[U-Boot] [PATCH] mx5: Add HAB boot support
Add SEC_CONFIG[1] fuse checking.
Signed-off-by: Andrej Rosano andrej.rosano@f-secure.com --- arch/arm/mach-imx/Makefile | 5 +++++ arch/arm/mach-imx/hab.c | 5 +++++ arch/arm/mach-imx/mx5/soc.c | 8 ++++++++ drivers/crypto/fsl/Makefile | 2 ++ 4 files changed, 20 insertions(+)
diff --git a/arch/arm/mach-imx/Makefile b/arch/arm/mach-imx/Makefile index 95a542fa01..687c28c932 100644 --- a/arch/arm/mach-imx/Makefile +++ b/arch/arm/mach-imx/Makefile @@ -49,14 +49,19 @@ ifeq ($(SOC),$(filter $(SOC),mx7ulp)) obj-y += cache.o obj-$(CONFIG_SECURE_BOOT) += hab.o endif +ifeq ($(SOC),$(filter $(SOC),mx5)) +obj-$(CONFIG_SECURE_BOOT) += hab.o +endif ifeq ($(SOC),$(filter $(SOC),vf610)) obj-y += ddrmc-vf610.o endif ifneq ($(CONFIG_SPL_BUILD),y) obj-$(CONFIG_CMD_BMODE) += cmd_bmode.o obj-$(CONFIG_CMD_HDMIDETECT) += cmd_hdmidet.o +ifneq ($(SOC),$(filter $(SOC),mx5)) obj-$(CONFIG_CMD_DEKBLOB) += cmd_dek.o endif +endif
PLUGIN = board/$(BOARDDIR)/plugin
diff --git a/arch/arm/mach-imx/hab.c b/arch/arm/mach-imx/hab.c index 5f197775c1..a2b91af7d5 100644 --- a/arch/arm/mach-imx/hab.c +++ b/arch/arm/mach-imx/hab.c @@ -498,7 +498,9 @@ int imx_hab_authenticate_image(uint32_t ddr_start, uint32_t image_size, printf("\nAuthenticate image from DDR location 0x%x...\n", ddr_start);
+#if !defined(CONFIG_MX5) hab_caam_clock_enable(1); +#endif
/* Calculate IVT address header */ ivt_addr = ddr_start + ivt_offset; @@ -592,7 +594,10 @@ hab_exit_failure_print_status: #endif
hab_caam_clock_disable: + +#if !defined(CONFIG_MX5) hab_caam_clock_enable(0); +#endif
if (load_addr != 0) result = 0; diff --git a/arch/arm/mach-imx/mx5/soc.c b/arch/arm/mach-imx/mx5/soc.c index 2b63871bc4..fab3958702 100644 --- a/arch/arm/mach-imx/mx5/soc.c +++ b/arch/arm/mach-imx/mx5/soc.c @@ -15,11 +15,19 @@ #include <linux/errno.h> #include <asm/io.h> #include <asm/mach-imx/boot_mode.h> +#include <asm/mach-imx/hab.h>
#if !(defined(CONFIG_MX51) || defined(CONFIG_MX53)) #error "CPU_TYPE not defined" #endif
+#if defined(CONFIG_SECURE_BOOT) +struct imx_sec_config_fuse_t const imx_sec_config_fuse = { + .bank = 0, + .word = 4, +}; +#endif + u32 get_cpu_rev(void) { #ifdef CONFIG_MX51 diff --git a/drivers/crypto/fsl/Makefile b/drivers/crypto/fsl/Makefile index ea878e1822..13e4a95459 100644 --- a/drivers/crypto/fsl/Makefile +++ b/drivers/crypto/fsl/Makefile @@ -6,6 +6,8 @@
obj-y += sec.o obj-$(CONFIG_FSL_CAAM) += jr.o fsl_hash.o jobdesc.o error.o +ifneq ($(SOC),$(filter $(SOC),mx5)) obj-$(CONFIG_CMD_BLOB) += fsl_blob.o obj-$(CONFIG_CMD_DEKBLOB) += fsl_blob.o +endif obj-$(CONFIG_RSA_FREESCALE_EXP) += fsl_rsa.o
andrej.rosanoļ¼ f-secure.com
