[U-Boot] [PATCH 1/3] tools: zynqimage: Align image_size/image_stored_size
Bootrom is not capable to work with non aligned bootloader sizes. SPL with OF_SEPARATE generates non-align images quite often that's why this change is required before OF_SEPARATE enableding.
tools/zynqmpbif.c | 4 ++-- tools/zynqmpimage.c | 1 + 2 files changed, 3 insertions(+), 2 deletions(-)
diff --git a/tools/zynqmpbif.c b/tools/zynqmpbif.c index a33c15e1f018..8c47107c7b94 100644 --- a/tools/zynqmpbif.c +++ b/tools/zynqmpbif.c @@ -425,8 +425,8 @@ static int bif_add_part(struct bif_entry *bf, const char *data, size_t len) if (!bif_output.header->image_offset) bif_output.header->image_offset = cpu_to_le32(bf->offset); - bif_output.header->image_size = cpu_to_le32(len); - bif_output.header->image_stored_size = cpu_to_le32(len); + bif_output.header->image_size = cpu_to_le32(len_padded); + bif_output.header->image_stored_size = cpu_to_le32(len_padded);
bif_output.header->image_attributes &= ~HEADER_CPU_SELECT_MASK; switch (bf->dest_cpu) { diff --git a/tools/zynqmpimage.c b/tools/zynqmpimage.c index 19b2f02ff150..67032aa7b23c 100644 --- a/tools/zynqmpimage.c +++ b/tools/zynqmpimage.c @@ -411,6 +411,7 @@ static void zynqmpimage_set_header(void *ptr, struct stat *sbuf, int ifd, cpu_to_le32((uint32_t)sizeof(struct zynqmp_header)); zynqhdr->image_size = cpu_to_le32(params->file_size - sizeof(struct zynqmp_header)); + zynqhdr->image_size = ROUND(zynqhdr->image_size, 4); zynqhdr->image_stored_size = zynqhdr->image_size; zynqhdr->image_load = 0xfffc0000; if (params->eflag)
Build warning was added by: "fdt: Add warning about CONFIG_OF_EMBED" (sha1: 841d5fbae4e993476fa87d8933db0cd58d3c2d41)
ZynqMP mini configurations are not moved yet and it is questionable if make sense to move them too.
Depends on the patch: "tools: zynqimage: Align image_size/image_stored_size"
--- configs/avnet_ultra96_rev1_defconfig | 1 - configs/xilinx_zynqmp_zc1232_revA_defconfig | 1 - configs/xilinx_zynqmp_zc1254_revA_defconfig | 1 - configs/xilinx_zynqmp_zc1275_revA_defconfig | 1 - configs/xilinx_zynqmp_zc1275_revB_defconfig | 1 - configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig | 1 - configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig | 1 - configs/xilinx_zynqmp_zc1751_xm017_dc3_defconfig | 1 - configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig | 1 - configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig | 1 - configs/xilinx_zynqmp_zcu100_revC_defconfig | 1 - configs/xilinx_zynqmp_zcu102_rev1_0_defconfig | 1 - configs/xilinx_zynqmp_zcu102_revA_defconfig | 1 - configs/xilinx_zynqmp_zcu102_revB_defconfig | 1 - configs/xilinx_zynqmp_zcu104_revA_defconfig | 1 - configs/xilinx_zynqmp_zcu104_revC_defconfig | 1 - configs/xilinx_zynqmp_zcu106_revA_defconfig | 1 - configs/xilinx_zynqmp_zcu111_revA_defconfig | 1 - 18 files changed, 18 deletions(-)
diff --git a/configs/avnet_ultra96_rev1_defconfig b/configs/avnet_ultra96_rev1_defconfig index 77389732a6ae..896de78b34e4 100644 --- a/configs/avnet_ultra96_rev1_defconfig +++ b/configs/avnet_ultra96_rev1_defconfig @@ -39,7 +39,6 @@ CONFIG_CMD_TIME=y CONFIG_CMD_TIMER=y CONFIG_CMD_EXT4_WRITE=y CONFIG_SPL_OF_CONTROL=y -CONFIG_OF_EMBED=y CONFIG_DEFAULT_DEVICE_TREE="avnet-ultra96-rev1" CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM=y diff --git a/configs/xilinx_zynqmp_zc1232_revA_defconfig b/configs/xilinx_zynqmp_zc1232_revA_defconfig index 0acf672a93dc..983e61e48e1a 100644 --- a/configs/xilinx_zynqmp_zc1232_revA_defconfig +++ b/configs/xilinx_zynqmp_zc1232_revA_defconfig @@ -29,7 +29,6 @@ CONFIG_CMD_SF=y CONFIG_CMD_TIME=y CONFIG_CMD_TIMER=y CONFIG_SPL_OF_CONTROL=y -CONFIG_OF_EMBED=y CONFIG_DEFAULT_DEVICE_TREE="zynqmp-zc1232-revA" CONFIG_SPL_DM=y CONFIG_CLK_ZYNQMP=y diff --git a/configs/xilinx_zynqmp_zc1254_revA_defconfig b/configs/xilinx_zynqmp_zc1254_revA_defconfig index 90985d6c92fe..10d3489b6905 100644 --- a/configs/xilinx_zynqmp_zc1254_revA_defconfig +++ b/configs/xilinx_zynqmp_zc1254_revA_defconfig @@ -29,7 +29,6 @@ CONFIG_CMD_SF=y CONFIG_CMD_TIME=y CONFIG_CMD_TIMER=y CONFIG_SPL_OF_CONTROL=y -CONFIG_OF_EMBED=y CONFIG_DEFAULT_DEVICE_TREE="zynqmp-zc1254-revA" CONFIG_SPL_DM=y CONFIG_CLK_ZYNQMP=y diff --git a/configs/xilinx_zynqmp_zc1275_revA_defconfig b/configs/xilinx_zynqmp_zc1275_revA_defconfig index 7d2bd2e53f0f..9ac3dd85f196 100644 --- a/configs/xilinx_zynqmp_zc1275_revA_defconfig +++ b/configs/xilinx_zynqmp_zc1275_revA_defconfig @@ -29,7 +29,6 @@ CONFIG_CMD_SF=y CONFIG_CMD_TIME=y CONFIG_CMD_TIMER=y CONFIG_SPL_OF_CONTROL=y -CONFIG_OF_EMBED=y CONFIG_DEFAULT_DEVICE_TREE="zynqmp-zc1275-revA" CONFIG_SPL_DM=y CONFIG_CLK_ZYNQMP=y diff --git a/configs/xilinx_zynqmp_zc1275_revB_defconfig b/configs/xilinx_zynqmp_zc1275_revB_defconfig index e8e32cbba196..c154b15871f1 100644 --- a/configs/xilinx_zynqmp_zc1275_revB_defconfig +++ b/configs/xilinx_zynqmp_zc1275_revB_defconfig @@ -31,7 +31,6 @@ CONFIG_CMD_SF=y CONFIG_CMD_TIME=y CONFIG_CMD_TIMER=y CONFIG_SPL_OF_CONTROL=y -CONFIG_OF_EMBED=y CONFIG_DEFAULT_DEVICE_TREE="zynqmp-zc1275-revB" CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM=y diff --git a/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig b/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig index 14c051a19ec4..f2caac790a1a 100644 --- a/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig @@ -40,7 +40,6 @@ CONFIG_CMD_TIME=y CONFIG_CMD_TIMER=y CONFIG_CMD_EXT4_WRITE=y CONFIG_SPL_OF_CONTROL=y -CONFIG_OF_EMBED=y CONFIG_DEFAULT_DEVICE_TREE="zynqmp-zc1751-xm015-dc1" CONFIG_ENV_IS_IN_FAT=y CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig b/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig index 4fd495997092..bbbbb8ef4d07 100644 --- a/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig @@ -39,7 +39,6 @@ CONFIG_CMD_TIME=y CONFIG_CMD_TIMER=y CONFIG_CMD_EXT4_WRITE=y CONFIG_SPL_OF_CONTROL=y -CONFIG_OF_EMBED=y CONFIG_DEFAULT_DEVICE_TREE="zynqmp-zc1751-xm016-dc2" CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM=y diff --git a/configs/xilinx_zynqmp_zc1751_xm017_dc3_defconfig b/configs/xilinx_zynqmp_zc1751_xm017_dc3_defconfig index dab36e276a20..d91d511a3af0 100644 --- a/configs/xilinx_zynqmp_zc1751_xm017_dc3_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm017_dc3_defconfig @@ -36,7 +36,6 @@ CONFIG_CMD_TIME=y CONFIG_CMD_TIMER=y CONFIG_CMD_EXT4_WRITE=y CONFIG_SPL_OF_CONTROL=y -CONFIG_OF_EMBED=y CONFIG_DEFAULT_DEVICE_TREE="zynqmp-zc1751-xm017-dc3" CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM=y diff --git a/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig b/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig index 2225a4748787..10e0fca65578 100644 --- a/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig @@ -32,7 +32,6 @@ CONFIG_CMD_TIME=y CONFIG_CMD_TIMER=y CONFIG_CMD_EXT4_WRITE=y CONFIG_SPL_OF_CONTROL=y -CONFIG_OF_EMBED=y CONFIG_DEFAULT_DEVICE_TREE="zynqmp-zc1751-xm018-dc4" CONFIG_ENV_IS_IN_FAT=y CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig b/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig index b95db94d6c83..d14d6c4972b7 100644 --- a/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig @@ -32,7 +32,6 @@ CONFIG_CMD_TIME=y CONFIG_CMD_TIMER=y CONFIG_CMD_EXT4_WRITE=y CONFIG_SPL_OF_CONTROL=y -CONFIG_OF_EMBED=y CONFIG_DEFAULT_DEVICE_TREE="zynqmp-zc1751-xm019-dc5" CONFIG_ENV_IS_IN_FAT=y CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/xilinx_zynqmp_zcu100_revC_defconfig b/configs/xilinx_zynqmp_zcu100_revC_defconfig index 2fe5573e3541..ca96b9ee2aa3 100644 --- a/configs/xilinx_zynqmp_zcu100_revC_defconfig +++ b/configs/xilinx_zynqmp_zcu100_revC_defconfig @@ -39,7 +39,6 @@ CONFIG_CMD_TIME=y CONFIG_CMD_TIMER=y CONFIG_CMD_EXT4_WRITE=y CONFIG_SPL_OF_CONTROL=y -CONFIG_OF_EMBED=y CONFIG_DEFAULT_DEVICE_TREE="zynqmp-zcu100-revC" CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM=y diff --git a/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig b/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig index ef61496407d7..30d3147a7a8b 100644 --- a/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig +++ b/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig @@ -44,7 +44,6 @@ CONFIG_CMD_TIME=y CONFIG_CMD_TIMER=y CONFIG_CMD_EXT4_WRITE=y CONFIG_SPL_OF_CONTROL=y -CONFIG_OF_EMBED=y CONFIG_DEFAULT_DEVICE_TREE="zynqmp-zcu102-rev1.0" CONFIG_ENV_IS_IN_FAT=y CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/xilinx_zynqmp_zcu102_revA_defconfig b/configs/xilinx_zynqmp_zcu102_revA_defconfig index 26d2bdcddf1e..bada5e117317 100644 --- a/configs/xilinx_zynqmp_zcu102_revA_defconfig +++ b/configs/xilinx_zynqmp_zcu102_revA_defconfig @@ -44,7 +44,6 @@ CONFIG_CMD_TIME=y CONFIG_CMD_TIMER=y CONFIG_CMD_EXT4_WRITE=y CONFIG_SPL_OF_CONTROL=y -CONFIG_OF_EMBED=y CONFIG_DEFAULT_DEVICE_TREE="zynqmp-zcu102-revA" CONFIG_ENV_IS_IN_FAT=y CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/xilinx_zynqmp_zcu102_revB_defconfig b/configs/xilinx_zynqmp_zcu102_revB_defconfig index 265fdda6acc4..3c4ac01b220c 100644 --- a/configs/xilinx_zynqmp_zcu102_revB_defconfig +++ b/configs/xilinx_zynqmp_zcu102_revB_defconfig @@ -44,7 +44,6 @@ CONFIG_CMD_TIME=y CONFIG_CMD_TIMER=y CONFIG_CMD_EXT4_WRITE=y CONFIG_SPL_OF_CONTROL=y -CONFIG_OF_EMBED=y CONFIG_DEFAULT_DEVICE_TREE="zynqmp-zcu102-revB" CONFIG_ENV_IS_IN_FAT=y CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/xilinx_zynqmp_zcu104_revA_defconfig b/configs/xilinx_zynqmp_zcu104_revA_defconfig index b4030a627bf5..90fd431df3dd 100644 --- a/configs/xilinx_zynqmp_zcu104_revA_defconfig +++ b/configs/xilinx_zynqmp_zcu104_revA_defconfig @@ -38,7 +38,6 @@ CONFIG_CMD_TIME=y CONFIG_CMD_TIMER=y CONFIG_CMD_EXT4_WRITE=y CONFIG_SPL_OF_CONTROL=y -CONFIG_OF_EMBED=y CONFIG_DEFAULT_DEVICE_TREE="zynqmp-zcu104-revA" CONFIG_ENV_IS_IN_FAT=y CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/xilinx_zynqmp_zcu104_revC_defconfig b/configs/xilinx_zynqmp_zcu104_revC_defconfig index ebf2bba7469b..eb30e2398f2c 100644 --- a/configs/xilinx_zynqmp_zcu104_revC_defconfig +++ b/configs/xilinx_zynqmp_zcu104_revC_defconfig @@ -38,7 +38,6 @@ CONFIG_CMD_TIME=y CONFIG_CMD_TIMER=y CONFIG_CMD_EXT4_WRITE=y CONFIG_SPL_OF_CONTROL=y -CONFIG_OF_EMBED=y CONFIG_DEFAULT_DEVICE_TREE="zynqmp-zcu104-revC" CONFIG_ENV_IS_IN_FAT=y CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/xilinx_zynqmp_zcu106_revA_defconfig b/configs/xilinx_zynqmp_zcu106_revA_defconfig index 3ad1f60e7ccd..9e8eb5f483a2 100644 --- a/configs/xilinx_zynqmp_zcu106_revA_defconfig +++ b/configs/xilinx_zynqmp_zcu106_revA_defconfig @@ -41,7 +41,6 @@ CONFIG_CMD_TIME=y CONFIG_CMD_TIMER=y CONFIG_CMD_EXT4_WRITE=y CONFIG_SPL_OF_CONTROL=y -CONFIG_OF_EMBED=y CONFIG_DEFAULT_DEVICE_TREE="zynqmp-zcu106-revA" CONFIG_ENV_IS_IN_FAT=y CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/xilinx_zynqmp_zcu111_revA_defconfig b/configs/xilinx_zynqmp_zcu111_revA_defconfig index 7ddb0c31c2eb..b8e96042da0a 100644 --- a/configs/xilinx_zynqmp_zcu111_revA_defconfig +++ b/configs/xilinx_zynqmp_zcu111_revA_defconfig @@ -37,7 +37,6 @@ CONFIG_CMD_TIME=y CONFIG_CMD_TIMER=y CONFIG_CMD_EXT4_WRITE=y CONFIG_SPL_OF_CONTROL=y -CONFIG_OF_EMBED=y CONFIG_DEFAULT_DEVICE_TREE="zynqmp-zcu111-revA" CONFIG_ENV_IS_IN_FAT=y CONFIG_NET_RANDOM_ETHADDR=y
Zynq mini configurations are not moved yet and it is questionable if make sense to move them too.
configs/syzygy_hub_defconfig | 1 - configs/zynq_dlc20_rev1_0_defconfig | 1 - 2 files changed, 2 deletions(-)
diff --git a/configs/syzygy_hub_defconfig b/configs/syzygy_hub_defconfig index c4bca0636f3f..75139d93b346 100644 --- a/configs/syzygy_hub_defconfig +++ b/configs/syzygy_hub_defconfig @@ -31,7 +31,6 @@ CONFIG_CMD_USB=y CONFIG_CMD_TFTPPUT=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y -CONFIG_OF_EMBED=y CONFIG_DEFAULT_DEVICE_TREE="zynq-syzygy-hub" CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_FPGA_XILINX=y diff --git a/configs/zynq_dlc20_rev1_0_defconfig b/configs/zynq_dlc20_rev1_0_defconfig index e39bd131ff75..7ead19208f4f 100644 --- a/configs/zynq_dlc20_rev1_0_defconfig +++ b/configs/zynq_dlc20_rev1_0_defconfig @@ -35,7 +35,6 @@ CONFIG_CMD_USB=y CONFIG_CMD_TFTPPUT=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y -CONFIG_OF_EMBED=y CONFIG_DEFAULT_DEVICE_TREE="zynq-dlc20-rev1.0" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y
- zynqhdr->image_size = ROUND(zynqhdr->image_size, 4); zynqhdr->image_stored_size = zynqhdr->image_size; zynqhdr->image_load = 0xfffc0000; if (params->eflag)
Please ignore this part of the patch. I will do this differently with aligning input file.
Thanks, Michal
Michal Simek
Michal Simek
