[PATCH 0/9] mmc: Aspeed fixes
These changes get the SDHCI hardware on the AST2600 and AST2500 working using the same device tree layout as upstream Linux.
The series has been tested on the Qemu models of the ast2500-evb and ast2600-evb, and tested on the ast2600a3-evb hardware.
Joel Stanley (9): ARM: dts: ast2600: Update SDHCI nodes ARM: dts: ast2500: Update SDHCI nodes clk/aspeed: Add debug message when clock fails clk/ast2600: Adjust eMMC clock names clk/ast2500: Add SD clock mmc/aspeed: Add debuging for clock probe failures mmc/aspeed: Probe from controller mmc/aspeed: Enable controller clocks config/ast2600: Enable eMMC related boot options
drivers/clk/aspeed/clk_ast2500.c | 26 +++++++++++++++ drivers/clk/aspeed/clk_ast2600.c | 8 ++--- drivers/mmc/aspeed_sdhci.c | 45 +++++++++++++++++++++++-- arch/arm/dts/ast2500-evb.dts | 4 +++ arch/arm/dts/ast2500-u-boot.dtsi | 25 -------------- arch/arm/dts/ast2500.dtsi | 28 ++++++++++++++++ arch/arm/dts/ast2600-evb.dts | 24 ++++++-------- arch/arm/dts/ast2600.dtsi | 57 ++++++++++++++------------------ configs/evb-ast2600_defconfig | 13 ++++++++ drivers/mmc/Kconfig | 1 + 10 files changed, 154 insertions(+), 77 deletions(-)
Match the description used by the Linux kernel, except use scu instead of syscon as the phandle.
Signed-off-by: Joel Stanley joel@jms.id.au --- arch/arm/dts/ast2600-evb.dts | 24 +++++++-------- arch/arm/dts/ast2600.dtsi | 57 +++++++++++++++--------------------- 2 files changed, 35 insertions(+), 46 deletions(-)
diff --git a/arch/arm/dts/ast2600-evb.dts b/arch/arm/dts/ast2600-evb.dts index 0d650543134a..47a0daa6dfbf 100644 --- a/arch/arm/dts/ast2600-evb.dts +++ b/arch/arm/dts/ast2600-evb.dts @@ -15,9 +15,9 @@ };
aliases { - mmc0 = &emmc_slot0; - mmc1 = &sdhci_slot0; - mmc2 = &sdhci_slot1; + mmc0 = &emmc; + mmc1 = &sdhci0; + mmc2 = &sdhci1; spi0 = &fmc; spi1 = &spi1; spi2 = &spi2; @@ -134,18 +134,16 @@ }; };
-&emmc { - u-boot,dm-pre-reloc; - timing-phase = <0x700ff>; + +&emmc_controller { + status = "okay"; };
-&emmc_slot0 { - u-boot,dm-pre-reloc; - status = "okay"; - bus-width = <4>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_emmc_default>; - sdhci-drive-type = <1>; +&emmc { + non-removable; + bus-width = <4>; + max-frequency = <100000000>; + clk-phase-mmc-hs200 = <9>, <225>; };
&i2c4 { diff --git a/arch/arm/dts/ast2600.dtsi b/arch/arm/dts/ast2600.dtsi index 64074309b7b2..3161e76941fd 100644 --- a/arch/arm/dts/ast2600.dtsi +++ b/arch/arm/dts/ast2600.dtsi @@ -416,60 +416,51 @@ status = "disabled"; };
- sdhci: sdhci@1e740000 { - #interrupt-cells = <1>; - compatible = "aspeed,aspeed-sdhci-irq", "simple-mfd"; - reg = <0x1e740000 0x1000>; - interrupts = <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>; - interrupt-controller; - clocks = <&scu ASPEED_CLK_GATE_SDCLK>, - <&scu ASPEED_CLK_GATE_SDEXTCLK>; - clock-names = "ctrlclk", "extclk"; + sdc: sdc@1e740000 { + compatible = "aspeed,ast2600-sd-controller"; + reg = <0x1e740000 0x100>; #address-cells = <1>; #size-cells = <1>; - ranges = <0x0 0x1e740000 0x1000>; + ranges = <0 0x1e740000 0x10000>; + clocks = <&scu ASPEED_CLK_GATE_SDCLK>; + status = "disabled";
- sdhci_slot0: sdhci_slot0@100 { - compatible = "aspeed,sdhci-ast2600"; + sdhci0: sdhci@1e740100 { + compatible = "aspeed,ast2600-sdhci", "sdhci"; reg = <0x100 0x100>; - interrupts = <0>; - interrupt-parent = <&sdhci>; + interrupts = <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>; sdhci,auto-cmd12; clocks = <&scu ASPEED_CLK_SDIO>; status = "disabled"; };
- sdhci_slot1: sdhci_slot1@200 { - compatible = "aspeed,sdhci-ast2600"; + sdhci1: sdhci@1e740200 { + compatible = "aspeed,ast2600-sdhci", "sdhci"; reg = <0x200 0x100>; - interrupts = <1>; - interrupt-parent = <&sdhci>; + interrupts = <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>; sdhci,auto-cmd12; clocks = <&scu ASPEED_CLK_SDIO>; status = "disabled"; }; };
- emmc: emmc@1e750000 { - #interrupt-cells = <1>; - compatible = "aspeed,aspeed-emmc-irq", "simple-mfd"; - reg = <0x1e750000 0x1000>; - interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>; - interrupt-controller; - clocks = <&scu ASPEED_CLK_GATE_EMMCCLK>, - <&scu ASPEED_CLK_GATE_EMMCEXTCLK>; - clock-names = "ctrlclk", "extclk"; + emmc_controller: sdc@1e750000 { + compatible = "aspeed,ast2600-sd-controller"; + reg = <0x1e750000 0x100>; #address-cells = <1>; #size-cells = <1>; - ranges = <0x0 0x1e750000 0x1000>; + ranges = <0 0x1e750000 0x10000>; + clocks = <&scu ASPEED_CLK_GATE_EMMCCLK>; + status = "disabled";
- emmc_slot0: emmc_slot0@100 { - compatible = "aspeed,emmc-ast2600"; + emmc: sdhci@1e750100 { + compatible = "aspeed,ast2600-sdhci"; reg = <0x100 0x100>; - interrupts = <0>; - interrupt-parent = <&emmc>; + sdhci,auto-cmd12; + interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>; clocks = <&scu ASPEED_CLK_EMMC>; - status = "disabled"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_emmc_default>; }; };
Joel Stanley
