[U-Boot] Pull request for mmc sub-system for v2019.07
Hi Tom,
I am not able to setup ssh to denx mmc tree, so use my github for this request-pull, please see whether this is ok for you. Please pull mmc-2019-5-3 for v2019.07-rc1 Travis build: https://travis-ci.org/MrVan/u-boot/builds/527760370
Thanks, Peng.
The following changes since commit b4ee6daad7a2604ca9466b2ba48de86cc27d381f:
Merge tag 'u-boot-imx-20190426' of git://git.denx.de/u-boot-imx (2019-05-01 07:25:51 -0400)
https://github.com/MrVan/u-boot.git tags/mmc-2019-5-3
for you to fetch changes up to 37cb626da25d0d895079c85866d0c2030cd98438:
mmc: sdhci: Add Support for ADMA2 (2019-05-03 20:44:11 +0800)
---------------------------------------------------------------- - adma support for sdhci - a few fixes to fsl_esdhc ---------------------------------------------------------------- Faiz Abbas (2): mmc: sdhci: Move DMA handling to prepare_dma() function mmc: sdhci: Add Support for ADMA2
Ye Li (2): mmc: fsl_esdhc: fix sd/mmc ddr mode clock setting issue mmc: fsl_esdhc: Fix wp_enable issue
drivers/mmc/Kconfig | 14 ++++++++++++ drivers/mmc/fsl_esdhc.c | 41 +++++++++++++++++++++++++-------- drivers/mmc/sdhci.c | 188 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++----------------------------------- include/sdhci.h | 44 +++++++++++++++++++++++++++++++++++ 4 files changed, 233 insertions(+), 54 deletions(-)
On Sat, May 04, 2019 at 03:00:31AM +0000, Peng Fan wrote:
Hi Tom,
Thanks, Peng.
Peng Fan
