[PATCH] arm: Migrate GICV2 / GICV3 to Kconfig
Migrate CONFIG_GICV2 and CONFIG_GICV3 to Kconfig. We still have the GIC related registers that need to be handled more cleanly but start by moving this symbol to Kconfig.
Signed-off-by: Tom Rini trini@konsulko.com --- arch/arm/Kconfig | 10 ++++++++++ arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 8 ++++++++ arch/arm/include/asm/arch-fsl-layerscape/config.h | 2 -- arch/arm/mach-rmobile/Kconfig.64 | 12 ++++++++++++ arch/arm/mach-tegra/Kconfig | 2 ++ arch/arm/mach-versal/Kconfig | 3 --- include/configs/falcon.h | 9 ++++----- include/configs/ls1012a_common.h | 2 -- include/configs/ls1043a_common.h | 1 - include/configs/ls1046a_common.h | 1 - include/configs/ls2080a_common.h | 1 - include/configs/lx2160a_common.h | 1 - include/configs/presidio_asic.h | 1 - include/configs/rcar-gen3-common.h | 1 - include/configs/socfpga_soc64_common.h | 5 ----- include/configs/tegra186-common.h | 3 --- include/configs/tegra210-common.h | 3 --- include/configs/xilinx_zynqmp.h | 1 - 18 files changed, 36 insertions(+), 30 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index d692139199c4..55e6c73eef50 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -63,6 +63,12 @@ config LNX_KRNL_IMG_TEXT_OFFSET_BASE endif endif
+config GICV2 + bool + +config GICV3 + bool + config GIC_V3_ITS bool "ARM GICV3 ITS" select REGMAP @@ -952,6 +958,7 @@ config ARCH_SOCFPGA select CPU_V7A if TARGET_SOCFPGA_GEN5 || TARGET_SOCFPGA_ARRIA10 select DM select DM_SERIAL + select GICV2 select GPIO_EXTRA_HEADER select ENABLE_ARM_SOC_BOOT0_HOOK if TARGET_SOCFPGA_GEN5 || TARGET_SOCFPGA_ARRIA10 select OF_CONTROL @@ -1062,6 +1069,7 @@ config ARCH_VERSAL select DM_ETH if NET select DM_MMC if MMC select DM_SERIAL + select GICV3 select GPIO_EXTRA_HEADER select OF_CONTROL imply BOARD_LATE_INIT @@ -1130,6 +1138,7 @@ config ARCH_ZYNQMP select DM_SPI if SPI select DM_SPI_FLASH if DM_SPI select FIRMWARE + select GICV2 select GPIO_EXTRA_HEADER select OF_CONTROL select SPL_BOARD_INIT if SPL @@ -1878,6 +1887,7 @@ config TARGET_DURIAN config TARGET_PRESIDIO_ASIC bool "Support Cortina Presidio ASIC Platform" select ARM64 + select GICV2
config TARGET_XENGUEST_ARM64 bool "Xen guest ARM64" diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index 9c58f69dbd0d..5c7ec9ccab57 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -4,6 +4,7 @@ config ARCH_LS1012A select ARM_ERRATA_855873 if !TFABOOT select FSL_LAYERSCAPE select FSL_LSCH2 + select GICV2 select SYS_FSL_SRDS_1 select SYS_HAS_SERDES select SYS_FSL_DDR_BE @@ -25,6 +26,7 @@ config ARCH_LS1028A select ARMV8_SET_SMPEN select FSL_LAYERSCAPE select FSL_LSCH3 + select GICV3 select NXP_LSCH3_2 select SYS_FSL_HAS_CCI400 select SYS_FSL_SRDS_1 @@ -58,6 +60,7 @@ config ARCH_LS1043A select ARM_ERRATA_855873 if !TFABOOT select FSL_LAYERSCAPE select FSL_LSCH2 + select GICV2 select SYS_FSL_SRDS_1 select SYS_HAS_SERDES select SYS_FSL_DDR @@ -89,6 +92,7 @@ config ARCH_LS1046A select ARMV8_SET_SMPEN select FSL_LAYERSCAPE select FSL_LSCH2 + select GICV2 select SYS_FSL_SRDS_1 select SYS_HAS_SERDES select SYS_FSL_DDR @@ -124,6 +128,7 @@ config ARCH_LS1088A select ARM_ERRATA_855873 if !TFABOOT select FSL_LAYERSCAPE select FSL_LSCH3 + select GICV3 select SYS_FSL_SRDS_1 select SYS_HAS_SERDES select SYS_FSL_DDR @@ -168,6 +173,7 @@ config ARCH_LS2080A select ARM_ERRATA_833471 select FSL_LAYERSCAPE select FSL_LSCH3 + select GICV3 select SYS_FSL_SRDS_1 select SYS_HAS_SERDES select SYS_FSL_DDR @@ -214,6 +220,7 @@ config ARCH_LX2162A bool select ARMV8_SET_SMPEN select FSL_LSCH3 + select GICV3 select NXP_LSCH3_2 select SYS_HAS_SERDES select SYS_FSL_SRDS_1 @@ -245,6 +252,7 @@ config ARCH_LX2160A bool select ARMV8_SET_SMPEN select FSL_LSCH3 + select GICV3 select NXP_LSCH3_2 select SYS_HAS_SERDES select SYS_FSL_SRDS_1 diff --git a/arch/arm/include/asm/arch-fsl-layerscape/config.h b/arch/arm/include/asm/arch-fsl-layerscape/config.h index 3675ce763d1d..f932db10c307 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/config.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/config.h @@ -123,7 +123,6 @@ #elif defined(CONFIG_ARCH_LS1088A) #define CONFIG_SYS_FSL_NUM_CC_PLLS 3 #define CONFIG_SYS_FSL_CLUSTER_CLOCKS { 1, 1 } -#define CONFIG_GICV3 #define CONFIG_SYS_PAGE_SIZE 0x10000
#define SRDS_MAX_LANES 4 @@ -239,7 +238,6 @@ #elif defined(CONFIG_ARCH_LS1028A) #define CONFIG_SYS_FSL_NUM_CC_PLLS 3 #define CONFIG_SYS_FSL_CLUSTER_CLOCKS { 1, 1 } -#define CONFIG_GICV3 #define CONFIG_FSL_TZPC_BP147 #define CONFIG_FSL_TZASC_400
diff --git a/arch/arm/mach-rmobile/Kconfig.64 b/arch/arm/mach-rmobile/Kconfig.64 index a6dcce180b4d..98549742e76b 100644 --- a/arch/arm/mach-rmobile/Kconfig.64 +++ b/arch/arm/mach-rmobile/Kconfig.64 @@ -4,61 +4,73 @@ menu "Select Target SoC"
config R8A774A1 bool "Renesas SoC R8A774A1" + select GICV2 imply CLK_R8A774A1 imply PINCTRL_PFC_R8A774A1
config R8A774B1 bool "Renesas SoC R8A774B1" + select GICV2 imply CLK_R8A774B1 imply PINCTRL_PFC_R8A774B1
config R8A774C0 bool "Renesas SoC R8A774C0" + select GICV2 imply CLK_R8A774C0 imply PINCTRL_PFC_R8A774C0
config R8A774E1 bool "Renesas SoC R8A774E1" + select GICV2 imply CLK_R8A774E1 imply PINCTRL_PFC_R8A774E1
config R8A7795 bool "Renesas SoC R8A7795" + select GICV2 imply CLK_R8A7795 imply PINCTRL_PFC_R8A7795
config R8A7796 bool "Renesas SoC R8A7796" + select GICV2 imply CLK_R8A7796 imply PINCTRL_PFC_R8A7796
config R8A77965 bool "Renesas SoC R8A77965" + select GICV2 imply CLK_R8A77965 imply PINCTRL_PFC_R8A77965
config R8A77970 bool "Renesas SoC R8A77970" + select GICV2 imply CLK_R8A77970 imply PINCTRL_PFC_R8A77970
config R8A77980 bool "Renesas SoC R8A77980" + select GICV2 imply CLK_R8A77980 imply PINCTRL_PFC_R8A77980
config R8A77990 bool "Renesas SoC R8A77990" + select GICV2 imply CLK_R8A77990 imply PINCTRL_PFC_R8A77990
config R8A77995 bool "Renesas SoC R8A77995" + select GICV2 imply CLK_R8A77995 imply PINCTRL_PFC_R8A77995
config R8A779A0 bool "Renesas SoC R8A779A0" + select GICV3 imply CLK_R8A779A0 imply PINCTRL_PFC_R8A779A0
diff --git a/arch/arm/mach-tegra/Kconfig b/arch/arm/mach-tegra/Kconfig index 478c7a9e388a..311266400df9 100644 --- a/arch/arm/mach-tegra/Kconfig +++ b/arch/arm/mach-tegra/Kconfig @@ -124,6 +124,7 @@ config TEGRA124
config TEGRA210 bool "Tegra210 family" + select GICV2 select TEGRA_ARMV8_COMMON select TEGRA_CLKRST select TEGRA_GPIO @@ -137,6 +138,7 @@ config TEGRA210 config TEGRA186 bool "Tegra186 family" select DM_MAILBOX + select GICV2 select TEGRA186_BPMP select TEGRA186_CLOCK select TEGRA186_GPIO diff --git a/arch/arm/mach-versal/Kconfig b/arch/arm/mach-versal/Kconfig index ebd2da3887ec..0c6ad345ffda 100644 --- a/arch/arm/mach-versal/Kconfig +++ b/arch/arm/mach-versal/Kconfig @@ -21,9 +21,6 @@ config SYS_CONFIG_NAME Based on this option include/configs/<CONFIG_SYS_CONFIG_NAME>.h header will be used for board configuration.
-config GICV3 - def_bool y - config SYS_MALLOC_LEN default 0x2000000
diff --git a/include/configs/falcon.h b/include/configs/falcon.h index 5ecbd1d3edd4..67931febf84f 100644 --- a/include/configs/falcon.h +++ b/include/configs/falcon.h @@ -11,14 +11,13 @@
#include "rcar-gen3-common.h"
-/* Generic Interrupt Controller Definitions */ -#ifdef CONFIG_GICV2 -#undef CONFIG_GICV2 +/* + * Generic Interrupt Controller Definitions. Undefine v2 locations and define + * v3 locations. + */ #undef GICD_BASE #undef GICC_BASE #undef GICR_BASE -#endif -#define CONFIG_GICV3 #define GICD_BASE 0xF1000000 #define GICR_BASE 0xF1060000
diff --git a/include/configs/ls1012a_common.h b/include/configs/ls1012a_common.h index 670b55de26b1..7c8fe7be000a 100644 --- a/include/configs/ls1012a_common.h +++ b/include/configs/ls1012a_common.h @@ -6,8 +6,6 @@ #ifndef __LS1012A_COMMON_H #define __LS1012A_COMMON_H
-#define CONFIG_GICV2 - #include <asm/arch/config.h> #include <asm/arch/stream_id_lsch2.h> #include <linux/sizes.h> diff --git a/include/configs/ls1043a_common.h b/include/configs/ls1043a_common.h index 834c3e6780af..22f1bb21c16d 100644 --- a/include/configs/ls1043a_common.h +++ b/include/configs/ls1043a_common.h @@ -27,7 +27,6 @@ #endif
#define CONFIG_REMAKE_ELF -#define CONFIG_GICV2
#include <asm/arch/stream_id_lsch2.h> #include <asm/arch/config.h> diff --git a/include/configs/ls1046a_common.h b/include/configs/ls1046a_common.h index 289acc02d380..cd2103270848 100644 --- a/include/configs/ls1046a_common.h +++ b/include/configs/ls1046a_common.h @@ -27,7 +27,6 @@ #endif
#include <asm/arch/config.h> #include <asm/arch/stream_id_lsch2.h> diff --git a/include/configs/ls2080a_common.h b/include/configs/ls2080a_common.h index 45273364cf39..fd89133f4924 100644 --- a/include/configs/ls2080a_common.h +++ b/include/configs/ls2080a_common.h @@ -8,7 +8,6 @@ #define __LS2_COMMON_H
#define CONFIG_REMAKE_ELF -#define CONFIG_GICV3
#include <asm/arch/stream_id_lsch3.h> #include <asm/arch/config.h> diff --git a/include/configs/lx2160a_common.h b/include/configs/lx2160a_common.h index 1338ee3cda3b..6fe25764975e 100644 --- a/include/configs/lx2160a_common.h +++ b/include/configs/lx2160a_common.h @@ -12,7 +12,6 @@
#define CONFIG_REMAKE_ELF #define CONFIG_FSL_LAYERSCAPE -#define CONFIG_GICV3 #define CONFIG_FSL_TZPC_BP147 #define CONFIG_FSL_MEMAC
diff --git a/include/configs/presidio_asic.h b/include/configs/presidio_asic.h index 3f926212820a..646a496084aa 100644 --- a/include/configs/presidio_asic.h +++ b/include/configs/presidio_asic.h @@ -23,7 +23,6 @@ /* note: arch/arm/cpu/armv8/start.S which references GICD_BASE/GICC_BASE * does not yet support DT. Thus define it here. */ -#define CONFIG_GICV2 #define GICD_BASE 0xf7011000 #define GICC_BASE 0xf7012000
diff --git a/include/configs/rcar-gen3-common.h b/include/configs/rcar-gen3-common.h index 99ef27bccd5d..2bad3a9d1bd2 100644 --- a/include/configs/rcar-gen3-common.h +++ b/include/configs/rcar-gen3-common.h @@ -26,7 +26,6 @@ #define CONFIG_INITRD_TAG
/* Generic Interrupt Controller Definitions */ -#define CONFIG_GICV2 #define GICD_BASE 0xF1010000 #define GICC_BASE 0xF1020000
diff --git a/include/configs/socfpga_soc64_common.h b/include/configs/socfpga_soc64_common.h index 38fd775b5b6e..91f81503a9bf 100644 --- a/include/configs/socfpga_soc64_common.h +++ b/include/configs/socfpga_soc64_common.h @@ -116,11 +116,6 @@ unsigned int cm_get_qspi_controller_clk_hz(void); "then source ${scriptaddr}; fi\0" \ "socfpga_legacy_reset_compat=1\0"
-/* - * Generic Interrupt Controller Definitions - */ -#define CONFIG_GICV2 - /* * External memory configurations */ diff --git a/include/configs/tegra186-common.h b/include/configs/tegra186-common.h index d5f21e090722..dbf42203de27 100644 --- a/include/configs/tegra186-common.h +++ b/include/configs/tegra186-common.h @@ -17,9 +17,6 @@ * Physical Memory Map */
-/* Generic Interrupt Controller */ -#define CONFIG_GICV2 - #undef FDTFILE #define BOOTENV_EFI_SET_FDTFILE_FALLBACK \ "if test -z "${fdtfile}" -a -n "${soc}"; then " \ diff --git a/include/configs/tegra210-common.h b/include/configs/tegra210-common.h index 2226effe16ab..2817b1dac79a 100644 --- a/include/configs/tegra210-common.h +++ b/include/configs/tegra210-common.h @@ -14,9 +14,6 @@ */ #define V_NS16550_CLK 408000000 /* 408MHz (pllp_out0) */
-/* Generic Interrupt Controller */ -#define CONFIG_GICV2 - /* * Memory layout for where various images get loaded by boot scripts: * diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index 262154cdffdc..c62d751c1375 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -15,7 +15,6 @@ /* #define CONFIG_ARMV8_SWITCH_TO_EL1 */
/* Generic Interrupt Controller Definitions */ -#define CONFIG_GICV2 #define GICD_BASE 0xF9010000 #define GICC_BASE 0xF9020000
