[U-Boot-Users] Problems on IDE
Hello,
on my custom board (PXA270) I have an IDE bus on DoM (mapped at 0x14400000) and an IDE bus on PCMCIA/CF (mapped at 0x20000000).
The DoM works while CF not. Here my output (please, note that I modified a bit the cmd_ide code in order to remove a device from Standby Mode):
equantum> pinit on CF Card CFA 128MB CHH 5.0 Fixed Disk Card IDE interface [silicon] [unique] [single] [sleep] [standby] [idle] [low power] equantum> ide reset
Reset IDE: Bus 0: ide_outb (dev= 0, port= 0x1f6, val= 0xe0) : @ 0x144003ec ide_inb (dev= 0, port= 0x1f7) : @ 0x144003ee -> 0x50 OK Bus 1: ide_outb (dev= 2, port= 0x1f6, val= 0xe0) : @ 0x200001f6 ide_inb (dev= 2, port= 0x1f7) : @ 0x200001f7 -> 0x51 OK Device 0: ide_outb (dev= 0, port= 0x1f6, val= 0xe0) : @ 0x144003ec ide_inb (dev= 0, port= 0x1f2) : @ 0x144003e4 -> 0x01 ide_inb (dev= 0, port= 0x1f3) : @ 0x144003e6 -> 0x01 ide_inb (dev= 0, port= 0x1f4) : @ 0x144003e8 -> 0x00 ide_outb (dev= 0, port= 0x1f7, val= 0xec) : @ 0x144003ee ide_inb (dev= 0, port= 0x1f7) : @ 0x144003ee -> 0xd0 ide_inb (dev= 0, port= 0x1f7) : @ 0x144003ee -> 0x58 in input data base for read is 144001f0 Model: PQI IDE DiskOnModule Firm: N050316D Ser#: OD4M0G000015 Type: Hard Disk Capacity: 499.5 MB = 0.4 GB (1023120 x 512) ide_read dev 0 start 0, blocks 1 buffer at A2EFF91C ide_outb (dev= 0, port= 0x1f6, val= 0xe0) : @ 0x144003ec ide_inb (dev= 0, port= 0x1f7) : @ 0x144003ee -> 0x50 ide_outb (dev= 0, port= 0x1f7, val= 0xe5) : @ 0x144003ee ide_inb (dev= 0, port= 0x1f7) : @ 0x144003ee -> 0x50 ide_inb (dev= 0, port= 0x1f2) : @ 0x144003e4 -> 0xff Powersaving FF ide_inb (dev= 0, port= 0x1f7) : @ 0x144003ee -> 0x50 ide_outb (dev= 0, port= 0x1f2, val= 0x01) : @ 0x144003e4 ide_outb (dev= 0, port= 0x1f3, val= 0x00) : @ 0x144003e6 ide_outb (dev= 0, port= 0x1f4, val= 0x00) : @ 0x144003e8 ide_outb (dev= 0, port= 0x1f5, val= 0x00) : @ 0x144003ea ide_outb (dev= 0, port= 0x1f6, val= 0xe0) : @ 0x144003ec ide_outb (dev= 0, port= 0x1f7, val= 0x20) : @ 0x144003ee ide_inb (dev= 0, port= 0x1f7) : @ 0x144003ee -> 0xd0 ide_inb (dev= 0, port= 0x1f7) : @ 0x144003ee -> 0x58 in input data base for read is 144001f0 ide_inb (dev= 0, port= 0x1f7) : @ 0x144003ee -> 0x50 Device 1: ide_outb (dev= 1, port= 0x1f6, val= 0xf0) : @ 0x144001f6 ide_inb (dev= 1, port= 0x1f2) : @ 0x144001f2 -> 0x00 ide_outb (dev= 1, port= 0x1f7, val= 0xec) : @ 0x144001f7 ide_inb (dev= 1, port= 0x1f7) : @ 0x144001f7 -> 0x00 Retrying... ide_outb (dev= 1, port= 0x1f6, val= 0xf0) : @ 0x144001f6 ide_outb (dev= 1, port= 0x1f7, val= 0x08) : @ 0x144001f7 ide_outb (dev= 1, port= 0x1f6, val= 0xf0) : @ 0x144001f6 ide_inb (dev= 1, port= 0x1f2) : @ 0x144001f2 -> 0x00 ide_outb (dev= 1, port= 0x1f7, val= 0xec) : @ 0x144001f7 ide_inb (dev= 1, port= 0x1f7) : @ 0x144001f7 -> 0x00 Retrying... ide_outb (dev= 1, port= 0x1f6, val= 0xf0) : @ 0x144001f6 ide_outb (dev= 1, port= 0x1f7, val= 0x08) : @ 0x144001f7 ide_outb (dev= 1, port= 0x1f6, val= 0xf0) : @ 0x144001f6 not available Device 2: ide_outb (dev= 2, port= 0x1f6, val= 0xe0) : @ 0x200001f6 ide_inb (dev= 2, port= 0x1f2) : @ 0x200001f2 -> 0x01 ide_inb (dev= 2, port= 0x1f3) : @ 0x200001f3 -> 0x01 ide_inb (dev= 2, port= 0x1f4) : @ 0x200001f4 -> 0x00 ide_outb (dev= 2, port= 0x1f7, val= 0xec) : @ 0x200001f7 ide_inb (dev= 2, port= 0x1f7) : @ 0x200001f7 -> 0xd0 ide_inb (dev= 2, port= 0x1f7) : @ 0x200001f7 -> 0x58 in input data base for read is 200001f0 Model: 128MB CHH Firm: Rev 1.00 Ser#: 0524700CA802470033 Type: Removable Hard Disk Capacity: 122.2 MB = 0.1 GB (250368 x 512) ide_read dev 2 start 0, blocks 1 buffer at A2EFF91C ide_outb (dev= 2, port= 0x1f6, val= 0xe0) : @ 0x200001f6 ide_inb (dev= 2, port= 0x1f7) : @ 0x200001f7 -> 0xd0 ide_inb (dev= 2, port= 0x1f7) : @ 0x200001f7 -> 0x51 ide_outb (dev= 2, port= 0x1f7, val= 0xe5) : @ 0x200001f7 ide_inb (dev= 2, port= 0x1f7) : @ 0x200001f7 -> 0xd0 ide_inb (dev= 2, port= 0x1f7) : @ 0x200001f7 -> 0x50 ide_inb (dev= 2, port= 0x1f2) : @ 0x200001f2 -> 0x00 Powersaving 00 ide_outb (dev= 2, port= 0x1f7, val= 0xe3) : @ 0x200001f7 ide_inb (dev= 2, port= 0x1f7) : @ 0x200001f7 -> 0xd0 ide_inb (dev= 2, port= 0x1f7) : @ 0x200001f7 -> 0x50 ide_outb (dev= 2, port= 0x1f7, val= 0xe5) : @ 0x200001f7 ide_inb (dev= 2, port= 0x1f7) : @ 0x200001f7 -> 0x50 ide_inb (dev= 2, port= 0x1f2) : @ 0x200001f2 -> 0xff Powersaving FF ide_inb (dev= 2, port= 0x1f7) : @ 0x200001f7 -> 0x50 ide_outb (dev= 2, port= 0x1f2, val= 0x01) : @ 0x200001f2 ide_outb (dev= 2, port= 0x1f3, val= 0x00) : @ 0x200001f3 ide_outb (dev= 2, port= 0x1f4, val= 0x00) : @ 0x200001f4 ide_outb (dev= 2, port= 0x1f5, val= 0x00) : @ 0x200001f5 ide_outb (dev= 2, port= 0x1f6, val= 0xe0) : @ 0x200001f6 ide_outb (dev= 2, port= 0x1f7, val= 0x20) : @ 0x200001f7 ide_inb (dev= 2, port= 0x1f7) : @ 0x200001f7 -> 0xd0 ide_inb (dev= 2, port= 0x1f7) : @ 0x200001f7 -> 0x51 ide_inb (dev= 2, port= 0x1f1) : @ 0x200001f1 -> 0x10 Error (no IRQ) dev 2 blk 0: status 0x51/0x10 Device 3: ide_outb (dev= 3, port= 0x1f6, val= 0xf0) : @ 0x200001f6 ide_inb (dev= 3, port= 0x1f2) : @ 0x200001f2 -> 0x00 ide_outb (dev= 3, port= 0x1f7, val= 0xec) : @ 0x200001f7 ide_inb (dev= 3, port= 0x1f7) : @ 0x200001f7 -> 0xd0 ide_inb (dev= 3, port= 0x1f7) : @ 0x200001f7 -> 0x58 in input data base for read is 200001f0 Model: 128MB CHH Firm: Rev 1.00 Ser#: 0524700CA802470033 Type: Removable Hard Disk Capacity: 122.2 MB = 0.1 GB (250368 x 512) ide_read dev 3 start 0, blocks 1 buffer at A2EFF91C ide_outb (dev= 3, port= 0x1f6, val= 0xf0) : @ 0x200001f6 ide_inb (dev= 3, port= 0x1f7) : @ 0x200001f7 -> 0x00 ide_outb (dev= 3, port= 0x1f7, val= 0xe5) : @ 0x200001f7 ide_inb (dev= 3, port= 0x1f7) : @ 0x200001f7 -> 0x50 ide_inb (dev= 3, port= 0x1f2) : @ 0x200001f2 -> 0xff Powersaving FF ide_inb (dev= 3, port= 0x1f7) : @ 0x200001f7 -> 0x50 ide_outb (dev= 3, port= 0x1f2, val= 0x01) : @ 0x200001f2 ide_outb (dev= 3, port= 0x1f3, val= 0x00) : @ 0x200001f3 ide_outb (dev= 3, port= 0x1f4, val= 0x00) : @ 0x200001f4 ide_outb (dev= 3, port= 0x1f5, val= 0x00) : @ 0x200001f5 ide_outb (dev= 3, port= 0x1f6, val= 0xf0) : @ 0x200001f6 ide_outb (dev= 3, port= 0x1f7, val= 0x20) : @ 0x200001f7 ide_inb (dev= 3, port= 0x1f7) : @ 0x200001f7 -> 0xd0 ide_inb (dev= 3, port= 0x1f7) : @ 0x200001f7 -> 0x51 ide_inb (dev= 3, port= 0x1f1) : @ 0x200001f1 -> 0x10 Error (no IRQ) dev 3 blk 0: status 0x51/0x10
As you can see device 0 is correctly recognized, device 1 is not present, and device 2 doesn't work while device 3, which is not present, gives answers similar to device 2!
Device 2 is recognized but when the system tries to read the first sector it gets an error!
Note also that on Linux the CF works correctly, so the PCMCIA memory settings should be ok.
Here my board configuration:
#define CONFIG_PXA_PCMCIA 1 #define CONFIG_PXA_IDE 1
#define CFG_IDE_MAXBUS 2 #define CFG_IDE_MAXDEVICE 4
#define CONFIG_PCMCIA_SLOT_A 1 /* just to keep build system happy */
#define CFG_PCMCIA_MEM_ADDR 0x28000000 #define CFG_PCMCIA_MEM_SIZE 0x04000000
/* Memory configuration */ #define CFG_MECR_VAL 0x00000002 #define CFG_MCMEM0_VAL 0x00010504 #define CFG_MCMEM1_VAL 0x00014511 #define CFG_MCATT0_VAL 0x00010504 #define CFG_MCATT1_VAL 0x00014511 #define CFG_MCIO0_VAL 0x00004715 #define CFG_MCIO1_VAL 0x00014511
#define CFG_ATA_BASE_ADDR 0x14000000 #define CFG_ATA_IDE0_OFFSET 0x00400000 /* for the DOM */ #define CFG_ATA_IDE1_OFFSET 0x0c000000 /* for the PCMCIA */
/* IDE device 0 is accessed at 16-bit only (A0 is not used) * while device 1 is accessed at 8-bit */ #define CFG_ATA_PORT_ADDR(dev, port) (((dev) < 1) ? ((port) << 1) : (port))
/* Offset for data I/O */ #define CFG_ATA_DATA_OFFSET 0x1f0
/* Offset for normal register accesses */ #define CFG_ATA_REG_OFFSET 0x1f0
/* Offset for alternate registers */ #define CFG_ATA_ALT_OFFSET 0x3f0
/* We have ATAPI support */ #define CONFIG_ATAPI 1
Does someone know what's wrong?
Thanks,
Rodolfo
Rodolfo Giometti
