[PATCH] efi: change usage syntax
syntax was changed from "," to ":". Account this also in the documentation. Fixes: 2b3fbcb59f efi_loader: use ':' as separator for setenv -i
Signed-off-by: Maxim Uvarov maxim.uvarov@linaro.org --- cmd/nvedit.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/cmd/nvedit.c b/cmd/nvedit.c index d188c6aa6b..d03accead9 100644 --- a/cmd/nvedit.c +++ b/cmd/nvedit.c @@ -1472,7 +1472,7 @@ static char env_help_text[] = "env select [target] - select environment target\n" #endif #if defined(CONFIG_CMD_NVEDIT_EFI) - "env set -e [-nv][-bs][-rt][-at][-a][-i addr,size][-v] name [arg ...]\n" + "env set -e [-nv][-bs][-rt][-at][-a][-i addr:size][-v] name [arg ...]\n" " - set UEFI variable; unset if '-i' or 'arg' not specified\n" #endif "env set [-f] name [arg ...]\n";
Thank you for the patch.
For future contributions, please, use scripts/get_maintainer.pl to determine who should be on copy.
Nits: We would normally write this as Fixes: 2b3fbcb59f41 ("efi_loader: use ':' as separator for setenv -i")
I will also correct the following line when merging:
diff --git a/cmd/nvedit.c b/cmd/nvedit.c index 63b0c5f802..7fce723800 100644 --- a/cmd/nvedit.c +++ b/cmd/nvedit.c @@ -1541,7 +1541,7 @@ U_BOOT_CMD_COMPLETE( "set environment variables", #if defined(CONFIG_CMD_NVEDIT_EFI) "-e [-guid guid][-nv][-bs][-rt][-at][-a][-v]\n" - " [-i addr,size name], or [name [value ...]]\n" + " [-i addr:size name], or [name [value ...]]\n" " - set UEFI variable 'name' to 'value' ...'\n" " "-guid": GUID xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx\n" " "-nv": set non-volatile attribute\n"
Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de
- "env set -e [-nv][-bs][-rt][-at][-a][-i addr:size][-v] name [arg ...]\n" " - set UEFI variable; unset if '-i' or 'arg' not specified\n"
Maxim Uvarov
