[U-Boot] [PATCH REPOST] spi: tegra: clear RDY bit prior to every transfer
The RDY bit indicates that a transfer is complete. This needs to be cleared by SW before every single HW transaction, rather than only at the start of each SW transaction (those being made up of n HW transactions).
It seems that earlier HW may have cleared this bit autonomously when starting a new transfer, and hence this code was not needed in practice. However, this is generally a good idea in all cases. In Tegra124, the HW behaviour appears to have changed, and SW must explicitly clear this bit. Otherwise, SW will believe that transfers have completed when they have not, and may e.g. read stale data from the RX FIFO.
Signed-off-by: Yen Lin yelin@nvidia.com [swarren, rewrote commit description, unified duplicate RDY clearing code and moved it right before the start of the HW transaction, unconditionally exit loop after reading RX data, rather than checking if TX FIFO is empty, since it is guaranteed to be] Signed-off-by: Stephen Warren swarren@nvidia.com --- drivers/spi/tegra114_spi.c | 21 ++++++++------------- 1 file changed, 8 insertions(+), 13 deletions(-)
diff --git a/drivers/spi/tegra114_spi.c b/drivers/spi/tegra114_spi.c index 4d2af483d77f..810fa4718ce1 100644 --- a/drivers/spi/tegra114_spi.c +++ b/drivers/spi/tegra114_spi.c @@ -289,9 +289,6 @@ int tegra114_spi_xfer(struct spi_slave *slave, unsigned int bitlen, reg = readl(®s->fifo_status); writel(reg, ®s->fifo_status);
- /* clear ready bit */ - setbits_le32(®s->xfer_status, SPI_XFER_STS_RDY); - clrsetbits_le32(®s->command1, SPI_CMD1_CS_SW_VAL, SPI_CMD1_RX_EN | SPI_CMD1_TX_EN | SPI_CMD1_LSBY_FE | (slave->cs << SPI_CMD1_CS_SEL_SHIFT)); @@ -305,7 +302,6 @@ int tegra114_spi_xfer(struct spi_slave *slave, unsigned int bitlen, /* handle data in 32-bit chunks */ while (num_bytes > 0) { int bytes; - int is_read = 0; int tm, i;
tmpdout = 0; @@ -319,6 +315,9 @@ int tegra114_spi_xfer(struct spi_slave *slave, unsigned int bitlen,
num_bytes -= bytes;
+ /* clear ready bit */ + setbits_le32(®s->xfer_status, SPI_XFER_STS_RDY); + clrsetbits_le32(®s->command1, SPI_CMD1_BIT_LEN_MASK << SPI_CMD1_BIT_LEN_SHIFT, (bytes * 8 - 1) << SPI_CMD1_BIT_LEN_SHIFT); @@ -329,20 +328,14 @@ int tegra114_spi_xfer(struct spi_slave *slave, unsigned int bitlen, * Wait for SPI transmit FIFO to empty, or to time out. * The RX FIFO status will be read and cleared last */ - for (tm = 0, is_read = 0; tm < SPI_TIMEOUT; ++tm) { + for (tm = 0; tm < SPI_TIMEOUT; ++tm) { u32 fifo_status, xfer_status;
- fifo_status = readl(®s->fifo_status); - - /* We can exit when we've had both RX and TX activity */ - if (is_read && - (fifo_status & SPI_FIFO_STS_TX_FIFO_EMPTY)) - break; - xfer_status = readl(®s->xfer_status); if (!(xfer_status & SPI_XFER_STS_RDY)) continue;
+ fifo_status = readl(®s->fifo_status); if (fifo_status & SPI_FIFO_STS_ERR) { debug("%s: got a fifo error: ", __func__); if (fifo_status & SPI_FIFO_STS_TX_FIFO_OVF) @@ -367,7 +360,6 @@ int tegra114_spi_xfer(struct spi_slave *slave, unsigned int bitlen,
if (!(fifo_status & SPI_FIFO_STS_RX_FIFO_EMPTY)) { tmpdin = readl(®s->rx_fifo); - is_read = 1;
/* swap bytes read in */ if (din != NULL) { @@ -377,6 +369,9 @@ int tegra114_spi_xfer(struct spi_slave *slave, unsigned int bitlen, } din += bytes; } + + /* We can exit when we've had both RX and TX */ + break; } }
Stephen Warren
