND_BASE #define CONFIG_SPL_NAND_DRIVERS #define CONFIG_SPL_NAND_ECC -#define CONFIG_SPL_NAND_SIMPLE #define CONFIG_SPL_NAND_LOAD #endif
diff --git a/include/configs/devkit3250.h b/include/configs/devkit3250.h index 6124867..8bb813f 100644 --- a/include/configs/devkit3250.h +++ b/include/configs/devkit3250.h @@ -183,7 +183,6 @@ /* SPL will use serial */
/* SPL loads an image from NAND */ -#define CONFIG_SPL_NAND_SIMPLE #define CONFIG_SPL_NAND_RAW_ONLY #define CONFIG_SPL_NAND_DRIVERS
diff --git a/include/configs/devkit8000.h b/include/configs/devkit8000.h index 5b249d1..8af6f17 100644 --- a/include/configs/devkit8000.h +++ b/include/configs/devkit8000.h @@ -191,7 +191,6 @@ #define CONFIG_SPL_TEXT_BASE 0x40200000 /*CONFIG_SYS_SRAM_START*/
/* NAND boot config */ -#define CONFIG_SYS_NAND_BUSWIDTH_16BIT #define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_PAGE_COUNT 64 #define CONFIG_SYS_NAND_PAGE_SIZE 2048 diff --git a/include/configs/dra7xx_evm.h b/include/configs/dra7xx_evm.h index 1a58c6e..c8b70a7 100644 --- a/include/configs/dra7xx_evm.h +++ b/include/configs/dra7xx_evm.h @@ -171,13 +171,10 @@ #define CONFIG_SYS_NAND_PAGE_SIZE 2048 #define CONFIG_SYS_NAND_OOBSIZE 64 #define CONFIG_SYS_NAND_BLOCK_SIZE (128*1024) -#define CONFIG_SYS_NAND_BUSWIDTH_16BIT #define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ CONFIG_SYS_NAND_PAGE_SIZE) #define CONFIG_SYS_NAND_5_ADDR_CYCLE /* NAND: driver related configs */ -#define CONFIG_NAND_OMAP_GPMC -#define CONFIG_NAND_OMAP_ELM #define CONFIG_SYS_NAND_ONFI_DETECTION #define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH8_CODE_HW #define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS @@ -204,9 +201,6 @@ "-(NAND.file-system)" #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x000c0000 /* NAND: SPL related configs */ -#ifdef CONFIG_SPL_NAND_SUPPORT -#define CONFIG_SPL_NAND_AM33XX_BCH -#endif /* NAND: SPL falcon mode configs */ #ifdef CONFIG_SPL_OS_BOOT #define CONFIG_CMD_SPL_NAND_OFS 0x00080000 /* os-boot params*/ diff --git a/include/configs/ipam390.h b/include/configs/ipam390.h index a21261f..2ac8b0f 100644 --- a/include/configs/ipam390.h +++ b/include/configs/ipam390.h @@ -176,7 +176,6 @@ #define CONFIG_SPL_NAND_BASE #define CONFIG_SPL_NAND_DRIVERS #define CONFIG_SPL_NAND_ECC -#define CONFIG_SPL_NAND_SIMPLE #define CONFIG_SPL_NAND_LOAD
/* diff --git a/include/configs/mcx.h b/include/configs/mcx.h index f255334..a0d8bb6 100644 --- a/include/configs/mcx.h +++ b/include/configs/mcx.h @@ -250,9 +250,6 @@
/* **** PISMO SUPPORT *** */ #define CONFIG_NAND -#define CONFIG_SYS_NAND_BUSWIDTH_16BIT -#define CONFIG_NAND_OMAP_GPMC -#define CONFIG_NAND_OMAP_GPMC_PREFETCH #define SMNAND_ENV_OFFSET 0x180000 /* environment starts here */
/* Redundant Environment */ @@ -280,7 +277,6 @@
#define CONFIG_SPL_NAND_BASE #define CONFIG_SPL_NAND_DRIVERS diff --git a/include/configs/omap3_beagle.h b/include/configs/omap3_beagle.h index a87a75e..5c53351 100644 --- a/include/configs/omap3_beagle.h +++ b/include/configs/omap3_beagle.h @@ -80,7 +80,6 @@ /* * Board NAND Info. */ -#define CONFIG_NAND_OMAP_GPMC #define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of NAND */ /* devices */
@@ -261,7 +260,6 @@ #define CONFIG_SPL_OMAP3_ID_NAND
/* NAND boot config */ -#define CONFIG_SYS_NAND_BUSWIDTH_16BIT #define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_PAGE_COUNT 64 #define CONFIG_SYS_NAND_PAGE_SIZE 2048 diff --git a/include/configs/omap3_cairo.h b/include/configs/omap3_cairo.h index 4f8ce54..069a9bc 100644 --- a/include/configs/omap3_cairo.h +++ b/include/configs/omap3_cairo.h @@ -61,7 +61,6 @@ /* * Board NAND Info. */ -#define CONFIG_NAND_OMAP_GPMC #define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of NAND */ /* devices */ #define CONFIG_EXTRA_ENV_SETTINGS \ diff --git a/include/configs/omap3_evm.h b/include/configs/omap3_evm.h index bc859c8..a021da8 100644 --- a/include/configs/omap3_evm.h +++ b/include/configs/omap3_evm.h @@ -53,7 +53,6 @@ /* #define CONFIG_USB_MUSB_UDC */
/* NAND SPL */ -#define CONFIG_SPL_NAND_SIMPLE #define CONFIG_SPL_NAND_BASE #define CONFIG_SPL_NAND_DRIVERS #define CONFIG_SPL_NAND_ECC @@ -169,7 +168,6 @@
/* Max number of NAND devices */ #define CONFIG_SYS_MAX_NAND_DEVICE 1 -#define CONFIG_SYS_NAND_BUSWIDTH_16BIT /* Timeout values (in ticks) */ #define CONFIG_SYS_FLASH_ERASE_TOUT (100 * CONFIG_SYS_HZ) #define CONFIG_SYS_FLASH_WRITE_TOUT (100 * CONFIG_SYS_HZ) @@ -249,7 +247,6 @@ #if defined(CONFIG_CMD_NAND) #define CONFIG_SYS_FLASH_BASE NAND_BASE
-#define CONFIG_NAND_OMAP_GPMC #define CONFIG_ENV_OFFSET SMNAND_ENV_OFFSET #elif defined(CONFIG_CMD_ONENAND) #define CONFIG_SYS_FLASH_BASE ONENAND_MAP diff --git a/include/configs/omap3_igep00x0.h b/include/configs/omap3_igep00x0.h index 39f1e54..1182cf5 100644 --- a/include/configs/omap3_igep00x0.h +++ b/include/configs/omap3_igep00x0.h @@ -98,7 +98,6 @@
/* NAND config */ #define CONFIG_SPL_OMAP3_ID_NAND -#define CONFIG_SYS_NAND_BUSWIDTH_16BIT #define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_PAGE_COUNT 64 #define CONFIG_SYS_NAND_PAGE_SIZE 2048 @@ -115,7 +114,6 @@ #define CONFIG_SYS_NAND_ECCSIZE 512 #define CONFIG_SYS_NAND_ECCBYTES 14 #define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH8_CODE_HW_DETECTION_SW -#define CONFIG_NAND_OMAP_GPMC #define CONFIG_BCH
/* UBI configuration */ diff --git a/include/configs/omap3_logic.h b/include/configs/omap3_logic.h index e5ffb85..be7e458 100644 --- a/include/configs/omap3_logic.h +++ b/include/configs/omap3_logic.h @@ -71,13 +71,10 @@
/* Board NAND Info. */ #ifdef CONFIG_NAND -#define CONFIG_NAND_OMAP_GPMC - #define CONFIG_SYS_NAND_ADDR NAND_BASE /* physical address */ /* to access nand */ #define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of */ /* NAND devices */ -#define CONFIG_SYS_NAND_BUSWIDTH_16BIT #define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_PAGE_COUNT 64 #define CONFIG_SYS_NAND_PAGE_SIZE 2048 diff --git a/include/configs/omap3_overo.h b/include/configs/omap3_overo.h index bc4a59e..d7999a9 100644 --- a/include/configs/omap3_overo.h +++ b/include/configs/omap3_overo.h @@ -196,7 +196,6 @@ #define CONFIG_SYS_INIT_RAM_SIZE 0x800
/* NAND boot config */ -#define CONFIG_SYS_NAND_BUSWIDTH_16BIT #define CONFIG_SYS_NAND_MAX_ECCPOS 56 #define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_PAGE_COUNT 64 diff --git a/include/configs/omap3_pandora.h b/include/configs/omap3_pandora.h index 53c53ef..9c98091 100644 --- a/include/configs/omap3_pandora.h +++ b/include/configs/omap3_pandora.h @@ -49,7 +49,6 @@ */ #define CONFIG_SYS_NAND_ADDR NAND_BASE /* physical address */ /* to access nand */ -#define CONFIG_SYS_NAND_BUSWIDTH_16BIT #define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_HAM1_CODE_SW #define CONFIG_SYS_NAND_PAGE_SIZE 2048 #define CONFIG_SYS_NAND_OOBSIZE 64 diff --git a/include/configs/omap3_zoom1.h b/include/configs/omap3_zoom1.h index 7f4f56f..67df5d7 100644 --- a/include/configs/omap3_zoom1.h +++ b/include/configs/omap3_zoom1.h @@ -76,7 +76,6 @@ #define CONFIG_SYS_NAND_BASE NAND_BASE /* physical address */ /* to access nand at */ /* CS0 */ -#define CONFIG_SYS_NAND_BUSWIDTH_16BIT
/* Environment information */
diff --git a/include/configs/omapl138_lcdk.h b/include/configs/omapl138_lcdk.h index 08e7deb..b7934d9 100644 --- a/include/configs/omapl138_lcdk.h +++ b/include/configs/omapl138_lcdk.h @@ -160,7 +160,6 @@ #define CONFIG_SYS_NAND_USE_FLASH_BBT #define CONFIG_SYS_NAND_4BIT_HW_ECC_OOBFIRST #define CONFIG_SYS_NAND_PAGE_2K -#define CONFIG_SYS_NAND_BUSWIDTH_16BIT #define CONFIG_SYS_NAND_CS 3 #define CONFIG_SYS_NAND_BASE DAVINCI_ASYNC_EMIF_DATA_CE3_BASE #define CONFIG_SYS_NAND_MASK_CLE 0x10 @@ -192,7 +191,6 @@ #define CONFIG_SPL_NAND_BASE #define CONFIG_SPL_NAND_DRIVERS #define CONFIG_SPL_NAND_ECC -#define CONFIG_SPL_NAND_SIMPLE #define CONFIG_SPL_NAND_LOAD #endif
diff --git a/include/configs/pengwyn.h b/include/configs/pengwyn.h index a76bbce..4e098b8 100644 --- a/include/configs/pengwyn.h +++ b/include/configs/pengwyn.h @@ -114,8 +114,6 @@ /* SPL */
/* NAND support */ -#define CONFIG_NAND_OMAP_GPMC -#define CONFIG_NAND_OMAP_ELM
/* NAND Configuration. */ #define CONFIG_SYS_NAND_5_ADDR_CYCLE diff --git a/include/configs/siemens-am33x-common.h b/include/configs/siemens-am33x-common.h index 5101d70..be88d84 100644 --- a/include/configs/siemens-am33x-common.h +++ b/include/configs/siemens-am33x-common.h @@ -122,7 +122,6 @@
-#define CONFIG_SPL_NAND_AM33XX_BCH #define CONFIG_SPL_NAND_BASE #define CONFIG_SPL_NAND_DRIVERS #define CONFIG_SPL_NAND_ECC @@ -516,8 +515,6 @@ "512k(mtdoops)," \ "-(configuration)"
-#define CONFIG_NAND_OMAP_GPMC -#define CONFIG_NAND_OMAP_ELM #define CONFIG_SYS_NAND_BASE (0x08000000) /* physical address */ /* to access nand at */ /* CS0 */ diff --git a/include/configs/tam3517-common.h b/include/configs/tam3517-common.h index 37f8767..cb6c16b 100644 --- a/include/configs/tam3517-common.h +++ b/include/configs/tam3517-common.h @@ -131,7 +131,6 @@
/* **** PISMO SUPPORT *** */ #define CONFIG_NAND -#define CONFIG_NAND_OMAP_GPMC #define SMNAND_ENV_OFFSET 0x180000 /* environment starts here */
/* Redundant Environment */ @@ -164,7 +163,6 @@ /* Defines for SPL */ #define CONFIG_SPL_FRAMEWORK #define CONFIG_SPL_CONSOLE -#define CONFIG_SPL_NAND_SIMPLE #define CONFIG_SPL_NAND_SOFTECC #define CONFIG_SPL_NAND_WORKSPACE 0x8f07f000 /* below BSS */
@@ -196,7 +194,6 @@ #define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTORS 0x80 /* 64KiB */
/* NAND boot config */ -#define CONFIG_SYS_NAND_BUSWIDTH_16BIT #define CONFIG_SYS_NAND_PAGE_COUNT 64 #define CONFIG_SYS_NAND_PAGE_SIZE 2048 #define CONFIG_SYS_NAND_OOBSIZE 64 @@ -209,7 +206,6 @@ #define CONFIG_SYS_NAND_ECCSIZE 256 #define CONFIG_SYS_NAND_ECCBYTES 3 #define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_HAM1_CODE_SW -#define CONFIG_NAND_OMAP_GPMC_PREFETCH
#define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE
diff --git a/include/configs/tao3530.h b/include/configs/tao3530.h index 1f36ac6..80a1932 100644 --- a/include/configs/tao3530.h +++ b/include/configs/tao3530.h @@ -81,7 +81,6 @@ /* * Board NAND Info. */ -#define CONFIG_NAND_OMAP_GPMC #define CONFIG_SYS_NAND_ADDR NAND_BASE /* physical address */ /* to access nand */ #define CONFIG_SYS_NAND_BASE NAND_BASE /* physical address */ @@ -90,7 +89,6 @@
#define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of NAND */ /* devices */ -#define CONFIG_SYS_NAND_BUSWIDTH_16BIT /* Environment information */
#define CONFIG_EXTRA_ENV_SETTINGS \ @@ -233,7 +231,6 @@
#define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" diff --git a/include/configs/tegra-common.h b/include/configs/tegra-common.h index 723435e..ca9bef3 100644 --- a/include/configs/tegra-common.h +++ b/include/configs/tegra-common.h @@ -89,7 +89,6 @@
/* Defines for SPL */ #define CONFIG_SPL_FRAMEWORK -#define CONFIG_SPL_NAND_SIMPLE #define CONFIG_SPL_MAX_FOOTPRINT (CONFIG_SYS_TEXT_BASE - \ CONFIG_SPL_TEXT_BASE) #define CONFIG_SYS_SPL_MALLOC_SIZE 0x00010000 diff --git a/include/configs/ti816x_evm.h b/include/configs/ti816x_evm.h index bba10ec..f6218d2 100644 --- a/include/configs/ti816x_evm.h +++ b/include/configs/ti816x_evm.h @@ -68,19 +68,15 @@ #define CONFIG_SYS_MAX_NAND_DEVICE 1
/* NAND: SPL related configs */ -#define CONFIG_SPL_NAND_AM33XX_BCH
/* NAND: device related configs */ #define CONFIG_SYS_NAND_5_ADDR_CYCLE -#define CONFIG_SYS_NAND_BUSWIDTH_16BIT #define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ CONFIG_SYS_NAND_PAGE_SIZE) #define CONFIG_SYS_NAND_PAGE_SIZE 2048 #define CONFIG_SYS_NAND_OOBSIZE 64 #define CONFIG_SYS_NAND_BLOCK_SIZE (128*1024) /* NAND: driver related configs */ -#define CONFIG_NAND_OMAP_GPMC_PREFETCH -#define CONFIG_NAND_OMAP_ELM #define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS #define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ 10, 11, 12, 13, 14, 15, 16, 17, \ @@ -113,7 +109,6 @@
/* SPL */ /* Defines for SPL */ -#define CONFIG_SPL_NAND_AM33XX_BCH /* ELM support */ #define CONFIG_SPL_TEXT_BASE 0x40400000 #define CONFIG_SPL_MAX_SIZE (SRAM_SCRATCH_SPACE_ADDR - \ CONFIG_SPL_TEXT_BASE) diff --git a/include/configs/ti_am335x_common.h b/include/configs/ti_am335x_common.h index bf44121..66cacdf 100644 --- a/include/configs/ti_am335x_common.h +++ b/include/configs/ti_am335x_common.h @@ -74,10 +74,6 @@ * s_init when we have SPL used. */
-#ifdef CONFIG_NAND -#define CONFIG_SPL_NAND_AM33XX_BCH /* ELM support */ -#endif - /* Now bring in the rest of the common code. */ #include <configs/ti_armv7_omap.h>
diff --git a/include/configs/ti_armv7_omap.h b/include/configs/ti_armv7_omap.h index 6834500..cf696ff 100644 --- a/include/configs/ti_armv7_omap.h +++ b/include/configs/ti_armv7_omap.h @@ -24,7 +24,6 @@ * access CS0 at is 0x8000000. */ #ifdef CONFIG_NAND -#define CONFIG_NAND_OMAP_GPMC #ifndef CONFIG_SYS_NAND_BASE #define CONFIG_SYS_NAND_BASE 0x8000000 #endif diff --git a/include/configs/ti_omap3_common.h b/include/configs/ti_omap3_common.h index 393d867..2373727 100644 --- a/include/configs/ti_omap3_common.h +++ b/include/configs/ti_omap3_common.h @@ -65,7 +65,6 @@ (64 << 20))
#ifdef CONFIG_NAND -#define CONFIG_SPL_NAND_SIMPLE #define CONFIG_SYS_NAND_BASE 0x30000000 #endif
diff --git a/include/configs/ti_omap4_common.h b/include/configs/ti_omap4_common.h index acfac24..dbf3478 100644 --- a/include/configs/ti_omap4_common.h +++ b/include/configs/ti_omap4_common.h @@ -143,10 +143,6 @@ #define CONFIG_SYS_SPL_ARGS_ADDR (CONFIG_SYS_SDRAM_BASE + \ (128 << 20))
-#ifdef CONFIG_NAND -#define CONFIG_SPL_NAND_AM33XX_BCH /* ELM support */ -#endif - #ifdef CONFIG_SPL_BUILD /* No need for i2c in SPL mode as we will use SRI2C for PMIC access on OMAP4 */ #undef CONFIG_SYS_I2C diff --git a/include/configs/ti_omap5_common.h b/include/configs/ti_omap5_common.h index 4c3a276..e892073 100644 --- a/include/configs/ti_omap5_common.h +++ b/include/configs/ti_omap5_common.h @@ -104,10 +104,6 @@ #define CONFIG_SYS_SPL_ARGS_ADDR (CONFIG_SYS_SDRAM_BASE + \ (128 << 20))
-#ifdef CONFIG_NAND -#define CONFIG_SPL_NAND_AM33XX_BCH /* ELM support */ -#endif - #ifdef CONFIG_SPL_BUILD #undef CONFIG_TIMER #endif diff --git a/include/configs/tricorder.h b/include/configs/tricorder.h index fbdd43a..87c2f90 100644 --- a/include/configs/tricorder.h +++ b/include/configs/tricorder.h @@ -84,7 +84,6 @@ "2m(fdt)," \ "-(ubi)"
-#define CONFIG_NAND_OMAP_GPMC #define CONFIG_SYS_NAND_ADDR NAND_BASE /* physical address */ /* to access nand */ #define CONFIG_SYS_NAND_BASE NAND_BASE /* physical address */ @@ -254,7 +253,6 @@
#define CONFIG_SPL_NAND_BASE #define CONFIG_SPL_NAND_DRIVERS diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 4689d63..d42e839 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -1620,9 +1620,6 @@ CONFIG_NAND_MXC CONFIG_NAND_MXC_V1_1 CONFIG_NAND_NDFC CONFIG_NAND_OMAP_ECCSCHEME -CONFIG_NAND_OMAP_ELM -CONFIG_NAND_OMAP_GPMC -CONFIG_NAND_OMAP_GPMC_PREFETCH CONFIG_NAND_OMAP_GPMC_WSCFG CONFIG_NAND_SECBOOT CONFIG_NAND_SPL @@ -2254,7 +2251,6 @@ CONFIG_SPL_MMC_LOAD CONFIG_SPL_MMC_MINIMAL CONFIG_SPL_MPC83XX_WAIT_FOR_NAND CONFIG_SPL_MXS_PSWITCH_WAIT -CONFIG_SPL_NAND_AM33XX_BCH CONFIG_SPL_NAND_BASE CONFIG_SPL_NAND_BOOT CONFIG_SPL_NAND_DRIVERS @@ -2263,7 +2259,6 @@ CONFIG_SPL_NAND_INIT CONFIG_SPL_NAND_LOAD CONFIG_SPL_NAND_MINIMAL CONFIG_SPL_NAND_RAW_ONLY -CONFIG_SPL_NAND_SIMPLE CONFIG_SPL_NAND_SOFTECC CONFIG_SPL_NAND_WORKSPACE CONFIG_SPL_NO_CPU_SUPPORT_CODE
2017-08-26 15:37 GMT+02:00 Simon Glass sjg@chromium.org:
Tested by: Enric Balletbo i Serra enric.balletbo@collabora.com
Adam Ford
Enric Balletbo Serra
