[U-Boot] [Patch v1] ARMV7: AM3517/05: Add support for CraneBoard.
It is a low cost reference design based on Sitara AM3517 SoC from Texas Instruments Please refer to <www.craneboard.org> for more details.
Signed-off-by: Srinath srinath@mistralsolutions.com --- MAINTAINERS | 4 + MAKEALL | 1 + board/ti/am3517crane/Makefile | 46 ++++ board/ti/am3517crane/am3517crane.c | 75 +++++++ board/ti/am3517crane/am3517crane.h | 395 ++++++++++++++++++++++++++++++++++++ board/ti/am3517crane/config.mk | 29 +++ boards.cfg | 1 + include/configs/am3517_crane.h | 340 +++++++++++++++++++++++++++++++ 8 files changed, 891 insertions(+), 0 deletions(-) create mode 100644 board/ti/am3517crane/Makefile create mode 100644 board/ti/am3517crane/am3517crane.c create mode 100644 board/ti/am3517crane/am3517crane.h create mode 100644 board/ti/am3517crane/config.mk create mode 100644 include/configs/am3517_crane.h
diff --git a/MAINTAINERS b/MAINTAINERS index 4756f14..13cbc95 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -726,6 +726,10 @@ Eric Millbrandt emillbrandt@dekaresearch.com
galaxy5200 mpc5200
+Nagendra T S nagendra@mistralsolutions.com + + am3517_crane ARM ARMV7 (AM35x SoC) + Rolf Offermanns rof@sysgo.de
shannon SA1100 diff --git a/MAKEALL b/MAKEALL index a732e6a..cb59b22 100755 --- a/MAKEALL +++ b/MAKEALL @@ -418,6 +418,7 @@ LIST_ARM11=" \ ## ARMV7 Systems ######################################################################### LIST_ARMV7=" \ + am3517_crane \ am3517_evm \ ca9x4_ct_vxp \ devkit8000 \ diff --git a/board/ti/am3517crane/Makefile b/board/ti/am3517crane/Makefile new file mode 100644 index 0000000..1fe2bca --- /dev/null +++ b/board/ti/am3517crane/Makefile @@ -0,0 +1,46 @@ +# +# Author: Srinath R srinath@mistralsolutions.com +# +# Based on logicpd/am3517evm/Makefile +# +# Copyright (C) 2011 Mistral Solutions Pvt Ltd +# +# This program is free software; you can redistribute it and/or modify +# it under the terms of the GNU General Public License as published by +# the Free Software Foundation; either version 2 of the License, or +# (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS := am3517crane.o + +SRCS := $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) + +$(LIB): $(obj).depend $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +clean: + rm -f $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend diff --git a/board/ti/am3517crane/am3517crane.c b/board/ti/am3517crane/am3517crane.c new file mode 100644 index 0000000..d007044 --- /dev/null +++ b/board/ti/am3517crane/am3517crane.c @@ -0,0 +1,75 @@ +/* + * am3517crane.c - board file for AM3517 CraneBoard + * + * Author: Srinath.R srinath@mistralsolutions.com + * + * Based on logicpd/am3517evm/am3517evm.c + * + * Copyright (C) 2011 Mistral Solutions Pvt Ltd + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/mem.h> +#include <asm/arch/mux.h> +#include <asm/arch/sys_proto.h> +#include <asm/mach-types.h> +#include <i2c.h> +#include "am3517crane.h" + +DECLARE_GLOBAL_DATA_PTR; + +/* + * Routine: board_init + * Description: Early hardware init. + */ +int board_init(void) +{ + gpmc_init(); /* in SRAM or SDRAM, finish GPMC */ + /* board id for Linux */ + gd->bd->bi_arch_number = MACH_TYPE_CRANEBOARD; + /* boot param addr */ + gd->bd->bi_boot_params = (OMAP34XX_SDRC_CS0 + 0x100); + + return 0; +} + +/* + * Routine: misc_init_r + * Description: Init i2c, ethernet, etc... (done here so udelay works) + */ +int misc_init_r(void) +{ +#ifdef CONFIG_DRIVER_OMAP34XX_I2C + i2c_init(CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE); +#endif + + dieid_num_r(); + + return 0; +} + +/* + * Routine: set_muxconf_regs + * Description: Setting up the configuration Mux registers specific to the + * hardware. Many pins need to be moved from protect to primary + * mode. + */ +void set_muxconf_regs(void) +{ + MUX_AM3517CRANE(); +} diff --git a/board/ti/am3517crane/am3517crane.h b/board/ti/am3517crane/am3517crane.h new file mode 100644 index 0000000..41db972 --- /dev/null +++ b/board/ti/am3517crane/am3517crane.h @@ -0,0 +1,395 @@ +/* + * am3517crane.h - Header file for the AM3517 CraneBoard. + * + * Author: Srinath R srinath@mistralsolutions.com + * + * Based on logicpd/am3517evm/am3517evm.h + * + * Copyright (C) 2011 Mistral Solutions Pvt Ltd + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#ifndef _AM3517CRANE_H_ +#define _AM3517CRANE_H_ + +const omap3_sysinfo sysinfo = { + DDR_DISCRETE, + "CraneBoard", + "NAND", +}; +/* AM3517 specific mux configuration */ +#define CONTROL_PADCONF_SYS_NRESWARM 0x0A08 +/* CCDC */ +#define CONTROL_PADCONF_CCDC_PCLK 0x01E4 +#define CONTROL_PADCONF_CCDC_FIELD 0x01E6 +#define CONTROL_PADCONF_CCDC_HD 0x01E8 +#define CONTROL_PADCONF_CCDC_VD 0x01EA +#define CONTROL_PADCONF_CCDC_WEN 0x01EC +#define CONTROL_PADCONF_CCDC_DATA0 0x01EE +#define CONTROL_PADCONF_CCDC_DATA1 0x01F0 +#define CONTROL_PADCONF_CCDC_DATA2 0x01F2 +#define CONTROL_PADCONF_CCDC_DATA3 0x01F4 +#define CONTROL_PADCONF_CCDC_DATA4 0x01F6 +#define CONTROL_PADCONF_CCDC_DATA5 0x01F8 +#define CONTROL_PADCONF_CCDC_DATA6 0x01FA +#define CONTROL_PADCONF_CCDC_DATA7 0x01FC +/* RMII */ +#define CONTROL_PADCONF_RMII_MDIO_DATA 0x01FE +#define CONTROL_PADCONF_RMII_MDIO_CLK 0x0200 +#define CONTROL_PADCONF_RMII_RXD0 0x0202 +#define CONTROL_PADCONF_RMII_RXD1 0x0204 +#define CONTROL_PADCONF_RMII_CRS_DV 0x0206 +#define CONTROL_PADCONF_RMII_RXER 0x0208 +#define CONTROL_PADCONF_RMII_TXD0 0x020A +#define CONTROL_PADCONF_RMII_TXD1 0x020C +#define CONTROL_PADCONF_RMII_TXEN 0x020E +#define CONTROL_PADCONF_RMII_50MHZ_CLK 0x0210 +#define CONTROL_PADCONF_USB0_DRVBUS 0x0212 +/* CAN */ +#define CONTROL_PADCONF_HECC1_TXD 0x0214 +#define CONTROL_PADCONF_HECC1_RXD 0x0216 +#define CONTROL_PADCONF_SYS_BOOT7 0x0218 +#define CONTROL_PADCONF_SDRC_DQS0N 0x021A +#define CONTROL_PADCONF_SDRC_DQS1N 0x021C +#define CONTROL_PADCONF_SDRC_DQS2N 0x021E +#define CONTROL_PADCONF_SDRC_DQS3N 0x0220 +#define CONTROL_PADCONF_STRBEN_DLY0 0x0222 +#define CONTROL_PADCONF_STRBEN_DLY1 0x0224 +#define CONTROL_PADCONF_SYS_BOOT8 0x0226 + +/* + * IEN - Input Enable + * IDIS - Input Disable + * PTD - Pull type Down + * PTU - Pull type Up + * DIS - Pull type selection is inactive + * EN - Pull type selection is active + * M0 - Mode 0 + * The commented string gives the final mux configuration for that pin + */ +#define MUX_AM3517CRANE()\ + /*SDRC*/\ + MUX_VAL(CP(SDRC_D0), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D1), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D2), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D3), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D4), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D5), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D6), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D7), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D8), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D9), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D10), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D11), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D12), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D13), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D14), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D15), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D16), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D17), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D18), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D19), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D20), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D21), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D22), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D23), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D24), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D25), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D26), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D27), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D28), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D29), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D30), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_D31), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_CLK), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_DQS0), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_CKE0), (M0))\ + MUX_VAL(CP(SDRC_DQS1), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_DQS2), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_DQS3), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SDRC_DQS0N), (IEN | PTD | EN | M0))\ + MUX_VAL(CP(SDRC_DQS1N), (IEN | PTD | EN | M0))\ + MUX_VAL(CP(SDRC_DQS2N), (IEN | PTD | EN | M0))\ + MUX_VAL(CP(SDRC_DQS3N), (IEN | PTD | EN | M0))\ + MUX_VAL(CP(SDRC_CKE0), (M0))\ + MUX_VAL(CP(SDRC_CKE1), (M0))\ + /*sdrc_strben_dly0*/\ + MUX_VAL(CP(STRBEN_DLY0), (IEN | PTD | EN | M0))\ + /*sdrc_strben_dly1*/\ + MUX_VAL(CP(STRBEN_DLY1), (IEN | PTD | EN | M0))\ + /*GPMC*/\ + MUX_VAL(CP(GPMC_A1), (M7))\ + MUX_VAL(CP(GPMC_A2), (IDIS | PTU | DIS | M4))\ + MUX_VAL(CP(GPMC_A3), (IDIS | PTU | EN | M4))\ + MUX_VAL(CP(GPMC_A4), (IDIS | PTU | EN | M4))\ + MUX_VAL(CP(GPMC_A5), (IDIS | PTU | EN | M4))\ + MUX_VAL(CP(GPMC_A6), (M7))\ + MUX_VAL(CP(GPMC_A7), (IDIS | PTU | EN | M4))\ + MUX_VAL(CP(GPMC_A8), (IEN | PTU | EN | M4))\ + MUX_VAL(CP(GPMC_A9), (M7))\ + MUX_VAL(CP(GPMC_A10), (M7))\ + MUX_VAL(CP(GPMC_D0), (IEN | PTU | EN | M0))\ + MUX_VAL(CP(GPMC_D1), (IEN | PTU | EN | M0))\ + MUX_VAL(CP(GPMC_D2), (IEN | PTU | EN | M0))\ + MUX_VAL(CP(GPMC_D3), (IEN | PTU | EN | M0))\ + MUX_VAL(CP(GPMC_D4), (IEN | PTU | EN | M0))\ + MUX_VAL(CP(GPMC_D5), (IEN | PTU | EN | M0))\ + MUX_VAL(CP(GPMC_D6), (IEN | PTU | EN | M0))\ + MUX_VAL(CP(GPMC_D7), (IEN | PTU | EN | M0))\ + MUX_VAL(CP(GPMC_D8), (IEN | PTU | EN | M0))\ + MUX_VAL(CP(GPMC_D9), (IEN | PTU | EN | M0))\ + MUX_VAL(CP(GPMC_D10), (IEN | PTU | EN | M0))\ + MUX_VAL(CP(GPMC_D11), (IEN | PTU | EN | M0))\ + MUX_VAL(CP(GPMC_D12), (IEN | PTU | EN | M0))\ + MUX_VAL(CP(GPMC_D13), (IEN | PTU | EN | M0))\ + MUX_VAL(CP(GPMC_D14), (IEN | PTU | EN | M0))\ + MUX_VAL(CP(GPMC_D15), (IEN | PTU | EN | M0))\ + MUX_VAL(CP(GPMC_NCS0), (IDIS | PTU | EN | M0))\ + MUX_VAL(CP(GPMC_NCS1), (IDIS | PTU | EN | M4))\ + MUX_VAL(CP(GPMC_NCS2), (M7))\ + MUX_VAL(CP(GPMC_NCS3), (M7))\ + MUX_VAL(CP(GPMC_NCS4), (M7))\ + MUX_VAL(CP(GPMC_NCS5), (M7))\ + MUX_VAL(CP(GPMC_NCS6), (M7))\ + MUX_VAL(CP(GPMC_NCS7), (M7))\ + MUX_VAL(CP(GPMC_CLK), (IDIS | PTU | EN | M0))/*TP*/\ + MUX_VAL(CP(GPMC_NADV_ALE), (IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(GPMC_NOE), (IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(GPMC_NWE), (IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(GPMC_NBE0_CLE), (IDIS | PTU | EN | M0))\ + MUX_VAL(CP(GPMC_NBE1), (M7))\ + MUX_VAL(CP(GPMC_NWP), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(GPMC_WAIT0), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(GPMC_WAIT1), (M7))\ + MUX_VAL(CP(GPMC_WAIT2), (M7))\ + MUX_VAL(CP(GPMC_WAIT3), (IDIS | PTU | EN | M4))/*GPIO_65*/\ + /*DSS*/\ + MUX_VAL(CP(DSS_PCLK), (IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(DSS_HSYNC), (IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(DSS_VSYNC), (IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(DSS_ACBIAS), (IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(DSS_DATA0), (IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(DSS_DATA1), (IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(DSS_DATA2), (IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(DSS_DATA3), (IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(DSS_DATA4), (IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(DSS_DATA5), (IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(DSS_DATA6), (IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(DSS_DATA7), (IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(DSS_DATA8), (IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(DSS_DATA9), (IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(DSS_DATA10), (IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(DSS_DATA11), (IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(DSS_DATA12), (IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(DSS_DATA13), (IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(DSS_DATA14), (IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(DSS_DATA15), (IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(DSS_DATA16), (IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(DSS_DATA17), (IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(DSS_DATA18), (IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(DSS_DATA19), (IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(DSS_DATA20), (IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(DSS_DATA21), (IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(DSS_DATA22), (IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(DSS_DATA23), (IDIS | PTD | DIS | M0))\ + /*MMC1*/\ + MUX_VAL(CP(MMC1_CLK), (IEN | PTU | EN | M0))\ + MUX_VAL(CP(MMC1_CMD), (IEN | PTU | DIS | M0))\ + MUX_VAL(CP(MMC1_DAT0), (IEN | PTU | DIS | M0))\ + MUX_VAL(CP(MMC1_DAT1), (IEN | PTU | DIS | M0))\ + MUX_VAL(CP(MMC1_DAT2), (IEN | PTU | DIS | M0))\ + MUX_VAL(CP(MMC1_DAT3), (IEN | PTU | DIS | M0))\ + MUX_VAL(CP(MMC1_DAT4), (IEN | PTU | DIS | M0))\ + MUX_VAL(CP(MMC1_DAT5), (IEN | PTU | DIS | M0))\ + MUX_VAL(CP(MMC1_DAT6), (IEN | PTU | DIS | M0))\ + MUX_VAL(CP(MMC1_DAT7), (IEN | PTU | DIS | M0))\ + /*MMC2*/\ + MUX_VAL(CP(MMC2_CLK), (IEN | PTD | EN | M0))\ + MUX_VAL(CP(MMC2_CMD), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(MMC2_DAT0), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(MMC2_DAT1), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(MMC2_DAT2), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(MMC2_DAT3), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(MMC2_DAT4), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(MMC2_DAT5), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(MMC2_DAT6), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(MMC2_DAT7), (IEN | PTD | DIS | M0))\ + /*McBSP*/\ + MUX_VAL(CP(MCBSP_CLKS), (IEN | PTU | DIS | M0))\ + MUX_VAL(CP(MCBSP1_CLKR), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(MCBSP1_FSR), (IDIS | PTU | EN | M0))\ + MUX_VAL(CP(MCBSP1_DX), (IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(MCBSP1_DR), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(MCBSP1_FSX), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(MCBSP1_CLKX), (IEN | PTD | DIS | M0))\ + \ + MUX_VAL(CP(MCBSP2_FSX), (M7))\ + MUX_VAL(CP(MCBSP2_CLKX), (M7))\ + MUX_VAL(CP(MCBSP2_DR), (M7))\ + MUX_VAL(CP(MCBSP2_DX), (M7))\ + \ + MUX_VAL(CP(MCBSP3_DX), (IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(MCBSP3_DR), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(MCBSP3_CLKX), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(MCBSP3_FSX), (IEN | PTD | DIS | M0))\ + \ + MUX_VAL(CP(MCBSP4_CLKX), (M7))\ + MUX_VAL(CP(MCBSP4_DR), (M7))\ + MUX_VAL(CP(MCBSP4_DX), (M7))\ + MUX_VAL(CP(MCBSP4_FSX), (M7))\ + /*UART*/\ + MUX_VAL(CP(UART1_TX), (M7))\ + MUX_VAL(CP(UART1_RTS), (M7))\ + MUX_VAL(CP(UART1_CTS), (M7))\ + MUX_VAL(CP(UART1_RX), (M7))\ + \ + MUX_VAL(CP(UART2_CTS), (M7))\ + MUX_VAL(CP(UART2_RTS), (M7))\ + MUX_VAL(CP(UART2_TX), (M7))\ + MUX_VAL(CP(UART2_RX), (M7))\ + \ + MUX_VAL(CP(UART3_CTS_RCTX), (IEN | PTU | DIS | M0))\ + MUX_VAL(CP(UART3_RTS_SD), (IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(UART3_RX_IRRX), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(UART3_TX_IRTX), (IDIS | PTD | DIS | M0))\ + /*I2C 1, 2, 3*/\ + MUX_VAL(CP(I2C1_SCL), (IEN | PTU | EN | M0))\ + MUX_VAL(CP(I2C1_SDA), (IEN | PTU | EN | M0))\ + MUX_VAL(CP(I2C2_SCL), (IEN | PTU | EN | M0))\ + MUX_VAL(CP(I2C2_SDA), (IEN | PTU | EN | M0))\ + MUX_VAL(CP(I2C3_SCL), (IEN | PTU | EN | M0))\ + MUX_VAL(CP(I2C3_SDA), (IEN | PTU | EN | M0))\ + /*McSPI*/\ + MUX_VAL(CP(MCSPI1_CLK), (IEN | PTU | EN | M4))/*GPIO_171 TP*/\ + MUX_VAL(CP(MCSPI1_SIMO), (IEN | PTU | EN | M4))/*GPIO_172 TP*/\ + MUX_VAL(CP(MCSPI1_SOMI), (IEN | PTU | EN | M4))/*GPIO_173 TP*/\ + MUX_VAL(CP(MCSPI1_CS0), (IEN | PTU | EN | M4))/*GPIO_174 TP*/\ + MUX_VAL(CP(MCSPI1_CS1), (IEN | PTU | EN | M4))/*GPIO_175 TP*/\ + MUX_VAL(CP(MCSPI1_CS2), (IEN | PTU | EN | M4))/*GPIO_176 TP*/\ + MUX_VAL(CP(MCSPI1_CS3), (IEN | PTD | EN | M4))/*GPIO_176 TP*/\ + \ + MUX_VAL(CP(MCSPI2_CLK), (M7))\ + MUX_VAL(CP(MCSPI2_SIMO), (M7))\ + MUX_VAL(CP(MCSPI2_SOMI), (M7))\ + MUX_VAL(CP(MCSPI2_CS0), (M7))\ + MUX_VAL(CP(MCSPI2_CS1), (M7))\ + /*CCDC*/\ + MUX_VAL(CP(CCDC_PCLK), (IEN | PTU | EN | M0))\ + MUX_VAL(CP(CCDC_FIELD), (IEN | PTD | DIS | M1))/*CCDC_DATA8*/\ + MUX_VAL(CP(CCDC_HD), (IEN | PTU | EN | M0))\ + MUX_VAL(CP(CCDC_VD), (IEN | PTU | EN | M0))\ + MUX_VAL(CP(CCDC_WEN), (IEN | PTD | DIS | M1))/*CCDC_DATA9 */\ + MUX_VAL(CP(CCDC_DATA0), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(CCDC_DATA1), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(CCDC_DATA2), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(CCDC_DATA3), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(CCDC_DATA4), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(CCDC_DATA5), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(CCDC_DATA6), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(CCDC_DATA7), (IEN | PTD | DIS | M0))\ + /*RMII*/\ + MUX_VAL(CP(RMII_MDIO_DATA), (IEN | M0))\ + MUX_VAL(CP(RMII_MDIO_CLK), (M0))\ + MUX_VAL(CP(RMII_RXD0), (IEN | PTD | M0))\ + MUX_VAL(CP(RMII_RXD1), (IEN | PTD | M0))\ + MUX_VAL(CP(RMII_CRS_DV), (IEN | PTD | M0))\ + MUX_VAL(CP(RMII_RXER), (PTD | M0))\ + MUX_VAL(CP(RMII_TXD0), (PTD | M0))\ + MUX_VAL(CP(RMII_TXD1), (PTD | M0))\ + MUX_VAL(CP(RMII_TXEN), (PTD | M0))\ + MUX_VAL(CP(RMII_50MHZ_CLK), (IEN | PTD | EN | M0))\ + /*HECC*/\ + MUX_VAL(CP(HECC1_TXD), (IEN | PTU | EN | M0))\ + MUX_VAL(CP(HECC1_RXD), (IEN | PTU | EN | M0))\ + /*HSUSB*/\ + MUX_VAL(CP(USB0_DRVBUS), (IEN | PTD | EN | M0))\ + /*HDQ*/\ + MUX_VAL(CP(HDQ_SIO), (IEN | PTU | EN | M4))\ + /*Control and debug*/\ + MUX_VAL(CP(SYS_32K), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SYS_CLKREQ), (IEN | PTD | DIS | M4))/*GPIO_1 TPS_SLEEP*/\ + MUX_VAL(CP(SYS_NIRQ), (IEN | PTU | EN | M0))\ + /*SYS_nRESWARM*/\ + MUX_VAL(CP(SYS_NRESWARM), (IEN | PTU | EN | M0))/*GPIO_30 ToExp*/\ + MUX_VAL(CP(SYS_BOOT1), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SYS_BOOT2), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SYS_BOOT3), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SYS_BOOT4), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SYS_BOOT5), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(SYS_BOOT6), (IDIS | PTD | DIS | M0))\ + MUX_VAL(CP(SYS_BOOT7), (IEN | PTD | EN | M0))\ + MUX_VAL(CP(SYS_BOOT8), (IEN | PTD | EN | M0))\ + MUX_VAL(CP(SYS_CLKOUT1), (IEN | PTD | DIS | M4))/*GPIO_10 TP*/\ + MUX_VAL(CP(SYS_CLKOUT2), (IEN | PTU | EN | M0))\ + /*JTAG*/\ + MUX_VAL(CP(JTAG_nTRST), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(JTAG_TCK), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(JTAG_TMS), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(JTAG_TDI), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(JTAG_EMU0), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(JTAG_EMU1), (IEN | PTD | DIS | M0))\ + /*ETK (ES2 onwards)*/\ + MUX_VAL(CP(ETK_CLK_ES2), (IEN | PTU | EN | M3))\ + MUX_VAL(CP(ETK_CTL_ES2), (IDIS | PTD | DIS | M3))\ + MUX_VAL(CP(ETK_D0_ES2), (IEN | PTD | DIS | M3))\ + MUX_VAL(CP(ETK_D1_ES2), (IEN | PTD | DIS | M3))\ + MUX_VAL(CP(ETK_D2_ES2), (IEN | PTD | EN | M3))\ + MUX_VAL(CP(ETK_D3_ES2), (IEN | PTD | DIS | M3))\ + MUX_VAL(CP(ETK_D4_ES2), (IEN | PTD | DIS | M3))\ + MUX_VAL(CP(ETK_D5_ES2), (IEN | PTD | DIS | M3))\ + MUX_VAL(CP(ETK_D6_ES2), (IEN | PTD | DIS | M3))\ + MUX_VAL(CP(ETK_D7_ES2), (IEN | PTD | DIS | M3))\ + MUX_VAL(CP(ETK_D8_ES2), (IEN | PTD | DIS | M3))\ + MUX_VAL(CP(ETK_D9_ES2), (IEN | PTD | DIS | M3))\ + MUX_VAL(CP(ETK_D10_ES2), (M7))\ + MUX_VAL(CP(ETK_D11_ES2), (M7))\ + MUX_VAL(CP(ETK_D12_ES2), (M7))\ + MUX_VAL(CP(ETK_D13_ES2), (M7))\ + MUX_VAL(CP(ETK_D14_ES2), (M7))\ + MUX_VAL(CP(ETK_D15_ES2), (M7))\ + /*Die to Die*/\ + MUX_VAL(CP(D2D_MCAD34), (IEN | PTD | EN | M0))\ + MUX_VAL(CP(D2D_MCAD35), (IEN | PTD | EN | M0))\ + MUX_VAL(CP(D2D_MCAD36), (IEN | PTD | EN | M0))\ + MUX_VAL(CP(D2D_CLK26MI), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(D2D_NRESPWRON), (IEN | PTD | EN | M0))\ + MUX_VAL(CP(D2D_NRESWARM), (IEN | PTU | EN | M0))\ + MUX_VAL(CP(D2D_ARM9NIRQ), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(D2D_UMA2P6FIQ), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(D2D_SPINT), (IEN | PTD | EN | M0))\ + MUX_VAL(CP(D2D_FRINT), (IEN | PTD | EN | M0))\ + MUX_VAL(CP(D2D_DMAREQ0), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(D2D_DMAREQ1), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(D2D_DMAREQ2), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(D2D_DMAREQ3), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(D2D_N3GTRST), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(D2D_N3GTDI), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(D2D_N3GTDO), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(D2D_N3GTMS), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(D2D_N3GTCK), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(D2D_N3GRTCK), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(D2D_MSTDBY), (IEN | PTU | EN | M0))\ + MUX_VAL(CP(D2D_SWAKEUP), (IEN | PTD | EN | M0))\ + MUX_VAL(CP(D2D_IDLEREQ), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(D2D_IDLEACK), (IEN | PTU | EN | M0))\ + MUX_VAL(CP(D2D_MWRITE), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(D2D_SWRITE), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(D2D_MREAD), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(D2D_SREAD), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(D2D_MBUSFLAG), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(D2D_SBUSFLAG), (IEN | PTD | DIS | M0))\ + +#endif /* _AM3517CRANE_H_ */ diff --git a/board/ti/am3517crane/config.mk b/board/ti/am3517crane/config.mk new file mode 100644 index 0000000..c6a18b5 --- /dev/null +++ b/board/ti/am3517crane/config.mk @@ -0,0 +1,29 @@ +# +# Author: Srinath R srinath@mistralsolutions.com +# +# Based on logicpd/am3517evm/config.mk +# +# Copyright (C) 2011 Mistral Solutions Pvt Ltd +# +# This program is free software; you can redistribute it and/or modify +# it under the terms of the GNU General Public License as published by +# the Free Software Foundation; either version 2 of the License, or +# (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. +# +# Physical Address: +# 8000'0000 (bank0) +# A000/0000 (bank1) +# Linux-Kernel is expected to be at 8000'8000, entry 8000'8000 +# (mem base + reserved) + +# For use with external or internal boots. +CONFIG_SYS_TEXT_BASE = 0x80008000 diff --git a/boards.cfg b/boards.cfg index 45c3102..fd5a6eb 100644 --- a/boards.cfg +++ b/boards.cfg @@ -116,6 +116,7 @@ omap3_overo arm armv7 overo - omap3_pandora arm armv7 pandora - omap3 igep0020 arm armv7 igep0020 isee omap3 igep0030 arm armv7 igep0030 isee omap3 +am3517_crane arm armv7 am3517crane ti omap3 am3517_evm arm armv7 am3517evm logicpd omap3 omap3_zoom1 arm armv7 zoom1 logicpd omap3 omap3_zoom2 arm armv7 zoom2 logicpd omap3 diff --git a/include/configs/am3517_crane.h b/include/configs/am3517_crane.h new file mode 100644 index 0000000..ef0c0a1 --- /dev/null +++ b/include/configs/am3517_crane.h @@ -0,0 +1,340 @@ +/* + * am3517_crane.h - Default configuration for AM3517 CraneBoard. + * + * Author: Srinath.R srinath@mistralsolutions.com + * + * Based on include/configs/am3517evm.h + * + * Copyright (C) 2011 Mistral Solutions pvt Ltd + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* + * High Level Configuration Options + */ +#define CONFIG_ARMV7 1 /* This is an ARM V7 CPU core */ +#define CONFIG_OMAP 1 /* in a TI OMAP core */ +#define CONFIG_OMAP34XX 1 /* which is a 34XX */ +#define CONFIG_OMAP3_AM3517CRANE 1 /* working with CRANEBOARD */ + +#define CONFIG_EMIF4 /* The chip has EMIF4 controller */ + +#include <asm/arch/cpu.h> /* get chip and board defs */ +#include <asm/arch/omap3.h> + +/* + * Display CPU and Board information + */ +#define CONFIG_DISPLAY_CPUINFO 1 +#define CONFIG_DISPLAY_BOARDINFO 1 + +/* Clock Defines */ +#define V_OSCK 26000000 /* Clock output from T2 */ +#define V_SCLK (V_OSCK >> 1) + +#undef CONFIG_USE_IRQ /* no support for IRQs */ +#define CONFIG_MISC_INIT_R + +#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_INITRD_TAG 1 +#define CONFIG_REVISION_TAG 1 + +/* + * Size of malloc() pool + */ +#define CONFIG_ENV_SIZE (128 << 10) /* 128 KiB sector */ +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (128 << 10)) + /* initial data */ +/* + * DDR related + */ +#define CONFIG_OMAP3_MICRON_DDR 1 /* Micron DDR */ +#define CONFIG_SYS_CS0_SIZE (256 * 1024 * 1024) + +/* + * Hardware drivers + */ + +/* + * NS16550 Configuration + */ +#define V_NS16550_CLK 48000000 /* 48MHz (APLL96/2) */ + +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE (-4) +#define CONFIG_SYS_NS16550_CLK V_NS16550_CLK + +/* + * select serial console configuration + */ +#define CONFIG_CONS_INDEX 3 +#define CONFIG_SYS_NS16550_COM3 OMAP34XX_UART3 +#define CONFIG_SERIAL3 3 /* UART3 on CRANEBOARD */ + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE {4800, 9600, 19200, 38400, 57600,\ + 115200} +#define CONFIG_MMC 1 +#define CONFIG_OMAP3_MMC 1 +#define CONFIG_DOS_PARTITION 1 + +/* + * USB configuration + * Enable CONFIG_MUSB_HCD for Host functionalities MSC, keyboard + * Enable CONFIG_MUSB_UDC for Device functionalities. + */ +#define CONFIG_USB_AM35X 1 +#define CONFIG_MUSB_HCD 1 + +#ifdef CONFIG_USB_AM35X + +#ifdef CONFIG_MUSB_HCD +#define CONFIG_CMD_USB + +#define CONFIG_USB_STORAGE +#define CONGIG_CMD_STORAGE +#define CONFIG_CMD_FAT + +#ifdef CONFIG_USB_KEYBOARD +#define CONFIG_SYS_USB_EVENT_POLL +#define CONFIG_PREBOOT "usb start" +#endif /* CONFIG_USB_KEYBOARD */ + +#endif /* CONFIG_MUSB_HCD */ + +#ifdef CONFIG_MUSB_UDC +/* USB device configuration */ +#define CONFIG_USB_DEVICE 1 +#define CONFIG_USB_TTY 1 +#define CONFIG_SYS_CONSOLE_IS_IN_ENV 1 +/* Change these to suit your needs */ +#define CONFIG_USBD_VENDORID 0x0451 +#define CONFIG_USBD_PRODUCTID 0x5678 +#define CONFIG_USBD_MANUFACTURER "Texas Instruments" +#define CONFIG_USBD_PRODUCT_NAME "AM3517CRANE" +#endif /* CONFIG_MUSB_UDC */ + +#endif /* CONFIG_USB_AM35X */ + +/* commands to include */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_EXT2 /* EXT2 Support */ +#define CONFIG_CMD_FAT /* FAT support */ +#define CONFIG_CMD_JFFS2 /* JFFS2 Support */ + +#define CONFIG_CMD_I2C /* I2C serial bus support */ +#define CONFIG_CMD_MMC /* MMC support */ +#define CONFIG_CMD_NAND /* NAND support */ +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_PING + +#undef CONFIG_CMD_FLASH /* flinfo, erase, protect */ +#undef CONFIG_CMD_FPGA /* FPGA configuration Support */ +#undef CONFIG_CMD_IMI /* iminfo */ +#undef CONFIG_CMD_IMLS /* List all found images */ + +#define CONFIG_SYS_NO_FLASH +#define CONFIG_HARD_I2C 1 +#define CONFIG_SYS_I2C_SPEED 100000 +#define CONFIG_SYS_I2C_SLAVE 1 +#define CONFIG_SYS_I2C_BUS 0 +#define CONFIG_SYS_I2C_BUS_SELECT 1 +#define CONFIG_DRIVER_OMAP34XX_I2C 1 + +#undef CONFIG_CMD_NET +#undef CONFIG_CMD_NFS +/* + * Board NAND Info. + */ +#define CONFIG_SYS_NAND_ADDR NAND_BASE /* physical address */ + /* to access nand */ +#define CONFIG_SYS_NAND_BASE NAND_BASE /* physical address */ + /* to access */ + /* nand at CS0 */ + +#define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of */ + /* NAND devices */ +#define CONFIG_SYS_64BIT_VSPRINTF /* needed for nand_util.c */ + +#define CONFIG_JFFS2_NAND +/* nand device jffs2 lives on */ +#define CONFIG_JFFS2_DEV "nand0" +/* start of jffs2 partition */ +#define CONFIG_JFFS2_PART_OFFSET 0x680000 +#define CONFIG_JFFS2_PART_SIZE 0xf980000 /* sz of jffs2 part */ + +/* Environment information */ +#define CONFIG_BOOTDELAY 10 + +#define CONFIG_BOOTFILE uImage + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "loadaddr=0x82000000\0" \ + "console=ttyS2,115200n8\0" \ + "mmcargs=setenv bootargs console=${console} " \ + "root=/dev/mmcblk0p2 rw " \ + "rootfstype=ext3 rootwait\0" \ + "nandargs=setenv bootargs console=${console} " \ + "root=/dev/mtdblock4 rw " \ + "rootfstype=jffs2\0" \ + "loadbootscript=fatload mmc 0 ${loadaddr} boot.scr\0" \ + "bootscript=echo Running bootscript from mmc ...; " \ + "source ${loadaddr}\0" \ + "loaduimage=fatload mmc 0 ${loadaddr} uImage\0" \ + "mmcboot=echo Booting from mmc ...; " \ + "run mmcargs; " \ + "bootm ${loadaddr}\0" \ + "nandboot=echo Booting from nand ...; " \ + "run nandargs; " \ + "nand read ${loadaddr} 280000 400000; " \ + "bootm ${loadaddr}\0" \ + +#define CONFIG_BOOTCOMMAND \ + "if mmc init; then " \ + "if run loadbootscript; then " \ + "run bootscript; " \ + "else " \ + "if run loaduimage; then " \ + "run mmcboot; " \ + "else run nandboot; " \ + "fi; " \ + "fi; " \ + "else run nandboot; fi" + +#define CONFIG_AUTO_COMPLETE 1 +/* + * Miscellaneous configurable options + */ +#define V_PROMPT "AM3517_CRANE # " + +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#define CONFIG_SYS_PROMPT V_PROMPT +#define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */ +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_MAXARGS 32 /* max number of command */ + /* args */ +/* Boot Argument Buffer Size */ +#define CONFIG_SYS_BARGSIZE (CONFIG_SYS_CBSIZE) +/* memtest works on */ +#define CONFIG_SYS_MEMTEST_START (OMAP34XX_SDRC_CS0) +#define CONFIG_SYS_MEMTEST_END (OMAP34XX_SDRC_CS0 + \ + 0x01F00000) /* 31MB */ + +#define CONFIG_SYS_LOAD_ADDR (OMAP34XX_SDRC_CS0) /* default load */ + /* address */ + +/* + * AM3517 has 12 GP timers, they can be driven by the system clock + * (12/13/16.8/19.2/38.4MHz) or by 32KHz clock. We use 13MHz (V_SCLK). + * This rate is divided by a local divisor. + */ +#define CONFIG_SYS_TIMERBASE OMAP34XX_GPT2 +#define CONFIG_SYS_PTV 2 /* Divisor: 2^(PTV+1) => 8 */ +#define CONFIG_SYS_HZ 1000 + +/*----------------------------------------------------------------------- + * Stack sizes + * + * The stack sizes are set up in start.S using the settings below + */ +#define CONFIG_STACKSIZE (128 << 10) /* regular stack 128 KiB */ +#ifdef CONFIG_USE_IRQ +#define CONFIG_STACKSIZE_IRQ (4 << 10) /* IRQ stack 4 KiB */ +#define CONFIG_STACKSIZE_FIQ (4 << 10) /* FIQ stack 4 KiB */ +#endif + +/*----------------------------------------------------------------------- + * Physical Memory Map + */ +#define CONFIG_NR_DRAM_BANKS 2 /* CS1 may or may not be populated */ +#define PHYS_SDRAM_1 OMAP34XX_SDRC_CS0 +#define PHYS_SDRAM_1_SIZE (32 << 20) /* at least 32 MiB */ +#define PHYS_SDRAM_2 OMAP34XX_SDRC_CS1 + +/* SDRAM Bank Allocation method */ +#define SDRC_R_B_C 1 + +/*----------------------------------------------------------------------- + * FLASH and environment organization + */ + +/* **** PISMO SUPPORT *** */ + +/* Configure the PISMO */ +#define PISMO1_NAND_SIZE GPMC_SIZE_128M +#define PISMO1_ONEN_SIZE GPMC_SIZE_128M + +#define CONFIG_SYS_MAX_FLASH_SECT 520 /* max number of sectors */ + /* on one chip */ +#define CONFIG_SYS_MAX_FLASH_BANKS 2 /* max number of flash banks */ +#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 2 sectors */ + +#define CONFIG_SYS_FLASH_BASE boot_flash_base + +/* Monitor at start of flash */ +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE + +#define CONFIG_NAND_OMAP_GPMC +#define GPMC_NAND_ECC_LP_x16_LAYOUT 1 +#define CONFIG_ENV_IS_IN_NAND 1 +#define SMNAND_ENV_OFFSET 0x260000 /* environment starts here */ + +#define CONFIG_SYS_ENV_SECT_SIZE boot_flash_sec +#define CONFIG_ENV_OFFSET boot_flash_off +#define CONFIG_ENV_ADDR boot_flash_env_addr + +/*----------------------------------------------------------------------- + * CFI FLASH driver setup + */ +/* timeout values are in ticks */ +#define CONFIG_SYS_FLASH_ERASE_TOUT (100 * CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_WRITE_TOUT (100 * CONFIG_SYS_HZ) + +/* Flash banks JFFS2 should use */ +#define CONFIG_SYS_MAX_MTD_BANKS (CONFIG_SYS_MAX_FLASH_BANKS + \ + CONFIG_SYS_MAX_NAND_DEVICE) +#define CONFIG_SYS_JFFS2_MEM_NAND +/* use flash_info[2] */ +#define CONFIG_SYS_JFFS2_FIRST_BANK CONFIG_SYS_MAX_FLASH_BANKS +#define CONFIG_SYS_JFFS2_NUM_BANKS 1 + +#ifndef __ASSEMBLY__ +extern unsigned int boot_flash_base; +extern volatile unsigned int boot_flash_env_addr; +extern unsigned int boot_flash_off; +extern unsigned int boot_flash_sec; +extern unsigned int boot_flash_type; +#endif + +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 +#define CONFIG_SYS_INIT_RAM_ADDR 0x4020f800 +#define CONFIG_SYS_INIT_RAM_SIZE 0x800 +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_INIT_RAM_ADDR + \ + CONFIG_SYS_INIT_RAM_SIZE - \ + GENERATED_GBL_DATA_SIZE) +#endif /* __CONFIG_H */
Dear Wolfgang,
I did not receive any comments for this patch, Please let us know your suggestions/comments/acceptance.
With Regards Srinath
-----Original Message----- From: srinath@mistralsolutions.com [mailto:srinath@mistralsolutions.com] Sent: Friday, April 01, 2011 6:13 PM To: u-boot@lists.denx.de Cc: wd@denx.de; nagendra@mistralsolutions.com; umeshk@mistralsolutions.com; Srinath Subject: [U-Boot][Patch v1] ARMV7: AM3517/05: Add support for CraneBoard.
galaxy5200 mpc5200
Pushed to u-boot-ti
http://git.denx.de/?p=u-boot/u-boot-ti.git;a=commitdiff;h=fd0962f6ab1ce44303...
Thanks, Sandeep
Paulraj, Sandeep
Srinath R
