[U-Boot] [PATCH v1 0/3] New tag for Flattened Image Trees (FIT) - Booting Xen from a FIT.
The FIT config now supports a tag named "loadables:" which is a comma separated list. Users can add any number of images to the list, and u-boot will move the selected binaries to their listed load_addresses. This allows u-boot to boot xen from using an FIT configuration. Xen expects a kernel to be placed at a predetermined location, however the "kernel" field was already filled by xen itself. This change allows the user to move the required binary before xen boots, all within the FIT's configuration.
Karl Apsite (3): add test for two 'loadables' mkimage will now report information about loadable add boot_get_loadables() to load listed images
common/bootm.c | 22 +++++++++ common/image-fit.c | 25 +++++++++- common/image.c | 93 +++++++++++++++++++++++++++++++++++ doc/uImage.FIT/source_file_format.txt | 4 ++ include/bootstage.h | 1 + include/image.h | 6 ++- test/image/test-fit.py | 73 +++++++++++++++++++++++---- 7 files changed, 213 insertions(+), 11 deletions(-)
I don't think I received the patches, just this cover letter. Did you send them do the mailing list? Or are they waiting on ML approval?
Karl Apsite
