[U-Boot] [PATCH 0/2] Enable network support on at91sam9n12ek board
This patch set base on the following patch set: - arm: at91: add at91sam9n12ek board support - http://patchwork.ozlabs.org/patch/237184/
And implement the following things - add ks8851_16mll ethernet driver - Enable network support on at91sam9n12ek board.
Bo Shen (1): ARM: at91sam9n12: add network support with ksz8851_16mll
Roberto Cerati (1): net: ks8851_mll: add ethernet support
board/atmel/at91sam9n12ek/at91sam9n12ek.c | 36 ++ drivers/net/Makefile | 1 + drivers/net/ks8851_mll.c | 635 +++++++++++++++++++++++++++++ drivers/net/ks8851_mll.h | 357 ++++++++++++++++ include/configs/at91sam9n12ek.h | 4 + include/netdev.h | 1 + 6 files changed, 1034 insertions(+) create mode 100644 drivers/net/ks8851_mll.c create mode 100644 drivers/net/ks8851_mll.h
The device interface is 16 bits wide. All the available packets are read from the incoming fifo.
Signed-off-by: Roberto Cerati roberto.cerati@bticino.it Signed-off-by: Raffaele Recalcati raffaele.recalcati@bticino.it [voice.shen@atmel.com: address comments from review results] [voice.shen@atmel.com: clean up for submit] Signed-off-by: Bo Shen voice.shen@atmel.com --- drivers/net/Makefile | 1 + drivers/net/ks8851_mll.c | 635 ++++++++++++++++++++++++++++++++++++++++++++++ drivers/net/ks8851_mll.h | 357 ++++++++++++++++++++++++++ include/netdev.h | 1 + 4 files changed, 994 insertions(+) create mode 100644 drivers/net/ks8851_mll.c create mode 100644 drivers/net/ks8851_mll.h
diff --git a/drivers/net/Makefile b/drivers/net/Makefile index 786a656..f4cc072 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -50,6 +50,7 @@ COBJS-$(CONFIG_FTMAC100) += ftmac100.o COBJS-$(CONFIG_GRETH) += greth.o COBJS-$(CONFIG_INCA_IP_SWITCH) += inca-ip_sw.o COBJS-$(CONFIG_DRIVER_KS8695ETH) += ks8695eth.o +COBJS-$(CONFIG_KS8851_MLL) += ks8851_mll.o COBJS-$(CONFIG_LAN91C96) += lan91c96.o COBJS-$(CONFIG_MACB) += macb.o COBJS-$(CONFIG_MCFFEC) += mcffec.o mcfmii.o diff --git a/drivers/net/ks8851_mll.c b/drivers/net/ks8851_mll.c new file mode 100644 index 0000000..1a6cf11 --- /dev/null +++ b/drivers/net/ks8851_mll.c @@ -0,0 +1,635 @@ +/* + * Micrel KS8851_MLL 16bit Network driver + * Copyright (c) 2011 Roberto Cerati roberto.cerati@bticino.it + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#include <asm/io.h> +#include <common.h> +#include <command.h> +#include <malloc.h> +#include <net.h> +#include <miiphy.h> + +#include "ks8851_mll.h" + +#define DRIVERNAME "ks8851_mll" + +#define MAX_RECV_FRAMES 32 +#define MAX_BUF_SIZE 2048 +#define TX_BUF_SIZE 2000 +#define RX_BUF_SIZE 2000 + +static const struct chip_id chip_ids[] = { + {CIDER_ID, "KSZ8851"}, + {0, NULL}, +}; + +/* union ks_tx_hdr - tx header data + * @txb: The header as bytes + * @txw: The header as 16bit, little-endian words + * + * A dual representation of the tx header data to allow + * access to individual bytes, and to allow 16bit accesses + * with 16bit alignment. + */ +union ks_tx_hdr { + u8 txb[4]; + __le16 txw[2]; +}; + +/* struct ks_net - KS8851 driver private data + * @net_device : The network device we're bound to + * @txh : temporaly buffer to save status/length. + * @frame_head_info : frame header information for multi-pkt rx. + * @statelock : Lock on this structure for tx list. + * @msg_enable : The message flags controlling driver output (see ethtool). + * @frame_cnt : number of frames received. + * @bus_width : i/o bus width. + * @irq : irq number assigned to this device. + * @rc_rxqcr : Cached copy of KS_RXQCR. + * @rc_txcr : Cached copy of KS_TXCR. + * @rc_ier : Cached copy of KS_IER. + * @sharedbus : Multipex(addr and data bus) mode indicator. + * @cmd_reg_cache : command register cached. + * @cmd_reg_cache_int : command register cached. Used in the irq handler. + * @promiscuous : promiscuous mode indicator. + * @all_mcast : mutlicast indicator. + * @mcast_lst_size : size of multicast list. + * @mcast_lst : multicast list. + * @mcast_bits : multicast enabed. + * @mac_addr : MAC address assigned to this device. + * @fid : frame id. + * @extra_byte : number of extra byte prepended rx pkt. + * @enabled : indicator this device works. + */ + +/* Receive multiplex framer header info */ +struct type_frame_head { + u16 sts; /* Frame status */ + u16 len; /* Byte count */ +} fr_h_i[MAX_RECV_FRAMES]; + +struct ks_net { + struct net_device *netdev; + union ks_tx_hdr txh; + struct type_frame_head *frame_head_info; + u32 msg_enable; + u32 frame_cnt; + int bus_width; + int irq; + u16 rc_rxqcr; + u16 rc_txcr; + u16 rc_ier; + u16 sharedbus; + u16 cmd_reg_cache; + u16 cmd_reg_cache_int; + u16 promiscuous; + u16 all_mcast; + u16 mcast_lst_size; + u8 mcast_lst[MAX_MCAST_LST][MAC_ADDR_LEN]; + u8 mcast_bits[HW_MCAST_SIZE]; + u8 mac_addr[6]; + u8 fid; + u8 extra_byte; + u8 enabled; +} ks_str, *ks; + +#define BE3 0x8000 /* Byte Enable 3 */ +#define BE2 0x4000 /* Byte Enable 2 */ +#define BE1 0x2000 /* Byte Enable 1 */ +#define BE0 0x1000 /* Byte Enable 0 */ + +static u8 ks_rdreg8(struct eth_device *dev, u16 offset) +{ + u8 shift_bit = offset & 0x03; + u8 shift_data = (offset & 1) << 3; + + writew(offset | (BE0 << shift_bit), dev->iobase + 2); + + return (u8)(readw(dev->iobase) >> shift_data); +} + +static u16 ks_rdreg16(struct eth_device *dev, u16 offset) +{ + writew(offset | ((BE1 | BE0) << (offset & 0x02)), dev->iobase + 2); + + return readw(dev->iobase); +} + +static void ks_wrreg8(struct eth_device *dev, u16 offset, u8 val) +{ + u8 shift_bit = (offset & 0x03); + u16 value_write = (u16)(val << ((offset & 1) << 3)); + + writew(offset | (BE0 << shift_bit), dev->iobase + 2); + writew(value_write, dev->iobase); +} + +static void ks_wrreg16(struct eth_device *dev, u16 offset, u16 val) +{ + writew(offset | ((BE1 | BE0) << (offset & 0x02)), dev->iobase + 2); + writew(val, dev->iobase); +} + +/* ks_inblk - read a block of data from QMU. This is called after sudo DMA mode + * enabled. + * @ks: The chip state + * @wptr: buffer address to save data + * @len: length in byte to read + */ +static inline void ks_inblk(struct eth_device *dev, u16 *wptr, u32 len) +{ + len >>= 1; + + while (len--) + *wptr++ = readw(dev->iobase); +} + +/* ks_outblk - write data to QMU. This is called after sudo DMA mode enabled. + * @ks: The chip information + * @wptr: buffer address + * @len: length in byte to write + */ +static inline void ks_outblk(struct eth_device *dev, u16 *wptr, u32 len) +{ + len >>= 1; + + while (len--) + writew(*wptr++, dev->iobase); +} + +static void ks_enable_int(struct eth_device *dev) +{ + ks_wrreg16(dev, KS_IER, ks->rc_ier); +} + +static void ks_set_powermode(struct eth_device *dev, unsigned pwrmode) +{ + unsigned pmecr; + + ks_rdreg16(dev, KS_GRR); + pmecr = ks_rdreg16(dev, KS_PMECR); + pmecr &= ~PMECR_PM_MASK; + pmecr |= pwrmode; + + ks_wrreg16(dev, KS_PMECR, pmecr); +} + +/* ks_read_config - read chip configuration of bus width. + * @ks: The chip information + */ +static void ks_read_config(struct eth_device *dev) +{ + u16 reg_data = 0; + + /* Regardless of bus width, 8 bit read should always work. */ + reg_data = ks_rdreg8(dev, KS_CCR) & 0x00FF; + reg_data |= ks_rdreg8(dev, KS_CCR + 1) << 8; + + /* addr/data bus are multiplexed */ + ks->sharedbus = (reg_data & CCR_SHARED) == CCR_SHARED; + + /* There are garbage data when reading data from QMU, + * depending on bus-width. + */ + if (reg_data & CCR_8BIT) { + ks->bus_width = ENUM_BUS_8BIT; + ks->extra_byte = 1; + } else if (reg_data & CCR_16BIT) { + ks->bus_width = ENUM_BUS_16BIT; + ks->extra_byte = 2; + } else { + ks->bus_width = ENUM_BUS_32BIT; + ks->extra_byte = 4; + } +} + +/* ks_soft_reset - issue one of the soft reset to the device + * @ks: The device state. + * @op: The bit(s) to set in the GRR + * + * Issue the relevant soft-reset command to the device's GRR register + * specified by @op. + * + * Note, the delays are in there as a caution to ensure that the reset + * has time to take effect and then complete. Since the datasheet does + * not currently specify the exact sequence, we have chosen something + * that seems to work with our device. + */ +static void ks_soft_reset(struct eth_device *dev, unsigned op) +{ + /* Disable interrupt first */ + ks_wrreg16(dev, KS_IER, 0x0000); + ks_wrreg16(dev, KS_GRR, op); + mdelay(10); /* wait a short time to effect reset */ + ks_wrreg16(dev, KS_GRR, 0); + mdelay(1); /* wait for condition to clear */ +} + +void ks_enable_qmu(struct eth_device *dev) +{ + u16 w; + + w = ks_rdreg16(dev, KS_TXCR); + + /* Enables QMU Transmit (TXCR). */ + ks_wrreg16(dev, KS_TXCR, w | TXCR_TXE); + + /* RX Frame Count Threshold Enable and Auto-Dequeue RXQ Frame + * Enable + */ + w = ks_rdreg16(dev, KS_RXQCR); + ks_wrreg16(dev, KS_RXQCR, w | RXQCR_RXFCTE); + + /* Enables QMU Receive (RXCR1). */ + w = ks_rdreg16(dev, KS_RXCR1); + ks_wrreg16(dev, KS_RXCR1, w | RXCR1_RXE); +} + +static void ks_disable_qmu(struct eth_device *dev) +{ + u16 w; + + w = ks_rdreg16(dev, KS_TXCR); + + /* Disables QMU Transmit (TXCR). */ + w &= ~TXCR_TXE; + ks_wrreg16(dev, KS_TXCR, w); + + /* Disables QMU Receive (RXCR1). */ + w = ks_rdreg16(dev, KS_RXCR1); + w &= ~RXCR1_RXE; + ks_wrreg16(dev, KS_RXCR1, w); +} + +static inline void ks_read_qmu(struct eth_device *dev, u16 *buf, u32 len) +{ + u32 r = ks->extra_byte & 0x1; + u32 w = ks->extra_byte - r; + + /* 1. set sudo DMA mode */ + ks_wrreg16(dev, KS_RXFDPR, RXFDPR_RXFPAI); + ks_wrreg8(dev, KS_RXQCR, (ks->rc_rxqcr | RXQCR_SDA) & 0xff); + + /* 2. read prepend data + * + * read 4 + extra bytes and discard them. + * extra bytes for dummy, 2 for status, 2 for len + */ + + if (r) + ks_rdreg8(dev, 0); + + ks_inblk(dev, buf, w + 2 + 2); + + /* 3. read pkt data */ + ks_inblk(dev, buf, ALIGN(len, 4)); + + /* 4. reset sudo DMA Mode */ + ks_wrreg8(dev, KS_RXQCR, (ks->rc_rxqcr & ~RXQCR_SDA) & 0xff); +} + +static void ks_rcv(struct eth_device *dev, uchar **pv_data) +{ + struct type_frame_head *frame_hdr = ks->frame_head_info; + int i; + + ks->frame_cnt = ks_rdreg16(dev, KS_RXFCTR) >> 8; + + /* read all header information */ + for (i = 0; i < ks->frame_cnt; i++) { + /* Checking Received packet status */ + frame_hdr->sts = ks_rdreg16(dev, KS_RXFHSR); + /* Get packet len from hardware */ + frame_hdr->len = ks_rdreg16(dev, KS_RXFHBCR); + frame_hdr++; + } + + frame_hdr = ks->frame_head_info; + while (ks->frame_cnt--) { + if ((frame_hdr->sts & RXFSHR_RXFV) && + (frame_hdr->len < RX_BUF_SIZE) && + frame_hdr->len) { + /* read data block including CRC 4 bytes */ + ks_read_qmu(dev, (u16 *)(*pv_data), frame_hdr->len); + + /* NetRxPackets buffer size is ok (*pv_data pointer) */ + NetReceive(*pv_data, frame_hdr->len); + pv_data++; + } else { + ks_wrreg16(dev, KS_RXQCR, (ks->rc_rxqcr | RXQCR_RRXEF)); + printf(DRIVERNAME ": bad packet\n"); + } + frame_hdr++; + } +} + +/* ks_read_selftest - read the selftest memory info. + * @ks: The device state + * + * Read and check the TX/RX memory selftest information. + */ +static int ks_read_selftest(struct eth_device *dev) +{ + u16 both_done = MBIR_TXMBF | MBIR_RXMBF; + u16 mbir; + int ret = 0; + + mbir = ks_rdreg16(dev, KS_MBIR); + + if ((mbir & both_done) != both_done) { + printf(DRIVERNAME ": Memory selftest not finished\n"); + return 0; + } + + if (mbir & MBIR_TXMBFA) { + printf(DRIVERNAME ": TX memory selftest fails\n"); + ret |= 1; + } + + if (mbir & MBIR_RXMBFA) { + printf(DRIVERNAME ": RX memory selftest fails\n"); + ret |= 2; + } + + debug(DRIVERNAME ": the selftest passes\n"); + + return ret; +} + +static void ks_setup(struct eth_device *dev) +{ + u16 w; + + /* Setup Transmit Frame Data Pointer Auto-Increment (TXFDPR) */ + ks_wrreg16(dev, KS_TXFDPR, TXFDPR_TXFPAI); + + /* Setup Receive Frame Data Pointer Auto-Increment */ + ks_wrreg16(dev, KS_RXFDPR, RXFDPR_RXFPAI); + + /* Setup Receive Frame Threshold - 1 frame (RXFCTFC) */ + ks_wrreg16(dev, KS_RXFCTR, 1 & RXFCTR_THRESHOLD_MASK); + + /* Setup RxQ Command Control (RXQCR) */ + ks->rc_rxqcr = RXQCR_CMD_CNTL; + ks_wrreg16(dev, KS_RXQCR, ks->rc_rxqcr); + + /* set the force mode to half duplex, default is full duplex + * because if the auto-negotiation fails, most switch uses + * half-duplex. + */ + w = ks_rdreg16(dev, KS_P1MBCR); + w &= ~P1MBCR_FORCE_FDX; + ks_wrreg16(dev, KS_P1MBCR, w); + + w = TXCR_TXFCE | TXCR_TXPE | TXCR_TXCRC | TXCR_TCGIP; + ks_wrreg16(dev, KS_TXCR, w); + + w = RXCR1_RXFCE | RXCR1_RXBE | RXCR1_RXUE | RXCR1_RXME | RXCR1_RXIPFCC; + + /* Normal mode */ + w |= RXCR1_RXPAFMA; + + ks_wrreg16(dev, KS_RXCR1, w); +} + +static void ks_setup_int(struct eth_device *dev) +{ + ks->rc_ier = 0x00; + + /* Clear the interrupts status of the hardware. */ + ks_wrreg16(dev, KS_ISR, 0xffff); + + /* Enables the interrupts of the hardware. */ + ks->rc_ier = (IRQ_LCI | IRQ_TXI | IRQ_RXI); +} + +static int ks8851_mll_detect_chip(struct eth_device *dev) +{ + unsigned short val, i; + + ks_read_config(dev); + + val = ks_rdreg16(dev, KS_CIDER); + + if (val == 0xffff) { + /* Special case -- no chip present */ + printf(DRIVERNAME ": is chip mounted ?\n"); + return -1; + } else if ((val & 0xfff0) != CIDER_ID) { + printf(DRIVERNAME ": Invalid chip id 0x%04x\n", val); + return -1; + } + + debug("Read back KS8851 id 0x%x\n", val); + + /* only one entry in the table */ + val &= 0xfff0; + for (i = 0; chip_ids[i].id != 0; i++) { + if (chip_ids[i].id == val) + break; + } + if (!chip_ids[i].id) { + printf(DRIVERNAME ": Unknown chip ID %04x\n", val); + return -1; + } + + dev->priv = (void *)&chip_ids[i]; + + return 0; +} + +static void ks8851_mll_reset(struct eth_device *dev) +{ + /* wake up powermode to normal mode */ + ks_set_powermode(dev, PMECR_PM_NORMAL); + mdelay(1); /* wait for normal mode to take effect */ + + /* Disable interrupt and reset */ + ks_soft_reset(dev, GRR_GSR); + + /* turn off the IRQs and ack any outstanding */ + ks_wrreg16(dev, KS_IER, 0x0000); + ks_wrreg16(dev, KS_ISR, 0xffff); + + /* shutdown RX/TX QMU */ + ks_disable_qmu(dev); +} + +static void ks8851_mll_phy_configure(struct eth_device *dev) +{ + u16 data; + + ks_setup(dev); + ks_setup_int(dev); + + /* Probing the phy */ + data = ks_rdreg16(dev, KS_OBCR); + ks_wrreg16(dev, KS_OBCR, data | OBCR_ODS_16MA); + + debug(DRIVERNAME ": phy initialized\n"); +} + +static void ks8851_mll_enable(struct eth_device *dev) +{ + ks_wrreg16(dev, KS_ISR, 0xffff); + ks_enable_int(dev); + ks_enable_qmu(dev); +} + +static int ks8851_mll_init(struct eth_device *dev, bd_t *bd) +{ + struct chip_id *id = dev->priv; + + debug(DRIVERNAME ": detected %s controller\n", id->name); + + if (ks_read_selftest(dev)) { + printf(DRIVERNAME ": Selftest failed\n"); + return -1; + } + + ks8851_mll_reset(dev); + + /* Configure the PHY, initialize the link state */ + ks8851_mll_phy_configure(dev); + + /* static allocation of private informations */ + ks->frame_head_info = fr_h_i; + + /* Turn on Tx + Rx */ + ks8851_mll_enable(dev); + + return 0; +} + +static void ks_write_qmu(struct eth_device *dev, u8 *pdata, u16 len) +{ + /* start header at txb[0] to align txw entries */ + ks->txh.txw[0] = 0; + ks->txh.txw[1] = cpu_to_le16(len); + + /* 1. set sudo-DMA mode */ + ks_wrreg16(dev, KS_TXFDPR, TXFDPR_TXFPAI); + ks_wrreg8(dev, KS_RXQCR, (ks->rc_rxqcr | RXQCR_SDA) & 0xff); + /* 2. write status/lenth info */ + ks_outblk(dev, ks->txh.txw, 4); + /* 3. write pkt data */ + ks_outblk(dev, (u16 *)pdata, ALIGN(len, 4)); + /* 4. reset sudo-DMA mode */ + ks_wrreg8(dev, KS_RXQCR, (ks->rc_rxqcr & ~RXQCR_SDA) & 0xff); + /* 5. Enqueue Tx(move the pkt from TX buffer into TXQ) */ + ks_wrreg16(dev, KS_TXQCR, TXQCR_METFE); + /* 6. wait until TXQCR_METFE is auto-cleared */ + do { } while (ks_rdreg16(dev, KS_TXQCR) & TXQCR_METFE); +} + +static int ks8851_mll_send(struct eth_device *dev, void *packet, int length) +{ + u8 *data = (u8 *)packet; + u16 tmplen = (u16)length; + u16 retv; + + /* Extra space are required: + * 4 byte for alignment, 4 for status/length, 4 for CRC + */ + retv = ks_rdreg16(dev, KS_TXMIR) & 0x1fff; + if (retv >= tmplen + 12) { + ks_write_qmu(dev, data, tmplen); + return 0; + } else { + printf(DRIVERNAME ": failed to send packet: No buffer\n"); + return -1; + } +} + +static void ks8851_mll_halt(struct eth_device *dev) +{ + ks8851_mll_reset(dev); +} + +/* Maximum receive ring size; that is, the number of packets + * we can buffer before overflow happens. Basically, this just + * needs to be enough to prevent a packet being discarded while + * we are processing the previous one. + */ +static int ks8851_mll_recv(struct eth_device *dev) +{ + u16 status; + + status = ks_rdreg16(dev, KS_ISR); + + ks_wrreg16(dev, KS_ISR, status); + + if ((status & IRQ_RXI)) + ks_rcv(dev, (uchar **)NetRxPackets); + + if ((status & IRQ_LDI)) { + u16 pmecr = ks_rdreg16(dev, KS_PMECR); + pmecr &= ~PMECR_WKEVT_MASK; + ks_wrreg16(dev, KS_PMECR, pmecr | PMECR_WKEVT_LINK); + } + + return 0; +} + +static int ks8851_mll_write_hwaddr(struct eth_device *dev) +{ + u16 addrl, addrm, addrh; + + addrh = (dev->enetaddr[0] << 8) | dev->enetaddr[1]; + addrm = (dev->enetaddr[2] << 8) | dev->enetaddr[3]; + addrl = (dev->enetaddr[4] << 8) | dev->enetaddr[5]; + + ks_wrreg16(dev, KS_MARH, addrh); + ks_wrreg16(dev, KS_MARM, addrm); + ks_wrreg16(dev, KS_MARL, addrl); + + return 0; +} + +int ks8851_mll_initialize(u8 dev_num, int base_addr) +{ + struct eth_device *dev; + + dev = malloc(sizeof(*dev)); + if (!dev) { + printf("Error: Failed to allocate memory\n"); + return -1; + } + memset(dev, 0, sizeof(*dev)); + + dev->iobase = base_addr; + + ks = &ks_str; + + /* Try to detect chip. Will fail if not present. */ + if (ks8851_mll_detect_chip(dev)) { + free(dev); + return -1; + } + + dev->init = ks8851_mll_init; + dev->halt = ks8851_mll_halt; + dev->send = ks8851_mll_send; + dev->recv = ks8851_mll_recv; + dev->write_hwaddr = ks8851_mll_write_hwaddr; + sprintf(dev->name, "%s-%hu", DRIVERNAME, dev_num); + + eth_register(dev); + + return 0; +} diff --git a/drivers/net/ks8851_mll.h b/drivers/net/ks8851_mll.h new file mode 100644 index 0000000..3a2743f --- /dev/null +++ b/drivers/net/ks8851_mll.h @@ -0,0 +1,357 @@ +/* + * drivers/net/ks8851_mll.c + * + * Supports: + * KS8851 16bit MLL chip from Micrel Inc. + * + * Copyright (c) 2009 Micrel Inc. + * + * modified by + * (c) 2011 Bticino s.p.a, Roberto Cerati roberto.cerati@bticino.it + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ +#ifndef _KS8851_MLL_H_ +#define _KS8851_MLL_H_ + +#include <linux/types.h> + +#define KS_CCR 0x08 +#define CCR_EEPROM (1 << 9) +#define CCR_SPI (1 << 8) +#define CCR_8BIT (1 << 7) +#define CCR_16BIT (1 << 6) +#define CCR_32BIT (1 << 5) +#define CCR_SHARED (1 << 4) +#define CCR_32PIN (1 << 0) + +/* MAC address registers */ +#define KS_MARL 0x10 +#define KS_MARM 0x12 +#define KS_MARH 0x14 + +#define KS_OBCR 0x20 +#define OBCR_ODS_16MA (1 << 6) + +#define KS_EEPCR 0x22 +#define EEPCR_EESA (1 << 4) +#define EEPCR_EESB (1 << 3) +#define EEPCR_EEDO (1 << 2) +#define EEPCR_EESCK (1 << 1) +#define EEPCR_EECS (1 << 0) + +#define KS_MBIR 0x24 +#define MBIR_TXMBF (1 << 12) +#define MBIR_TXMBFA (1 << 11) +#define MBIR_RXMBF (1 << 4) +#define MBIR_RXMBFA (1 << 3) + +#define KS_GRR 0x26 +#define GRR_QMU (1 << 1) +#define GRR_GSR (1 << 0) + +#define KS_WFCR 0x2A +#define WFCR_MPRXE (1 << 7) +#define WFCR_WF3E (1 << 3) +#define WFCR_WF2E (1 << 2) +#define WFCR_WF1E (1 << 1) +#define WFCR_WF0E (1 << 0) + +#define KS_WF0CRC0 0x30 +#define KS_WF0CRC1 0x32 +#define KS_WF0BM0 0x34 +#define KS_WF0BM1 0x36 +#define KS_WF0BM2 0x38 +#define KS_WF0BM3 0x3A + +#define KS_WF1CRC0 0x40 +#define KS_WF1CRC1 0x42 +#define KS_WF1BM0 0x44 +#define KS_WF1BM1 0x46 +#define KS_WF1BM2 0x48 +#define KS_WF1BM3 0x4A + +#define KS_WF2CRC0 0x50 +#define KS_WF2CRC1 0x52 +#define KS_WF2BM0 0x54 +#define KS_WF2BM1 0x56 +#define KS_WF2BM2 0x58 +#define KS_WF2BM3 0x5A + +#define KS_WF3CRC0 0x60 +#define KS_WF3CRC1 0x62 +#define KS_WF3BM0 0x64 +#define KS_WF3BM1 0x66 +#define KS_WF3BM2 0x68 +#define KS_WF3BM3 0x6A + +#define KS_TXCR 0x70 +#define TXCR_TCGICMP (1 << 8) +#define TXCR_TCGUDP (1 << 7) +#define TXCR_TCGTCP (1 << 6) +#define TXCR_TCGIP (1 << 5) +#define TXCR_FTXQ (1 << 4) +#define TXCR_TXFCE (1 << 3) +#define TXCR_TXPE (1 << 2) +#define TXCR_TXCRC (1 << 1) +#define TXCR_TXE (1 << 0) + +#define KS_TXSR 0x72 +#define TXSR_TXLC (1 << 13) +#define TXSR_TXMC (1 << 12) +#define TXSR_TXFID_MASK (0x3f << 0) +#define TXSR_TXFID_SHIFT (0) +#define TXSR_TXFID_GET(_v) (((_v) >> 0) & 0x3f) + + +#define KS_RXCR1 0x74 +#define RXCR1_FRXQ (1 << 15) +#define RXCR1_RXUDPFCC (1 << 14) +#define RXCR1_RXTCPFCC (1 << 13) +#define RXCR1_RXIPFCC (1 << 12) +#define RXCR1_RXPAFMA (1 << 11) +#define RXCR1_RXFCE (1 << 10) +#define RXCR1_RXEFE (1 << 9) +#define RXCR1_RXMAFMA (1 << 8) +#define RXCR1_RXBE (1 << 7) +#define RXCR1_RXME (1 << 6) +#define RXCR1_RXUE (1 << 5) +#define RXCR1_RXAE (1 << 4) +#define RXCR1_RXINVF (1 << 1) +#define RXCR1_RXE (1 << 0) +#define RXCR1_FILTER_MASK (RXCR1_RXINVF | RXCR1_RXAE | \ + RXCR1_RXMAFMA | RXCR1_RXPAFMA) + +#define KS_RXCR2 0x76 +#define RXCR2_SRDBL_MASK (0x7 << 5) +#define RXCR2_SRDBL_SHIFT (5) +#define RXCR2_SRDBL_4B (0x0 << 5) +#define RXCR2_SRDBL_8B (0x1 << 5) +#define RXCR2_SRDBL_16B (0x2 << 5) +#define RXCR2_SRDBL_32B (0x3 << 5) +/* #define RXCR2_SRDBL_FRAME (0x4 << 5) */ +#define RXCR2_IUFFP (1 << 4) +#define RXCR2_RXIUFCEZ (1 << 3) +#define RXCR2_UDPLFE (1 << 2) +#define RXCR2_RXICMPFCC (1 << 1) +#define RXCR2_RXSAF (1 << 0) + +#define KS_TXMIR 0x78 + +#define KS_RXFHSR 0x7C +#define RXFSHR_RXFV (1 << 15) +#define RXFSHR_RXICMPFCS (1 << 13) +#define RXFSHR_RXIPFCS (1 << 12) +#define RXFSHR_RXTCPFCS (1 << 11) +#define RXFSHR_RXUDPFCS (1 << 10) +#define RXFSHR_RXBF (1 << 7) +#define RXFSHR_RXMF (1 << 6) +#define RXFSHR_RXUF (1 << 5) +#define RXFSHR_RXMR (1 << 4) +#define RXFSHR_RXFT (1 << 3) +#define RXFSHR_RXFTL (1 << 2) +#define RXFSHR_RXRF (1 << 1) +#define RXFSHR_RXCE (1 << 0) +#define RXFSHR_ERR (RXFSHR_RXCE | RXFSHR_RXRF |\ + RXFSHR_RXFTL | RXFSHR_RXMR |\ + RXFSHR_RXICMPFCS | RXFSHR_RXIPFCS |\ + RXFSHR_RXTCPFCS) +#define KS_RXFHBCR 0x7E +#define RXFHBCR_CNT_MASK 0x0FFF + +#define KS_TXQCR 0x80 +#define TXQCR_AETFE (1 << 2) +#define TXQCR_TXQMAM (1 << 1) +#define TXQCR_METFE (1 << 0) + +#define KS_RXQCR 0x82 +#define RXQCR_RXDTTS (1 << 12) +#define RXQCR_RXDBCTS (1 << 11) +#define RXQCR_RXFCTS (1 << 10) +#define RXQCR_RXIPHTOE (1 << 9) +#define RXQCR_RXDTTE (1 << 7) +#define RXQCR_RXDBCTE (1 << 6) +#define RXQCR_RXFCTE (1 << 5) +#define RXQCR_ADRFE (1 << 4) +#define RXQCR_SDA (1 << 3) +#define RXQCR_RRXEF (1 << 0) +#define RXQCR_CMD_CNTL (RXQCR_RXFCTE|RXQCR_ADRFE) + +#define KS_TXFDPR 0x84 +#define TXFDPR_TXFPAI (1 << 14) +#define TXFDPR_TXFP_MASK (0x7ff << 0) +#define TXFDPR_TXFP_SHIFT (0) + +#define KS_RXFDPR 0x86 +#define RXFDPR_RXFPAI (1 << 14) + +#define KS_RXDTTR 0x8C +#define KS_RXDBCTR 0x8E + +#define KS_IER 0x90 +#define KS_ISR 0x92 +#define IRQ_LCI (1 << 15) +#define IRQ_TXI (1 << 14) +#define IRQ_RXI (1 << 13) +#define IRQ_RXOI (1 << 11) +#define IRQ_TXPSI (1 << 9) +#define IRQ_RXPSI (1 << 8) +#define IRQ_TXSAI (1 << 6) +#define IRQ_RXWFDI (1 << 5) +#define IRQ_RXMPDI (1 << 4) +#define IRQ_LDI (1 << 3) +#define IRQ_EDI (1 << 2) +#define IRQ_SPIBEI (1 << 1) +#define IRQ_DEDI (1 << 0) + +#define KS_RXFCTR 0x9C +#define RXFCTR_THRESHOLD_MASK 0x00FF + +#define KS_RXFC 0x9D +#define RXFCTR_RXFC_MASK (0xff << 8) +#define RXFCTR_RXFC_SHIFT (8) +#define RXFCTR_RXFC_GET(_v) (((_v) >> 8) & 0xff) +#define RXFCTR_RXFCT_MASK (0xff << 0) +#define RXFCTR_RXFCT_SHIFT (0) + +#define KS_TXNTFSR 0x9E + +#define KS_MAHTR0 0xA0 +#define KS_MAHTR1 0xA2 +#define KS_MAHTR2 0xA4 +#define KS_MAHTR3 0xA6 + +#define KS_FCLWR 0xB0 +#define KS_FCHWR 0xB2 +#define KS_FCOWR 0xB4 + +#define KS_CIDER 0xC0 +#define CIDER_ID 0x8870 +#define CIDER_REV_MASK (0x7 << 1) +#define CIDER_REV_SHIFT (1) +#define CIDER_REV_GET(_v) (((_v) >> 1) & 0x7) + +#define KS_CGCR 0xC6 +#define KS_IACR 0xC8 +#define IACR_RDEN (1 << 12) +#define IACR_TSEL_MASK (0x3 << 10) +#define IACR_TSEL_SHIFT (10) +#define IACR_TSEL_MIB (0x3 << 10) +#define IACR_ADDR_MASK (0x1f << 0) +#define IACR_ADDR_SHIFT (0) + +#define KS_IADLR 0xD0 +#define KS_IAHDR 0xD2 + +#define KS_PMECR 0xD4 +#define PMECR_PME_DELAY (1 << 14) +#define PMECR_PME_POL (1 << 12) +#define PMECR_WOL_WAKEUP (1 << 11) +#define PMECR_WOL_MAGICPKT (1 << 10) +#define PMECR_WOL_LINKUP (1 << 9) +#define PMECR_WOL_ENERGY (1 << 8) +#define PMECR_AUTO_WAKE_EN (1 << 7) +#define PMECR_WAKEUP_NORMAL (1 << 6) +#define PMECR_WKEVT_MASK (0xf << 2) +#define PMECR_WKEVT_SHIFT (2) +#define PMECR_WKEVT_GET(_v) (((_v) >> 2) & 0xf) +#define PMECR_WKEVT_ENERGY (0x1 << 2) +#define PMECR_WKEVT_LINK (0x2 << 2) +#define PMECR_WKEVT_MAGICPKT (0x4 << 2) +#define PMECR_WKEVT_FRAME (0x8 << 2) +#define PMECR_PM_MASK (0x3 << 0) +#define PMECR_PM_SHIFT (0) +#define PMECR_PM_NORMAL (0x0 << 0) +#define PMECR_PM_ENERGY (0x1 << 0) +#define PMECR_PM_SOFTDOWN (0x2 << 0) +#define PMECR_PM_POWERSAVE (0x3 << 0) + +/* Standard MII PHY data */ +#define KS_P1MBCR 0xE4 +#define P1MBCR_FORCE_FDX (1 << 8) + +#define KS_P1MBSR 0xE6 +#define P1MBSR_AN_COMPLETE (1 << 5) +#define P1MBSR_AN_CAPABLE (1 << 3) +#define P1MBSR_LINK_UP (1 << 2) + +#define KS_PHY1ILR 0xE8 +#define KS_PHY1IHR 0xEA +#define KS_P1ANAR 0xEC +#define KS_P1ANLPR 0xEE + +#define KS_P1SCLMD 0xF4 +#define P1SCLMD_LEDOFF (1 << 15) +#define P1SCLMD_TXIDS (1 << 14) +#define P1SCLMD_RESTARTAN (1 << 13) +#define P1SCLMD_DISAUTOMDIX (1 << 10) +#define P1SCLMD_FORCEMDIX (1 << 9) +#define P1SCLMD_AUTONEGEN (1 << 7) +#define P1SCLMD_FORCE100 (1 << 6) +#define P1SCLMD_FORCEFDX (1 << 5) +#define P1SCLMD_ADV_FLOW (1 << 4) +#define P1SCLMD_ADV_100BT_FDX (1 << 3) +#define P1SCLMD_ADV_100BT_HDX (1 << 2) +#define P1SCLMD_ADV_10BT_FDX (1 << 1) +#define P1SCLMD_ADV_10BT_HDX (1 << 0) + +#define KS_P1CR 0xF6 +#define P1CR_HP_MDIX (1 << 15) +#define P1CR_REV_POL (1 << 13) +#define P1CR_OP_100M (1 << 10) +#define P1CR_OP_FDX (1 << 9) +#define P1CR_OP_MDI (1 << 7) +#define P1CR_AN_DONE (1 << 6) +#define P1CR_LINK_GOOD (1 << 5) +#define P1CR_PNTR_FLOW (1 << 4) +#define P1CR_PNTR_100BT_FDX (1 << 3) +#define P1CR_PNTR_100BT_HDX (1 << 2) +#define P1CR_PNTR_10BT_FDX (1 << 1) +#define P1CR_PNTR_10BT_HDX (1 << 0) + +/* TX Frame control */ +#define TXFR_TXIC (1 << 15) +#define TXFR_TXFID_MASK (0x3f << 0) +#define TXFR_TXFID_SHIFT (0) + +#define KS_P1SR 0xF8 +#define P1SR_HP_MDIX (1 << 15) +#define P1SR_REV_POL (1 << 13) +#define P1SR_OP_100M (1 << 10) +#define P1SR_OP_FDX (1 << 9) +#define P1SR_OP_MDI (1 << 7) +#define P1SR_AN_DONE (1 << 6) +#define P1SR_LINK_GOOD (1 << 5) +#define P1SR_PNTR_FLOW (1 << 4) +#define P1SR_PNTR_100BT_FDX (1 << 3) +#define P1SR_PNTR_100BT_HDX (1 << 2) +#define P1SR_PNTR_10BT_FDX (1 << 1) +#define P1SR_PNTR_10BT_HDX (1 << 0) + +#define ENUM_BUS_NONE 0 +#define ENUM_BUS_8BIT 1 +#define ENUM_BUS_16BIT 2 +#define ENUM_BUS_32BIT 3 + +#define MAX_MCAST_LST 32 +#define HW_MCAST_SIZE 8 +#define MAC_ADDR_LEN 6 + +/* Chip ID values */ +struct chip_id { + u16 id; + char *name; +}; + +#endif diff --git a/include/netdev.h b/include/netdev.h index fd3e243..7c2aacb 100644 --- a/include/netdev.h +++ b/include/netdev.h @@ -71,6 +71,7 @@ int greth_initialize(bd_t *bis); void gt6426x_eth_initialize(bd_t *bis); int inca_switch_initialize(bd_t *bis); int ks8695_eth_initialize(void); +int ks8851_mll_initialize(u8 dev_num, int base_addr); int lan91c96_initialize(u8 dev_num, int base_addr); int macb_eth_initialize(int id, void *regs, unsigned int phy_addr); int mcdmafec_initialize(bd_t *bis);
[snip]
- @txb: The header as bytes
/* * union ks_tx_hdr...
Please fix globally.
[snip]
#define<space> please, thanks.
Looks fine aside from these style problems however, thanks!
Hi Tom,
[snip]
- union ks_tx_hdr...
If I use this style comments, when use checkpatch.pl to check, it will report: --->8--- WARNING: networking block comments don't use an empty /* line, use /* Comment... #81: FILE: drivers/net/ks8851_mll.c:41: + +/* ---<8---
So, do you think I should ignore the warning and fix this?
[snip]
I will fix it in next version.
Best Regards, Bo Shen
-----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1
On 04/23/2013 09:20 PM, Bo Shen wrote:
Hi Tom,
[snip]
Add a patch that adds: - --ignore NETWORKING_BLOCK_COMMENT_STYLE
To .checkpatch.conf to the series first, as that should turn off that check. Then correct as U-Boot uses the same style in all drivers.
Thanks again!
- -- Tom
Hi Tom,
Hi Tom,
[snip]
Thanks for your information. I will add this patch and fix the comment style in next version.
Thanks again!
Tom -----BEGIN PGP SIGNATURE----- Version: GnuPG v1.4.11 (GNU/Linux) Comment: Using GnuPG with Thunderbird - http://www.enigmail.net/
iQIcBAEBAgAGBQJRdzeWAAoJENk4IS6UOR1WA+gP/3tiJGaGdGXepBVzNr5xwrFW 0R7aBWx9buMKwyKCxFNlKz1fUfCwOfzS1nHQGN95fK3pvApI7XyYLcmUPN7+bx3p CdgNVlaSHX5gqpl4+CHMKvF2QP4DjMT3jlUQPdTeYaaNCukMZDd3YRRpenazpWnL igruu+NVghwgZxOQF7D9ubovizBdXzwHcV45R5iW2ZCkUAwr2PYnilOOt9hhizqB bHScCXZ8rEWHttGpq+KeYVqWjhFyN/sgFcTuSyrBv56tXRgkUIrKfb6v/bUYI4Xz 8lx1AEBBsA6XVGupgPVLWXLwxYDLDS7vHklKrj68iAlqf7Rj2O2SYWbxHe6NL1vG 4sHJpExtieRcGAV632RmQTqduskOiJMYLxbvU+UVeTLyCV9CCFrae+c2E8oIYO2R OSp1FrX5cdmXQWFY4SdoQ2NTWl/rUDOoUaTjLFBONMg8j9Z37JqZoO2GXohbv0El Pl1BQmYfTRdrqa+MAF7ukxlOeDVLNzi0F2dOpB/R01Tn9qKfw+/lg5hFChp1E2je f5hSqlLl932sPCUCuJzuwZbr1Ye77sJx88ns8V3dldrwYhG4VA5tLYFcioIXg81Y SUzvmAjly92OXc34hXnrhK0Bny4evblHfaDVW+fhVADac4JhHKSoj8wbhWFyllkt 7QMgxq6ycR76u01Z1Q4e =nsHB -----END PGP SIGNATURE-----
add network support with ksz8851_16mll on at91sam9n12ek board
Signed-off-by: Bo Shen voice.shen@atmel.com --- board/atmel/at91sam9n12ek/at91sam9n12ek.c | 36 +++++++++++++++++++++++++++++ include/configs/at91sam9n12ek.h | 4 ++++ 2 files changed, 40 insertions(+)
diff --git a/board/atmel/at91sam9n12ek/at91sam9n12ek.c b/board/atmel/at91sam9n12ek/at91sam9n12ek.c index 8752794..3013a42 100644 --- a/board/atmel/at91sam9n12ek/at91sam9n12ek.c +++ b/board/atmel/at91sam9n12ek/at91sam9n12ek.c @@ -33,6 +33,7 @@ #include <lcd.h> #include <atmel_hlcdc.h> #include <atmel_mci.h> +#include <netdev.h>
#ifdef CONFIG_LCD_INFO #include <nand.h> @@ -190,6 +191,30 @@ int board_mmc_init(bd_t *bd) } #endif
+#ifdef CONFIG_KS8851_MLL +void at91sam9n12ek_ks8851_hw_init(void) +{ + struct at91_smc *smc = (struct at91_smc *)ATMEL_BASE_SMC; + + writel(AT91_SMC_SETUP_NWE(2) | AT91_SMC_SETUP_NCS_WR(0) | + AT91_SMC_SETUP_NRD(1) | AT91_SMC_SETUP_NCS_RD(0), + &smc->cs[2].setup); + writel(AT91_SMC_PULSE_NWE(7) | AT91_SMC_PULSE_NCS_WR(7) | + AT91_SMC_PULSE_NRD(7) | AT91_SMC_PULSE_NCS_RD(7), + &smc->cs[2].pulse); + writel(AT91_SMC_CYCLE_NWE(9) | AT91_SMC_CYCLE_NRD(9), + &smc->cs[2].cycle); + writel(AT91_SMC_MODE_RM_NRD | AT91_SMC_MODE_WM_NWE | + AT91_SMC_MODE_EXNW_DISABLE | + AT91_SMC_MODE_BAT | AT91_SMC_MODE_DBW_16 | + AT91_SMC_MODE_TDF_CYCLE(1), + &smc->cs[2].mode); + + /* Configure NCS2 PIN */ + at91_set_b_periph(AT91_PIO_PORTD, 19, 0); +} +#endif + int board_early_init_f(void) { /* Enable clocks for all PIOs */ @@ -217,9 +242,20 @@ int board_init(void) at91_lcd_hw_init(); #endif
+#ifdef CONFIG_KS8851_MLL + at91sam9n12ek_ks8851_hw_init(); +#endif + return 0; }
+#ifdef CONFIG_KS8851_MLL +int board_eth_init(bd_t *bis) +{ + return ks8851_mll_initialize(0, CONFIG_KS8851_MLL_BASEADDR); +} +#endif + int dram_init(void) { gd->ram_size = get_ram_size((void *)CONFIG_SYS_SDRAM_BASE, diff --git a/include/configs/at91sam9n12ek.h b/include/configs/at91sam9n12ek.h index 8d2673d..b4b1c31 100644 --- a/include/configs/at91sam9n12ek.h +++ b/include/configs/at91sam9n12ek.h @@ -167,6 +167,10 @@ #define CONFIG_DOS_PARTITION #endif
+/* Ethernet */ +#define CONFIG_KS8851_MLL +#define CONFIG_KS8851_MLL_BASEADDR 0x30000000 /* use NCS2 */ + #define CONFIG_SYS_LOAD_ADDR 0x22000000 /* load address */
#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE
Bo Shen
