[U-Boot] Linking script image into u-boot
Is it possible to create a script, convert it to an image, and then link that image into u-boot? The goal of which would be to have a script that could be executed without having to download it. I have searched the manual and the mailing list and the source code, but don't see an obvious way to do this.
As an alternative, I could convert the bytes in the image file to an initialized char array in a .c file. That .c file could then be compiled and linked with u-boot. I assume that at runtime I could use the source command with the address of the char array as an argument to run the script.
Suggestions?
Suggestions?
If you're willing to change the build by introducing a new C file maybe using the CONFIG_EXTRA_ENV_SETTINGS define in your *_config.h works for you? Does it have to be a script that isn't in an environment variable?
CONFIG_EXTRA_ENV_SETTINGS would work fine for me. Thanks
On Fri, Jun 4, 2010 at 9:58 AM, Ben Gardiner bengardiner@nanometrics.ca wrote:
Suggestions?
-- Ben Gardiner Nanometrics Inc. +1 (613) 592-6776 x239 http://www.nanometrics.ca
Dear Mark Fanara,
In message AANLkTinoltaKvYMrmEcgTlPSSizwYnuTTnPWfs7NUD2O@mail.gmail.com you wrote:
This is possible.
This is possible, too.
But why do you consider such complicated approaches when you can simply concatenate the images (eventually with a little padding so they remain aligned to sector boundaries)? Standard tools like "cat" and "dd" are your friends...
Ben Gardiner
Mark Fanara
