[U-Boot] [PATCH] [resend] net: fman: fix 2.5G SGMII settings
The settings for 2.5G SGMII are wrong, which the 2.5G case is missed in set_if_mode(), and the serdes PCS configuration are wrong, this patch uses the correct settings took from Linux.
Signed-off-by: Shaohui Xie Shaohui.Xie@nxp.com --- not sure what was wrong, the patch did not show in patchwork, so resend it. Sorry for the bothering.
drivers/net/fm/eth.c | 32 ++++++++++++++++++++++---------- drivers/net/fm/memac.c | 1 + include/fsl_memac.h | 1 + 3 files changed, 24 insertions(+), 10 deletions(-)
diff --git a/drivers/net/fm/eth.c b/drivers/net/fm/eth.c index eb8e936..543aaa8 100644 --- a/drivers/net/fm/eth.c +++ b/drivers/net/fm/eth.c @@ -45,9 +45,11 @@ static void dtsec_configure_serdes(struct fm_eth *priv)
qsgmii_loop: /* SGMII IF mode + AN enable only for 1G SGMII, not for 2.5G */ - value = PHY_SGMII_IF_MODE_SGMII; - if (!sgmii_2500) - value |= PHY_SGMII_IF_MODE_AN; + value = PHY_SGMII_IF_MODE_SGMII | PHY_SGMII_IF_MODE_AN; + if (sgmii_2500) + value = PHY_SGMII_CR_PHY_RESET | + PHY_SGMII_IF_SPEED_GIGABIT | + PHY_SGMII_IF_MODE_SGMII;
memac_mdio_write(&bus, i, MDIO_DEVAD_NONE, 0x14, value);
@@ -55,15 +57,24 @@ qsgmii_loop: value = PHY_SGMII_DEV_ABILITY_SGMII; memac_mdio_write(&bus, i, MDIO_DEVAD_NONE, 0x4, value);
- /* Adjust link timer for SGMII - - 1.6 ms in units of 8 ns = 2 * 10^5 = 0x30d40 */ - memac_mdio_write(&bus, i, MDIO_DEVAD_NONE, 0x13, 0x3); - memac_mdio_write(&bus, i, MDIO_DEVAD_NONE, 0x12, 0xd40); + if (sgmii_2500) { + /* Adjust link timer for 2.5G SGMII, + * 1.6 ms in units of 3.2 ns: + * 1.6ms / 3.2ns = 5 * 10^5 = 0x7a120. + */ + memac_mdio_write(&bus, i, MDIO_DEVAD_NONE, 0x13, 0x0007); + memac_mdio_write(&bus, i, MDIO_DEVAD_NONE, 0x12, 0xa120); + } else { + /* Adjust link timer for SGMII, + * 1.6 ms in units of 8 ns: + * 1.6ms / 8ns = 2 * 10^5 = 0x30d40. + */ + memac_mdio_write(&bus, i, MDIO_DEVAD_NONE, 0x13, 0x3); + memac_mdio_write(&bus, i, MDIO_DEVAD_NONE, 0x12, 0xd40); + }
/* Restart AN */ - value = PHY_SGMII_CR_DEF_VAL; - if (!sgmii_2500) - value |= PHY_SGMII_CR_RESET_AN; + value = PHY_SGMII_CR_DEF_VAL | PHY_SGMII_CR_RESET_AN; memac_mdio_write(&bus, i, MDIO_DEVAD_NONE, 0, value);
if ((priv->enet_if == PHY_INTERFACE_MODE_QSGMII) && (i < 3)) { @@ -391,6 +402,7 @@ static int fm_eth_startup(struct fm_eth *fm_eth)
/* For some reason we need to set SPEED_100 */ if (((fm_eth->enet_if == PHY_INTERFACE_MODE_SGMII) || + (fm_eth->enet_if == PHY_INTERFACE_MODE_SGMII_2500) || (fm_eth->enet_if == PHY_INTERFACE_MODE_QSGMII)) && mac->set_if_mode) mac->set_if_mode(mac, fm_eth->enet_if, SPEED_100); diff --git a/drivers/net/fm/memac.c b/drivers/net/fm/memac.c index 81a64bf..1b5779c 100644 --- a/drivers/net/fm/memac.c +++ b/drivers/net/fm/memac.c @@ -90,6 +90,7 @@ static void memac_set_interface_mode(struct fsl_enet_mac *mac, if_mode |= (IF_MODE_GMII | IF_MODE_RM); break; case PHY_INTERFACE_MODE_SGMII: + case PHY_INTERFACE_MODE_SGMII_2500: case PHY_INTERFACE_MODE_QSGMII: if_mode &= ~IF_MODE_MASK; if_mode |= (IF_MODE_GMII); diff --git a/include/fsl_memac.h b/include/fsl_memac.h index bed2a40..431c2a0 100644 --- a/include/fsl_memac.h +++ b/include/fsl_memac.h @@ -226,6 +226,7 @@ struct memac { #define PHY_SGMII_CR_PHY_RESET 0x8000 #define PHY_SGMII_CR_RESET_AN 0x0200 #define PHY_SGMII_CR_DEF_VAL 0x1140 +#define PHY_SGMII_IF_SPEED_GIGABIT 0x0008 #define PHY_SGMII_DEV_ABILITY_SGMII 0x4001 #define PHY_SGMII_IF_MODE_AN 0x0002 #define PHY_SGMII_IF_MODE_SGMII 0x0001
shh.xie@gmail.com
