Data abort when starting DFU on SAMA5D2
Hi, I am currently using an ATSAMA5D27-WLSOM1-EK1. This boards embeds an ATSAMA5D27-WLSOM1, which in turns holds an ATSAMA5D27 and a 8MB QSPI flash. I have been wanting to program u-boot in the QSPI flash thanks to DFU, since the board is able to boot from QSPI and is supported in uboot. To do so, I have executed the following steps: - check out recent uboot version (2023.07.02, but issed described below is observed on master too) - load sama5d27_wlsom1_ek_qspiflash_defconfig - tune the configuration to enable DFU: - CONFIG_CMD_DFU=y - CONFIG_DFU_SF=y - CONFIG_USB_GADGET_DOWNLOAD=y - build uboot, upload and run it onto external ram thanks to snagrecover ([1]). - running "bdinfo" shows that board is properly defined/recognized - "sf probe" properly detects the qspi flash chip - in u-boot console, configure dfu: - setenv dfu_alt_info uboot raw 0 0x80000 - start DFU: - dfu 0 sf 2:0
Unfortunately, this step systematically and immediately leads to a data abort with the following log:
=> dfu 0 sf 2:0 data abort pc : [<2fda9ee0>] lr : [<2fd8dc08>] reloc pc : [<26f3fee0>]lr : [<26f23c08>] sp : 2f963fe8 ip : 2f9829cc fp : 00000000 r10: 2fde1cd9 r9 : 2f969e80 r8 : 2fdfc304 r7 : 00000000 r6 : 00000000 r5 : 2fdf3034 r4 : 2f982948 r3 : 0a299cfc r2 : ffffffec r1 : 00000000 r0 : 00000000 Flags: nzCv IRQs off FIQs off Mode SVC_32 Code: e5843058 e5950004 e3a01000 e5903008 (e5933008) Resetting CPU ...
resetting ... System reset not supported on this platform ### ERROR ### Please RESET the board ###
A quick translation with addr2line shows that the data abort occurs in include/linux/usb/gagdet.h, in usb_ep_alloc_request, likely because of ep being NULL, which seems confirmed by adding some custom logs in both usb_ep_alloc_request and its caller (composite_bind). Before digging further, does anyone have successfully used DFU on SAMA5D2 boards (and if so, am I missing something in the configuration) ? Or does this data abort show that some support is still missing to make it work for SAMA5D2 ?
Kind regards, Alexis
[1] https://github.com/bootlin/snagboot
Hi Alexis,
- CONFIG_CMD_DFU=y
- CONFIG_DFU_SF=y
- start DFU:
- dfu 0 sf 2:0
I believe this is related to the gadget more than DFU itself. Zixun LI (in CC) has attempted gadget on this platform at some point.
Mihai (also in CC) has did some tests with USB on this platform as well. Cristian has more knowledge of the USB implementation on sama5d2.
Eugen
Hi Alexis,
I've tried to USB gardet under u-boot without success (linux is ok).
I've contacted Microchip support (No.01275010) and from them: "we confirmed with the internal team that USB is not fully functional with u-boot so for any query related to working of USB in u-boot we request you to create a NASCAR."
Regards, Zixun
On Wed, Aug 2, 2023 at 9:11 AM Eugen Hristev eugen.hristev@collabora.com wrote:
Hi Alexis,
flash. I
since the
have
is
- CONFIG_CMD_DFU=y
- CONFIG_DFU_SF=y
([1]).
- start DFU:
- dfu 0 sf 2:0
abort
ep being
further,
that some
Eugen
Hello Zixun, Eugen,
On 8/2/23 09:38, admin LI wrote:
Hi Alexis,
Thanks for the feedback and the status confirmation. I fell back with sam-ba for the moment
Kind regards,
Regards, Zixun
On Wed, Aug 2, 2023 at 9:11 AM Eugen Hristev <eugen.hristev@collabora.com mailto:eugen.hristev@collabora.com> wrote:
Hi Alexis, On 8/1/23 10:09, Alexis Lothoré wrote: > Hi, > I am currently using an ATSAMA5D27-WLSOM1-EK1. This boards embeds an > ATSAMA5D27-WLSOM1, which in turns holds an ATSAMA5D27 and a 8MB QSPI flash. I > have been wanting to program u-boot in the QSPI flash thanks to DFU, since the > board is able to boot from QSPI and is supported in uboot. To do so, I have > executed the following steps: > - check out recent uboot version (2023.07.02, but issed described below is > observed on master too) > - load sama5d27_wlsom1_ek_qspiflash_defconfig > - tune the configuration to enable DFU: > - CONFIG_CMD_DFU=y > - CONFIG_DFU_SF=y > - CONFIG_USB_GADGET_DOWNLOAD=y > - build uboot, upload and run it onto external ram thanks to snagrecover ([1]). > - running "bdinfo" shows that board is properly defined/recognized > - "sf probe" properly detects the qspi flash chip > - in u-boot console, configure dfu: > - setenv dfu_alt_info uboot raw 0 0x80000 > - start DFU: > - dfu 0 sf 2:0 > > Unfortunately, this step systematically and immediately leads to a data abort > with the following log: > > => dfu 0 sf 2:0 > data abort > pc : [<2fda9ee0>] lr : [<2fd8dc08>] > reloc pc : [<26f3fee0>]lr : [<26f23c08>] > sp : 2f963fe8 ip : 2f9829cc fp : 00000000 > r10: 2fde1cd9 r9 : 2f969e80 r8 : 2fdfc304 > r7 : 00000000 r6 : 00000000 r5 : 2fdf3034 r4 : 2f982948 > r3 : 0a299cfc r2 : ffffffec r1 : 00000000 r0 : 00000000 > Flags: nzCv IRQs off FIQs off Mode SVC_32 > Code: e5843058 e5950004 e3a01000 e5903008 (e5933008) > Resetting CPU ... > > resetting ... > System reset not supported on this platform > ### ERROR ### Please RESET the board ### > > A quick translation with addr2line shows that the data abort occurs in > include/linux/usb/gagdet.h, in usb_ep_alloc_request, likely because of ep being > NULL, which seems confirmed by adding some custom logs in both > usb_ep_alloc_request and its caller (composite_bind). Before digging further, > does anyone have successfully used DFU on SAMA5D2 boards (and if so, am I > missing something in the configuration) ? Or does this data abort show that some > support is still missing to make it work for SAMA5D2 ? I believe this is related to the gadget more than DFU itself. Zixun LI (in CC) has attempted gadget on this platform at some point. Mihai (also in CC) has did some tests with USB on this platform as well. Cristian has more knowledge of the USB implementation on sama5d2. Eugen > > Kind regards, > Alexis > > [1] https://github.com/bootlin/snagboot <https://github.com/bootlin/snagboot>
admin LI
Alexis Lothoré
Eugen Hristev
