[U-Boot] [PATCH] Convert CONFIG_SKIP_LOWLEVEL_INIT et al to Kconfig
This converts the following to Kconfig: CONFIG_SKIP_LOWLEVEL_INIT CONFIG_SKIP_LOWLEVEL_INIT_ONLY
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/Kconfig b/Kconfig index 1f0904f704..15c84a1c65 100644 --- a/Kconfig +++ b/Kconfig @@ -57,6 +57,31 @@ config LOCALVERSION_AUTO
which is done within the script "scripts/setlocalversion".)
+config SKIP_LOWLEVEL_INIT + bool "Skip low-level initialization" + depends on ARM || NDS32 || MIPS || RISCV + help + If this variable is defined, then certain + low level initializations (like setting up the memory + controller) are omitted and/or U-Boot does not + relocate itself into RAM. + + Normally this variable MUST NOT be defined. The only + exception is when U-Boot is loaded (to RAM) by some + other boot loader or by a debugger which performs + these initializations itself. + + This is different from SKIP_LOWLEVEL_INIT_ONLY available + for some ARM users. + +config SKIP_LOWLEVEL_INIT_ONLY + bool "Skip only lowlevel_init() call" + depends on ARM + help + This allows just the call to lowlevel_init() + to be skipped. The normal CP15 init (such as enabling the + instruction cache) is still performed. + config CC_OPTIMIZE_FOR_SIZE bool "Optimize for size" default y diff --git a/README b/README index 1389e8ff12..2a06e278d8 100644 --- a/README +++ b/README @@ -3076,11 +3076,6 @@ Low Level (hardware related) configuration options: other boot loader or by a debugger which performs these initializations itself.
-- CONFIG_SKIP_LOWLEVEL_INIT_ONLY - [ARM926EJ-S only] This allows just the call to lowlevel_init() - to be skipped. The normal CP15 init (such as enabling the - instruction cache) is still performed. - - CONFIG_SPL_BUILD Modifies the behaviour of start.S when compiling a loader that is executed before the actual U-Boot. E.g. when diff --git a/arch/arm/mach-mvebu/include/mach/config.h b/arch/arm/mach-mvebu/include/mach/config.h index bbcfcfd141..84c3bab4b6 100644 --- a/arch/arm/mach-mvebu/include/mach/config.h +++ b/arch/arm/mach-mvebu/include/mach/config.h @@ -27,10 +27,6 @@
#define CONFIG_SYS_L2_PL310
-#ifdef CONFIG_SPL_BUILD -#define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */ -#endif - /* * By default the generated mvebu kwbimage.cfg is used * If for some board, different configuration file need to be used, diff --git a/board/freescale/ls1021aqds/README b/board/freescale/ls1021aqds/README index 6cf7146fb2..2d3b22d78b 100644 --- a/board/freescale/ls1021aqds/README +++ b/board/freescale/ls1021aqds/README @@ -115,4 +115,3 @@ LS1021a rev1.0 Soc specific Options/Settings -------------------------------------------- If the LS1021a Soc is rev1.0, you need modify the configure file. Add the following define in include/configs/ls1021aqds.h: -#define CONFIG_SKIP_LOWLEVEL_INIT diff --git a/board/freescale/ls1021atwr/README b/board/freescale/ls1021atwr/README index 896a659476..e3b9e5a454 100644 --- a/board/freescale/ls1021atwr/README +++ b/board/freescale/ls1021atwr/README @@ -112,4 +112,3 @@ LS1021a rev1.0 Soc specific Options/Settings -------------------------------------------- If the LS1021a Soc is rev1.0, you need modify the configure file. Add the following define in include/configs/ls1021atwr.h: -#define CONFIG_SKIP_LOWLEVEL_INIT diff --git a/configs/SBx81LIFKW_defconfig b/configs/SBx81LIFKW_defconfig index db843db9c2..dca37db14c 100644 --- a/configs/SBx81LIFKW_defconfig +++ b/configs/SBx81LIFKW_defconfig @@ -5,6 +5,7 @@ CONFIG_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x00600000 CONFIG_TARGET_SBx81LIFKW=y CONFIG_IDENT_STRING="\nSBx81LIFKW" +CONFIG_SKIP_LOWLEVEL_INIT=y # CONFIG_SYS_MALLOC_F is not set CONFIG_BOOTDELAY=3 CONFIG_SILENT_CONSOLE=y diff --git a/configs/SBx81LIFXCAT_defconfig b/configs/SBx81LIFXCAT_defconfig index c06ad6e32f..2d16415231 100644 --- a/configs/SBx81LIFXCAT_defconfig +++ b/configs/SBx81LIFXCAT_defconfig @@ -5,6 +5,7 @@ CONFIG_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x00600000 CONFIG_TARGET_SBx81LIFXCAT=y CONFIG_IDENT_STRING="\nSBx81LIFXCAT" +CONFIG_SKIP_LOWLEVEL_INIT=y # CONFIG_SYS_MALLOC_F is not set CONFIG_BOOTDELAY=3 CONFIG_SILENT_CONSOLE=y diff --git a/configs/am335x_baltos_defconfig b/configs/am335x_baltos_defconfig index d6db96c379..e9e2b10bc1 100644 --- a/configs/am335x_baltos_defconfig +++ b/configs/am335x_baltos_defconfig @@ -10,6 +10,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/am335x_boneblack_vboot_defconfig b/configs/am335x_boneblack_vboot_defconfig index 47c4e99233..c58caeed51 100644 --- a/configs/am335x_boneblack_vboot_defconfig +++ b/configs/am335x_boneblack_vboot_defconfig @@ -6,6 +6,7 @@ CONFIG_ARCH_OMAP2PLUS=y CONFIG_TI_COMMON_CMD_OPTIONS=y CONFIG_AM33XX=y CONFIG_SPL=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y diff --git a/configs/am335x_evm_defconfig b/configs/am335x_evm_defconfig index 2aa9b65caf..95756d0fd0 100644 --- a/configs/am335x_evm_defconfig +++ b/configs/am335x_evm_defconfig @@ -4,6 +4,7 @@ CONFIG_ARCH_OMAP2PLUS=y CONFIG_TI_COMMON_CMD_OPTIONS=y CONFIG_AM33XX=y CONFIG_SPL=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_SPL_LOAD_FIT=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/am335x_guardian_defconfig b/configs/am335x_guardian_defconfig index 3cada51d35..78830eda92 100644 --- a/configs/am335x_guardian_defconfig +++ b/configs/am335x_guardian_defconfig @@ -14,6 +14,7 @@ CONFIG_ENV_OFFSET=0x300000 CONFIG_SPL=y CONFIG_BOOTSTAGE_STASH_ADDR=0x0 CONFIG_SPL_LIBDISK_SUPPORT=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_CONSOLE_MUX=y CONFIG_SYS_CONSOLE_INFO_QUIET=y diff --git a/configs/am335x_hs_evm_defconfig b/configs/am335x_hs_evm_defconfig index f5da7f674f..864c07f840 100644 --- a/configs/am335x_hs_evm_defconfig +++ b/configs/am335x_hs_evm_defconfig @@ -6,6 +6,7 @@ CONFIG_ISW_ENTRY_ADDR=0x40300350 CONFIG_TI_COMMON_CMD_OPTIONS=y CONFIG_AM33XX=y CONFIG_SPL=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_IMAGE_POST_PROCESS=y CONFIG_SPL_LOAD_FIT=y diff --git a/configs/am335x_hs_evm_uart_defconfig b/configs/am335x_hs_evm_uart_defconfig index 3708a6f623..a914bcdeb9 100644 --- a/configs/am335x_hs_evm_uart_defconfig +++ b/configs/am335x_hs_evm_uart_defconfig @@ -9,6 +9,7 @@ CONFIG_AM33XX=y CONFIG_SPL=y # CONFIG_SPL_FS_FAT is not set # CONFIG_SPL_LIBDISK_SUPPORT is not set +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_IMAGE_POST_PROCESS=y CONFIG_SPL_LOAD_FIT=y diff --git a/configs/am335x_igep003x_defconfig b/configs/am335x_igep003x_defconfig index 8ed52a5ffb..cdab2a6315 100644 --- a/configs/am335x_igep003x_defconfig +++ b/configs/am335x_igep003x_defconfig @@ -13,6 +13,7 @@ CONFIG_ENV_SIZE=0x18000 CONFIG_SPL=y CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="MACH_TYPE=MACH_TYPE_IGEP0033" diff --git a/configs/am335x_pdu001_defconfig b/configs/am335x_pdu001_defconfig index e69f81b6e5..4ca2f7545f 100644 --- a/configs/am335x_pdu001_defconfig +++ b/configs/am335x_pdu001_defconfig @@ -12,6 +12,7 @@ CONFIG_SPL=y CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_LOCALVERSION="-EETS-1.0.0" +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=1 # CONFIG_USE_BOOTCOMMAND is not set diff --git a/configs/am335x_shc_defconfig b/configs/am335x_shc_defconfig index 5698208f84..6d9836900b 100644 --- a/configs/am335x_shc_defconfig +++ b/configs/am335x_shc_defconfig @@ -14,6 +14,7 @@ CONFIG_SPL=y CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SERIES=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_SHOW_BOOT_PROGRESS=y # CONFIG_USE_BOOTCOMMAND is not set diff --git a/configs/am335x_shc_ict_defconfig b/configs/am335x_shc_ict_defconfig index 3f8a6bad03..787f78c04e 100644 --- a/configs/am335x_shc_ict_defconfig +++ b/configs/am335x_shc_ict_defconfig @@ -15,6 +15,7 @@ CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SHC_ICT=y CONFIG_SERIES=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_SHOW_BOOT_PROGRESS=y # CONFIG_USE_BOOTCOMMAND is not set diff --git a/configs/am335x_shc_netboot_defconfig b/configs/am335x_shc_netboot_defconfig index d0a7d62a24..e2bef56ccb 100644 --- a/configs/am335x_shc_netboot_defconfig +++ b/configs/am335x_shc_netboot_defconfig @@ -15,6 +15,7 @@ CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SHC_NETBOOT=y CONFIG_SERIES=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_SHOW_BOOT_PROGRESS=y # CONFIG_USE_BOOTCOMMAND is not set diff --git a/configs/am335x_shc_sdboot_defconfig b/configs/am335x_shc_sdboot_defconfig index 30fa40abda..f0473143f4 100644 --- a/configs/am335x_shc_sdboot_defconfig +++ b/configs/am335x_shc_sdboot_defconfig @@ -15,6 +15,7 @@ CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SHC_SDBOOT=y CONFIG_SERIES=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_SHOW_BOOT_PROGRESS=y # CONFIG_USE_BOOTCOMMAND is not set diff --git a/configs/am335x_sl50_defconfig b/configs/am335x_sl50_defconfig index 01fc52b4ed..690fc4c378 100644 --- a/configs/am335x_sl50_defconfig +++ b/configs/am335x_sl50_defconfig @@ -12,6 +12,7 @@ CONFIG_ENV_OFFSET=0x0 CONFIG_SPL=y CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_EXTRA_OPTIONS="EMMC_BOOT" CONFIG_SYS_CONSOLE_INFO_QUIET=y diff --git a/configs/am43xx_evm_defconfig b/configs/am43xx_evm_defconfig index 7c74047f3a..12996bf288 100644 --- a/configs/am43xx_evm_defconfig +++ b/configs/am43xx_evm_defconfig @@ -7,6 +7,7 @@ CONFIG_AM43XX=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_ENV_SIZE=0x10000 CONFIG_SPL=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_SPL_LOAD_FIT=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=1" diff --git a/configs/am43xx_evm_rtconly_defconfig b/configs/am43xx_evm_rtconly_defconfig index caf761b565..64a103c41d 100644 --- a/configs/am43xx_evm_rtconly_defconfig +++ b/configs/am43xx_evm_rtconly_defconfig @@ -7,6 +7,7 @@ CONFIG_AM43XX=y CONFIG_SPL_RTC_DDR_SUPPORT=y CONFIG_ENV_SIZE=0x10000 CONFIG_SPL=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_SPL_LOAD_FIT=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=1" diff --git a/configs/am43xx_evm_usbhost_boot_defconfig b/configs/am43xx_evm_usbhost_boot_defconfig index 9a2f31fef0..01da927c5b 100644 --- a/configs/am43xx_evm_usbhost_boot_defconfig +++ b/configs/am43xx_evm_usbhost_boot_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_AM43XX=y CONFIG_ENV_SIZE=0x10000 CONFIG_SPL=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_SPL_LOAD_FIT=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=1" @@ -15,9 +16,9 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_OS_BOOT=y +CONFIG_SPL_USB_HOST_SUPPORT=y CONFIG_SPL_USB_GADGET=y CONFIG_SPL_USB_ETHER=y -CONFIG_SPL_USB_HOST_SUPPORT=y CONFIG_CMD_SPL=y CONFIG_CMD_SPL_NAND_OFS=0x00100000 CONFIG_CMD_SPL_WRITE_SIZE=0x40000 diff --git a/configs/am43xx_hs_evm_defconfig b/configs/am43xx_hs_evm_defconfig index d634ab1450..9da350949b 100644 --- a/configs/am43xx_hs_evm_defconfig +++ b/configs/am43xx_hs_evm_defconfig @@ -11,6 +11,8 @@ CONFIG_TI_SECURE_EMIF_TOTAL_REGION_SIZE=0x02000000 CONFIG_TI_SECURE_EMIF_PROTECTED_REGION_SIZE=0x01c00000 CONFIG_ENV_SIZE=0x10000 CONFIG_SPL=y +CONFIG_SPL_TEXT_BASE=0x403018E0 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_IMAGE_POST_PROCESS=y CONFIG_SPL_LOAD_FIT=y @@ -21,7 +23,6 @@ CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=1" CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_MISC_INIT_R is not set CONFIG_VERSION_VARIABLE=y -CONFIG_SPL_TEXT_BASE=0x403018E0 CONFIG_SPL_ETH_SUPPORT=y CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_NET_SUPPORT=y diff --git a/configs/am65x_evm_a53_defconfig b/configs/am65x_evm_a53_defconfig index 9d02dbc01a..daa42f9290 100644 --- a/configs/am65x_evm_a53_defconfig +++ b/configs/am65x_evm_a53_defconfig @@ -12,13 +12,14 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL_STACK_R_ADDR=0x82000000 CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y +CONFIG_SPL_TEXT_BASE=0x80080000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_LOAD_FIT=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTCOMMAND="run findfdt; run envboot; run init_${boot}; run get_kern_${boot}; run get_fdt_${boot}; run get_overlay_${boot}; run run_kern" # CONFIG_DISPLAY_CPUINFO is not set -CONFIG_SPL_TEXT_BASE=0x80080000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y CONFIG_SPL_SEPARATE_BSS=y diff --git a/configs/am65x_hs_evm_a53_defconfig b/configs/am65x_hs_evm_a53_defconfig index 87547ed9ab..1f072504e9 100644 --- a/configs/am65x_hs_evm_a53_defconfig +++ b/configs/am65x_hs_evm_a53_defconfig @@ -13,6 +13,8 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL_STACK_R_ADDR=0x82000000 CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y +CONFIG_SPL_TEXT_BASE=0x80080000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_FIT_IMAGE_POST_PROCESS=y @@ -21,7 +23,6 @@ CONFIG_SPL_FIT_IMAGE_POST_PROCESS=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTCOMMAND="run findfdt; run envboot; run init_${boot}; run get_kern_${boot}; run get_fdt_${boot}; run get_overlay_${boot}; run run_kern" # CONFIG_DISPLAY_CPUINFO is not set -CONFIG_SPL_TEXT_BASE=0x80080000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y CONFIG_SPL_SEPARATE_BSS=y diff --git a/configs/arndale_defconfig b/configs/arndale_defconfig index 012d6f571d..b73a7c377c 100644 --- a/configs/arndale_defconfig +++ b/configs/arndale_defconfig @@ -7,6 +7,8 @@ CONFIG_TARGET_ARNDALE=y CONFIG_NR_DRAM_BANKS=8 CONFIG_SPL=y CONFIG_IDENT_STRING=" for ARNDALE" +CONFIG_SPL_TEXT_BASE=0x02023400 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y @@ -14,7 +16,6 @@ CONFIG_USE_PREBOOT=y CONFIG_SILENT_CONSOLE=y CONFIG_CONSOLE_MUX=y # CONFIG_SPL_FRAMEWORK is not set -CONFIG_SPL_TEXT_BASE=0x02023400 CONFIG_SYS_PROMPT="ARNDALE # " CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y diff --git a/configs/aspenite_defconfig b/configs/aspenite_defconfig index 8e677172cf..8ddfda60a9 100644 --- a/configs/aspenite_defconfig +++ b/configs/aspenite_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_ASPENITE=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_NR_DRAM_BANKS=2 CONFIG_IDENT_STRING="\nMarvell-Aspenite DB" +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_BOOTDELAY=3 CONFIG_USE_PREBOOT=y # CONFIG_DISPLAY_BOARDINFO is not set diff --git a/configs/at91rm9200ek_ram_defconfig b/configs/at91rm9200ek_ram_defconfig index 93171912bc..d6fa3c1a2f 100644 --- a/configs/at91rm9200ek_ram_defconfig +++ b/configs/at91rm9200ek_ram_defconfig @@ -7,6 +7,7 @@ CONFIG_ENV_SIZE=0x10000 CONFIG_ENV_OFFSET=0x40000 CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SECT_SIZE=0x10000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_CPUINFO is not set diff --git a/configs/at91sam9260ek_dataflash_cs0_defconfig b/configs/at91sam9260ek_dataflash_cs0_defconfig index ef1b3b46be..ae5598e085 100644 --- a/configs/at91sam9260ek_dataflash_cs0_defconfig +++ b/configs/at91sam9260ek_dataflash_cs0_defconfig @@ -12,6 +12,7 @@ CONFIG_DEBUG_UART_BASE=0xfffff200 CONFIG_DEBUG_UART_CLOCK=132000000 CONFIG_ENV_SECT_SIZE=0x210 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9260,SYS_USE_DATAFLASH_CS0" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/at91sam9260ek_dataflash_cs1_defconfig b/configs/at91sam9260ek_dataflash_cs1_defconfig index 89129ce2f9..0fe8174532 100644 --- a/configs/at91sam9260ek_dataflash_cs1_defconfig +++ b/configs/at91sam9260ek_dataflash_cs1_defconfig @@ -12,6 +12,7 @@ CONFIG_DEBUG_UART_BASE=0xfffff200 CONFIG_DEBUG_UART_CLOCK=132000000 CONFIG_ENV_SECT_SIZE=0x210 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9260,SYS_USE_DATAFLASH_CS1" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/at91sam9260ek_nandflash_defconfig b/configs/at91sam9260ek_nandflash_defconfig index 79ef08c8ce..a3a6ddf6c1 100644 --- a/configs/at91sam9260ek_nandflash_defconfig +++ b/configs/at91sam9260ek_nandflash_defconfig @@ -9,6 +9,7 @@ CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0xfffff200 CONFIG_DEBUG_UART_CLOCK=132000000 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9260,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/at91sam9261ek_dataflash_cs0_defconfig b/configs/at91sam9261ek_dataflash_cs0_defconfig index 410f71142d..650641d51e 100644 --- a/configs/at91sam9261ek_dataflash_cs0_defconfig +++ b/configs/at91sam9261ek_dataflash_cs0_defconfig @@ -11,6 +11,7 @@ CONFIG_DEBUG_UART_BASE=0xfffff200 CONFIG_DEBUG_UART_CLOCK=100000000 CONFIG_ENV_SECT_SIZE=0x210 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9261,SYS_USE_DATAFLASH_CS0" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/at91sam9261ek_dataflash_cs3_defconfig b/configs/at91sam9261ek_dataflash_cs3_defconfig index 83437583b6..ea82cdfa1b 100644 --- a/configs/at91sam9261ek_dataflash_cs3_defconfig +++ b/configs/at91sam9261ek_dataflash_cs3_defconfig @@ -11,6 +11,7 @@ CONFIG_DEBUG_UART_BASE=0xfffff200 CONFIG_DEBUG_UART_CLOCK=100000000 CONFIG_ENV_SECT_SIZE=0x210 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9261,SYS_USE_DATAFLASH_CS3" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/at91sam9261ek_nandflash_defconfig b/configs/at91sam9261ek_nandflash_defconfig index 471715ab86..46d985dc3f 100644 --- a/configs/at91sam9261ek_nandflash_defconfig +++ b/configs/at91sam9261ek_nandflash_defconfig @@ -8,6 +8,7 @@ CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0xfffff200 CONFIG_DEBUG_UART_CLOCK=100000000 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9261,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/at91sam9263ek_dataflash_cs0_defconfig b/configs/at91sam9263ek_dataflash_cs0_defconfig index ce30dbb370..d4203828ad 100644 --- a/configs/at91sam9263ek_dataflash_cs0_defconfig +++ b/configs/at91sam9263ek_dataflash_cs0_defconfig @@ -12,6 +12,7 @@ CONFIG_DEBUG_UART_BASE=0xffffee00 CONFIG_DEBUG_UART_CLOCK=100000000 CONFIG_ENV_SECT_SIZE=0x210 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263,SYS_USE_DATAFLASH" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/at91sam9263ek_dataflash_defconfig b/configs/at91sam9263ek_dataflash_defconfig index ce30dbb370..d4203828ad 100644 --- a/configs/at91sam9263ek_dataflash_defconfig +++ b/configs/at91sam9263ek_dataflash_defconfig @@ -12,6 +12,7 @@ CONFIG_DEBUG_UART_BASE=0xffffee00 CONFIG_DEBUG_UART_CLOCK=100000000 CONFIG_ENV_SECT_SIZE=0x210 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263,SYS_USE_DATAFLASH" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/at91sam9263ek_nandflash_defconfig b/configs/at91sam9263ek_nandflash_defconfig index 5149b34760..190fabff9b 100644 --- a/configs/at91sam9263ek_nandflash_defconfig +++ b/configs/at91sam9263ek_nandflash_defconfig @@ -9,6 +9,7 @@ CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0xffffee00 CONFIG_DEBUG_UART_CLOCK=100000000 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/at91sam9263ek_norflash_defconfig b/configs/at91sam9263ek_norflash_defconfig index 03c55622e0..66b4cd19f9 100644 --- a/configs/at91sam9263ek_norflash_defconfig +++ b/configs/at91sam9263ek_norflash_defconfig @@ -12,6 +12,7 @@ CONFIG_DEBUG_UART_BASE=0xffffee00 CONFIG_DEBUG_UART_CLOCK=100000000 CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263,SYS_USE_NORFLASH" CONFIG_BOOTDELAY=3 # CONFIG_CONSOLE_MUX is not set diff --git a/configs/at91sam9g10ek_dataflash_cs0_defconfig b/configs/at91sam9g10ek_dataflash_cs0_defconfig index 8a3cf115dc..2c02f8b106 100644 --- a/configs/at91sam9g10ek_dataflash_cs0_defconfig +++ b/configs/at91sam9g10ek_dataflash_cs0_defconfig @@ -11,6 +11,7 @@ CONFIG_DEBUG_UART_BASE=0xfffff200 CONFIG_DEBUG_UART_CLOCK=100000000 CONFIG_ENV_SECT_SIZE=0x210 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G10,SYS_USE_DATAFLASH_CS0" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/at91sam9g10ek_dataflash_cs3_defconfig b/configs/at91sam9g10ek_dataflash_cs3_defconfig index 89466b0014..8249916fe5 100644 --- a/configs/at91sam9g10ek_dataflash_cs3_defconfig +++ b/configs/at91sam9g10ek_dataflash_cs3_defconfig @@ -11,6 +11,7 @@ CONFIG_DEBUG_UART_BASE=0xfffff200 CONFIG_DEBUG_UART_CLOCK=100000000 CONFIG_ENV_SECT_SIZE=0x210 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G10,SYS_USE_DATAFLASH_CS3" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/at91sam9g10ek_nandflash_defconfig b/configs/at91sam9g10ek_nandflash_defconfig index 029cc9bbcf..eb4aeb594e 100644 --- a/configs/at91sam9g10ek_nandflash_defconfig +++ b/configs/at91sam9g10ek_nandflash_defconfig @@ -8,6 +8,7 @@ CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0xfffff200 CONFIG_DEBUG_UART_CLOCK=100000000 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G10,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/at91sam9g20ek_2mmc_defconfig b/configs/at91sam9g20ek_2mmc_defconfig index 1c9cc0cdc9..b5500364e6 100644 --- a/configs/at91sam9g20ek_2mmc_defconfig +++ b/configs/at91sam9g20ek_2mmc_defconfig @@ -11,6 +11,7 @@ CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0xfffff200 CONFIG_DEBUG_UART_CLOCK=132000000 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20,AT91SAM9G20EK_2MMC,SYS_USE_MMC" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/at91sam9g20ek_2mmc_nandflash_defconfig b/configs/at91sam9g20ek_2mmc_nandflash_defconfig index a0a149904d..7dd54fb71d 100644 --- a/configs/at91sam9g20ek_2mmc_nandflash_defconfig +++ b/configs/at91sam9g20ek_2mmc_nandflash_defconfig @@ -9,6 +9,7 @@ CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0xfffff200 CONFIG_DEBUG_UART_CLOCK=132000000 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20,AT91SAM9G20EK_2MMC,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/at91sam9g20ek_dataflash_cs0_defconfig b/configs/at91sam9g20ek_dataflash_cs0_defconfig index 86c7116b83..893e9ea293 100644 --- a/configs/at91sam9g20ek_dataflash_cs0_defconfig +++ b/configs/at91sam9g20ek_dataflash_cs0_defconfig @@ -12,6 +12,7 @@ CONFIG_DEBUG_UART_BASE=0xfffff200 CONFIG_DEBUG_UART_CLOCK=132000000 CONFIG_ENV_SECT_SIZE=0x210 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20,SYS_USE_DATAFLASH_CS0" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/at91sam9g20ek_dataflash_cs1_defconfig b/configs/at91sam9g20ek_dataflash_cs1_defconfig index c1c7b21cd8..c91d47c9eb 100644 --- a/configs/at91sam9g20ek_dataflash_cs1_defconfig +++ b/configs/at91sam9g20ek_dataflash_cs1_defconfig @@ -12,6 +12,7 @@ CONFIG_DEBUG_UART_BASE=0xfffff200 CONFIG_DEBUG_UART_CLOCK=132000000 CONFIG_ENV_SECT_SIZE=0x210 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20,SYS_USE_DATAFLASH_CS1" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/at91sam9g20ek_nandflash_defconfig b/configs/at91sam9g20ek_nandflash_defconfig index d8535b60d9..9be767b9fe 100644 --- a/configs/at91sam9g20ek_nandflash_defconfig +++ b/configs/at91sam9g20ek_nandflash_defconfig @@ -9,6 +9,7 @@ CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0xfffff200 CONFIG_DEBUG_UART_CLOCK=132000000 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/at91sam9m10g45ek_mmc_defconfig b/configs/at91sam9m10g45ek_mmc_defconfig index a5b6f45a8e..0e8624ea8d 100644 --- a/configs/at91sam9m10g45ek_mmc_defconfig +++ b/configs/at91sam9m10g45ek_mmc_defconfig @@ -9,6 +9,7 @@ CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0xffffee00 CONFIG_DEBUG_UART_CLOCK=132000000 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/at91sam9m10g45ek_nandflash_defconfig b/configs/at91sam9m10g45ek_nandflash_defconfig index 44c50739a0..8c50427128 100644 --- a/configs/at91sam9m10g45ek_nandflash_defconfig +++ b/configs/at91sam9m10g45ek_nandflash_defconfig @@ -8,6 +8,7 @@ CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0xffffee00 CONFIG_DEBUG_UART_CLOCK=132000000 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_NAND_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/at91sam9n12ek_mmc_defconfig b/configs/at91sam9n12ek_mmc_defconfig index aad6ee43f3..0475c0901c 100644 --- a/configs/at91sam9n12ek_mmc_defconfig +++ b/configs/at91sam9n12ek_mmc_defconfig @@ -9,6 +9,7 @@ CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0xfffff200 CONFIG_DEBUG_UART_CLOCK=132000000 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=3 # CONFIG_CONSOLE_MUX is not set diff --git a/configs/at91sam9n12ek_nandflash_defconfig b/configs/at91sam9n12ek_nandflash_defconfig index a2cb37e1ae..25bfe00d09 100644 --- a/configs/at91sam9n12ek_nandflash_defconfig +++ b/configs/at91sam9n12ek_nandflash_defconfig @@ -8,6 +8,7 @@ CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0xfffff200 CONFIG_DEBUG_UART_CLOCK=132000000 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_NAND_BOOT=y CONFIG_BOOTDELAY=3 # CONFIG_CONSOLE_MUX is not set diff --git a/configs/at91sam9n12ek_spiflash_defconfig b/configs/at91sam9n12ek_spiflash_defconfig index e49a90d21f..662e449355 100644 --- a/configs/at91sam9n12ek_spiflash_defconfig +++ b/configs/at91sam9n12ek_spiflash_defconfig @@ -11,6 +11,7 @@ CONFIG_DEBUG_UART_BASE=0xfffff200 CONFIG_DEBUG_UART_CLOCK=132000000 CONFIG_ENV_SECT_SIZE=0x1000 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SPI_BOOT=y CONFIG_BOOTDELAY=3 # CONFIG_CONSOLE_MUX is not set diff --git a/configs/at91sam9rlek_dataflash_defconfig b/configs/at91sam9rlek_dataflash_defconfig index 85130d7a49..71086a2d7d 100644 --- a/configs/at91sam9rlek_dataflash_defconfig +++ b/configs/at91sam9rlek_dataflash_defconfig @@ -12,6 +12,7 @@ CONFIG_DEBUG_UART_BASE=0xfffff200 CONFIG_DEBUG_UART_CLOCK=100000000 CONFIG_ENV_SECT_SIZE=0x210 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9RL,SYS_USE_DATAFLASH" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/at91sam9rlek_mmc_defconfig b/configs/at91sam9rlek_mmc_defconfig index 38357632e7..deb607b626 100644 --- a/configs/at91sam9rlek_mmc_defconfig +++ b/configs/at91sam9rlek_mmc_defconfig @@ -10,6 +10,7 @@ CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0xfffff200 CONFIG_DEBUG_UART_CLOCK=100000000 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9RL,SYS_USE_MMC" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/at91sam9rlek_nandflash_defconfig b/configs/at91sam9rlek_nandflash_defconfig index 41a59891af..9efd71f946 100644 --- a/configs/at91sam9rlek_nandflash_defconfig +++ b/configs/at91sam9rlek_nandflash_defconfig @@ -9,6 +9,7 @@ CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0xfffff200 CONFIG_DEBUG_UART_CLOCK=100000000 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9RL,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/at91sam9x5ek_dataflash_defconfig b/configs/at91sam9x5ek_dataflash_defconfig index 10df6441a4..f2279557ea 100644 --- a/configs/at91sam9x5ek_dataflash_defconfig +++ b/configs/at91sam9x5ek_dataflash_defconfig @@ -11,6 +11,7 @@ CONFIG_DEBUG_UART_BASE=0xfffff200 CONFIG_DEBUG_UART_CLOCK=132000000 CONFIG_ENV_SECT_SIZE=0x210 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="SYS_USE_DATAFLASH" CONFIG_BOOTDELAY=3 diff --git a/configs/at91sam9x5ek_mmc_defconfig b/configs/at91sam9x5ek_mmc_defconfig index 158c1ec3cb..ddbdbdde8a 100644 --- a/configs/at91sam9x5ek_mmc_defconfig +++ b/configs/at91sam9x5ek_mmc_defconfig @@ -9,6 +9,7 @@ CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0xfffff200 CONFIG_DEBUG_UART_CLOCK=132000000 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_FIT=y CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=3 diff --git a/configs/at91sam9x5ek_nandflash_defconfig b/configs/at91sam9x5ek_nandflash_defconfig index b5c282dc25..4ced4f6d24 100644 --- a/configs/at91sam9x5ek_nandflash_defconfig +++ b/configs/at91sam9x5ek_nandflash_defconfig @@ -8,6 +8,7 @@ CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0xfffff200 CONFIG_DEBUG_UART_CLOCK=132000000 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_FIT=y CONFIG_NAND_BOOT=y CONFIG_BOOTDELAY=3 diff --git a/configs/at91sam9x5ek_spiflash_defconfig b/configs/at91sam9x5ek_spiflash_defconfig index 1fe37f96d1..c2e677ffd7 100644 --- a/configs/at91sam9x5ek_spiflash_defconfig +++ b/configs/at91sam9x5ek_spiflash_defconfig @@ -11,6 +11,7 @@ CONFIG_DEBUG_UART_BASE=0xfffff200 CONFIG_DEBUG_UART_CLOCK=132000000 CONFIG_ENV_SECT_SIZE=0x1000 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_FIT=y CONFIG_SPI_BOOT=y CONFIG_BOOTDELAY=3 diff --git a/configs/at91sam9xeek_dataflash_cs0_defconfig b/configs/at91sam9xeek_dataflash_cs0_defconfig index c713735306..abee0bfa09 100644 --- a/configs/at91sam9xeek_dataflash_cs0_defconfig +++ b/configs/at91sam9xeek_dataflash_cs0_defconfig @@ -12,6 +12,7 @@ CONFIG_DEBUG_UART_BASE=0xfffff200 CONFIG_DEBUG_UART_CLOCK=132000000 CONFIG_ENV_SECT_SIZE=0x210 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9XE,SYS_USE_DATAFLASH_CS0" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/at91sam9xeek_dataflash_cs1_defconfig b/configs/at91sam9xeek_dataflash_cs1_defconfig index 1862fc4b5a..b726ba1f9e 100644 --- a/configs/at91sam9xeek_dataflash_cs1_defconfig +++ b/configs/at91sam9xeek_dataflash_cs1_defconfig @@ -12,6 +12,7 @@ CONFIG_DEBUG_UART_BASE=0xfffff200 CONFIG_DEBUG_UART_CLOCK=132000000 CONFIG_ENV_SECT_SIZE=0x210 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9XE,SYS_USE_DATAFLASH_CS1" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/at91sam9xeek_nandflash_defconfig b/configs/at91sam9xeek_nandflash_defconfig index 110b1799f2..298f8c38cb 100644 --- a/configs/at91sam9xeek_nandflash_defconfig +++ b/configs/at91sam9xeek_nandflash_defconfig @@ -9,6 +9,7 @@ CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0xfffff200 CONFIG_DEBUG_UART_CLOCK=132000000 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9XE,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/axm_defconfig b/configs/axm_defconfig index a1d374aeb5..b46650f78f 100644 --- a/configs/axm_defconfig +++ b/configs/axm_defconfig @@ -21,6 +21,7 @@ CONFIG_DEBUG_UART_CLOCK=18432000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT_ONLY=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20,MACH_TYPE=2068" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTCOMMAND=y diff --git a/configs/bcm11130_defconfig b/configs/bcm11130_defconfig index dc7d723fe3..c9c094086e 100644 --- a/configs/bcm11130_defconfig +++ b/configs/bcm11130_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_BCM28155_AP=y CONFIG_SYS_TEXT_BASE=0xae000000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="SYS_MMC_ENV_DEV=0" CONFIG_MISC_INIT_R=y CONFIG_VERSION_VARIABLE=y diff --git a/configs/bcm11130_nand_defconfig b/configs/bcm11130_nand_defconfig index aa4105db39..d9dd64d511 100644 --- a/configs/bcm11130_nand_defconfig +++ b/configs/bcm11130_nand_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_BCM28155_AP=y CONFIG_SYS_TEXT_BASE=0xae000000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_MISC_INIT_R=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set diff --git a/configs/bcm23550_w1d_defconfig b/configs/bcm23550_w1d_defconfig index b94b2db0a0..1b1b6c2128 100644 --- a/configs/bcm23550_w1d_defconfig +++ b/configs/bcm23550_w1d_defconfig @@ -5,6 +5,7 @@ CONFIG_ENABLE_ARM_SOC_BOOT0_HOOK=y CONFIG_TARGET_BCM23550_W1D=y CONFIG_SYS_TEXT_BASE=0x9f000000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_SKIP_LOWLEVEL_INIT=y # CONFIG_ANDROID_BOOT_IMAGE is not set CONFIG_MISC_INIT_R=y CONFIG_VERSION_VARIABLE=y diff --git a/configs/bcm28155_ap_defconfig b/configs/bcm28155_ap_defconfig index f04e3644c8..ea37a687ce 100644 --- a/configs/bcm28155_ap_defconfig +++ b/configs/bcm28155_ap_defconfig @@ -3,6 +3,7 @@ CONFIG_ENABLE_ARM_SOC_BOOT0_HOOK=y CONFIG_TARGET_BCM28155_AP=y CONFIG_SYS_TEXT_BASE=0xae000000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_SKIP_LOWLEVEL_INIT=y # CONFIG_ANDROID_BOOT_IMAGE is not set CONFIG_MISC_INIT_R=y CONFIG_VERSION_VARIABLE=y diff --git a/configs/bcm28155_w1d_defconfig b/configs/bcm28155_w1d_defconfig index 9f3020c16e..beafb69522 100644 --- a/configs/bcm28155_w1d_defconfig +++ b/configs/bcm28155_w1d_defconfig @@ -3,6 +3,7 @@ CONFIG_ENABLE_ARM_SOC_BOOT0_HOOK=y CONFIG_TARGET_BCM28155_AP=y CONFIG_SYS_TEXT_BASE=0xae000000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_MISC_INIT_R=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set diff --git a/configs/bcm7260_defconfig b/configs/bcm7260_defconfig index 2c18d36afc..395a10ed43 100644 --- a/configs/bcm7260_defconfig +++ b/configs/bcm7260_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_BCMSTB=y CONFIG_SYS_TEXT_BASE=0x10100000 CONFIG_TARGET_BCM7260=y CONFIG_NR_DRAM_BANKS=1 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_BOOTDELAY=1 diff --git a/configs/bcm7445_defconfig b/configs/bcm7445_defconfig index c79de19919..81d1bf6ef0 100644 --- a/configs/bcm7445_defconfig +++ b/configs/bcm7445_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_BCMSTB=y CONFIG_SYS_TEXT_BASE=0x80100000 CONFIG_TARGET_BCM7445=y CONFIG_NR_DRAM_BANKS=3 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_BOOTDELAY=1 diff --git a/configs/bcm911360_entphn-ns_defconfig b/configs/bcm911360_entphn-ns_defconfig index 673c0f2182..3380255ee9 100644 --- a/configs/bcm911360_entphn-ns_defconfig +++ b/configs/bcm911360_entphn-ns_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_BCMCYGNUS=y CONFIG_SYS_TEXT_BASE=0x61000000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="SYS_SDRAM_SIZE=0x20000000,ARMV7_NONSEC" CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set diff --git a/configs/bcm911360_entphn_defconfig b/configs/bcm911360_entphn_defconfig index 723482eb2d..ba036addd4 100644 --- a/configs/bcm911360_entphn_defconfig +++ b/configs/bcm911360_entphn_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_BCMCYGNUS=y CONFIG_SYS_TEXT_BASE=0x61000000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="SYS_SDRAM_SIZE=0x20000000" CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set diff --git a/configs/bcm911360k_defconfig b/configs/bcm911360k_defconfig index dfb9f8461f..6f810ba9a2 100644 --- a/configs/bcm911360k_defconfig +++ b/configs/bcm911360k_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_BCMCYGNUS=y CONFIG_SYS_TEXT_BASE=0x61000000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="SYS_SDRAM_SIZE=0x40000000" CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set diff --git a/configs/bcm958300k-ns_defconfig b/configs/bcm958300k-ns_defconfig index cc510530f6..6ff7470de6 100644 --- a/configs/bcm958300k-ns_defconfig +++ b/configs/bcm958300k-ns_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_BCMCYGNUS=y CONFIG_SYS_TEXT_BASE=0x61000000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="SYS_SDRAM_SIZE=0x40000000,ARMV7_NONSEC" CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set diff --git a/configs/bcm958300k_defconfig b/configs/bcm958300k_defconfig index dfb9f8461f..6f810ba9a2 100644 --- a/configs/bcm958300k_defconfig +++ b/configs/bcm958300k_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_BCMCYGNUS=y CONFIG_SYS_TEXT_BASE=0x61000000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="SYS_SDRAM_SIZE=0x40000000" CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set diff --git a/configs/bcm958305k_defconfig b/configs/bcm958305k_defconfig index dfb9f8461f..6f810ba9a2 100644 --- a/configs/bcm958305k_defconfig +++ b/configs/bcm958305k_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_BCMCYGNUS=y CONFIG_SYS_TEXT_BASE=0x61000000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="SYS_SDRAM_SIZE=0x40000000" CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set diff --git a/configs/bcm958622hr_defconfig b/configs/bcm958622hr_defconfig index 5ee8c6912b..2bdba1c0ce 100644 --- a/configs/bcm958622hr_defconfig +++ b/configs/bcm958622hr_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_BCMNSP=y CONFIG_SYS_TEXT_BASE=0x61000000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="SYS_SDRAM_SIZE=0x01000000" CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set diff --git a/configs/bcm963158_ram_defconfig b/configs/bcm963158_ram_defconfig index 8863131ed0..09a82da74d 100644 --- a/configs/bcm963158_ram_defconfig +++ b/configs/bcm963158_ram_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_TEXT_BASE=0x10000000 CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_NR_DRAM_BANKS=1 CONFIG_TARGET_BCM963158=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y @@ -39,7 +40,6 @@ CONFIG_NAND=y CONFIG_NAND_BRCMNAND=y CONFIG_NAND_BRCMNAND_63158=y CONFIG_SPECIFY_CONSOLE_INDEX=y -# CONFIG_SPL_SERIAL_PRESENT is not set CONFIG_CONS_INDEX=0 CONFIG_DM_SERIAL=y CONFIG_SERIAL_SEARCH_ALL=y diff --git a/configs/bcm968380gerg_ram_defconfig b/configs/bcm968380gerg_ram_defconfig index ae9c681bf3..70a059c988 100644 --- a/configs/bcm968380gerg_ram_defconfig +++ b/configs/bcm968380gerg_ram_defconfig @@ -6,6 +6,7 @@ CONFIG_SOC_BMIPS_BCM6838=y # CONFIG_MIPS_BOOT_CMDLINE_LEGACY is not set # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y +CONFIG_SKIP_LOWLEVEL_INIT=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DISPLAY_CPUINFO=y @@ -48,7 +49,6 @@ CONFIG_POWER_DOMAIN=y CONFIG_BCM6328_POWER_DOMAIN=y CONFIG_DM_RESET=y CONFIG_RESET_BCM6345=y -# CONFIG_SPL_SERIAL_PRESENT is not set CONFIG_DM_SERIAL=y CONFIG_BCM6345_SERIAL=y CONFIG_SYSRESET_WATCHDOG=y diff --git a/configs/bcm968580xref_ram_defconfig b/configs/bcm968580xref_ram_defconfig index 7e63dd145b..ed066090aa 100644 --- a/configs/bcm968580xref_ram_defconfig +++ b/configs/bcm968580xref_ram_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x10000000 CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_NR_DRAM_BANKS=1 CONFIG_TARGET_BCM968580XREF=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y @@ -34,7 +35,6 @@ CONFIG_NAND=y CONFIG_NAND_BRCMNAND=y CONFIG_NAND_BRCMNAND_6858=y CONFIG_SPECIFY_CONSOLE_INDEX=y -# CONFIG_SPL_SERIAL_PRESENT is not set CONFIG_CONS_INDEX=0 CONFIG_DM_SERIAL=y CONFIG_SERIAL_SEARCH_ALL=y diff --git a/configs/birdland_bav335a_defconfig b/configs/birdland_bav335a_defconfig index 422d093328..aaee4a78b3 100644 --- a/configs/birdland_bav335a_defconfig +++ b/configs/birdland_bav335a_defconfig @@ -12,6 +12,7 @@ CONFIG_SPL=y CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_BAV_VERSION=1 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=1" # CONFIG_USE_BOOTCOMMAND is not set diff --git a/configs/birdland_bav335b_defconfig b/configs/birdland_bav335b_defconfig index 5b4f9b7b99..336fb0d6e3 100644 --- a/configs/birdland_bav335b_defconfig +++ b/configs/birdland_bav335b_defconfig @@ -12,6 +12,7 @@ CONFIG_SPL=y CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_BAV_VERSION=2 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=1" # CONFIG_USE_BOOTCOMMAND is not set diff --git a/configs/bk4r1_defconfig b/configs/bk4r1_defconfig index 5d47395f5e..4628580902 100644 --- a/configs/bk4r1_defconfig +++ b/configs/bk4r1_defconfig @@ -7,6 +7,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_SYS_BOOTCOUNT_SINGLEWORD=y CONFIG_SYS_BOOTCOUNT_ADDR=0x4006e02c CONFIG_TARGET_BK4R1=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/phytec/pcm052/imximage.cfg" CONFIG_BOOTDELAY=3 @@ -72,8 +73,6 @@ CONFIG_PINCTRL=y CONFIG_PINCTRL_VYBRID=y CONFIG_DM_RTC=y CONFIG_RTC_M41T62=y -# CONFIG_SPL_SERIAL_PRESENT is not set -# CONFIG_TPL_SERIAL_PRESENT is not set CONFIG_DM_SERIAL=y CONFIG_FSL_LPUART=y CONFIG_SPI=y diff --git a/configs/brppt1_mmc_defconfig b/configs/brppt1_mmc_defconfig index d0ee6194cf..d9302527e5 100644 --- a/configs/brppt1_mmc_defconfig +++ b/configs/brppt1_mmc_defconfig @@ -12,6 +12,7 @@ CONFIG_ENV_SIZE=0x10000 CONFIG_ENV_OFFSET=0x40000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y +CONFIG_SKIP_LOWLEVEL_INIT=y # CONFIG_EXPERT is not set # CONFIG_FIT is not set CONFIG_OF_BOARD_SETUP=y diff --git a/configs/brppt1_nand_defconfig b/configs/brppt1_nand_defconfig index ff227de4b7..9962463349 100644 --- a/configs/brppt1_nand_defconfig +++ b/configs/brppt1_nand_defconfig @@ -11,6 +11,7 @@ CONFIG_ENV_SIZE=0x10000 CONFIG_ENV_OFFSET=0x60000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y +CONFIG_SKIP_LOWLEVEL_INIT=y # CONFIG_EXPERT is not set # CONFIG_FIT is not set CONFIG_OF_BOARD_SETUP=y diff --git a/configs/brppt1_spi_defconfig b/configs/brppt1_spi_defconfig index a29dc0385e..2bd401b6d0 100644 --- a/configs/brppt1_spi_defconfig +++ b/configs/brppt1_spi_defconfig @@ -14,6 +14,7 @@ CONFIG_SPL=y CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y +CONFIG_SKIP_LOWLEVEL_INIT=y # CONFIG_EXPERT is not set # CONFIG_FIT is not set CONFIG_OF_BOARD_SETUP=y diff --git a/configs/brsmarc1_defconfig b/configs/brsmarc1_defconfig index 8863a2d5cc..f4329037c7 100644 --- a/configs/brsmarc1_defconfig +++ b/configs/brsmarc1_defconfig @@ -15,6 +15,7 @@ CONFIG_SPL=y CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y +CONFIG_SKIP_LOWLEVEL_INIT=y # CONFIG_EXPERT is not set # CONFIG_FIT is not set CONFIG_OF_BOARD_SETUP=y diff --git a/configs/brxre1_defconfig b/configs/brxre1_defconfig index d4169c0327..aa971d0de1 100644 --- a/configs/brxre1_defconfig +++ b/configs/brxre1_defconfig @@ -13,6 +13,7 @@ CONFIG_ENV_SIZE=0x10000 CONFIG_ENV_OFFSET=0x40000 CONFIG_SPL_SYS_MALLOC_F_LEN=0x4000 CONFIG_SPL=y +CONFIG_SKIP_LOWLEVEL_INIT=y # CONFIG_EXPERT is not set # CONFIG_FIT is not set CONFIG_OF_BOARD_SETUP=y diff --git a/configs/chiliboard_defconfig b/configs/chiliboard_defconfig index f275d21d16..e4f7829994 100644 --- a/configs/chiliboard_defconfig +++ b/configs/chiliboard_defconfig @@ -12,6 +12,7 @@ CONFIG_ENV_OFFSET=0x20000 CONFIG_SPL=y CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=1 # CONFIG_USE_BOOTCOMMAND is not set diff --git a/configs/chromebit_mickey_defconfig b/configs/chromebit_mickey_defconfig index 18f6c388c6..89c21cd202 100644 --- a/configs/chromebit_mickey_defconfig +++ b/configs/chromebit_mickey_defconfig @@ -12,11 +12,12 @@ CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_DEBUG_UART=y +CONFIG_SPL_TEXT_BASE=0xff704000 +CONFIG_SKIP_LOWLEVEL_INIT_ONLY=y CONFIG_USE_PREBOOT=y CONFIG_DEFAULT_FDT_FILE="rk3288-veyron-mickey.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_SPL_TEXT_BASE=0xff704000 # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 diff --git a/configs/chromebook_bob_defconfig b/configs/chromebook_bob_defconfig index 967162248c..af7532e790 100644 --- a/configs/chromebook_bob_defconfig +++ b/configs/chromebook_bob_defconfig @@ -14,10 +14,11 @@ CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_DEBUG_UART=y +CONFIG_SPL_TEXT_BASE=0xff8c2000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-gru-bob.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_SPL_TEXT_BASE=0xff8c2000 # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x4000 diff --git a/configs/chromebook_jerry_defconfig b/configs/chromebook_jerry_defconfig index 3d2188a23a..9ae4b2e07d 100644 --- a/configs/chromebook_jerry_defconfig +++ b/configs/chromebook_jerry_defconfig @@ -11,6 +11,8 @@ CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_DEBUG_UART=y +CONFIG_SPL_TEXT_BASE=0xff704000 +CONFIG_SKIP_LOWLEVEL_INIT_ONLY=y CONFIG_USE_PREBOOT=y CONFIG_SILENT_CONSOLE=y CONFIG_LOG=y @@ -18,7 +20,6 @@ CONFIG_DEFAULT_FDT_FILE="rk3288-veyron-jerry.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_SPL_TEXT_BASE=0xff704000 # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 diff --git a/configs/chromebook_minnie_defconfig b/configs/chromebook_minnie_defconfig index 7047440e74..c35f4f92ae 100644 --- a/configs/chromebook_minnie_defconfig +++ b/configs/chromebook_minnie_defconfig @@ -12,12 +12,13 @@ CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_DEBUG_UART=y +CONFIG_SPL_TEXT_BASE=0xff704000 +CONFIG_SKIP_LOWLEVEL_INIT_ONLY=y CONFIG_USE_PREBOOT=y CONFIG_SILENT_CONSOLE=y CONFIG_DEFAULT_FDT_FILE="rk3288-veyron-minnie.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_SPL_TEXT_BASE=0xff704000 # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 diff --git a/configs/chromebook_speedy_defconfig b/configs/chromebook_speedy_defconfig index 5319ecb253..396d8e697a 100644 --- a/configs/chromebook_speedy_defconfig +++ b/configs/chromebook_speedy_defconfig @@ -12,13 +12,14 @@ CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_DEBUG_UART=y +CONFIG_SPL_TEXT_BASE=0xff704000 +CONFIG_SKIP_LOWLEVEL_INIT_ONLY=y CONFIG_USE_PREBOOT=y CONFIG_SILENT_CONSOLE=y CONFIG_DEFAULT_FDT_FILE="rk3288-veyron-speedy.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_SPL_TEXT_BASE=0xff704000 # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 diff --git a/configs/ci20_mmc_defconfig b/configs/ci20_mmc_defconfig index 69a449f9e7..3342792ad6 100644 --- a/configs/ci20_mmc_defconfig +++ b/configs/ci20_mmc_defconfig @@ -7,6 +7,8 @@ CONFIG_SPL_MMC_SUPPORT=y CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_ARCH_JZ47XX=y +CONFIG_SPL_TEXT_BASE=0xf4000a00 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_FIT=y CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS4,115200 rw rootwait root=/dev/mmcblk0p1" @@ -15,7 +17,6 @@ CONFIG_BOOTCOMMAND="ext4load mmc 0:1 0x88000000 /boot/uImage; bootm 0x88000000" CONFIG_MISC_INIT_R=y CONFIG_DISPLAY_CPUINFO=y CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_SPL_TEXT_BASE=0xf4000a00 # CONFIG_SPL_BANNER_PRINT is not set CONFIG_SPL_MMC_TINY=y CONFIG_HUSH_PARSER=y diff --git a/configs/cm_t335_defconfig b/configs/cm_t335_defconfig index ab9f1fde44..6c75ae46b0 100644 --- a/configs/cm_t335_defconfig +++ b/configs/cm_t335_defconfig @@ -13,6 +13,7 @@ CONFIG_ENV_OFFSET=0x300000 CONFIG_SPL=y CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y diff --git a/configs/cm_t43_defconfig b/configs/cm_t43_defconfig index 214a054ac4..ae76fa66f9 100644 --- a/configs/cm_t43_defconfig +++ b/configs/cm_t43_defconfig @@ -15,6 +15,8 @@ CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y +CONFIG_SPL_TEXT_BASE=0x40300350 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y @@ -22,7 +24,6 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_SPL_TEXT_BASE=0x40300350 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x480 CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/colibri_vf_defconfig b/configs/colibri_vf_defconfig index 43945146ea..f5cc7e5aea 100644 --- a/configs/colibri_vf_defconfig +++ b/configs/colibri_vf_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_TEXT_BASE=0x3f401000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_TARGET_COLIBRI_VF=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/toradex/colibri_vf/imximage.cfg,IMX_NAND" CONFIG_BOOTDELAY=1 @@ -74,8 +75,6 @@ CONFIG_PINCTRL=y CONFIG_PINCTRL_VYBRID=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y -# CONFIG_SPL_SERIAL_PRESENT is not set -# CONFIG_TPL_SERIAL_PRESENT is not set CONFIG_DM_SERIAL=y CONFIG_FSL_LPUART=y CONFIG_USB=y diff --git a/configs/comtrend_ar5315u_ram_defconfig b/configs/comtrend_ar5315u_ram_defconfig index 940e603114..a3b6ebdafb 100644 --- a/configs/comtrend_ar5315u_ram_defconfig +++ b/configs/comtrend_ar5315u_ram_defconfig @@ -6,6 +6,7 @@ CONFIG_SOC_BMIPS_BCM6318=y # CONFIG_MIPS_BOOT_CMDLINE_LEGACY is not set # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y +CONFIG_SKIP_LOWLEVEL_INIT=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DISPLAY_CPUINFO=y @@ -50,7 +51,6 @@ CONFIG_BCM6318_USBH_PHY=y CONFIG_BCM6328_POWER_DOMAIN=y CONFIG_DM_RESET=y CONFIG_RESET_BCM6345=y -# CONFIG_SPL_SERIAL_PRESENT is not set CONFIG_DM_SERIAL=y CONFIG_BCM6345_SERIAL=y CONFIG_SPI=y diff --git a/configs/comtrend_ar5387un_ram_defconfig b/configs/comtrend_ar5387un_ram_defconfig index 07aa8ddcac..443f796cff 100644 --- a/configs/comtrend_ar5387un_ram_defconfig +++ b/configs/comtrend_ar5387un_ram_defconfig @@ -6,6 +6,7 @@ CONFIG_SOC_BMIPS_BCM6328=y # CONFIG_MIPS_BOOT_CMDLINE_LEGACY is not set # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y +CONFIG_SKIP_LOWLEVEL_INIT=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DISPLAY_CPUINFO=y @@ -51,7 +52,6 @@ CONFIG_POWER_DOMAIN=y CONFIG_BCM6328_POWER_DOMAIN=y CONFIG_DM_RESET=y CONFIG_RESET_BCM6345=y -# CONFIG_SPL_SERIAL_PRESENT is not set CONFIG_DM_SERIAL=y CONFIG_BCM6345_SERIAL=y CONFIG_SPI=y diff --git a/configs/comtrend_ct5361_ram_defconfig b/configs/comtrend_ct5361_ram_defconfig index 58a721b276..f02e93e1e5 100644 --- a/configs/comtrend_ct5361_ram_defconfig +++ b/configs/comtrend_ct5361_ram_defconfig @@ -6,6 +6,7 @@ CONFIG_SOC_BMIPS_BCM6348=y # CONFIG_MIPS_BOOT_CMDLINE_LEGACY is not set # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y +CONFIG_SKIP_LOWLEVEL_INIT=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DISPLAY_CPUINFO=y @@ -49,7 +50,6 @@ CONFIG_PHY=y CONFIG_BCM6348_USBH_PHY=y CONFIG_DM_RESET=y CONFIG_RESET_BCM6345=y -# CONFIG_SPL_SERIAL_PRESENT is not set CONFIG_DM_SERIAL=y CONFIG_BCM6345_SERIAL=y CONFIG_USB=y diff --git a/configs/comtrend_vr3032u_ram_defconfig b/configs/comtrend_vr3032u_ram_defconfig index 013c9ee1f6..1af17706dd 100644 --- a/configs/comtrend_vr3032u_ram_defconfig +++ b/configs/comtrend_vr3032u_ram_defconfig @@ -6,6 +6,7 @@ CONFIG_SOC_BMIPS_BCM63268=y # CONFIG_MIPS_BOOT_CMDLINE_LEGACY is not set # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y +CONFIG_SKIP_LOWLEVEL_INIT=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DISPLAY_CPUINFO=y @@ -45,7 +46,6 @@ CONFIG_POWER_DOMAIN=y CONFIG_BCM6328_POWER_DOMAIN=y CONFIG_DM_RESET=y CONFIG_RESET_BCM6345=y -# CONFIG_SPL_SERIAL_PRESENT is not set CONFIG_DM_SERIAL=y CONFIG_BCM6345_SERIAL=y CONFIG_USB=y diff --git a/configs/comtrend_wap5813n_ram_defconfig b/configs/comtrend_wap5813n_ram_defconfig index 6e0a645200..f958c6b384 100644 --- a/configs/comtrend_wap5813n_ram_defconfig +++ b/configs/comtrend_wap5813n_ram_defconfig @@ -6,6 +6,7 @@ CONFIG_SOC_BMIPS_BCM6368=y # CONFIG_MIPS_BOOT_CMDLINE_LEGACY is not set # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y +CONFIG_SKIP_LOWLEVEL_INIT=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DISPLAY_CPUINFO=y @@ -49,7 +50,6 @@ CONFIG_PHY=y CONFIG_BCM6368_USBH_PHY=y CONFIG_DM_RESET=y CONFIG_RESET_BCM6345=y -# CONFIG_SPL_SERIAL_PRESENT is not set CONFIG_DM_SERIAL=y CONFIG_BCM6345_SERIAL=y CONFIG_USB=y diff --git a/configs/controlcenterdc_defconfig b/configs/controlcenterdc_defconfig index 46fe75365b..79ddbff789 100644 --- a/configs/controlcenterdc_defconfig +++ b/configs/controlcenterdc_defconfig @@ -14,6 +14,8 @@ CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_DEBUG_UART=y CONFIG_AHCI=y +CONFIG_SPL_TEXT_BASE=0x40000030 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y @@ -21,7 +23,6 @@ CONFIG_USE_PREBOOT=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_LAST_STAGE_INIT=y -CONFIG_SPL_TEXT_BASE=0x40000030 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SPI_LOAD=y diff --git a/configs/corvus_defconfig b/configs/corvus_defconfig index f4d45272ba..dc95e44bb5 100644 --- a/configs/corvus_defconfig +++ b/configs/corvus_defconfig @@ -13,13 +13,14 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_ENV_OFFSET=0x100000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y +CONFIG_SPL_TEXT_BASE=0x300000 +CONFIG_SKIP_LOWLEVEL_INIT_ONLY=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9M10G45,MACH_TYPE=2066,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk mtdparts=atmel_nand:256k(bootstrap)ro,512k(uboot)ro,256k(env),256k(env_redundant),256k(spare),512k(dtb),6M(kernel)ro,-(rootfs) root=/dev/mtdblock7 rw rootfstype=jffs2" # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_SPL_TEXT_BASE=0x300000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/d2net_v2_defconfig b/configs/d2net_v2_defconfig index b4cf22c4d7..e8f0ccb566 100644 --- a/configs/d2net_v2_defconfig +++ b/configs/d2net_v2_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_NET2BIG_V2=y CONFIG_NR_DRAM_BANKS=2 CONFIG_IDENT_STRING=" D2 v2" +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="D2NET_V2" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/da850evm_defconfig b/configs/da850evm_defconfig index cfd910ad26..2f82983c19 100644 --- a/configs/da850evm_defconfig +++ b/configs/da850evm_defconfig @@ -12,6 +12,8 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y +CONFIG_SPL_TEXT_BASE=0x80000000 +CONFIG_SKIP_LOWLEVEL_INIT_ONLY=y CONFIG_SYS_EXTRA_OPTIONS="MAC_ADDR_IN_SPIFLASH" CONFIG_BOOTDELAY=3 CONFIG_DEFAULT_FDT_FILE="da850-evm.dtb" @@ -20,7 +22,6 @@ CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_SPL_TEXT_BASE=0x80000000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_SPI_LOAD=y diff --git a/configs/da850evm_direct_nor_defconfig b/configs/da850evm_direct_nor_defconfig index 698ac13a28..e93bf4b7e8 100644 --- a/configs/da850evm_direct_nor_defconfig +++ b/configs/da850evm_direct_nor_defconfig @@ -7,6 +7,7 @@ CONFIG_DA850_LOWLEVEL=y CONFIG_TI_COMMON_CMD_OPTIONS=y CONFIG_SYS_MALLOC_F_LEN=0x800 CONFIG_NR_DRAM_BANKS=1 +CONFIG_SKIP_LOWLEVEL_INIT_ONLY=y CONFIG_SYS_EXTRA_OPTIONS="USE_NOR,DIRECT_NOR_BOOT" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/da850evm_nand_defconfig b/configs/da850evm_nand_defconfig index 701093977e..4c781104ca 100644 --- a/configs/da850evm_nand_defconfig +++ b/configs/da850evm_nand_defconfig @@ -11,6 +11,8 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y +CONFIG_SPL_TEXT_BASE=0x80000000 +CONFIG_SKIP_LOWLEVEL_INIT_ONLY=y CONFIG_SYS_EXTRA_OPTIONS="MAC_ADDR_IN_SPIFLASH" CONFIG_BOOTDELAY=3 CONFIG_DEFAULT_FDT_FILE="da850-evm.dtb" @@ -18,7 +20,6 @@ CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_SPL_TEXT_BASE=0x80000000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_NAND_SUPPORT=y diff --git a/configs/db-88f6281-bp-nand_defconfig b/configs/db-88f6281-bp-nand_defconfig index 0d046834a4..9803107129 100644 --- a/configs/db-88f6281-bp-nand_defconfig +++ b/configs/db-88f6281-bp-nand_defconfig @@ -7,6 +7,7 @@ CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_DB_88F6281_BP=y CONFIG_NR_DRAM_BANKS=2 CONFIG_IDENT_STRING="\nMarvell DB-88F6281-BP" +CONFIG_SKIP_LOWLEVEL_INIT=y # CONFIG_SYS_MALLOC_F is not set CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set diff --git a/configs/db-88f6281-bp-spi_defconfig b/configs/db-88f6281-bp-spi_defconfig index 01ef497682..38adec3c0d 100644 --- a/configs/db-88f6281-bp-spi_defconfig +++ b/configs/db-88f6281-bp-spi_defconfig @@ -7,6 +7,7 @@ CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_DB_88F6281_BP=y CONFIG_NR_DRAM_BANKS=2 CONFIG_IDENT_STRING="\nMarvell DB-88F6281-BP" +CONFIG_SKIP_LOWLEVEL_INIT=y # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT=y CONFIG_BOOTDELAY=3 diff --git a/configs/devkit3250_defconfig b/configs/devkit3250_defconfig index ae7be20f99..47b5496beb 100644 --- a/configs/devkit3250_defconfig +++ b/configs/devkit3250_defconfig @@ -9,13 +9,14 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y +CONFIG_SPL_TEXT_BASE=0x00000000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_BOOTDELAY=1 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200n8" CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_SPL_TEXT_BASE=0x00000000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_NAND_SUPPORT=y diff --git a/configs/dns325_defconfig b/configs/dns325_defconfig index 6e95fb265e..08387ddfff 100644 --- a/configs/dns325_defconfig +++ b/configs/dns325_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_DNS325=y CONFIG_NR_DRAM_BANKS=2 CONFIG_IDENT_STRING="\nD-Link DNS-325" +CONFIG_SKIP_LOWLEVEL_INIT=y # CONFIG_SYS_MALLOC_F is not set CONFIG_BOOTDELAY=3 CONFIG_USE_PREBOOT=y diff --git a/configs/dockstar_defconfig b/configs/dockstar_defconfig index 18df663b7b..200b4c0a6c 100644 --- a/configs/dockstar_defconfig +++ b/configs/dockstar_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_DOCKSTAR=y CONFIG_NR_DRAM_BANKS=2 CONFIG_IDENT_STRING="\nSeagate FreeAgent DockStar" +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_BOOTDELAY=3 CONFIG_USE_PREBOOT=y # CONFIG_DISPLAY_BOARDINFO is not set diff --git a/configs/draco_defconfig b/configs/draco_defconfig index 4ba3bde2e6..419de5e1fc 100644 --- a/configs/draco_defconfig +++ b/configs/draco_defconfig @@ -17,6 +17,7 @@ CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_BOOTDELAY=3 CONFIG_USE_PREBOOT=y diff --git a/configs/dreamplug_defconfig b/configs/dreamplug_defconfig index 206539da5b..dc3196a9c9 100644 --- a/configs/dreamplug_defconfig +++ b/configs/dreamplug_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_DREAMPLUG=y CONFIG_NR_DRAM_BANKS=2 CONFIG_IDENT_STRING="\nMarvell-DreamPlug" +CONFIG_SKIP_LOWLEVEL_INIT=y # CONFIG_SYS_MALLOC_F is not set CONFIG_BOOTDELAY=3 CONFIG_USE_PREBOOT=y diff --git a/configs/ds109_defconfig b/configs/ds109_defconfig index 8f332a021d..2144bcc757 100644 --- a/configs/ds109_defconfig +++ b/configs/ds109_defconfig @@ -5,6 +5,7 @@ CONFIG_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_DS109=y CONFIG_NR_DRAM_BANKS=2 +CONFIG_SKIP_LOWLEVEL_INIT=y # CONFIG_SYS_MALLOC_F is not set CONFIG_USE_PREBOOT=y CONFIG_HUSH_PARSER=y diff --git a/configs/elgin-rv1108_defconfig b/configs/elgin-rv1108_defconfig index bcca040c9a..450a475854 100644 --- a/configs/elgin-rv1108_defconfig +++ b/configs/elgin-rv1108_defconfig @@ -7,6 +7,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0x10210000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y # CONFIG_USE_BOOTCOMMAND is not set CONFIG_DEFAULT_FDT_FILE="rv1108-elgin-r1.dtb" # CONFIG_DISPLAY_CPUINFO is not set @@ -40,7 +41,6 @@ CONFIG_PINCTRL=y CONFIG_PINCTRL_ROCKCHIP_RV1108=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_BAUDRATE=1500000 -# CONFIG_SPL_SERIAL_PRESENT is not set CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYSRESET=y CONFIG_USB=y diff --git a/configs/etamin_defconfig b/configs/etamin_defconfig index 31e711d32f..98e9e71a48 100644 --- a/configs/etamin_defconfig +++ b/configs/etamin_defconfig @@ -18,6 +18,7 @@ CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_BOOTDELAY=3 CONFIG_USE_PREBOOT=y diff --git a/configs/ethernut5_defconfig b/configs/ethernut5_defconfig index 45a9175dac..b1fd664345 100644 --- a/configs/ethernut5_defconfig +++ b/configs/ethernut5_defconfig @@ -8,6 +8,7 @@ CONFIG_ENV_SIZE=0x21000 CONFIG_ENV_OFFSET=0x3DE000 CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SECT_SIZE=0x21000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9XE" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/evb-px5_defconfig b/configs/evb-px5_defconfig index 5a06b2a99f..b8314ffee2 100644 --- a/configs/evb-px5_defconfig +++ b/configs/evb-px5_defconfig @@ -16,6 +16,7 @@ CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ANDROID_BOOT_IMAGE=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/evb-rk3036_defconfig b/configs/evb-rk3036_defconfig index d4d5a02740..fc25f0e023 100644 --- a/configs/evb-rk3036_defconfig +++ b/configs/evb-rk3036_defconfig @@ -11,13 +11,14 @@ CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEBUG_UART_BASE=0x20068000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART=y +CONFIG_SPL_TEXT_BASE=0x10081000 +CONFIG_SKIP_LOWLEVEL_INIT=y # CONFIG_ANDROID_BOOT_IMAGE is not set CONFIG_USE_PREBOOT=y CONFIG_DEFAULT_FDT_FILE="rk3036-evb.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y # CONFIG_SPL_FRAMEWORK is not set -CONFIG_SPL_TEXT_BASE=0x10081000 CONFIG_SPL_STACK_R=y CONFIG_CMD_GPT=y CONFIG_CMD_I2C=y diff --git a/configs/evb-rk3128_defconfig b/configs/evb-rk3128_defconfig index a3189638a1..f8a6e144da 100644 --- a/configs/evb-rk3128_defconfig +++ b/configs/evb-rk3128_defconfig @@ -6,6 +6,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_DEBUG_UART_BASE=0x20068000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_FIT=y CONFIG_DEFAULT_FDT_FILE="rk3128-evb.dtb" # CONFIG_DISPLAY_CPUINFO is not set diff --git a/configs/evb-rk3229_defconfig b/configs/evb-rk3229_defconfig index 128fbcd64c..fcad1380ad 100644 --- a/configs/evb-rk3229_defconfig +++ b/configs/evb-rk3229_defconfig @@ -10,6 +10,8 @@ CONFIG_SPL_STACK_R_ADDR=0x60600000 CONFIG_DEBUG_UART_BASE=0x11030000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART=y +CONFIG_SPL_TEXT_BASE=0x60000000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y @@ -18,7 +20,6 @@ CONFIG_USE_PREBOOT=y CONFIG_DEFAULT_FDT_FILE="rk3229-evb.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_SPL_TEXT_BASE=0x60000000 # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 diff --git a/configs/evb-rk3288_defconfig b/configs/evb-rk3288_defconfig index 405fde0c80..b498b558d4 100644 --- a/configs/evb-rk3288_defconfig +++ b/configs/evb-rk3288_defconfig @@ -8,13 +8,14 @@ CONFIG_SPL_SIZE_LIMIT=307200 CONFIG_DEBUG_UART_BASE=0xff690000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART=y +CONFIG_SPL_TEXT_BASE=0 +CONFIG_SKIP_LOWLEVEL_INIT_ONLY=y # CONFIG_ANDROID_BOOT_IMAGE is not set CONFIG_USE_PREBOOT=y CONFIG_SILENT_CONSOLE=y CONFIG_DEFAULT_FDT_FILE="rk3288-evb-rk808.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_SPL_TEXT_BASE=0 CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y CONFIG_CMD_I2C=y diff --git a/configs/evb-rk3328_defconfig b/configs/evb-rk3328_defconfig index 37610774c1..58b54bc3d6 100644 --- a/configs/evb-rk3328_defconfig +++ b/configs/evb-rk3328_defconfig @@ -12,6 +12,7 @@ CONFIG_SPL_STACK_R_ADDR=0x600000 CONFIG_DEBUG_UART_BASE=0xFF130000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_TPL_SYS_MALLOC_F_LEN=0x800 # CONFIG_ANDROID_BOOT_IMAGE is not set CONFIG_FIT=y diff --git a/configs/evb-rk3399_defconfig b/configs/evb-rk3399_defconfig index a0d215a5f1..92e4691857 100644 --- a/configs/evb-rk3399_defconfig +++ b/configs/evb-rk3399_defconfig @@ -8,6 +8,7 @@ CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEBUG_UART_BASE=0xFF1A0000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-evb.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y diff --git a/configs/evb-rv1108_defconfig b/configs/evb-rv1108_defconfig index 0eff03ce9f..9baf81d1c7 100644 --- a/configs/evb-rv1108_defconfig +++ b/configs/evb-rv1108_defconfig @@ -6,6 +6,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0x10210000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y # CONFIG_USE_BOOTCOMMAND is not set CONFIG_DEFAULT_FDT_FILE="rv1108-evb.dtb" # CONFIG_DISPLAY_CPUINFO is not set @@ -37,7 +38,6 @@ CONFIG_GMAC_ROCKCHIP=y CONFIG_PINCTRL=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_BAUDRATE=1500000 -# CONFIG_SPL_SERIAL_PRESENT is not set CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYSRESET=y CONFIG_USB=y diff --git a/configs/ficus-rk3399_defconfig b/configs/ficus-rk3399_defconfig index 8b3692cdf0..895a25d7e5 100644 --- a/configs/ficus-rk3399_defconfig +++ b/configs/ficus-rk3399_defconfig @@ -8,9 +8,10 @@ CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEBUG_UART_BASE=0xFF1A0000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART=y +CONFIG_SPL_TEXT_BASE=0xff8c2000 +CONFIG_SKIP_LOWLEVEL_INIT=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_SPL_TEXT_BASE=0xff8c2000 # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x4000 diff --git a/configs/firefly-rk3288_defconfig b/configs/firefly-rk3288_defconfig index 7ca522b479..127b111db9 100644 --- a/configs/firefly-rk3288_defconfig +++ b/configs/firefly-rk3288_defconfig @@ -9,13 +9,14 @@ CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEBUG_UART_BASE=0xff690000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART=y +CONFIG_SPL_TEXT_BASE=0xff704000 +CONFIG_SKIP_LOWLEVEL_INIT_ONLY=y # CONFIG_ANDROID_BOOT_IMAGE is not set CONFIG_USE_PREBOOT=y CONFIG_SILENT_CONSOLE=y CONFIG_DEFAULT_FDT_FILE="rk3288-firefly.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_SPL_TEXT_BASE=0xff704000 CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_CMD_GPIO=y diff --git a/configs/firefly-rk3399_defconfig b/configs/firefly-rk3399_defconfig index d022631465..8d9a20b5f0 100644 --- a/configs/firefly-rk3399_defconfig +++ b/configs/firefly-rk3399_defconfig @@ -8,6 +8,7 @@ CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEBUG_UART_BASE=0xFF1A0000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-firefly.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y diff --git a/configs/gardena-smart-gateway-at91sam_defconfig b/configs/gardena-smart-gateway-at91sam_defconfig index c495ba4612..1e219daa3a 100644 --- a/configs/gardena-smart-gateway-at91sam_defconfig +++ b/configs/gardena-smart-gateway-at91sam_defconfig @@ -17,6 +17,9 @@ CONFIG_DEBUG_UART_BASE=0xfffff200 CONFIG_DEBUG_UART_CLOCK=132000000 CONFIG_SMBIOS_PRODUCT_NAME="at91sam9x5ek" CONFIG_DEBUG_UART=y +CONFIG_SPL_TEXT_BASE=0x300000 +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_SKIP_LOWLEVEL_INIT_ONLY=y CONFIG_FIT=y CONFIG_NAND_BOOT=y CONFIG_BOOTDELAY=3 @@ -24,7 +27,6 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk mtdparts=atmel_nand:256k(bootstrap)ro,768k(uboot)ro,256k(env_redundant),256k(env),512k(dtb),6M(kernel)ro,-(rootfs) rootfstype=ubifs ubi.mtd=6 root=ubi0:rootfs rw" CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_SPL_TEXT_BASE=0x300000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SEPARATE_BSS=y # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set diff --git a/configs/gardena-smart-gateway-mt7688-ram_defconfig b/configs/gardena-smart-gateway-mt7688-ram_defconfig index 1a1167b2a6..4499acc0d7 100644 --- a/configs/gardena-smart-gateway-mt7688-ram_defconfig +++ b/configs/gardena-smart-gateway-mt7688-ram_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_BOOTCOUNT_ADDR=0xb000006c CONFIG_ARCH_MTMIPS=y # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y @@ -67,7 +68,6 @@ CONFIG_PHY=y CONFIG_POWER_DOMAIN=y CONFIG_RAM=y CONFIG_DM_RESET=y -# CONFIG_SPL_SERIAL_PRESENT is not set CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_MT7621_SPI=y diff --git a/configs/geekbox_defconfig b/configs/geekbox_defconfig index 7f8b3930a9..fa6f6371aa 100644 --- a/configs/geekbox_defconfig +++ b/configs/geekbox_defconfig @@ -8,6 +8,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0xFF690000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3368-geekbox.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y diff --git a/configs/goflexhome_defconfig b/configs/goflexhome_defconfig index 5fa8b4d1f5..0f531d618a 100644 --- a/configs/goflexhome_defconfig +++ b/configs/goflexhome_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_GOFLEXHOME=y CONFIG_NR_DRAM_BANKS=2 CONFIG_IDENT_STRING="\nSeagate GoFlex Home" +CONFIG_SKIP_LOWLEVEL_INIT=y # CONFIG_SYS_MALLOC_F is not set CONFIG_BOOTDELAY=3 CONFIG_USE_PREBOOT=y diff --git a/configs/gplugd_defconfig b/configs/gplugd_defconfig index 4766be03b8..2a427c82b3 100644 --- a/configs/gplugd_defconfig +++ b/configs/gplugd_defconfig @@ -5,6 +5,7 @@ CONFIG_TARGET_GPLUGD=y CONFIG_SYS_TEXT_BASE=0x00f00000 CONFIG_NR_DRAM_BANKS=2 CONFIG_IDENT_STRING="\nMarvell-gplugD" +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_BOOTDELAY=3 CONFIG_USE_PREBOOT=y # CONFIG_DISPLAY_BOARDINFO is not set diff --git a/configs/gurnard_defconfig b/configs/gurnard_defconfig index f461d92980..f8d552165e 100644 --- a/configs/gurnard_defconfig +++ b/configs/gurnard_defconfig @@ -5,6 +5,7 @@ CONFIG_TARGET_GURNARD=y CONFIG_ENV_SIZE=0x40000 CONFIG_ENV_OFFSET=0x80000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_SKIP_LOWLEVEL_INIT_ONLY=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G45" CONFIG_BOOTDELAY=3 diff --git a/configs/guruplug_defconfig b/configs/guruplug_defconfig index 12ca8b35a8..1ced4d301a 100644 --- a/configs/guruplug_defconfig +++ b/configs/guruplug_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_GURUPLUG=y CONFIG_NR_DRAM_BANKS=2 CONFIG_IDENT_STRING="\nMarvell-GuruPlug" +CONFIG_SKIP_LOWLEVEL_INIT=y # CONFIG_SYS_MALLOC_F is not set CONFIG_BOOTDELAY=3 CONFIG_USE_PREBOOT=y diff --git a/configs/highbank_defconfig b/configs/highbank_defconfig index 6873810789..d5b1ffbd62 100644 --- a/configs/highbank_defconfig +++ b/configs/highbank_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_TEXT_BASE=0x00008000 CONFIG_NR_DRAM_BANKS=0 CONFIG_SYS_BOOTCOUNT_SINGLEWORD=y CONFIG_SYS_BOOTCOUNT_ADDR=0xfff3cf0c +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/huawei_hg556a_ram_defconfig b/configs/huawei_hg556a_ram_defconfig index b8da32e2dc..68ced00212 100644 --- a/configs/huawei_hg556a_ram_defconfig +++ b/configs/huawei_hg556a_ram_defconfig @@ -6,6 +6,7 @@ CONFIG_SOC_BMIPS_BCM6358=y # CONFIG_MIPS_BOOT_CMDLINE_LEGACY is not set # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y +CONFIG_SKIP_LOWLEVEL_INIT=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DISPLAY_CPUINFO=y @@ -49,7 +50,6 @@ CONFIG_PHY=y CONFIG_BCM6358_USBH_PHY=y CONFIG_DM_RESET=y CONFIG_RESET_BCM6345=y -# CONFIG_SPL_SERIAL_PRESENT is not set CONFIG_DM_SERIAL=y CONFIG_BCM6345_SERIAL=y CONFIG_USB=y diff --git a/configs/ib62x0_defconfig b/configs/ib62x0_defconfig index 13a2e83a0b..7f0b86678f 100644 --- a/configs/ib62x0_defconfig +++ b/configs/ib62x0_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_IB62X0=y CONFIG_NR_DRAM_BANKS=2 CONFIG_IDENT_STRING=" RaidSonic ICY BOX IB-NAS62x0" +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_BOOTDELAY=3 CONFIG_USE_PREBOOT=y # CONFIG_DISPLAY_BOARDINFO is not set diff --git a/configs/iconnect_defconfig b/configs/iconnect_defconfig index aa67a6cef0..de4f1aeb95 100644 --- a/configs/iconnect_defconfig +++ b/configs/iconnect_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_ICONNECT=y CONFIG_NR_DRAM_BANKS=2 CONFIG_IDENT_STRING=" Iomega iConnect" +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_BOOTDELAY=3 CONFIG_USE_PREBOOT=y # CONFIG_DISPLAY_BOARDINFO is not set diff --git a/configs/imgtec_xilfpga_defconfig b/configs/imgtec_xilfpga_defconfig index cea6424780..221c0f3df9 100644 --- a/configs/imgtec_xilfpga_defconfig +++ b/configs/imgtec_xilfpga_defconfig @@ -3,6 +3,7 @@ CONFIG_SYS_MALLOC_F_LEN=0x600 CONFIG_TARGET_XILFPGA=y # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_BOOTDELAY=5 # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_HUSH_PARSER=y diff --git a/configs/inetspace_v2_defconfig b/configs/inetspace_v2_defconfig index 95dfa9c571..2c3dc08ce1 100644 --- a/configs/inetspace_v2_defconfig +++ b/configs/inetspace_v2_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_NETSPACE_V2=y CONFIG_NR_DRAM_BANKS=2 CONFIG_IDENT_STRING=" IS v2" +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="INETSPACE_V2" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/k2e_evm_defconfig b/configs/k2e_evm_defconfig index 260605533e..527d1dc191 100644 --- a/configs/k2e_evm_defconfig +++ b/configs/k2e_evm_defconfig @@ -13,6 +13,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_OF_BOARD_SETUP=y # CONFIG_USE_BOOTCOMMAND is not set diff --git a/configs/k2e_hs_evm_defconfig b/configs/k2e_hs_evm_defconfig index 98e3cdeb90..54444449d1 100644 --- a/configs/k2e_hs_evm_defconfig +++ b/configs/k2e_hs_evm_defconfig @@ -8,6 +8,7 @@ CONFIG_SYS_TEXT_BASE=0xC000060 CONFIG_TI_COMMON_CMD_OPTIONS=y CONFIG_TARGET_K2E_EVM=y CONFIG_NR_DRAM_BANKS=2 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_IMAGE_POST_PROCESS=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/k2g_evm_defconfig b/configs/k2g_evm_defconfig index 27804517fe..087583089b 100644 --- a/configs/k2g_evm_defconfig +++ b/configs/k2g_evm_defconfig @@ -13,6 +13,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_OF_BOARD_SETUP=y # CONFIG_USE_BOOTCOMMAND is not set diff --git a/configs/k2g_hs_evm_defconfig b/configs/k2g_hs_evm_defconfig index f5f3678bbe..17ff7174d1 100644 --- a/configs/k2g_hs_evm_defconfig +++ b/configs/k2g_hs_evm_defconfig @@ -8,6 +8,7 @@ CONFIG_SYS_TEXT_BASE=0xC000060 CONFIG_TI_COMMON_CMD_OPTIONS=y CONFIG_TARGET_K2G_EVM=y CONFIG_NR_DRAM_BANKS=2 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_IMAGE_POST_PROCESS=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/k2hk_evm_defconfig b/configs/k2hk_evm_defconfig index 2d5f1934d0..a1c2207104 100644 --- a/configs/k2hk_evm_defconfig +++ b/configs/k2hk_evm_defconfig @@ -13,6 +13,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_OF_BOARD_SETUP=y # CONFIG_USE_BOOTCOMMAND is not set diff --git a/configs/k2hk_hs_evm_defconfig b/configs/k2hk_hs_evm_defconfig index 8d679208b0..767e5070a1 100644 --- a/configs/k2hk_hs_evm_defconfig +++ b/configs/k2hk_hs_evm_defconfig @@ -8,6 +8,7 @@ CONFIG_SYS_TEXT_BASE=0xC000060 CONFIG_TI_COMMON_CMD_OPTIONS=y CONFIG_TARGET_K2HK_EVM=y CONFIG_NR_DRAM_BANKS=2 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_IMAGE_POST_PROCESS=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/k2l_evm_defconfig b/configs/k2l_evm_defconfig index b0898b0000..70a91985f5 100644 --- a/configs/k2l_evm_defconfig +++ b/configs/k2l_evm_defconfig @@ -13,6 +13,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_OF_BOARD_SETUP=y # CONFIG_USE_BOOTCOMMAND is not set diff --git a/configs/k2l_hs_evm_defconfig b/configs/k2l_hs_evm_defconfig index 8b7089bbc7..2e3ceb251c 100644 --- a/configs/k2l_hs_evm_defconfig +++ b/configs/k2l_hs_evm_defconfig @@ -8,6 +8,7 @@ CONFIG_SYS_TEXT_BASE=0xC000060 CONFIG_TI_COMMON_CMD_OPTIONS=y CONFIG_TARGET_K2L_EVM=y CONFIG_NR_DRAM_BANKS=2 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_FIT_IMAGE_POST_PROCESS=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_CONSOLE_INFO_QUIET=y diff --git a/configs/khadas-edge-captain-rk3399_defconfig b/configs/khadas-edge-captain-rk3399_defconfig index acfd91dbe7..06754c3da2 100644 --- a/configs/khadas-edge-captain-rk3399_defconfig +++ b/configs/khadas-edge-captain-rk3399_defconfig @@ -8,6 +8,7 @@ CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEBUG_UART_BASE=0xFF1A0000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-khadas-edge-captain.dtbi" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y diff --git a/configs/khadas-edge-rk3399_defconfig b/configs/khadas-edge-rk3399_defconfig index b71fd3a286..4b66193668 100644 --- a/configs/khadas-edge-rk3399_defconfig +++ b/configs/khadas-edge-rk3399_defconfig @@ -8,6 +8,7 @@ CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEBUG_UART_BASE=0xFF1A0000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-khadas-edge.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y diff --git a/configs/khadas-edge-v-rk3399_defconfig b/configs/khadas-edge-v-rk3399_defconfig index 0a789872dc..08f2999c4d 100644 --- a/configs/khadas-edge-v-rk3399_defconfig +++ b/configs/khadas-edge-v-rk3399_defconfig @@ -8,6 +8,7 @@ CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEBUG_UART_BASE=0xFF1A0000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-khadas-edge-v.dtbi" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y diff --git a/configs/km_kirkwood_128m16_defconfig b/configs/km_kirkwood_128m16_defconfig index 1ba69fc614..86cd975aa3 100644 --- a/configs/km_kirkwood_128m16_defconfig +++ b/configs/km_kirkwood_128m16_defconfig @@ -5,6 +5,7 @@ CONFIG_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x07d00000 CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_IDENT_STRING="\nKeymile Kirkwood 128M16" +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="KM_KIRKWOOD_128M16" CONFIG_MISC_INIT_R=y CONFIG_VERSION_VARIABLE=y diff --git a/configs/km_kirkwood_defconfig b/configs/km_kirkwood_defconfig index df0c9d322c..319b726273 100644 --- a/configs/km_kirkwood_defconfig +++ b/configs/km_kirkwood_defconfig @@ -5,6 +5,7 @@ CONFIG_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x07d00000 CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_IDENT_STRING="\nKeymile Kirkwood" +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="KM_KIRKWOOD" CONFIG_MISC_INIT_R=y CONFIG_VERSION_VARIABLE=y diff --git a/configs/km_kirkwood_pci_defconfig b/configs/km_kirkwood_pci_defconfig index c5020caab0..08e0561db9 100644 --- a/configs/km_kirkwood_pci_defconfig +++ b/configs/km_kirkwood_pci_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_TEXT_BASE=0x07d00000 CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_KM_FPGA_CONFIG=y CONFIG_IDENT_STRING="\nKeymile Kirkwood PCI" +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="KM_KIRKWOOD_PCI" CONFIG_MISC_INIT_R=y CONFIG_VERSION_VARIABLE=y diff --git a/configs/kmcoge5un_defconfig b/configs/kmcoge5un_defconfig index c3510c473b..6e567a1494 100644 --- a/configs/kmcoge5un_defconfig +++ b/configs/kmcoge5un_defconfig @@ -8,6 +8,7 @@ CONFIG_PIGGY_MAC_ADRESS_OFFSET=3 CONFIG_KM_ENV_IS_IN_SPI_NOR=y CONFIG_KM_PIGGY4_88E6352=y CONFIG_IDENT_STRING="\nKeymile COGE5UN" +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="KM_COGE5UN" CONFIG_MISC_INIT_R=y CONFIG_VERSION_VARIABLE=y diff --git a/configs/kmnusa_defconfig b/configs/kmnusa_defconfig index bcdf97ce1a..beab8f5e15 100644 --- a/configs/kmnusa_defconfig +++ b/configs/kmnusa_defconfig @@ -8,6 +8,7 @@ CONFIG_KM_FPGA_CONFIG=y CONFIG_KM_ENV_IS_IN_SPI_NOR=y CONFIG_KM_PIGGY4_88E6352=y CONFIG_IDENT_STRING="\nKeymile NUSA" +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="KM_NUSA" CONFIG_MISC_INIT_R=y CONFIG_VERSION_VARIABLE=y diff --git a/configs/kmsugp1_defconfig b/configs/kmsugp1_defconfig index 2f123bd3f2..41627bb052 100644 --- a/configs/kmsugp1_defconfig +++ b/configs/kmsugp1_defconfig @@ -8,6 +8,7 @@ CONFIG_KM_FPGA_CONFIG=y CONFIG_KM_ENV_IS_IN_SPI_NOR=y CONFIG_KM_PIGGY4_88E6352=y CONFIG_IDENT_STRING="\nKeymile SUGP1" +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="KM_SUGP1" CONFIG_MISC_INIT_R=y CONFIG_VERSION_VARIABLE=y diff --git a/configs/kmsuv31_defconfig b/configs/kmsuv31_defconfig index 2c9c9bb3fa..5e460357e2 100644 --- a/configs/kmsuv31_defconfig +++ b/configs/kmsuv31_defconfig @@ -7,6 +7,7 @@ CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_KM_FPGA_CONFIG=y CONFIG_KM_ENV_IS_IN_SPI_NOR=y CONFIG_IDENT_STRING="\nKeymile SUV31" +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="KM_SUV31" CONFIG_MISC_INIT_R=y CONFIG_VERSION_VARIABLE=y diff --git a/configs/kylin-rk3036_defconfig b/configs/kylin-rk3036_defconfig index c254d3e5cf..fda08015c1 100644 --- a/configs/kylin-rk3036_defconfig +++ b/configs/kylin-rk3036_defconfig @@ -12,13 +12,14 @@ CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEBUG_UART_BASE=0x20068000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART=y +CONFIG_SPL_TEXT_BASE=0x10081000 +CONFIG_SKIP_LOWLEVEL_INIT=y # CONFIG_ANDROID_BOOT_IMAGE is not set CONFIG_USE_PREBOOT=y CONFIG_DEFAULT_FDT_FILE="rk3036-kylin.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y # CONFIG_SPL_FRAMEWORK is not set -CONFIG_SPL_TEXT_BASE=0x10081000 CONFIG_SPL_STACK_R=y CONFIG_CMD_GPT=y CONFIG_CMD_I2C=y diff --git a/configs/legoev3_defconfig b/configs/legoev3_defconfig index 0f9f62450d..43691f4471 100644 --- a/configs/legoev3_defconfig +++ b/configs/legoev3_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_DAVINCI=y CONFIG_SYS_TEXT_BASE=0xc1080000 CONFIG_TARGET_LEGOEV3=y CONFIG_NR_DRAM_BANKS=1 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_BOOTDELAY=0 CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set diff --git a/configs/linkit-smart-7688-ram_defconfig b/configs/linkit-smart-7688-ram_defconfig index aa76633802..19b4a02406 100644 --- a/configs/linkit-smart-7688-ram_defconfig +++ b/configs/linkit-smart-7688-ram_defconfig @@ -5,6 +5,7 @@ CONFIG_ARCH_MTMIPS=y CONFIG_BOARD_LINKIT_SMART_7688=y # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_LEGACY_IMAGE_FORMAT=y @@ -54,7 +55,6 @@ CONFIG_MT76X8_USB_PHY=y CONFIG_POWER_DOMAIN=y CONFIG_RAM=y CONFIG_DM_RESET=y -# CONFIG_SPL_SERIAL_PRESENT is not set CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_MT7621_SPI=y diff --git a/configs/lion-rk3368_defconfig b/configs/lion-rk3368_defconfig index 77dbb281f1..e5401ab4ba 100644 --- a/configs/lion-rk3368_defconfig +++ b/configs/lion-rk3368_defconfig @@ -15,6 +15,8 @@ CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_SMBIOS_PRODUCT_NAME="sheep_rk3368" CONFIG_DEBUG_UART=y +CONFIG_SPL_TEXT_BASE=0x00000000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ANDROID_BOOT_IMAGE=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y @@ -28,7 +30,6 @@ CONFIG_DEFAULT_FDT_FILE="rockchip/rk3368-lion-haikou.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_ARCH_EARLY_INIT_R=y -CONFIG_SPL_TEXT_BASE=0x00000000 CONFIG_SPL_BOOTROM_SUPPORT=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_TPL_SYS_MALLOC_SIMPLE=y diff --git a/configs/ls1012a2g5rdb_qspi_defconfig b/configs/ls1012a2g5rdb_qspi_defconfig index 1ef92b445a..d9d41dc2eb 100644 --- a/configs/ls1012a2g5rdb_qspi_defconfig +++ b/configs/ls1012a2g5rdb_qspi_defconfig @@ -5,6 +5,7 @@ CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y CONFIG_NR_DRAM_BANKS=2 CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y diff --git a/configs/ls1012a2g5rdb_tfa_defconfig b/configs/ls1012a2g5rdb_tfa_defconfig index 852cc5634e..19a2af1186 100644 --- a/configs/ls1012a2g5rdb_tfa_defconfig +++ b/configs/ls1012a2g5rdb_tfa_defconfig @@ -7,6 +7,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y diff --git a/configs/ls1012afrdm_qspi_defconfig b/configs/ls1012afrdm_qspi_defconfig index 2b83e4ad17..04becf7d48 100644 --- a/configs/ls1012afrdm_qspi_defconfig +++ b/configs/ls1012afrdm_qspi_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x40100000 CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y CONFIG_NR_DRAM_BANKS=2 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y diff --git a/configs/ls1012afrdm_tfa_defconfig b/configs/ls1012afrdm_tfa_defconfig index 0e1d15266f..a3b85b4815 100644 --- a/configs/ls1012afrdm_tfa_defconfig +++ b/configs/ls1012afrdm_tfa_defconfig @@ -6,6 +6,7 @@ CONFIG_QSPI_AHB_INIT=y CONFIG_NR_DRAM_BANKS=2 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y diff --git a/configs/ls1012afrwy_qspi_SECURE_BOOT_defconfig b/configs/ls1012afrwy_qspi_SECURE_BOOT_defconfig index 3b1568f207..4fbb7e0e96 100644 --- a/configs/ls1012afrwy_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1012afrwy_qspi_SECURE_BOOT_defconfig @@ -5,6 +5,7 @@ CONFIG_SECURE_BOOT=y CONFIG_FSL_LS_PPA=y CONFIG_NR_DRAM_BANKS=2 CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y diff --git a/configs/ls1012afrwy_qspi_defconfig b/configs/ls1012afrwy_qspi_defconfig index 08eedec827..2d49752e91 100644 --- a/configs/ls1012afrwy_qspi_defconfig +++ b/configs/ls1012afrwy_qspi_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x40100000 CONFIG_FSL_LS_PPA=y CONFIG_NR_DRAM_BANKS=2 CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y diff --git a/configs/ls1012afrwy_tfa_SECURE_BOOT_defconfig b/configs/ls1012afrwy_tfa_SECURE_BOOT_defconfig index 640a462dfb..e4b1da0615 100644 --- a/configs/ls1012afrwy_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1012afrwy_tfa_SECURE_BOOT_defconfig @@ -7,6 +7,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y diff --git a/configs/ls1012afrwy_tfa_defconfig b/configs/ls1012afrwy_tfa_defconfig index 65ed34e583..a780c9494b 100644 --- a/configs/ls1012afrwy_tfa_defconfig +++ b/configs/ls1012afrwy_tfa_defconfig @@ -6,6 +6,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y diff --git a/configs/ls1012aqds_qspi_defconfig b/configs/ls1012aqds_qspi_defconfig index 90b30a6172..14620cd2de 100644 --- a/configs/ls1012aqds_qspi_defconfig +++ b/configs/ls1012aqds_qspi_defconfig @@ -5,6 +5,7 @@ CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y CONFIG_NR_DRAM_BANKS=2 CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y diff --git a/configs/ls1012aqds_tfa_SECURE_BOOT_defconfig b/configs/ls1012aqds_tfa_SECURE_BOOT_defconfig index f011aa02f5..d38c6be9ed 100644 --- a/configs/ls1012aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1012aqds_tfa_SECURE_BOOT_defconfig @@ -7,6 +7,7 @@ CONFIG_QSPI_AHB_INIT=y CONFIG_NR_DRAM_BANKS=2 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y diff --git a/configs/ls1012aqds_tfa_defconfig b/configs/ls1012aqds_tfa_defconfig index 0379b61fa8..f1bd4987fe 100644 --- a/configs/ls1012aqds_tfa_defconfig +++ b/configs/ls1012aqds_tfa_defconfig @@ -7,6 +7,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y diff --git a/configs/ls1012ardb_qspi_SECURE_BOOT_defconfig b/configs/ls1012ardb_qspi_SECURE_BOOT_defconfig index 533e251341..07e71a7819 100644 --- a/configs/ls1012ardb_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1012ardb_qspi_SECURE_BOOT_defconfig @@ -6,6 +6,7 @@ CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y CONFIG_NR_DRAM_BANKS=2 CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y diff --git a/configs/ls1012ardb_qspi_defconfig b/configs/ls1012ardb_qspi_defconfig index f9ea2097fb..de38a544ae 100644 --- a/configs/ls1012ardb_qspi_defconfig +++ b/configs/ls1012ardb_qspi_defconfig @@ -5,6 +5,7 @@ CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y CONFIG_NR_DRAM_BANKS=2 CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y diff --git a/configs/ls1012ardb_tfa_SECURE_BOOT_defconfig b/configs/ls1012ardb_tfa_SECURE_BOOT_defconfig index f3a2a13e0b..29d30ec911 100644 --- a/configs/ls1012ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1012ardb_tfa_SECURE_BOOT_defconfig @@ -8,6 +8,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y diff --git a/configs/ls1012ardb_tfa_defconfig b/configs/ls1012ardb_tfa_defconfig index 275fad8cf9..001705d323 100644 --- a/configs/ls1012ardb_tfa_defconfig +++ b/configs/ls1012ardb_tfa_defconfig @@ -7,6 +7,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y diff --git a/configs/ls1021aqds_ddr4_nor_defconfig b/configs/ls1021aqds_ddr4_nor_defconfig index 61855e9b7c..9d37aaa151 100644 --- a/configs/ls1021aqds_ddr4_nor_defconfig +++ b/configs/ls1021aqds_ddr4_nor_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_LS1021AQDS=y CONFIG_SYS_TEXT_BASE=0x60100000 CONFIG_NR_DRAM_BANKS=1 CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls1021aqds_ddr4_nor_lpuart_defconfig b/configs/ls1021aqds_ddr4_nor_lpuart_defconfig index 213f2dfb5b..1dafe78d14 100644 --- a/configs/ls1021aqds_ddr4_nor_lpuart_defconfig +++ b/configs/ls1021aqds_ddr4_nor_lpuart_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_LS1021AQDS=y CONFIG_SYS_TEXT_BASE=0x60100000 CONFIG_NR_DRAM_BANKS=1 CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls1021aqds_nand_defconfig b/configs/ls1021aqds_nand_defconfig index 3e0075d08d..51ce62620e 100644 --- a/configs/ls1021aqds_nand_defconfig +++ b/configs/ls1021aqds_nand_defconfig @@ -8,6 +8,8 @@ CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_AHCI=y +CONFIG_SPL_TEXT_BASE=0x10000000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y @@ -19,7 +21,6 @@ CONFIG_SILENT_CONSOLE=y # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_MISC_INIT_R=y -CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xe8 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls1021aqds_nor_SECURE_BOOT_defconfig b/configs/ls1021aqds_nor_SECURE_BOOT_defconfig index 43b3f6d255..8eecb6ab40 100644 --- a/configs/ls1021aqds_nor_SECURE_BOOT_defconfig +++ b/configs/ls1021aqds_nor_SECURE_BOOT_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x60100000 CONFIG_SECURE_BOOT=y CONFIG_NR_DRAM_BANKS=1 CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/ls1021aqds_nor_defconfig b/configs/ls1021aqds_nor_defconfig index 7f42e51263..219c51ca2f 100644 --- a/configs/ls1021aqds_nor_defconfig +++ b/configs/ls1021aqds_nor_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_LS1021AQDS=y CONFIG_SYS_TEXT_BASE=0x60100000 CONFIG_NR_DRAM_BANKS=1 CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls1021aqds_nor_lpuart_defconfig b/configs/ls1021aqds_nor_lpuart_defconfig index b67c24cf64..94927aa00e 100644 --- a/configs/ls1021aqds_nor_lpuart_defconfig +++ b/configs/ls1021aqds_nor_lpuart_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_LS1021AQDS=y CONFIG_SYS_TEXT_BASE=0x60100000 CONFIG_NR_DRAM_BANKS=1 CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls1021aqds_qspi_defconfig b/configs/ls1021aqds_qspi_defconfig index db74cc5712..a90b502908 100644 --- a/configs/ls1021aqds_qspi_defconfig +++ b/configs/ls1021aqds_qspi_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_LS1021AQDS=y CONFIG_SYS_TEXT_BASE=0x40100000 CONFIG_NR_DRAM_BANKS=1 CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls1021aqds_sdcard_ifc_defconfig b/configs/ls1021aqds_sdcard_ifc_defconfig index daabf7680b..d9566fc5b7 100644 --- a/configs/ls1021aqds_sdcard_ifc_defconfig +++ b/configs/ls1021aqds_sdcard_ifc_defconfig @@ -9,6 +9,8 @@ CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_AHCI=y +CONFIG_SPL_TEXT_BASE=0x10000000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SD_BOOT" @@ -18,7 +20,6 @@ CONFIG_SILENT_CONSOLE=y # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_MISC_INIT_R=y -CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xe8 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls1021aqds_sdcard_qspi_defconfig b/configs/ls1021aqds_sdcard_qspi_defconfig index cc71c28259..3378fa77fe 100644 --- a/configs/ls1021aqds_sdcard_qspi_defconfig +++ b/configs/ls1021aqds_sdcard_qspi_defconfig @@ -9,6 +9,8 @@ CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_AHCI=y +CONFIG_SPL_TEXT_BASE=0x10000000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SD_BOOT,SD_BOOT_QSPI" @@ -18,7 +20,6 @@ CONFIG_SILENT_CONSOLE=y # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_MISC_INIT_R=y -CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xe8 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls1021atwr_nor_SECURE_BOOT_defconfig b/configs/ls1021atwr_nor_SECURE_BOOT_defconfig index 8871c61b87..73b89e1dbc 100644 --- a/configs/ls1021atwr_nor_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_nor_SECURE_BOOT_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x60100000 CONFIG_SECURE_BOOT=y CONFIG_NR_DRAM_BANKS=1 CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT=y diff --git a/configs/ls1021atwr_nor_defconfig b/configs/ls1021atwr_nor_defconfig index a5aaa9a350..8bf9267c45 100644 --- a/configs/ls1021atwr_nor_defconfig +++ b/configs/ls1021atwr_nor_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_LS1021ATWR=y CONFIG_SYS_TEXT_BASE=0x60100000 CONFIG_NR_DRAM_BANKS=1 CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/ls1021atwr_nor_lpuart_defconfig b/configs/ls1021atwr_nor_lpuart_defconfig index fe0f6c4052..f5a031dd60 100644 --- a/configs/ls1021atwr_nor_lpuart_defconfig +++ b/configs/ls1021atwr_nor_lpuart_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_LS1021ATWR=y CONFIG_SYS_TEXT_BASE=0x60100000 CONFIG_NR_DRAM_BANKS=1 CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/ls1021atwr_qspi_defconfig b/configs/ls1021atwr_qspi_defconfig index 0e2525fd71..34f73604fd 100644 --- a/configs/ls1021atwr_qspi_defconfig +++ b/configs/ls1021atwr_qspi_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_LS1021ATWR=y CONFIG_SYS_TEXT_BASE=0x40100000 CONFIG_NR_DRAM_BANKS=1 CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig index ad07a98440..8fc5c271cf 100644 --- a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig @@ -9,6 +9,8 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y +CONFIG_SPL_TEXT_BASE=0x10000000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y @@ -22,7 +24,6 @@ CONFIG_SILENT_CONSOLE=y # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_MISC_INIT_R=y -CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xe8 CONFIG_SPL_CRYPTO_SUPPORT=y diff --git a/configs/ls1021atwr_sdcard_ifc_defconfig b/configs/ls1021atwr_sdcard_ifc_defconfig index 1a01e5fdbc..984b706204 100644 --- a/configs/ls1021atwr_sdcard_ifc_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_defconfig @@ -8,6 +8,8 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_AHCI=y +CONFIG_SPL_TEXT_BASE=0x10000000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y @@ -22,7 +24,6 @@ CONFIG_SILENT_CONSOLE=y # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_MISC_INIT_R=y -CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xe8 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls1021atwr_sdcard_qspi_defconfig b/configs/ls1021atwr_sdcard_qspi_defconfig index 2dad37e6d7..1234850961 100644 --- a/configs/ls1021atwr_sdcard_qspi_defconfig +++ b/configs/ls1021atwr_sdcard_qspi_defconfig @@ -8,6 +8,8 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_AHCI=y +CONFIG_SPL_TEXT_BASE=0x10000000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y @@ -22,7 +24,6 @@ CONFIG_SILENT_CONSOLE=y # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_MISC_INIT_R=y -CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xe8 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls1028aqds_tfa_SECURE_BOOT_defconfig b/configs/ls1028aqds_tfa_SECURE_BOOT_defconfig index 3170d81aaf..33c2af8a36 100644 --- a/configs/ls1028aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1028aqds_tfa_SECURE_BOOT_defconfig @@ -8,6 +8,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls1028aqds_tfa_defconfig b/configs/ls1028aqds_tfa_defconfig index 2da7b1d94e..55463c8a9b 100644 --- a/configs/ls1028aqds_tfa_defconfig +++ b/configs/ls1028aqds_tfa_defconfig @@ -7,6 +7,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls1028ardb_tfa_SECURE_BOOT_defconfig b/configs/ls1028ardb_tfa_SECURE_BOOT_defconfig index c1e88b5465..f1dd0e26cf 100644 --- a/configs/ls1028ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1028ardb_tfa_SECURE_BOOT_defconfig @@ -8,6 +8,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls1028ardb_tfa_defconfig b/configs/ls1028ardb_tfa_defconfig index 4d0c12f96f..b713a3a3eb 100644 --- a/configs/ls1028ardb_tfa_defconfig +++ b/configs/ls1028ardb_tfa_defconfig @@ -7,6 +7,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls1043aqds_defconfig b/configs/ls1043aqds_defconfig index 65b2dd18f9..f6b4b90e81 100644 --- a/configs/ls1043aqds_defconfig +++ b/configs/ls1043aqds_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x60100000 CONFIG_FSL_LS_PPA=y CONFIG_NR_DRAM_BANKS=2 CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls1043aqds_lpuart_defconfig b/configs/ls1043aqds_lpuart_defconfig index 51fc761f45..3b55f80dc5 100644 --- a/configs/ls1043aqds_lpuart_defconfig +++ b/configs/ls1043aqds_lpuart_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x60100000 CONFIG_FSL_LS_PPA=y CONFIG_NR_DRAM_BANKS=2 CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls1043aqds_nand_defconfig b/configs/ls1043aqds_nand_defconfig index 10d08f8d6f..b04ec523df 100644 --- a/configs/ls1043aqds_nand_defconfig +++ b/configs/ls1043aqds_nand_defconfig @@ -9,6 +9,8 @@ CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_AHCI=y +CONFIG_SPL_TEXT_BASE=0x10000000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y @@ -19,7 +21,6 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 mtdparts=60000000.nor:2m@0x100000(nor_bank0_uboot),40m@0x1100000(nor_bank0_fit),7m(nor_bank0_user),2m@0x4100000(nor_bank4_uboot),40m@0x5100000(nor_bank4_fit),-(nor_bank4_user);7e800000.flash:1m(nand_uboot),1m(nand_uboot_env),20m(nand_fit);spi0.0:1m(uboot),5m(kernel),1m(dtb),9m(file_system)" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_MISC_INIT_R=y -CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xf0 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls1043aqds_nor_ddr3_defconfig b/configs/ls1043aqds_nor_ddr3_defconfig index 65734f5cda..869bbf2972 100644 --- a/configs/ls1043aqds_nor_ddr3_defconfig +++ b/configs/ls1043aqds_nor_ddr3_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x60100000 CONFIG_FSL_LS_PPA=y CONFIG_NR_DRAM_BANKS=2 CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls1043aqds_qspi_defconfig b/configs/ls1043aqds_qspi_defconfig index cc998775bd..c60a23950d 100644 --- a/configs/ls1043aqds_qspi_defconfig +++ b/configs/ls1043aqds_qspi_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x40100000 CONFIG_FSL_LS_PPA=y CONFIG_NR_DRAM_BANKS=2 CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls1043aqds_sdcard_ifc_defconfig b/configs/ls1043aqds_sdcard_ifc_defconfig index 5ab5ef6545..23ebac9c1f 100644 --- a/configs/ls1043aqds_sdcard_ifc_defconfig +++ b/configs/ls1043aqds_sdcard_ifc_defconfig @@ -10,6 +10,8 @@ CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_AHCI=y +CONFIG_SPL_TEXT_BASE=0x10000000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y @@ -20,7 +22,6 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 mtdparts=60000000.nor:2m@0x100000(nor_bank0_uboot),40m@0x1100000(nor_bank0_fit),7m(nor_bank0_user),2m@0x4100000(nor_bank4_uboot),40m@0x5100000(nor_bank4_fit),-(nor_bank4_user);7e800000.flash:1m(nand_uboot),1m(nand_uboot_env),20m(nand_fit);spi0.0:1m(uboot),5m(kernel),1m(dtb),9m(file_system)" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_MISC_INIT_R=y -CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xf0 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls1043aqds_sdcard_qspi_defconfig b/configs/ls1043aqds_sdcard_qspi_defconfig index ecd30238af..868d07fdc3 100644 --- a/configs/ls1043aqds_sdcard_qspi_defconfig +++ b/configs/ls1043aqds_sdcard_qspi_defconfig @@ -10,6 +10,8 @@ CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_AHCI=y +CONFIG_SPL_TEXT_BASE=0x10000000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y @@ -20,7 +22,6 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 mtdparts=spi0.0:1m(uboot),5m(kernel),1m(dtb),9m(file_system)" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_MISC_INIT_R=y -CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xf0 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig b/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig index 472786ab26..5e3eb9ff5c 100644 --- a/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig @@ -7,6 +7,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls1043aqds_tfa_defconfig b/configs/ls1043aqds_tfa_defconfig index b49ac2cb5d..efa903b8d6 100644 --- a/configs/ls1043aqds_tfa_defconfig +++ b/configs/ls1043aqds_tfa_defconfig @@ -6,6 +6,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls1043ardb_SECURE_BOOT_defconfig b/configs/ls1043ardb_SECURE_BOOT_defconfig index 57791a748e..cfc1666f4b 100644 --- a/configs/ls1043ardb_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_SECURE_BOOT_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x60100000 CONFIG_SECURE_BOOT=y CONFIG_FSL_LS_PPA=y CONFIG_NR_DRAM_BANKS=2 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls1043ardb_defconfig b/configs/ls1043ardb_defconfig index 49d498ae80..149d35cb5a 100644 --- a/configs/ls1043ardb_defconfig +++ b/configs/ls1043ardb_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_LS1043ARDB=y CONFIG_SYS_TEXT_BASE=0x60100000 CONFIG_FSL_LS_PPA=y CONFIG_NR_DRAM_BANKS=2 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls1043ardb_nand_SECURE_BOOT_defconfig b/configs/ls1043ardb_nand_SECURE_BOOT_defconfig index 3e2ecf414a..7d764945be 100644 --- a/configs/ls1043ardb_nand_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_nand_SECURE_BOOT_defconfig @@ -9,6 +9,8 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y +CONFIG_SPL_TEXT_BASE=0x10000000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y @@ -19,7 +21,6 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 mtdparts=60000000.nor:2m@0x100000(nor_bank0_uboot),40m@0x1100000(nor_bank0_fit),7m(nor_bank0_user),2m@0x4100000(nor_bank4_uboot),40m@0x5100000(nor_bank4_fit),-(nor_bank4_user);7e800000.flash:1m(nand_uboot),1m(nand_uboot_env),20m(nand_fit);spi0.0:1m(uboot),5m(kernel),1m(dtb),9m(file_system)" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_MISC_INIT_R=y -CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xf0 CONFIG_SPL_CRYPTO_SUPPORT=y diff --git a/configs/ls1043ardb_nand_defconfig b/configs/ls1043ardb_nand_defconfig index 68865fa363..353fa38043 100644 --- a/configs/ls1043ardb_nand_defconfig +++ b/configs/ls1043ardb_nand_defconfig @@ -8,6 +8,8 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y +CONFIG_SPL_TEXT_BASE=0x10000000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y @@ -18,7 +20,6 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 mtdparts=60000000.nor:2m@0x100000(nor_bank0_uboot),40m@0x1100000(nor_bank0_fit),7m(nor_bank0_user),2m@0x4100000(nor_bank4_uboot),40m@0x5100000(nor_bank4_fit),-(nor_bank4_user);7e800000.flash:1m(nand_uboot),1m(nand_uboot_env),20m(nand_fit);spi0.0:1m(uboot),5m(kernel),1m(dtb),9m(file_system)" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_MISC_INIT_R=y -CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SPL_BOARD_INIT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xf0 diff --git a/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig b/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig index 759d3703cd..fe35aeb7cf 100644 --- a/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig @@ -10,6 +10,8 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y +CONFIG_SPL_TEXT_BASE=0x10000000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y @@ -19,7 +21,6 @@ CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 mtdparts=60000000.nor:2m@0x100000(nor_bank0_uboot),40m@0x1100000(nor_bank0_fit),7m(nor_bank0_user),2m@0x4100000(nor_bank4_uboot),40m@0x5100000(nor_bank4_fit),-(nor_bank4_user);7e800000.flash:1m(nand_uboot),1m(nand_uboot_env),20m(nand_fit);spi0.0:1m(uboot),5m(kernel),1m(dtb),9m(file_system)" CONFIG_MISC_INIT_R=y -CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x110 CONFIG_SPL_CRYPTO_SUPPORT=y diff --git a/configs/ls1043ardb_sdcard_defconfig b/configs/ls1043ardb_sdcard_defconfig index ddfa7ca430..d31bcaa156 100644 --- a/configs/ls1043ardb_sdcard_defconfig +++ b/configs/ls1043ardb_sdcard_defconfig @@ -9,6 +9,8 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y +CONFIG_SPL_TEXT_BASE=0x10000000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y @@ -18,7 +20,6 @@ CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 mtdparts=60000000.nor:2m@0x100000(nor_bank0_uboot),40m@0x1100000(nor_bank0_fit),7m(nor_bank0_user),2m@0x4100000(nor_bank4_uboot),40m@0x5100000(nor_bank4_fit),-(nor_bank4_user);7e800000.flash:1m(nand_uboot),1m(nand_uboot_env),20m(nand_fit);spi0.0:1m(uboot),5m(kernel),1m(dtb),9m(file_system)" CONFIG_MISC_INIT_R=y -CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SPL_BOARD_INIT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xf0 diff --git a/configs/ls1043ardb_tfa_SECURE_BOOT_defconfig b/configs/ls1043ardb_tfa_SECURE_BOOT_defconfig index 5c8257de4e..3400bcfa95 100644 --- a/configs/ls1043ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_tfa_SECURE_BOOT_defconfig @@ -6,6 +6,7 @@ CONFIG_SECURE_BOOT=y CONFIG_NR_DRAM_BANKS=2 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls1043ardb_tfa_defconfig b/configs/ls1043ardb_tfa_defconfig index 75bb52ad4a..59947e95b7 100644 --- a/configs/ls1043ardb_tfa_defconfig +++ b/configs/ls1043ardb_tfa_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_TEXT_BASE=0x82000000 CONFIG_NR_DRAM_BANKS=2 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls1046afrwy_tfa_defconfig b/configs/ls1046afrwy_tfa_defconfig index 1d27408762..4023212013 100644 --- a/configs/ls1046afrwy_tfa_defconfig +++ b/configs/ls1046afrwy_tfa_defconfig @@ -7,6 +7,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls1046aqds_SECURE_BOOT_defconfig b/configs/ls1046aqds_SECURE_BOOT_defconfig index e863c97307..738d4e2f7a 100644 --- a/configs/ls1046aqds_SECURE_BOOT_defconfig +++ b/configs/ls1046aqds_SECURE_BOOT_defconfig @@ -5,6 +5,7 @@ CONFIG_SECURE_BOOT=y CONFIG_FSL_LS_PPA=y CONFIG_NR_DRAM_BANKS=2 CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls1046aqds_defconfig b/configs/ls1046aqds_defconfig index 30f9d82291..c4edc80c0a 100644 --- a/configs/ls1046aqds_defconfig +++ b/configs/ls1046aqds_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x60100000 CONFIG_FSL_LS_PPA=y CONFIG_NR_DRAM_BANKS=2 CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls1046aqds_lpuart_defconfig b/configs/ls1046aqds_lpuart_defconfig index a2381b7952..2b163f27a7 100644 --- a/configs/ls1046aqds_lpuart_defconfig +++ b/configs/ls1046aqds_lpuart_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x60100000 CONFIG_FSL_LS_PPA=y CONFIG_NR_DRAM_BANKS=2 CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls1046aqds_nand_defconfig b/configs/ls1046aqds_nand_defconfig index a6b6866a8a..0e6a7954c3 100644 --- a/configs/ls1046aqds_nand_defconfig +++ b/configs/ls1046aqds_nand_defconfig @@ -6,6 +6,8 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_AHCI=y +CONFIG_SPL_TEXT_BASE=0x10000000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y @@ -16,7 +18,6 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 mtdparts=60000000.nor:2m@0x100000(nor_bank0_uboot),40m@0x1100000(nor_bank0_fit),7m(nor_bank0_user),2m@0x4100000(nor_bank4_uboot),40m@0x5100000(nor_bank4_fit),-(nor_bank4_user);7e800000.flash:4m(nand_uboot),36m(nand_kernel),472m(nand_free);spi0.0:2m(uboot),14m(free)" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_MISC_INIT_R=y -CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SPL_BOARD_INIT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x110 diff --git a/configs/ls1046aqds_qspi_defconfig b/configs/ls1046aqds_qspi_defconfig index 7c0b0d3c23..3a8ac00f81 100644 --- a/configs/ls1046aqds_qspi_defconfig +++ b/configs/ls1046aqds_qspi_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x40100000 CONFIG_FSL_LS_PPA=y CONFIG_NR_DRAM_BANKS=2 CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls1046aqds_sdcard_ifc_defconfig b/configs/ls1046aqds_sdcard_ifc_defconfig index 77dc0b015b..2e9a05c130 100644 --- a/configs/ls1046aqds_sdcard_ifc_defconfig +++ b/configs/ls1046aqds_sdcard_ifc_defconfig @@ -10,6 +10,8 @@ CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_AHCI=y +CONFIG_SPL_TEXT_BASE=0x10000000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y @@ -20,7 +22,6 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 mtdparts=60000000.nor:2m@0x100000(nor_bank0_uboot),40m@0x1100000(nor_bank0_fit),7m(nor_bank0_user),2m@0x4100000(nor_bank4_uboot),40m@0x5100000(nor_bank4_fit),-(nor_bank4_user);7e800000.flash:4m(nand_uboot),36m(nand_kernel),472m(nand_free);spi0.0:2m(uboot),14m(free)" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_MISC_INIT_R=y -CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SPL_BOARD_INIT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x110 diff --git a/configs/ls1046aqds_sdcard_qspi_defconfig b/configs/ls1046aqds_sdcard_qspi_defconfig index 723a04f017..d11690fa00 100644 --- a/configs/ls1046aqds_sdcard_qspi_defconfig +++ b/configs/ls1046aqds_sdcard_qspi_defconfig @@ -10,6 +10,8 @@ CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_AHCI=y +CONFIG_SPL_TEXT_BASE=0x10000000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y @@ -20,7 +22,6 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 mtdparts=1550000.spi-0:2m(uboot),14m(free)" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_MISC_INIT_R=y -CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SPL_BOARD_INIT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x110 diff --git a/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig b/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig index 2b4f72f54c..95f1fd1163 100644 --- a/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig @@ -7,6 +7,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls1046aqds_tfa_defconfig b/configs/ls1046aqds_tfa_defconfig index 6449d3a771..eed2f4b8d2 100644 --- a/configs/ls1046aqds_tfa_defconfig +++ b/configs/ls1046aqds_tfa_defconfig @@ -6,6 +6,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls1046ardb_emmc_defconfig b/configs/ls1046ardb_emmc_defconfig index 855edc726e..c8548020b1 100644 --- a/configs/ls1046ardb_emmc_defconfig +++ b/configs/ls1046ardb_emmc_defconfig @@ -10,6 +10,8 @@ CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_AHCI=y +CONFIG_SPL_TEXT_BASE=0x10000000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y @@ -20,7 +22,6 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 mtdparts=1550000.spi-0:1m(rcw),15m(u-boot),48m(kernel.itb);7e800000.flash:16m(nand_uboot),48m(nand_kernel),448m(nand_free)" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_MISC_INIT_R=y -CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SPL_BOARD_INIT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x110 diff --git a/configs/ls1046ardb_qspi_SECURE_BOOT_defconfig b/configs/ls1046ardb_qspi_SECURE_BOOT_defconfig index dd784459b3..4b309ee580 100644 --- a/configs/ls1046ardb_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1046ardb_qspi_SECURE_BOOT_defconfig @@ -6,6 +6,7 @@ CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y CONFIG_NR_DRAM_BANKS=2 CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls1046ardb_qspi_defconfig b/configs/ls1046ardb_qspi_defconfig index ef5e73dd28..39d1a2fb64 100644 --- a/configs/ls1046ardb_qspi_defconfig +++ b/configs/ls1046ardb_qspi_defconfig @@ -5,6 +5,7 @@ CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y CONFIG_NR_DRAM_BANKS=2 CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls1046ardb_qspi_spl_defconfig b/configs/ls1046ardb_qspi_spl_defconfig index 6326c47cdb..c131527dcf 100644 --- a/configs/ls1046ardb_qspi_spl_defconfig +++ b/configs/ls1046ardb_qspi_spl_defconfig @@ -11,6 +11,8 @@ CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_AHCI=y +CONFIG_SPL_TEXT_BASE=0x10000000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y @@ -20,7 +22,6 @@ CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 mtdparts=1550000.spi-0:1m(rcw),15m(u-boot),48m(kernel.itb);7e800000.flash:16m(nand_uboot),48m(nand_kernel),448m(nand_free)" CONFIG_MISC_INIT_R=y -CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig b/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig index 7bf23ad7fd..7389ad585b 100644 --- a/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig +++ b/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig @@ -10,6 +10,8 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y +CONFIG_SPL_TEXT_BASE=0x10000000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y @@ -19,7 +21,6 @@ CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 mtdparts=1550000.spi-0:1m(rcw),15m(u-boot),48m(kernel.itb);7e800000.flash:16m(nand_uboot),48m(nand_kernel),448m(nand_free)" CONFIG_MISC_INIT_R=y -CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x110 CONFIG_SPL_CRYPTO_SUPPORT=y diff --git a/configs/ls1046ardb_sdcard_defconfig b/configs/ls1046ardb_sdcard_defconfig index 829861b03b..1328b59c8d 100644 --- a/configs/ls1046ardb_sdcard_defconfig +++ b/configs/ls1046ardb_sdcard_defconfig @@ -10,6 +10,8 @@ CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_AHCI=y +CONFIG_SPL_TEXT_BASE=0x10000000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y @@ -19,7 +21,6 @@ CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 mtdparts=1550000.spi-0:1m(rcw),15m(u-boot),48m(kernel.itb);7e800000.flash:16m(nand_uboot),48m(nand_kernel),448m(nand_free)" CONFIG_MISC_INIT_R=y -CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_SPL_BOARD_INIT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x110 diff --git a/configs/ls1046ardb_tfa_SECURE_BOOT_defconfig b/configs/ls1046ardb_tfa_SECURE_BOOT_defconfig index 9423d7db22..a2631a2bdd 100644 --- a/configs/ls1046ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1046ardb_tfa_SECURE_BOOT_defconfig @@ -8,6 +8,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls1046ardb_tfa_defconfig b/configs/ls1046ardb_tfa_defconfig index 1aca8ef13e..83608e4df6 100644 --- a/configs/ls1046ardb_tfa_defconfig +++ b/configs/ls1046ardb_tfa_defconfig @@ -7,6 +7,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls1088aqds_defconfig b/configs/ls1088aqds_defconfig index 56af5261e3..53a816c465 100644 --- a/configs/ls1088aqds_defconfig +++ b/configs/ls1088aqds_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x30100000 CONFIG_FSL_LS_PPA=y CONFIG_NR_DRAM_BANKS=2 CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls1088aqds_qspi_SECURE_BOOT_defconfig b/configs/ls1088aqds_qspi_SECURE_BOOT_defconfig index bb90ed7549..194339ccac 100644 --- a/configs/ls1088aqds_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1088aqds_qspi_SECURE_BOOT_defconfig @@ -6,6 +6,7 @@ CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y CONFIG_NR_DRAM_BANKS=2 CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y diff --git a/configs/ls1088aqds_qspi_defconfig b/configs/ls1088aqds_qspi_defconfig index 8aeca657e8..1e7881025d 100644 --- a/configs/ls1088aqds_qspi_defconfig +++ b/configs/ls1088aqds_qspi_defconfig @@ -5,6 +5,7 @@ CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y CONFIG_NR_DRAM_BANKS=2 CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y diff --git a/configs/ls1088aqds_sdcard_ifc_defconfig b/configs/ls1088aqds_sdcard_ifc_defconfig index 58a6795b6d..ac40e1d7ad 100644 --- a/configs/ls1088aqds_sdcard_ifc_defconfig +++ b/configs/ls1088aqds_sdcard_ifc_defconfig @@ -10,6 +10,8 @@ CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_AHCI=y +CONFIG_SPL_TEXT_BASE=0x1800a000 +CONFIG_SKIP_LOWLEVEL_INIT=y # CONFIG_SYS_MALLOC_F is not set CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4" @@ -18,7 +20,6 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 ramdisk_size=0x3000000 default_hugepagesz=2m hugepagesz=2m hugepages=256" # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_SPL_TEXT_BASE=0x1800a000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x8b0 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls1088aqds_sdcard_qspi_defconfig b/configs/ls1088aqds_sdcard_qspi_defconfig index 5b5cbfa5d6..e087dd62ca 100644 --- a/configs/ls1088aqds_sdcard_qspi_defconfig +++ b/configs/ls1088aqds_sdcard_qspi_defconfig @@ -10,6 +10,8 @@ CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_AHCI=y +CONFIG_SPL_TEXT_BASE=0x1800a000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y @@ -21,7 +23,6 @@ CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21 # CONFIG_USE_BOOTCOMMAND is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_SPL_TEXT_BASE=0x1800a000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x8b0 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls1088aqds_tfa_defconfig b/configs/ls1088aqds_tfa_defconfig index 145beea761..33b54520c5 100644 --- a/configs/ls1088aqds_tfa_defconfig +++ b/configs/ls1088aqds_tfa_defconfig @@ -8,6 +8,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls1088ardb_qspi_SECURE_BOOT_defconfig b/configs/ls1088ardb_qspi_SECURE_BOOT_defconfig index 265303c356..b326fafcdb 100644 --- a/configs/ls1088ardb_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1088ardb_qspi_SECURE_BOOT_defconfig @@ -6,6 +6,7 @@ CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y CONFIG_NR_DRAM_BANKS=2 CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y diff --git a/configs/ls1088ardb_qspi_defconfig b/configs/ls1088ardb_qspi_defconfig index 6dd9df2dc1..f8c91b6fe1 100644 --- a/configs/ls1088ardb_qspi_defconfig +++ b/configs/ls1088ardb_qspi_defconfig @@ -5,6 +5,7 @@ CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y CONFIG_NR_DRAM_BANKS=2 CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y diff --git a/configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig b/configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig index 3d531295ae..7a2a170a16 100644 --- a/configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig @@ -10,6 +10,8 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y +CONFIG_SPL_TEXT_BASE=0x1800a000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y @@ -22,7 +24,6 @@ CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21 CONFIG_MISC_INIT_R=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_SPL_TEXT_BASE=0x1800a000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x8b0 CONFIG_SPL_CRYPTO_SUPPORT=y diff --git a/configs/ls1088ardb_sdcard_qspi_defconfig b/configs/ls1088ardb_sdcard_qspi_defconfig index 51b74e7c35..22a34bbede 100644 --- a/configs/ls1088ardb_sdcard_qspi_defconfig +++ b/configs/ls1088ardb_sdcard_qspi_defconfig @@ -10,6 +10,8 @@ CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_AHCI=y +CONFIG_SPL_TEXT_BASE=0x1800a000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y @@ -22,7 +24,6 @@ CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21 CONFIG_MISC_INIT_R=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_SPL_TEXT_BASE=0x1800a000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x8b0 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls1088ardb_tfa_SECURE_BOOT_defconfig b/configs/ls1088ardb_tfa_SECURE_BOOT_defconfig index 45df1347fa..c909862a5c 100644 --- a/configs/ls1088ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1088ardb_tfa_SECURE_BOOT_defconfig @@ -9,6 +9,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls1088ardb_tfa_defconfig b/configs/ls1088ardb_tfa_defconfig index b7c40a4d6c..516c565297 100644 --- a/configs/ls1088ardb_tfa_defconfig +++ b/configs/ls1088ardb_tfa_defconfig @@ -8,6 +8,7 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls2080a_emu_defconfig b/configs/ls2080a_emu_defconfig index 7e17728811..d45a026be3 100644 --- a/configs/ls2080a_emu_defconfig +++ b/configs/ls2080a_emu_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_LS2080A_EMU=y CONFIG_SYS_TEXT_BASE=0x30100000 CONFIG_NR_DRAM_BANKS=3 CONFIG_IDENT_STRING=" LS2080A-EMU" +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls2080a_simu_defconfig b/configs/ls2080a_simu_defconfig index 12f5b2eb74..ce50f4092b 100644 --- a/configs/ls2080a_simu_defconfig +++ b/configs/ls2080a_simu_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_LS2080A_SIMU=y CONFIG_SYS_TEXT_BASE=0x30100000 CONFIG_NR_DRAM_BANKS=3 CONFIG_IDENT_STRING=" LS2080A-SIMU" +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls2080aqds_SECURE_BOOT_defconfig b/configs/ls2080aqds_SECURE_BOOT_defconfig index c0fde247fc..a2b851f6c8 100644 --- a/configs/ls2080aqds_SECURE_BOOT_defconfig +++ b/configs/ls2080aqds_SECURE_BOOT_defconfig @@ -5,6 +5,7 @@ CONFIG_SECURE_BOOT=y CONFIG_FSL_LS_PPA=y CONFIG_NR_DRAM_BANKS=3 CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls2080aqds_defconfig b/configs/ls2080aqds_defconfig index e265ac177b..d3eebb30ea 100644 --- a/configs/ls2080aqds_defconfig +++ b/configs/ls2080aqds_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x30100000 CONFIG_FSL_LS_PPA=y CONFIG_NR_DRAM_BANKS=3 CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls2080aqds_nand_defconfig b/configs/ls2080aqds_nand_defconfig index 3a3694107d..f95d4f8b17 100644 --- a/configs/ls2080aqds_nand_defconfig +++ b/configs/ls2080aqds_nand_defconfig @@ -8,6 +8,8 @@ CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_NR_DRAM_BANKS=3 CONFIG_SPL=y CONFIG_AHCI=y +CONFIG_SPL_TEXT_BASE=0x1800a000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y @@ -17,7 +19,6 @@ CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 ramdisk_size=0x2000000 default_hugepagesz=2m hugepagesz=2m hugepages=256" # CONFIG_USE_BOOTCOMMAND is not set -CONFIG_SPL_TEXT_BASE=0x1800a000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/ls2080aqds_qspi_defconfig b/configs/ls2080aqds_qspi_defconfig index 53abf71bbd..bfa9b67576 100644 --- a/configs/ls2080aqds_qspi_defconfig +++ b/configs/ls2080aqds_qspi_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_LS2080AQDS=y CONFIG_SYS_TEXT_BASE=0x20100000 CONFIG_NR_DRAM_BANKS=3 CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls2080aqds_sdcard_defconfig b/configs/ls2080aqds_sdcard_defconfig index 9d1715f03f..b4b90b7495 100644 --- a/configs/ls2080aqds_sdcard_defconfig +++ b/configs/ls2080aqds_sdcard_defconfig @@ -10,6 +10,8 @@ CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_NR_DRAM_BANKS=3 CONFIG_SPL=y CONFIG_AHCI=y +CONFIG_SPL_TEXT_BASE=0x1800a000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y @@ -19,7 +21,6 @@ CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 ramdisk_size=0x2000000 default_hugepagesz=2m hugepagesz=2m hugepages=256" # CONFIG_USE_BOOTCOMMAND is not set -CONFIG_SPL_TEXT_BASE=0x1800a000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x8b0 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls2080ardb_SECURE_BOOT_defconfig b/configs/ls2080ardb_SECURE_BOOT_defconfig index 5f307f6caf..94115fa4d7 100644 --- a/configs/ls2080ardb_SECURE_BOOT_defconfig +++ b/configs/ls2080ardb_SECURE_BOOT_defconfig @@ -5,6 +5,7 @@ CONFIG_SECURE_BOOT=y CONFIG_FSL_LS_PPA=y CONFIG_NR_DRAM_BANKS=3 CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls2080ardb_defconfig b/configs/ls2080ardb_defconfig index c92121e6d3..ab6dcbacee 100644 --- a/configs/ls2080ardb_defconfig +++ b/configs/ls2080ardb_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x30100000 CONFIG_FSL_LS_PPA=y CONFIG_NR_DRAM_BANKS=3 CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls2080ardb_nand_defconfig b/configs/ls2080ardb_nand_defconfig index 56b78feab2..062f0b59f7 100644 --- a/configs/ls2080ardb_nand_defconfig +++ b/configs/ls2080ardb_nand_defconfig @@ -8,6 +8,8 @@ CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_NR_DRAM_BANKS=3 CONFIG_SPL=y CONFIG_AHCI=y +CONFIG_SPL_TEXT_BASE=0x1800a000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y @@ -18,7 +20,6 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS1,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0600 ramdisk_size=0x2000000 default_hugepagesz=2m hugepagesz=2m hugepages=256" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_MISC_INIT_R=y -CONFIG_SPL_TEXT_BASE=0x1800a000 CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y diff --git a/configs/ls2081ardb_defconfig b/configs/ls2081ardb_defconfig index da055d2d17..5b21c02c6a 100644 --- a/configs/ls2081ardb_defconfig +++ b/configs/ls2081ardb_defconfig @@ -5,6 +5,7 @@ CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y CONFIG_NR_DRAM_BANKS=3 CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls2088aqds_tfa_defconfig b/configs/ls2088aqds_tfa_defconfig index f0ebe7bc35..80e5c67ab2 100644 --- a/configs/ls2088aqds_tfa_defconfig +++ b/configs/ls2088aqds_tfa_defconfig @@ -6,6 +6,7 @@ CONFIG_NR_DRAM_BANKS=3 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls2088ardb_qspi_SECURE_BOOT_defconfig b/configs/ls2088ardb_qspi_SECURE_BOOT_defconfig index d4b5d87e66..768adadd1e 100644 --- a/configs/ls2088ardb_qspi_SECURE_BOOT_defconfig +++ b/configs/ls2088ardb_qspi_SECURE_BOOT_defconfig @@ -6,6 +6,7 @@ CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y CONFIG_NR_DRAM_BANKS=3 CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls2088ardb_qspi_defconfig b/configs/ls2088ardb_qspi_defconfig index a38ec3da3e..48230fd88c 100644 --- a/configs/ls2088ardb_qspi_defconfig +++ b/configs/ls2088ardb_qspi_defconfig @@ -5,6 +5,7 @@ CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y CONFIG_NR_DRAM_BANKS=3 CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig b/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig index 0f84055993..38837c0f72 100644 --- a/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig @@ -9,6 +9,7 @@ CONFIG_NR_DRAM_BANKS=3 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y diff --git a/configs/ls2088ardb_tfa_defconfig b/configs/ls2088ardb_tfa_defconfig index 014acc5e91..7095dec9b2 100644 --- a/configs/ls2088ardb_tfa_defconfig +++ b/configs/ls2088ardb_tfa_defconfig @@ -8,6 +8,7 @@ CONFIG_NR_DRAM_BANKS=3 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y diff --git a/configs/lschlv2_defconfig b/configs/lschlv2_defconfig index 03498480f1..9734e7f993 100644 --- a/configs/lschlv2_defconfig +++ b/configs/lschlv2_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_LSXL=y CONFIG_NR_DRAM_BANKS=2 CONFIG_IDENT_STRING=" LS-CHLv2" +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_EXTRA_OPTIONS="LSCHLV2" CONFIG_API=y diff --git a/configs/lsxhl_defconfig b/configs/lsxhl_defconfig index a0662815e2..0d25fb51f6 100644 --- a/configs/lsxhl_defconfig +++ b/configs/lsxhl_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_LSXL=y CONFIG_NR_DRAM_BANKS=2 CONFIG_IDENT_STRING=" LS-XHL" +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_EXTRA_OPTIONS="LSXHL" CONFIG_API=y diff --git a/configs/lx2160aqds_tfa_SECURE_BOOT_defconfig b/configs/lx2160aqds_tfa_SECURE_BOOT_defconfig index 3d4506bbff..0abc3c668a 100644 --- a/configs/lx2160aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/lx2160aqds_tfa_SECURE_BOOT_defconfig @@ -8,6 +8,7 @@ CONFIG_NR_DRAM_BANKS=3 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y diff --git a/configs/lx2160aqds_tfa_defconfig b/configs/lx2160aqds_tfa_defconfig index 4e85543649..dcea0723c6 100644 --- a/configs/lx2160aqds_tfa_defconfig +++ b/configs/lx2160aqds_tfa_defconfig @@ -7,6 +7,7 @@ CONFIG_NR_DRAM_BANKS=3 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y diff --git a/configs/lx2160ardb_tfa_SECURE_BOOT_defconfig b/configs/lx2160ardb_tfa_SECURE_BOOT_defconfig index ede4e0f75f..400ebd1f7f 100644 --- a/configs/lx2160ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/lx2160ardb_tfa_SECURE_BOOT_defconfig @@ -9,6 +9,7 @@ CONFIG_NR_DRAM_BANKS=3 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y diff --git a/configs/lx2160ardb_tfa_defconfig b/configs/lx2160ardb_tfa_defconfig index 7bcb7921d1..b7b89d6f66 100644 --- a/configs/lx2160ardb_tfa_defconfig +++ b/configs/lx2160ardb_tfa_defconfig @@ -8,6 +8,7 @@ CONFIG_NR_DRAM_BANKS=3 CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y diff --git a/configs/meesc_dataflash_defconfig b/configs/meesc_dataflash_defconfig index 5d0f2471c0..7c87dc2b8e 100644 --- a/configs/meesc_dataflash_defconfig +++ b/configs/meesc_dataflash_defconfig @@ -8,6 +8,7 @@ CONFIG_ENV_SIZE=0x4200 CONFIG_ENV_OFFSET=0x4200 CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SECT_SIZE=0x210 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263,SYS_USE_DATAFLASH" CONFIG_BOOTDELAY=3 diff --git a/configs/meesc_defconfig b/configs/meesc_defconfig index 5312974c3b..7bd667a6af 100644 --- a/configs/meesc_defconfig +++ b/configs/meesc_defconfig @@ -6,6 +6,7 @@ CONFIG_TARGET_MEESC=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_ENV_OFFSET=0xC0000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 diff --git a/configs/mgcoge3un_defconfig b/configs/mgcoge3un_defconfig index 15a6dd5b08..608c773a18 100644 --- a/configs/mgcoge3un_defconfig +++ b/configs/mgcoge3un_defconfig @@ -7,6 +7,7 @@ CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_PIGGY_MAC_ADRESS_OFFSET=3 CONFIG_KM_PIGGY4_88E6061=y CONFIG_IDENT_STRING="\nKeymile COGE3UN" +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="KM_MGCOGE3UN" CONFIG_MISC_INIT_R=y CONFIG_VERSION_VARIABLE=y diff --git a/configs/miqi-rk3288_defconfig b/configs/miqi-rk3288_defconfig index 1fee1be58a..9f4e5ea59f 100644 --- a/configs/miqi-rk3288_defconfig +++ b/configs/miqi-rk3288_defconfig @@ -9,13 +9,14 @@ CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEBUG_UART_BASE=0xff690000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART=y +CONFIG_SPL_TEXT_BASE=0xff704000 +CONFIG_SKIP_LOWLEVEL_INIT_ONLY=y # CONFIG_ANDROID_BOOT_IMAGE is not set CONFIG_USE_PREBOOT=y CONFIG_SILENT_CONSOLE=y CONFIG_DEFAULT_FDT_FILE="rk3288-miqi.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_SPL_TEXT_BASE=0xff704000 CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_CMD_GPIO=y diff --git a/configs/mx31pdk_defconfig b/configs/mx31pdk_defconfig index 7eb07e6413..7ee29e1617 100644 --- a/configs/mx31pdk_defconfig +++ b/configs/mx31pdk_defconfig @@ -8,8 +8,9 @@ CONFIG_TARGET_MX31PDK=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y -# CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_TEXT_BASE=0x87dc0000 +CONFIG_SKIP_LOWLEVEL_INIT=y +# CONFIG_SPL_FRAMEWORK is not set CONFIG_SPL_NAND_SUPPORT=y # CONFIG_AUTO_COMPLETE is not set CONFIG_CMD_BOOTZ=y diff --git a/configs/nanopc-t4-rk3399_defconfig b/configs/nanopc-t4-rk3399_defconfig index 1d4c8f8a02..f678e2dc5d 100644 --- a/configs/nanopc-t4-rk3399_defconfig +++ b/configs/nanopc-t4-rk3399_defconfig @@ -8,6 +8,7 @@ CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEBUG_UART_BASE=0xFF1A0000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-nanopc-t4.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y diff --git a/configs/nanopi-m4-rk3399_defconfig b/configs/nanopi-m4-rk3399_defconfig index 7375b758a2..2be10a4eaa 100644 --- a/configs/nanopi-m4-rk3399_defconfig +++ b/configs/nanopi-m4-rk3399_defconfig @@ -8,6 +8,7 @@ CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEBUG_UART_BASE=0xFF1A0000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-nanopi-m4.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y diff --git a/configs/nanopi-neo4-rk3399_defconfig b/configs/nanopi-neo4-rk3399_defconfig index 874ee5efb6..834918d242 100644 --- a/configs/nanopi-neo4-rk3399_defconfig +++ b/configs/nanopi-neo4-rk3399_defconfig @@ -8,6 +8,7 @@ CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEBUG_UART_BASE=0xFF1A0000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-nanopi-neo4.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y diff --git a/configs/nas220_defconfig b/configs/nas220_defconfig index 9b5d594c81..7100e0d287 100644 --- a/configs/nas220_defconfig +++ b/configs/nas220_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_NAS220=y CONFIG_NR_DRAM_BANKS=2 CONFIG_IDENT_STRING="\nNAS 220" +CONFIG_SKIP_LOWLEVEL_INIT=y # CONFIG_SYS_MALLOC_F is not set CONFIG_BOOTDELAY=3 CONFIG_USE_PREBOOT=y diff --git a/configs/net2big_v2_defconfig b/configs/net2big_v2_defconfig index 2a309f5441..55f1abe7b4 100644 --- a/configs/net2big_v2_defconfig +++ b/configs/net2big_v2_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_NET2BIG_V2=y CONFIG_NR_DRAM_BANKS=2 CONFIG_IDENT_STRING=" 2Big v2" +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="NET2BIG_V2" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/netgear_cg3100d_ram_defconfig b/configs/netgear_cg3100d_ram_defconfig index 8f507502d8..7e4ea87c70 100644 --- a/configs/netgear_cg3100d_ram_defconfig +++ b/configs/netgear_cg3100d_ram_defconfig @@ -5,6 +5,7 @@ CONFIG_ARCH_BMIPS=y # CONFIG_MIPS_BOOT_CMDLINE_LEGACY is not set # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y +CONFIG_SKIP_LOWLEVEL_INIT=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DISPLAY_CPUINFO=y @@ -42,7 +43,6 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_MTD=y CONFIG_DM_RESET=y CONFIG_RESET_BCM6345=y -# CONFIG_SPL_SERIAL_PRESENT is not set CONFIG_DM_SERIAL=y CONFIG_BCM6345_SERIAL=y CONFIG_SPI=y diff --git a/configs/netgear_dgnd3700v2_ram_defconfig b/configs/netgear_dgnd3700v2_ram_defconfig index 72572f15c2..59949f03d5 100644 --- a/configs/netgear_dgnd3700v2_ram_defconfig +++ b/configs/netgear_dgnd3700v2_ram_defconfig @@ -6,6 +6,7 @@ CONFIG_SOC_BMIPS_BCM6362=y # CONFIG_MIPS_BOOT_CMDLINE_LEGACY is not set # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y +CONFIG_SKIP_LOWLEVEL_INIT=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DISPLAY_CPUINFO=y @@ -49,7 +50,6 @@ CONFIG_POWER_DOMAIN=y CONFIG_BCM6328_POWER_DOMAIN=y CONFIG_DM_RESET=y CONFIG_RESET_BCM6345=y -# CONFIG_SPL_SERIAL_PRESENT is not set CONFIG_DM_SERIAL=y CONFIG_BCM6345_SERIAL=y CONFIG_USB=y diff --git a/configs/netspace_lite_v2_defconfig b/configs/netspace_lite_v2_defconfig index ee58114b94..0730d5fd9a 100644 --- a/configs/netspace_lite_v2_defconfig +++ b/configs/netspace_lite_v2_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_NETSPACE_V2=y CONFIG_NR_DRAM_BANKS=2 CONFIG_IDENT_STRING=" NS v2 Lite" +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="NETSPACE_LITE_V2" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/netspace_max_v2_defconfig b/configs/netspace_max_v2_defconfig index 2a95a55752..eca7bed589 100644 --- a/configs/netspace_max_v2_defconfig +++ b/configs/netspace_max_v2_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_NETSPACE_V2=y CONFIG_NR_DRAM_BANKS=2 CONFIG_IDENT_STRING=" NS Max v2" +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="NETSPACE_MAX_V2" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/netspace_mini_v2_defconfig b/configs/netspace_mini_v2_defconfig index 6933a9ba86..fcc30f8780 100644 --- a/configs/netspace_mini_v2_defconfig +++ b/configs/netspace_mini_v2_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_NETSPACE_V2=y CONFIG_NR_DRAM_BANKS=2 CONFIG_IDENT_STRING=" NS v2 Mini" +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="NETSPACE_MINI_V2" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/netspace_v2_defconfig b/configs/netspace_v2_defconfig index fc806e445e..b731cd3e44 100644 --- a/configs/netspace_v2_defconfig +++ b/configs/netspace_v2_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_NETSPACE_V2=y CONFIG_NR_DRAM_BANKS=2 CONFIG_IDENT_STRING=" NS v2" +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="NETSPACE_V2" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/nokia_rx51_defconfig b/configs/nokia_rx51_defconfig index ab5bb2de6f..c7303ff56c 100644 --- a/configs/nokia_rx51_defconfig +++ b/configs/nokia_rx51_defconfig @@ -4,6 +4,7 @@ CONFIG_ARCH_OMAP2PLUS=y CONFIG_SYS_TEXT_BASE=0x80008000 CONFIG_TARGET_NOKIA_RX51=y CONFIG_NR_DRAM_BANKS=2 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_BOOTDELAY=30 CONFIG_USE_PREBOOT=y CONFIG_PREBOOT="setenv mmcnum 1; setenv mmcpart 1;setenv mmcscriptfile bootmenu.scr;if run switchmmc; then setenv mmcdone true;setenv mmctype fat;if run scriptload; then true; else setenv mmctype ext2;if run scriptload; then true; else setenv mmctype ext4;if run scriptload; then true; else setenv mmcdone false;fi;fi;fi;if ${mmcdone}; then run scriptboot;fi;fi;if run slide; then true; else setenv bootmenu_delay 0;setenv bootdelay 0;fi" diff --git a/configs/nsa310s_defconfig b/configs/nsa310s_defconfig index 064ea0523d..a16113b1c3 100644 --- a/configs/nsa310s_defconfig +++ b/configs/nsa310s_defconfig @@ -5,6 +5,7 @@ CONFIG_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_NSA310S=y CONFIG_NR_DRAM_BANKS=2 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_BOOTDELAY=3 CONFIG_USE_PREBOOT=y # CONFIG_DISPLAY_BOARDINFO is not set diff --git a/configs/odroid-xu3_defconfig b/configs/odroid-xu3_defconfig index 8493312837..2c2b0508d4 100644 --- a/configs/odroid-xu3_defconfig +++ b/configs/odroid-xu3_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_TEXT_BASE=0x43E00000 CONFIG_ARCH_EXYNOS5=y CONFIG_NR_DRAM_BANKS=8 CONFIG_IDENT_STRING=" for ODROID-XU3/XU4/HC1/HC2" +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_FIT=y diff --git a/configs/odroid_defconfig b/configs/odroid_defconfig index 95d77b7ebc..d51149c84b 100644 --- a/configs/odroid_defconfig +++ b/configs/odroid_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_TEXT_BASE=0x43e00000 CONFIG_ARCH_EXYNOS4=y CONFIG_TARGET_ODROID=y CONFIG_NR_DRAM_BANKS=8 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_FIT=y diff --git a/configs/omapl138_lcdk_defconfig b/configs/omapl138_lcdk_defconfig index d2342c37cf..326ac9372b 100644 --- a/configs/omapl138_lcdk_defconfig +++ b/configs/omapl138_lcdk_defconfig @@ -11,13 +11,14 @@ CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y +CONFIG_SPL_TEXT_BASE=0x80000000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_BOOTDELAY=3 CONFIG_LOGLEVEL=3 CONFIG_MISC_INIT_R=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_SPL_TEXT_BASE=0x80000000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xb5 CONFIG_SPL_NAND_SUPPORT=y diff --git a/configs/openrd_base_defconfig b/configs/openrd_base_defconfig index 43dc6c5c1a..03d84fb1e1 100644 --- a/configs/openrd_base_defconfig +++ b/configs/openrd_base_defconfig @@ -7,6 +7,7 @@ CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_OPENRD=y CONFIG_NR_DRAM_BANKS=2 CONFIG_IDENT_STRING="\nOpenRD-Base" +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="BOARD_IS_OPENRD_BASE" CONFIG_BOOTDELAY=3 CONFIG_USE_PREBOOT=y diff --git a/configs/openrd_client_defconfig b/configs/openrd_client_defconfig index 71c4475466..9b1258968c 100644 --- a/configs/openrd_client_defconfig +++ b/configs/openrd_client_defconfig @@ -7,6 +7,7 @@ CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_OPENRD=y CONFIG_NR_DRAM_BANKS=2 CONFIG_IDENT_STRING="\nOpenRD-Client" +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="BOARD_IS_OPENRD_CLIENT" CONFIG_BOOTDELAY=3 CONFIG_USE_PREBOOT=y diff --git a/configs/openrd_ultimate_defconfig b/configs/openrd_ultimate_defconfig index bdfa4ac862..f078582d49 100644 --- a/configs/openrd_ultimate_defconfig +++ b/configs/openrd_ultimate_defconfig @@ -7,6 +7,7 @@ CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_OPENRD=y CONFIG_NR_DRAM_BANKS=2 CONFIG_IDENT_STRING="\nOpenRD-Ultimate" +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="BOARD_IS_OPENRD_ULTIMATE" CONFIG_BOOTDELAY=3 CONFIG_USE_PREBOOT=y diff --git a/configs/orangepi-rk3399_defconfig b/configs/orangepi-rk3399_defconfig index 7b02c59f08..d17f049349 100644 --- a/configs/orangepi-rk3399_defconfig +++ b/configs/orangepi-rk3399_defconfig @@ -8,6 +8,7 @@ CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEBUG_UART_BASE=0xFF1A0000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-orangepi.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y diff --git a/configs/origen_defconfig b/configs/origen_defconfig index d9e9931e91..a8c8c55433 100644 --- a/configs/origen_defconfig +++ b/configs/origen_defconfig @@ -7,12 +7,13 @@ CONFIG_ARCH_EXYNOS4=y CONFIG_TARGET_ORIGEN=y CONFIG_SPL=y CONFIG_IDENT_STRING=" for ORIGEN" +CONFIG_SPL_TEXT_BASE=0x02021410 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_SPL_FRAMEWORK is not set -CONFIG_SPL_TEXT_BASE=0x02021410 CONFIG_SYS_PROMPT="ORIGEN # " # CONFIG_CMD_XIMG is not set CONFIG_CMD_THOR_DOWNLOAD=y diff --git a/configs/pcm051_rev1_defconfig b/configs/pcm051_rev1_defconfig index 17433768f7..2a1a23aaeb 100644 --- a/configs/pcm051_rev1_defconfig +++ b/configs/pcm051_rev1_defconfig @@ -11,6 +11,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_EXTRA_OPTIONS="REV1" # CONFIG_USE_BOOTCOMMAND is not set diff --git a/configs/pcm051_rev3_defconfig b/configs/pcm051_rev3_defconfig index d85e3fc8de..70ed24ab8a 100644 --- a/configs/pcm051_rev3_defconfig +++ b/configs/pcm051_rev3_defconfig @@ -11,6 +11,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_EXTRA_OPTIONS="REV3" # CONFIG_USE_BOOTCOMMAND is not set diff --git a/configs/pcm052_defconfig b/configs/pcm052_defconfig index b7e3d04641..e0fcebf957 100644 --- a/configs/pcm052_defconfig +++ b/configs/pcm052_defconfig @@ -4,6 +4,7 @@ CONFIG_ARCH_VF610=y CONFIG_SYS_TEXT_BASE=0x3f401000 CONFIG_NR_DRAM_BANKS=1 CONFIG_TARGET_PCM052=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/phytec/pcm052/imximage.cfg" CONFIG_BOOTDELAY=3 CONFIG_BOARD_EARLY_INIT_F=y diff --git a/configs/peach-pi_defconfig b/configs/peach-pi_defconfig index a4848d5c7b..0e78649e90 100644 --- a/configs/peach-pi_defconfig +++ b/configs/peach-pi_defconfig @@ -7,12 +7,13 @@ CONFIG_TARGET_PEACH_PI=y CONFIG_NR_DRAM_BANKS=7 CONFIG_SPL=y CONFIG_IDENT_STRING=" for Peach-Pi" +CONFIG_SPL_TEXT_BASE=0x02024410 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y CONFIG_SILENT_CONSOLE=y # CONFIG_SPL_FRAMEWORK is not set -CONFIG_SPL_TEXT_BASE=0x02024410 CONFIG_SYS_PROMPT="Peach-Pi # " CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y diff --git a/configs/peach-pit_defconfig b/configs/peach-pit_defconfig index e3bca5f61a..88e4a5c79d 100644 --- a/configs/peach-pit_defconfig +++ b/configs/peach-pit_defconfig @@ -6,12 +6,13 @@ CONFIG_ARCH_EXYNOS5=y CONFIG_TARGET_PEACH_PIT=y CONFIG_SPL=y CONFIG_IDENT_STRING=" for Peach-Pit" +CONFIG_SPL_TEXT_BASE=0x02024410 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y CONFIG_SILENT_CONSOLE=y # CONFIG_SPL_FRAMEWORK is not set -CONFIG_SPL_TEXT_BASE=0x02024410 CONFIG_SYS_PROMPT="Peach-Pit # " CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y diff --git a/configs/pengwyn_defconfig b/configs/pengwyn_defconfig index bd7d0a6d8b..ed316a5ac1 100644 --- a/configs/pengwyn_defconfig +++ b/configs/pengwyn_defconfig @@ -12,6 +12,7 @@ CONFIG_ENV_SIZE=0x4000 CONFIG_SPL=y CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y diff --git a/configs/pepper_defconfig b/configs/pepper_defconfig index 85349f4044..1bb492ca06 100644 --- a/configs/pepper_defconfig +++ b/configs/pepper_defconfig @@ -11,6 +11,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y diff --git a/configs/phycore-am335x-r2-wega_defconfig b/configs/phycore-am335x-r2-wega_defconfig index 43acb55c41..0a0b756106 100644 --- a/configs/phycore-am335x-r2-wega_defconfig +++ b/configs/phycore-am335x-r2-wega_defconfig @@ -13,6 +13,7 @@ CONFIG_ENV_OFFSET=0x000a0000 CONFIG_SPL=y CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y +CONFIG_SKIP_LOWLEVEL_INIT=y # CONFIG_FIT is not set CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_CONSOLE_INFO_QUIET=y diff --git a/configs/phycore-rk3288_defconfig b/configs/phycore-rk3288_defconfig index 7cfbd50c1e..11876a0df4 100644 --- a/configs/phycore-rk3288_defconfig +++ b/configs/phycore-rk3288_defconfig @@ -9,6 +9,8 @@ CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEBUG_UART_BASE=0xff690000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART=y +CONFIG_SPL_TEXT_BASE=0xff704000 +CONFIG_SKIP_LOWLEVEL_INIT_ONLY=y # CONFIG_ANDROID_BOOT_IMAGE is not set CONFIG_USE_PREBOOT=y CONFIG_SILENT_CONSOLE=y @@ -16,7 +18,6 @@ CONFIG_CONSOLE_MUX=y CONFIG_DEFAULT_FDT_FILE="rk3288-phycore-rdk.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_SPL_TEXT_BASE=0xff704000 CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/picosam9g45_defconfig b/configs/picosam9g45_defconfig index abae023915..314bac0db6 100644 --- a/configs/picosam9g45_defconfig +++ b/configs/picosam9g45_defconfig @@ -13,6 +13,8 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y +CONFIG_SPL_TEXT_BASE=0x300000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9M10G45,SYS_USE_MMC" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y @@ -21,7 +23,6 @@ CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/mmcblk0p2 rw rootwait" CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_SPL_TEXT_BASE=0x300000 CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/pm9g45_defconfig b/configs/pm9g45_defconfig index b5304b963c..9b19faed6d 100644 --- a/configs/pm9g45_defconfig +++ b/configs/pm9g45_defconfig @@ -8,6 +8,7 @@ CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0xffffee00 CONFIG_DEBUG_UART_CLOCK=132000000 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_NAND_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/pogo_e02_defconfig b/configs/pogo_e02_defconfig index 08c52ffdf1..f34a4ac200 100644 --- a/configs/pogo_e02_defconfig +++ b/configs/pogo_e02_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_POGO_E02=y CONFIG_NR_DRAM_BANKS=2 CONFIG_IDENT_STRING="\nPogo E02" +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_BOOTDELAY=3 CONFIG_USE_PREBOOT=y # CONFIG_DISPLAY_BOARDINFO is not set diff --git a/configs/popmetal-rk3288_defconfig b/configs/popmetal-rk3288_defconfig index efa20d0800..69d745b5f7 100644 --- a/configs/popmetal-rk3288_defconfig +++ b/configs/popmetal-rk3288_defconfig @@ -9,6 +9,8 @@ CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEBUG_UART_BASE=0xff690000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART=y +CONFIG_SPL_TEXT_BASE=0xff704000 +CONFIG_SKIP_LOWLEVEL_INIT_ONLY=y # CONFIG_ANDROID_BOOT_IMAGE is not set CONFIG_USE_PREBOOT=y CONFIG_SILENT_CONSOLE=y @@ -16,7 +18,6 @@ CONFIG_CONSOLE_MUX=y CONFIG_DEFAULT_FDT_FILE="rk3288-popmetal.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_SPL_TEXT_BASE=0xff704000 CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_CMD_GPIO=y diff --git a/configs/puma-rk3399_defconfig b/configs/puma-rk3399_defconfig index faf95c5505..a6b6870b0b 100644 --- a/configs/puma-rk3399_defconfig +++ b/configs/puma-rk3399_defconfig @@ -12,12 +12,13 @@ CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_DEBUG_UART=y +CONFIG_SPL_TEXT_BASE=0xff8c2000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SPL_FIT_GENERATOR="board/theobroma-systems/puma_rk3399/fit_spl_atf.sh" CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-puma-haikou.dtb" CONFIG_MISC_INIT_R=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_SPL_TEXT_BASE=0xff8c2000 # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x4000 diff --git a/configs/pxm2_defconfig b/configs/pxm2_defconfig index 201b9c9357..764b55cb67 100644 --- a/configs/pxm2_defconfig +++ b/configs/pxm2_defconfig @@ -17,6 +17,7 @@ CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_BOOTDELAY=3 CONFIG_USE_PREBOOT=y diff --git a/configs/rastaban_defconfig b/configs/rastaban_defconfig index 452e761412..04a87b3d79 100644 --- a/configs/rastaban_defconfig +++ b/configs/rastaban_defconfig @@ -17,6 +17,7 @@ CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_BOOTDELAY=3 CONFIG_USE_PREBOOT=y diff --git a/configs/roc-rk3399-pc_defconfig b/configs/roc-rk3399-pc_defconfig index 28b18333d7..3f1e623f78 100644 --- a/configs/roc-rk3399-pc_defconfig +++ b/configs/roc-rk3399-pc_defconfig @@ -8,6 +8,7 @@ CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEBUG_UART_BASE=0xFF1A0000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-roc-pc.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y diff --git a/configs/rock-pi-4-rk3399_defconfig b/configs/rock-pi-4-rk3399_defconfig index 554945dd19..05208d25a5 100644 --- a/configs/rock-pi-4-rk3399_defconfig +++ b/configs/rock-pi-4-rk3399_defconfig @@ -8,6 +8,7 @@ CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEBUG_UART_BASE=0xFF1A0000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-rock-pi-4.dtb" CONFIG_MISC_INIT_R=y # CONFIG_DISPLAY_CPUINFO is not set diff --git a/configs/rock2_defconfig b/configs/rock2_defconfig index 9d5f3b59e8..a12f23ffaf 100644 --- a/configs/rock2_defconfig +++ b/configs/rock2_defconfig @@ -9,13 +9,14 @@ CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEBUG_UART_BASE=0xff690000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART=y +CONFIG_SPL_TEXT_BASE=0xff704000 +CONFIG_SKIP_LOWLEVEL_INIT_ONLY=y # CONFIG_ANDROID_BOOT_IMAGE is not set CONFIG_USE_PREBOOT=y CONFIG_SILENT_CONSOLE=y CONFIG_DEFAULT_FDT_FILE="rk3288-rock2-square.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_SPL_TEXT_BASE=0xff704000 CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_CMD_GPIO=y diff --git a/configs/rock64-rk3328_defconfig b/configs/rock64-rk3328_defconfig index 3ab0af1158..0653e0dfc1 100644 --- a/configs/rock64-rk3328_defconfig +++ b/configs/rock64-rk3328_defconfig @@ -13,6 +13,7 @@ CONFIG_DEBUG_UART_BASE=0xFF130000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_SMBIOS_PRODUCT_NAME="rock64_rk3328" CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_TPL_SYS_MALLOC_F_LEN=0x800 # CONFIG_ANDROID_BOOT_IMAGE is not set CONFIG_FIT=y diff --git a/configs/rock960-rk3399_defconfig b/configs/rock960-rk3399_defconfig index abcc53fc8e..a6bcbbe480 100644 --- a/configs/rock960-rk3399_defconfig +++ b/configs/rock960-rk3399_defconfig @@ -8,10 +8,11 @@ CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEBUG_UART_BASE=0xFF1A0000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART=y +CONFIG_SPL_TEXT_BASE=0xff8c2000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-rock960.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_SPL_TEXT_BASE=0xff8c2000 # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x4000 diff --git a/configs/rock_defconfig b/configs/rock_defconfig index d5a57d6544..a64d336851 100644 --- a/configs/rock_defconfig +++ b/configs/rock_defconfig @@ -11,11 +11,12 @@ CONFIG_SPL_STACK_R_ADDR=0x60080000 CONFIG_DEBUG_UART_BASE=0x20064000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART=y +CONFIG_SPL_TEXT_BASE=0x10080800 +CONFIG_SKIP_LOWLEVEL_INIT_ONLY=y CONFIG_USE_PREBOOT=y CONFIG_DEFAULT_FDT_FILE="rk3188-radxarock.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_SPL_TEXT_BASE=0x10080800 CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_RANDOM_UUID=y diff --git a/configs/rockpro64-rk3399_defconfig b/configs/rockpro64-rk3399_defconfig index 40ebad5abb..cd75252b87 100644 --- a/configs/rockpro64-rk3399_defconfig +++ b/configs/rockpro64-rk3399_defconfig @@ -8,6 +8,7 @@ CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEBUG_UART_BASE=0xFF1A0000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-rockpro64.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y diff --git a/configs/rpi_2_defconfig b/configs/rpi_2_defconfig index bf331c0ad0..2196bda6f8 100644 --- a/configs/rpi_2_defconfig +++ b/configs/rpi_2_defconfig @@ -4,6 +4,7 @@ CONFIG_ARCH_BCM283X=y CONFIG_SYS_TEXT_BASE=0x00008000 CONFIG_TARGET_RPI_2=y CONFIG_NR_DRAM_BANKS=1 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_OF_BOARD_SETUP=y CONFIG_USE_PREBOOT=y diff --git a/configs/rpi_3_32b_defconfig b/configs/rpi_3_32b_defconfig index c2417a0ec9..dfe9eb29d5 100644 --- a/configs/rpi_3_32b_defconfig +++ b/configs/rpi_3_32b_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_TEXT_BASE=0x00008000 CONFIG_TARGET_RPI_3_32B=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_OF_BOARD_SETUP=y CONFIG_USE_PREBOOT=y diff --git a/configs/rut_defconfig b/configs/rut_defconfig index ec31d52377..1fffea8619 100644 --- a/configs/rut_defconfig +++ b/configs/rut_defconfig @@ -17,6 +17,7 @@ CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_BOOTDELAY=3 CONFIG_USE_PREBOOT=y diff --git a/configs/s32v234evb_defconfig b/configs/s32v234evb_defconfig index 7ccb9f132c..f0171215d4 100644 --- a/configs/s32v234evb_defconfig +++ b/configs/s32v234evb_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_S32V234EVB=y CONFIG_SYS_TEXT_BASE=0x3E800000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/s32v234evb/s32v234evb.cfg" CONFIG_USE_BOOTARGS=y diff --git a/configs/s5pc210_universal_defconfig b/configs/s5pc210_universal_defconfig index ad52e3a2cb..00e2767bbc 100644 --- a/configs/s5pc210_universal_defconfig +++ b/configs/s5pc210_universal_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_TEXT_BASE=0x44800000 CONFIG_ARCH_EXYNOS4=y CONFIG_TARGET_S5PC210_UNIVERSAL=y CONFIG_NR_DRAM_BANKS=2 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="Please use defined boot" diff --git a/configs/sagem_f@st1704_ram_defconfig b/configs/sagem_f@st1704_ram_defconfig index eb6efa245c..daf8e22755 100644 --- a/configs/sagem_f@st1704_ram_defconfig +++ b/configs/sagem_f@st1704_ram_defconfig @@ -6,6 +6,7 @@ CONFIG_SOC_BMIPS_BCM6338=y # CONFIG_MIPS_BOOT_CMDLINE_LEGACY is not set # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y +CONFIG_SKIP_LOWLEVEL_INIT=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DISPLAY_CPUINFO=y @@ -47,7 +48,6 @@ CONFIG_DM_ETH=y CONFIG_BCM6348_ETH=y CONFIG_DM_RESET=y CONFIG_RESET_BCM6345=y -# CONFIG_SPL_SERIAL_PRESENT is not set CONFIG_DM_SERIAL=y CONFIG_BCM6345_SERIAL=y CONFIG_SPI=y diff --git a/configs/sama5d27_som1_ek_mmc1_defconfig b/configs/sama5d27_som1_ek_mmc1_defconfig index 29d364ce17..ce0ec139c2 100644 --- a/configs/sama5d27_som1_ek_mmc1_defconfig +++ b/configs/sama5d27_som1_ek_mmc1_defconfig @@ -18,6 +18,8 @@ CONFIG_DEBUG_UART_CLOCK=82000000 CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_DEBUG_UART=y +CONFIG_SPL_TEXT_BASE=0x200000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D2" @@ -27,7 +29,6 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk root=/dev/mmcblk1p2 rw rootwait" CONFIG_MISC_INIT_R=y # CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_SPL_TEXT_BASE=0x200000 CONFIG_SPL_SEPARATE_BSS=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/sama5d27_som1_ek_mmc_defconfig b/configs/sama5d27_som1_ek_mmc_defconfig index bb74c63993..5073c45497 100644 --- a/configs/sama5d27_som1_ek_mmc_defconfig +++ b/configs/sama5d27_som1_ek_mmc_defconfig @@ -19,6 +19,8 @@ CONFIG_DEBUG_UART_CLOCK=82000000 CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_DEBUG_UART=y +CONFIG_SPL_TEXT_BASE=0x200000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D2" @@ -28,7 +30,6 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p2 rw rootwait" CONFIG_MISC_INIT_R=y # CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_SPL_TEXT_BASE=0x200000 CONFIG_SPL_SEPARATE_BSS=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/sama5d27_som1_ek_qspiflash_defconfig b/configs/sama5d27_som1_ek_qspiflash_defconfig index 50b7983850..b9d613bd85 100644 --- a/configs/sama5d27_som1_ek_qspiflash_defconfig +++ b/configs/sama5d27_som1_ek_qspiflash_defconfig @@ -19,6 +19,8 @@ CONFIG_ENV_SECT_SIZE=0x1000 CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_DEBUG_UART=y +CONFIG_SPL_TEXT_BASE=0x200000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D2" @@ -28,7 +30,6 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p2 rw rootwait" CONFIG_MISC_INIT_R=y # CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_SPL_TEXT_BASE=0x200000 CONFIG_SPL_SEPARATE_BSS=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/sama5d2_icp_mmc_defconfig b/configs/sama5d2_icp_mmc_defconfig index 535aab5a12..3ef1110cbd 100644 --- a/configs/sama5d2_icp_mmc_defconfig +++ b/configs/sama5d2_icp_mmc_defconfig @@ -18,6 +18,7 @@ CONFIG_DEBUG_UART_CLOCK=83000000 CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D2" diff --git a/configs/sama5d2_ptc_ek_mmc_defconfig b/configs/sama5d2_ptc_ek_mmc_defconfig index 17699dec52..64c42a2567 100644 --- a/configs/sama5d2_ptc_ek_mmc_defconfig +++ b/configs/sama5d2_ptc_ek_mmc_defconfig @@ -10,6 +10,7 @@ CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0xf801c000 CONFIG_DEBUG_UART_CLOCK=82000000 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D2" @@ -36,7 +37,6 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91-sama5d2_ptc_ek" CONFIG_ENV_IS_IN_FAT=y CONFIG_DM=y -CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_CLK=y CONFIG_CLK_AT91=y CONFIG_AT91_UTMI=y diff --git a/configs/sama5d2_ptc_ek_nandflash_defconfig b/configs/sama5d2_ptc_ek_nandflash_defconfig index 0b18bd41fc..43dc329294 100644 --- a/configs/sama5d2_ptc_ek_nandflash_defconfig +++ b/configs/sama5d2_ptc_ek_nandflash_defconfig @@ -9,6 +9,7 @@ CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0xf801c000 CONFIG_DEBUG_UART_CLOCK=82000000 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D2" @@ -35,7 +36,6 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91-sama5d2_ptc_ek" CONFIG_ENV_IS_IN_NAND=y CONFIG_DM=y -CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_CLK=y CONFIG_CLK_AT91=y CONFIG_AT91_UTMI=y diff --git a/configs/sama5d2_xplained_emmc_defconfig b/configs/sama5d2_xplained_emmc_defconfig index 92d7c5e9cf..1a54fbf71a 100644 --- a/configs/sama5d2_xplained_emmc_defconfig +++ b/configs/sama5d2_xplained_emmc_defconfig @@ -18,6 +18,8 @@ CONFIG_DEBUG_UART_CLOCK=83000000 CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_DEBUG_UART=y +CONFIG_SPL_TEXT_BASE=0x200000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D2,SYS_USE_MMC" @@ -26,7 +28,6 @@ CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p2 rw rootwait" # CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_SPL_TEXT_BASE=0x200000 CONFIG_SPL_SEPARATE_BSS=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/sama5d2_xplained_mmc_defconfig b/configs/sama5d2_xplained_mmc_defconfig index 43990336fa..5630880a19 100644 --- a/configs/sama5d2_xplained_mmc_defconfig +++ b/configs/sama5d2_xplained_mmc_defconfig @@ -19,6 +19,8 @@ CONFIG_DEBUG_UART_CLOCK=83000000 CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_DEBUG_UART=y +CONFIG_SPL_TEXT_BASE=0x200000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D2,SYS_USE_MMC" @@ -28,7 +30,6 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk root=/dev/mmcblk1p2 rw rootwait" CONFIG_MISC_INIT_R=y # CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_SPL_TEXT_BASE=0x200000 CONFIG_SPL_SEPARATE_BSS=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/sama5d2_xplained_qspiflash_defconfig b/configs/sama5d2_xplained_qspiflash_defconfig index f24dac6c4f..6736c8fae7 100644 --- a/configs/sama5d2_xplained_qspiflash_defconfig +++ b/configs/sama5d2_xplained_qspiflash_defconfig @@ -19,6 +19,8 @@ CONFIG_ENV_SECT_SIZE=0x1000 CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_DEBUG_UART=y +CONFIG_SPL_TEXT_BASE=0x200000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D2,SYS_USE_MMC" @@ -28,7 +30,6 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p1 rw rootwait" CONFIG_MISC_INIT_R=y # CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_SPL_TEXT_BASE=0x200000 CONFIG_SPL_SEPARATE_BSS=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/sama5d2_xplained_spiflash_defconfig b/configs/sama5d2_xplained_spiflash_defconfig index 6958621cdf..bdbf598d6d 100644 --- a/configs/sama5d2_xplained_spiflash_defconfig +++ b/configs/sama5d2_xplained_spiflash_defconfig @@ -20,6 +20,8 @@ CONFIG_ENV_SECT_SIZE=0x1000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_DEBUG_UART=y +CONFIG_SPL_TEXT_BASE=0x200000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_FIT=y CONFIG_SPI_BOOT=y @@ -28,7 +30,6 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p1 rw rootwait" CONFIG_MISC_INIT_R=y # CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_SPL_TEXT_BASE=0x200000 CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x10000 CONFIG_HUSH_PARSER=y diff --git a/configs/sama5d36ek_cmp_mmc_defconfig b/configs/sama5d36ek_cmp_mmc_defconfig index 2f0415d97f..7890bd9ebf 100644 --- a/configs/sama5d36ek_cmp_mmc_defconfig +++ b/configs/sama5d36ek_cmp_mmc_defconfig @@ -10,6 +10,7 @@ CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0xffffee00 CONFIG_DEBUG_UART_CLOCK=132000000 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_FIT=y CONFIG_SD_BOOT=y diff --git a/configs/sama5d36ek_cmp_nandflash_defconfig b/configs/sama5d36ek_cmp_nandflash_defconfig index 3bcfbf071e..b2f885447b 100644 --- a/configs/sama5d36ek_cmp_nandflash_defconfig +++ b/configs/sama5d36ek_cmp_nandflash_defconfig @@ -9,6 +9,7 @@ CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0xffffee00 CONFIG_DEBUG_UART_CLOCK=132000000 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_FIT=y CONFIG_NAND_BOOT=y diff --git a/configs/sama5d36ek_cmp_spiflash_defconfig b/configs/sama5d36ek_cmp_spiflash_defconfig index 3fbdd54c04..192c6bec79 100644 --- a/configs/sama5d36ek_cmp_spiflash_defconfig +++ b/configs/sama5d36ek_cmp_spiflash_defconfig @@ -12,6 +12,7 @@ CONFIG_DEBUG_UART_BASE=0xffffee00 CONFIG_DEBUG_UART_CLOCK=132000000 CONFIG_ENV_SECT_SIZE=0x1000 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_FIT=y CONFIG_SPI_BOOT=y diff --git a/configs/sama5d3_xplained_mmc_defconfig b/configs/sama5d3_xplained_mmc_defconfig index ebd3a402ac..dd20087b26 100644 --- a/configs/sama5d3_xplained_mmc_defconfig +++ b/configs/sama5d3_xplained_mmc_defconfig @@ -19,6 +19,8 @@ CONFIG_DEBUG_UART_CLOCK=132000000 CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_DEBUG_UART=y +CONFIG_SPL_TEXT_BASE=0x300000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_FIT=y CONFIG_SD_BOOT=y @@ -26,7 +28,6 @@ CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p2 rw rootwait" # CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_SPL_TEXT_BASE=0x300000 CONFIG_SPL_SEPARATE_BSS=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/sama5d3_xplained_nandflash_defconfig b/configs/sama5d3_xplained_nandflash_defconfig index 2ebba96c23..9e678ce368 100644 --- a/configs/sama5d3_xplained_nandflash_defconfig +++ b/configs/sama5d3_xplained_nandflash_defconfig @@ -15,6 +15,8 @@ CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0xffffee00 CONFIG_DEBUG_UART_CLOCK=132000000 CONFIG_DEBUG_UART=y +CONFIG_SPL_TEXT_BASE=0x300000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_FIT=y CONFIG_NAND_BOOT=y @@ -22,7 +24,6 @@ CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk mtdparts=atmel_nand:256k(bootstrap)ro,768k(uboot)ro,256K(env_redundant),256k(env),512k(dtb),6M(kernel)ro,-(rootfs) rootfstype=ubifs ubi.mtd=6 root=ubi0:rootfs" # CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_SPL_TEXT_BASE=0x300000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/sama5d3xek_mmc_defconfig b/configs/sama5d3xek_mmc_defconfig index 86b375f7cc..4ba8c3033c 100644 --- a/configs/sama5d3xek_mmc_defconfig +++ b/configs/sama5d3xek_mmc_defconfig @@ -19,6 +19,8 @@ CONFIG_DEBUG_UART_CLOCK=132000000 CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_DEBUG_UART=y +CONFIG_SPL_TEXT_BASE=0x300000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_FIT=y CONFIG_SD_BOOT=y @@ -28,7 +30,6 @@ CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p2 rw rootwai # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_SPL_TEXT_BASE=0x300000 CONFIG_SPL_SEPARATE_BSS=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/sama5d3xek_nandflash_defconfig b/configs/sama5d3xek_nandflash_defconfig index 120461add3..ccf931921d 100644 --- a/configs/sama5d3xek_nandflash_defconfig +++ b/configs/sama5d3xek_nandflash_defconfig @@ -15,6 +15,8 @@ CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0xffffee00 CONFIG_DEBUG_UART_CLOCK=132000000 CONFIG_DEBUG_UART=y +CONFIG_SPL_TEXT_BASE=0x300000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_FIT=y CONFIG_NAND_BOOT=y @@ -24,7 +26,6 @@ CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk mtdparts=atmel_nand:256k(boots # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_SPL_TEXT_BASE=0x300000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/sama5d3xek_spiflash_defconfig b/configs/sama5d3xek_spiflash_defconfig index b27a288b4a..8ff2fae7b8 100644 --- a/configs/sama5d3xek_spiflash_defconfig +++ b/configs/sama5d3xek_spiflash_defconfig @@ -20,6 +20,8 @@ CONFIG_ENV_SECT_SIZE=0x1000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_DEBUG_UART=y +CONFIG_SPL_TEXT_BASE=0x300000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_FIT=y CONFIG_SPI_BOOT=y @@ -27,7 +29,6 @@ CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk mtdparts=atmel_nand:256k(bootstrap)ro,768k(uboot)ro,256K(env_redundant),256k(env),512k(dtb),6M(kernel)ro,-(rootfs) rootfstype=ubifs ubi.mtd=6 root=ubi0:rootfs" # CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_SPL_TEXT_BASE=0x300000 CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x10000 CONFIG_HUSH_PARSER=y diff --git a/configs/sama5d4_xplained_mmc_defconfig b/configs/sama5d4_xplained_mmc_defconfig index f9d7389613..bf9f113632 100644 --- a/configs/sama5d4_xplained_mmc_defconfig +++ b/configs/sama5d4_xplained_mmc_defconfig @@ -19,6 +19,8 @@ CONFIG_DEBUG_UART_CLOCK=100000000 CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_DEBUG_UART=y +CONFIG_SPL_TEXT_BASE=0x200000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_FIT=y CONFIG_SD_BOOT=y @@ -27,7 +29,6 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p2 rw rootwait" CONFIG_MISC_INIT_R=y # CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_SPL_TEXT_BASE=0x200000 CONFIG_SPL_SEPARATE_BSS=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/sama5d4_xplained_nandflash_defconfig b/configs/sama5d4_xplained_nandflash_defconfig index d25cd615d6..f9883fa147 100644 --- a/configs/sama5d4_xplained_nandflash_defconfig +++ b/configs/sama5d4_xplained_nandflash_defconfig @@ -15,6 +15,8 @@ CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0xfc00c000 CONFIG_DEBUG_UART_CLOCK=100000000 CONFIG_DEBUG_UART=y +CONFIG_SPL_TEXT_BASE=0x200000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_FIT=y CONFIG_NAND_BOOT=y @@ -23,7 +25,6 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk mtdparts=atmel_nand:256k(bootstrap)ro,768k(uboot)ro,256K(env_redundant),256k(env),512k(dtb),6M(kernel)ro,-(rootfs) rootfstype=ubifs ubi.mtd=6 root=ubi0:rootfs" CONFIG_MISC_INIT_R=y # CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_SPL_TEXT_BASE=0x200000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/sama5d4_xplained_spiflash_defconfig b/configs/sama5d4_xplained_spiflash_defconfig index a2e9595088..7aefdfa441 100644 --- a/configs/sama5d4_xplained_spiflash_defconfig +++ b/configs/sama5d4_xplained_spiflash_defconfig @@ -20,6 +20,8 @@ CONFIG_ENV_SECT_SIZE=0x1000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_DEBUG_UART=y +CONFIG_SPL_TEXT_BASE=0x200000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_FIT=y CONFIG_SPI_BOOT=y @@ -28,7 +30,6 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk mtdparts=atmel_nand:256k(bootstrap)ro,768k(uboot)ro,256K(env_redundant),256k(env),512k(dtb),6M(kernel)ro,-(rootfs) rootfstype=ubifs ubi.mtd=6 root=ubi0:rootfs" CONFIG_MISC_INIT_R=y # CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_SPL_TEXT_BASE=0x200000 CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x10000 CONFIG_HUSH_PARSER=y diff --git a/configs/sama5d4ek_mmc_defconfig b/configs/sama5d4ek_mmc_defconfig index 711de5572a..e425e82e82 100644 --- a/configs/sama5d4ek_mmc_defconfig +++ b/configs/sama5d4ek_mmc_defconfig @@ -19,6 +19,8 @@ CONFIG_DEBUG_UART_CLOCK=88000000 CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_DEBUG_UART=y +CONFIG_SPL_TEXT_BASE=0x200000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_FIT=y CONFIG_SD_BOOT=y @@ -28,7 +30,6 @@ CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p2 rw rootwai # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_SPL_TEXT_BASE=0x200000 CONFIG_SPL_SEPARATE_BSS=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/sama5d4ek_nandflash_defconfig b/configs/sama5d4ek_nandflash_defconfig index 7b1f44c451..5811574fe7 100644 --- a/configs/sama5d4ek_nandflash_defconfig +++ b/configs/sama5d4ek_nandflash_defconfig @@ -15,6 +15,8 @@ CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0xfc00c000 CONFIG_DEBUG_UART_CLOCK=88000000 CONFIG_DEBUG_UART=y +CONFIG_SPL_TEXT_BASE=0x200000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_FIT=y CONFIG_NAND_BOOT=y @@ -24,7 +26,6 @@ CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk mtdparts=atmel_nand:256k(boots # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_SPL_TEXT_BASE=0x200000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/sama5d4ek_spiflash_defconfig b/configs/sama5d4ek_spiflash_defconfig index aa1a492997..7840f9c524 100644 --- a/configs/sama5d4ek_spiflash_defconfig +++ b/configs/sama5d4ek_spiflash_defconfig @@ -20,6 +20,8 @@ CONFIG_ENV_SECT_SIZE=0x1000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_DEBUG_UART=y +CONFIG_SPL_TEXT_BASE=0x200000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_FIT=y CONFIG_SPI_BOOT=y @@ -27,7 +29,6 @@ CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk mtdparts=atmel_nand:256k(bootstrap)ro,768k(uboot)ro,256K(env_redundant),256k(env),512k(dtb),6M(kernel)ro,-(rootfs) rootfstype=ubifs ubi.mtd=6 root=ubi0:rootfs" # CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_SPL_TEXT_BASE=0x200000 CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x10000 CONFIG_HUSH_PARSER=y diff --git a/configs/sfr_nb4-ser_ram_defconfig b/configs/sfr_nb4-ser_ram_defconfig index 07ad515f70..6267975663 100644 --- a/configs/sfr_nb4-ser_ram_defconfig +++ b/configs/sfr_nb4-ser_ram_defconfig @@ -7,6 +7,7 @@ CONFIG_BOARD_SFR_NB4_SER=y # CONFIG_MIPS_BOOT_CMDLINE_LEGACY is not set # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y +CONFIG_SKIP_LOWLEVEL_INIT=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DISPLAY_CPUINFO=y @@ -51,7 +52,6 @@ CONFIG_PHY=y CONFIG_BCM6358_USBH_PHY=y CONFIG_DM_RESET=y CONFIG_RESET_BCM6345=y -# CONFIG_SPL_SERIAL_PRESENT is not set CONFIG_DM_SERIAL=y CONFIG_BCM6345_SERIAL=y CONFIG_USB=y diff --git a/configs/sheep-rk3368_defconfig b/configs/sheep-rk3368_defconfig index 4883f5932b..55ebe3f803 100644 --- a/configs/sheep-rk3368_defconfig +++ b/configs/sheep-rk3368_defconfig @@ -7,6 +7,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0xFF1b0000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ANDROID_BOOT_IMAGE=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3368-sheep.dtb" # CONFIG_DISPLAY_CPUINFO is not set diff --git a/configs/sheevaplug_defconfig b/configs/sheevaplug_defconfig index 734e894c98..c708df72c0 100644 --- a/configs/sheevaplug_defconfig +++ b/configs/sheevaplug_defconfig @@ -7,6 +7,7 @@ CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_SHEEVAPLUG=y CONFIG_NR_DRAM_BANKS=2 CONFIG_IDENT_STRING="\nMarvell-Sheevaplug" +CONFIG_SKIP_LOWLEVEL_INIT=y # CONFIG_SYS_MALLOC_F is not set CONFIG_BOOTDELAY=3 CONFIG_USE_PREBOOT=y diff --git a/configs/smartweb_defconfig b/configs/smartweb_defconfig index 9e73051def..5adc552884 100644 --- a/configs/smartweb_defconfig +++ b/configs/smartweb_defconfig @@ -15,6 +15,7 @@ CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL_SYS_MALLOC_F_LEN=0x400 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y +CONFIG_SKIP_LOWLEVEL_INIT_ONLY=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9260" CONFIG_BOOTDELAY=3 diff --git a/configs/smdk5250_defconfig b/configs/smdk5250_defconfig index 6c7eb9315c..e76c2a40ed 100644 --- a/configs/smdk5250_defconfig +++ b/configs/smdk5250_defconfig @@ -9,13 +9,14 @@ CONFIG_TARGET_SMDK5250=y CONFIG_NR_DRAM_BANKS=8 CONFIG_SPL=y CONFIG_IDENT_STRING=" for SMDK5250" +CONFIG_SPL_TEXT_BASE=0x02023400 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y CONFIG_SILENT_CONSOLE=y CONFIG_CONSOLE_MUX=y # CONFIG_SPL_FRAMEWORK is not set -CONFIG_SPL_TEXT_BASE=0x02023400 CONFIG_SYS_PROMPT="SMDK5250 # " CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y diff --git a/configs/smdk5420_defconfig b/configs/smdk5420_defconfig index 714c9636cd..eadb353fd7 100644 --- a/configs/smdk5420_defconfig +++ b/configs/smdk5420_defconfig @@ -7,13 +7,14 @@ CONFIG_TARGET_SMDK5420=y CONFIG_NR_DRAM_BANKS=7 CONFIG_SPL=y CONFIG_IDENT_STRING=" for SMDK5420" +CONFIG_SPL_TEXT_BASE=0x02024410 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y CONFIG_SILENT_CONSOLE=y CONFIG_CONSOLE_MUX=y # CONFIG_SPL_FRAMEWORK is not set -CONFIG_SPL_TEXT_BASE=0x02024410 CONFIG_SYS_PROMPT="SMDK5420 # " CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y diff --git a/configs/smdkv310_defconfig b/configs/smdkv310_defconfig index 880867fdca..f5d073adbe 100644 --- a/configs/smdkv310_defconfig +++ b/configs/smdkv310_defconfig @@ -5,10 +5,11 @@ CONFIG_SYS_TEXT_BASE=0x43E00000 CONFIG_ARCH_EXYNOS4=y CONFIG_SPL=y CONFIG_IDENT_STRING=" for SMDKC210/V310" +CONFIG_SPL_TEXT_BASE=0x02021410 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_USE_BOOTCOMMAND is not set # CONFIG_SPL_FRAMEWORK is not set -CONFIG_SPL_TEXT_BASE=0x02021410 CONFIG_SYS_PROMPT="SMDKV310 # " # CONFIG_CMD_XIMG is not set CONFIG_CMD_GPT=y diff --git a/configs/snapper9260_defconfig b/configs/snapper9260_defconfig index d3d51c52e0..c0c970f3e1 100644 --- a/configs/snapper9260_defconfig +++ b/configs/snapper9260_defconfig @@ -6,6 +6,7 @@ CONFIG_TARGET_SNAPPER9260=y CONFIG_ENV_SIZE=0x40000 CONFIG_ENV_OFFSET=0x80000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9260" CONFIG_BOOTDELAY=3 diff --git a/configs/snapper9g20_defconfig b/configs/snapper9g20_defconfig index 6466ee80f2..59af5ada65 100644 --- a/configs/snapper9g20_defconfig +++ b/configs/snapper9g20_defconfig @@ -6,6 +6,7 @@ CONFIG_TARGET_SNAPPER9260=y CONFIG_ENV_SIZE=0x40000 CONFIG_ENV_OFFSET=0x80000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20" CONFIG_BOOTDELAY=3 diff --git a/configs/snow_defconfig b/configs/snow_defconfig index e4d3703e00..a6fb3d55bf 100644 --- a/configs/snow_defconfig +++ b/configs/snow_defconfig @@ -12,12 +12,13 @@ CONFIG_DEBUG_UART_BASE=0x12c30000 CONFIG_DEBUG_UART_CLOCK=100000000 CONFIG_IDENT_STRING=" for snow" CONFIG_DEBUG_UART=y +CONFIG_SPL_TEXT_BASE=0x02023400 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y CONFIG_SILENT_CONSOLE=y # CONFIG_SPL_FRAMEWORK is not set -CONFIG_SPL_TEXT_BASE=0x02023400 CONFIG_SYS_PROMPT="snow # " CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y diff --git a/configs/spring_defconfig b/configs/spring_defconfig index bdbfc64b4c..0dd4e3f0be 100644 --- a/configs/spring_defconfig +++ b/configs/spring_defconfig @@ -12,12 +12,13 @@ CONFIG_DEBUG_UART_BASE=0x12c30000 CONFIG_DEBUG_UART_CLOCK=100000000 CONFIG_IDENT_STRING=" for spring" CONFIG_DEBUG_UART=y +CONFIG_SPL_TEXT_BASE=0x02023400 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y CONFIG_SILENT_CONSOLE=y # CONFIG_SPL_FRAMEWORK is not set -CONFIG_SPL_TEXT_BASE=0x02023400 CONFIG_SYS_PROMPT="spring # " CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y diff --git a/configs/stih410-b2260_defconfig b/configs/stih410-b2260_defconfig index 7b79c08ef4..27a05f2890 100644 --- a/configs/stih410-b2260_defconfig +++ b/configs/stih410-b2260_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_STI=y CONFIG_SYS_TEXT_BASE=0x7D600000 CONFIG_NR_DRAM_BANKS=1 CONFIG_IDENT_STRING="STMicroelectronics STiH410-B2260" +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/taurus_defconfig b/configs/taurus_defconfig index 3676ecd419..9c6f641e6f 100644 --- a/configs/taurus_defconfig +++ b/configs/taurus_defconfig @@ -23,6 +23,7 @@ CONFIG_DEBUG_UART_CLOCK=18432000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT_ONLY=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20,MACH_TYPE=2067" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/thuban_defconfig b/configs/thuban_defconfig index ade82c86e3..cc54b86051 100644 --- a/configs/thuban_defconfig +++ b/configs/thuban_defconfig @@ -17,6 +17,7 @@ CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_BOOTDELAY=3 CONFIG_USE_PREBOOT=y diff --git a/configs/ti814x_evm_defconfig b/configs/ti814x_evm_defconfig index 031fead67f..bd030faf0d 100644 --- a/configs/ti814x_evm_defconfig +++ b/configs/ti814x_evm_defconfig @@ -12,6 +12,8 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y +CONFIG_SPL_TEXT_BASE=0x40300000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_BOOTDELAY=1 CONFIG_SYS_CONSOLE_INFO_QUIET=y @@ -19,7 +21,6 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_SPL_TEXT_BASE=0x40300000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_YMODEM_SUPPORT=y diff --git a/configs/ti816x_evm_defconfig b/configs/ti816x_evm_defconfig index d341633fe1..9e31a60104 100644 --- a/configs/ti816x_evm_defconfig +++ b/configs/ti816x_evm_defconfig @@ -12,6 +12,8 @@ CONFIG_ENV_OFFSET=0x001c0000 CONFIG_SPL=y CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y +CONFIG_SPL_TEXT_BASE=0x40400000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y @@ -21,7 +23,6 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_MISC_INIT_R is not set CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_SPL_TEXT_BASE=0x40400000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_NAND_SUPPORT=y diff --git a/configs/tinker-rk3288_defconfig b/configs/tinker-rk3288_defconfig index 443f4d88b9..c7df6f93b3 100644 --- a/configs/tinker-rk3288_defconfig +++ b/configs/tinker-rk3288_defconfig @@ -8,6 +8,8 @@ CONFIG_SPL_SIZE_LIMIT=307200 CONFIG_DEBUG_UART_BASE=0xff690000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART=y +CONFIG_SPL_TEXT_BASE=0 +CONFIG_SKIP_LOWLEVEL_INIT_ONLY=y # CONFIG_ANDROID_BOOT_IMAGE is not set CONFIG_USE_PREBOOT=y CONFIG_SILENT_CONSOLE=y @@ -15,7 +17,6 @@ CONFIG_CONSOLE_MUX=y CONFIG_DEFAULT_FDT_FILE="rk3288-tinker.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_SPL_TEXT_BASE=0 CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y CONFIG_CMD_I2C=y diff --git a/configs/trats2_defconfig b/configs/trats2_defconfig index 86075946ed..93c521b95a 100644 --- a/configs/trats2_defconfig +++ b/configs/trats2_defconfig @@ -4,6 +4,7 @@ CONFIG_ARCH_EXYNOS=y CONFIG_SYS_TEXT_BASE=0x43e00000 CONFIG_ARCH_EXYNOS4=y CONFIG_TARGET_TRATS2=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_FIT=y diff --git a/configs/trats_defconfig b/configs/trats_defconfig index c8f1e29d3e..0acfb07a54 100644 --- a/configs/trats_defconfig +++ b/configs/trats_defconfig @@ -4,6 +4,7 @@ CONFIG_ARCH_EXYNOS=y CONFIG_SYS_TEXT_BASE=0x63300000 CONFIG_ARCH_EXYNOS4=y CONFIG_TARGET_TRATS=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/ts4800_defconfig b/configs/ts4800_defconfig index 208366e7d0..b48b0c6a4c 100644 --- a/configs/ts4800_defconfig +++ b/configs/ts4800_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x90008000 CONFIG_TARGET_TS4800=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_CMD_BMODE is not set +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_BOOTDELAY=1 CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/usb_a9263_dataflash_defconfig b/configs/usb_a9263_dataflash_defconfig index 5779aeb053..1890f50ae6 100644 --- a/configs/usb_a9263_dataflash_defconfig +++ b/configs/usb_a9263_dataflash_defconfig @@ -8,6 +8,7 @@ CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0x2000 CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SECT_SIZE=0x2000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263,SYS_USE_DATAFLASH" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y diff --git a/configs/vct_platinum_defconfig b/configs/vct_platinum_defconfig index 2a35ace0e0..728367ccc4 100644 --- a/configs/vct_platinum_defconfig +++ b/configs/vct_platinum_defconfig @@ -1,6 +1,7 @@ CONFIG_MIPS=y CONFIG_TARGET_VCT=y CONFIG_VCT_PLATINUM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_AUTO_COMPLETE is not set diff --git a/configs/vct_platinum_onenand_defconfig b/configs/vct_platinum_onenand_defconfig index ded3de0499..bf137ac837 100644 --- a/configs/vct_platinum_onenand_defconfig +++ b/configs/vct_platinum_onenand_defconfig @@ -2,6 +2,7 @@ CONFIG_MIPS=y CONFIG_TARGET_VCT=y CONFIG_VCT_PLATINUM=y CONFIG_VCT_ONENAND=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_AUTO_COMPLETE is not set diff --git a/configs/vct_platinum_onenand_small_defconfig b/configs/vct_platinum_onenand_small_defconfig index 4afb03ee9e..d733e66f1b 100644 --- a/configs/vct_platinum_onenand_small_defconfig +++ b/configs/vct_platinum_onenand_small_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_VCT=y CONFIG_VCT_PLATINUM=y CONFIG_VCT_ONENAND=y CONFIG_VCT_SMALL_IMAGE=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_AUTO_COMPLETE is not set diff --git a/configs/vct_platinum_small_defconfig b/configs/vct_platinum_small_defconfig index 8a3f94aadf..346e5df6d0 100644 --- a/configs/vct_platinum_small_defconfig +++ b/configs/vct_platinum_small_defconfig @@ -2,6 +2,7 @@ CONFIG_MIPS=y CONFIG_TARGET_VCT=y CONFIG_VCT_PLATINUM=y CONFIG_VCT_SMALL_IMAGE=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_AUTO_COMPLETE is not set diff --git a/configs/vct_platinumavc_defconfig b/configs/vct_platinumavc_defconfig index 3783becc8a..7681756d48 100644 --- a/configs/vct_platinumavc_defconfig +++ b/configs/vct_platinumavc_defconfig @@ -1,6 +1,7 @@ CONFIG_MIPS=y CONFIG_TARGET_VCT=y CONFIG_VCT_PLATINUMAVC=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_AUTO_COMPLETE is not set diff --git a/configs/vct_platinumavc_onenand_defconfig b/configs/vct_platinumavc_onenand_defconfig index e7e9c6cde1..d2e22ff93e 100644 --- a/configs/vct_platinumavc_onenand_defconfig +++ b/configs/vct_platinumavc_onenand_defconfig @@ -2,6 +2,7 @@ CONFIG_MIPS=y CONFIG_TARGET_VCT=y CONFIG_VCT_PLATINUMAVC=y CONFIG_VCT_ONENAND=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_AUTO_COMPLETE is not set diff --git a/configs/vct_platinumavc_onenand_small_defconfig b/configs/vct_platinumavc_onenand_small_defconfig index 776472666c..f65c515278 100644 --- a/configs/vct_platinumavc_onenand_small_defconfig +++ b/configs/vct_platinumavc_onenand_small_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_VCT=y CONFIG_VCT_PLATINUMAVC=y CONFIG_VCT_ONENAND=y CONFIG_VCT_SMALL_IMAGE=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_AUTO_COMPLETE is not set diff --git a/configs/vct_platinumavc_small_defconfig b/configs/vct_platinumavc_small_defconfig index 0d8cd07f9f..99ec3b764e 100644 --- a/configs/vct_platinumavc_small_defconfig +++ b/configs/vct_platinumavc_small_defconfig @@ -2,6 +2,7 @@ CONFIG_MIPS=y CONFIG_TARGET_VCT=y CONFIG_VCT_PLATINUMAVC=y CONFIG_VCT_SMALL_IMAGE=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_AUTO_COMPLETE is not set diff --git a/configs/vct_premium_defconfig b/configs/vct_premium_defconfig index 2396b24d55..1906940344 100644 --- a/configs/vct_premium_defconfig +++ b/configs/vct_premium_defconfig @@ -1,6 +1,7 @@ CONFIG_MIPS=y CONFIG_TARGET_VCT=y CONFIG_VCT_PREMIUM=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_AUTO_COMPLETE is not set diff --git a/configs/vct_premium_onenand_defconfig b/configs/vct_premium_onenand_defconfig index f1d01d9c90..c111f95f50 100644 --- a/configs/vct_premium_onenand_defconfig +++ b/configs/vct_premium_onenand_defconfig @@ -2,6 +2,7 @@ CONFIG_MIPS=y CONFIG_TARGET_VCT=y CONFIG_VCT_PREMIUM=y CONFIG_VCT_ONENAND=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_AUTO_COMPLETE is not set diff --git a/configs/vct_premium_onenand_small_defconfig b/configs/vct_premium_onenand_small_defconfig index 751f881942..aff7871a33 100644 --- a/configs/vct_premium_onenand_small_defconfig +++ b/configs/vct_premium_onenand_small_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_VCT=y CONFIG_VCT_PREMIUM=y CONFIG_VCT_ONENAND=y CONFIG_VCT_SMALL_IMAGE=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_AUTO_COMPLETE is not set diff --git a/configs/vct_premium_small_defconfig b/configs/vct_premium_small_defconfig index a8eba61827..e023126430 100644 --- a/configs/vct_premium_small_defconfig +++ b/configs/vct_premium_small_defconfig @@ -2,6 +2,7 @@ CONFIG_MIPS=y CONFIG_TARGET_VCT=y CONFIG_VCT_PREMIUM=y CONFIG_VCT_SMALL_IMAGE=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_AUTO_COMPLETE is not set diff --git a/configs/vf610twr_defconfig b/configs/vf610twr_defconfig index f3e55b87bd..5bfb9c3fc7 100644 --- a/configs/vf610twr_defconfig +++ b/configs/vf610twr_defconfig @@ -3,6 +3,7 @@ CONFIG_SYS_THUMB_BUILD=y CONFIG_ARCH_VF610=y CONFIG_SYS_TEXT_BASE=0x3f401000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/vf610twr/imximage.cfg" CONFIG_BOOTDELAY=3 CONFIG_LOGLEVEL=3 diff --git a/configs/vf610twr_nand_defconfig b/configs/vf610twr_nand_defconfig index 64b108d41d..9a1e3e737e 100644 --- a/configs/vf610twr_nand_defconfig +++ b/configs/vf610twr_nand_defconfig @@ -3,6 +3,7 @@ CONFIG_SYS_THUMB_BUILD=y CONFIG_ARCH_VF610=y CONFIG_SYS_TEXT_BASE=0x3f401000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/vf610twr/imximage.cfg" CONFIG_BOOTDELAY=3 CONFIG_LOGLEVEL=3 diff --git a/configs/vinco_defconfig b/configs/vinco_defconfig index 4ab62e74ae..dd3af43177 100644 --- a/configs/vinco_defconfig +++ b/configs/vinco_defconfig @@ -7,6 +7,7 @@ CONFIG_ENV_SIZE=0x10000 CONFIG_ENV_OFFSET=0x10000 CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SECT_SIZE=0x1000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_SPI_BOOT=y CONFIG_BOOTDELAY=3 diff --git a/configs/vyasa-rk3288_defconfig b/configs/vyasa-rk3288_defconfig index c74c1457a7..df6b258b7c 100644 --- a/configs/vyasa-rk3288_defconfig +++ b/configs/vyasa-rk3288_defconfig @@ -10,12 +10,13 @@ CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEBUG_UART_BASE=0xff690000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART=y +CONFIG_SPL_TEXT_BASE=0xff704000 +CONFIG_SKIP_LOWLEVEL_INIT_ONLY=y CONFIG_USE_PREBOOT=y CONFIG_SILENT_CONSOLE=y CONFIG_DEFAULT_FDT_FILE="rk3288-vyasa.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_SPL_TEXT_BASE=0xff704000 CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_CMD_GPIO=y diff --git a/configs/wb45n_defconfig b/configs/wb45n_defconfig index be6744b82b..8d206319f9 100644 --- a/configs/wb45n_defconfig +++ b/configs/wb45n_defconfig @@ -10,11 +10,12 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_ENV_OFFSET=0xa0000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y +CONFIG_SPL_TEXT_BASE=0x300000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9X5,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_SPL_TEXT_BASE=0x300000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/wb50n_defconfig b/configs/wb50n_defconfig index ef427f350d..5058685156 100644 --- a/configs/wb50n_defconfig +++ b/configs/wb50n_defconfig @@ -10,10 +10,11 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_ENV_OFFSET=0xA0000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y +CONFIG_SPL_TEXT_BASE=0x300000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D3,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 -CONFIG_SPL_TEXT_BASE=0x300000 CONFIG_SPL_NAND_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/work_92105_defconfig b/configs/work_92105_defconfig index 5131805c4a..03fb5fd34b 100644 --- a/configs/work_92105_defconfig +++ b/configs/work_92105_defconfig @@ -12,6 +12,8 @@ CONFIG_CMD_MAX6957=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y +CONFIG_SPL_TEXT_BASE=0x00000000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS2,115200n8" @@ -19,7 +21,6 @@ CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y -CONFIG_SPL_TEXT_BASE=0x00000000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_NAND_SUPPORT=y diff --git a/configs/xilinx_zynqmp_r5_defconfig b/configs/xilinx_zynqmp_r5_defconfig index de4460c137..ac422b7a77 100644 --- a/configs/xilinx_zynqmp_r5_defconfig +++ b/configs/xilinx_zynqmp_r5_defconfig @@ -5,6 +5,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0xff010000 CONFIG_DEBUG_UART_CLOCK=100000000 CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_BOOTSTAGE=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SYS_PROMPT="ZynqMP r5> " diff --git a/configs/zynq_cse_nand_defconfig b/configs/zynq_cse_nand_defconfig index 0910d3bf9d..18c1adf40c 100644 --- a/configs/zynq_cse_nand_defconfig +++ b/configs/zynq_cse_nand_defconfig @@ -8,6 +8,7 @@ CONFIG_ENV_SIZE=0x190 CONFIG_SPL_STACK_R_ADDR=0x200000 CONFIG_SPL=y CONFIG_SYS_MALLOC_LEN=0x1000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_CUSTOM_LDSCRIPT=y CONFIG_SYS_LDSCRIPT="arch/arm/mach-zynq/u-boot.lds" CONFIG_USE_PREBOOT=y diff --git a/configs/zynq_cse_nor_defconfig b/configs/zynq_cse_nor_defconfig index 0a6b172b7e..39a881afea 100644 --- a/configs/zynq_cse_nor_defconfig +++ b/configs/zynq_cse_nor_defconfig @@ -8,6 +8,7 @@ CONFIG_ENV_SIZE=0x190 CONFIG_SPL_STACK_R_ADDR=0x200000 CONFIG_SPL=y CONFIG_SYS_MALLOC_LEN=0x1000 +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_CUSTOM_LDSCRIPT=y CONFIG_SYS_LDSCRIPT="arch/arm/mach-zynq/u-boot.lds" CONFIG_USE_PREBOOT=y diff --git a/configs/zynq_cse_qspi_defconfig b/configs/zynq_cse_qspi_defconfig index 4972d70805..d71e2b65ec 100644 --- a/configs/zynq_cse_qspi_defconfig +++ b/configs/zynq_cse_qspi_defconfig @@ -13,6 +13,7 @@ CONFIG_DEBUG_UART_CLOCK=0 # CONFIG_ZYNQ_DDRC_INIT is not set # CONFIG_CMD_ZYNQ is not set CONFIG_DEBUG_UART=y +CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_CUSTOM_LDSCRIPT=y CONFIG_SYS_LDSCRIPT="arch/arm/mach-zynq/u-boot.lds" # CONFIG_ARCH_FIXUP_FDT_MEMORY is not set diff --git a/include/configs/SBx81LIFKW.h b/include/configs/SBx81LIFKW.h index f24cd23af2..1a33e313be 100644 --- a/include/configs/SBx81LIFKW.h +++ b/include/configs/SBx81LIFKW.h @@ -11,7 +11,6 @@ */ #define CONFIG_FEROCEON_88FR131 1 /* CPU Core subversion */ #define CONFIG_KW88F6281 1 /* SOC Name */ -#define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */ #define CONFIG_SYS_KWD_CONFIG $(CONFIG_BOARDDIR)/kwbimage.cfg
/* additions for new ARM relocation support */ diff --git a/include/configs/SBx81LIFXCAT.h b/include/configs/SBx81LIFXCAT.h index b602323262..1670f4dcd2 100644 --- a/include/configs/SBx81LIFXCAT.h +++ b/include/configs/SBx81LIFXCAT.h @@ -11,7 +11,6 @@ */ #define CONFIG_FEROCEON_88FR131 1 /* CPU Core subversion */ #define CONFIG_KW88F6281 1 /* SOC Name */ -#define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */ #define CONFIG_SYS_KWD_CONFIG $(CONFIG_BOARDDIR)/kwbimage.cfg
/* additions for new ARM relocation support */ diff --git a/include/configs/adp-ae3xx.h b/include/configs/adp-ae3xx.h index 1fe33917d0..5fc34886be 100644 --- a/include/configs/adp-ae3xx.h +++ b/include/configs/adp-ae3xx.h @@ -15,8 +15,6 @@ */ #define CONFIG_USE_INTERRUPT
-#define CONFIG_SKIP_LOWLEVEL_INIT - #define CONFIG_SKIP_TRUNOFF_WATCHDOG
#define CONFIG_ARCH_MAP_SYSMEM diff --git a/include/configs/adp-ag101p.h b/include/configs/adp-ag101p.h index 6cf494e73f..9140ac4c92 100644 --- a/include/configs/adp-ag101p.h +++ b/include/configs/adp-ag101p.h @@ -15,8 +15,6 @@ */ #define CONFIG_USE_INTERRUPT
-#define CONFIG_SKIP_LOWLEVEL_INIT - #define CONFIG_ARCH_MAP_SYSMEM
#define CONFIG_BOOTP_SEND_HOSTNAME diff --git a/include/configs/am43xx_evm.h b/include/configs/am43xx_evm.h index d355b80c2f..95cf37d29f 100644 --- a/include/configs/am43xx_evm.h +++ b/include/configs/am43xx_evm.h @@ -45,9 +45,6 @@ * Since SPL did pll and ddr initialization for us, * we don't need to do it twice. */ -#if !defined(CONFIG_SPL_BUILD) && !defined(CONFIG_QSPI_BOOT) -#define CONFIG_SKIP_LOWLEVEL_INIT -#endif
/* * When building U-Boot such that there is no previous loader diff --git a/include/configs/am65x_evm.h b/include/configs/am65x_evm.h index 6072e4a48c..5ec0417ab9 100644 --- a/include/configs/am65x_evm.h +++ b/include/configs/am65x_evm.h @@ -50,10 +50,6 @@ #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "tispl.bin" #endif
-#ifndef CONFIG_CPU_V7R -#define CONFIG_SKIP_LOWLEVEL_INIT -#endif - #define CONFIG_SPL_MAX_SIZE CONFIG_SYS_K3_MAX_DOWNLODABLE_IMAGE_SIZE
#define CONFIG_SYS_BOOTM_LEN SZ_64M diff --git a/include/configs/aspenite.h b/include/configs/aspenite.h index 79bf8f26e9..1b33e15609 100644 --- a/include/configs/aspenite.h +++ b/include/configs/aspenite.h @@ -15,7 +15,6 @@ #define CONFIG_SHEEVA_88SV331xV5 1 /* CPU Core subversion */ #define CONFIG_ARMADA100 1 /* SOC Family Name */ #define CONFIG_ARMADA168 1 /* SOC Used on this Board */ -#define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */
/* * There is no internal RAM in ARMADA100, using DRAM diff --git a/include/configs/at91-sama5_common.h b/include/configs/at91-sama5_common.h index 7af6b8b843..25ec2ee8b8 100644 --- a/include/configs/at91-sama5_common.h +++ b/include/configs/at91-sama5_common.h @@ -13,10 +13,6 @@ #define CONFIG_SYS_AT91_SLOW_CLOCK 32768 #define CONFIG_SYS_AT91_MAIN_CLOCK 12000000 /* from 12 MHz crystal */
-#ifndef CONFIG_SPL_BUILD -#define CONFIG_SKIP_LOWLEVEL_INIT -#endif - /* general purpose I/O */ #ifndef CONFIG_DM_GPIO #define CONFIG_AT91_GPIO diff --git a/include/configs/at91rm9200ek.h b/include/configs/at91rm9200ek.h index 8bfba35e16..db87733ddf 100644 --- a/include/configs/at91rm9200ek.h +++ b/include/configs/at91rm9200ek.h @@ -22,9 +22,6 @@ * at91rm9200ek_ram_config -> continue booting from 0x20100000 in RAM; lowlevel * initialisation was done by some preloader */ -#ifdef CONFIG_RAMBOOT -#define CONFIG_SKIP_LOWLEVEL_INIT -#endif
/* * AT91C_XTAL_CLOCK is the frequency of external xtal in hertz diff --git a/include/configs/at91sam9260ek.h b/include/configs/at91sam9260ek.h index b283c9d873..712f66a503 100644 --- a/include/configs/at91sam9260ek.h +++ b/include/configs/at91sam9260ek.h @@ -38,7 +38,6 @@ #define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG -#define CONFIG_SKIP_LOWLEVEL_INIT
/* general purpose I/O */ #define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */ diff --git a/include/configs/at91sam9261ek.h b/include/configs/at91sam9261ek.h index 599e2627f6..3d6094c8c7 100644 --- a/include/configs/at91sam9261ek.h +++ b/include/configs/at91sam9261ek.h @@ -26,8 +26,6 @@ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG
-#define CONFIG_SKIP_LOWLEVEL_INIT - #define CONFIG_ATMEL_LEGACY
/* diff --git a/include/configs/at91sam9263ek.h b/include/configs/at91sam9263ek.h index 3e7adf63f3..0d348b992f 100644 --- a/include/configs/at91sam9263ek.h +++ b/include/configs/at91sam9263ek.h @@ -25,7 +25,6 @@ #define CONFIG_INITRD_TAG 1
#ifndef CONFIG_SYS_USE_BOOT_NORFLASH -#define CONFIG_SKIP_LOWLEVEL_INIT #else #define CONFIG_SYS_USE_NORFLASH #endif diff --git a/include/configs/at91sam9m10g45ek.h b/include/configs/at91sam9m10g45ek.h index 044c428a71..b792405749 100644 --- a/include/configs/at91sam9m10g45ek.h +++ b/include/configs/at91sam9m10g45ek.h @@ -21,7 +21,6 @@ #define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG -#define CONFIG_SKIP_LOWLEVEL_INIT
/* general purpose I/O */ #define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */ diff --git a/include/configs/at91sam9n12ek.h b/include/configs/at91sam9n12ek.h index bc79e1739b..d4af7acfcc 100644 --- a/include/configs/at91sam9n12ek.h +++ b/include/configs/at91sam9n12ek.h @@ -17,7 +17,6 @@ #define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG -#define CONFIG_SKIP_LOWLEVEL_INIT
/* LCD */ #define LCD_BPP LCD_COLOR16 diff --git a/include/configs/at91sam9rlek.h b/include/configs/at91sam9rlek.h index 1c67be56b0..0ddce9c127 100644 --- a/include/configs/at91sam9rlek.h +++ b/include/configs/at91sam9rlek.h @@ -16,8 +16,6 @@ #define CONFIG_SYS_AT91_SLOW_CLOCK 32768 /* slow clock xtal */ #define CONFIG_SYS_AT91_MAIN_CLOCK 12000000 /* main clock xtal */
-#define CONFIG_SKIP_LOWLEVEL_INIT - #define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ #define CONFIG_SETUP_MEMORY_TAGS 1 #define CONFIG_INITRD_TAG 1 diff --git a/include/configs/at91sam9x5ek.h b/include/configs/at91sam9x5ek.h index ad7d281dd6..7d6c712e20 100644 --- a/include/configs/at91sam9x5ek.h +++ b/include/configs/at91sam9x5ek.h @@ -15,7 +15,6 @@ #define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG -#define CONFIG_SKIP_LOWLEVEL_INIT
/* general purpose I/O */ #define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */ diff --git a/include/configs/bcm23550_w1d.h b/include/configs/bcm23550_w1d.h index f59cd75d68..6ed87abb07 100644 --- a/include/configs/bcm23550_w1d.h +++ b/include/configs/bcm23550_w1d.h @@ -11,7 +11,6 @@
/* CPU, chip, mach, etc */ #define CONFIG_KONA -#define CONFIG_SKIP_LOWLEVEL_INIT #define CONFIG_KONA_RESET_S
/* diff --git a/include/configs/bcm28155_ap.h b/include/configs/bcm28155_ap.h index 111858ffb0..d652eb544e 100644 --- a/include/configs/bcm28155_ap.h +++ b/include/configs/bcm28155_ap.h @@ -11,7 +11,6 @@
/* * Memory configuration diff --git a/include/configs/bcm_ep_board.h b/include/configs/bcm_ep_board.h index b67100aa3a..f7e79cdf6a 100644 --- a/include/configs/bcm_ep_board.h +++ b/include/configs/bcm_ep_board.h @@ -8,8 +8,6 @@
#include <asm/arch/configs.h>
-#define CONFIG_SKIP_LOWLEVEL_INIT - /* * Memory configuration * (these must be defined elsewhere) diff --git a/include/configs/bcmstb.h b/include/configs/bcmstb.h index b8437052a9..1364ce55f8 100644 --- a/include/configs/bcmstb.h +++ b/include/configs/bcmstb.h @@ -35,7 +35,6 @@ extern phys_addr_t prior_stage_fdt_address; /* * CPU configuration. */ -#define CONFIG_SKIP_LOWLEVEL_INIT
/* * Memory configuration. diff --git a/include/configs/bk4r1.h b/include/configs/bk4r1.h index 285e28b535..f54622e264 100644 --- a/include/configs/bk4r1.h +++ b/include/configs/bk4r1.h @@ -66,8 +66,6 @@ #include <asm/arch/imx-regs.h> #include <linux/sizes.h>
-#define CONFIG_SKIP_LOWLEVEL_INIT - /* Enable passing of ATAGs */ #define CONFIG_CMDLINE_TAG
diff --git a/include/configs/bmips_bcm3380.h b/include/configs/bmips_bcm3380.h index e2f9e76a97..de646e0744 100644 --- a/include/configs/bmips_bcm3380.h +++ b/include/configs/bmips_bcm3380.h @@ -16,7 +16,6 @@ #define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_SDRAM_BASE + 0x100000
#if defined(CONFIG_BMIPS_BOOT_RAM) -#define CONFIG_SKIP_LOWLEVEL_INIT #define CONFIG_SYS_INIT_SP_OFFSET 0x2000 #endif
diff --git a/include/configs/bmips_bcm6318.h b/include/configs/bmips_bcm6318.h index 476aa51af3..6015d7345c 100644 --- a/include/configs/bmips_bcm6318.h +++ b/include/configs/bmips_bcm6318.h @@ -23,7 +23,6 @@ #define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_SDRAM_BASE + 0x100000
diff --git a/include/configs/bmips_bcm63268.h b/include/configs/bmips_bcm63268.h index 1456b0ec47..7333d2a1bb 100644 --- a/include/configs/bmips_bcm63268.h +++ b/include/configs/bmips_bcm63268.h @@ -23,7 +23,6 @@ #define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_SDRAM_BASE + 0x100000
diff --git a/include/configs/bmips_bcm6328.h b/include/configs/bmips_bcm6328.h index faf9abcc3e..8cae873274 100644 --- a/include/configs/bmips_bcm6328.h +++ b/include/configs/bmips_bcm6328.h @@ -23,7 +23,6 @@ #define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_SDRAM_BASE + 0x100000
diff --git a/include/configs/bmips_bcm6338.h b/include/configs/bmips_bcm6338.h index 83050c94a6..e4e522abd9 100644 --- a/include/configs/bmips_bcm6338.h +++ b/include/configs/bmips_bcm6338.h @@ -16,7 +16,6 @@ #define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_SDRAM_BASE + 0x100000
diff --git a/include/configs/bmips_bcm6348.h b/include/configs/bmips_bcm6348.h index 5eb8b0f9d0..8d23de73eb 100644 --- a/include/configs/bmips_bcm6348.h +++ b/include/configs/bmips_bcm6348.h @@ -21,7 +21,6 @@ #define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_SDRAM_BASE + 0x100000
diff --git a/include/configs/bmips_bcm6358.h b/include/configs/bmips_bcm6358.h index 7becf3fcb9..e8665b8818 100644 --- a/include/configs/bmips_bcm6358.h +++ b/include/configs/bmips_bcm6358.h @@ -23,7 +23,6 @@ #define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_SDRAM_BASE + 0x100000
diff --git a/include/configs/bmips_bcm6362.h b/include/configs/bmips_bcm6362.h index 60777207e1..965be54974 100644 --- a/include/configs/bmips_bcm6362.h +++ b/include/configs/bmips_bcm6362.h @@ -23,7 +23,6 @@ #define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_SDRAM_BASE + 0x100000
diff --git a/include/configs/bmips_bcm6368.h b/include/configs/bmips_bcm6368.h index 1a57476e05..1dc6784b96 100644 --- a/include/configs/bmips_bcm6368.h +++ b/include/configs/bmips_bcm6368.h @@ -23,7 +23,6 @@ #define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_SDRAM_BASE + 0x100000
diff --git a/include/configs/bmips_bcm6838.h b/include/configs/bmips_bcm6838.h index d735c51efc..7ff9d284a0 100644 --- a/include/configs/bmips_bcm6838.h +++ b/include/configs/bmips_bcm6838.h @@ -16,7 +16,6 @@ #define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_SDRAM_BASE + 0x100000
diff --git a/include/configs/broadcom_bcm963158.h b/include/configs/broadcom_bcm963158.h index a0f7ead4c7..4166d716d9 100644 --- a/include/configs/broadcom_bcm963158.h +++ b/include/configs/broadcom_bcm963158.h @@ -28,8 +28,6 @@ #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_TEXT_BASE + SZ_16M) #define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_TEXT_BASE
-#define CONFIG_SKIP_LOWLEVEL_INIT - #ifdef CONFIG_NAND #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_SELF_INIT diff --git a/include/configs/broadcom_bcm968580xref.h b/include/configs/broadcom_bcm968580xref.h index fdb620341d..a175670f25 100644 --- a/include/configs/broadcom_bcm968580xref.h +++ b/include/configs/broadcom_bcm968580xref.h @@ -27,8 +27,6 @@ #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_TEXT_BASE + SZ_16M) #define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_TEXT_BASE
-#define CONFIG_SKIP_LOWLEVEL_INIT - #ifdef CONFIG_NAND #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_SELF_INIT diff --git a/include/configs/bur_am335x_common.h b/include/configs/bur_am335x_common.h index 42e3e568be..398ebb4105 100644 --- a/include/configs/bur_am335x_common.h +++ b/include/configs/bur_am335x_common.h @@ -48,9 +48,6 @@ * Since SPL did pll and ddr initialization for us, * we don't need to do it twice. */ -#if !defined(CONFIG_SPL_BUILD) && !defined(CONFIG_NOR_BOOT) -#define CONFIG_SKIP_LOWLEVEL_INIT -#endif /* !CONFIG_SPL_BUILD, ... */ /* * Our DDR memory always starts at 0x80000000 and U-Boot shall have * relocated itself to higher in memory by the time this value is used. diff --git a/include/configs/ci20.h b/include/configs/ci20.h index 21a86323c2..b0a70ae20c 100644 --- a/include/configs/ci20.h +++ b/include/configs/ci20.h @@ -9,8 +9,6 @@ #ifndef __CONFIG_CI20_H__ #define __CONFIG_CI20_H__
-#define CONFIG_SKIP_LOWLEVEL_INIT - /* Ingenic JZ4780 clock configuration. */ #define CONFIG_SYS_HZ 1000 #define CONFIG_SYS_MHZ 1200 diff --git a/include/configs/cm_t43.h b/include/configs/cm_t43.h index 1314cf96a2..a852a8ae5f 100644 --- a/include/configs/cm_t43.h +++ b/include/configs/cm_t43.h @@ -65,9 +65,6 @@ * Since SPL did pll and ddr initialization for us, * we don't need to do it twice. */ -#if !defined(CONFIG_SPL_BUILD) -#define CONFIG_SKIP_LOWLEVEL_INIT -#endif
#define CONFIG_HSMMC2_8BIT
diff --git a/include/configs/colibri_vf.h b/include/configs/colibri_vf.h index da9a8426ec..2660396894 100644 --- a/include/configs/colibri_vf.h +++ b/include/configs/colibri_vf.h @@ -16,8 +16,6 @@
#define CONFIG_SYS_FSL_CLK
-#define CONFIG_SKIP_LOWLEVEL_INIT - #ifdef CONFIG_VIDEO_FSL_DCU_FB #define CONFIG_SPLASH_SCREEN_ALIGN #define CONFIG_VIDEO_LOGO diff --git a/include/configs/controlcenterdc.h b/include/configs/controlcenterdc.h index f6d53284d7..08e3e2cfb3 100644 --- a/include/configs/controlcenterdc.h +++ b/include/configs/controlcenterdc.h @@ -12,7 +12,6 @@ */ #define CONFIG_CUSTOMER_BOARD_SUPPORT
-#define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */ #define CONFIG_BOARD_LATE_INIT
/* diff --git a/include/configs/corvus.h b/include/configs/corvus.h index f2df66eaa3..1eca9ad7da 100644 --- a/include/configs/corvus.h +++ b/include/configs/corvus.h @@ -32,7 +32,6 @@ #define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG -#define CONFIG_SKIP_LOWLEVEL_INIT_ONLY
/* general purpose I/O */ #define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */ diff --git a/include/configs/da850evm.h b/include/configs/da850evm.h index 41f0813a01..9c7ae38e77 100644 --- a/include/configs/da850evm.h +++ b/include/configs/da850evm.h @@ -26,7 +26,6 @@ #define CONFIG_SYS_OSCIN_FREQ 24000000 #define CONFIG_SYS_TIMERBASE DAVINCI_TIMER0_BASE #define CONFIG_SYS_HZ_CLOCK clk_get(DAVINCI_AUXCLK_CLKID) -#define CONFIG_SKIP_LOWLEVEL_INIT_ONLY
#ifdef CONFIG_DIRECT_NOR_BOOT #define CONFIG_SYS_DV_NOR_BOOT_CFG (0x11) diff --git a/include/configs/db-88f6281-bp.h b/include/configs/db-88f6281-bp.h index 1b5541e49e..c16fa32dce 100644 --- a/include/configs/db-88f6281-bp.h +++ b/include/configs/db-88f6281-bp.h @@ -8,7 +8,6 @@ */ #define CONFIG_FEROCEON_88FR131 1 /* CPU Core subversion */ #define CONFIG_KW88F6281 1 /* SOC Name */ -#define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */ #define CONFIG_SYS_TCLK 166666667 #define CONFIG_SYS_KWD_CONFIG $(CONFIG_BOARDDIR)/kwbimage.cfg #define CONFIG_BUILD_TARGET "u-boot.kwb" diff --git a/include/configs/devkit3250.h b/include/configs/devkit3250.h index 16031c1da6..d9153fe1f4 100644 --- a/include/configs/devkit3250.h +++ b/include/configs/devkit3250.h @@ -14,10 +14,6 @@
#define CONFIG_MACH_TYPE MACH_TYPE_DEVKIT3250
-#if !defined(CONFIG_SPL_BUILD) -#define CONFIG_SKIP_LOWLEVEL_INIT -#endif - /* * Memory configurations */ diff --git a/include/configs/dns325.h b/include/configs/dns325.h index f72ee90ab5..1e50a4d950 100644 --- a/include/configs/dns325.h +++ b/include/configs/dns325.h @@ -22,7 +22,6 @@ */ #define CONFIG_FEROCEON_88FR131 /* CPU Core subversion */ #define CONFIG_KW88F6281 /* SOC Name */ -#define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */
/* * Commands configuration diff --git a/include/configs/dockstar.h b/include/configs/dockstar.h index f33978829d..a294697d5e 100644 --- a/include/configs/dockstar.h +++ b/include/configs/dockstar.h @@ -16,7 +16,6 @@ */ #define CONFIG_FEROCEON_88FR131 1 /* CPU Core subversion */ #define CONFIG_KW88F6281 1 /* SOC Name */ -#define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */
/* * mv-common.h should be defined after CMD configs since it used them diff --git a/include/configs/ethernut5.h b/include/configs/ethernut5.h index c9e7c8c0e2..7ae02c967f 100644 --- a/include/configs/ethernut5.h +++ b/include/configs/ethernut5.h @@ -14,7 +14,6 @@ /* The first stage boot loader expects u-boot running at this address. */
/* The first stage boot loader takes care of low level initialization. */ -#define CONFIG_SKIP_LOWLEVEL_INIT
/* Set our official architecture number. */ #define CONFIG_MACH_TYPE MACH_TYPE_ETHERNUT5 diff --git a/include/configs/exynos-common.h b/include/configs/exynos-common.h index 5ae2b427ca..227f9eb887 100644 --- a/include/configs/exynos-common.h +++ b/include/configs/exynos-common.h @@ -15,8 +15,6 @@ #include <asm/arch/cpu.h> /* get chip and board defs */ #include <linux/sizes.h>
-#define CONFIG_SKIP_LOWLEVEL_INIT - /* Keep L2 Cache Disabled */
/* input clock of PLL: 24MHz input clock */ diff --git a/include/configs/gardena-smart-gateway-at91sam.h b/include/configs/gardena-smart-gateway-at91sam.h index 482e4714b1..d567d08a7a 100644 --- a/include/configs/gardena-smart-gateway-at91sam.h +++ b/include/configs/gardena-smart-gateway-at91sam.h @@ -13,11 +13,6 @@ #define CONFIG_SYS_AT91_SLOW_CLOCK 32768 #define CONFIG_SYS_AT91_MAIN_CLOCK 12000000 /* 12 MHz crystal */
-#ifndef CONFIG_SPL_BUILD -#define CONFIG_SKIP_LOWLEVEL_INIT -#endif -#define CONFIG_SKIP_LOWLEVEL_INIT_ONLY - /* general purpose I/O */ #define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */
diff --git a/include/configs/gardena-smart-gateway-mt7688.h b/include/configs/gardena-smart-gateway-mt7688.h index b3b89d2ab9..8a6a2b79d5 100644 --- a/include/configs/gardena-smart-gateway-mt7688.h +++ b/include/configs/gardena-smart-gateway-mt7688.h @@ -16,10 +16,6 @@
#define CONFIG_SYS_INIT_SP_OFFSET 0x400000
-#ifdef CONFIG_BOOT_RAM -#define CONFIG_SKIP_LOWLEVEL_INIT -#endif - /* UART */ #define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200, \ 230400, 500000, 1500000 } diff --git a/include/configs/goflexhome.h b/include/configs/goflexhome.h index 1d69a4e518..212dee8bdc 100644 --- a/include/configs/goflexhome.h +++ b/include/configs/goflexhome.h @@ -19,7 +19,6 @@ */ #define CONFIG_FEROCEON_88FR131 1 /* CPU Core subversion */ #define CONFIG_KW88F6281 1 /* SOC Name */ -#define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */
/* * Default GPIO configuration and LED status diff --git a/include/configs/gplugd.h b/include/configs/gplugd.h index 7da8739a19..965b8bd471 100644 --- a/include/configs/gplugd.h +++ b/include/configs/gplugd.h @@ -21,7 +21,6 @@ #define CONFIG_ARMADA100 1 /* SOC Family Name */ #define CONFIG_ARMADA168 1 /* SOC Used on this Board */ #define CONFIG_MACH_TYPE MACH_TYPE_GPLUGD /* Machine type */ -#define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */
/* * There is no internal RAM in ARMADA100, using DRAM diff --git a/include/configs/highbank.h b/include/configs/highbank.h index c0e295b6b7..a4b6f83c2a 100644 --- a/include/configs/highbank.h +++ b/include/configs/highbank.h @@ -63,6 +63,5 @@
#define CONFIG_SYS_SDRAM_BASE 0x00000000 #define CONFIG_SYS_INIT_SP_ADDR 0x01000000 -#define CONFIG_SKIP_LOWLEVEL_INIT
#endif diff --git a/include/configs/ib62x0.h b/include/configs/ib62x0.h index 5e54441c73..4c2a267e61 100644 --- a/include/configs/ib62x0.h +++ b/include/configs/ib62x0.h @@ -13,7 +13,6 @@ */ #define CONFIG_FEROCEON_88FR131 /* CPU Core subversion */ #define CONFIG_KW88F6281 /* SOC Name */ -#define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */
/* * Compression configuration diff --git a/include/configs/iconnect.h b/include/configs/iconnect.h index 87113d7805..513054e303 100644 --- a/include/configs/iconnect.h +++ b/include/configs/iconnect.h @@ -13,7 +13,6 @@ */ #define CONFIG_FEROCEON_88FR131 /* CPU Core subversion */ #define CONFIG_KW88F6281 /* SOC Name */ -#define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */
/* * Machine type diff --git a/include/configs/imgtec_xilfpga.h b/include/configs/imgtec_xilfpga.h index 8e2d72323d..0f22d05363 100644 --- a/include/configs/imgtec_xilfpga.h +++ b/include/configs/imgtec_xilfpga.h @@ -11,7 +11,6 @@ #define __XILFPGA_CONFIG_H
/* BootROM + MIG is pretty smart. DDR and Cache initialized */ -#define CONFIG_SKIP_LOWLEVEL_INIT
/*-------------------------------------------- * CPU configuration diff --git a/include/configs/integrator-common.h b/include/configs/integrator-common.h index 9223fc2cde..5c863addd8 100644 --- a/include/configs/integrator-common.h +++ b/include/configs/integrator-common.h @@ -50,7 +50,6 @@ * image to run at reset/power up * e.g. whether the ARM Boot Monitor runs before U-Boot */ -/* #define CONFIG_SKIP_LOWLEVEL_INIT */
/* * The ARM boot monitor does not relocate U-Boot. diff --git a/include/configs/km/km_arm.h b/include/configs/km/km_arm.h index 829a5c7825..d1defcc230 100644 --- a/include/configs/km/km_arm.h +++ b/include/configs/km/km_arm.h @@ -58,8 +58,6 @@ "appended one; fi\0" \ ""
-#define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */ - /* * For booting Linux, the board info and command line data * have to be in the first 8 MB of memory, since this is diff --git a/include/configs/lacie_kw.h b/include/configs/lacie_kw.h index 1ba28b501f..a09794b7a9 100644 --- a/include/configs/lacie_kw.h +++ b/include/configs/lacie_kw.h @@ -37,7 +37,6 @@ #else #define CONFIG_KW88F6281 #endif -#define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */
/* * Core clock definition diff --git a/include/configs/legoev3.h b/include/configs/legoev3.h index c1eeca0c60..77e492a4bd 100644 --- a/include/configs/legoev3.h +++ b/include/configs/legoev3.h @@ -22,7 +22,6 @@ #define CONFIG_SYS_OSCIN_FREQ 24000000 #define CONFIG_SYS_TIMERBASE DAVINCI_TIMER0_BASE #define CONFIG_SYS_HZ_CLOCK clk_get(DAVINCI_AUXCLK_CLKID) -#define CONFIG_SKIP_LOWLEVEL_INIT
/* * Memory Info diff --git a/include/configs/linkit-smart-7688.h b/include/configs/linkit-smart-7688.h index 2adf38545a..c5d45c5b87 100644 --- a/include/configs/linkit-smart-7688.h +++ b/include/configs/linkit-smart-7688.h @@ -16,10 +16,6 @@
-#ifdef CONFIG_BOOT_RAM -#define CONFIG_SKIP_LOWLEVEL_INIT -#endif - /* UART */ #define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200, \ 230400, 500000, 1500000 } diff --git a/include/configs/ls1012a_common.h b/include/configs/ls1012a_common.h index dd2a679b79..475637f236 100644 --- a/include/configs/ls1012a_common.h +++ b/include/configs/ls1012a_common.h @@ -13,8 +13,6 @@
#define CONFIG_SYS_CLK_FREQ 125000000
-#define CONFIG_SKIP_LOWLEVEL_INIT - #ifdef CONFIG_TFABOOT #define CONFIG_SYS_INIT_SP_ADDR CONFIG_SYS_TEXT_BASE #else diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index 66771e279b..36cbe75473 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -12,8 +12,6 @@
-#define CONFIG_SKIP_LOWLEVEL_INIT - #define CONFIG_DEEP_SLEEP
/* diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index 31abee81ed..1db5a4a9b6 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -12,7 +12,6 @@
-#define CONFIG_SKIP_LOWLEVEL_INIT #define CONFIG_DEEP_SLEEP
/* diff --git a/include/configs/ls1028a_common.h b/include/configs/ls1028a_common.h index 40fcd22582..66178fbcdb 100644 --- a/include/configs/ls1028a_common.h +++ b/include/configs/ls1028a_common.h @@ -17,8 +17,6 @@ /* Link Definitions */ #define CONFIG_SYS_INIT_SP_ADDR CONFIG_SYS_TEXT_BASE
-#define CONFIG_SKIP_LOWLEVEL_INIT - #define CONFIG_VERY_BIG_RAM #define CONFIG_SYS_DDR_SDRAM_BASE 0x80000000UL #define CONFIG_SYS_FSL_DDR_SDRAM_BASE_PHY 0 diff --git a/include/configs/ls1043a_common.h b/include/configs/ls1043a_common.h index 70447a2183..0a85a7c028 100644 --- a/include/configs/ls1043a_common.h +++ b/include/configs/ls1043a_common.h @@ -38,8 +38,6 @@ #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_FSL_OCRAM_BASE + 0xfff0) #endif
-#define CONFIG_SKIP_LOWLEVEL_INIT - #define CONFIG_VERY_BIG_RAM #define CONFIG_SYS_DDR_SDRAM_BASE 0x80000000 #define CONFIG_SYS_FSL_DDR_SDRAM_BASE_PHY 0 diff --git a/include/configs/ls1043aqds.h b/include/configs/ls1043aqds.h index 0ea3ca0332..ea6c30cb3b 100644 --- a/include/configs/ls1043aqds.h +++ b/include/configs/ls1043aqds.h @@ -16,8 +16,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_CLK_FREQ get_board_sys_clk() #define CONFIG_DDR_CLK_FREQ get_board_ddr_clk()
-#define CONFIG_SKIP_LOWLEVEL_INIT - #define CONFIG_LAYERSCAPE_NS_ACCESS
#define CONFIG_DIMM_SLOTS_PER_CTLR 1 diff --git a/include/configs/ls1046a_common.h b/include/configs/ls1046a_common.h index 59c43f1ae1..deef50d709 100644 --- a/include/configs/ls1046a_common.h +++ b/include/configs/ls1046a_common.h @@ -39,8 +39,6 @@ #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_FSL_OCRAM_BASE + 0xfff0) #endif
-#define CONFIG_SKIP_LOWLEVEL_INIT - #define CONFIG_VERY_BIG_RAM #define CONFIG_SYS_DDR_SDRAM_BASE 0x80000000 #define CONFIG_SYS_FSL_DDR_SDRAM_BASE_PHY 0 diff --git a/include/configs/ls1046aqds.h b/include/configs/ls1046aqds.h index eea738e602..e9ce9fc5ac 100644 --- a/include/configs/ls1046aqds.h +++ b/include/configs/ls1046aqds.h @@ -16,8 +16,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_CLK_FREQ get_board_sys_clk() #define CONFIG_DDR_CLK_FREQ get_board_ddr_clk()
#define CONFIG_DIMM_SLOTS_PER_CTLR 1 diff --git a/include/configs/ls1088a_common.h b/include/configs/ls1088a_common.h index 6f04dbaccd..cb9d0c9de8 100644 --- a/include/configs/ls1088a_common.h +++ b/include/configs/ls1088a_common.h @@ -46,8 +46,6 @@ #endif #endif
-#define CONFIG_SKIP_LOWLEVEL_INIT - #define CONFIG_VERY_BIG_RAM #define CONFIG_SYS_DDR_SDRAM_BASE 0x80000000UL #define CONFIG_SYS_FSL_DDR_SDRAM_BASE_PHY 0 diff --git a/include/configs/ls2080a_common.h b/include/configs/ls2080a_common.h index 6be581a229..8dc7dbc528 100644 --- a/include/configs/ls2080a_common.h +++ b/include/configs/ls2080a_common.h @@ -32,8 +32,6 @@ #endif #endif
-#define CONFIG_SKIP_LOWLEVEL_INIT - #ifndef CONFIG_SYS_FSL_DDR4 #define CONFIG_SYS_DDR_RAW_TIMING #endif diff --git a/include/configs/lsxl.h b/include/configs/lsxl.h index 3ba5548f25..59fa9aa127 100644 --- a/include/configs/lsxl.h +++ b/include/configs/lsxl.h @@ -28,8 +28,6 @@ #define CONFIG_FEROCEON_88FR131 /* CPU Core subversion */ #define CONFIG_KW88F6281 /* SOC Name */
-#define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */ - #define CONFIG_KIRKWOOD_GPIO
/* diff --git a/include/configs/lx2160a_common.h b/include/configs/lx2160a_common.h index 711b434baf..552dc8c0c6 100644 --- a/include/configs/lx2160a_common.h +++ b/include/configs/lx2160a_common.h @@ -19,7 +19,6 @@ #define CONFIG_SYS_INIT_SP_ADDR CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_FLASH_BASE 0x20000000
-#define CONFIG_SKIP_LOWLEVEL_INIT #define CONFIG_BOARD_EARLY_INIT_F 1
/* DDR */ diff --git a/include/configs/meesc.h b/include/configs/meesc.h index 3a173a2665..927f80f3b0 100644 --- a/include/configs/meesc.h +++ b/include/configs/meesc.h @@ -32,7 +32,6 @@ #define CONFIG_SYS_AT91_MAIN_CLOCK 16000000/* 16.0 MHz crystal */
/* Misc CPU related */ -#define CONFIG_SKIP_LOWLEVEL_INIT #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG #define CONFIG_SERIAL_TAG diff --git a/include/configs/mv-plug-common.h b/include/configs/mv-plug-common.h index 486650f183..d38d9872c0 100644 --- a/include/configs/mv-plug-common.h +++ b/include/configs/mv-plug-common.h @@ -11,7 +11,6 @@ * High Level Configuration Options (easy to change) */ #define CONFIG_KW88F6281 1 /* SOC Name */ -#define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */
/* * mv-common.h should be defined after CMD configs since it used them diff --git a/include/configs/mx31pdk.h b/include/configs/mx31pdk.h index 04e3b8ff28..6a98ffc4df 100644 --- a/include/configs/mx31pdk.h +++ b/include/configs/mx31pdk.h @@ -25,10 +25,6 @@ #define CONFIG_SPL_TARGET "u-boot-with-spl.bin" #define CONFIG_SPL_MAX_SIZE 2048
-#ifndef CONFIG_SPL_BUILD -#define CONFIG_SKIP_LOWLEVEL_INIT -#endif - /* * Size of malloc() pool */ diff --git a/include/configs/mx7_common.h b/include/configs/mx7_common.h index 70dda35eb0..c36efa9ffe 100644 --- a/include/configs/mx7_common.h +++ b/include/configs/mx7_common.h @@ -58,10 +58,5 @@ * launched by OPTEE, because of that we shall skip all the low level * initialization since it was already done by ATF or OPTEE */ -#if (CONFIG_OPTEE_TZDRAM_SIZE != 0) -#ifndef CONFIG_OPTEE -#define CONFIG_SKIP_LOWLEVEL_INIT -#endif -#endif
#endif diff --git a/include/configs/nas220.h b/include/configs/nas220.h index bdfa42fd30..b441e45769 100644 --- a/include/configs/nas220.h +++ b/include/configs/nas220.h @@ -21,7 +21,6 @@ */ #define CONFIG_FEROCEON_88FR131 /* #define CPU Core subversion */ #define CONFIG_KW88F6192 /* SOC Name */ -#define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */
/* power-on led, regulator, sata0, sata1 */ #define NAS220_GE_OE_VAL_LOW ((1 << 12)|(1 << 14)|(1 << 24)|(1 << 28)) diff --git a/include/configs/nokia_rx51.h b/include/configs/nokia_rx51.h index fd755bbcea..0d5731cd14 100644 --- a/include/configs/nokia_rx51.h +++ b/include/configs/nokia_rx51.h @@ -40,8 +40,6 @@ #define V_OSCK 26000000 /* Clock output from T2 */ #define V_SCLK (V_OSCK >> 1)
-#define CONFIG_SKIP_LOWLEVEL_INIT /* X-Loader set everything up */ - #define CONFIG_CMDLINE_TAG /* enable passing kernel command line string */ #define CONFIG_INITRD_TAG /* enable passing initrd */ #define CONFIG_REVISION_TAG /* enable passing revision tag*/ diff --git a/include/configs/nsa310s.h b/include/configs/nsa310s.h index eb465e0690..3e8170d363 100644 --- a/include/configs/nsa310s.h +++ b/include/configs/nsa310s.h @@ -13,7 +13,6 @@ #define CONFIG_FEROCEON_88FR131 1 /* CPU Core subversion */ #define CONFIG_KW88F6192 1 /* SOC Name */ #define CONFIG_KW88F6702 1 /* SOC Name */ -#define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */
/* compression configuration */ #define CONFIG_BZIP2 diff --git a/include/configs/omapl138_lcdk.h b/include/configs/omapl138_lcdk.h index 1c41e7e97a..d34a5fcb37 100644 --- a/include/configs/omapl138_lcdk.h +++ b/include/configs/omapl138_lcdk.h @@ -23,7 +23,6 @@ #define CONFIG_SYS_TIMERBASE DAVINCI_TIMER0_BASE #define CONFIG_SYS_HZ_CLOCK clk_get(DAVINCI_AUXCLK_CLKID) #define CONFIG_SYS_HZ 1000 -#define CONFIG_SKIP_LOWLEVEL_INIT
/* * Memory Info diff --git a/include/configs/openrd.h b/include/configs/openrd.h index 62d8862cc7..0531958750 100644 --- a/include/configs/openrd.h +++ b/include/configs/openrd.h @@ -18,7 +18,6 @@ */ #define CONFIG_SHEEVA_88SV131 1 /* CPU Core subversion */ #define CONFIG_KW88F6281 1 /* SOC Name */ -#define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */
/* * Commands configuration diff --git a/include/configs/pcm052.h b/include/configs/pcm052.h index fb8f3c8609..81ca660fc6 100644 --- a/include/configs/pcm052.h +++ b/include/configs/pcm052.h @@ -11,8 +11,6 @@ #include <asm/arch/imx-regs.h> #include <linux/sizes.h>
diff --git a/include/configs/picosam9g45.h b/include/configs/picosam9g45.h index ad41d16149..b54375aa07 100644 --- a/include/configs/picosam9g45.h +++ b/include/configs/picosam9g45.h @@ -24,7 +24,6 @@ #define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG -#define CONFIG_SKIP_LOWLEVEL_INIT
/* general purpose I/O */ #define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */ diff --git a/include/configs/pm9261.h b/include/configs/pm9261.h index 99ca1f730e..e59c0fc049 100644 --- a/include/configs/pm9261.h +++ b/include/configs/pm9261.h @@ -132,8 +132,6 @@ #define CONFIG_SETUP_MEMORY_TAGS 1 #define CONFIG_INITRD_TAG 1
-#undef CONFIG_SKIP_LOWLEVEL_INIT - /* * Hardware drivers */ diff --git a/include/configs/pm9263.h b/include/configs/pm9263.h index 595acf1b94..bc68335f13 100644 --- a/include/configs/pm9263.h +++ b/include/configs/pm9263.h @@ -144,7 +144,6 @@ #define CONFIG_SETUP_MEMORY_TAGS 1 #define CONFIG_INITRD_TAG 1
-#undef CONFIG_SKIP_LOWLEVEL_INIT #define CONFIG_USER_LOWLEVEL_INIT 1
/* diff --git a/include/configs/pm9g45.h b/include/configs/pm9g45.h index ae87f9be79..e1c91b995d 100644 --- a/include/configs/pm9g45.h +++ b/include/configs/pm9g45.h @@ -22,7 +22,6 @@ #define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG -#define CONFIG_SKIP_LOWLEVEL_INIT
/* general purpose I/O */ #define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */ diff --git a/include/configs/pogo_e02.h b/include/configs/pogo_e02.h index 68d726835c..dc9ffc01b9 100644 --- a/include/configs/pogo_e02.h +++ b/include/configs/pogo_e02.h @@ -22,7 +22,6 @@ */ #define CONFIG_FEROCEON_88FR131 /* CPU Core subversion */ #define CONFIG_KW88F6281 /* SOC Name */ -#define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */
/* * Commands configuration diff --git a/include/configs/rk3036_common.h b/include/configs/rk3036_common.h index 7f148eff87..205fcde4ab 100644 --- a/include/configs/rk3036_common.h +++ b/include/configs/rk3036_common.h @@ -9,7 +9,6 @@ #include "rockchip-common.h"
#define CONFIG_SYS_CBSIZE 1024 -#define CONFIG_SKIP_LOWLEVEL_INIT
#define CONFIG_ROCKCHIP_STIMER_BASE 0x200440a0 #define COUNTER_FREQUENCY 24000000 diff --git a/include/configs/rk3128_common.h b/include/configs/rk3128_common.h index d0c9e5c809..929e8ba722 100644 --- a/include/configs/rk3128_common.h +++ b/include/configs/rk3128_common.h @@ -11,7 +11,6 @@ #define CONFIG_SYS_MAXARGS 16 #define CONFIG_BAUDRATE 115200 #define CONFIG_SYS_CBSIZE 1024 -#define CONFIG_SKIP_LOWLEVEL_INIT
#define CONFIG_ROCKCHIP_STIMER_BASE 0x200440a0 #define COUNTER_FREQUENCY 24000000 diff --git a/include/configs/rk3188_common.h b/include/configs/rk3188_common.h index 3bcc04808a..b208c66dfd 100644 --- a/include/configs/rk3188_common.h +++ b/include/configs/rk3188_common.h @@ -11,7 +11,6 @@ #include <asm/arch-rockchip/hardware.h> #include "rockchip-common.h"
-#define CONFIG_SKIP_LOWLEVEL_INIT_ONLY #define CONFIG_SYS_CBSIZE 1024
#ifdef CONFIG_SPL_ROCKCHIP_BACK_TO_BROM diff --git a/include/configs/rk322x_common.h b/include/configs/rk322x_common.h index 7e0c831174..3b53065f1c 100644 --- a/include/configs/rk322x_common.h +++ b/include/configs/rk322x_common.h @@ -8,7 +8,6 @@ #include <asm/arch-rockchip/hardware.h> #include "rockchip-common.h"
-#define CONFIG_SKIP_LOWLEVEL_INIT #define CONFIG_SYS_CBSIZE 1024 #define CONFIG_SYS_BOOTM_LEN (64 << 20) /* 64M */
diff --git a/include/configs/rk3288_common.h b/include/configs/rk3288_common.h index bcda769af5..f97e6a5210 100644 --- a/include/configs/rk3288_common.h +++ b/include/configs/rk3288_common.h @@ -11,7 +11,6 @@
#define CONFIG_SYS_BOOTM_LEN (16 << 20) /* 16MB */
#define CONFIG_ROCKCHIP_STIMER_BASE 0xff810020 diff --git a/include/configs/rk3328_common.h b/include/configs/rk3328_common.h index 3ff3331c80..17ce08c711 100644 --- a/include/configs/rk3328_common.h +++ b/include/configs/rk3328_common.h @@ -13,7 +13,6 @@ #define CONFIG_ROCKCHIP_STIMER_BASE 0xff1d0020
#define CONFIG_SYS_INIT_SP_ADDR 0x00300000 #define CONFIG_SYS_LOAD_ADDR 0x00800800 diff --git a/include/configs/rk3368_common.h b/include/configs/rk3368_common.h index e4b2114a0d..a73bd63529 100644 --- a/include/configs/rk3368_common.h +++ b/include/configs/rk3368_common.h @@ -17,7 +17,6 @@ #define SDRAM_MAX_SIZE 0xff000000 #define CONFIG_BAUDRATE 115200 #define CONFIG_SYS_CBSIZE 1024 -#define CONFIG_SKIP_LOWLEVEL_INIT
#define CONFIG_ROCKCHIP_STIMER_BASE 0xff830020 #define COUNTER_FREQUENCY 24000000 diff --git a/include/configs/rk3399_common.h b/include/configs/rk3399_common.h index 126c34763e..b1b2c5cc6d 100644 --- a/include/configs/rk3399_common.h +++ b/include/configs/rk3399_common.h @@ -9,7 +9,6 @@ #include "rockchip-common.h"
#define COUNTER_FREQUENCY 24000000 #define CONFIG_ROCKCHIP_STIMER_BASE 0xff8680a0 diff --git a/include/configs/rpi.h b/include/configs/rpi.h index 8473cecd94..7b1c20a746 100644 --- a/include/configs/rpi.h +++ b/include/configs/rpi.h @@ -9,10 +9,6 @@ #include <linux/sizes.h> #include <asm/arch/timer.h>
-#if defined(CONFIG_TARGET_RPI_2) || defined(CONFIG_TARGET_RPI_3_32B) -#define CONFIG_SKIP_LOWLEVEL_INIT -#endif - /* Architecture, CPU, etc.*/
/* Use SoC timer for AArch32, but architected timer for AArch64 */ diff --git a/include/configs/rv1108_common.h b/include/configs/rv1108_common.h index 758e85e89d..ca85b81b5a 100644 --- a/include/configs/rv1108_common.h +++ b/include/configs/rv1108_common.h @@ -11,7 +11,6 @@ #define CONFIG_IRAM_BASE 0x10080000
#define CONFIG_SYS_TIMER_RATE (24 * 1000 * 1000) /* TIMER1,initialized by ddr initialize code */ diff --git a/include/configs/s32v234evb.h b/include/configs/s32v234evb.h index cc6d920637..7c344ef0aa 100644 --- a/include/configs/s32v234evb.h +++ b/include/configs/s32v234evb.h @@ -32,8 +32,6 @@
#define CONFIG_MACH_TYPE 4146
-#define CONFIG_SKIP_LOWLEVEL_INIT - /* Config CACHE */ #define CONFIG_CMD_CACHE
diff --git a/include/configs/siemens-am33x-common.h b/include/configs/siemens-am33x-common.h index ea6cc38fc1..480af8e5a8 100644 --- a/include/configs/siemens-am33x-common.h +++ b/include/configs/siemens-am33x-common.h @@ -138,9 +138,6 @@ * Since SPL did pll and ddr initialization for us, * we don't need to do it twice. */ -#ifndef CONFIG_SPL_BUILD -#define CONFIG_SKIP_LOWLEVEL_INIT -#endif
#ifndef CONFIG_SPL_BUILD /* diff --git a/include/configs/smartweb.h b/include/configs/smartweb.h index c1a43a5e55..8926a4927b 100644 --- a/include/configs/smartweb.h +++ b/include/configs/smartweb.h @@ -43,7 +43,6 @@ #define CONFIG_CMDLINE_TAG /* pass commandline to Kernel */ #define CONFIG_SETUP_MEMORY_TAGS /* pass memory defs to kernel */ #define CONFIG_INITRD_TAG /* pass initrd param to kernel */ -#define CONFIG_SKIP_LOWLEVEL_INIT_ONLY /* U-Boot is loaded by a bootloader */
/* We set the max number of command args high to avoid HUSH bugs. */ #define CONFIG_SYS_MAXARGS 32 diff --git a/include/configs/smdkv310.h b/include/configs/smdkv310.h index 68af0ef450..27e508e985 100644 --- a/include/configs/smdkv310.h +++ b/include/configs/smdkv310.h @@ -34,7 +34,6 @@ #define CONFIG_ENV_OVERWRITE
/* MMC SPL */ -#define CONFIG_SKIP_LOWLEVEL_INIT #define COPY_BL2_FNPTR_ADDR 0x00002488
#define CONFIG_BOOTCOMMAND "fatload mmc 0 40007000 uImage; bootm 40007000" diff --git a/include/configs/snapper9260.h b/include/configs/snapper9260.h index b0408a5592..79391734ab 100644 --- a/include/configs/snapper9260.h +++ b/include/configs/snapper9260.h @@ -23,7 +23,6 @@ #define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG -#define CONFIG_SKIP_LOWLEVEL_INIT
/* SDRAM */ #define CONFIG_SYS_SDRAM_BASE ATMEL_BASE_CS1 diff --git a/include/configs/snapper9g45.h b/include/configs/snapper9g45.h index ffcfdcaafc..b5e1f5071d 100644 --- a/include/configs/snapper9g45.h +++ b/include/configs/snapper9g45.h @@ -22,7 +22,6 @@ #define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG -#define CONFIG_SKIP_LOWLEVEL_INIT_ONLY
/* SDRAM */ #define CONFIG_SYS_SDRAM_BASE ATMEL_BASE_CS6 diff --git a/include/configs/stih410-b2260.h b/include/configs/stih410-b2260.h index b67efbb168..4648245afa 100644 --- a/include/configs/stih410-b2260.h +++ b/include/configs/stih410-b2260.h @@ -59,8 +59,6 @@
#define CONFIG_SYS_MAX_FLASH_BANKS 1
-#define CONFIG_SKIP_LOWLEVEL_INIT - /* USB Configs */ #define CONFIG_USB_OHCI_NEW #define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 2 diff --git a/include/configs/taurus.h b/include/configs/taurus.h index fdd1c5224b..a59fbfa269 100644 --- a/include/configs/taurus.h +++ b/include/configs/taurus.h @@ -37,8 +37,6 @@ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG
-#define CONFIG_SKIP_LOWLEVEL_INIT_ONLY - /* general purpose I/O */ #define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */ #define CONFIG_AT91_GPIO diff --git a/include/configs/tegra-common-post.h b/include/configs/tegra-common-post.h index fae0e761fb..afa9395d71 100644 --- a/include/configs/tegra-common-post.h +++ b/include/configs/tegra-common-post.h @@ -103,9 +103,6 @@
/* overrides for SPL build here */ #ifdef CONFIG_SPL_BUILD - -#define CONFIG_SKIP_LOWLEVEL_INIT_ONLY - /* remove I2C support */ #ifdef CONFIG_SYS_I2C_TEGRA #undef CONFIG_SYS_I2C_TEGRA diff --git a/include/configs/ti814x_evm.h b/include/configs/ti814x_evm.h index 46b1b41ef9..b0dcc2b7bb 100644 --- a/include/configs/ti814x_evm.h +++ b/include/configs/ti814x_evm.h @@ -144,9 +144,6 @@ * Since SPL did pll and ddr initialization for us, * we don't need to do it twice. */ -#ifndef CONFIG_SPL_BUILD -#define CONFIG_SKIP_LOWLEVEL_INIT -#endif
/* Ethernet */ #define CONFIG_BOOTP_DNS2 diff --git a/include/configs/ti816x_evm.h b/include/configs/ti816x_evm.h index fc5608b3fd..e91b48b284 100644 --- a/include/configs/ti816x_evm.h +++ b/include/configs/ti816x_evm.h @@ -100,9 +100,6 @@ /* Since SPL did pll and ddr initialization for us, * we don't need to do it twice. */ -#ifndef CONFIG_SPL_BUILD -#define CONFIG_SKIP_LOWLEVEL_INIT -#endif
/* * Disable MMC DM for SPL build and can be re-enabled after adding diff --git a/include/configs/ti_am335x_common.h b/include/configs/ti_am335x_common.h index 19e1e2249e..748201dec4 100644 --- a/include/configs/ti_am335x_common.h +++ b/include/configs/ti_am335x_common.h @@ -48,9 +48,6 @@ * Since SPL did pll and ddr initialization for us, * we don't need to do it twice. */ -#if !defined(CONFIG_SPL_BUILD) && !defined(CONFIG_NOR_BOOT) -#define CONFIG_SKIP_LOWLEVEL_INIT -#endif
/* * When building U-Boot such that there is no previous loader diff --git a/include/configs/ti_armv7_keystone2.h b/include/configs/ti_armv7_keystone2.h index d7bb1efcbf..ace6b29341 100644 --- a/include/configs/ti_armv7_keystone2.h +++ b/include/configs/ti_armv7_keystone2.h @@ -12,7 +12,6 @@ #define CONFIG_SOC_KEYSTONE
/* U-Boot Build Configuration */ -#define CONFIG_SKIP_LOWLEVEL_INIT /* U-Boot is a 2nd stage loader */
/* SoC Configuration */ #define CONFIG_SPL_TARGET "u-boot-spi.gph" diff --git a/include/configs/ts4800.h b/include/configs/ts4800.h index 4e274bd414..45ac59802f 100644 --- a/include/configs/ts4800.h +++ b/include/configs/ts4800.h @@ -14,8 +14,6 @@
/* High Level Configuration Options */
-#define CONFIG_SKIP_LOWLEVEL_INIT /* U-Boot is a 2nd stage bootloader */ - #define CONFIG_HW_WATCHDOG
#define CONFIG_MACH_TYPE MACH_TYPE_TS48XX diff --git a/include/configs/usb_a9263.h b/include/configs/usb_a9263.h index c0ba647d09..6bcf4dce3a 100644 --- a/include/configs/usb_a9263.h +++ b/include/configs/usb_a9263.h @@ -26,8 +26,6 @@ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG
-#define CONFIG_SKIP_LOWLEVEL_INIT - /* * Hardware drivers */ diff --git a/include/configs/vct.h b/include/configs/vct.h index 571071593a..433e141a22 100644 --- a/include/configs/vct.h +++ b/include/configs/vct.h @@ -27,8 +27,6 @@ #define CPU_CLOCK_RATE 324000000 /* Clock for the MIPS core */ #define CONFIG_SYS_MIPS_TIMER_FREQ (CPU_CLOCK_RATE / 2)
-#define CONFIG_SKIP_LOWLEVEL_INIT /* SDRAM is initialized by the bootstrap code */ - #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_MONITOR_LEN (256 << 10) #define CONFIG_SYS_MALLOC_LEN (1 << 20) diff --git a/include/configs/vf610twr.h b/include/configs/vf610twr.h index ba85bc91e7..c24b1c8709 100644 --- a/include/configs/vf610twr.h +++ b/include/configs/vf610twr.h @@ -14,8 +14,6 @@
diff --git a/include/configs/wb45n.h b/include/configs/wb45n.h index 43de2e1119..2fb13633a5 100644 --- a/include/configs/wb45n.h +++ b/include/configs/wb45n.h @@ -15,7 +15,6 @@ #define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG -#define CONFIG_SKIP_LOWLEVEL_INIT
/* general purpose I/O */ #define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */ diff --git a/include/configs/wb50n.h b/include/configs/wb50n.h index 6e471f62e6..4729d770be 100644 --- a/include/configs/wb50n.h +++ b/include/configs/wb50n.h @@ -16,10 +16,6 @@ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG
-#ifndef CONFIG_SPL_BUILD -#define CONFIG_SKIP_LOWLEVEL_INIT -#endif - /* general purpose I/O */ #define CONFIG_AT91_GPIO
diff --git a/include/configs/work_92105.h b/include/configs/work_92105.h index e260a637d6..158990c46b 100644 --- a/include/configs/work_92105.h +++ b/include/configs/work_92105.h @@ -19,10 +19,6 @@ */ #define CONFIG_MACH_TYPE 736
-#if !defined(CONFIG_SPL_BUILD) -#define CONFIG_SKIP_LOWLEVEL_INIT -#endif - /* * Memory configurations */ diff --git a/include/configs/xilinx_zynqmp_r5.h b/include/configs/xilinx_zynqmp_r5.h index 4eb3312e2d..6e7df0498e 100644 --- a/include/configs/xilinx_zynqmp_r5.h +++ b/include/configs/xilinx_zynqmp_r5.h @@ -39,8 +39,6 @@
#define CONFIG_SYS_UBOOT_START CONFIG_SYS_TEXT_BASE
-#define CONFIG_SKIP_LOWLEVEL_INIT - /* 0x0 - 0x40 is used for placing exception vectors */ #define CONFIG_SYS_MEMTEST_START 0x40 #define CONFIG_SYS_MEMTEST_END 0x100 diff --git a/include/configs/zynq_cse.h b/include/configs/zynq_cse.h index daf7d75d30..f7a475b5a9 100644 --- a/include/configs/zynq_cse.h +++ b/include/configs/zynq_cse.h @@ -9,8 +9,6 @@ #ifndef __CONFIG_ZYNQ_CSE_H #define __CONFIG_ZYNQ_CSE_H
-#define CONFIG_SKIP_LOWLEVEL_INIT - #include <configs/zynq-common.h>
/* Undef unneeded configs */ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index b18eab1707..facb27a85d 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -1614,8 +1614,6 @@ CONFIG_SH_SPI_BASE CONFIG_SIEMENS_MACH_TYPE CONFIG_SIMU CONFIG_SKIP_LOCAL_MAC_RANDOMIZATION -CONFIG_SKIP_LOWLEVEL_INIT -CONFIG_SKIP_LOWLEVEL_INIT_ONLY CONFIG_SKIP_TRUNOFF_WATCHDOG CONFIG_SLIC CONFIG_SLTTMR
On Sat, Aug 31, 2019 at 01:25:18PM -0500, Adam Ford wrote:
This converts the following to Kconfig: CONFIG_SKIP_LOWLEVEL_INIT CONFIG_SKIP_LOWLEVEL_INIT_ONLY
Signed-off-by: Adam Ford aford173@gmail.com
This causes problems on at least: arm: + phycore-am335x-r2-wega apalis_t30 thuban am335x_hs_evm_uart trimslice colibri_t30 nyan-big harmony jetson-tk1 birdland_bav335b am335x_evm etamin colibri_t20 cardhu paz00 pcm051_rev3 pcm051_rev1 venice2 am335x_hs_evm birdland_bav335a am335x_pdu001 medcom-wide ventana seaboard chiliboard beaver am335x_igep003x tec tec-ng cei-tk1-som plutux dalmore rut am335x_boneblack_vboot am335x_guardian pxm2 rastaban apalis-tk1 pepper draco am335x_sl50
And others like turris_omnia have a size-change and so probably have another conversion problem. Thanks!
Adam Ford
