[PATCH] arm64: zynqmp: Disable the lock option for mini qspi
From: Venkatesh Yadav Abbarapu venkatesh.abbarapu@amd.com
As mini configs are required only for flashing the images, so disabling the lock config which will save nearly 6KB of memory.
Signed-off-by: Venkatesh Yadav Abbarapu venkatesh.abbarapu@amd.com Signed-off-by: Michal Simek michal.simek@amd.com ---
Depends on https://lore.kernel.org/all/20230928034940.2220-2-venkatesh.abbarapu@amd.com... --- configs/xilinx_zynqmp_mini_qspi_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/xilinx_zynqmp_mini_qspi_defconfig b/configs/xilinx_zynqmp_mini_qspi_defconfig index a1adfb9e5d14..4a74ca76a281 100644 --- a/configs/xilinx_zynqmp_mini_qspi_defconfig +++ b/configs/xilinx_zynqmp_mini_qspi_defconfig @@ -77,6 +77,7 @@ CONFIG_SPL_DM_SEQ_ALIAS=y # CONFIG_DM_MAILBOX is not set # CONFIG_MMC is not set # CONFIG_SPI_FLASH_SMART_HWCAPS is not set +# CONFIG_SPI_FLASH_LOCK is not set # CONFIG_SPI_FLASH_UNLOCK_ALL is not set CONFIG_SPI_FLASH_GIGADEVICE=y CONFIG_SPI_FLASH_ISSI=y
Applied. M
Michal Simek
