[U-Boot] [PULL] Please pull u-boot-imx
Hi Tom,
please pull from u-boot-imx, thanks !
The following changes since commit d5abcf94c7123167725fc22ace342f0d455093c1:
ti: boot: Register the MMC controllers in SPL in the same way as in u-boot (2017-03-19 22:17:14 -0400)
git://www.denx.de/git/u-boot-imx.git master
for you to fetch changes up to f479cec3b623778c26b23f66dc28cf33100ce089:
imx: i.mx6q: add the initial support for LogicPD i.MX6Q SOM (2017-04-12 18:59:12 +0200)
---------------------------------------------------------------- Adam Ford (1): imx: i.mx6q: add the initial support for LogicPD i.MX6Q SOM
Breno Lima (1): mx6sabresd: README: Add eMMC boot configuration
Jagan Teki (2): configs: imx6: Select missing BOARD_LATE_INIT MAINTAINERS: Fix ARM FREESCALE IMX files
Lukasz Majewski (1): MCCMON6: defconfig: Add tftp_nor_dtb command for NOR DTB update
Marek Vasut (2): ARM: mxs: Rename M28EVK ARM: mx5: Rename M53EVK
Markus Niebel (1): cmd_mmc: fix arg parsing for setdsr subcmd
Peng Fan (3): imx: mx6slevk: use SPI_BOOT imx: mx6slevk: introduce device tree support imx: mx6slevk: enable more DM drivers
Tim Harvey (8): drivers: net: phy: add MV88E6xx options to Kconfig imx: ventana: add GW5904 support imx: ventana: add GW560x support imx: ventana: add GW5903 support imx: ventana: config: add EMMC boot options imx: ventana: fix GW5903 VDD_ARM rail imx: ventana: add new board configs to MAINTAINERS imx: ventana: config: set MMC env Partition to 1
Vagrant Cascadian (1): Set console speed to 115200 on mx6cuboxi.
Ye Li (1): imx: mx7ulp: Fix SPLL/APLL clock rate calculation issue
Yung-Ching LIN (4): board: advantech: dms-ba16: Add the configuration options for display initialization board: advantech: dms-ba16: add the PMIC configuration support board: advantech: dms-ba16: fix AR8033 reset timing issue board: advantech: dms-ba16: apply the proper register setting to fix the voltage peak issue
MAINTAINERS | 3 +- arch/arm/Kconfig | 4 +- arch/arm/cpu/armv7/mx6/Kconfig | 16 + arch/arm/cpu/armv7/mx7ulp/scg.c | 8 +- arch/arm/dts/Makefile | 2 + arch/arm/dts/imx6q-logicpd.dts | 190 +++++ arch/arm/dts/imx6qdl-logicpd.dtsi | 361 +++++++++ arch/arm/dts/imx6sl-evk.dts | 641 +++++++++++++++ arch/arm/dts/imx6sl-pinfunc.h | 1077 ++++++++++++++++++++++++++ arch/arm/dts/imx6sl.dtsi | 927 ++++++++++++++++++++++ board/advantech/dms-ba16/dms-ba16.c | 60 +- board/{denx => aries}/m28evk/Kconfig | 2 +- board/{denx => aries}/m28evk/MAINTAINERS | 2 +- board/{denx => aries}/m28evk/Makefile | 0 board/{denx => aries}/m28evk/README | 6 +- board/{denx => aries}/m28evk/m28evk.c | 6 +- board/{denx => aries}/m28evk/spl_boot.c | 6 +- board/{denx => aries}/m53evk/Kconfig | 2 +- board/{denx => aries}/m53evk/MAINTAINERS | 2 +- board/{denx => aries}/m53evk/Makefile | 2 +- board/{denx => aries}/m53evk/imximage.cfg | 2 +- board/{denx => aries}/m53evk/m53evk.c | 4 +- board/freescale/mx6sabresd/README | 55 +- board/freescale/mx6slevk/mx6slevk.c | 244 +++--- board/gateworks/gw_ventana/MAINTAINERS | 4 +- board/gateworks/gw_ventana/common.c | 490 +++++++++++- board/gateworks/gw_ventana/common.h | 2 +- board/gateworks/gw_ventana/eeprom.c | 15 +- board/gateworks/gw_ventana/gsc.c | 4 + board/gateworks/gw_ventana/gw_ventana.c | 52 +- board/gateworks/gw_ventana/gw_ventana_spl.c | 56 +- board/gateworks/gw_ventana/ventana_eeprom.h | 3 + board/logicpd/imx6/Kconfig | 12 + board/logicpd/imx6/MAINTAINERS | 6 + board/logicpd/imx6/Makefile | 10 + board/logicpd/imx6/README | 37 + board/logicpd/imx6/imx6logic.c | 184 +++++ board/logicpd/imx6/mx6q_2x_MT41K512M16HA.cfg | 112 +++ cmd/mmc.c | 2 +- configs/gwventana_emmc_defconfig | 1 + configs/gwventana_gw5904_defconfig | 68 ++ configs/gwventana_nand_defconfig | 1 + configs/imx6dl_icore_rqs_mmc_defconfig | 1 - configs/imx6q_icore_rqs_mmc_defconfig | 1 - configs/imx6q_logic_defconfig | 38 + configs/imx6ul_isiot_emmc_defconfig | 1 - configs/imx6ul_isiot_mmc_defconfig | 1 - configs/imx6ul_isiot_nand_defconfig | 1 - configs/m53evk_defconfig | 2 +- configs/mx6slevk_defconfig | 16 +- configs/mx6slevk_spinor_defconfig | 19 +- configs/mx6slevk_spl_defconfig | 2 +- doc/README.mxs | 2 +- drivers/net/phy/Kconfig | 13 + drivers/video/mxsfb.c | 2 +- include/configs/advantech_dms-ba16.h | 2 + include/configs/gw_ventana.h | 7 +- include/configs/imx6_logic.h | 178 +++++ include/configs/m53evk.h | 2 +- include/configs/mccmon6.h | 8 + include/configs/mx6cuboxi.h | 2 +- include/configs/mx6slevk.h | 9 +- include/dt-bindings/clock/imx6sl-clock.h | 180 +++++ scripts/config_whitelist.txt | 2 +- 64 files changed, 4931 insertions(+), 239 deletions(-) create mode 100644 arch/arm/dts/imx6q-logicpd.dts create mode 100644 arch/arm/dts/imx6qdl-logicpd.dtsi create mode 100644 arch/arm/dts/imx6sl-evk.dts create mode 100644 arch/arm/dts/imx6sl-pinfunc.h create mode 100644 arch/arm/dts/imx6sl.dtsi rename board/{denx => aries}/m28evk/Kconfig (89%) rename board/{denx => aries}/m28evk/MAINTAINERS (84%) rename board/{denx => aries}/m28evk/Makefile (100%) rename board/{denx => aries}/m28evk/README (82%) rename board/{denx => aries}/m28evk/m28evk.c (96%) rename board/{denx => aries}/m28evk/spl_boot.c (98%) rename board/{denx => aries}/m53evk/Kconfig (89%) rename board/{denx => aries}/m53evk/MAINTAINERS (84%) rename board/{denx => aries}/m53evk/Makefile (88%) rename board/{denx => aries}/m53evk/imximage.cfg (98%) rename board/{denx => aries}/m53evk/m53evk.c (99%) create mode 100644 board/logicpd/imx6/Kconfig create mode 100644 board/logicpd/imx6/MAINTAINERS create mode 100644 board/logicpd/imx6/Makefile create mode 100644 board/logicpd/imx6/README create mode 100644 board/logicpd/imx6/imx6logic.c create mode 100644 board/logicpd/imx6/mx6q_2x_MT41K512M16HA.cfg create mode 100644 configs/gwventana_gw5904_defconfig create mode 100644 configs/imx6q_logic_defconfig create mode 100644 include/configs/imx6_logic.h create mode 100644 include/dt-bindings/clock/imx6sl-clock.h
On Thu, Apr 13, 2017 at 10:01:28AM +0200, Stefano Babic wrote:
Hi Tom,
Stefano Babic
