[U-Boot] [PATCH] ARM: rpi: fix RPi1 board rev detection for warranty bit
Apparently the firmware's board rev response includes both the board revision and some other data even on the RPi1. In particular, the "warranty bit" is bit 24. We need to mask that out when looking up the board ID.
Signed-off-by: Stephen Warren swarren@wwwdotorg.org --- board/raspberrypi/rpi/rpi.c | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/board/raspberrypi/rpi/rpi.c b/board/raspberrypi/rpi/rpi.c index 50a699bb9e0c..a105953541be 100644 --- a/board/raspberrypi/rpi/rpi.c +++ b/board/raspberrypi/rpi/rpi.c @@ -278,10 +278,17 @@ static void get_board_rev(void) * https://github.com/pimoroni/RPi.version/blob/master/RPi/version.py * http://www.raspberrypi.org/forums/viewtopic.php?f=63&t=99293&p=69028... * (a few posts down) + * + * For the RPi 1, bit 24 is the "warranty bit", so we mask off just the + * lower byte to use as the board rev: + * http://www.raspberrypi.org/forums/viewtopic.php?f=63&t=98367&start=2... + * http://www.raspberrypi.org/forums/viewtopic.php?f=31&t=20594 */ rpi_board_rev = msg->get_board_rev.body.resp.rev; if (rpi_board_rev & 0x800000) rpi_board_rev = (rpi_board_rev >> 4) & 0xff; + else + rpi_board_rev &= 0xff; if (rpi_board_rev >= ARRAY_SIZE(models)) { printf("RPI: Board rev %u outside known range\n", rpi_board_rev);
Stephen Warren
