[PATCH v2 00/21] Refactor the architecture parts of mt7628
This patch series are divided into two parts:
The main part is to rewrite the whole architecture code of mt7628: 1. Lock parts of the d-cache for initial stack so the rest of the code can be reimplemented in C. 2. Memory controller & DDR initialization have been fully written to support detecting DDR size automatically. 3. DDR calibration has also been reimplemented with a clear logic. 4. Implemented a new sysreset driver to take advantage of the reset controller so we can drop the use of syscon-based sysreset to reduce size.
The second part is to add SPL support for mt7628: 1. With SPL enabled we can build the ROM-bootable and RAM-bootable binary simultaneously, and we can drop RAM boot related configs and defconfig files. 2. Generate compressed u-boot.bin image for SPL to reduce size of final combined binary. 3. Enable DM support for SPL for a more flexible device probing. 4. Add a demo board (mt7628_rfb) aims at router application.
Changes since v1: 1. Split 'mips: mtmips: rewrite lowlevel codes of mt7628' into multiple patches. 2. Dropped a patch which tried to use customized get_tbclk(). 3. Dropped a patch which tried to rename mt7628a.dtsi to mt7628.dtsi 4. Refactor the patch which restores exception vector base before booting linux. 5. Define a new option to enable u_boot_list in SPL. 6. Enable compressed spl payload for all boards. 7. Enable DM and DT support for linkit and gardena-smart-gateway. 8. Complete pinmux for all three UARTs for SPL. 9. Rewrite u_boot_lzma_img.py.
Weijie Gao (21): mips: add support to restore exception vector base before booting linux mips: mtmips: add predefined i-cache/d-cache size and linesize mips: add an option to support initialize SRAM for initial stack mips: start.S: avoid overwriting outside gd when clearing global data in stack sysreset: add reset controller based reboot driver mips: mtmips: make use of sysreset-resetctrl for mt7628 soc configs: enable CONFIG_RESTORE_EXCEPTION_VECTOR_BASE for all mtmips boards mips: add a mtmips-specific field to architecture-specific global data mips: add a option to support not reserving malloc space on initial stack mips: mtmips: rewrite lowlevel codes of mt7628 dts: mtmips: remove all unusable nodes and properties from mt7628s.dtsi dts: mtmips: add u-boot,dm-pre-reloc for some nodes in mt7628a.dtsi dts: mtmips: add alternative pinmux node for uart2 mips: enable support for appending dtb to spl binary mips: add an option to enable u_boot_list section for SPL loaders in u-boot-spl.lds lib: enable lzma decompression support for SPL build Makefile: add support to generate LZMA compressed u-boot image tools: binman: add etype file for u-boot-lzma-img mips: mtmips: add SPL support mips: mtmips: enable SPL for all boards mips: mtmips: add support for mt7628-rfb
Makefile | 22 ++ arch/mips/Kconfig | 60 ++++ arch/mips/cpu/start.S | 16 +- arch/mips/cpu/u-boot-spl.lds | 4 +- arch/mips/dts/Makefile | 1 + arch/mips/dts/mediatek,mt7628-rfb.dts | 67 ++++ arch/mips/dts/mt7628-u-boot.dtsi | 24 ++ arch/mips/dts/mt7628a.dtsi | 93 ++--- arch/mips/include/asm/global_data.h | 3 + arch/mips/include/asm/u-boot-mips.h | 2 + arch/mips/lib/bootm.c | 3 + arch/mips/lib/traps.c | 19 + arch/mips/mach-mtmips/Kconfig | 133 +++---- arch/mips/mach-mtmips/Makefile | 8 +- arch/mips/mach-mtmips/cpu.c | 58 +--- arch/mips/mach-mtmips/ddr_cal.c | 211 +++++++++++ arch/mips/mach-mtmips/ddr_calibrate.c | 309 ----------------- arch/mips/mach-mtmips/ddr_init.c | 194 +++++++++++ arch/mips/mach-mtmips/include/mach/ddr.h | 52 +++ arch/mips/mach-mtmips/include/mach/mc.h | 180 ++++++++++ arch/mips/mach-mtmips/include/mach/serial.h | 13 + arch/mips/mach-mtmips/include/mach/spl.h | 14 + arch/mips/mach-mtmips/lowlevel_init.S | 328 ------------------ arch/mips/mach-mtmips/mt7628/Makefile | 6 + arch/mips/mach-mtmips/mt7628/ddr.c | 173 +++++++++ arch/mips/mach-mtmips/mt7628/init.c | 109 ++++++ arch/mips/mach-mtmips/mt7628/lowlevel_init.S | 161 +++++++++ arch/mips/mach-mtmips/mt7628/mt7628.h | 104 ++++++ arch/mips/mach-mtmips/mt7628/serial.c | 34 ++ arch/mips/mach-mtmips/mt76xx.h | 32 -- arch/mips/mach-mtmips/spl.c | 35 ++ arch/mips/mach-mtmips/spl_load.c | 121 +++++++ board/gardena/smart-gateway-mt7688/board.c | 2 + board/mediatek/mt7628/Kconfig | 12 + board/mediatek/mt7628/MAINTAINERS | 7 + board/mediatek/mt7628/Makefile | 3 + board/mediatek/mt7628/board.c | 8 + ...gardena-smart-gateway-mt7688-ram_defconfig | 74 ---- .../gardena-smart-gateway-mt7688_defconfig | 15 +- configs/linkit-smart-7688-ram_defconfig | 65 ---- configs/linkit-smart-7688_defconfig | 15 +- configs/mt7628_rfb_defconfig | 45 +++ drivers/sysreset/Kconfig | 6 + drivers/sysreset/Makefile | 1 + drivers/sysreset/sysreset_resetctl.c | 48 +++ .../configs/gardena-smart-gateway-mt7688.h | 18 +- include/configs/linkit-smart-7688.h | 19 +- include/configs/mt7628.h | 52 +++ lib/Kconfig | 5 + lib/Makefile | 1 + tools/binman/README.entries | 15 + tools/binman/etype/u_boot_lzma_img.py | 28 ++ 52 files changed, 1987 insertions(+), 1041 deletions(-) create mode 100644 arch/mips/dts/mediatek,mt7628-rfb.dts create mode 100644 arch/mips/dts/mt7628-u-boot.dtsi create mode 100644 arch/mips/mach-mtmips/ddr_cal.c delete mode 100644 arch/mips/mach-mtmips/ddr_calibrate.c create mode 100644 arch/mips/mach-mtmips/ddr_init.c create mode 100644 arch/mips/mach-mtmips/include/mach/ddr.h create mode 100644 arch/mips/mach-mtmips/include/mach/mc.h create mode 100644 arch/mips/mach-mtmips/include/mach/serial.h create mode 100644 arch/mips/mach-mtmips/include/mach/spl.h delete mode 100644 arch/mips/mach-mtmips/lowlevel_init.S create mode 100644 arch/mips/mach-mtmips/mt7628/Makefile create mode 100644 arch/mips/mach-mtmips/mt7628/ddr.c create mode 100644 arch/mips/mach-mtmips/mt7628/init.c create mode 100644 arch/mips/mach-mtmips/mt7628/lowlevel_init.S create mode 100644 arch/mips/mach-mtmips/mt7628/mt7628.h create mode 100644 arch/mips/mach-mtmips/mt7628/serial.c delete mode 100644 arch/mips/mach-mtmips/mt76xx.h create mode 100644 arch/mips/mach-mtmips/spl.c create mode 100644 arch/mips/mach-mtmips/spl_load.c create mode 100644 board/mediatek/mt7628/Kconfig create mode 100644 board/mediatek/mt7628/MAINTAINERS create mode 100644 board/mediatek/mt7628/Makefile create mode 100644 board/mediatek/mt7628/board.c delete mode 100644 configs/gardena-smart-gateway-mt7688-ram_defconfig delete mode 100644 configs/linkit-smart-7688-ram_defconfig create mode 100644 configs/mt7628_rfb_defconfig create mode 100644 drivers/sysreset/sysreset_resetctl.c create mode 100644 include/configs/mt7628.h create mode 100644 tools/binman/etype/u_boot_lzma_img.py
Hi Weijie,
I've added another of my mail addresses to cc (mail@roese.nl) as the sending to the other 2 addresses does not seem to work.
- Lock parts of the d-cache for initial stack so the rest of the code can be reimplemented in C.
- Memory controller & DDR initialization have been fully written to support detecting DDR size automatically.
- DDR calibration has also been reimplemented with a clear logic.
- Implemented a new sysreset driver to take advantage of the reset controller so we can drop the use of syscon-based sysreset to reduce size.
- With SPL enabled we can build the ROM-bootable and RAM-bootable binary simultaneously, and we can drop RAM boot related configs and defconfig files.
- Generate compressed u-boot.bin image for SPL to reduce size of final combined binary.
- Enable DM support for SPL for a more flexible device probing.
- Add a demo board (mt7628_rfb) aims at router application.
Changes since v1:
- Split 'mips: mtmips: rewrite lowlevel codes of mt7628' into multiple patches.
- Dropped a patch which tried to use customized get_tbclk().
- Dropped a patch which tried to rename mt7628a.dtsi to mt7628.dtsi
- Refactor the patch which restores exception vector base before booting linux.
- Define a new option to enable u_boot_list in SPL.
- Enable compressed spl payload for all boards.
- Enable DM and DT support for linkit and gardena-smart-gateway.
- Complete pinmux for all three UARTs for SPL.
- Rewrite u_boot_lzma_img.py.
Weijie Gao (21):
It seems that patch 09/21 is missing on the list. Is it stuck in moderation? Or is the patch numbering corrupt?
Thanks, Stefan
On Fri, 2020-01-17 at 15:40 +0100, Stefan Roese wrote:
Hi Weijie,
Changes since v1:
Weijie Gao (21):
Thanks, Stefan
It's missing on my list. I've resent it.
Hi Weijie,
Hi Weijie,
Changes since v1:
Weijie Gao (21):
Thanks, Stefan
Thanks. Applying this patchset on top of current mainline results in this compilation error (using linkit-smart-7688_defconfig):
arch/mips/mach-mtmips/built-in.o: In function `get_tbclk': /home/stefan/git/u-boot/u-boot/arch/mips/mach-mtmips/mt7628/init.c:108: multiple definition of `get_tbclk' arch/mips/cpu/built-in.o:/home/stefan/git/u-boot/u-boot/arch/mips/cpu/time.c:18: first defined here make: *** [Makefile:1695: u-boot] Error 1
Is something else missing?
Thanks, Stefan
On 20.01.20 08:08, Stefan Roese wrote:
Hi Weijie,
Hi Weijie,
Changes since v1:
Weijie Gao (21):
Thanks, Stefan
Okay, I think I found it. This patch here is missing:
https://patchwork.ozlabs.org/patch/1215073/
Thanks, Stefan
On Mon, 2020-01-20 at 08:08 +0100, Stefan Roese wrote:
Hi Weijie,
Hi Weijie,
Changes since v1:
Weijie Gao (21):
Thanks, Stefan
Thanks, Stefan
Daniel said he has merged a patch which makes the original get_tbclk weak (arch/mips/cpu/time.c), and let me drop a related patch.
I haven't seen it shown in mainline yet.
Stefan Roese
Weijie Gao
