[U-Boot] [PATCH] mx6slevk: Fix the reset delay for the the LAN8720 PHY
Since commit 59370f3fcd1350 ("net: phy: delay only if reset handler is registered") Ethernet is no longer functional.
This commit does not have an issue in itself, but it revelead a problem with the Ethernet initialization.
According to the LAN8720 datasheet tpurstd (time that reset line should stay asserted) is 25ms.
So do as suggested in order to have Ethernet working again.
Signed-off-by: Fabio Estevam fabio.estevam@nxp.com --- board/freescale/mx6slevk/mx6slevk.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/freescale/mx6slevk/mx6slevk.c b/board/freescale/mx6slevk/mx6slevk.c index 5eab4b5..721ec21 100644 --- a/board/freescale/mx6slevk/mx6slevk.c +++ b/board/freescale/mx6slevk/mx6slevk.c @@ -156,7 +156,7 @@ static void setup_iomux_fec(void)
/* Reset LAN8720 PHY */ gpio_direction_output(ETH_PHY_RESET , 0); - udelay(1000); + udelay(25000); gpio_set_value(ETH_PHY_RESET, 1); }
- udelay(1000);
- udelay(25000); gpio_set_value(ETH_PHY_RESET, 1);
Best regards, Stefano Babic
Fabio Estevam
Stefano Babic
