[U-Boot] [PULL] u-boot-pxa.git/master
The following changes since commit 5ed6f447af60aabd2669d913f673793c1ce48f47:
P1022DS: Set CONFIG_SPL_MAX_SIZE directly (2013-05-03 09:19:43 -0400)
git://git.denx.de/u-boot-pxa.git master
for you to fetch changes up to 66a62ce0dc48d2319938c72f34a562f519c5d5c2:
h2200: Add board reset support (2013-05-05 23:47:05 +0200)
---------------------------------------------------------------- Mike Dunn (5): lib: import bitrev library from the linux kernel pxa_lcd: add the ACX544AKN lcd device pxa_lcd: make lcd_enable() a weak pointer pxa27x_udc: remove call to unimplemented set_GPIO_mode() mtd: nand: add driver for diskonchip g4 nand flash
Łukasz Dałek (2): pxa: Add weak attribute to reset_cpu() function h2200: Add board reset support
arch/arm/cpu/pxa/pxa2xx.c | 2 +- arch/arm/include/asm/arch-pxa/hardware.h | 11 -- board/h2200/h2200.c | 9 ++ drivers/mtd/nand/Makefile | 2 + drivers/mtd/nand/docg4.c | 1028 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ drivers/mtd/nand/docg4_spl.c | 222 ++++++++++++++++++++++++++++ drivers/usb/gadget/pxa27x_udc.c | 4 +- drivers/video/pxa_lcd.c | 34 ++++- include/linux/bitrev.h | 23 +++ include/linux/mtd/docg4.h | 134 +++++++++++++++++ lib/Makefile | 1 + lib/bitrev.c | 59 ++++++++ 12 files changed, 1515 insertions(+), 14 deletions(-) create mode 100644 drivers/mtd/nand/docg4.c create mode 100644 drivers/mtd/nand/docg4_spl.c create mode 100644 include/linux/bitrev.h create mode 100644 include/linux/mtd/docg4.h create mode 100644 lib/bitrev.c
??ukasz Da??ek (2): pxa: Add weak attribute to reset_cpu() function h2200: Add board reset support
Ahem, this is for Albert :)
Dear Tom Rini,
The following changes since commit 5ed6f447af60aabd2669d913f673793c1ce48f47: P1022DS: Set CONFIG_SPL_MAX_SIZE directly (2013-05-03 09:19:43 -0400)
are available in the git repository at: git://git.denx.de/u-boot-pxa.git master
for you to fetch changes up to 66a62ce0dc48d2319938c72f34a562f519c5d5c2: h2200: Add board reset support (2013-05-05 23:47:05 +0200)
Yes it is, my bad.
Best regards, Marek Vasut
Hi Marek,
arch/arm/cpu/pxa/pxa2xx.c | 2 +- arch/arm/include/asm/arch-pxa/hardware.h | 11 -- board/h2200/h2200.c | 9 ++ drivers/mtd/nand/Makefile | 2 + drivers/mtd/nand/docg4.c | 1028 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ drivers/mtd/nand/docg4_spl.c | 222 ++++++++++++++++++++++++++++ drivers/usb/gadget/pxa27x_udc.c | 4 +- drivers/video/pxa_lcd.c | 34 ++++- include/linux/bitrev.h | 23 +++ include/linux/mtd/docg4.h | 134 +++++++++++++++++ lib/Makefile | 1 + lib/bitrev.c | 59 ++++++++ 12 files changed, 1515 insertions(+), 14 deletions(-) create mode 100644 drivers/mtd/nand/docg4.c create mode 100644 drivers/mtd/nand/docg4_spl.c create mode 100644 include/linux/bitrev.h create mode 100644 include/linux/mtd/docg4.h create mode 100644 lib/bitrev.c _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Applied to u-boot-arm/master, thanks!
Amicalement,
Albert ARIBAUD
