[U-Boot] [PATCH] ARM: tegra: increase buffer size and sys args num
Tegra kernel booting needs a long bootargs command line.
Default value of CONFIG_SYS_CBSIZE is too small to printf out the long command line and will cause system panic.
Default value of CONFIG_SYS_MAXARGS is too small to setenv bootargs as the long command line, then kernel won't boot without the complete bootargs.
Increase this 2 config options solve this problem.
Signed-off-by: Bryan Wu pengw@nvidia.com Signed-off-by: Michael Scott hashcode0f@gmail.com Cc: Tom Warren twarren@nvidia.com Cc: Stephen Warren swarren@nvidia.com Cc: Bryan Wu pengw@nvidia.com --- include/configs/tegra-common.h | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/include/configs/tegra-common.h b/include/configs/tegra-common.h index 5d2b12a..a6d7bf1 100644 --- a/include/configs/tegra-common.h +++ b/include/configs/tegra-common.h @@ -107,11 +107,11 @@ * Increasing the size of the IO buffer as default nfsargs size is more * than 256 and so it is not possible to edit it */ -#define CONFIG_SYS_CBSIZE (256 * 2) /* Console I/O Buffer Size */ +#define CONFIG_SYS_CBSIZE (1024 * 2) /* Console I/O Buffer Size */ /* Print Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ sizeof(CONFIG_SYS_PROMPT) + 16) -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_MAXARGS 64 /* max number of command args */ /* Boot Argument Buffer Size */ #define CONFIG_SYS_BARGSIZE (CONFIG_SYS_CBSIZE)
Michael Scott
