[U-Boot] [PATCH] UBIFS: Change ubifsload to set the filesize variable
This is the same behaviour like tftp or fatload command.
Signed-off-by: Bastian Ruppert Bastian.Ruppert@Sewerin.de CC: kmpark@infradead.org --- fs/ubifs/ubifs.c | 4 ++++ 1 files changed, 4 insertions(+), 0 deletions(-)
diff --git a/fs/ubifs/ubifs.c b/fs/ubifs/ubifs.c index 5a5c739..2b9d2d2 100644 --- a/fs/ubifs/ubifs.c +++ b/fs/ubifs/ubifs.c @@ -688,6 +688,7 @@ int ubifs_load(char *filename, u32 addr, u32 size) int i; int count; int last_block_size = 0; + char buf [10];
c->ubi = ubi_open_volume(c->vi.ubi_num, c->vi.vol_id, UBI_READONLY); /* ubifs_findfile will resolve symlinks, so we know that we get @@ -719,6 +720,9 @@ int ubifs_load(char *filename, u32 addr, u32 size) printf("Loading file '%s' to addr 0x%08x with size %d (0x%08x)...\n", filename, addr, size, size);
+ sprintf(buf, "%lX", size); + setenv("filesize", buf); + page.addr = (void *)addr; page.index = 0; page.inode = inode;
Dear Bastian Ruppert,
In message 1315220629-9192-1-git-send-email-Bastian.Ruppert@Sewerin.de you wrote:
- sprintf(buf, "%lX", size);
- setenv("filesize", buf);
Please insert this piece of code _after_ the file has successfully been loaded to RAM (not before starting to load it).
Signed-off-by: Bastian Ruppert Bastian.Ruppert@Sewerin.de CC: kmpark@infradead.org --- fs/ubifs/ubifs.c | 6 +++++- 1 files changed, 5 insertions(+), 1 deletions(-)
diff --git a/fs/ubifs/ubifs.c b/fs/ubifs/ubifs.c index 5a5c739..75a2edc 100644 --- a/fs/ubifs/ubifs.c +++ b/fs/ubifs/ubifs.c @@ -688,6 +688,7 @@ int ubifs_load(char *filename, u32 addr, u32 size) int i; int count; int last_block_size = 0; + char buf [10];
c->ubi = ubi_open_volume(c->vi.ubi_num, c->vi.vol_id, UBI_READONLY); /* ubifs_findfile will resolve symlinks, so we know that we get @@ -739,8 +740,11 @@ int ubifs_load(char *filename, u32 addr, u32 size)
if (err) printf("Error reading file '%s'\n", filename); - else + else { + sprintf(buf, "%lX", size); + setenv("filesize", buf); printf("Done\n"); + }
ubifs_iput(inode);
Hi Bastian,
Acked-by: Detlev Zundel dzu@denx.de
Cheers Detlev
In message 1315227837-17714-1-git-send-email-Bastian.Ruppert@Sewerin.de you wrote:
Applied, thanks.
Commit 46d7274 "UBIFS: Change ubifsload to set the filesize variable" introduced the follwing compiler warning:
ubifs.c: In function 'ubifs_load': ubifs.c:742: warning: format '%lX' expects type 'long unsigned int', but argument 3 has type 'u32'
Signed-off-by: Wolfgang Denk wd@denx.de Cc: Bastian Ruppert Bastian.Ruppert@Sewerin.de --- fs/ubifs/ubifs.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/fs/ubifs/ubifs.c b/fs/ubifs/ubifs.c index 2e6313a..604eb8f 100644 --- a/fs/ubifs/ubifs.c +++ b/fs/ubifs/ubifs.c @@ -739,7 +739,7 @@ int ubifs_load(char *filename, u32 addr, u32 size) if (err) printf("Error reading file '%s'\n", filename); else { - sprintf(buf, "%lX", size); + sprintf(buf, "%X", size); setenv("filesize", buf); printf("Done\n"); }
Dear Wolfgang Denk,
Applied, thanks.
char buf [10];
maybe you want to check set_local_var() too ?
Dear Marek Vasut,
Yes, we should clean up all these auto-generated environment variables one day. But what you propose here is not a good approach:
(1) not all boards use the hush shell, and set_local_var() is only available there. (2) if you make such a change, then you must make it everywhere, and you must make sure not to break existent use of these things.
Both is definitely out of the scope of this patch.
On Monday, September 05, 2011 04:27:28 PM Wolfgang Denk wrote:
Dear Marek Vasut,
You're definitelly right on this thing.
Bastian Ruppert
Detlev Zundel
