[U-Boot] [RFC] ks8851_mll: add ethernet support
The device interface is 16 bits wide. All the available packets are read from the incoming fifo.
Signed-off-by: Roberto Cerati <roberto.cerati@bticino.it Signed-off-by: Raffaele Recalcati raffaele.recalcati@bticino.it --- This driver has been adapted to u-boot starting from ks8851_mll linux driver. The smsc911x u-boot has been used as reference.
TODO: smsc911x reads only one packet from incoming fifo, ks8851_mll reads all packets in the incoming fifo, but it is not checked if upper driver level (net/eth.c ?) manages more than one packet.
This driver has been tested against u-boot-2009.11-psp03.00.01.06 u-boot version present in ti-dvsdk_dm3730-evm_4_01_00_09 DVSDK. The board name is baia and is based on dm3730 soc adapted from evm-dm3730 Ti board.
drivers/net/Makefile | 1 + drivers/net/ks8851_mll.c | 708 ++++++++++++++++++++++++++++++++++++++++++++++ drivers/net/ks8851_mll.h | 358 +++++++++++++++++++++++ 3 files changed, 1067 insertions(+), 0 deletions(-) create mode 100644 drivers/net/ks8851_mll.c create mode 100644 drivers/net/ks8851_mll.h
diff --git a/drivers/net/Makefile b/drivers/net/Makefile index fd9d0b4..ed69090 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -84,6 +84,7 @@ COBJS-$(CONFIG_TSI108_ETH) += tsi108_eth.o COBJS-$(CONFIG_ULI526X) += uli526x.o COBJS-$(CONFIG_VSC7385_ENET) += vsc7385.o COBJS-$(CONFIG_XILINX_EMACLITE) += xilinx_emaclite.o +COBJS-$(CONFIG_KS8851_MLL) += ks8851_mll.o
COBJS := $(sort $(COBJS-y)) SRCS := $(COBJS:.o=.c) diff --git a/drivers/net/ks8851_mll.c b/drivers/net/ks8851_mll.c new file mode 100644 index 0000000..b1560cc --- /dev/null +++ b/drivers/net/ks8851_mll.c @@ -0,0 +1,708 @@ +/* + * Micrel KS8851_MLL 16bit Network driver + * Copyright (c) 2011 Roberto Cerati roberto.cerati@bticino.it + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#include <common.h> +#include <command.h> +#include <malloc.h> +#include <net.h> +#include <miiphy.h> + +#include "ks8851_mll.h" + +#define MAX_RECV_FRAMES 32 +#define MAX_BUF_SIZE 2048 +#define TX_BUF_SIZE 2000 +#define RX_BUF_SIZE 2000 + +#define KS_CCR 0x08 +#define CCR_EEPROM (1 << 9) +#define CCR_SPI (1 << 8) +#define CCR_8BIT (1 << 7) +#define CCR_16BIT (1 << 6) +#define CCR_32BIT (1 << 5) +#define CCR_SHARED (1 << 4) +#define CCR_32PIN (1 << 0) + +/* + * union ks_tx_hdr - tx header data + * @txb: The header as bytes + * @txw: The header as 16bit, little-endian words + * + * A dual representation of the tx header data to allow + * access to individual bytes, and to allow 16bit accesses + * with 16bit alignment. + */ +union ks_tx_hdr { + u8 txb[4]; + __le16 txw[2]; +}; + +/* + * struct ks_net - KS8851 driver private data + * @net_device : The network device we're bound to + * @txh : temporaly buffer to save status/length. + * @frame_head_info : frame header information for multi-pkt rx. + * @statelock : Lock on this structure for tx list. + * @msg_enable : The message flags controlling driver output (see ethtool). + * @frame_cnt : number of frames received. + * @bus_width : i/o bus width. + * @irq : irq number assigned to this device. + * @rc_rxqcr : Cached copy of KS_RXQCR. + * @rc_txcr : Cached copy of KS_TXCR. + * @rc_ier : Cached copy of KS_IER. + * @sharedbus : Multipex(addr and data bus) mode indicator. + * @cmd_reg_cache : command register cached. + * @cmd_reg_cache_int : command register cached. Used in the irq handler. + * @promiscuous : promiscuous mode indicator. + * @all_mcast : mutlicast indicator. + * @mcast_lst_size : size of multicast list. + * @mcast_lst : multicast list. + * @mcast_bits : multicast enabed. + * @mac_addr : MAC address assigned to this device. + * @fid : frame id. + * @extra_byte : number of extra byte prepended rx pkt. + * @enabled : indicator this device works. + * + */ + +/* Receive multiplex framer header info */ +struct type_frame_head { + u16 sts; /* Frame status */ + u16 len; /* Byte count */ +} fr_h_i[MAX_RECV_FRAMES]; + +struct ks_net { + struct net_device *netdev; + union ks_tx_hdr txh; + struct type_frame_head *frame_head_info; + u32 msg_enable; + u32 frame_cnt; + int bus_width; + int irq; + + u16 rc_rxqcr; + u16 rc_txcr; + u16 rc_ier; + u16 sharedbus; + u16 cmd_reg_cache; + u16 cmd_reg_cache_int; + u16 promiscuous; + u16 all_mcast; + u16 mcast_lst_size; + u8 mcast_lst[MAX_MCAST_LST][MAC_ADDR_LEN]; + u8 mcast_bits[HW_MCAST_SIZE]; + u8 mac_addr[6]; + u8 fid; + u8 extra_byte; + u8 enabled; +} ks_str, *ks; + +#define BE3 0x8000 /* Byte Enable 3 */ +#define BE2 0x4000 /* Byte Enable 2 */ +#define BE1 0x2000 /* Byte Enable 1 */ +#define BE0 0x1000 /* Byte Enable 0 */ + +#define mdelay(n) udelay((n)*1000) + +static u8 ks_rdreg8(struct eth_device *dev, u16 offset) +{ + volatile u16 *hw_addr = (u16 *)(dev->iobase); + volatile u16 *hw_addr_cmd = (u16 *)(dev->iobase + 2); + + u16 data; + + u8 shift_bit = offset & 0x03; + u8 shift_data = (offset & 1) << 3; + + *hw_addr_cmd = offset | (u16)(BE0 << shift_bit); + + data = *hw_addr; + return (u8)(data >> shift_data); +} + +static u16 ks_rdreg16(struct eth_device *dev, u16 offset) +{ + volatile u16 *hw_addr = (u16 *)(dev->iobase); + volatile u16 *hw_addr_cmd = (u16 *)(dev->iobase + 2); + + *hw_addr_cmd = offset | ((BE1 | BE0) << (offset & 0x02)); + + return *hw_addr; +} + +static void ks_wrreg8(struct eth_device *dev, u16 offset, u8 val) +{ + volatile u16 *hw_addr = (u16 *)(dev->iobase); + volatile u16 *hw_addr_cmd = (u16 *)(dev->iobase + 2); + + u8 shift_bit = (offset & 0x03); + u16 value_write = (u16)(val << ((offset & 1) << 3)); + + *hw_addr_cmd = (u16)offset | (BE0 << shift_bit); + *hw_addr = value_write; +} + +static void ks_wrreg16(struct eth_device *dev, u16 offset, u16 val) +{ + volatile u16 *hw_addr = (u16 *)(dev->iobase); + volatile u16 *hw_addr_cmd = (u16 *)(dev->iobase + 2); + + *hw_addr_cmd = offset | ((BE1 | BE0) << (offset & 0x02)); + *hw_addr = val; +} + +/* + * ks_inblk - read a block of data from QMU. This is called after sudo DMA mode + * enabled. + * @ks: The chip state + * @wptr: buffer address to save data + * @len: length in byte to read + * + */ +static inline void ks_inblk(struct eth_device *dev, u16 *wptr, u32 len) +{ + volatile u16 *hw_addr = (u16 *)(dev->iobase); + u16 tmp; + len >>= 1; + while (len--) + *wptr++ = *hw_addr; +} + +/* + * ks_outblk - write data to QMU. This is called after sudo DMA mode enabled. + * @ks: The chip information + * @wptr: buffer address + * @len: length in byte to write + * + */ +static inline void ks_outblk(struct eth_device *dev, u16 *wptr, u32 len) +{ + volatile u16 *hw_addr = (u16 *)(dev->iobase); + len >>= 1; + while (len--) + *hw_addr = *wptr++; +} + +static void ks_disable_int(struct eth_device *dev) +{ + ks_wrreg16(dev, KS_IER, 0x0000); +} + +static void ks_enable_int(struct eth_device *dev) +{ + ks_wrreg16(dev, KS_IER, ks->rc_ier); +} + +static void ks_set_powermode(struct eth_device *dev, unsigned pwrmode) +{ + unsigned pmecr; + + ks_rdreg16(dev, KS_GRR); + pmecr = ks_rdreg16(dev, KS_PMECR); + pmecr &= ~PMECR_PM_MASK; + pmecr |= pwrmode; + + ks_wrreg16(dev, KS_PMECR, pmecr); +} + +/* + * ks_read_config - read chip configuration of bus width. + * @ks: The chip information + * + */ +static void ks_read_config(struct eth_device *dev) +{ + u16 reg_data = 0; + + /* Regardless of bus width, 8 bit read should always work.*/ + reg_data = ks_rdreg8(dev, KS_CCR) & 0x00FF; + reg_data |= ks_rdreg8(dev, KS_CCR+1) << 8; + + /* addr/data bus are multiplexed */ + ks->sharedbus = (reg_data & CCR_SHARED) == CCR_SHARED; + + /* + * There are garbage data when reading data from QMU, + * depending on bus-width. + */ + if (reg_data & CCR_8BIT) { + ks->bus_width = ENUM_BUS_8BIT; + ks->extra_byte = 1; + } else if (reg_data & CCR_16BIT) { + ks->bus_width = ENUM_BUS_16BIT; + ks->extra_byte = 2; + } else { + ks->bus_width = ENUM_BUS_32BIT; + ks->extra_byte = 4; + } +} + +/* + * ks_soft_reset - issue one of the soft reset to the device + * @ks: The device state. + * @op: The bit(s) to set in the GRR + * + * Issue the relevant soft-reset command to the device's GRR register + * specified by @op. + * + * Note, the delays are in there as a caution to ensure that the reset + * has time to take effect and then complete. Since the datasheet does + * not currently specify the exact sequence, we have chosen something + * that seems to work with our device. + */ +static void ks_soft_reset(struct eth_device *dev, unsigned op) +{ + /* Disable interrupt first */ + ks_wrreg16(dev, KS_IER, 0x0000); + ks_wrreg16(dev, KS_GRR, op); + mdelay(10); /* wait a short time to effect reset */ + ks_wrreg16(dev, KS_GRR, 0); + mdelay(1); /* wait for condition to clear */ +} + +void ks_enable_qmu(struct eth_device *dev) +{ + u16 w; + + w = ks_rdreg16(dev, KS_TXCR); + + /* Enables QMU Transmit (TXCR). */ + ks_wrreg16(dev, KS_TXCR, w | TXCR_TXE); + + /* + * RX Frame Count Threshold Enable and Auto-Dequeue RXQ Frame + * Enable + */ + w = ks_rdreg16(dev, KS_RXQCR); + ks_wrreg16(dev, KS_RXQCR, w | RXQCR_RXFCTE); + + /* Enables QMU Receive (RXCR1). */ + w = ks_rdreg16(dev, KS_RXCR1); + ks_wrreg16(dev, KS_RXCR1, w | RXCR1_RXE); +} + +static void ks_disable_qmu(struct eth_device *dev) +{ + u16 w; + + w = ks_rdreg16(dev, KS_TXCR); + + /* Disables QMU Transmit (TXCR). */ + w &= ~TXCR_TXE; + ks_wrreg16(dev, KS_TXCR, w); + + /* Disables QMU Receive (RXCR1). */ + w = ks_rdreg16(dev, KS_RXCR1); + w &= ~RXCR1_RXE ; + ks_wrreg16(dev, KS_RXCR1, w); + +} + +static inline void ks_read_qmu(struct eth_device *dev, u16 *buf, u32 len) +{ + u32 r = ks->extra_byte & 0x1 ; + u32 w = ks->extra_byte - r; + + /* 1. set sudo DMA mode */ + ks_wrreg16(dev, KS_RXFDPR, RXFDPR_RXFPAI); + ks_wrreg8(dev, KS_RXQCR, (ks->rc_rxqcr | RXQCR_SDA) & 0xff); + + /* + * 2. read prepend data + * + * read 4 + extra bytes and discard them. + * extra bytes for dummy, 2 for status, 2 for len + */ + + if ((r)) + ks_rdreg8(dev, 0); + + ks_inblk(dev, buf, w + 2 + 2); + + /* 3. read pkt data */ + ks_inblk(dev, buf, ALIGN(len, 4)); + + /* 4. reset sudo DMA Mode */ + ks_wrreg8(dev, KS_RXQCR, ks->rc_rxqcr); +} + +static void ks_rcv(struct eth_device *dev, uchar **pv_data) +{ + u32 i; + struct type_frame_head *frame_hdr = ks->frame_head_info; + + ks->frame_cnt = ks_rdreg16(dev, KS_RXFCTR) >> 8; + + /* read all header information */ + for (i = 0; i < ks->frame_cnt; i++) { + /* Checking Received packet status */ + frame_hdr->sts = ks_rdreg16(dev, KS_RXFHSR); + /* Get packet len from hardware */ + frame_hdr->len = ks_rdreg16(dev, KS_RXFHBCR); + frame_hdr++; + } + + frame_hdr = ks->frame_head_info; + while (ks->frame_cnt--) { + if ((frame_hdr->sts & RXFSHR_RXFV) && + (frame_hdr->len < RX_BUF_SIZE) && frame_hdr->len) { + + /* read data block including CRC 4 bytes */ + ks_read_qmu(dev, (u16 *)(*pv_data), frame_hdr->len); + + /* NetRxPackets buffer size is ok (*pv_data pointer) */ + NetReceive(*pv_data, frame_hdr->len); + pv_data++; + } else { + ks_wrreg16(dev, KS_RXQCR, (ks->rc_rxqcr | RXQCR_RRXEF)); + printf(DRIVERNAME + ": bad packet. \n"); + } + frame_hdr++; + } +} + +/* + * ks_read_selftest - read the selftest memory info. + * @ks: The device state + * + * Read and check the TX/RX memory selftest information. + */ +static int ks_read_selftest(struct eth_device *dev) +{ + unsigned both_done = MBIR_TXMBF | MBIR_RXMBF; + int ret = 0; + unsigned rd; + + rd = ks_rdreg16(dev, KS_MBIR); + + if ((rd & both_done) != both_done) { + printf(DRIVERNAME ": Memory selftest not finished\n"); + return 0; + } + + if (rd & MBIR_TXMBFA) { + printf(DRIVERNAME ": TX memory selftest fails\n"); + ret |= 1; + } + + if (rd & MBIR_RXMBFA) { + printf(DRIVERNAME ": RX memory selftest fails\n"); + ret |= 2; + } + + printf(DRIVERNAME ": the selftest passes\n"); + return ret; +} + +static void ks_setup(struct eth_device *dev) +{ + u16 w; + + /* + * Configure QMU Transmit + */ + + /* Setup Transmit Frame Data Pointer Auto-Increment (TXFDPR) */ + ks_wrreg16(dev, KS_TXFDPR, TXFDPR_TXFPAI); + + /* Setup Receive Frame Data Pointer Auto-Increment */ + ks_wrreg16(dev, KS_RXFDPR, RXFDPR_RXFPAI); + + /* Setup Receive Frame Threshold - 1 frame (RXFCTFC) */ + ks_wrreg16(dev, KS_RXFCTR, 1 & RXFCTR_THRESHOLD_MASK); + + /* Setup RxQ Command Control (RXQCR) */ + ks->rc_rxqcr = RXQCR_CMD_CNTL; + ks_wrreg16(dev, KS_RXQCR, ks->rc_rxqcr); + + /* + * set the force mode to half duplex, default is full duplex + * because if the auto-negotiation fails, most switch uses + * half-duplex. + */ + w = ks_rdreg16(dev, KS_P1MBCR); + w &= ~P1MBCR_FORCE_FDX; + ks_wrreg16(dev, KS_P1MBCR, w); + + w = TXCR_TXFCE | TXCR_TXPE | TXCR_TXCRC | TXCR_TCGIP; + ks_wrreg16(dev, KS_TXCR, w); + + w = RXCR1_RXFCE | RXCR1_RXBE | RXCR1_RXUE | RXCR1_RXME | RXCR1_RXIPFCC; + + /* Normal mode */ + w |= RXCR1_RXPAFMA; + + ks_wrreg16(dev, KS_RXCR1, w); +} + +static void ks_setup_int(struct eth_device *dev) +{ + ks->rc_ier = 0x00; + + /* Clear the interrupts status of the hardware. */ + ks_wrreg16(dev, KS_ISR, 0xffff); + + /* Enables the interrupts of the hardware. */ + ks->rc_ier = (IRQ_LCI | IRQ_TXI | IRQ_RXI); +} + +static int ks8851_mll_detect_chip(struct eth_device *dev) +{ + unsigned short val, i; + + ks_read_config(dev); + + if (ks->bus_width == ENUM_BUS_16BIT) + printf(DRIVERNAME ": ENUM_BUS_16BIT\n"); + else + printf(DRIVERNAME ": no 16 bit bus\n"); + + + val = ks_rdreg16(dev, KS_CIDER); + + if (val == 0xffff) { + /* Special case -- no chip present */ + printf(DRIVERNAME ": is chip mounted ?\n"); + return -1; + } else if ((val & 0xfff0) != CIDER_ID) { + printf(DRIVERNAME ": Invalid chip id 0x%04lx\n", val); + return -1; + } + + printf("Read back KS8851 id 0x%x\n", val); + + /* only one entry in the table */ + val &= 0xfff0; + for (i = 0; chip_ids[i].id != 0; i++) { + if (chip_ids[i].id == val) + break; + } + if (!chip_ids[i].id) { + printf(DRIVERNAME ": Unknown chip ID %04x\n", val); + return -1; + } + + dev->priv = (void *)&chip_ids[i]; + + return 0; +} + +static void ks8851_mll_reset(struct eth_device *dev) +{ + /* wake up powermode to normal mode */ + ks_set_powermode(dev, PMECR_PM_NORMAL); + mdelay(1); /* wait for normal mode to take effect */ + + /* Disable interrupt and reset */ + ks_soft_reset(dev, GRR_GSR); + + /* turn off the IRQs and ack any outstanding */ + ks_wrreg16(dev, KS_IER, 0x0000); + ks_wrreg16(dev, KS_ISR, 0xffff); + + /* shutdown RX/TX QMU */ + ks_disable_qmu(dev); +} + +static void ks8851_mll_handle_mac_address(struct eth_device *dev) +{ + u16 addrh, addrm, addrl; + uchar *m = dev->enetaddr; + + addrh = m[1] | (m[0] << 8); + addrm = m[3] | (m[2] << 8); + addrl = m[5] | (m[4] << 8); + + ks_wrreg16(dev, KS_MARH, addrh); + ks_wrreg16(dev, KS_MARM, addrm); + ks_wrreg16(dev, KS_MARL, addrl); + + printf(DRIVERNAME ": MAC %pM\n", m); +} + +static void ks8851_mll_phy_configure(struct eth_device *dev) +{ + ks_setup(dev); + ks_setup_int(dev); + u16 data; + + /* Probing the phy */ + data = ks_rdreg16(dev, KS_OBCR); + ks_wrreg16(dev, KS_OBCR, data | OBCR_ODS_16MA); + + printf(DRIVERNAME ": phy initialized\n"); +} + + +static void ks8851_mll_enable(struct eth_device *dev) +{ + ks_wrreg16(dev, KS_ISR, 0xffff); + ks_enable_int(dev); + ks_enable_qmu(dev); +} + +static int ks8851_mll_init(struct eth_device *dev, bd_t * bd) +{ + struct chip_id *id = dev->priv; + + printf(DRIVERNAME ": detected %s controller\n", id->name); + + if (ks_read_selftest(dev)) { + printf(DRIVERNAME ": Selftest failed\n"); + return -1; + } + + ks8851_mll_reset(dev); + + /* Configure the PHY, initialize the link state */ + ks8851_mll_phy_configure(dev); + + /* static allocation of private informations */ + ks->frame_head_info = fr_h_i; + + ks8851_mll_handle_mac_address(dev); + + /* Turn on Tx + Rx */ + ks8851_mll_enable(dev); + + return 0; +} + +static void ks_write_qmu(struct eth_device *dev, u8 *pdata, u16 len) +{ + /* start header at txb[0] to align txw entries */ + ks->txh.txw[0] = 0; + ks->txh.txw[1] = cpu_to_le16(len); + + /* 1. set sudo-DMA mode */ + ks_wrreg8(dev, KS_RXQCR, (ks->rc_rxqcr | RXQCR_SDA) & 0xff); + /* 2. write status/lenth info */ + ks_outblk(dev, ks->txh.txw, 4); + /* 3. write pkt data */ + ks_outblk(dev, (u16 *)pdata, ALIGN(len, 4)); + /* 4. reset sudo-DMA mode */ + ks_wrreg8(dev, KS_RXQCR, ks->rc_rxqcr); + /* 5. Enqueue Tx(move the pkt from TX buffer into TXQ) */ + ks_wrreg16(dev, KS_TXQCR, TXQCR_METFE); + /* 6. wait until TXQCR_METFE is auto-cleared */ + while (ks_rdreg16(dev, KS_TXQCR) & TXQCR_METFE) + ; +} + +static int ks8851_mll_send(struct eth_device *dev, + volatile void *packet, int length) +{ + u8 *data = (u8 *)packet; + u16 tmplen = (u16) length; + u32 status = 0; + + u16 retv; + + /* + * Extra space are required: + * 4 byte for alignment, 4 for status/length, 4 for CRC + */ + retv = ks_rdreg16(dev, KS_TXMIR) & 0x1fff; + if (retv >= tmplen + 12) + ks_write_qmu(dev, data, tmplen); + else + status = 1; + + if (!status) + return 0; + + printf(DRIVERNAME ": failed to send packet: %s%s\n", + status & 1 ? "No buffer " : "", + status & 2 ? "Other error" : ""); + + return -1; +} + +static void ks8851_mll_halt(struct eth_device *dev) +{ + ks8851_mll_reset(dev); +} + +/* + * Maximum receive ring size; that is, the number of packets + * we can buffer before overflow happens. Basically, this just + * needs to be enough to prevent a packet being discarded while + * we are processing the previous one. + */ +static int ks8851_mll_rx(struct eth_device *dev) +{ + u16 status; + + status = ks_rdreg16(dev, KS_ISR); + + ks_wrreg16(dev, KS_ISR, status); + + if ((status & IRQ_RXI)) + ks_rcv(dev, (uchar **)NetRxPackets); + + if ((status & IRQ_LDI)) { + u16 pmecr = ks_rdreg16(dev, KS_PMECR); + pmecr &= ~PMECR_WKEVT_MASK; + ks_wrreg16(dev, KS_PMECR, pmecr | PMECR_WKEVT_LINK); + } + + return 0; +} + +int ks8851_mll_register(u8 dev_num, int base_addr) +{ + unsigned short addrl, addrm, addrh; + struct eth_device *dev; + + dev = malloc(sizeof(*dev)); + if (!dev) { + free(dev); + return -1; + } + memset(dev, 0, sizeof(*dev)); + + dev->iobase = base_addr; + + ks = &ks_str; + + /* Try to detect chip. Will fail if not present. */ + if (ks8851_mll_detect_chip(dev)) { + free(dev); + return 0; + } + + addrh = ks_rdreg16(dev, KS_MARH); + addrm = ks_rdreg16(dev, KS_MARM); + addrl = ks_rdreg16(dev, KS_MARL); + dev->enetaddr[0] = addrh >> 8; + dev->enetaddr[1] = addrh; + dev->enetaddr[2] = addrm >> 8; + dev->enetaddr[3] = addrm; + dev->enetaddr[4] = addrl >> 8; + dev->enetaddr[5] = addrl; + + dev->init = ks8851_mll_init; + dev->halt = ks8851_mll_halt; + dev->send = ks8851_mll_send; + dev->recv = ks8851_mll_rx; + sprintf(dev->name, "%s-%hu", DRIVERNAME, dev_num); + + eth_register(dev); + return 1; +} diff --git a/drivers/net/ks8851_mll.h b/drivers/net/ks8851_mll.h new file mode 100644 index 0000000..0a1d2d3 --- /dev/null +++ b/drivers/net/ks8851_mll.h @@ -0,0 +1,358 @@ +/** + * drivers/net/ks8851_mll.c + * Copyright (c) 2009 Micrel Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ +/* + * modified by + * (c) 2011 Bticino s.p.a, Roberto Cerati roberto.cerati@bticino.it + */ +/** + * Supports: + * KS8851 16bit MLL chip from Micrel Inc. + */ +#ifndef _KS8851_MLL_H_ +#define _KS8851_MLL_H_ + +#include <linux/types.h> + +#define DRIVERNAME "ks8851_mll" + +/* MAC address registers */ +#define KS_MARL 0x10 +#define KS_MARM 0x12 +#define KS_MARH 0x14 + +#define KS_OBCR 0x20 +#define OBCR_ODS_16MA (1 << 6) + +#define KS_EEPCR 0x22 +#define EEPCR_EESA (1 << 4) +#define EEPCR_EESB (1 << 3) +#define EEPCR_EEDO (1 << 2) +#define EEPCR_EESCK (1 << 1) +#define EEPCR_EECS (1 << 0) + +#define KS_MBIR 0x24 +#define MBIR_TXMBF (1 << 12) +#define MBIR_TXMBFA (1 << 11) +#define MBIR_RXMBF (1 << 4) +#define MBIR_RXMBFA (1 << 3) + +#define KS_GRR 0x26 +#define GRR_QMU (1 << 1) +#define GRR_GSR (1 << 0) + +#define KS_WFCR 0x2A +#define WFCR_MPRXE (1 << 7) +#define WFCR_WF3E (1 << 3) +#define WFCR_WF2E (1 << 2) +#define WFCR_WF1E (1 << 1) +#define WFCR_WF0E (1 << 0) + +#define KS_WF0CRC0 0x30 +#define KS_WF0CRC1 0x32 +#define KS_WF0BM0 0x34 +#define KS_WF0BM1 0x36 +#define KS_WF0BM2 0x38 +#define KS_WF0BM3 0x3A + +#define KS_WF1CRC0 0x40 +#define KS_WF1CRC1 0x42 +#define KS_WF1BM0 0x44 +#define KS_WF1BM1 0x46 +#define KS_WF1BM2 0x48 +#define KS_WF1BM3 0x4A + +#define KS_WF2CRC0 0x50 +#define KS_WF2CRC1 0x52 +#define KS_WF2BM0 0x54 +#define KS_WF2BM1 0x56 +#define KS_WF2BM2 0x58 +#define KS_WF2BM3 0x5A + +#define KS_WF3CRC0 0x60 +#define KS_WF3CRC1 0x62 +#define KS_WF3BM0 0x64 +#define KS_WF3BM1 0x66 +#define KS_WF3BM2 0x68 +#define KS_WF3BM3 0x6A + +#define KS_TXCR 0x70 +#define TXCR_TCGICMP (1 << 8) +#define TXCR_TCGUDP (1 << 7) +#define TXCR_TCGTCP (1 << 6) +#define TXCR_TCGIP (1 << 5) +#define TXCR_FTXQ (1 << 4) +#define TXCR_TXFCE (1 << 3) +#define TXCR_TXPE (1 << 2) +#define TXCR_TXCRC (1 << 1) +#define TXCR_TXE (1 << 0) + +#define KS_TXSR 0x72 +#define TXSR_TXLC (1 << 13) +#define TXSR_TXMC (1 << 12) +#define TXSR_TXFID_MASK (0x3f << 0) +#define TXSR_TXFID_SHIFT (0) +#define TXSR_TXFID_GET(_v) (((_v) >> 0) & 0x3f) + + +#define KS_RXCR1 0x74 +#define RXCR1_FRXQ (1 << 15) +#define RXCR1_RXUDPFCC (1 << 14) +#define RXCR1_RXTCPFCC (1 << 13) +#define RXCR1_RXIPFCC (1 << 12) +#define RXCR1_RXPAFMA (1 << 11) +#define RXCR1_RXFCE (1 << 10) +#define RXCR1_RXEFE (1 << 9) +#define RXCR1_RXMAFMA (1 << 8) +#define RXCR1_RXBE (1 << 7) +#define RXCR1_RXME (1 << 6) +#define RXCR1_RXUE (1 << 5) +#define RXCR1_RXAE (1 << 4) +#define RXCR1_RXINVF (1 << 1) +#define RXCR1_RXE (1 << 0) +#define RXCR1_FILTER_MASK (RXCR1_RXINVF | RXCR1_RXAE | \ + RXCR1_RXMAFMA | RXCR1_RXPAFMA) + +#define KS_RXCR2 0x76 +#define RXCR2_SRDBL_MASK (0x7 << 5) +#define RXCR2_SRDBL_SHIFT (5) +#define RXCR2_SRDBL_4B (0x0 << 5) +#define RXCR2_SRDBL_8B (0x1 << 5) +#define RXCR2_SRDBL_16B (0x2 << 5) +#define RXCR2_SRDBL_32B (0x3 << 5) +/* #define RXCR2_SRDBL_FRAME (0x4 << 5) */ +#define RXCR2_IUFFP (1 << 4) +#define RXCR2_RXIUFCEZ (1 << 3) +#define RXCR2_UDPLFE (1 << 2) +#define RXCR2_RXICMPFCC (1 << 1) +#define RXCR2_RXSAF (1 << 0) + +#define KS_TXMIR 0x78 + +#define KS_RXFHSR 0x7C +#define RXFSHR_RXFV (1 << 15) +#define RXFSHR_RXICMPFCS (1 << 13) +#define RXFSHR_RXIPFCS (1 << 12) +#define RXFSHR_RXTCPFCS (1 << 11) +#define RXFSHR_RXUDPFCS (1 << 10) +#define RXFSHR_RXBF (1 << 7) +#define RXFSHR_RXMF (1 << 6) +#define RXFSHR_RXUF (1 << 5) +#define RXFSHR_RXMR (1 << 4) +#define RXFSHR_RXFT (1 << 3) +#define RXFSHR_RXFTL (1 << 2) +#define RXFSHR_RXRF (1 << 1) +#define RXFSHR_RXCE (1 << 0) +#define RXFSHR_ERR (RXFSHR_RXCE | RXFSHR_RXRF |\ + RXFSHR_RXFTL | RXFSHR_RXMR |\ + RXFSHR_RXICMPFCS | RXFSHR_RXIPFCS |\ + RXFSHR_RXTCPFCS) +#define KS_RXFHBCR 0x7E +#define RXFHBCR_CNT_MASK 0x0FFF + +#define KS_TXQCR 0x80 +#define TXQCR_AETFE (1 << 2) +#define TXQCR_TXQMAM (1 << 1) +#define TXQCR_METFE (1 << 0) + +#define KS_RXQCR 0x82 +#define RXQCR_RXDTTS (1 << 12) +#define RXQCR_RXDBCTS (1 << 11) +#define RXQCR_RXFCTS (1 << 10) +#define RXQCR_RXIPHTOE (1 << 9) +#define RXQCR_RXDTTE (1 << 7) +#define RXQCR_RXDBCTE (1 << 6) +#define RXQCR_RXFCTE (1 << 5) +#define RXQCR_ADRFE (1 << 4) +#define RXQCR_SDA (1 << 3) +#define RXQCR_RRXEF (1 << 0) +#define RXQCR_CMD_CNTL (RXQCR_RXFCTE|RXQCR_ADRFE) + +#define KS_TXFDPR 0x84 +#define TXFDPR_TXFPAI (1 << 14) +#define TXFDPR_TXFP_MASK (0x7ff << 0) +#define TXFDPR_TXFP_SHIFT (0) + +#define KS_RXFDPR 0x86 +#define RXFDPR_RXFPAI (1 << 14) + +#define KS_RXDTTR 0x8C +#define KS_RXDBCTR 0x8E + +#define KS_IER 0x90 +#define KS_ISR 0x92 +#define IRQ_LCI (1 << 15) +#define IRQ_TXI (1 << 14) +#define IRQ_RXI (1 << 13) +#define IRQ_RXOI (1 << 11) +#define IRQ_TXPSI (1 << 9) +#define IRQ_RXPSI (1 << 8) +#define IRQ_TXSAI (1 << 6) +#define IRQ_RXWFDI (1 << 5) +#define IRQ_RXMPDI (1 << 4) +#define IRQ_LDI (1 << 3) +#define IRQ_EDI (1 << 2) +#define IRQ_SPIBEI (1 << 1) +#define IRQ_DEDI (1 << 0) + +#define KS_RXFCTR 0x9C +#define RXFCTR_THRESHOLD_MASK 0x00FF + +#define KS_RXFC 0x9D +#define RXFCTR_RXFC_MASK (0xff << 8) +#define RXFCTR_RXFC_SHIFT (8) +#define RXFCTR_RXFC_GET(_v) (((_v) >> 8) & 0xff) +#define RXFCTR_RXFCT_MASK (0xff << 0) +#define RXFCTR_RXFCT_SHIFT (0) + +#define KS_TXNTFSR 0x9E + +#define KS_MAHTR0 0xA0 +#define KS_MAHTR1 0xA2 +#define KS_MAHTR2 0xA4 +#define KS_MAHTR3 0xA6 + +#define KS_FCLWR 0xB0 +#define KS_FCHWR 0xB2 +#define KS_FCOWR 0xB4 + +#define KS_CIDER 0xC0 +#define CIDER_ID 0x8870 +#define CIDER_REV_MASK (0x7 << 1) +#define CIDER_REV_SHIFT (1) +#define CIDER_REV_GET(_v) (((_v) >> 1) & 0x7) + +#define KS_CGCR 0xC6 +#define KS_IACR 0xC8 +#define IACR_RDEN (1 << 12) +#define IACR_TSEL_MASK (0x3 << 10) +#define IACR_TSEL_SHIFT (10) +#define IACR_TSEL_MIB (0x3 << 10) +#define IACR_ADDR_MASK (0x1f << 0) +#define IACR_ADDR_SHIFT (0) + +#define KS_IADLR 0xD0 +#define KS_IAHDR 0xD2 + +#define KS_PMECR 0xD4 +#define PMECR_PME_DELAY (1 << 14) +#define PMECR_PME_POL (1 << 12) +#define PMECR_WOL_WAKEUP (1 << 11) +#define PMECR_WOL_MAGICPKT (1 << 10) +#define PMECR_WOL_LINKUP (1 << 9) +#define PMECR_WOL_ENERGY (1 << 8) +#define PMECR_AUTO_WAKE_EN (1 << 7) +#define PMECR_WAKEUP_NORMAL (1 << 6) +#define PMECR_WKEVT_MASK (0xf << 2) +#define PMECR_WKEVT_SHIFT (2) +#define PMECR_WKEVT_GET(_v) (((_v) >> 2) & 0xf) +#define PMECR_WKEVT_ENERGY (0x1 << 2) +#define PMECR_WKEVT_LINK (0x2 << 2) +#define PMECR_WKEVT_MAGICPKT (0x4 << 2) +#define PMECR_WKEVT_FRAME (0x8 << 2) +#define PMECR_PM_MASK (0x3 << 0) +#define PMECR_PM_SHIFT (0) +#define PMECR_PM_NORMAL (0x0 << 0) +#define PMECR_PM_ENERGY (0x1 << 0) +#define PMECR_PM_SOFTDOWN (0x2 << 0) +#define PMECR_PM_POWERSAVE (0x3 << 0) + +/* Standard MII PHY data */ +#define KS_P1MBCR 0xE4 +#define P1MBCR_FORCE_FDX (1 << 8) + +#define KS_P1MBSR 0xE6 +#define P1MBSR_AN_COMPLETE (1 << 5) +#define P1MBSR_AN_CAPABLE (1 << 3) +#define P1MBSR_LINK_UP (1 << 2) + +#define KS_PHY1ILR 0xE8 +#define KS_PHY1IHR 0xEA +#define KS_P1ANAR 0xEC +#define KS_P1ANLPR 0xEE + +#define KS_P1SCLMD 0xF4 +#define P1SCLMD_LEDOFF (1 << 15) +#define P1SCLMD_TXIDS (1 << 14) +#define P1SCLMD_RESTARTAN (1 << 13) +#define P1SCLMD_DISAUTOMDIX (1 << 10) +#define P1SCLMD_FORCEMDIX (1 << 9) +#define P1SCLMD_AUTONEGEN (1 << 7) +#define P1SCLMD_FORCE100 (1 << 6) +#define P1SCLMD_FORCEFDX (1 << 5) +#define P1SCLMD_ADV_FLOW (1 << 4) +#define P1SCLMD_ADV_100BT_FDX (1 << 3) +#define P1SCLMD_ADV_100BT_HDX (1 << 2) +#define P1SCLMD_ADV_10BT_FDX (1 << 1) +#define P1SCLMD_ADV_10BT_HDX (1 << 0) + +#define KS_P1CR 0xF6 +#define P1CR_HP_MDIX (1 << 15) +#define P1CR_REV_POL (1 << 13) +#define P1CR_OP_100M (1 << 10) +#define P1CR_OP_FDX (1 << 9) +#define P1CR_OP_MDI (1 << 7) +#define P1CR_AN_DONE (1 << 6) +#define P1CR_LINK_GOOD (1 << 5) +#define P1CR_PNTR_FLOW (1 << 4) +#define P1CR_PNTR_100BT_FDX (1 << 3) +#define P1CR_PNTR_100BT_HDX (1 << 2) +#define P1CR_PNTR_10BT_FDX (1 << 1) +#define P1CR_PNTR_10BT_HDX (1 << 0) + +/* TX Frame control */ + +#define TXFR_TXIC (1 << 15) +#define TXFR_TXFID_MASK (0x3f << 0) +#define TXFR_TXFID_SHIFT (0) + +#define KS_P1SR 0xF8 +#define P1SR_HP_MDIX (1 << 15) +#define P1SR_REV_POL (1 << 13) +#define P1SR_OP_100M (1 << 10) +#define P1SR_OP_FDX (1 << 9) +#define P1SR_OP_MDI (1 << 7) +#define P1SR_AN_DONE (1 << 6) +#define P1SR_LINK_GOOD (1 << 5) +#define P1SR_PNTR_FLOW (1 << 4) +#define P1SR_PNTR_100BT_FDX (1 << 3) +#define P1SR_PNTR_100BT_HDX (1 << 2) +#define P1SR_PNTR_10BT_FDX (1 << 1) +#define P1SR_PNTR_10BT_HDX (1 << 0) + +#define ENUM_BUS_NONE 0 +#define ENUM_BUS_8BIT 1 +#define ENUM_BUS_16BIT 2 +#define ENUM_BUS_32BIT 3 + +#define MAX_MCAST_LST 32 +#define HW_MCAST_SIZE 8 +#define MAC_ADDR_LEN 6 + +/* Chip ID values */ + +struct chip_id { + u16 id; + char *name; +}; + +static const struct chip_id chip_ids[] = { + { CIDER_ID, "KSZ8851" }, + { 0, NULL }, +}; + +#endif
Dear Raffaele Recalcati,
In message 1300267039-3607-1-git-send-email-lamiaposta71@gmail.com you wrote:
We only add code to mainline that has users in mainline. Please resubmit with the patches that add support for this board. Thanks.
- Micrel KS8851_MLL 16bit Network driver
- Copyright (c) 2011 Roberto Cerati roberto.cerati@bticino.it
- This program is free software; you can redistribute it and/or modify
- it under the terms of the GNU General Public License version 2 as
- published by the Free Software Foundation.
Also, U-Boot requires the v2 or later clause, please see bullet # 3 at http://www.denx.de/wiki/view/U-Boot/Patches#Attributing_Code_Copyrights_Sign
- volatile u16 *hw_addr = (u16 *)(dev->iobase);
- volatile u16 *hw_addr_cmd = (u16 *)(dev->iobase + 2);
- u16 data;
- u8 shift_bit = offset & 0x03;
- u8 shift_data = (offset & 1) << 3;
- *hw_addr_cmd = offset | (u16)(BE0 << shift_bit);
- data = *hw_addr;
And please get rid of all these volatile declarations and use proper I/O accessors instead.
Before resubmitting, make sure to run checkpatch.
if you're basing this driver on other code, then the copyright info in the header should be preserved from the other files
this is a fairly fat func to be forcing inline. in general, let gcc handle the optimization and only use "inline" when you really really need it.
+int ks8851_mll_register(u8 dev_num, int base_addr) +{ ...
- dev->init = ks8851_mll_init;
- dev->halt = ks8851_mll_halt;
- dev->send = ks8851_mll_send;
- dev->recv = ks8851_mll_rx;
missing dev->write_hwaddr
--- /dev/null +++ b/drivers/net/ks8851_mll.h +static const struct chip_id chip_ids[] = {
- { CIDER_ID, "KSZ8851" },
- { 0, NULL },
headers should not be defining variables. this belongs in the .c file. -mike
Mike Frysinger
Raffaele Recalcati
