[PATCH v1] net: nuvoton : Add NPCM7xx EMAC driver
NPCM750 provides identical ethernet MAC controllers for WAN/LAN applications.
Signed-off-by: Jim Liu JJLIU0@nuvoton.com --- drivers/net/Kconfig | 5 + drivers/net/Makefile | 1 + drivers/net/npcm750_eth.c | 745 ++++++++++++++++++++++++++++++++++++++ 3 files changed, 751 insertions(+) create mode 100644 drivers/net/npcm750_eth.c
diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index 7fe0e00649..34cd48648a 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -496,6 +496,11 @@ config MT7628_ETH The MediaTek MT7628 ethernet interface is used on MT7628 and MT7688 based boards.
+config NET_NPCM750 + bool "Nuvoton NPCM750 Ethernet MAC" + help + support NPCM750 EMAC + config NET_OCTEON bool "MIPS Octeon ethernet support" depends on ARCH_OCTEON diff --git a/drivers/net/Makefile b/drivers/net/Makefile index 69fb3bbbf7..345d0904ea 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -64,6 +64,7 @@ obj-$(CONFIG_MVMDIO) += mvmdio.o obj-$(CONFIG_MVNETA) += mvneta.o obj-$(CONFIG_MVPP2) += mvpp2.o obj-$(CONFIG_NETCONSOLE) += netconsole.o +obj-$(CONFIG_NET_NPCM750) += npcm750_eth.o obj-$(CONFIG_NET_OCTEON) += octeon/ obj-$(CONFIG_NET_OCTEONTX) += octeontx/ obj-$(CONFIG_NET_OCTEONTX2) += octeontx2/ diff --git a/drivers/net/npcm750_eth.c b/drivers/net/npcm750_eth.c new file mode 100644 index 0000000000..409d5cce4a --- /dev/null +++ b/drivers/net/npcm750_eth.c @@ -0,0 +1,745 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) 2021 Nuvoton Technology Corp. + */ + +#include <common.h> +#include <cpu_func.h> +#include <dm.h> +#include <errno.h> +#include <miiphy.h> +#include <malloc.h> +#include <net.h> +#include <regmap.h> +#include <serial.h> +#include <syscon.h> +#include <asm/io.h> +#include <linux/err.h> +#include <linux/iopoll.h> + +#define MAC_ADDR_SIZE 6 +#define CONFIG_TX_DESCR_NUM 32 +#define CONFIG_RX_DESCR_NUM 32 + +#define TX_TOTAL_BUFSIZE \ + ((CONFIG_TX_DESCR_NUM + 1) * PKTSIZE_ALIGN + PKTALIGN) +#define RX_TOTAL_BUFSIZE \ + ((CONFIG_RX_DESCR_NUM + 1) * PKTSIZE_ALIGN + PKTALIGN) + +#define CONFIG_MDIO_TIMEOUT (3 * CONFIG_SYS_HZ) + +struct npcm750_rxbd { + unsigned int sl; + unsigned int buffer; + unsigned int reserved; + unsigned int next; +} __aligned(ARCH_DMA_MINALIGN); + +struct npcm750_txbd { + unsigned int mode; + unsigned int buffer; + unsigned int sl; + unsigned int next; +} __aligned(ARCH_DMA_MINALIGN); + +struct emc_regs { + u32 camcmr; /* 0x00 */ + u32 camen; /* 0x04 */ + u32 cam0m; /* 0x08 */ + u32 cam0l; /* 0x0c */ + u32 cam1m; /* 0x10 */ + u32 cam1l; /* 0x14 */ + u32 cam2m; /* 0x18 */ + u32 cam2l; /* 0x1c */ + u32 cam3m; /* 0x20 */ + u32 cam3l; /* 0x24 */ + u32 cam4m; /* 0x28 */ + u32 cam4l; /* 0x2c */ + u32 cam5m; /* 0x30 */ + u32 cam5l; /* 0x34 */ + u32 cam6m; /* 0x38 */ + u32 cam6l; /* 0x3c */ + u32 cam7m; /* 0x40 */ + u32 cam7l; /* 0x44 */ + u32 cam8m; /* 0x48 */ + u32 cam8l; /* 0x4c */ + u32 cam9m; /* 0x50 */ + u32 cam9l; /* 0x54 */ + u32 cam10m; /* 0x58 */ + u32 cam10l; /* 0x5c */ + u32 cam11m; /* 0x60 */ + u32 cam11l; /* 0x64 */ + u32 cam12m; /* 0x68 */ + u32 cam12l; /* 0x6c */ + u32 cam13m; /* 0x70 */ + u32 cam13l; /* 0x74 */ + u32 cam14m; /* 0x78 */ + u32 cam14l; /* 0x7c */ + u32 cam15m; /* 0x80 */ + u32 cam15l; /* 0x84 */ + u32 txdlsa; /* 0x88 */ + u32 rxdlsa; /* 0x8c */ + u32 mcmdr; /* 0x90 */ + u32 miid; /* 0x94 */ + u32 miida; /* 0x98 */ + u32 fftcr; /* 0x9c */ + u32 tsdr; /* 0xa0 */ + u32 rsdr; /* 0xa4 */ + u32 dmarfc; /* 0xa8 */ + u32 mien; /* 0xac */ + u32 mista; /* 0xb0 */ + u32 mgsta; /* 0xb4 */ + u32 mpcnt; /* 0xb8 */ + u32 mrpc; /* 0xbc */ + u32 mrpcc; /* 0xc0 */ + u32 mrepc; /* 0xc4 */ + u32 dmarfs; /* 0xc8 */ + u32 ctxdsa; /* 0xcc */ + u32 ctxbsa; /* 0xd0 */ + u32 crxdsa; /* 0xd4 */ + u32 crxbsa; /* 0xd8 */ +}; + +struct npcm750_eth_dev { + struct npcm750_txbd tdesc[CONFIG_TX_DESCR_NUM] __aligned(ARCH_DMA_MINALIGN); + struct npcm750_rxbd rdesc[CONFIG_RX_DESCR_NUM] __aligned(ARCH_DMA_MINALIGN); + u8 txbuffs[TX_TOTAL_BUFSIZE] __aligned(ARCH_DMA_MINALIGN); + u8 rxbuffs[RX_TOTAL_BUFSIZE] __aligned(ARCH_DMA_MINALIGN); + struct emc_regs *emc_regs_p; + struct phy_device *phydev; + struct mii_dev *bus; + struct npcm750_txbd *curr_txd; + struct npcm750_rxbd *curr_rxd; + u32 interface; + u32 max_speed; + u32 idx; + struct regmap *gcr_regmap; +}; + +struct npcm750_eth_pdata { + struct eth_pdata eth_pdata; +}; + +/* mac controller bit */ +#define MCMDR_RXON BIT(0) +#define MCMDR_ACP BIT(3) +#define MCMDR_SPCRC BIT(5) +#define MCMDR_TXON BIT(8) +#define MCMDR_NDEF BIT(9) +#define MCMDR_FDUP BIT(18) +#define MCMDR_ENMDC BIT(19) +#define MCMDR_OPMOD BIT(20) +#define MCMDR_SWR BIT(24) + +/* cam command regiser */ +#define CAMCMR_AUP 0x01 +#define CAMCMR_AMP BIT(1) +#define CAMCMR_ABP BIT(2) +#define CAMCMR_CCAM BIT(3) +#define CAMCMR_ECMP BIT(4) +#define CAM0EN 0x01 + +/* mac mii controller bit */ +#define MDCON BIT(19) +#define PHYAD BIT(8) +#define PHYWR BIT(16) +#define PHYBUSY BIT(17) +#define PHYPRESP BIT(18) +#define CAM_ENTRY_SIZE 0x08 + +/* rx and tx status */ +#define TXDS_TXCP BIT(19) +#define RXDS_CRCE BIT(17) +#define RXDS_PTLE BIT(19) +#define RXDS_RXGD BIT(20) +#define RXDS_ALIE BIT(21) +#define RXDS_RP BIT(22) + +/* mac interrupt status*/ +#define MISTA_RXINTR BIT(0) +#define MISTA_CRCE BIT(1) +#define MISTA_RXOV BIT(2) +#define MISTA_PTLE BIT(3) +#define MISTA_RXGD BIT(4) +#define MISTA_ALIE BIT(5) +#define MISTA_RP BIT(6) +#define MISTA_MMP BIT(7) +#define MISTA_DFOI BIT(8) +#define MISTA_DENI BIT(9) +#define MISTA_RDU BIT(10) +#define MISTA_RXBERR BIT(11) +#define MISTA_CFR BIT(14) +#define MISTA_TXINTR BIT(16) +#define MISTA_TXEMP BIT(17) +#define MISTA_TXCP BIT(18) +#define MISTA_EXDEF BIT(19) +#define MISTA_NCS BIT(20) +#define MISTA_TXABT BIT(21) +#define MISTA_LC BIT(22) +#define MISTA_TDU BIT(23) +#define MISTA_TXBERR BIT(24) + +#define ENSTART 0x01 +#define ENRXINTR BIT(0) +#define ENCRCE BIT(1) +#define EMRXOV BIT(2) +#define ENPTLE BIT(3) +#define ENRXGD BIT(4) +#define ENALIE BIT(5) +#define ENRP BIT(6) +#define ENMMP BIT(7) +#define ENDFO BIT(8) +#define ENDENI BIT(9) +#define ENRDU BIT(10) +#define ENRXBERR BIT(11) +#define ENCFR BIT(14) +#define ENTXINTR BIT(16) +#define ENTXEMP BIT(17) +#define ENTXCP BIT(18) +#define ENTXDEF BIT(19) +#define ENNCS BIT(20) +#define ENTXABT BIT(21) +#define ENLC BIT(22) +#define ENTDU BIT(23) +#define ENTXBERR BIT(24) + +#define RX_STAT_RBC 0xffff +#define RX_STAT_RXINTR BIT(16) +#define RX_STAT_CRCE BIT(17) +#define RX_STAT_PTLE BIT(19) +#define RX_STAT_RXGD BIT(20) +#define RX_STAT_ALIE BIT(21) +#define RX_STAT_RP BIT(22) +#define RX_STAT_OWNER (BIT(30) | BIT(31)) + +#define TX_STAT_TBC 0xffff +#define TX_STAT_TXINTR BIT(16) +#define TX_STAT_DEF BIT(17) +#define TX_STAT_TXCP BIT(19) +#define TX_STAT_EXDEF BIT(20) +#define TX_STAT_NCS BIT(21) +#define TX_STAT_TXBT BIT(22) +#define TX_STAT_LC BIT(23) +#define TX_STAT_TXHA BIT(24) +#define TX_STAT_PAU BIT(25) +#define TX_STAT_SQE BIT(26) + +/* rx and tx owner bit */ +#define RX_OWEN_DMA BIT(31) +#define RX_OWEN_CPU 0x00 //bit 30 & bit 31 +#define TX_OWEN_DMA BIT(31) +#define TX_OWEN_CPU (~(BIT(31))) + +/* tx frame desc controller bit */ +#define MACTXINTEN 0x04 +#define CRCMODE 0x02 +#define PADDINGMODE 0x01 + +/* fftcr controller bit */ +#define RXTHD 0x03 +#define TXTHD (BIT(8) | BIT(9)) +#define BLENGTH BIT(21) + +/* global setting for driver */ +#define RX_DESC_SIZE 128 +#define TX_DESC_SIZE 64 +#define MAX_RBUFF_SZ 0x600 +#define MAX_TBUFF_SZ 0x600 +#define TX_TIMEOUT 50 +#define DELAY 1000 +#define CAM0 0x0 +#define RX_POLL_SIZE (RX_DESC_SIZE / 2) +#define MII_TIMEOUT 100 +#define GCR_INTCR 0x3c +#define INTCR_R1EN BIT(5) + +enum MIIDA_MDCCR_T { + MIIDA_MDCCR_4 = 0x00, + MIIDA_MDCCR_6 = 0x01, + MIIDA_MDCCR_8 = 0x02, + MIIDA_MDCCR_12 = 0x03, + MIIDA_MDCCR_16 = 0x04, + MIIDA_MDCCR_20 = 0x05, + MIIDA_MDCCR_24 = 0x06, + MIIDA_MDCCR_28 = 0x07, + MIIDA_MDCCR_30 = 0x08, + MIIDA_MDCCR_32 = 0x09, + MIIDA_MDCCR_36 = 0x0A, + MIIDA_MDCCR_40 = 0x0B, + MIIDA_MDCCR_44 = 0x0C, + MIIDA_MDCCR_48 = 0x0D, + MIIDA_MDCCR_54 = 0x0E, + MIIDA_MDCCR_60 = 0x0F, +}; + +DECLARE_GLOBAL_DATA_PTR; + +static int npcm750_mdio_read(struct mii_dev *bus, int addr, int devad, int regs) +{ + struct npcm750_eth_dev *priv = (struct npcm750_eth_dev *)bus->priv; + struct emc_regs *reg = priv->emc_regs_p; + u32 start, val; + int timeout = CONFIG_MDIO_TIMEOUT; + + val = (addr << 0x08) | regs | PHYBUSY | (MIIDA_MDCCR_60 << 20); + writel(val, ®->miida); + + start = get_timer(0); + while (get_timer(start) < timeout) { + if (!(readl(®->miida) & PHYBUSY)) { + val = readl(®->miid); + return val; + } + udelay(10); + }; + return -ETIMEDOUT; +} + +static int npcm750_mdio_write(struct mii_dev *bus, int addr, int devad, int regs, + u16 val) +{ + struct npcm750_eth_dev *priv = (struct npcm750_eth_dev *)bus->priv; + struct emc_regs *reg = priv->emc_regs_p; + ulong start; + int ret = -ETIMEDOUT, timeout = CONFIG_MDIO_TIMEOUT; + + writel(val, ®->miid); + writel((addr << 0x08) | regs | PHYBUSY | PHYWR | (MIIDA_MDCCR_60 << 20), ®->miida); + + start = get_timer(0); + while (get_timer(start) < timeout) { + if (!(readl(®->miida) & PHYBUSY)) { + ret = 0; + break; + } + udelay(10); + }; + return ret; +} + +static int npcm750_mdio_reset(struct mii_dev *bus) +{ + return 0; +} + +static int npcm750_mdio_init(const char *name, struct npcm750_eth_dev *priv) +{ + struct emc_regs *reg = priv->emc_regs_p; + struct mii_dev *bus = mdio_alloc(); + + if (!bus) { + printf("Failed to allocate MDIO bus\n"); + return -ENOMEM; + } + + bus->read = npcm750_mdio_read; + bus->write = npcm750_mdio_write; + snprintf(bus->name, sizeof(bus->name), "%s", name); + bus->reset = npcm750_mdio_reset; + + bus->priv = (void *)priv; + + writel(readl(®->mcmdr) | MCMDR_ENMDC, ®->mcmdr); + return mdio_register(bus); +} + +static void npcm750_tx_descs_init(struct npcm750_eth_dev *priv) +{ + struct emc_regs *reg = priv->emc_regs_p; + struct npcm750_txbd *desc_table_p = &priv->tdesc[0]; + struct npcm750_txbd *desc_p; + u8 *txbuffs = &priv->txbuffs[0]; + u32 idx; + + writel((u32)desc_table_p, ®->txdlsa); + priv->curr_txd = desc_table_p; + + for (idx = 0; idx < CONFIG_TX_DESCR_NUM; idx++) { + desc_p = &desc_table_p[idx]; + desc_p->buffer = (u32)&txbuffs[idx * PKTSIZE_ALIGN]; + desc_p->sl = 0; + desc_p->mode = 0; + desc_p->mode = TX_OWEN_CPU | PADDINGMODE | CRCMODE | MACTXINTEN; + if (idx < (CONFIG_TX_DESCR_NUM - 1)) + desc_p->next = (u32)&desc_table_p[idx + 1]; + else + desc_p->next = (u32)&priv->tdesc[0]; + } + flush_dcache_range((ulong)&desc_table_p[0], + (ulong)&desc_table_p[CONFIG_TX_DESCR_NUM]); +} + +static void npcm750_rx_descs_init(struct npcm750_eth_dev *priv) +{ + struct emc_regs *reg = priv->emc_regs_p; + struct npcm750_rxbd *desc_table_p = &priv->rdesc[0]; + struct npcm750_rxbd *desc_p; + u8 *rxbuffs = &priv->rxbuffs[0]; + u32 idx; + + flush_dcache_range((ulong)priv->rxbuffs[0], + (ulong)priv->rxbuffs[CONFIG_RX_DESCR_NUM]); + + writel((u32)desc_table_p, ®->rxdlsa); + priv->curr_rxd = desc_table_p; + + for (idx = 0; idx < CONFIG_RX_DESCR_NUM; idx++) { + desc_p = &desc_table_p[idx]; + desc_p->sl = RX_OWEN_DMA; + desc_p->buffer = (u32)&rxbuffs[idx * PKTSIZE_ALIGN]; + if (idx < (CONFIG_RX_DESCR_NUM - 1)) + desc_p->next = (u32)&desc_table_p[idx + 1]; + else + desc_p->next = (u32)&priv->rdesc[0]; + } + flush_dcache_range((ulong)&desc_table_p[0], + (ulong)&desc_table_p[CONFIG_RX_DESCR_NUM]); +} + +static void npcm750_set_fifo_threshold(struct npcm750_eth_dev *priv) +{ + struct emc_regs *reg = priv->emc_regs_p; + unsigned int val; + + val = RXTHD | TXTHD | BLENGTH; + writel(val, ®->fftcr); +} + +static void npcm750_set_global_maccmd(struct npcm750_eth_dev *priv) +{ + struct emc_regs *reg = priv->emc_regs_p; + unsigned int val; + + val = readl(®->mcmdr); + val |= MCMDR_SPCRC | MCMDR_ENMDC | MCMDR_ACP | MCMDR_NDEF; + writel(val, ®->mcmdr); +} + +static void npcm750_set_cam(struct npcm750_eth_dev *priv, + unsigned int x, unsigned char *pval) +{ + struct emc_regs *reg = priv->emc_regs_p; + unsigned int msw, lsw; + + msw = (pval[0] << 24) | (pval[1] << 16) | (pval[2] << 8) | pval[3]; + lsw = (pval[4] << 24) | (pval[5] << 16); + + writel(lsw, ®->cam0l + x * CAM_ENTRY_SIZE); + writel(msw, ®->cam0m + x * CAM_ENTRY_SIZE); + writel(readl(®->camen) | CAM0EN, ®->camen); + writel(CAMCMR_ECMP | CAMCMR_ABP | CAMCMR_AUP, ®->camcmr); +} + +static void npcm750_adjust_link(struct emc_regs *reg, + struct phy_device *phydev) +{ + u32 val = readl(®->mcmdr); + + if (!phydev->link) { + printf("%s: No link.\n", phydev->dev->name); + return; + } + + if (phydev->speed == 100) + val |= MCMDR_OPMOD; + else + val &= ~MCMDR_OPMOD; + + if (phydev->duplex) + val |= MCMDR_FDUP; + else + val &= ~MCMDR_FDUP; + + writel(val, ®->mcmdr); + + debug("Speed: %d, %s duplex%s\n", phydev->speed, + (phydev->duplex) ? "full" : "half", + (phydev->port == PORT_FIBRE) ? ", fiber mode" : ""); +} + +static int npcm750_phy_init(struct npcm750_eth_dev *priv, void *dev) +{ + struct phy_device *phydev; + int ret; + u32 address = 0x0; + + phydev = phy_connect(priv->bus, address, dev, priv->interface); + if (!phydev) + return -ENODEV; + + if (priv->max_speed) { + ret = phy_set_supported(phydev, priv->max_speed); + if (ret) + return ret; + } + phydev->advertising = phydev->supported; + + priv->phydev = phydev; + phy_config(phydev); + return 0; +} + +static int npcm750_eth_start(struct udevice *dev) +{ + struct eth_pdata *pdata = dev_get_plat(dev); + struct npcm750_eth_dev *priv = dev_get_priv(dev); + struct emc_regs *reg = priv->emc_regs_p; + u8 *enetaddr = pdata->enetaddr; + int ret; + + writel(readl(®->mcmdr) & ~MCMDR_TXON & ~MCMDR_RXON, ®->mcmdr); + + writel(readl(®->mcmdr) | MCMDR_SWR, ®->mcmdr); + do { + ret = readl(®->mcmdr); + } while (ret & MCMDR_SWR); + + npcm750_rx_descs_init(priv); + npcm750_tx_descs_init(priv); + + npcm750_set_cam(priv, priv->idx, enetaddr); + npcm750_set_global_maccmd(priv); + npcm750_set_fifo_threshold(priv); + + /* Start up the PHY */ + ret = phy_startup(priv->phydev); + if (ret) { + printf("Could not initialize PHY\n"); + return ret; + } + + npcm750_adjust_link(reg, priv->phydev); + writel(readl(®->mcmdr) | MCMDR_TXON | MCMDR_RXON, ®->mcmdr); + + return 0; +} + +static int npcm750_eth_send(struct udevice *dev, void *packet, int length) +{ + struct npcm750_eth_dev *priv = dev_get_priv(dev); + struct emc_regs *reg = priv->emc_regs_p; + struct npcm750_txbd *desc_p; + struct npcm750_txbd *next_desc_p; + + desc_p = priv->curr_txd; + + invalidate_dcache_range((ulong)desc_p, (ulong)(desc_p + 1)); + /* Check if the descriptor is owned by CPU */ + if (desc_p->mode & TX_OWEN_DMA) { + next_desc_p = (struct npcm750_txbd *)desc_p->next; + + while ((next_desc_p != desc_p) && (next_desc_p->mode & TX_OWEN_DMA)) + next_desc_p = (struct npcm750_txbd *)next_desc_p->next; + + if (next_desc_p == desc_p) { + struct emc_regs *reg = priv->emc_regs_p; + + writel(0, ®->tsdr); + serial_printf("TX: overflow and exit\n"); + return -EPERM; + } + + desc_p = next_desc_p; + } + + memcpy((void *)desc_p->buffer, packet, length); + flush_dcache_range((ulong)desc_p->buffer, + (ulong)desc_p->buffer + roundup(length, ARCH_DMA_MINALIGN)); + desc_p->sl = 0; + desc_p->sl = length & TX_STAT_TBC; + desc_p->mode = TX_OWEN_DMA | PADDINGMODE | CRCMODE; + flush_dcache_range((ulong)desc_p, (ulong)(desc_p + 1)); + + if (!(readl(®->mcmdr) & MCMDR_TXON)) + writel(readl(®->mcmdr) | MCMDR_TXON, ®->mcmdr); + priv->curr_txd = (struct npcm750_txbd *)priv->curr_txd->next; + + writel(0, ®->tsdr); + return 0; +} + +static int npcm750_eth_recv(struct udevice *dev, int flags, uchar **packetp) +{ + struct npcm750_eth_dev *priv = dev_get_priv(dev); + struct npcm750_rxbd *desc_p; + struct npcm750_rxbd *next_desc_p; + int length = -1; + + desc_p = priv->curr_rxd; + invalidate_dcache_range((ulong)desc_p, (ulong)(desc_p + 1)); + + if ((desc_p->sl & RX_STAT_OWNER) == RX_OWEN_DMA) { + next_desc_p = (struct npcm750_rxbd *)desc_p->next; + while ((next_desc_p != desc_p) && + ((next_desc_p->sl & RX_STAT_OWNER) == RX_OWEN_CPU)) { + next_desc_p = (struct npcm750_rxbd *)next_desc_p->next; + } + + if (next_desc_p == desc_p) { + struct emc_regs *reg = priv->emc_regs_p; + + writel(0, ®->rsdr); + serial_printf("RX: overflow and exit\n"); + return -EPERM; + } + desc_p = next_desc_p; + } + + /* Check if the descriptor is owned by CPU */ + if ((desc_p->sl & RX_STAT_OWNER) == RX_OWEN_CPU) { + if (desc_p->sl & RX_STAT_RXGD) { + length = desc_p->sl & RX_STAT_RBC; + invalidate_dcache_range((ulong)desc_p->buffer, + (ulong)(desc_p->buffer + roundup(length, + ARCH_DMA_MINALIGN))); + *packetp = (u8 *)(u32)desc_p->buffer; + priv->curr_rxd = desc_p; + } + } + return length; +} + +static int npcm750_eth_free_pkt(struct udevice *dev, uchar *packet, int length) +{ + struct npcm750_eth_dev *priv = dev_get_priv(dev); + struct emc_regs *reg = priv->emc_regs_p; + struct npcm750_rxbd *desc_p = priv->curr_rxd; + + /* + * Make the current descriptor valid again and go to + * the next one + */ + desc_p->sl |= RX_OWEN_DMA; + flush_dcache_range((ulong)desc_p, (ulong)(desc_p + 1)); + priv->curr_rxd = (struct npcm750_rxbd *)priv->curr_rxd->next; + writel(0, ®->rsdr); + + return 0; +} + +static void npcm750_eth_stop(struct udevice *dev) +{ + struct npcm750_eth_dev *priv = dev_get_priv(dev); + struct emc_regs *reg = priv->emc_regs_p; + + writel(readl(®->mcmdr) & ~MCMDR_TXON, ®->mcmdr); + writel(readl(®->mcmdr) & ~MCMDR_RXON, ®->mcmdr); + priv->curr_txd = (struct npcm750_txbd *)readl(®->txdlsa); + priv->curr_rxd = (struct npcm750_rxbd *)readl(®->rxdlsa); + phy_shutdown(priv->phydev); +} + +static int npcm750_eth_write_hwaddr(struct udevice *dev) +{ + struct eth_pdata *pdata = dev_get_plat(dev); + struct npcm750_eth_dev *priv = dev_get_priv(dev); + + npcm750_set_cam(priv, CAM0, pdata->enetaddr); + return 0; +} + +static int npcm750_eth_bind(struct udevice *dev) +{ + return 0; +} + +static int npcm750_eth_probe(struct udevice *dev) +{ + struct eth_pdata *pdata = dev_get_plat(dev); + struct npcm750_eth_dev *priv = dev_get_priv(dev); + u32 iobase = pdata->iobase; + int ret; + + memset(priv, 0, sizeof(struct npcm750_eth_dev)); + ret = dev_read_u32(dev, "id", &priv->idx); + if (ret) { + printf("failed to get id\n"); + return -EINVAL; + } + + priv->gcr_regmap = syscon_regmap_lookup_by_phandle(dev, "syscon-gcr"); + if (IS_ERR(priv->gcr_regmap)) + return -EINVAL; + + priv->emc_regs_p = (struct emc_regs *)iobase; + priv->interface = pdata->phy_interface; + priv->max_speed = pdata->max_speed; + + if (priv->idx == 0) { + /* Enable RMII for EMC1 module */ + regmap_update_bits(priv->gcr_regmap, GCR_INTCR, INTCR_R1EN, INTCR_R1EN); + } + + npcm750_mdio_init(dev->name, priv); + priv->bus = miiphy_get_dev_by_name(dev->name); + + ret = npcm750_phy_init(priv, dev); + + return ret; +} + +static int npcm750_eth_remove(struct udevice *dev) +{ + struct npcm750_eth_dev *priv = dev_get_priv(dev); + + free(priv->phydev); + mdio_unregister(priv->bus); + mdio_free(priv->bus); + + return 0; +} + +static const struct eth_ops npcm750_eth_ops = { + .start = npcm750_eth_start, + .send = npcm750_eth_send, + .recv = npcm750_eth_recv, + .free_pkt = npcm750_eth_free_pkt, + .stop = npcm750_eth_stop, + .write_hwaddr = npcm750_eth_write_hwaddr, +}; + +static int npcm750_eth_ofdata_to_platdata(struct udevice *dev) +{ + struct npcm750_eth_pdata *npcm750_pdata = dev_get_plat(dev); + struct eth_pdata *pdata = &npcm750_pdata->eth_pdata; + const char *phy_mode; + const fdt32_t *cell; + int ret = 0; + + pdata->iobase = (phys_addr_t)dev_read_addr_ptr(dev); + + pdata->phy_interface = -1; + phy_mode = fdt_getprop(gd->fdt_blob, dev_of_offset(dev), "phy-mode", NULL); + if (phy_mode) + pdata->phy_interface = phy_get_interface_by_name(phy_mode); + if (pdata->phy_interface == -1) { + printf("%s: Invalid PHY interface '%s'\n", __func__, phy_mode); + return -EINVAL; + } + + pdata->max_speed = 0; + cell = fdt_getprop(gd->fdt_blob, dev_of_offset(dev), "max-speed", NULL); + if (cell) + pdata->max_speed = fdt32_to_cpu(*cell); + + return ret; +} + +static const struct udevice_id npcm750_eth_ids[] = { + { .compatible = "nuvoton,npcm750-emc" }, + { } +}; + +U_BOOT_DRIVER(eth_npcm750) = { + .name = "eth_npcm750", + .id = UCLASS_ETH, + .of_match = npcm750_eth_ids, + .of_to_plat = npcm750_eth_ofdata_to_platdata, + .bind = npcm750_eth_bind, + .probe = npcm750_eth_probe, + .remove = npcm750_eth_remove, + .ops = &npcm750_eth_ops, + .priv_auto = sizeof(struct npcm750_eth_dev), + .plat_auto = sizeof(struct npcm750_eth_pdata), + .flags = DM_FLAG_ALLOC_PRIV_DMA, +};
+config NET_NPCM750
help
- Copyright (c) 2021 Nuvoton Technology Corp.
unsigned int sl;
unsigned int next;
unsigned int mode;
unsigned int sl;
unsigned int next;
+struct emc_regs {
u32 interface;
u32 max_speed;
u32 idx;
u32 start, val;
return val;
udelay(10);
return -ETIMEDOUT;
u16 val)
ulong start;
ret = 0;
break;
udelay(10);
return ret;
if (!bus) {
return -ENOMEM;
u32 idx;
desc_p->sl = 0;
desc_p->mode = 0;
else
u32 idx;
else
unsigned int val;
unsigned int val;
return;
val |= MCMDR_OPMOD;
else
if (phydev->duplex)
val |= MCMDR_FDUP;
else
val &= ~MCMDR_FDUP;
int ret;
u32 address = 0x0;
if (!phydev)
return -ENODEV;
if (ret)
return ret;
phy_config(phydev);
int ret;
do {
if (ret) {
return ret;
writel(0, ®->tsdr);
return -EPERM;
desc_p->sl = 0;
writel(0, ®->tsdr);
int length = -1;
writel(0, ®->rsdr);
return -EPERM;
return length;
* the next one
writel(0, ®->rsdr);
int ret;
if (ret) {
return -EINVAL;
return -EINVAL;
return ret;
free(priv->phydev);
int ret = 0;
if (phy_mode)
return -EINVAL;
if (cell)
return ret;
.id = UCLASS_ETH,
2.17.1
Reviewed-by: Ramon Fried rfried.dev@gmail.com
Signed-off-by: Jim Liu JJLIU0@nuvoton.com Reviewed-by: Ramon Fried rfried.dev@gmail.com
Jim Liu
Ramon Fried
