Re: [U-Boot] [PATCH 3/9 v8] Exynos5420: Add clock initialization for 5420
ping.
-------- Original Message -------- Subject: Re: [PATCH 3/9 v8] Exynos5420: Add clock initialization for 5420 Date: Thu, 21 Nov 2013 16:03:23 +0900 From: Minkyu Kang mk7.kang@samsung.com Organization: SAMSUNG ELECTRONICS To: Rajeshwari S Shinde rajeshwari.s@samsung.com CC: u-boot@lists.denx.de, patches@linaro.org, sjg@chromium.org, chander.kashyap@linaro.org, u-boot-review@google.com, alim.akhtar@samsung.com, trini@ti.com
Dear Rajeshwari,
On 15/11/13 13:59, Rajeshwari S Shinde wrote:
This patch adds code for clock initialization and clock settings of various IP's and controllers, required for Exynos5420
Signed-off-by: Rajeshwari S Shinde rajeshwari.s@samsung.com Signed-off-by: Akshay Saraswat akshay.s@samsung.com Acked-by: Simon Glass sjg@chromium.org
Changes in V2:
- None
Changes in V3:
- None
Changes in V4:
- Corrected the multiline commenting style
Changes in V5:
- None
Changes in V6:
- None
Changes in V7:
- Correct the logic for exynos5420_set_spi_clk api.
Changes in V8:
- Chnages the if condition loop for pro_id and cpu_id.
arch/arm/cpu/armv7/exynos/clock.c | 258 ++++++++- arch/arm/cpu/armv7/exynos/clock_init.h | 17 + arch/arm/cpu/armv7/exynos/clock_init_exynos5.c | 352 +++++++++++- arch/arm/cpu/armv7/exynos/exynos5_setup.h | 738 +++++++++++++++++++------ arch/arm/include/asm/arch-exynos/clk.h | 1 + arch/arm/include/asm/arch-exynos/clock.h | 494 +++++++++++++++++ 6 files changed, 1659 insertions(+), 201 deletions(-)
diff --git a/arch/arm/cpu/armv7/exynos/clock_init_exynos5.c b/arch/arm/cpu/armv7/exynos/clock_init_exynos5.c index a24c2f3..e7f1496 100644 --- a/arch/arm/cpu/armv7/exynos/clock_init_exynos5.c +++ b/arch/arm/cpu/armv7/exynos/clock_init_exynos5.c @@ -24,6 +24,24 @@ DECLARE_GLOBAL_DATA_PTR;
struct arm_clk_ratios arm_clk_ratios[] = { +#ifdef CONFIG_EXYNOS5420
.arm_freq_mhz = 900,
.apll_mdiv = 0x96,
.apll_pdiv = 0x2,
.apll_sdiv = 0x1,
.arm2_ratio = 0x0,
.apll_ratio = 0x3,
.pclk_dbg_ratio = 0x6,
.atb_ratio = 0x6,
.periph_ratio = 0x7,
.acp_ratio = 0x0,
.cpud_ratio = 0x2,
.arm_ratio = 0x0,
+#else { .arm_freq_mhz = 600,
@@ -115,8 +133,133 @@ struct arm_clk_ratios arm_clk_ratios[] = { .cpud_ratio = 0x3, .arm_ratio = 0x0, } +#endif };
struct mem_timings mem_timings[] = { +#ifdef CONFIG_EXYNOS5420
.mem_manuf = MEM_MANUF_SAMSUNG,
.mem_type = DDR_MODE_DDR3,
.frequency_mhz = 800,
/* MPLL @800MHz*/
.mpll_mdiv = 0xc8,
.mpll_pdiv = 0x3,
.mpll_sdiv = 0x1,
/* CPLL @666MHz */
.cpll_mdiv = 0xde,
.cpll_pdiv = 0x4,
.cpll_sdiv = 0x1,
/* EPLL @600MHz */
.epll_mdiv = 0x64,
.epll_pdiv = 0x2,
.epll_sdiv = 0x1,
/* VPLL @430MHz */
.vpll_mdiv = 0xd7,
.vpll_pdiv = 0x3,
.vpll_sdiv = 0x2,
/* BPLL @800MHz */
.bpll_mdiv = 0xc8,
.bpll_pdiv = 0x3,
.bpll_sdiv = 0x1,
/* KPLL @600MHz */
.kpll_mdiv = 0x190,
.kpll_pdiv = 0x4,
.kpll_sdiv = 0x2,
/* DPLL @600MHz */
.dpll_mdiv = 0x190,
.dpll_pdiv = 0x4,
.dpll_sdiv = 0x2,
/* IPLL @370MHz */
.ipll_mdiv = 0xb9,
.ipll_pdiv = 0x3,
.ipll_sdiv = 0x2,
/* SPLL @400MHz */
.spll_mdiv = 0xc8,
.spll_pdiv = 0x3,
.spll_sdiv = 0x2,
.direct_cmd_msr = {
0x00020018, 0x00030000, 0x00010046, 0x00000d70,
0x00000c70
.timing_ref = 0x000000bb,
.timing_row = 0x6836650f,
.timing_data = 0x3630580b,
.timing_power = 0x41000a26,
.phy0_dqs = 0x08080808,
.phy1_dqs = 0x08080808,
.phy0_dq = 0x08080808,
.phy1_dq = 0x08080808,
.phy0_tFS = 0x8,
.phy1_tFS = 0x8,
.phy0_pulld_dqs = 0xf,
.phy1_pulld_dqs = 0xf,
.lpddr3_ctrl_phy_reset = 0x1,
.ctrl_start_point = 0x10,
.ctrl_inc = 0x10,
.ctrl_start = 0x1,
.ctrl_dll_on = 0x1,
.ctrl_ref = 0x8,
.ctrl_force = 0x1a,
.ctrl_rdlat = 0x0b,
.ctrl_bstlen = 0x08,
.fp_resync = 0x8,
.iv_size = 0x7,
.dfi_init_start = 1,
.aref_en = 1,
.rd_fetch = 0x3,
.zq_mode_dds = 0x7,
.zq_mode_term = 0x1,
.zq_mode_noterm = 1,
* Dynamic Clock: Always Running
* Memory Burst length: 8
* Number of chips: 1
* Memory Bus width: 32 bit
* Memory Type: DDR3
* Additional Latancy for PLL: 0 Cycle
.memcontrol = DMC_MEMCONTROL_CLK_STOP_DISABLE |
DMC_MEMCONTROL_DPWRDN_DISABLE |
DMC_MEMCONTROL_DPWRDN_ACTIVE_PRECHARGE |
DMC_MEMCONTROL_TP_DISABLE |
DMC_MEMCONTROL_DSREF_DISABLE |
DMC_MEMCONTROL_ADD_LAT_PALL_CYCLE(0) |
DMC_MEMCONTROL_MEM_TYPE_DDR3 |
DMC_MEMCONTROL_MEM_WIDTH_32BIT |
DMC_MEMCONTROL_NUM_CHIP_1 |
DMC_MEMCONTROL_BL_8 |
DMC_MEMCONTROL_PZQ_DISABLE |
DMC_MEMCONTROL_MRR_BYTE_7_0,
.memconfig = DMC_MEMCONFIG_CHIP_MAP_SPLIT |
DMC_MEMCONFIGX_CHIP_COL_10 |
DMC_MEMCONFIGX_CHIP_ROW_15 |
DMC_MEMCONFIGX_CHIP_BANK_8,
.prechconfig_tp_cnt = 0xff,
.dpwrdn_cyc = 0xff,
.dsref_cyc = 0xffff,
.concontrol = DMC_CONCONTROL_DFI_INIT_START_DISABLE |
DMC_CONCONTROL_TIMEOUT_LEVEL0 |
DMC_CONCONTROL_RD_FETCH_DISABLE |
DMC_CONCONTROL_EMPTY_DISABLE |
DMC_CONCONTROL_AREF_EN_DISABLE |
DMC_CONCONTROL_IO_PD_CON_DISABLE,
.dmc_channels = 1,
.chips_per_channel = 1,
.chips_to_configure = 1,
.send_zq_init = 1,
.gate_leveling_enable = 1,
.read_leveling_enable = 0,
+#else { .mem_manuf = MEM_MANUF_ELPIDA, .mem_type = DDR_MODE_DDR3, @@ -324,6 +467,7 @@ struct mem_timings mem_timings[] = { .impedance = IMP_OUTPUT_DRV_40_OHM, .gate_leveling_enable = 1, } +#endif };
/** @@ -399,7 +543,7 @@ struct mem_timings *clock_get_mem_timings(void) return NULL; }
-void system_clock_init() +static void exynos5250_system_clock_init(void) { struct exynos5_clock *clk = (struct exynos5_clock *)samsung_get_base_clock(); @@ -436,19 +580,13 @@ void system_clock_init() } while ((val | MUX_BPLL_SEL_MASK) != val);
/* PLL locktime */
- writel(APLL_LOCK_VAL, &clk->apll_lock);
- writel(MPLL_LOCK_VAL, &clk->mpll_lock);
- writel(BPLL_LOCK_VAL, &clk->bpll_lock);
- writel(CPLL_LOCK_VAL, &clk->cpll_lock);
- writel(GPLL_LOCK_VAL, &clk->gpll_lock);
- writel(EPLL_LOCK_VAL, &clk->epll_lock);
- writel(VPLL_LOCK_VAL, &clk->vpll_lock);
writel(mem->apll_pdiv * PLL_LOCK_FACTOR, &clk->apll_lock);
writel(mem->mpll_pdiv * PLL_LOCK_FACTOR, &clk->mpll_lock);
writel(mem->bpll_pdiv * PLL_LOCK_FACTOR, &clk->bpll_lock);
writel(mem->cpll_pdiv * PLL_LOCK_FACTOR, &clk->cpll_lock);
writel(mem->gpll_pdiv * PLL_X_LOCK_FACTOR, &clk->gpll_lock);
writel(mem->epll_pdiv * PLL_X_LOCK_FACTOR, &clk->epll_lock);
writel(mem->vpll_pdiv * PLL_X_LOCK_FACTOR, &clk->vpll_lock);
writel(CLK_REG_DISABLE, &clk->pll_div2_sel);
@@ -640,6 +778,192 @@ void system_clock_init() writel(val, &clk->div_fsys2); }
+static void exynos5420_system_clock_init(void) +{
- struct exynos5420_clock *clk =
(struct exynos5420_clock *)EXYNOS5_CLOCK_BASE;
- struct mem_timings *mem;
- struct arm_clk_ratios *arm_clk_ratio;
- u32 val;
- mem = clock_get_mem_timings();
- arm_clk_ratio = get_arm_ratios();
- /* PLL locktime */
- writel(arm_clk_ratio->apll_pdiv * PLL_LOCK_FACTOR, &clk->apll_lock);
- writel(mem->mpll_pdiv * PLL_LOCK_FACTOR, &clk->mpll_lock);
- writel(mem->bpll_pdiv * PLL_LOCK_FACTOR, &clk->bpll_lock);
- writel(mem->cpll_pdiv * PLL_LOCK_FACTOR, &clk->cpll_lock);
- writel(mem->dpll_pdiv * PLL_LOCK_FACTOR, &clk->dpll_lock);
- writel(mem->epll_pdiv * PLL_X_LOCK_FACTOR, &clk->epll_lock);
- writel(mem->vpll_pdiv * PLL_LOCK_FACTOR, &clk->vpll_lock);
- writel(mem->ipll_pdiv * PLL_LOCK_FACTOR, &clk->ipll_lock);
- writel(mem->spll_pdiv * PLL_LOCK_FACTOR, &clk->spll_lock);
- writel(mem->kpll_pdiv * PLL_LOCK_FACTOR, &clk->kpll_lock);
- setbits_le32(&clk->src_cpu, MUX_HPM_SEL_MASK);
- writel(0, &clk->src_top6);
- writel(0, &clk->src_cdrex);
- writel(SRC_KFC_HPM_SEL, &clk->src_kfc);
- writel(HPM_RATIO, &clk->div_cpu1);
- writel(CLK_DIV_CPU0_VAL, &clk->div_cpu0);
- /* switch A15 clock source to OSC clock before changing APLL */
- clrbits_le32(&clk->src_cpu, APLL_FOUT);
- /* Set APLL */
- writel(APLL_CON1_VAL, &clk->apll_con1);
- val = set_pll(arm_clk_ratio->apll_mdiv,
arm_clk_ratio->apll_pdiv,
arm_clk_ratio->apll_sdiv);
- writel(val, &clk->apll_con0);
- while ((readl(&clk->apll_con0) & PLL_LOCKED) == 0)
- /* now it is safe to switch to APLL */
- setbits_le32(&clk->src_cpu, APLL_FOUT);
- writel(CLK_DIV_KFC_VAL, &clk->div_kfc0);
- /* switch A7 clock source to OSC clock before changing KPLL */
- clrbits_le32(&clk->src_kfc, KPLL_FOUT);
- /* Set KPLL*/
- writel(KPLL_CON1_VAL, &clk->kpll_con1);
- val = set_pll(mem->kpll_mdiv, mem->kpll_pdiv, mem->kpll_sdiv);
- writel(val, &clk->kpll_con0);
- while ((readl(&clk->kpll_con0) & PLL_LOCKED) == 0)
- /* now it is safe to switch to KPLL */
- setbits_le32(&clk->src_kfc, KPLL_FOUT);
- /* Set MPLL */
- writel(MPLL_CON1_VAL, &clk->mpll_con1);
- val = set_pll(mem->mpll_mdiv, mem->mpll_pdiv, mem->mpll_sdiv);
- writel(val, &clk->mpll_con0);
- while ((readl(&clk->mpll_con0) & PLL_LOCKED) == 0)
- /* Set DPLL */
- writel(DPLL_CON1_VAL, &clk->dpll_con1);
- val = set_pll(mem->dpll_mdiv, mem->dpll_pdiv, mem->dpll_sdiv);
- writel(val, &clk->dpll_con0);
- while ((readl(&clk->dpll_con0) & PLL_LOCKED) == 0)
- /* Set EPLL */
- writel(EPLL_CON2_VAL, &clk->epll_con2);
- writel(EPLL_CON1_VAL, &clk->epll_con1);
- val = set_pll(mem->epll_mdiv, mem->epll_pdiv, mem->epll_sdiv);
- writel(val, &clk->epll_con0);
- while ((readl(&clk->epll_con0) & PLL_LOCKED) == 0)
- /* Set CPLL */
- writel(CPLL_CON1_VAL, &clk->cpll_con1);
- val = set_pll(mem->cpll_mdiv, mem->cpll_pdiv, mem->cpll_sdiv);
- writel(val, &clk->cpll_con0);
- while ((readl(&clk->cpll_con0) & PLL_LOCKED) == 0)
- /* Set IPLL */
- writel(IPLL_CON1_VAL, &clk->ipll_con1);
- val = set_pll(mem->ipll_mdiv, mem->ipll_pdiv, mem->ipll_sdiv);
- writel(val, &clk->ipll_con0);
- while ((readl(&clk->ipll_con0) & PLL_LOCKED) == 0)
- /* Set VPLL */
- writel(VPLL_CON1_VAL, &clk->vpll_con1);
- val = set_pll(mem->vpll_mdiv, mem->vpll_pdiv, mem->vpll_sdiv);
- writel(val, &clk->vpll_con0);
- while ((readl(&clk->vpll_con0) & PLL_LOCKED) == 0)
- /* Set BPLL */
- writel(BPLL_CON1_VAL, &clk->bpll_con1);
- val = set_pll(mem->bpll_mdiv, mem->bpll_pdiv, mem->bpll_sdiv);
- writel(val, &clk->bpll_con0);
- while ((readl(&clk->bpll_con0) & PLL_LOCKED) == 0)
- /* Set SPLL */
- writel(SPLL_CON1_VAL, &clk->spll_con1);
- val = set_pll(mem->spll_mdiv, mem->spll_pdiv, mem->spll_sdiv);
- writel(val, &clk->spll_con0);
- while ((readl(&clk->spll_con0) & PLL_LOCKED) == 0)
- writel(CLK_DIV_CDREX0_VAL, &clk->div_cdrex0);
- writel(CLK_DIV_CDREX1_VAL, &clk->div_cdrex1);
- writel(CLK_SRC_TOP0_VAL, &clk->src_top0);
- writel(CLK_SRC_TOP1_VAL, &clk->src_top1);
- writel(CLK_SRC_TOP2_VAL, &clk->src_top2);
- writel(CLK_SRC_TOP7_VAL, &clk->src_top7);
- writel(CLK_DIV_TOP0_VAL, &clk->div_top0);
- writel(CLK_DIV_TOP1_VAL, &clk->div_top1);
- writel(CLK_DIV_TOP2_VAL, &clk->div_top2);
- writel(0, &clk->src_top10);
- writel(0, &clk->src_top11);
- writel(0, &clk->src_top12);
- writel(CLK_SRC_TOP3_VAL, &clk->src_top3);
- writel(CLK_SRC_TOP4_VAL, &clk->src_top4);
- writel(CLK_SRC_TOP5_VAL, &clk->src_top5);
- /* DISP1 BLK CLK SELECTION */
- writel(CLK_SRC_DISP1_0_VAL, &clk->src_disp10);
- writel(CLK_DIV_DISP1_0_VAL, &clk->div_disp10);
- /* AUDIO BLK */
- writel(AUDIO0_SEL_EPLL, &clk->src_mau);
- writel(DIV_MAU_VAL, &clk->div_mau);
- /* FSYS */
- writel(CLK_SRC_FSYS0_VAL, &clk->src_fsys);
- writel(CLK_DIV_FSYS0_VAL, &clk->div_fsys0);
- writel(CLK_DIV_FSYS1_VAL, &clk->div_fsys1);
- writel(CLK_DIV_FSYS2_VAL, &clk->div_fsys2);
- writel(CLK_SRC_ISP_VAL, &clk->src_isp);
- writel(CLK_DIV_ISP0_VAL, &clk->div_isp0);
- writel(CLK_DIV_ISP1_VAL, &clk->div_isp1);
- writel(CLK_SRC_PERIC0_VAL, &clk->src_peric0);
- writel(CLK_SRC_PERIC1_VAL, &clk->src_peric1);
- writel(CLK_DIV_PERIC0_VAL, &clk->div_peric0);
- writel(CLK_DIV_PERIC1_VAL, &clk->div_peric1);
- writel(CLK_DIV_PERIC2_VAL, &clk->div_peric2);
- writel(CLK_DIV_PERIC3_VAL, &clk->div_peric3);
- writel(CLK_DIV_PERIC4_VAL, &clk->div_peric4);
- writel(CLK_DIV_CPERI1_VAL, &clk->div_cperi1);
- writel(CLK_DIV2_RATIO, &clk->clkdiv2_ratio);
- writel(CLK_DIV4_RATIO, &clk->clkdiv4_ratio);
- writel(CLK_DIV_G2D, &clk->div_g2d);
- writel(CLK_SRC_TOP6_VAL, &clk->src_top6);
- writel(CLK_SRC_CDREX_VAL, &clk->src_cdrex);
- writel(CLK_SRC_KFC_VAL, &clk->src_kfc);
+void system_clock_init(void) +{
- if (proid_is_exynos5420())
exynos5420_system_clock_init();
- else
exynos5250_system_clock_init();
void clock_init_dp_clock(void) { struct exynos5_clock *clk =
Thanks, Minkyu Kang.
Minkyu Kang
