[U-Boot] [PATCH 1/8] (RESEND) arm/pxa: remove unused u-boot.lds from board/vpac270
This file is not used, automatically generated u-boot.lds is used instead
Signed-off-by: Mikhail Kshevetskiy mikhail.kshevetskiy@gmail.com --- board/vpac270/u-boot.lds | 55 ---------------------------------------------- 1 files changed, 0 insertions(+), 55 deletions(-) delete mode 100644 board/vpac270/u-boot.lds
diff --git a/board/vpac270/u-boot.lds b/board/vpac270/u-boot.lds deleted file mode 100644 index 58c371d..0000000 --- a/board/vpac270/u-boot.lds +++ /dev/null @@ -1,55 +0,0 @@ -/* - * (C) Copyright 2000 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") -OUTPUT_ARCH(arm) -ENTRY(_start) -SECTIONS -{ - . = 0x00000000; - - . = ALIGN(4); - .text : - { - cpu/pxa/start.o (.text) - *(.text) - } - - . = ALIGN(4); - .rodata : { *(.rodata) } - - . = ALIGN(4); - .data : { *(.data) } - - . = ALIGN(4); - .got : { *(.got) } - - __u_boot_cmd_start = .; - .u_boot_cmd : { *(.u_boot_cmd) } - __u_boot_cmd_end = .; - - . = ALIGN(4); - __bss_start = .; - .bss : { *(.bss) } - _end = .; -}
Signed-off-by: Mikhail Kshevetskiy mikhail.kshevetskiy@gmail.com --- include/configs/vpac270.h | 3 +++ 1 files changed, 3 insertions(+), 0 deletions(-)
diff --git a/include/configs/vpac270.h b/include/configs/vpac270.h index 694a8f9..1e4d4c5 100644 --- a/include/configs/vpac270.h +++ b/include/configs/vpac270.h @@ -58,7 +58,10 @@ * Serial Console Configuration */ #define CONFIG_PXA_SERIAL +#define CONFIG_SERIAL_MULTI #define CONFIG_FFUART 1 +#define CONFIG_STUART 1 +#define CONFIG_BTUART 1 #define CONFIG_BAUDRATE 115200 #define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 }
* CONFIG_SYS_CLKS_IN_HZ is not used anywhere, so removing it * CONFIG_SYS_HZ is set to 1000 on most architectures, so it seems to be the safe default
v2: rebased against for-wd-master branch
Signed-off-by: Mikhail Kshevetskiy mikhail.kshevetskiy@gmail.com --- include/configs/vpac270.h | 3 +-- 1 files changed, 1 insertions(+), 2 deletions(-)
diff --git a/include/configs/vpac270.h b/include/configs/vpac270.h index 1e4d4c5..eb2dc93 100644 --- a/include/configs/vpac270.h +++ b/include/configs/vpac270.h @@ -149,8 +149,7 @@ /* * Clock Configuration */ -#undef CONFIG_SYS_CLKS_IN_HZ -#define CONFIG_SYS_HZ 3250000 /* Timer @ 3250000 Hz */ +#define CONFIG_SYS_HZ 1000 /* Timer @ 3250000 Hz */ #define CONFIG_SYS_CPUSPEED 0x190 /* 312MHz */
Define ENV_ADDR as MONITOR_BASE + MONITOR_LEN. Fix environment sector size (NOR: 32Kb for first four sectors and 128Kb for other; OneNAND: 128Kb).
Last but not least: we have MONITOR_LEN = 0x40000 and one sector for environment (size = 0x20000), so the kernel may start from 0x00060000 only.
Signed-off-by: Mikhail Kshevetskiy mikhail.kshevetskiy@gmail.com --- include/configs/vpac270.h | 11 ++++++++--- 1 files changed, 8 insertions(+), 3 deletions(-)
diff --git a/include/configs/vpac270.h b/include/configs/vpac270.h index eb2dc93..c81d567 100644 --- a/include/configs/vpac270.h +++ b/include/configs/vpac270.h @@ -45,7 +45,7 @@ "if ide reset && fatload ide 0 0xa4000000 uImage; then " \ "bootm 0xa4000000; " \ "fi; " \ - "bootm 0x40000;" + "bootm 0x60000;" #define CONFIG_BOOTARGS "console=tty0 console=ttyS0,115200" #define CONFIG_TIMESTAMP #define CONFIG_BOOTDELAY 2 /* Autoboot delay */ @@ -214,7 +214,12 @@ #define CONFIG_SYS_FLASH_PROTECTION 1
#define CONFIG_ENV_IS_IN_FLASH 1 -#define CONFIG_ENV_SECT_SIZE 0x4000 + +/* + * if (CONFIG_SYS_MONITOR_LEN <= 0x18000) CONFIG_ENV_SECT_SIZE = 0x8000; + * else CONFIG_ENV_SECT_SIZE = 0x20000 + */ +#define CONFIG_ENV_SECT_SIZE 0x20000
#elif defined(CONFIG_CMD_ONENAND) /* OneNAND */ #define CONFIG_SYS_NO_FLASH @@ -231,7 +236,7 @@ #define CONFIG_SYS_MONITOR_BASE 0x0 #define CONFIG_SYS_MONITOR_LEN 0x40000
-#define CONFIG_ENV_ADDR 0x40000 +#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) #define CONFIG_ENV_SIZE 0x4000
it looks like 4Kb for environment and 64Kb for stack is sufficient
Signed-off-by: Mikhail Kshevetskiy mikhail.kshevetskiy@gmail.com --- include/configs/vpac270.h | 4 ++-- 1 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/include/configs/vpac270.h b/include/configs/vpac270.h index c81d567..bd1b0f6 100644 --- a/include/configs/vpac270.h +++ b/include/configs/vpac270.h @@ -155,7 +155,7 @@ /* * Stack sizes */ -#define CONFIG_STACKSIZE (128*1024) /* regular stack */ +#define CONFIG_STACKSIZE (64*1024) /* regular stack */ #ifdef CONFIG_USE_IRQ #define CONFIG_STACKSIZE_IRQ (4*1024) /* IRQ stack */ #define CONFIG_STACKSIZE_FIQ (4*1024) /* FIQ stack */ @@ -237,7 +237,7 @@ #define CONFIG_SYS_MONITOR_LEN 0x40000
#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) -#define CONFIG_ENV_SIZE 0x4000 +#define CONFIG_ENV_SIZE (4 * 1024)
/* * IDE
it looks like u-boot allocates a buffer of CONFIG_ENV_SECT_SIZE size when making "saveenv" command. In our case CONFIG_ENV_SECT_SIZE is 128Kb, so having CONFIG_SYS_MALLOC_LEN = 128Kb is not sufficient.
Increase CONFIG_SYS_MALLOC_LEN to (196Kb + space for environment) to resolve a problem.
Signed-off-by: Mikhail Kshevetskiy mikhail.kshevetskiy@gmail.com --- include/configs/vpac270.h | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/include/configs/vpac270.h b/include/configs/vpac270.h index bd1b0f6..3ca25bf 100644 --- a/include/configs/vpac270.h +++ b/include/configs/vpac270.h @@ -32,7 +32,7 @@ * Environment settings */ #define CONFIG_ENV_OVERWRITE -#define CONFIG_SYS_MALLOC_LEN (128*1024) +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 196*1024) #define CONFIG_SYS_GBL_DATA_SIZE 128
#define CONFIG_BOOTCOMMAND \
pxa_mem_setup macro use r6 to store CONFIG_SYS_MDREFR_VAL during memory initialization. This reg is modified during execution of pxa_wait_ticks. Later we use r6 to setup MDREFR[APD] bit. As result MDREFR[APD] is always zero.
Signed-off-by: Mikhail Kshevetskiy mikhail.kshevetskiy@gmail.com --- arch/arm/include/asm/arch-pxa/macro.h | 20 ++++++++++++-------- 1 files changed, 12 insertions(+), 8 deletions(-)
diff --git a/arch/arm/include/asm/arch-pxa/macro.h b/arch/arm/include/asm/arch-pxa/macro.h index 035a57e..5a480fd 100644 --- a/arch/arm/include/asm/arch-pxa/macro.h +++ b/arch/arm/include/asm/arch-pxa/macro.h @@ -102,7 +102,11 @@ /* * This macro sets up the Memory controller of the PXA2xx CPU * - * Clobbered regs: r3, r4, r5 + * WARNING: This macro uses internally r3 and r7 regs for MEMC_BASE + * and CONFIG_SYS_MDREFR_VAL correspondingly. Please do not + * use this regs for other purpose inside this macro. + * + * Clobbered regs: r3, r4, r5, r6, r7 */ .macro pxa_mem_setup /* This comes handy when setting MDREFR */ @@ -157,7 +161,7 @@ bic r5, r5, #0xf00 /* MDREFR user config with zeroed DRI */
ldr r4, =CONFIG_SYS_MDREFR_VAL - mov r6, r4 + mov r7, r4 lsl r4, #20 lsr r4, #20 /* Get a valid DRI field */
@@ -187,12 +191,12 @@ * 6) Initialize SDRAM */
- bic r6, #MDREFR_SLFRSH - str r6, [r3, #MDREFR_OFFSET] + bic r7, #MDREFR_SLFRSH + str r7, [r3, #MDREFR_OFFSET] ldr r4, [r3, #MDREFR_OFFSET]
- orr r6, #MDREFR_E1PIN - str r6, [r3, #MDREFR_OFFSET] + orr r7, #MDREFR_E1PIN + str r7, [r3, #MDREFR_OFFSET] ldr r4, [r3, #MDREFR_OFFSET]
/* @@ -250,8 +254,8 @@ */
ldr r4, [r3, #MDREFR_OFFSET] - and r6, r6, #MDREFR_APD - orr r4, r4, r6 + and r7, r7, #MDREFR_APD + orr r4, r4, r7 str r4, [r3, #MDREFR_OFFSET] ldr r4, [r3, #MDREFR_OFFSET] .endm
WARNING: This macro do not assume the values for K0DB4, KxDB2, KxFREE, K1RUN, K2RUN and APD bits of CONFIG_SYS_MDREFR_VAL as it was done early on many pxa platforms. All pxa developers that plan
v1: * strict following to section 6.4.10 of Intel PXA27xx Developer's Manual. * use r7 to store CONFIG_SYS_MDREFR_VAL as r6 is used in pxa_wait_ticks.
v2: * rename pxa_mem_setup macro to pxa2xx_mem_setup * setting of MDREFR[K1RUN] and MDREFR[K2RUN] bits may be optional * skip certain configuration steps if SDRAM is not present/configured * improve/fix comments
v3: * move fixing of MDREFR[APD] bit setting to separate patch * revert skip certain configuration steps if SDRAM is not present/configured * improve/fix comments
PS: This patch is for review only, it should not go upstream at this point.
--- arch/arm/include/asm/arch-pxa/macro.h | 84 +++++++++++++++++++++------------ 1 files changed, 54 insertions(+), 30 deletions(-)
diff --git a/arch/arm/include/asm/arch-pxa/macro.h b/arch/arm/include/asm/arch-pxa/macro.h index 5a480fd..410e90b 100644 --- a/arch/arm/include/asm/arch-pxa/macro.h +++ b/arch/arm/include/asm/arch-pxa/macro.h @@ -107,10 +107,14 @@ * use this regs for other purpose inside this macro. * * Clobbered regs: r3, r4, r5, r6, r7 + * + * See section 6.4.10 of Intel PXA2xx Processor Developer's Manual + * http://www.marvell.com/products/processors/applications/pxa_family/pxa_27x_d... */ .macro pxa_mem_setup /* This comes handy when setting MDREFR */ ldr r3, =MEMC_BASE + ldr r7, =CONFIG_SYS_MDREFR_VAL
/* * 1) Initialize Asynchronous static memory controller @@ -153,51 +157,66 @@ */
/* - * Before accessing MDREFR we need a valid DRI field, so we set - * this to power on defaults + DRI field. + * Before accessing MDREFR we need a valid DRI field. + * Also we must properly configure MDREFR[K0DB2] and MDREFR[K0DB4]. + * Optionaly we can set MDREFR[KxFREE] bits. + * So we set MDREFR to power on defaults + (DRI, K0DB2, K0DB4, KxFREE) + * fields from the config. + * + * WARNING: K0DB2 and K0DB4 bits are usually set, while KxFREE bits + * are usually unset. */ ldr r5, [r3, #MDREFR_OFFSET] - bic r5, r5, #0x0ff - bic r5, r5, #0xf00 /* MDREFR user config with zeroed DRI */ - - ldr r4, =CONFIG_SYS_MDREFR_VAL - mov r7, r4 - lsl r4, #20 - lsr r4, #20 /* Get a valid DRI field */ - - orr r5, r5, r4 /* MDREFR user config with correct DRI */ + ldr r4, =( 0xFFF | MDREFR_K0DB4 | MDREFR_K0DB2 | \ + MDREFR_K0FREE | MDREFR_K1FREE | MDREFR_K2FREE ) + bic r5, r5, r4 /* clear DRI, K0DB2, K0DB4, KxFREE fields */ + and r4, r7, r4 + orr r5, r5, r4 /* use custom DRI, K0DB2, K0DB4, KxFREE */
orr r5, #MDREFR_K0RUN orr r5, #MDREFR_SLFRSH bic r5, #MDREFR_APD - bic r5, #MDREFR_E1PIN + + /* enable them later, if SDRAM is present */ + bic r5, #( MDREFR_E1PIN | MDREFR_K1RUN | MDREFR_K2RUN | \ + MDREFR_K1DB2 | MDREFR_K2DB2 )
str r5, [r3, #MDREFR_OFFSET] - ldr r4, [r3, #MDREFR_OFFSET] + ldr r5, [r3, #MDREFR_OFFSET]
/* * 5) Initialize Synchronous Static Memory (Flash/Peripherals) */
- /* Initialize SXCNFG register. Assert the enable bits. - * - * Write SXMRS to cause an MRS command to all enabled banks of - * synchronous static memory. Note that SXLCR need not be written - * at this time. + /* Initialize SXCNFG register to enable synchronous flash memory. + * While the synchronous flash banks are being configured, the SDRAM + * banks must be disabled and MDREFR[APD] must be de-asserted. */ write32rb (MEMC_BASE + SXCNFG_OFFSET), CONFIG_SYS_SXCNFG_VAL
/* - * 6) Initialize SDRAM + * 6) Initialize SDRAM, + * If SDRAM present, then MDREFR[K1RUN] and/or MDREFR[K2RUN] bits + * must be set. Also we must properly configure MDREFR[K1DB2] and + * MDREFR[K2DB2] in this case. + * + * WARNING: K1DB2 and K2DB2 bits are usually set if SDRAM present */
- bic r7, #MDREFR_SLFRSH - str r7, [r3, #MDREFR_OFFSET] - ldr r4, [r3, #MDREFR_OFFSET] + and r4, r7, #( MDREFR_K1RUN | MDREFR_K2RUN | \ + MDREFR_K1DB2 | MDREFR_K2DB2 ) + ldr r6, [r3, #MDREFR_OFFSET] + orr r6, r6, r4 + str r6, [r3, #MDREFR_OFFSET] + ldr r6, [r3, #MDREFR_OFFSET]
- orr r7, #MDREFR_E1PIN - str r7, [r3, #MDREFR_OFFSET] - ldr r4, [r3, #MDREFR_OFFSET] + bic r6, #MDREFR_SLFRSH + str r6, [r3, #MDREFR_OFFSET] + ldr r6, [r3, #MDREFR_OFFSET] + + orr r6, #MDREFR_E1PIN + str r6, [r3, #MDREFR_OFFSET] + ldr r6, [r3, #MDREFR_OFFSET]
/* * 7) Write MDCNFG with MDCNFG:DEx deasserted (set to 0), to configure @@ -230,7 +249,7 @@ .endr
/* - * 9) Write MDCNFG with enable bits asserted (MDCNFG:DEx set to 1). + * 9) Set custom MDCNFG[DEx] bits to enable required SDRAM partitions */
ldr r5, =CONFIG_SYS_MDCNFG_VAL @@ -242,7 +261,10 @@ ldr r4, [r3, #MDCNFG_OFFSET]
/* - * 10) Write MDMRS. + * 10) Write to MDMRS register to trigger an MRS command to + * all enabled banks of SDRAM. For each SDRAM partition pair + * that has one or both partitions enabled, this forces a pass + * through the MRS state and a return to NOP. */
ldr r4, =CONFIG_SYS_MDMRS_VAL @@ -250,12 +272,14 @@ ldr r4, [r3, #MDMRS_OFFSET]
/* - * 11) Enable APD + * 11) Optionaly enable auto-power-down by setting MDREFR[APD] + * + * WARNING: APD bit is usually set. */
ldr r4, [r3, #MDREFR_OFFSET] - and r7, r7, #MDREFR_APD - orr r4, r4, r7 + and r6, r7, #MDREFR_APD + orr r4, r4, r6 str r4, [r3, #MDREFR_OFFSET] ldr r4, [r3, #MDREFR_OFFSET] .endm
Mikhail Kshevetskiy
