[U-Boot] [PATCH] i2c: mv_i2c.c: Correct address endianness
0c0f719ad2f46c8566a56daee37ebdb7c078c3b1 accidentally changed the endianness of the i2c read and write addresses. This was noticable when accessing EEPROMs that use 2 byte addressing as the LSB was being sent first.
Signed-off-by: Bradley Bolen bradleybolen@gmail.com --- drivers/i2c/mv_i2c.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/i2c/mv_i2c.c b/drivers/i2c/mv_i2c.c index 7f52fa2..c780272 100644 --- a/drivers/i2c/mv_i2c.c +++ b/drivers/i2c/mv_i2c.c @@ -270,7 +270,7 @@ static int __i2c_read(struct mv_i2c *base, uchar chip, u8 *addr, int alen, msg.condition = I2C_COND_NORMAL; msg.acknack = I2C_ACKNAK_WAITACK; msg.direction = I2C_WRITE; - msg.data = *(addr++); + msg.data = addr[alen]; if (i2c_transfer(base, &msg)) return -1; } @@ -341,7 +341,7 @@ static int __i2c_write(struct mv_i2c *base, uchar chip, u8 *addr, int alen, msg.condition = I2C_COND_NORMAL; msg.acknack = I2C_ACKNAK_WAITACK; msg.direction = I2C_WRITE; - msg.data = *(addr++); + msg.data = addr[alen]; if (i2c_transfer(base, &msg)) return -1; }
if (i2c_transfer(base, &msg)) return -1; }msg.data = addr[alen];
Thanks for spotting:
Rewiewed-by: Stefan Roese sr@denx.de
Thanks, Stefan
Hello Stefan,
Am 19.12.2016 um 06:56 schrieb Stefan Roese:
}msg.data = addr[alen]; if (i2c_transfer(base, &msg)) return -1;
Typo ... I fix this when applying this patch.
Thanks!
bye, Heiko
Bradley Bolen
Heiko Schocher
Stefan Roese
