[U-Boot-Users] [PATCH 2/2][SH] Hitachi MS7750SE Support
6 May
2007
6 May
'07
10:15 p.m.
Hi , all.
I had MS7750SE[0] that was one of the reference boards of SH correspond to u-boot.
Now , 0 . Serial 1 . SDRAM 2 . Flash working.
As for this board, NIC that is called STNIC is installed. However, This has not been ported for u-boot yet. I plan to support this NIC in the future.
[0] : http://www.hitachi-ul.co.jp/e/SH-SE/index.html
Nobuhiro Iwamatsu
E-Mail : iwamatsu@nigauri.org
GPG ID : 3170EBE9
Signed-off-by: Nobuhiro Iwamatsu iwamatsu@nigauri.org
diff --git a/board/ms7750se/ms7750se.c b/board/ms7750se/ms7750se.c
new file mode 100644
index 0000000..4b4697b
--- /dev/null
+++ b/board/ms7750se/ms7750se.c
@@ -0,0 +1,51 @@
+ * Copyright (C) 2007
+ * Nobuhiro Iwamatsu iwamatsu@nigauri.org
+ * See file CREDITS for list of people who contributed to this
+ * project.
+ * This program is free software; you can redistribute it and/or
+ * modify it under the terms of the GNU General Public License as
+ * published by the Free Software Foundation; either version 2 of
+ * the License, or (at your option) any later version.
+ * This program is distributed in the hope that it will be useful,
+ * but WITHOUT ANY WARRANTY; without even the implied warranty of
+ * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+ * GNU General Public License for more details.
+ * You should have received a copy of the GNU General Public License
+ * along with this program; if not, write to the Free Software
+ * Foundation, Inc., 59 Temple Place, Suite 330, Boston,
+ * MA 02111-1307 USA
+#include <common.h>
+#include <asm/processor.h>
+int checkboard(void)
+ puts("BOARD: SH7750 Solution Engine\n");
+ return 0;
+int board_init(void)
+ return 0;
+int dram_init (void)
+ DECLARE_GLOBAL_DATA_PTR;
+ gd->bd->bi_memstart = CFG_SDRAM_BASE;
+ gd->bd->bi_memsize = CFG_SDRAM_SIZE;
+ printf("DRAM: %dMB\n", CFG_SDRAM_SIZE / (1024 * 1024));
+ return 0;
+int board_late_init(void)
+ return 0;
diff --git a/board/ms7750se/u-boot.lds b/board/ms7750se/u-boot.lds
index 0000000..5b35cfa
--- /dev/null
+++ b/board/ms7750se/u-boot.lds
@@ -0,0 +1,106 @@
+ * Copyrigth (c) 2007
+ * project.
+OUTPUT_FORMAT("elf32-sh-linux", "elf32-sh-linux", "elf32-sh-linux")
+OUTPUT_ARCH(sh)
+ENTRY(_start)
+SECTIONS
+ Base address of internal SDRAM is 0x0C000000.
+ Although size of SDRAM can be either 16 or 32 MBytes,
+ we assume 16 MBytes (ie ignore upper half if the full
+ 32 MBytes is present).
+ NOTE: This address must match with the definition of
+ TEXT_BASE in config.mk (in this directory).
+ . = 0x8C000000 + (64*1024*1024) - (256*1024);
+ PROVIDE (reloc_dst = .);
+ PROVIDE (_ftext = .);
+ PROVIDE (_fcode = .);
+ PROVIDE (_start = .);
+ .text :
+ cpu/sh4/start.o (.text)
+ . = ALIGN(8192);
+ common/environment.o (.ppcenv)
+ . = ALIGN(8192);
+ common/environment.o (.ppcenvr)
+ . = ALIGN(8192);
+ *(.text)
+ . = ALIGN(4);
+ } =0xFF
+ PROVIDE (_ecode = .);
+ .rodata :
+ *(.rodata)
+ . = ALIGN(4);
+ PROVIDE (_etext = .);
+ PROVIDE (_fdata = .);
+ .data :
+ *(.data)
+ . = ALIGN(4);
+ PROVIDE (_edata = .);
+ PROVIDE (_fgot = .);
+ .got :
+ *(.got)
+ . = ALIGN(4);
+ PROVIDE (_egot = .);
+ PROVIDE (__u_boot_cmd_start = .);
+ .u_boot_cmd :
+ *(.u_boot_cmd)
+ . = ALIGN(4);
+ PROVIDE (__u_boot_cmd_end = .);
+ PROVIDE (reloc_dst_end = .);
+ /* _reloc_dst_end = .; */
+ PROVIDE (bss_start = .);
+ PROVIDE (__bss_start = .);
+ .bss :
+ *(.bss)
+ . = ALIGN(4);
+ PROVIDE (bss_end = .);
+ PROVIDE (_end = .);
diff --git a/include/configs/ms7750se.h b/include/configs/ms7750se.h
index 0000000..0467a5e
--- /dev/null
+++ b/include/configs/ms7750se.h
@@ -0,0 +1,75 @@
+#ifndef __CONFIG_H
+#define __CONFIG_H
+#undef DEBUG
+#define CONFIG_SH 1
+#define CONFIG_SH4 1
+#define CONFIG_CPU_SH7750 1
+#define CONFIG_MS7750SE 1
+#define __LITTLE_ENDIAN__ 1
+//#define CONFIG_COMMANDS (CONFIG_CMD_DFL | CFG_CMD_NET |CFG_CMD_PING)
+#define CONFIG_COMMANDS CONFIG_CMD_DFL & ~CFG_CMD_NET
+#define CFG_SCIF_CONSOLE 1
+#define CONFIG_BAUDRATE 38400
+#define CONFIG_CONS_SCIF1 1
+#define BOARD_LATE_INIT 1
+#include <cmd_confdefs.h>
+#define CONFIG_BOOTDELAY -1
+#define CONFIG_BOOTARGS "console=ttySC0,115200"
+#define CONFIG_ENV_OVERWRITE 1
+#define CFG_SDRAM_BASE (0x8C000000)
+#define CFG_SDRAM_SIZE (64 * 1024 * 1024)
+#define CFG_LONGHELP
+#define CFG_PROMPT "=> "
+#define CFG_CBSIZE 256
+#define CFG_PBSIZE 256
+#define CFG_MAXARGS 16
+#define CFG_BARGSIZE 512
+#define CFG_BAUDRATE_TABLE { 115200, 57600, 38400, 19200, 9600 } /* List of legal baudrate settings for this board */
+#define CFG_MEMTEST_START (CFG_SDRAM_BASE)
+#define CFG_MEMTEST_END (TEXT_BASE - 0x100000)
+#define CFG_LOAD_ADDR (CFG_SDRAM_BASE + 4 * 1024 * 1024)
+#define CFG_MONITOR_BASE (CFG_FLASH_BASE) /* Address of u-boot image in Flash */
+#define CFG_MONITOR_LEN (128 * 1024)
+#define CFG_MALLOC_LEN (256 * 1024) /* Size of DRAM reserved for malloc() use */
+#define CFG_GBL_DATA_SIZE (256) /* size in bytes reserved for initial data */
+#define CFG_BOOTMAPSZ (8 * 1024 * 1024)
+#define CFG_RX_ETH_BUFFER (8)
+#define CFG_FLASH_CFI
+#define CFG_FLASH_CFI_DRIVER
+#undef CFG_FLASH_CFI_BROKEN_TABLE
+#undef CFG_FLASH_QUIET_TEST
+#define CFG_FLASH_EMPTY_INFO /* print 'E' for empty sector on flinfo */
+#define CFG_FLASH_BASE (0xA1000000)
+#define CFG_MAX_FLASH_BANKS (1) /* Max number of
+ * Flash memory banks
+#define CFG_MAX_FLASH_SECT 142
+#define CFG_FLASH_BANKS_LIST { CFG_FLASH_BASE }
+#define CFG_ENV_IS_IN_FLASH
+#define CFG_ENV_SECT_SIZE 0x20000
+#define CFG_ENV_SIZE (CFG_ENV_SECT_SIZE)
+#define CFG_ENV_ADDR (CFG_MONITOR_BASE + CFG_MONITOR_LEN)
+#define CFG_FLASH_ERASE_TOUT 120000
+#define CFG_FLASH_WRITE_TOUT 500
+#define CONFIG_SYS_CLK_FREQ 33333333
+#define TMU_CLK_DIVIDER 4
+#define CFG_HZ (CONFIG_SYS_CLK_FREQ / TMU_CLK_DIVIDER)
+#define CFG_PLL_SETTLING_TIME 100 /* in us */
+#endif /* __CONFIG_H */
6575
Nobuhiro Iwamatsu
