[PATCH] ARM: omap3_logic boards: Convert to DM_ETH
With the converstion of SMC911x to DM, this can facilitate the omap3 boards from LogicPD (now called Beacon EmbeddedWorks) to be converted. There isn't a clean solution to doing this in phases, so the boards are all being done together to avoid breaking functionality.
Because the GPMC bus hasn't been converted, the -u-boot.dtsi node needs to show the address of the ethernet controller for each board.
The board file, which is common betwen the OMAP35 and DM37 SOM LV and Torpedo boards, can remove the manual ethernet initialization, but it still needs to register the address and GPMC configuration for the Ethernet controller which is now being moved around to board_late_init().
Lastly, this patch updates the various config files to add the reference for DM_ETH and remove the SMC address, which is now fetched from the newly created device tree nodes.
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/arch/arm/dts/logicpd-som-lv-35xx-devkit-u-boot.dtsi b/arch/arm/dts/logicpd-som-lv-35xx-devkit-u-boot.dtsi index 173b492cd9..78211fd23c 100644 --- a/arch/arm/dts/logicpd-som-lv-35xx-devkit-u-boot.dtsi +++ b/arch/arm/dts/logicpd-som-lv-35xx-devkit-u-boot.dtsi @@ -15,6 +15,16 @@ /delete-property/ serial1; /delete-property/ serial2; }; + + ethernet@08000000 { + compatible = "smsc,lan9221","smsc,lan9115"; + reg = <0x08000000>; + bank-width = <2>; + vddvario-supply = <&vddvario>; + vdd33a-supply = <&vdd33a>; + reg-io-width = <4>; + smsc,save-mac-address; + }; };
&gpio1 { diff --git a/arch/arm/dts/logicpd-som-lv-37xx-devkit-u-boot.dtsi b/arch/arm/dts/logicpd-som-lv-37xx-devkit-u-boot.dtsi index 173b492cd9..78211fd23c 100644 --- a/arch/arm/dts/logicpd-som-lv-37xx-devkit-u-boot.dtsi +++ b/arch/arm/dts/logicpd-som-lv-37xx-devkit-u-boot.dtsi @@ -15,6 +15,16 @@ /delete-property/ serial1; /delete-property/ serial2; }; + + ethernet@08000000 { + compatible = "smsc,lan9221","smsc,lan9115"; + reg = <0x08000000>; + bank-width = <2>; + vddvario-supply = <&vddvario>; + vdd33a-supply = <&vdd33a>; + reg-io-width = <4>; + smsc,save-mac-address; + }; };
&gpio1 { diff --git a/arch/arm/dts/logicpd-torpedo-35xx-devkit-u-boot.dtsi b/arch/arm/dts/logicpd-torpedo-35xx-devkit-u-boot.dtsi index 581247def0..331ea906a0 100644 --- a/arch/arm/dts/logicpd-torpedo-35xx-devkit-u-boot.dtsi +++ b/arch/arm/dts/logicpd-torpedo-35xx-devkit-u-boot.dtsi @@ -15,6 +15,16 @@ /delete-property/ serial1; /delete-property/ serial2; }; + + ethernet@08000000 { + compatible = "smsc,lan9221","smsc,lan9115"; + reg = <0x08000000>; + bank-width = <2>; + vddvario-supply = <&vddvario>; + vdd33a-supply = <&vdd33a>; + reg-io-width = <4>; + smsc,save-mac-address; + }; };
&gpio1 { diff --git a/arch/arm/dts/logicpd-torpedo-37xx-devkit-u-boot.dtsi b/arch/arm/dts/logicpd-torpedo-37xx-devkit-u-boot.dtsi index 9b709c147c..f63bb53023 100644 --- a/arch/arm/dts/logicpd-torpedo-37xx-devkit-u-boot.dtsi +++ b/arch/arm/dts/logicpd-torpedo-37xx-devkit-u-boot.dtsi @@ -11,6 +11,16 @@ /delete-property/ serial1; /delete-property/ serial2; }; + + ethernet@08000000 { + compatible = "smsc,lan9221","smsc,lan9115"; + reg = <0x08000000>; + bank-width = <2>; + vddvario-supply = <&vddvario>; + vdd33a-supply = <&vdd33a>; + reg-io-width = <4>; + smsc,save-mac-address; + }; };
&i2c1 { diff --git a/board/logicpd/omap3som/omap3logic.c b/board/logicpd/omap3som/omap3logic.c index 21d8a21010..50572c6a71 100644 --- a/board/logicpd/omap3som/omap3logic.c +++ b/board/logicpd/omap3som/omap3logic.c @@ -14,7 +14,6 @@ #include <dm.h> #include <init.h> #include <ns16550.h> -#include <netdev.h> #include <flash.h> #include <nand.h> #include <i2c.h> @@ -58,6 +57,8 @@ DECLARE_GLOBAL_DATA_PTR; #define LOGIC_MT28_OMAP35_ASYNC_GPMC_CONFIG6 0x09030000 #define LOGIC_MT28_OMAP35_ASYNC_GPMC_CONFIG7 0x00000C50
+#define CONFIG_SMC911X_BASE 0x08000000 + #ifdef CONFIG_SPL_OS_BOOT int spl_start_uboot(void) { @@ -204,22 +205,6 @@ static void unlock_nand(void) nand_unlock(mtd, 0, mtd->size, 0); }
-int board_late_init(void) -{ -#ifdef CONFIG_CMD_NAND_LOCK_UNLOCK - unlock_nand(); -#endif - return 0; -} -#endif - -#if defined(CONFIG_MMC) -void board_mmc_power_init(void) -{ - twl4030_power_mmc_init(0); -} -#endif - #ifdef CONFIG_SMC911X /* GPMC CS1 settings for Logic SOM LV/Torpedo LAN92xx Ethernet chip */ static const u32 gpmc_lan92xx_config[] = { @@ -230,12 +215,25 @@ static const u32 gpmc_lan92xx_config[] = { NET_LAN92XX_GPMC_CONFIG5, NET_LAN92XX_GPMC_CONFIG6, }; +#endif
-int board_eth_init(bd_t *bis) +int board_late_init(void) { +#ifdef CONFIG_CMD_NAND_LOCK_UNLOCK + unlock_nand(); +#endif + +#ifdef CONFIG_SMC911X enable_gpmc_cs_config(gpmc_lan92xx_config, &gpmc_cfg->cs[1], CONFIG_SMC911X_BASE, GPMC_SIZE_16M); +#endif + return 0; +} +#endif
- return smc911x_initialize(0, CONFIG_SMC911X_BASE); +#if defined(CONFIG_MMC) +void board_mmc_power_init(void) +{ + twl4030_power_mmc_init(0); } #endif diff --git a/configs/omap35_logic_defconfig b/configs/omap35_logic_defconfig index bcf4efc621..a460ed559e 100644 --- a/configs/omap35_logic_defconfig +++ b/configs/omap35_logic_defconfig @@ -56,8 +56,8 @@ CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y CONFIG_SYS_NAND_U_BOOT_OFFS=0x80000 CONFIG_SPL_NAND_SIMPLE=y +CONFIG_DM_ETH=y CONFIG_SMC911X=y -CONFIG_SMC911X_BASE=0x08000000 CONFIG_SMC911X_32_BIT=y CONFIG_PINCTRL=y CONFIG_PINCTRL_SINGLE=y diff --git a/configs/omap35_logic_somlv_defconfig b/configs/omap35_logic_somlv_defconfig index 51c5d449e0..f6db27f02e 100644 --- a/configs/omap35_logic_somlv_defconfig +++ b/configs/omap35_logic_somlv_defconfig @@ -60,8 +60,8 @@ CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y CONFIG_SYS_NAND_U_BOOT_OFFS=0x80000 CONFIG_SPL_NAND_SIMPLE=y +CONFIG_DM_ETH=y CONFIG_SMC911X=y -CONFIG_SMC911X_BASE=0x08000000 CONFIG_SMC911X_32_BIT=y CONFIG_PINCTRL=y CONFIG_PINCTRL_SINGLE=y diff --git a/configs/omap3_logic_defconfig b/configs/omap3_logic_defconfig index 15925fb7db..918532a66c 100644 --- a/configs/omap3_logic_defconfig +++ b/configs/omap3_logic_defconfig @@ -55,8 +55,8 @@ CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y CONFIG_SYS_NAND_U_BOOT_OFFS=0x80000 CONFIG_SPL_NAND_SIMPLE=y +CONFIG_DM_ETH=y CONFIG_SMC911X=y -CONFIG_SMC911X_BASE=0x08000000 CONFIG_SMC911X_32_BIT=y CONFIG_PINCTRL=y CONFIG_PINCTRL_SINGLE=y diff --git a/configs/omap3_logic_somlv_defconfig b/configs/omap3_logic_somlv_defconfig index ea8fc37f12..4a63437653 100644 --- a/configs/omap3_logic_somlv_defconfig +++ b/configs/omap3_logic_somlv_defconfig @@ -62,8 +62,8 @@ CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y CONFIG_SYS_NAND_U_BOOT_OFFS=0x80000 CONFIG_SPL_NAND_SIMPLE=y +CONFIG_DM_ETH=y CONFIG_SMC911X=y -CONFIG_SMC911X_BASE=0x08000000 CONFIG_SMC911X_32_BIT=y CONFIG_PINCTRL=y CONFIG_PINCTRL_SINGLE=y
Applied to u-boot-ti.
Thanks and regards, Lokesh
Because of this the build is not going through. It is asking to fill in the SMC address value as below:
# # configuration written to .config # .config:1093:warning: symbol value '' invalid for SMC911X_BASE * * Restart config... * * * Network device support * Network device support (NETDEVICES) [Y/n/?] y Enable GbE PHY status parsing and configuration (PHY_GIGE) [N/y/?] n Altera Triple-Speed Ethernet MAC support (ALTERA_TSE) [N/y/?] n Broadcom SF2 (Starfighter2) Ethernet support (BCM_SF2_ETH) [N/y/?] n BCMGENET V5 support (BCMGENET) [N/y/?] n Synopsys DWC Ethernet QOS device support (DWC_ETH_QOS) [N/y/?] n Intel PRO/1000 Gigabit Ethernet support (E1000) [N/y/?] n Synopsys Designware Ethernet MAC (ETH_DESIGNWARE) [N/y/?] n OpenCores 10/100 Mbps Ethernet MAC (ETHOC) [N/y/?] n Freescale FMan ethernet support (FMAN_ENET) [N/y/?] n Ftmac100 Ethernet Support (FTMAC100) [N/y/?] n Ftgmac100 Ethernet Support (FTGMAC100) [N/y/?] n ColdFire Ethernet Support (MCFFEC) [N/y/?] n ColdFire DMA Ethernet Support (FSLDMAFEC) [N/y/?] n Cadence MACB/GEM Ethernet Interface (MACB) [N/y/?] n Enable RGMII (RGMII) [N/y/?] n Enable MII (MII) [N/y/?] n Realtek 8139 series Ethernet controller driver (RTL8139) [N/y/?] n Realtek 8169 series Ethernet controller driver (RTL8169) [N/y/?] n SMSC LAN911x and LAN921x controller driver (SMC911X) [Y/n/?] y SMC911X Base Address (SMC911X_BASE) [] (NEW)
Can you fix it and re send the patch?
- Restart config...
- Network device support
I got ahead of myself. My patch is based on a series [1] which converts SMC911X to DM_ETH.
[1] - https://patchwork.ozlabs.org/cover/1261535/
Until that series is applied, my patch is premature. I'll wait until [1] is applied, then, I'll rebase my patch and re-submit as V2.
Sorry about that.
adam
Adam Ford
Lokesh Vutla
