[U-Boot] [PATCH u-boot v3 0/3] Add Amlogic Meson SPI Flash Controller driver
The Amlogic Meson SoCs embeds a Flash oriented SPI Controller name SPIFC.
This patchset add the driver ported from linux, but also import the regmap regmap_read_poll_timeout() to implify the register polling in the driver.
Neil Armstrong (3): regmap: add regmap_read_poll_timeout() helper test: regmap: add regmap_read_poll_timeout test spi: Add Amlogic Meson SPI Flash Controller driver
drivers/spi/Kconfig | 8 + drivers/spi/Makefile | 1 + drivers/spi/meson_spifc.c | 320 ++++++++++++++++++++++++++++++++++++++ include/regmap.h | 38 +++++ test/dm/regmap.c | 26 ++++ 5 files changed, 393 insertions(+) create mode 100644 drivers/spi/meson_spifc.c
Add the regmap_read_poll_timeout() macro based on the Linux implementation to simplify register polling with configurable timeout and sleep.
Acked-by: Jagan Teki jagan@openedev.com Signed-off-by: Neil Armstrong narmstrong@baylibre.com --- include/regmap.h | 38 ++++++++++++++++++++++++++++++++++++++ 1 file changed, 38 insertions(+)
diff --git a/include/regmap.h b/include/regmap.h index b2b733fda6..a3afb72df5 100644 --- a/include/regmap.h +++ b/include/regmap.h @@ -239,6 +239,44 @@ int regmap_raw_read_range(struct regmap *map, uint range_num, uint offset, #define regmap_get(map, type, member, valp) \ regmap_range_get(map, 0, type, member, valp)
+/** + * regmap_read_poll_timeout - Poll until a condition is met or a timeout occurs + * + * @map: Regmap to read from + * @addr: Offset to poll + * @val: Unsigned integer variable to read the value into + * @cond: Break condition (usually involving @val) + * @sleep_us: Maximum time to sleep between reads in us (0 tight-loops). + * @timeout_ms: Timeout in ms, 0 means never timeout + * + * Returns 0 on success and -ETIMEDOUT upon a timeout or the regmap_read + * error return value in case of a error read. In the two former cases, + * the last read value at @addr is stored in @val. Must not be called + * from atomic context if sleep_us or timeout_us are used. + * + * This is modelled after the regmap_read_poll_timeout macros in linux but + * with millisecond timeout. + */ +#define regmap_read_poll_timeout(map, addr, val, cond, sleep_us, timeout_ms) \ +({ \ + unsigned long __start = get_timer(0); \ + int __ret; \ + for (;;) { \ + __ret = regmap_read((map), (addr), &(val)); \ + if (__ret) \ + break; \ + if (cond) \ + break; \ + if ((timeout_ms) && get_timer(__start) > (timeout_ms)) { \ + __ret = regmap_read((map), (addr), &(val)); \ + break; \ + } \ + if ((sleep_us)) \ + udelay((sleep_us)); \ + } \ + __ret ?: ((cond) ? 0 : -ETIMEDOUT); \ +}) + /** * regmap_update_bits() - Perform a read/modify/write using a mask *
Hi Neil,
Is there a change log somewhere? This is v3.
Hi Simon,
On 27/11/2018 02:02, Simon Glass wrote:
Hi Neil,
Forgot changelog on cover letter, v3 only changes the SPI driver, the regmap patches are only rebased against master.
Neil
Add test to regmap_read_poll_timeout() helper to check the timeout works properly but cannot test proper condition matching since read/write calls are not executed in sandbox.
Acked-by: Jagan Teki jagan@openedev.com Signed-off-by: Neil Armstrong narmstrong@baylibre.com --- test/dm/regmap.c | 26 ++++++++++++++++++++++++++ 1 file changed, 26 insertions(+)
diff --git a/test/dm/regmap.c b/test/dm/regmap.c index a8d7e6829e..9a70c159dd 100644 --- a/test/dm/regmap.c +++ b/test/dm/regmap.c @@ -144,3 +144,29 @@ static int dm_test_regmap_getset(struct unit_test_state *uts) }
DM_TEST(dm_test_regmap_getset, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); + +/* Read polling test */ +static int dm_test_regmap_poll(struct unit_test_state *uts) +{ + struct udevice *dev; + struct regmap *map; + uint reg; + unsigned long start; + + ut_assertok(uclass_get_device(UCLASS_SYSCON, 0, &dev)); + map = syscon_get_regmap(dev); + ut_assertok_ptr(map); + + start = get_timer(0); + + ut_asserteq(-ETIMEDOUT, + regmap_read_poll_timeout(map, 0, reg, + (reg == 0xcacafafa), + 1, 5 * CONFIG_SYS_HZ)); + + ut_assert(get_timer(start) > (5 * CONFIG_SYS_HZ)); + + return 0; +} + +DM_TEST(dm_test_regmap_poll, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT);
The Amlogic Meson SoCs embeds a Flash oriented SPI Controller name SPIFC. This driver, ported from the Linux meson-spi-spifc driver, add support for this controller on the Amlogic Meson GX SoCs in U-Boot.
Reviewed-by: Jagan Teki jagan@openedev.com Signed-off-by: Neil Armstrong narmstrong@baylibre.com --- drivers/spi/Kconfig | 8 + drivers/spi/Makefile | 1 + drivers/spi/meson_spifc.c | 320 ++++++++++++++++++++++++++++++++++++++ 3 files changed, 329 insertions(+) create mode 100644 drivers/spi/meson_spifc.c
diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index 516188ea88..6085788481 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -116,6 +116,14 @@ config ICH_SPI access the SPI NOR flash on platforms embedding this Intel ICH IP core.
+config MESON_SPIFC + bool "Amlogic Meson SPI Flash Controller driver" + depends on ARCH_MESON + help + Enable the Amlogic Meson SPI Flash Controller SPIFC) driver. + This driver can be used to access the SPI NOR flash chips on + Amlogic Meson SoCs. + config MT7621_SPI bool "MediaTek MT7621 SPI driver" depends on ARCH_MT7620 diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index 7242ea7e40..67b42daf4e 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -31,6 +31,7 @@ obj-$(CONFIG_FSL_QSPI) += fsl_qspi.o obj-$(CONFIG_ICH_SPI) += ich.o obj-$(CONFIG_KIRKWOOD_SPI) += kirkwood_spi.o obj-$(CONFIG_LPC32XX_SSP) += lpc32xx_ssp.o +obj-$(CONFIG_MESON_SPIFC) += meson_spifc.o obj-$(CONFIG_MPC8XX_SPI) += mpc8xx_spi.o obj-$(CONFIG_MPC8XXX_SPI) += mpc8xxx_spi.o obj-$(CONFIG_MT7621_SPI) += mt7621_spi.o diff --git a/drivers/spi/meson_spifc.c b/drivers/spi/meson_spifc.c new file mode 100644 index 0000000000..3d551694cb --- /dev/null +++ b/drivers/spi/meson_spifc.c @@ -0,0 +1,320 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2014 Beniamino Galvani b.galvani@gmail.com + * Copyright (C) 2018 BayLibre, SAS + * Author: Neil Armstrong narmstrong@baylibre.com + * + * Amlogic Meson SPI Flash Controller driver + */ + +#include <common.h> +#include <spi.h> +#include <clk.h> +#include <dm.h> +#include <regmap.h> +#include <errno.h> +#include <asm/io.h> +#include <linux/bitfield.h> + +/* register map */ +#define REG_CMD 0x00 +#define REG_ADDR 0x04 +#define REG_CTRL 0x08 +#define REG_CTRL1 0x0c +#define REG_STATUS 0x10 +#define REG_CTRL2 0x14 +#define REG_CLOCK 0x18 +#define REG_USER 0x1c +#define REG_USER1 0x20 +#define REG_USER2 0x24 +#define REG_USER3 0x28 +#define REG_USER4 0x2c +#define REG_SLAVE 0x30 +#define REG_SLAVE1 0x34 +#define REG_SLAVE2 0x38 +#define REG_SLAVE3 0x3c +#define REG_C0 0x40 +#define REG_B8 0x60 +#define REG_MAX 0x7c + +/* register fields */ +#define CMD_USER BIT(18) +#define CTRL_ENABLE_AHB BIT(17) +#define CLOCK_SOURCE BIT(31) +#define CLOCK_DIV_SHIFT 12 +#define CLOCK_DIV_MASK (0x3f << CLOCK_DIV_SHIFT) +#define CLOCK_CNT_HIGH_SHIFT 6 +#define CLOCK_CNT_HIGH_MASK (0x3f << CLOCK_CNT_HIGH_SHIFT) +#define CLOCK_CNT_LOW_SHIFT 0 +#define CLOCK_CNT_LOW_MASK (0x3f << CLOCK_CNT_LOW_SHIFT) +#define USER_DIN_EN_MS BIT(0) +#define USER_CMP_MODE BIT(2) +#define USER_CLK_NOT_INV BIT(7) +#define USER_UC_DOUT_SEL BIT(27) +#define USER_UC_DIN_SEL BIT(28) +#define USER_UC_MASK ((BIT(5) - 1) << 27) +#define USER1_BN_UC_DOUT_SHIFT 17 +#define USER1_BN_UC_DOUT_MASK (0xff << 16) +#define USER1_BN_UC_DIN_SHIFT 8 +#define USER1_BN_UC_DIN_MASK (0xff << 8) +#define USER4_CS_POL_HIGH BIT(23) +#define USER4_IDLE_CLK_HIGH BIT(29) +#define USER4_CS_ACT BIT(30) +#define SLAVE_TRST_DONE BIT(4) +#define SLAVE_OP_MODE BIT(30) +#define SLAVE_SW_RST BIT(31) + +#define SPIFC_BUFFER_SIZE 64 + +struct meson_spifc_priv { + struct regmap *regmap; + struct clk clk; +}; + +/** + * meson_spifc_drain_buffer() - copy data from device buffer to memory + * @spifc: the Meson SPI device + * @buf: the destination buffer + * @len: number of bytes to copy + */ +static void meson_spifc_drain_buffer(struct meson_spifc_priv *spifc, + u8 *buf, int len) +{ + u32 data; + int i = 0; + + while (i < len) { + regmap_read(spifc->regmap, REG_C0 + i, &data); + + if (len - i >= 4) { + *((u32 *)buf) = data; + buf += 4; + } else { + memcpy(buf, &data, len - i); + break; + } + i += 4; + } +} + +/** + * meson_spifc_fill_buffer() - copy data from memory to device buffer + * @spifc: the Meson SPI device + * @buf: the source buffer + * @len: number of bytes to copy + */ +static void meson_spifc_fill_buffer(struct meson_spifc_priv *spifc, + const u8 *buf, int len) +{ + u32 data = 0; + int i = 0; + + while (i < len) { + if (len - i >= 4) + data = *(u32 *)buf; + else + memcpy(&data, buf, len - i); + + regmap_write(spifc->regmap, REG_C0 + i, data); + + buf += 4; + i += 4; + } +} + +/** + * meson_spifc_txrx() - transfer a chunk of data + * @spifc: the Meson SPI device + * @dout: data buffer for TX + * @din: data buffer for RX + * @offset: offset of the data to transfer + * @len: length of the data to transfer + * @last_xfer: whether this is the last transfer of the message + * @last_chunk: whether this is the last chunk of the transfer + * Return: 0 on success, a negative value on error + */ +static int meson_spifc_txrx(struct meson_spifc_priv *spifc, + const u8 *dout, u8 *din, int offset, + int len, bool last_xfer, bool last_chunk) +{ + bool keep_cs = true; + u32 data; + int ret; + + if (dout) + meson_spifc_fill_buffer(spifc, dout + offset, len); + + /* enable DOUT stage */ + regmap_update_bits(spifc->regmap, REG_USER, USER_UC_MASK, + USER_UC_DOUT_SEL); + regmap_write(spifc->regmap, REG_USER1, + (8 * len - 1) << USER1_BN_UC_DOUT_SHIFT); + + /* enable data input during DOUT */ + regmap_update_bits(spifc->regmap, REG_USER, USER_DIN_EN_MS, + USER_DIN_EN_MS); + + if (last_chunk && last_xfer) + keep_cs = false; + + regmap_update_bits(spifc->regmap, REG_USER4, USER4_CS_ACT, + keep_cs ? USER4_CS_ACT : 0); + + /* clear transition done bit */ + regmap_update_bits(spifc->regmap, REG_SLAVE, SLAVE_TRST_DONE, 0); + /* start transfer */ + regmap_update_bits(spifc->regmap, REG_CMD, CMD_USER, CMD_USER); + + /* wait for the current operation to terminate */ + ret = regmap_read_poll_timeout(spifc->regmap, REG_SLAVE, data, + (data & SLAVE_TRST_DONE), + 0, 5 * CONFIG_SYS_HZ); + + if (!ret && din) + meson_spifc_drain_buffer(spifc, din + offset, len); + + return ret; +} + +/** + * meson_spifc_xfer() - perform a single transfer + * @dev: the SPI controller device + * @bitlen: length of the transfer + * @dout: data buffer for TX + * @din: data buffer for RX + * @flags: transfer flags + * Return: 0 on success, a negative value on error + */ +static int meson_spifc_xfer(struct udevice *slave, unsigned int bitlen, + const void *dout, void *din, unsigned long flags) +{ + struct meson_spifc_priv *spifc = dev_get_priv(slave->parent); + int blen = bitlen / 8; + int len, done = 0, ret = 0; + + if (bitlen % 8) + return -EINVAL; + + debug("xfer len %d (%d) dout %p din %p\n", bitlen, blen, dout, din); + + regmap_update_bits(spifc->regmap, REG_CTRL, CTRL_ENABLE_AHB, 0); + + while (done < blen && !ret) { + len = min_t(int, blen - done, SPIFC_BUFFER_SIZE); + ret = meson_spifc_txrx(spifc, dout, din, done, len, + flags & SPI_XFER_END, + done + len >= blen); + done += len; + } + + regmap_update_bits(spifc->regmap, REG_CTRL, CTRL_ENABLE_AHB, + CTRL_ENABLE_AHB); + + return ret; +} + +/** + * meson_spifc_set_speed() - program the clock divider + * @dev: the SPI controller device + * @speed: desired speed in Hz + */ +static int meson_spifc_set_speed(struct udevice *dev, uint speed) +{ + struct meson_spifc_priv *spifc = dev_get_priv(dev); + unsigned long parent, value; + int n; + + parent = clk_get_rate(&spifc->clk); + n = max_t(int, parent / speed - 1, 1); + + debug("parent %lu, speed %u, n %d\n", parent, speed, n); + + value = (n << CLOCK_DIV_SHIFT) & CLOCK_DIV_MASK; + value |= (n << CLOCK_CNT_LOW_SHIFT) & CLOCK_CNT_LOW_MASK; + value |= (((n + 1) / 2 - 1) << CLOCK_CNT_HIGH_SHIFT) & + CLOCK_CNT_HIGH_MASK; + + regmap_write(spifc->regmap, REG_CLOCK, value); + + return 0; +} + +/** + * meson_spifc_set_mode() - setups the SPI bus mode + * @dev: the SPI controller device + * @mode: desired mode bitfield + * Return: 0 on success, -ENODEV on error + */ +static int meson_spifc_set_mode(struct udevice *dev, uint mode) +{ + struct meson_spifc_priv *spifc = dev_get_priv(dev); + + if (mode & (SPI_CPHA | SPI_RX_QUAD | SPI_RX_DUAL | + SPI_TX_QUAD | SPI_TX_DUAL)) + return -ENODEV; + + regmap_update_bits(spifc->regmap, REG_USER, USER_CLK_NOT_INV, + mode & SPI_CPOL ? USER_CLK_NOT_INV : 0); + + regmap_update_bits(spifc->regmap, REG_USER4, USER4_CS_POL_HIGH, + mode & SPI_CS_HIGH ? USER4_CS_POL_HIGH : 0); + + return 0; +} + +/** + * meson_spifc_hw_init() - reset and initialize the SPI controller + * @spifc: the Meson SPI device + */ +static void meson_spifc_hw_init(struct meson_spifc_priv *spifc) +{ + /* reset device */ + regmap_update_bits(spifc->regmap, REG_SLAVE, SLAVE_SW_RST, + SLAVE_SW_RST); + /* disable compatible mode */ + regmap_update_bits(spifc->regmap, REG_USER, USER_CMP_MODE, 0); + /* set master mode */ + regmap_update_bits(spifc->regmap, REG_SLAVE, SLAVE_OP_MODE, 0); +} + +static const struct dm_spi_ops meson_spifc_ops = { + .xfer = meson_spifc_xfer, + .set_speed = meson_spifc_set_speed, + .set_mode = meson_spifc_set_mode, +}; + +static int meson_spifc_probe(struct udevice *dev) +{ + struct meson_spifc_priv *priv = dev_get_priv(dev); + int ret; + + ret = regmap_init_mem(dev_ofnode(dev), &priv->regmap); + if (ret) + return ret; + + ret = clk_get_by_index(dev, 0, &priv->clk); + if (ret) + return ret; + + ret = clk_enable(&priv->clk); + if (ret) + return ret; + + meson_spifc_hw_init(priv); + + return 0; +} + +static const struct udevice_id meson_spifc_ids[] = { + { .compatible = "amlogic,meson-gxbb-spifc", }, + { } +}; + +U_BOOT_DRIVER(meson_spifc) = { + .name = "meson_spifc", + .id = UCLASS_SPI, + .of_match = meson_spifc_ids, + .ops = &meson_spifc_ops, + .probe = meson_spifc_probe, + .priv_auto_alloc_size = sizeof(struct meson_spifc_priv), +};
On Thu, Nov 22, 2018 at 3:31 PM Neil Armstrong narmstrong@baylibre.com wrote:
Applied to u-boot-spi/master
Jagan Teki
Neil Armstrong
