[U-Boot] tools: socfpga: image installation script
Installing u-boot on socfpga is not trivial. Yes, it can be done with dd, but it is easy to make a typo and destroy a partition. Introduce a script that knows how to install all the copies, and actually checks signatures so that killing data is not trivial.
Signed-of-by: Pavel Machek pavel@denx.de
diff --git a/tools/socfpga_install b/tools/socfpga_install new file mode 100755 index 0000000..d02e73c --- /dev/null +++ b/tools/socfpga_install @@ -0,0 +1,50 @@ +#!/usr/bin/python3 +# Copyright 2015 Pavel Machek, Denx +# SPDX-License-Identifier: GPL-2.0+ +# +# Usage: sudo socfpga_install /dev/sdb3 u-boot-spl.bin u-boot-dts.img + +import subprocess +import sys +import os + +print("install device ", sys.argv[1]) +device = open(sys.argv[1], "r+b") + +sig = device.read(0x44) +if sig[0x40] != 0x41 or sig[0x41] != 0x53 or \ + sig[0x42] != 0x30 or sig[0x43] != 0x31: + print("Do not see AS01 signature, do you have right partition?") + sys.exit(1) +else: + print("Have partition with right signature") + +spl = sys.argv[2] +if spl == "_": + print("Skipping u-boot-spl installation") +else: + print("u-boot-spl.bin at ", spl) + + + res = subprocess.check_call(["tools/mkimage", "-T", "socfpgaimage", "-d", spl, "img.tmp"]) + if res != 0: + print("mkimage failed.") + sys.exit(1) + device.seek(0) + + spl_bin = open("img.tmp", "rb").read() + if len(spl_bin) != 65536: + print("Preloader image has wrong length.") + sys.exit(1) + + device.write(spl_bin) + device.write(spl_bin) + device.write(spl_bin) + device.write(spl_bin) + +print("u-boot.img at ", sys.argv[3]) +uboot_bin = open(sys.argv[3], "rb").read() +print("Have u-boot, %d bytes" % len(uboot_bin)) +device.seek(65536*4) +device.write(uboot_bin) +print("All done.")
This u-boot-spl.img and u-boot-dts.img is superseded by u-boot-with-spl.sfp for a long time. You can just dd that to partition 0xa2 and be done with it, no need to manually do what U-Boot buildsystem does for you.
- sig[0x42] != 0x30 or sig[0x43] != 0x31:
- print("Do not see AS01 signature, do you have right partition?")
- sys.exit(1)
+else:
- print("Have partition with right signature")
- print("Skipping u-boot-spl installation")
+else:
- print("u-boot-spl.bin at ", spl)
- res = subprocess.check_call(["tools/mkimage", "-T", "socfpgaimage", "-d", spl, "img.tmp"])
- if res != 0:
sys.exit(1)
- device.seek(0)
- spl_bin = open("img.tmp", "rb").read()
- if len(spl_bin) != 65536:
sys.exit(1)
- device.write(spl_bin)
Pavel Machek
