[U-Boot] 82xx serial, smc: add configurable SMC Rx buffer len
This patch adds the configuration option CONFIG_SYS_SMC_RXBUFLEN. With this option it is possible to allow the receive buffer for the SMC on 82xx to be greater then 1. In case CONFIG_SYS_SMC_RXBUFLEN == 1 this driver works as the old version.
When defining CONFIG_SYS_SMC_RXBUFLEN also CONFIG_SYS_MAXIDLE must be defined to setup the maximum idle timeout for the SMC.
Signed-off-by: Heiko Schocher hs@denx.de --- README | 8 ++++ cpu/mpc8260/serial_smc.c | 97 ++++++++++++++++++++++++++++----------------- 2 files changed, 68 insertions(+), 37 deletions(-)
diff --git a/README b/README index 86c1304..fbdccb0 100644 --- a/README +++ b/README @@ -484,6 +484,14 @@ The following options need to be configured: CONFIG_SYS_BAUDRATE_TABLE, see below. CONFIG_SYS_BRGCLK_PRESCALE, baudrate prescale
+- Console Rx buffer length + With CONFIG_SYS_SMC_RXBUFLEN it is possible to define + the maximum receive buffer length for the SMC. + This option is actual only for 82xx possible. + If using CONFIG_SYS_SMC_RXBUFLEN also CONFIG_SYS_MAXIDLE + must be defined, to setup the maximum idle timeout for + the SMC. + - Interrupt driven serial port input: CONFIG_SERIAL_SOFTWARE_FIFO
diff --git a/cpu/mpc8260/serial_smc.c b/cpu/mpc8260/serial_smc.c index a6efa66..794d6b3 100644 --- a/cpu/mpc8260/serial_smc.c +++ b/cpu/mpc8260/serial_smc.c @@ -64,6 +64,23 @@ DECLARE_GLOBAL_DATA_PTR;
#endif
+#if !defined(CONFIG_SYS_SMC_RXBUFLEN) +#define CONFIG_SYS_SMC_RXBUFLEN 1 +#define CONFIG_SYS_MAXIDLE 0 +#else +#if !defined(CONFIG_SYS_MAXIDLE) +#error "you must define CONFIG_SYS_MAXIDLE" +#endif +#endif + +typedef volatile struct serialbuffer { + cbd_t rxbd; /* Rx BD */ + cbd_t txbd; /* Tx BD */ + uint rxindex; /* index for next character to read */ + volatile uchar rxbuf[CONFIG_SYS_SMC_RXBUFLEN];/* rx buffers */ + volatile uchar txbuf; /* tx buffers */ +} serialbuffer_t; + /* map rs_table index to baud rate generator index */ static unsigned char brg_map[] = { 6, /* BRG7 for SMC1 */ @@ -79,9 +96,9 @@ int serial_init (void) volatile immap_t *im = (immap_t *)CONFIG_SYS_IMMR; volatile smc_t *sp; volatile smc_uart_t *up; - volatile cbd_t *tbdf, *rbdf; volatile cpm8260_t *cp = &(im->im_cpm); uint dpaddr; + volatile serialbuffer_t *rtx;
/* initialize pointers to SMC */
@@ -99,17 +116,21 @@ int serial_init (void) * damm: allocating space after the two buffers for rx/tx data */
- dpaddr = m8260_cpm_dpalloc((2 * sizeof (cbd_t)) + 2, 16); + /* allocate size of struct serialbuffer with bd rx/tx, + * buffer rx/tx and rx index + */ + dpaddr = m8260_cpm_dpalloc((sizeof(serialbuffer_t)), 16); + + rtx = (serialbuffer_t *)&im->im_dprambase[dpaddr];
/* Set the physical address of the host memory buffers in * the buffer descriptors. */ - rbdf = (cbd_t *)&im->im_dprambase[dpaddr]; - rbdf->cbd_bufaddr = (uint) (rbdf+2); - rbdf->cbd_sc = 0; - tbdf = rbdf + 1; - tbdf->cbd_bufaddr = ((uint) (rbdf+2)) + 1; - tbdf->cbd_sc = 0; + rtx->rxbd.cbd_bufaddr = (uint) &rtx->rxbuf; + rtx->rxbd.cbd_sc = 0; + + rtx->txbd.cbd_bufaddr = (uint) &rtx->txbuf; + rtx->txbd.cbd_sc = 0;
/* Set up the uart parameters in the parameter ram. */ @@ -142,13 +163,13 @@ int serial_init (void)
/* Make the first buffer the only buffer. */ - tbdf->cbd_sc |= BD_SC_WRAP; - rbdf->cbd_sc |= BD_SC_EMPTY | BD_SC_WRAP; + rtx->txbd.cbd_sc |= BD_SC_WRAP; + rtx->rxbd.cbd_sc |= BD_SC_EMPTY | BD_SC_WRAP;
- /* Single character receive. - */ - up->smc_mrblr = 1; - up->smc_maxidl = 0; + /* single/multi character receive. */ + up->smc_mrblr = CONFIG_SYS_SMC_RXBUFLEN; + up->smc_maxidl = CONFIG_SYS_MAXIDLE; + rtx->rxindex = 0;
/* Initialize Tx/Rx parameters. */ @@ -183,27 +204,23 @@ serial_setbrg (void) void serial_putc(const char c) { - volatile cbd_t *tbdf; - volatile char *buf; volatile smc_uart_t *up; volatile immap_t *im = (immap_t *)CONFIG_SYS_IMMR; + volatile serialbuffer_t *rtx;
if (c == '\n') serial_putc ('\r');
up = (smc_uart_t *)&(im->im_dprambase[PROFF_SMC]);
- tbdf = (cbd_t *)&im->im_dprambase[up->smc_tbase]; + rtx = (serialbuffer_t *)&im->im_dprambase[up->smc_rbase];
- /* Wait for last character to go. - */ - buf = (char *)tbdf->cbd_bufaddr; - while (tbdf->cbd_sc & BD_SC_READY) + /* Wait for last character to go. */ + while (rtx->txbd.cbd_sc & BD_SC_READY & BD_SC_READY) ; - - *buf = c; - tbdf->cbd_datlen = 1; - tbdf->cbd_sc |= BD_SC_READY; + rtx->txbuf = c; + rtx->txbd.cbd_datlen = 1; + rtx->txbd.cbd_sc |= BD_SC_READY; }
void @@ -217,39 +234,45 @@ serial_puts (const char *s) int serial_getc(void) { - volatile cbd_t *rbdf; - volatile unsigned char *buf; volatile smc_uart_t *up; volatile immap_t *im = (immap_t *)CONFIG_SYS_IMMR; - unsigned char c; + volatile serialbuffer_t *rtx; + unsigned char c;
- rbdf = (cbd_t *)&im->im_dprambase[up->smc_rbase]; + rtx = (serialbuffer_t *)&im->im_dprambase[up->smc_rbase];
/* Wait for character to show up. */ - buf = (unsigned char *)rbdf->cbd_bufaddr; - while (rbdf->cbd_sc & BD_SC_EMPTY) + while (rtx->rxbd.cbd_sc & BD_SC_EMPTY) ; - c = *buf; - rbdf->cbd_sc |= BD_SC_EMPTY;
+ /* the characters are read one by one, + * use the rxindex to know the next char to deliver + */ + c = *(unsigned char *) (rtx->rxbd.cbd_bufaddr + rtx->rxindex); + rtx->rxindex++; + + /* check if all char are readout, then make prepare for next receive */ + if (rtx->rxindex >= rtx->rxbd.cbd_datlen) { + rtx->rxindex = 0; + rtx->rxbd.cbd_sc |= BD_SC_EMPTY; + } return(c); }
int serial_tstc() { - volatile cbd_t *rbdf; volatile smc_uart_t *up; volatile immap_t *im = (immap_t *)CONFIG_SYS_IMMR; + volatile serialbuffer_t *rtx;
up = (smc_uart_t *)&(im->im_dprambase[PROFF_SMC]); + rtx = (serialbuffer_t *)&im->im_dprambase[up->smc_rbase];
- rbdf = (cbd_t *)&im->im_dprambase[up->smc_rbase]; - - return(!(rbdf->cbd_sc & BD_SC_EMPTY)); + return !(rtx->rxbd.cbd_sc & BD_SC_EMPTY); }
#endif /* CONFIG_CONS_ON_SMC */
Dear Heiko Schocher,
Applied, thanks.
Heiko Schocher
