Re: [U-Boot-Users] ARM Integrator AP patch 2
Made the patch specific to a board/cpu combination as suggested by Peter Pears.
Starting U-boot directly from the flash on the ARM integrator ommitted setting of the Core Module control register flag that remaps SSRAM to the base memory address 0x0000000. The problem surfaces when the ARM core (920T in my case) is mounted on a motherboard.(Integrator AP) and the bootloader started from flash. Starting the bootloader from the ARM debugger does not reveal this problem. It automatically sets this bit by default and explains why some people did not see the problem.
Added documentation to the README file that describes that the options CONFIG_CM9x0, CONFIG_INTEGRATOR and CFG_INTEGRATOR_CM_REMAP should be defined to turn this behaviour on.
Kind greetings,
Jean-Paul Saman
Philips Semiconductors CTO/RTG Building: WDA Philips HighTech Campus tel: +31 (0)40 27 45131
jean-paul.saman+FromInterNet@philips.com Sent by: u-boot-users-admin@lists.sourceforge.net 12-01-2005 14:46
To: u-boot-users@lists.sourceforge.net cc: (bcc: Jean-Paul Saman/EHV/SC/PHILIPS) Subject: [U-Boot-Users] ARM Integrator AP patch Classification: Unclassified
Here is the patch please apply and/or comment on it.
Kind greetings,
Jean-Paul Saman
[attachment "u-boot-12012005-integratorap-jpsaman-1.patch" deleted by Jean-Paul Saman/EHV/SC/PHILIPS]
Hmm,. looks like I forgot to attach the patch. Anyway here is it.:
Kind greetings,
Jean-Paul Saman
jean-paul.saman+FromInterNet@philips.com Sent by: u-boot-users-admin@lists.sourceforge.net 12-01-2005 17:22
To: u-boot-users@lists.sourceforge.net cc: (bcc: Jean-Paul Saman/EHV/SC/PHILIPS) Subject: Re: [U-Boot-Users] ARM Integrator AP patch 2 Classification:
Kind greetings,
Jean-Paul Saman
Kind greetings,
Jean-Paul Saman
------------------------------------------------------- The SF.Net email is sponsored by: Beat the post-holiday blues Get a FREE limited edition SourceForge.net t-shirt from ThinkGeek. It's fun and FREE -- well, almost....http://www.thinkgeek.com/sfshirt _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
jean-paul.saman@philips.com
