[PATCH 15/15] CI: add qemu_arm64_lwip to the test matrix
Build and run qemu_arm64_lwip_defconfig in CI. This tests the lightweight IP (lwIP) implementation of the dhcp, tftpboot and ping commands.
Signed-off-by: Jerome Forissier jerome.forissier@linaro.org --- .azure-pipelines.yml | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/.azure-pipelines.yml b/.azure-pipelines.yml index 27f69583c6..b036999210 100644 --- a/.azure-pipelines.yml +++ b/.azure-pipelines.yml @@ -199,6 +199,10 @@ stages: cd ${WORK_DIR} git config --global --add safe.directory ${WORK_DIR} git clone --depth=1 https://source.denx.de/u-boot/u-boot-test-hooks /tmp/uboot-test-hooks + # qemu_arm64_lwip_defconfig is the same as qemu_arm64 but with NET_LWIP enabled. + # The test config and the boardenv file from qemu_arm64 can be re-used so create symlinks + ln -s conf.qemu_arm64_na /tmp/uboot-test-hooks/bin/travis-ci/conf.qemu_arm64_lwip_na + ln -s u_boot_boardenv_qemu_arm64_na.py /tmp/uboot-test-hooks/py/travis-ci/u_boot_boardenv_qemu_arm64_lwip_na.py ln -s travis-ci /tmp/uboot-test-hooks/bin/`hostname` ln -s travis-ci /tmp/uboot-test-hooks/py/`hostname` grub-mkimage --prefix="" -o ~/grub_x86.efi -O i386-efi normal echo lsefimmap lsefi lsefisystab efinet tftp minicmd @@ -371,6 +375,9 @@ stages: qemu_arm64: TEST_PY_BD: "qemu_arm64" TEST_PY_TEST_SPEC: "not sleep" + qemu_arm64_lwip: + TEST_PY_BD: "qemu_arm64_lwip" + TEST_PY_TEST_SPEC: "test_net_dhcp_lwip or test_net_ping_lwip or test_net_tftpboot_lwip" qemu_m68k: TEST_PY_BD: "M5208EVBE" TEST_PY_ID: "--id qemu"
Jerome Forissier
