[U-Boot] [PATCH] UBI/cfi-mtd: Fix mtd name for multiple chips
On platforms with multiple NOR chips, currently only the first one can be selected using the "ubi part" command. This patch fixes this problem by using different names for the NOR "mtd devices".
It also changes the name of the NOR MTD device from "cfi-mtd" to "norX" (X indexing the device numer) to better match the mtdparts defaults.
Signed-off-by: Stefan Roese sr@denx.de Signed-off-by: Andreas Huber andreas.huber@keymile.com --- common/cmd_ubi.c | 26 +++++++++++++++++++++----- drivers/mtd/cfi_mtd.c | 4 +++- include/flash.h | 2 -- 3 files changed, 24 insertions(+), 8 deletions(-)
diff --git a/common/cmd_ubi.c b/common/cmd_ubi.c index b99fd58..9c17d71 100644 --- a/common/cmd_ubi.c +++ b/common/cmd_ubi.c @@ -404,9 +404,6 @@ static int ubi_dev_scan(struct mtd_info *info, char *ubidev) u8 pnum; int err;
- if (mtdparts_init() != 0) - return 1; - if (find_dev_and_part(ubidev, &dev, &pnum, &part) != 0) return 1;
@@ -445,6 +442,11 @@ static int do_ubi(cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) return 1; }
+ if (mtdparts_init() != 0) { + printf("Error initializing mtdparts!\n"); + return 1; + } + if (strcmp(argv[1], "part") == 0) { /* Print current partition */ if (argc == 2) { @@ -475,7 +477,7 @@ static int do_ubi(cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) }
/* - * Check for nand|onenand selection + * Check for nor|nand|onenand selection */ #if defined(CONFIG_CMD_NAND) if (strcmp(argv[2], "nand") == 0) { @@ -486,9 +488,23 @@ static int do_ubi(cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) #endif #if defined(CONFIG_FLASH_CFI_MTD) if (strcmp(argv[2], "nor") == 0) { + char mtd_dev[16]; + struct mtd_device *dev; + struct part_info *part; + u8 pnum; + + /* + * Search the mtd device number where this partition + * is located + */ + if (find_dev_and_part(argv[3], &dev, &pnum, &part)) { + printf("Partition %s not found!\n", argv[3]); + return 1; + } + sprintf(mtd_dev, "nor%d", dev->id->num); + ubi_dev.mtd_info = get_mtd_device_nm(mtd_dev); strcpy(ubi_dev.dev_name, "NOR"); ubi_dev.type = DEV_TYPE_NOR; - ubi_dev.mtd_info = get_mtd_device_nm(CFI_MTD_DEV_NAME); } #endif #if defined(CONFIG_CMD_ONENAND) diff --git a/drivers/mtd/cfi_mtd.c b/drivers/mtd/cfi_mtd.c index 1000f1b..f03e4fb 100644 --- a/drivers/mtd/cfi_mtd.c +++ b/drivers/mtd/cfi_mtd.c @@ -32,6 +32,7 @@ extern flash_info_t flash_info[];
static struct mtd_info cfi_mtd_info[CONFIG_SYS_MAX_FLASH_BANKS]; +static char cfi_mtd_names[CONFIG_SYS_MAX_FLASH_BANKS][16];
static int cfi_mtd_erase(struct mtd_info *mtd, struct erase_info *instr) { @@ -170,7 +171,8 @@ int cfi_mtd_init(void) if (error) continue;
- mtd->name = CFI_MTD_DEV_NAME; + sprintf(cfi_mtd_names[i], "nor%d", i); + mtd->name = cfi_mtd_names[i]; mtd->type = MTD_NORFLASH; mtd->flags = MTD_CAP_NORFLASH; mtd->size = fi->size; diff --git a/include/flash.h b/include/flash.h index 8b8979e..b016162 100644 --- a/include/flash.h +++ b/include/flash.h @@ -87,8 +87,6 @@ typedef unsigned long flash_sect_t; /* convert between bit value and numeric value */ #define CFI_FLASH_SHIFT_WIDTH 3
-/* cfi-mtd device name */ -#define CFI_MTD_DEV_NAME "cfi-mtd" /* Prototypes */
extern unsigned long flash_init (void);
Dear Stefan Roese,
Applied, thanks.
Stefan Roese
