[PATCH] timer: mtk: skip setting parent with dummy fixed-clock
Skip setting parent with dummy fixed-clock. Upstream linux might declare an additional clock for the mtk timer and that additional clock might also be a fixed-clock defined in DT. Setting parent of a dummy fixed-clock resulta in error hence mtk timer fails to probe.
Skip setting parent to permit correct probe of the mtk timer.
Fixes: d3c3606c5cc6 ("timer: MediaTek: add timer driver for MediaTek SoCs") Signed-off-by: Christian Marangi ansuelsmth@gmail.com --- drivers/timer/mtk_timer.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/timer/mtk_timer.c b/drivers/timer/mtk_timer.c index 8216c289837..06deb23eb99 100644 --- a/drivers/timer/mtk_timer.c +++ b/drivers/timer/mtk_timer.c @@ -73,7 +73,8 @@ static int mtk_timer_probe(struct udevice *dev) return ret;
ret = clk_get_by_index(dev, 1, &parent); - if (!ret) { + /* Skip setting the parent with dummy fixed-clock */ + if (!ret && parent.dev->driver != DM_DRIVER_GET(fixed_clock)) { ret = clk_set_parent(&clk, &parent); if (ret) return ret;
Christian Marangi
