[U-Boot] [PATCH v2] OMAP3: workaround for ARM Cortex-A8 erratum 725233
725233: PLD instructions executed with PLD data forwarding enabled can result in a processor deadlock
This deadlock can happen when NEON load instructions are used together with cache preload instructions (PLD). The problematic conditions can be triggered in-the-wild by NEON optimized functions from pixman library (http://cgit.freedesktop.org/pixman), which perform dynamic adjustment of prefetch distance.
The workaround disables PLD data forwarding by setting PLD_FWD bit in L2 Cache Auxiliary Control Register as recommended in ARM Cortex-A8 errata list.
The deadlock can only happen on r1pX revisions of Cortex-A8 (used in OMAP34xx/OMAP35xx). Performance impact of the workaround is practically non-existant.
Signed-off-by: Siarhei Siamashka siarhei.siamashka@gmail.com --- Revision history: v2 - Comment text extended with a bit more information about the affected Cortex-A8 core revisions, potential drawbacks (none known at the moment) and the information about where this CPU bug can be encountered in practice. No changes to the patch itself.
cpu/arm_cortexa8/omap3/board.c | 6 ++++++ 1 files changed, 6 insertions(+), 0 deletions(-)
diff --git a/cpu/arm_cortexa8/omap3/board.c b/cpu/arm_cortexa8/omap3/board.c index 2aa69b3..7b78fa4 100644 --- a/cpu/arm_cortexa8/omap3/board.c +++ b/cpu/arm_cortexa8/omap3/board.c @@ -146,6 +146,12 @@ void setup_auxcr() __asm__ __volatile__("orr r0, r0, #1 << 5"); /* SMI instruction to call ROM Code API */ __asm__ __volatile__(".word 0xE1600070"); + /* Set PLD_FWD bit in L2AUXCR (Cortex-A8 erratum 725233 workaround) */ + __asm__ __volatile__("mov r12, #0x2"); + __asm__ __volatile__("mrc p15, 1, r0, c9, c0, 2"); + __asm__ __volatile__("orr r0, r0, #1 << 27"); + /* SMI instruction to call ROM Code API */ + __asm__ __volatile__(".word 0xE1600070"); __asm__ __volatile__("mov r0, %0":"=r"(i)); __asm__ __volatile__("mov r12, %0":"=r"(j)); }
Thank you for the improvements on the comment. Ack-ed.
Tom
Seems important to me. I'm going to push it to u-boot-ti and send a pull request for the same
Tom
I saw the merge on TI so I went ahead and pulled. Applied to ARM. Thanks Tom
Tom
Paulraj, Sandeep
Siarhei Siamashka
Tom
