Please pull u-boot-marvell/next
Hi Tom,
please pull the following Marvell MVEBU related patches:
---------------------------------------------------------------- - kwboot higher baudrate (Pali & Marek) ----------------------------------------------------------------
Here the Azure build, without any issues:
https://dev.azure.com/sr0718/u-boot/_build/results?buildId=118&view=resu...
Thanks, Stefan
The following changes since commit 7fde64c004ea3ba46a20f7ef6d076f501bcb585f:
Azure/GitLab CI: Update docker image (2021-09-30 11:36:10 -0400)
git@source.denx.de:u-boot/custodians/u-boot-marvell.git next
for you to fetch changes up to 6c96332441cfdfa9093c899aa612f10f1a80719e:
MAINTAINERS: Add entry for kwbimage / kwboot tools (2021-10-01 11:07:13 +0200)
---------------------------------------------------------------- Marek Behún (19): tools: kwbimage: Fix printf format warning tools: kwboot: Fix buffer overflow in kwboot_terminal() tools: kwboot: Make the quit sequence buffer const tools: kwboot: Refactor and fix writing buffer tools: kwboot: Fix comparison of integers with different size tools: kwboot: Use a function to check whether received byte is a Xmodem reply tools: kwboot: Print new line after SPL output tools: kwboot: Allow greater timeout when executing header code tools: kwboot: Prevent waiting indefinitely if no xmodem reply is received tools: kwbimage: Simplify iteration over version 1 optional headers tools: kwbimage: Refactor image_version() tools: kwbimage: Refactor kwbimage header size determination tools: kwboot: Explicitly check against size of struct main_hdr_v1 tools: kwboot: Check whether baudrate was set to requested value tools: kwboot: Cosmetic fix tools: kwboot: Avoid code repetition in kwboot_img_patch() tools: kwboot: Update file header doc/kwboot.1: Update man page MAINTAINERS: Add entry for kwbimage / kwboot tools
Pali Rohár (20): tools: kwboot: Print version information header tools: kwboot: Fix kwboot_xm_sendblock() function when kwboot_tty_recv() fails tools: kwboot: Fix return type of kwboot_xm_makeblock() function tools: kwboot: Fix printing progress tools: kwboot: Print newline on error when progress was not completed tools: kwboot: Split sending image into header and data stages tools: kwboot: Allow non-xmodem text output from BootROM only in a specific case tools: kwboot: Properly finish xmodem transfer tools: kwboot: Always call kwboot_img_patch_hdr() tools: kwboot: Don't patch image header if signed tools: kwboot: Patch source address in image header tools: kwboot: Patch destination address to DDR area for SPI image tools: kwbimage: Update comments describing kwbimage v1 structures tools: kwboot: Round up header size to 128 B when patching tools: kwboot: Support higher baudrates when booting via UART tools: kwboot: Allow any baudrate on Linux tools: kwboot: Fix initializing tty device tools: kwboot: Disable tty interbyte timeout tools: kwboot: Disable non-blocking mode tools: kwboot: Add Pali and Marek as authors
MAINTAINERS | 10 + doc/kwboot.1 | 60 ++- tools/kwbimage.c | 130 ++---- tools/kwbimage.h | 99 +++- tools/kwboot.c | 1197 ++++++++++++++++++++++++++++++++++++++++++------- tools/termios_linux.h | 189 ++++++++ 6 files changed, 1385 insertions(+), 300 deletions(-) create mode 100644 tools/termios_linux.h
Stefan Roese
