[U-Boot] [Patch v3] omap4: duovero: Add Gumstix DuoVero machine.
This adds the Gumstix DuoVero machine [1]. This is a OMAP4430-based computer-on-module (COM aka SOM) that can be mounted on various expansion boards with different peripherals.
[1] https://store.gumstix.com/index.php/category/43/
Signed-off-by: Ash Charles ash@gumstix.com Cc: Tom Rini trini@ti.com --- board/gumstix/duovero/Makefile | 8 + board/gumstix/duovero/duovero.c | 264 +++++++++++++++++++++++++++++++ board/gumstix/duovero/duovero_mux_data.h | 199 +++++++++++++++++++++++ boards.cfg | 1 + include/configs/duovero.h | 62 ++++++++ include/configs/ti_omap4_common.h | 9 ++ 6 files changed, 543 insertions(+) create mode 100644 board/gumstix/duovero/Makefile create mode 100644 board/gumstix/duovero/duovero.c create mode 100644 board/gumstix/duovero/duovero_mux_data.h create mode 100644 include/configs/duovero.h
diff --git a/board/gumstix/duovero/Makefile b/board/gumstix/duovero/Makefile new file mode 100644 index 0000000..f738c58 --- /dev/null +++ b/board/gumstix/duovero/Makefile @@ -0,0 +1,8 @@ +# +# (C) Copyright 2000, 2001, 2002 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y := duovero.o diff --git a/board/gumstix/duovero/duovero.c b/board/gumstix/duovero/duovero.c new file mode 100644 index 0000000..fcc5155 --- /dev/null +++ b/board/gumstix/duovero/duovero.c @@ -0,0 +1,264 @@ +/* + * (C) Copyright 2013 + * Gumstix Inc. <www.gumstix.com> + * Maintainer: Ash Charles ash@gumstix.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#include <common.h> +#include <netdev.h> +#include <asm/arch/sys_proto.h> +#include <asm/arch/mmc_host_def.h> +#include <twl6030.h> +#include <asm/emif.h> +#include <asm/arch/clock.h> +#include <asm/arch/gpio.h> +#include <asm/gpio.h> + +#include "duovero_mux_data.h" + +#define WIFI_EN 43 + +#if defined(CONFIG_CMD_NET) +#define SMSC_NRESET 45 +static void setup_net_chip(void); +#endif + +#ifdef CONFIG_USB_EHCI +#include <usb.h> +#include <asm/arch/ehci.h> +#include <asm/ehci-omap.h> +#endif + +DECLARE_GLOBAL_DATA_PTR; + +const struct omap_sysinfo sysinfo = { + "Board: duovero\n" +}; + +struct omap4_scrm_regs *const scrm = (struct omap4_scrm_regs *)0x4a30a000; + +/** + * @brief board_init + * + * @return 0 + */ +int board_init(void) +{ + gpmc_init(); + + gd->bd->bi_arch_number = MACH_TYPE_OMAP4_DUOVERO; + gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100; + + return 0; +} + +/** + * @brief misc_init_r - Configure board specific configurations + * such as power configurations, ethernet initialization as phase2 of + * boot sequence + * + * @return 0 + */ +int misc_init_r(void) +{ + int ret = 0; + u8 val; + + /* wifi setup: first enable 32Khz clock from 6030 pmic */ + val = 0xe1; + ret = i2c_write(TWL6030_CHIP_PM, 0xbe, 1, &val, 1); + if (ret) + printf("Failed to enable 32Khz clock to wifi module\n"); + + /* then setup WIFI_EN as an output pin and send reset pulse */ + if (!gpio_request(WIFI_EN, "")) { + gpio_direction_output(WIFI_EN, 0); + gpio_set_value(WIFI_EN, 1); + udelay(1); + gpio_set_value(WIFI_EN, 0); + udelay(1); + gpio_set_value(WIFI_EN, 1); + } + +#if defined(CONFIG_CMD_NET) + setup_net_chip(); +#endif + return 0; +} + +void set_muxconf_regs_essential(void) +{ + do_set_mux((*ctrl)->control_padconf_core_base, + core_padconf_array_essential, + sizeof(core_padconf_array_essential) / + sizeof(struct pad_conf_entry)); + + do_set_mux((*ctrl)->control_padconf_wkup_base, + wkup_padconf_array_essential, + sizeof(wkup_padconf_array_essential) / + sizeof(struct pad_conf_entry)); + + do_set_mux((*ctrl)->control_padconf_core_base, + core_padconf_array_non_essential, + sizeof(core_padconf_array_non_essential) / + sizeof(struct pad_conf_entry)); + + do_set_mux((*ctrl)->control_padconf_wkup_base, + wkup_padconf_array_non_essential, + sizeof(wkup_padconf_array_non_essential) / + sizeof(struct pad_conf_entry)); +} + +#if !defined(CONFIG_SPL_BUILD) && defined(CONFIG_GENERIC_MMC) +int board_mmc_init(bd_t *bis) +{ + return omap_mmc_init(0, 0, 0, -1, -1); +} +#endif + + +#if defined(CONFIG_CMD_NET) + +#define GPMC_SIZE_16M 0xF +#define GPMC_BASEADDR_MASK 0x3F +#define GPMC_CS_ENABLE 0x1 + +void enable_gpmc_cs_config(const u32 *gpmc_config, struct gpmc_cs *cs, u32 base, + u32 size) +{ + writel(0, &cs->config7); + sdelay(1000); + /* Delay for settling */ + writel(gpmc_config[0], &cs->config1); + writel(gpmc_config[1], &cs->config2); + writel(gpmc_config[2], &cs->config3); + writel(gpmc_config[3], &cs->config4); + writel(gpmc_config[4], &cs->config5); + writel(gpmc_config[5], &cs->config6); + + /* + * Enable the config. size is the CS size and goes in + * bits 11:8. We set bit 6 to enable this CS and the base + * address goes into bits 5:0. + */ + writel((size << 8) | (GPMC_CS_ENABLE << 6) | + ((base >> 24) & GPMC_BASEADDR_MASK), + &cs->config7); + + sdelay(2000); +} + +/* GPMC CS configuration for an SMSC LAN9221 ethernet controller */ +#define NET_LAN9221_GPMC_CONFIG1 0x2a001203 +#define NET_LAN9221_GPMC_CONFIG2 0x000a0a02 +#define NET_LAN9221_GPMC_CONFIG3 0x00020200 +#define NET_LAN9221_GPMC_CONFIG4 0x0a030a03 +#define NET_LAN9221_GPMC_CONFIG5 0x000a0a0a +#define NET_LAN9221_GPMC_CONFIG6 0x8a070707 +#define NET_LAN9221_GPMC_CONFIG7 0x00000f6c + +/* GPMC definitions for LAN9221 chips on expansion boards */ +static const u32 gpmc_lan_config[] = { + NET_LAN9221_GPMC_CONFIG1, + NET_LAN9221_GPMC_CONFIG2, + NET_LAN9221_GPMC_CONFIG3, + NET_LAN9221_GPMC_CONFIG4, + NET_LAN9221_GPMC_CONFIG5, + NET_LAN9221_GPMC_CONFIG6, + /*CONFIG7- computed as params */ +}; + +/* + * Routine: setup_net_chip + * Description: Setting up the configuration GPMC registers specific to the + * Ethernet hardware. + */ +static void setup_net_chip(void) +{ + enable_gpmc_cs_config(gpmc_lan_config, &gpmc_cfg->cs[5], 0x2C000000, + GPMC_SIZE_16M); + + /* Make GPIO SMSC_NRESET as output pin and send reset pulse */ + if (!gpio_request(SMSC_NRESET, "")) { + gpio_direction_output(SMSC_NRESET, 0); + gpio_set_value(SMSC_NRESET, 1); + udelay(1); + gpio_set_value(SMSC_NRESET, 0); + udelay(1); + gpio_set_value(SMSC_NRESET, 1); + } +} +#endif + +int board_eth_init(bd_t *bis) +{ + int rc = 0; +#ifdef CONFIG_SMC911X + rc = smc911x_initialize(0, CONFIG_SMC911X_BASE); +#endif + return rc; +} + +#ifdef CONFIG_USB_EHCI + +static struct omap_usbhs_board_data usbhs_bdata = { + .port_mode[0] = OMAP_EHCI_PORT_MODE_PHY, + .port_mode[1] = OMAP_USBHS_PORT_MODE_UNUSED, + .port_mode[2] = OMAP_USBHS_PORT_MODE_UNUSED, +}; + +int ehci_hcd_init(int index, enum usb_init_type init, + struct ehci_hccr **hccr, struct ehci_hcor **hcor) +{ + int ret; + unsigned int utmi_clk; + u32 auxclk, altclksrc; + + /* Now we can enable our port clocks */ + utmi_clk = readl((void *)CM_L3INIT_HSUSBHOST_CLKCTRL); + utmi_clk |= HSUSBHOST_CLKCTRL_CLKSEL_UTMI_P1_MASK; + setbits_le32((void *)CM_L3INIT_HSUSBHOST_CLKCTRL, utmi_clk); + + auxclk = readl(&scrm->auxclk3); + /* Select sys_clk */ + auxclk &= ~AUXCLK_SRCSELECT_MASK; + auxclk |= AUXCLK_SRCSELECT_SYS_CLK << AUXCLK_SRCSELECT_SHIFT; + /* Set the divisor to 2 */ + auxclk &= ~AUXCLK_CLKDIV_MASK; + auxclk |= AUXCLK_CLKDIV_2 << AUXCLK_CLKDIV_SHIFT; + /* Request auxilary clock #3 */ + auxclk |= AUXCLK_ENABLE_MASK; + writel(auxclk, &scrm->auxclk3); + + altclksrc = readl(&scrm->altclksrc); + + /* Activate alternate system clock supplier */ + altclksrc &= ~ALTCLKSRC_MODE_MASK; + altclksrc |= ALTCLKSRC_MODE_ACTIVE; + + /* enable clocks */ + altclksrc |= ALTCLKSRC_ENABLE_INT_MASK | ALTCLKSRC_ENABLE_EXT_MASK; + + writel(altclksrc, &scrm->altclksrc); + + ret = omap_ehci_hcd_init(index, &usbhs_bdata, hccr, hcor); + if (ret < 0) + return ret; + + return 0; +} + +int ehci_hcd_stop(int index) +{ + return omap_ehci_hcd_stop(); +} +#endif + +/* + * get_board_rev() - get board revision + */ +u32 get_board_rev(void) +{ + return 0x20; +} diff --git a/board/gumstix/duovero/duovero_mux_data.h b/board/gumstix/duovero/duovero_mux_data.h new file mode 100644 index 0000000..1be247b --- /dev/null +++ b/board/gumstix/duovero/duovero_mux_data.h @@ -0,0 +1,199 @@ +/* + * (C) Copyright 2012 + * Gumstix Incorporated, <www.gumstix.com> + * Maintainer: Ash Charles ash@gumstix.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#ifndef _DUOVERO_MUX_DATA_H_ +#define _DUOVERO_MUX_DATA_H_ + +#include <asm/arch/mux_omap4.h> + +const struct pad_conf_entry core_padconf_array_essential[] = { + {SDMMC1_CLK, (PTU | OFF_EN | OFF_OUT_PTD | M0)}, /* sdmmc1_clk */ + {SDMMC1_CMD, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_cmd */ + {SDMMC1_DAT0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat0 */ + {SDMMC1_DAT1, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat1 */ + {SDMMC1_DAT2, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat2 */ + {SDMMC1_DAT3, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat3 */ + {I2C1_SCL, (PTU | IEN | M0)}, /* i2c1_scl */ + {I2C1_SDA, (PTU | IEN | M0)}, /* i2c1_sda */ + {I2C2_SCL, (PTU | IEN | M0)}, /* i2c2_scl */ + {I2C2_SDA, (PTU | IEN | M0)}, /* i2c2_sda */ + {I2C3_SCL, (PTU | IEN | M0)}, /* i2c3_scl */ + {I2C3_SDA, (PTU | IEN | M0)}, /* i2c3_sda */ + {I2C4_SCL, (PTU | IEN | M0)}, /* i2c4_scl */ + {I2C4_SDA, (PTU | IEN | M0)}, /* i2c4_sda */ + {UART3_CTS_RCTX, (PTU | IEN | M0)}, /* uart3_tx */ + {UART3_RTS_SD, (M0)}, /* uart3_rts_sd */ + {UART3_RX_IRRX, (PTU | IEN | M0)}, /* uart3_rx */ + {UART3_TX_IRTX, (M0)} /* uart3_tx */ +}; + +const struct pad_conf_entry wkup_padconf_array_essential[] = { + {PAD1_SR_SCL, (PTU | IEN | M0)}, /* sr_scl */ + {PAD0_SR_SDA, (PTU | IEN | M0)}, /* sr_sda */ + {PAD1_SYS_32K, (IEN | M0)} /* sys_32k */ +}; + +const struct pad_conf_entry core_padconf_array_non_essential[] = { + {GPMC_AD0, (PTU | IEN | M0)}, /* gpmc_ad0 */ + {GPMC_AD1, (PTU | IEN | M0)}, /* gpmc_ad1 */ + {GPMC_AD2, (PTU | IEN | M0)}, /* gpmc_ad2 */ + {GPMC_AD3, (PTU | IEN | M0)}, /* gpmc_ad3 */ + {GPMC_AD4, (PTU | IEN | M0)}, /* gpmc_ad4 */ + {GPMC_AD5, (PTU | IEN | M0)}, /* gpmc_ad5 */ + {GPMC_AD6, (PTU | IEN | M0)}, /* gpmc_ad6 */ + {GPMC_AD7, (PTU | IEN | M0)}, /* gpmc_ad7 */ + {GPMC_AD8, (PTU | IEN | M0)}, /* gpmc_ad8 */ + {GPMC_AD9, (PTU | IEN | M0)}, /* gpmc_ad9 */ + {GPMC_AD10, (PTU | IEN | M0)}, /* gpmc_ad10 */ + {GPMC_AD11, (PTU | IEN | M0)}, /* gpmc_ad11 */ + {GPMC_AD12, (PTU | IEN | M0)}, /* gpmc_ad12 */ + {GPMC_AD13, (PTU | IEN | M0)}, /* gpmc_ad13 */ + {GPMC_AD14, (PTU | IEN | M0)}, /* gpmc_ad14 */ + {GPMC_AD15, (PTU | IEN | M0)}, /* gpmc_ad15 */ + {GPMC_A16, (PTU | IEN | M3)}, /* gpio_40 */ + {GPMC_A17, (PTU | IEN | M3)}, /* gpio_41 - hdmi_ls_oe */ + {GPMC_A18, (PTU | IEN | M3)}, /* gpio_42 */ + {GPMC_A19, (PTU | IEN | M3)}, /* gpio_43 - wifi_en */ + {GPMC_A20, (PTU | IEN | M3)}, /* gpio_44 - eth_irq */ + {GPMC_A21, (PTU | IEN | M3)}, /* gpio_45 - eth_nreset */ + {GPMC_A22, (PTU | IEN | M3)}, /* gpio_46 - eth_pme */ + {GPMC_A23, (PTU | IEN | M3)}, /* gpio_47 */ + {GPMC_A24, (PTU | IEN | M3)}, /* gpio_48 - eth_mdix */ + {GPMC_A25, (PTU | IEN | M3)}, /* gpio_49 - bt_wakeup */ + {GPMC_NCS0, (PTU | M0)}, /* gpmc_ncs0 */ + {GPMC_NCS1, (PTU | M0)}, /* gpmc_ncs1 */ + {GPMC_NCS2, (PTU | M0)}, /* gpmc_ncs2 */ + {GPMC_NCS3, (PTU | IEN | M3)}, /* gpio_53 */ + {C2C_DATA12, (PTU | M0)}, /* gpmc_ncs4 */ + {C2C_DATA13, (PTU | M0)}, /* gpmc_ncs5 - eth_cs */ + {GPMC_NWP, (PTU | IEN | M0)}, /* gpmc_nwp */ + {GPMC_CLK, (PTU | IEN | M0)}, /* gpmc_clk */ + {GPMC_NADV_ALE, (PTU | M0)}, /* gpmc_nadv_ale */ + {GPMC_NBE0_CLE, (PTU | M0)}, /* gpmc_nbe0_cle */ + {GPMC_NBE1, (PTU | M0)}, /* gpmc_nbe1 */ + {GPMC_WAIT0, (PTU | IEN | M0)}, /* gpmc_wait0 */ + {GPMC_WAIT1, (PTU | IEN | M0)}, /* gpio_62 - usbh_nreset */ + {GPMC_NOE, (PTU | M0)}, /* gpmc_noe */ + {GPMC_NWE, (PTU | M0)}, /* gpmc_nwe */ + {HDMI_HPD, (PTD | IEN | M3)}, /* gpio_63 - hdmi_hpd */ + {HDMI_CEC, (PTU | IEN | M0)}, /* hdmi_cec */ + {HDMI_DDC_SCL, (M0)}, /* hdmi_ddc_scl */ + {HDMI_DDC_SDA, (IEN | M0)}, /* hdmi_ddc_sda */ + {CSI21_DX0, (IEN | M0)}, /* csi21_dx0 */ + {CSI21_DY0, (IEN | M0)}, /* csi21_dy0 */ + {CSI21_DX1, (IEN | M0)}, /* csi21_dx1 */ + {CSI21_DY1, (IEN | M0)}, /* csi21_dy1 */ + {CSI21_DX2, (IEN | M0)}, /* csi21_dx2 */ + {CSI21_DY2, (IEN | M0)}, /* csi21_dy2 */ + {CSI21_DX3, (IEN | M0)}, /* csi21_dx3 */ + {CSI21_DY3, (IEN | M0)}, /* csi21_dy3 */ + {CSI21_DX4, (IEN | M0)}, /* csi21_dx4 */ + {CSI21_DY4, (IEN | M0)}, /* csi21_dy4 */ + {CSI22_DX0, (IEN | M0)}, /* csi22_dx0 */ + {CSI22_DY0, (IEN | M0)}, /* csi22_dy0 */ + {CSI22_DX1, (IEN | M0)}, /* csi22_dx1 */ + {CSI22_DY1, (IEN | M0)}, /* csi22_dy1 */ + {USBB1_ULPITLL_CLK, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M4)},/* usbb1_ulpiphy_clk */ + {USBB1_ULPITLL_STP, (OFF_EN | OFF_OUT_PTD | M4)}, /* usbb1_ulpiphy_stp */ + {USBB1_ULPITLL_DIR, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dir */ + {USBB1_ULPITLL_NXT, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_nxt */ + {USBB1_ULPITLL_DAT0, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat0 */ + {USBB1_ULPITLL_DAT1, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat1 */ + {USBB1_ULPITLL_DAT2, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat2 */ + {USBB1_ULPITLL_DAT3, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat3 */ + {USBB1_ULPITLL_DAT4, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat4 */ + {USBB1_ULPITLL_DAT5, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat5 */ + {USBB1_ULPITLL_DAT6, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat6 */ + {USBB1_ULPITLL_DAT7, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat7 */ + {USBB1_HSIC_DATA, (PTU | IEN | M3)}, /* gpio_96 - usbh_cpen */ + {USBB1_HSIC_STROBE, (PTU | IEN | M3)}, /* gpio_97 - usbh_reset */ + {ABE_MCBSP2_CLKX, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_mcbsp2_clkx */ + {ABE_MCBSP2_DR, (IEN | OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp2_dr */ + {ABE_MCBSP2_DX, (OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp2_dx */ + {ABE_MCBSP2_FSX, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_mcbsp2_fsx */ + {ABE_PDM_UL_DATA, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_pdm_ul_data */ + {ABE_PDM_DL_DATA, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_pdm_dl_data */ + {ABE_PDM_FRAME, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_pdm_frame */ + {ABE_PDM_LB_CLK, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_pdm_lb_clk */ + {ABE_CLKS, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_clks */ + {ABE_DMIC_CLK1, (M0)}, /* abe_dmic_clk1 */ + {ABE_DMIC_DIN1, (IEN | M0)}, /* abe_dmic_din1 */ + {ABE_DMIC_DIN2, (IEN | M0)}, /* abe_dmic_din2 */ + {ABE_DMIC_DIN3, (IEN | M0)}, /* abe_dmic_din3 */ + {UART2_CTS, (PTU | IEN | M0)}, /* uart2_cts */ + {UART2_RTS, (M0)}, /* uart2_rts */ + {UART2_RX, (PTU | IEN | M0)}, /* uart2_rx */ + {UART2_TX, (M0)}, /* uart2_tx */ + {HDQ_SIO, (M0)}, /* hdq-sio */ + {MCSPI1_CLK, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi1_clk */ + {MCSPI1_SOMI, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi1_somi */ + {MCSPI1_SIMO, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi1_simo */ + {MCSPI1_CS0, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi1_cs0 */ + {MCSPI1_CS1, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi1_cs1 */ + {SDMMC5_CLK, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc5_clk */ + {SDMMC5_CMD, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc5_cmd */ + {SDMMC5_DAT0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc5_dat0 */ + {SDMMC5_DAT1, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc5_dat1 */ + {SDMMC5_DAT2, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc5_dat2 */ + {SDMMC5_DAT3, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc5_dat3 */ + {MCSPI4_CLK, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi4_clk */ + {MCSPI4_SIMO, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi4_simo */ + {MCSPI4_SOMI, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi4_somi */ + {MCSPI4_CS0, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi4_cs0 */ + {UART4_RX, (IEN | PTU | M0)}, /* uart4_rx */ + {UART4_TX, (M0)}, /* uart4_tx */ + {USBB2_ULPITLL_CLK, (PTU | IEN | M3)}, /* gpio_157 - start_adc */ + {USBB2_ULPITLL_STP, (PTU | IEN | M3)}, /* gpio_158 - spi_nirq */ + {USBB2_ULPITLL_DIR, (PTU | IEN | M3)}, /* gpio_159 - bt_nreset */ + {USBB2_ULPITLL_NXT, (PTU | IEN | M3)}, /* gpio_160 - audio_pwron*/ + {USBB2_ULPITLL_DAT0, (PTU | IEN | M3)}, /* gpio_161 - bid_0 */ + {USBB2_ULPITLL_DAT1, (PTU | IEN | M3)}, /* gpio_162 - bid_1 */ + {USBB2_ULPITLL_DAT2, (PTU | IEN | M3)}, /* gpio_163 - bid_2 */ + {USBB2_ULPITLL_DAT3, (PTU | IEN | M3)}, /* gpio_164 - bid_3 */ + {USBB2_ULPITLL_DAT4, (PTU | IEN | M3)}, /* gpio_165 - bid_4 */ + {USBB2_ULPITLL_DAT5, (PTU | IEN | M3)}, /* gpio_166 - ts_irq*/ + {USBB2_ULPITLL_DAT6, (PTU | IEN | M3)}, /* gpio_167 - gps_pps */ + {USBB2_ULPITLL_DAT7, (PTU | IEN | M3)}, /* gpio_168 */ + {USBB2_HSIC_DATA, (PTU | IEN | M3)}, /* gpio_169 */ + {USBB2_HSIC_STROBE, (PTU | IEN | M3)}, /* gpio_170 */ + {UNIPRO_TX1, (PTU | IEN | M3)}, /* gpio_173 */ + {USBA0_OTG_CE, (PTD | OFF_EN | OFF_PD | OFF_OUT_PTD | M0)}, /* usba0_otg_ce */ + {USBA0_OTG_DP, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* usba0_otg_dp */ + {USBA0_OTG_DM, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* usba0_otg_dm */ + {SYS_NIRQ1, (PTU | IEN | M0)}, /* sys_nirq1 */ + {SYS_NIRQ2, (PTU | IEN | M0)}, /* sys_nirq2 */ + {SYS_BOOT0, (M0)}, /* sys_boot0 */ + {SYS_BOOT1, (M0)}, /* sys_boot1 */ + {SYS_BOOT2, (M0)}, /* sys_boot2 */ + {SYS_BOOT3, (M0)}, /* sys_boot3 */ + {SYS_BOOT4, (M0)}, /* sys_boot4 */ + {SYS_BOOT5, (M0)}, /* sys_boot5 */ + {DPM_EMU0, (IEN | M0)}, /* dpm_emu0 */ + {DPM_EMU1, (IEN | M0)}, /* dpm_emu1 */ + {DPM_EMU16, (PTU | IEN | M3)}, /* gpio_27 */ + {DPM_EMU17, (PTU | IEN | M3)}, /* gpio_28 */ + {DPM_EMU18, (PTU | IEN | M3)}, /* gpio_29 */ + {DPM_EMU19, (PTU | IEN | M3)}, /* gpio_30 */ +}; + +const struct pad_conf_entry wkup_padconf_array_non_essential[] = { + {PAD1_FREF_XTAL_IN, (M0)}, /* fref_xtal_in */ + {PAD0_FREF_SLICER_IN, (M0)}, /* fref_slicer_in */ + {PAD1_FREF_CLK_IOREQ, (M0)}, /* fref_clk_ioreq */ + {PAD0_FREF_CLK0_OUT, (M7)}, /* safe mode */ + {PAD1_FREF_CLK3_REQ, M7}, /* safe mode */ + {PAD0_FREF_CLK3_OUT, (M0)}, /* fref_clk3_out */ + {PAD0_SYS_NRESPWRON, (M0)}, /* sys_nrespwron */ + {PAD1_SYS_NRESWARM, (M0)}, /* sys_nreswarm */ + {PAD0_SYS_PWR_REQ, (PTU | M0)}, /* sys_pwr_req */ + {PAD1_SYS_PWRON_RESET, (M3)}, /* gpio_wk29 */ + {PAD0_SYS_BOOT6, (M0)}, /* sys_boot6 */ + {PAD1_SYS_BOOT7, (M0)}, /* sys_boot7 */ +}; + + +#endif /* _DUOVERO_MUX_DATA_H_ */ diff --git a/boards.cfg b/boards.cfg index 9d90550..88b385a 100644 --- a/boards.cfg +++ b/boards.cfg @@ -358,6 +358,7 @@ Active arm armv7 omap3 ti evm Active arm armv7 omap3 ti evm omap3_evm_quick_nand - - Active arm armv7 omap3 ti sdp3430 omap3_sdp3430 - Nishanth Menon nm@ti.com Active arm armv7 omap3 timll devkit8000 devkit8000 - Thomas Weber weber@corscience.de +Active arm armv7 omap4 gumstix duovero duovero - Ash Charles ash@gumstix.com Active arm armv7 omap4 ti panda omap4_panda - Sricharan R r.sricharan@ti.com Active arm armv7 omap4 ti sdp4430 omap4_sdp4430 - Sricharan R r.sricharan@ti.com Active arm armv7 omap5 ti dra7xx dra7xx_evm dra7xx_evm:CONS_INDEX=1 Lokesh Vutla lokeshvutla@ti.com diff --git a/include/configs/duovero.h b/include/configs/duovero.h new file mode 100644 index 0000000..e68f415 --- /dev/null +++ b/include/configs/duovero.h @@ -0,0 +1,62 @@ +/* + * (C) Copyright: 2013 + * Gumstix, Inc - http://www.gumstix.com + * Maintainer: Ash Charles ash@gumstix.com + * + * Configuration settings for the Gumstix DuoVero board. + * See omap4_common.h for OMAP4 common part + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_DUOVERO_H +#define __CONFIG_DUOVERO_H + +/* + * High Level Configuration Options + */ +#define CONFIG_DUOVERO +#define MACH_TYPE_OMAP4_DUOVERO 4097 /* Until the next sync */ +#define CONFIG_MACH_TYPE MACH_TYPE_OMAP4_DUOVERO + +#include <configs/ti_omap4_common.h> + +#undef CONFIG_SPL_OS_BOOT + +#undef CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS +#define CONFIG_SYS_AUTOMATIC_SDRAM_DETECTION +#define CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS + +#undef CONFIG_SYS_PROMPT +#define CONFIG_SYS_PROMPT "duovero # " + +/* USB UHH support options */ +#define CONFIG_CMD_USB +#define CONFIG_USB_HOST +#define CONFIG_USB_EHCI +#define CONFIG_USB_EHCI_OMAP +#define CONFIG_USB_STORAGE +#define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 3 + +#define CONFIG_OMAP_EHCI_PHY1_RESET_GPIO 1 +#define CONFIG_OMAP_EHCI_PHY2_RESET_GPIO 62 + +#define CONFIG_SYS_ENABLE_PADS_ALL + +#define CONFIG_CMD_PING +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_NET + +#define CONFIG_SMC911X +#define CONFIG_SMC911X_32_BIT +#define CONFIG_SMC911X_BASE 0x2C000000 + +/* GPIO */ +#define CONFIG_CMD_GPIO + +/* ENV related config options */ +#define CONFIG_ENV_IS_NOWHERE + +#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG + +#endif /* __CONFIG_DUOVERO_H */ diff --git a/include/configs/ti_omap4_common.h b/include/configs/ti_omap4_common.h index 77fbfb6..44b3718 100644 --- a/include/configs/ti_omap4_common.h +++ b/include/configs/ti_omap4_common.h @@ -109,9 +109,13 @@ "importbootenv=echo Importing environment from mmc${mmcdev} ...; " \ "env import -t ${loadaddr} ${filesize}\0" \ "loadimage=load mmc ${bootpart} ${loadaddr} ${bootdir}/${bootfile}\0" \ + "loaduimage=load mmc ${mmcdev} ${loadaddr} uImage\0" \ "mmcboot=echo Booting from mmc${mmcdev} ...; " \ "run mmcargs; " \ "bootz ${loadaddr} - ${fdtaddr}\0" \ + "uimageboot=echo Booting from mmc${mmcdev} ...; " \ + "run mmcargs; " \ + "bootm ${loadaddr}\0" \ "findfdt="\ "if test $board_name = sdp4430; then " \ "setenv fdtfile omap4-sdp.dtb; fi; " \ @@ -121,6 +125,8 @@ "setenv fdtfile omap4-panda-a4.dtb; fi;" \ "if test $board_name = panda-es; then " \ "setenv fdtfile omap4-panda-es.dtb; fi;" \ + "if test $board_name = duovero; then " \ + "setenv fdtfile omap4-duovero.dtb; fi;" \ "if test $fdtfile = undefined; then " \ "echo WARNING: Could not determine device tree to use; fi; \0" \ "loadfdt=load mmc ${bootpart} ${fdtaddr} ${bootdir}/${fdtfile}\0" \ @@ -144,6 +150,9 @@ "run loadfdt;" \ "run mmcboot; " \ "fi; " \ + "if run loaduimage; then " \ + "run uimageboot;" \ + "fi; " \ "fi"
After renaming enable_gpmc_cs_config to enable_gpmc_net_config (due to Pekon's series), applied to u-boot-ti/master, thanks!
Ash Charles
