[U-Boot] [PATCH 1/2] [PATCH 1/2] ARM: sun7i: config: add config for Sinovoip/Bananapi BPI-R1
* needs different GMAC_TX_DELAY than lamobo-r1 (not compatible)
Signed-off-by: Steve Arnold stephen.arnold42@gmail.com --- configs/Bananapi_R1_defconfig | 16 ++++++++++++++++ 1 file changed, 16 insertions(+) create mode 100644 configs/Bananapi_R1_defconfig
diff --git a/configs/Bananapi_R1_defconfig b/configs/Bananapi_R1_defconfig new file mode 100644 index 0000000..3743d5c --- /dev/null +++ b/configs/Bananapi_R1_defconfig @@ -0,0 +1,16 @@ +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_MACH_SUN7I=y +CONFIG_DRAM_CLK=432 +CONFIG_GMAC_TX_DELAY=3 +CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-bananapi-r1" +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL=y +CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER,SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23),AHCI,USB_EHCI" +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_FPGA is not set +CONFIG_USB_EHCI_HCD=y +CONFIG_DM_ETH=y +CONFIG_PHYLIB=y +# CONFIG_RTL8211X_PHY_FORCE_MASTER=y
* changes from lamobo-r1 required include: - ahci power pin (remove) - usbvbus pin config - mmc pin config - uart2 enable
Signed-off-by: Steve Arnold stephen.arnold42@gmail.com --- arch/arm/dts/Makefile | 1 + arch/arm/dts/sun7i-a20-bananapi-r1.dts | 376 +++++++++++++++++++++++++++++++++ 2 files changed, 377 insertions(+) create mode 100644 arch/arm/dts/sun7i-a20-bananapi-r1.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 032c5ae..0cbae00 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -216,6 +216,7 @@ dtb-$(CONFIG_MACH_SUN7I) += \ sun7i-a20-ainol-aw1.dtb \ sun7i-a20-bananapi.dtb \ sun7i-a20-bananapi-m1-plus.dtb \ + sun7i-a20-bananapi-r1.dtb \ sun7i-a20-bananapro.dtb \ sun7i-a20-cubieboard2.dtb \ sun7i-a20-cubietruck.dtb \ diff --git a/arch/arm/dts/sun7i-a20-bananapi-r1.dts b/arch/arm/dts/sun7i-a20-bananapi-r1.dts new file mode 100644 index 0000000..1a550f9 --- /dev/null +++ b/arch/arm/dts/sun7i-a20-bananapi-r1.dts @@ -0,0 +1,376 @@ +/* + * Copyright 2015 Hans de Goede hdegoede@redhat.com + * Changes copyright 2016 Stephen Arnold nerdboy@gentoo.org + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +/dts-v1/; +#include "sun7i-a20.dtsi" +#include "sunxi-common-regulators.dtsi" + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/interrupt-controller/irq.h> +#include <dt-bindings/pinctrl/sun4i-a10.h> + +/ { + model = "Banana Pi BPI-R1"; + compatible = "sinovoip,bpi-r1", "allwinner,sun7i-a20"; + + aliases { + serial0 = &uart0; + serial1 = &uart2; + serial2 = &uart3; + serial3 = &uart7; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&led_pins_bpi_r1>; + + green { + label = "bpi-r1:green:usr"; + gpios = <&pio 7 24 GPIO_ACTIVE_HIGH>; /* PH24 */ + linux,default-trigger = "heartbeat"; + }; + }; + + reg_gmac_3v3: gmac-3v3 { + compatible = "regulator-fixed"; + pinctrl-names = "default"; + pinctrl-0 = <&gmac_power_pin_bpi_r1>; + regulator-name = "gmac-3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + startup-delay-us = <100000>; + enable-active-high; + gpio = <&pio 7 23 GPIO_ACTIVE_HIGH>; /* PH23 */ + }; + +}; + +&ahci { + target-supply = <®_ahci_5v>; + status = "okay"; +}; + +&cpu0 { + cpu-supply = <®_dcdc2>; +}; + +&ehci0 { + status = "okay"; +}; + +&ehci1 { + status = "okay"; +}; + +&ohci0 { + status = "okay"; +}; + +&ohci1 { + status = "okay"; +}; + +&gmac { + pinctrl-names = "default"; + pinctrl-0 = <&gmac_pins_rgmii_a>; + phy = <&phy1>; + phy-mode = "rgmii"; + phy-supply = <®_gmac_3v3>; + status = "okay"; + + fixed-link { + speed = <1000>; + full-duplex; + }; + + mdio { + compatible = "snps,dwmac-mdio"; + #address-cells = <1>; + #size-cells = <0>; + + switch: ethernet-switch@1e { + compatible = "brcm,bcm53125"; + reg = <30>; + #address-cells = <1>; + #size-cells = <0>; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port0: port@0 { + reg = <0>; + label = "lan2"; + }; + + port1: port@1 { + reg = <1>; + label = "lan3"; + }; + + port2: port@2 { + reg = <2>; + label = "lan4"; + }; + + port3: port@3 { + reg = <3>; + label = "wan"; + }; + + port4: port@4 { + reg = <4>; + label = "lan1"; + }; + + port8: port@8 { + reg = <8>; + label = "cpu"; + ethernet = <&gmac>; + phy-mode = "rgmii"; + fixed-link { + speed = <1000>; + full-duplex; + }; + }; + }; + }; + }; +}; + +&i2c0 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c0_pins_a>; + status = "okay"; + + axp209: pmic@34 { + compatible = "x-powers,axp209"; + reg = <0x34>; + interrupt-parent = <&nmi_intc>; + interrupts = <0 IRQ_TYPE_LEVEL_LOW>; + + interrupt-controller; + #interrupt-cells = <1>; + }; +}; + +#include "axp209.dtsi" + +&i2c2 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c2_pins_a>; + status = "okay"; +}; + +&ir0 { + pinctrl-names = "default"; + pinctrl-0 = <&ir0_rx_pins_a>; + status = "okay"; +}; + +&mmc0 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc0_pins_a>, <&mmc0_cd_pin_bpi_r1>; + vmmc-supply = <®_vcc3v3>; + bus-width = <4>; + cd-gpios = <&pio 7 1 GPIO_ACTIVE_HIGH>; /* PH1 */ + cd-inverted; + status = "okay"; +}; + +&otg_sram { + status = "okay"; +}; + +&pio { + usb0_id_detect_pin: usb0_id_detect_pin@0 { + allwinner,pins = "PH4"; + allwinner,function = "gpio_in"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + }; + + usb0_vbus_detect_pin: usb0_vbus_detect_pin@0 { + allwinner,pins = "PH5"; + allwinner,function = "gpio_in"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + }; + + usb0_vbus_pin_bpi_r1: usb0_vbus_pin@0 { + allwinner,pins = "PB9"; + allwinner,function = "gpio_out"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + }; + + usb2_vbus_pin_bpi_r1: usb2_vbus_pin@0 { + allwinner,pins = "PH3"; + allwinner,function = "gpio_out"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + }; + + mmc0_cd_pin_bpi_r1: mmc0_cd_pin@0 { + allwinner,pins = "PH1"; + allwinner,function = "gpio_in"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_PULL_UP>; + }; + + gmac_power_pin_bpi_r1: gmac_power_pin@0 { + allwinner,pins = "PH23"; + allwinner,function = "gpio_out"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + }; + + led_pins_bpi_r1: led_pins@0 { + allwinner,pins = "PH24"; + allwinner,function = "gpio_out"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + }; +}; + +®_ahci_5v { + status = "okay"; +}; + +®_dcdc2 { + regulator-always-on; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1400000>; + regulator-name = "vdd-cpu"; +}; + +®_dcdc3 { + regulator-always-on; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1400000>; + regulator-name = "vdd-int-dll"; +}; + +®_ldo1 { + regulator-name = "vdd-rtc"; +}; + +®_ldo2 { + regulator-always-on; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-name = "avcc"; +}; + +®_usb0_vbus { + pinctrl-0 = <&usb0_vbus_pin_bpi_r1>; + gpio = <&pio 1 9 GPIO_ACTIVE_HIGH>; /* PB9 */ + status = "okay"; +}; + +®_usb1_vbus { + status = "okay"; +}; + +®_usb2_vbus { + pinctrl-0 = <&usb2_vbus_pin_bpi_r1>; + gpio = <&pio 7 3 GPIO_ACTIVE_HIGH>; /* PH3 */ + status = "okay"; +}; + +&spi0 { + pinctrl-names = "default"; + pinctrl-0 = <&spi0_pins_a>, + <&spi0_cs0_pins_a>, + <&spi0_cs1_pins_a>; + status = "okay"; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_pins_a>; + status = "okay"; +}; + +&uart2 { + pinctrl-names = "default"; + pinctrl-0 = <&uart2_pins_a>; + status = "okay"; +}; + +&uart3 { + pinctrl-names = "default"; + pinctrl-0 = <&uart3_pins_b>; + status = "okay"; +}; + +&uart7 { + pinctrl-names = "default"; + pinctrl-0 = <&uart7_pins_a>; + status = "okay"; +}; + +&usb_otg { + dr_mode = "otg"; + status = "okay"; +}; + +&usb_power_supply { + status = "okay"; +}; + +&usbphy { + pinctrl-names = "default"; + pinctrl-0 = <&usb0_id_detect_pin>; + usb0_id_det-gpio = <&pio 7 4 GPIO_ACTIVE_HIGH>; /* PH4 */ + usb0_vbus_power-supply = <&usb_power_supply>; + usb0_vbus-supply = <®_usb0_vbus>; + usb1_vbus-supply = <®_usb1_vbus>; + usb2_vbus-supply = <®_usb2_vbus>; + status = "okay"; +};
Okay, please disregard the update with double "PATCH" in the subject; I need to get better with git send-email (besides just the Google insecure app thing for gmail).
I'm about to resend v2 with (hopefully) all the right stuff in it.
Thanks, Steve
On Mon, Oct 3, 2016 at 1:01 PM, Stephen Arnold stephen.arnold42@gmail.com wrote:
- changes from lamobo-r1 required include:
- mmc pin config
- uart2 enable
- Copyright 2015 Hans de Goede hdegoede@redhat.com
- Changes copyright 2016 Stephen Arnold nerdboy@gentoo.org
- This file is dual-licensed: you can use it either under the terms
- of the GPL or the X11 license, at your option. Note that this dual
- licensing only applies to this file, and not this project as a
- whole.
- a) This file is free software; you can redistribute it and/or
- Or, alternatively,
- b) Permission is hereby granted, free of charge, to any person
conditions:
aliases {
serial0 = &uart0;
serial1 = &uart2;
serial2 = &uart3;
serial3 = &uart7;
chosen {
leds {
green {
enable-active-high;
+&ahci {
status = "okay";
+&cpu0 {
+&ehci0 {
status = "okay";
+&ehci1 {
status = "okay";
+&ohci0 {
status = "okay";
+&ohci1 {
status = "okay";
+&gmac {
phy = <&phy1>;
phy-mode = "rgmii";
status = "okay";
fixed-link {
speed = <1000>;
full-duplex;
mdio {
#size-cells = <0>;
reg = <30>;
#size-cells = <0>;
ports {
#size-cells = <0>;
port0: port@0 {
reg = <0>;
label = "lan2";
port1: port@1 {
reg = <1>;
label = "lan3";
port2: port@2 {
reg = <2>;
label = "lan4";
port3: port@3 {
reg = <3>;
label = "wan";
port4: port@4 {
reg = <4>;
label = "lan1";
port8: port@8 {
reg = <8>;
label = "cpu";
ethernet = <&gmac>;
phy-mode = "rgmii";
fixed-link {
speed = <1000>;
full-duplex;
+&i2c0 {
status = "okay";
axp209: pmic@34 {
reg = <0x34>;
+&i2c2 {
status = "okay";
+&ir0 {
status = "okay";
+&mmc0 {
bus-width = <4>;
cd-inverted;
status = "okay";
+&otg_sram {
status = "okay";
+&pio {
+®_ahci_5v {
status = "okay";
+®_dcdc2 {
+®_dcdc3 {
+®_ldo1 {
+®_ldo2 {
+®_usb0_vbus {
status = "okay";
+®_usb1_vbus {
status = "okay";
+®_usb2_vbus {
status = "okay";
+&spi0 {
<&spi0_cs0_pins_a>,
<&spi0_cs1_pins_a>;
status = "okay";
+&uart0 {
status = "okay";
+&uart2 {
status = "okay";
+&uart3 {
status = "okay";
+&uart7 {
status = "okay";
+&usb_otg {
dr_mode = "otg";
status = "okay";
status = "okay";
+&usbphy {
status = "okay";
2.9.3
This is what I have now for send command:
git send-email --to=u-boot@lists.denx.de --confirm=always -M -1 --subject-prefix="PATCH v2" outgoing/*
Any u-boot-y tips are appreciated...
Steve
On Mon, Oct 3, 2016 at 1:19 PM, Stephen Arnold stephen.arnold42@gmail.com wrote:
Thanks, Steve
- mmc pin config
- uart2 enable
- whole.
conditions:
aliases {
serial0 = &uart0;
serial1 = &uart2;
serial2 = &uart3;
serial3 = &uart7;
chosen {
leds {
green {
enable-active-high;
+&ahci {
status = "okay";
+&cpu0 {
+&ehci0 {
status = "okay";
+&ehci1 {
status = "okay";
+&ohci0 {
status = "okay";
+&ohci1 {
status = "okay";
+&gmac {
phy = <&phy1>;
phy-mode = "rgmii";
status = "okay";
fixed-link {
speed = <1000>;
full-duplex;
mdio {
#size-cells = <0>;
reg = <30>;
#size-cells = <0>;
ports {
#size-cells = <0>;
port0: port@0 {
reg = <0>;
label = "lan2";
port1: port@1 {
reg = <1>;
label = "lan3";
port2: port@2 {
reg = <2>;
label = "lan4";
port3: port@3 {
reg = <3>;
label = "wan";
port4: port@4 {
reg = <4>;
label = "lan1";
port8: port@8 {
reg = <8>;
label = "cpu";
ethernet = <&gmac>;
phy-mode = "rgmii";
fixed-link {
speed = <1000>;
full-duplex;
+&i2c0 {
status = "okay";
axp209: pmic@34 {
reg = <0x34>;
+&i2c2 {
status = "okay";
+&ir0 {
status = "okay";
+&mmc0 {
bus-width = <4>;
cd-inverted;
status = "okay";
+&otg_sram {
status = "okay";
+&pio {
+®_ahci_5v {
status = "okay";
+®_dcdc2 {
+®_dcdc3 {
+®_ldo1 {
+®_ldo2 {
+®_usb0_vbus {
status = "okay";
+®_usb1_vbus {
status = "okay";
+®_usb2_vbus {
status = "okay";
+&spi0 {
<&spi0_cs0_pins_a>,
<&spi0_cs1_pins_a>;
status = "okay";
+&uart0 {
status = "okay";
+&uart2 {
status = "okay";
+&uart3 {
status = "okay";
+&uart7 {
status = "okay";
+&usb_otg {
dr_mode = "otg";
status = "okay";
status = "okay";
+&usbphy {
status = "okay";
2.9.3
Stephen Arnold
