[PATCH 0/6] revive Theobroma-Systems puma board
From: Heiko Stuebner heiko.stuebner@theobroma-systems.com
This revives the puma boards and makes them boot again with mainline uboot.
Main points may be going back to the general fit script and cleaning up the devicetree situation that got completely broken by the recent sync from mainline linux.
Heiko Stuebner (6): arm64: dts: rk3399-puma: fix gpio levels for gmac reset pin board: puma: fix indentation for -u-boot.dtsi board: puma: reorganize devicetrees to actually work and match upstream board: puma: fix indentation of misc_init_r board: puma: allow building with TPL as well board: puma: remove separate fit generator
arch/arm/dts/Makefile | 4 +- arch/arm/dts/rk3399-puma-ddr1333-u-boot.dtsi | 4 - arch/arm/dts/rk3399-puma-ddr1333.dts | 8 - arch/arm/dts/rk3399-puma-ddr1600-u-boot.dtsi | 4 - arch/arm/dts/rk3399-puma-ddr1600.dts | 9 - arch/arm/dts/rk3399-puma-ddr1866-u-boot.dtsi | 4 - arch/arm/dts/rk3399-puma-ddr1866.dts | 8 - arch/arm/dts/rk3399-puma-haikou.dts | 272 ++++++++++++++++++ arch/arm/dts/rk3399-puma-u-boot.dtsi | 43 +-- arch/arm/dts/rk3399-puma.dtsi | 2 +- board/theobroma-systems/puma_rk3399/Kconfig | 15 + .../puma_rk3399/fit_spl_atf.sh | 94 ------ .../puma_rk3399/puma-rk3399.c | 30 +- configs/puma-rk3399_defconfig | 3 +- 14 files changed, 334 insertions(+), 166 deletions(-) delete mode 100644 arch/arm/dts/rk3399-puma-ddr1333-u-boot.dtsi delete mode 100644 arch/arm/dts/rk3399-puma-ddr1333.dts delete mode 100644 arch/arm/dts/rk3399-puma-ddr1600-u-boot.dtsi delete mode 100644 arch/arm/dts/rk3399-puma-ddr1600.dts delete mode 100644 arch/arm/dts/rk3399-puma-ddr1866-u-boot.dtsi delete mode 100644 arch/arm/dts/rk3399-puma-ddr1866.dts create mode 100644 arch/arm/dts/rk3399-puma-haikou.dts delete mode 100755 board/theobroma-systems/puma_rk3399/fit_spl_atf.sh
The gmac reset has opposite values for the gpio declaration and the separate reset-active, bring this in line to make u-boot also find the ethernet-phy.
This mimics the upstream Linus commit found on https://lore.kernel.org/r/20200603132836.362519-1-heiko@sntech.de
Signed-off-by: Heiko Stuebner heiko.stuebner@theobroma-systems.com --- arch/arm/dts/rk3399-puma.dtsi | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/dts/rk3399-puma.dtsi b/arch/arm/dts/rk3399-puma.dtsi index 07694b196f..531520e771 100644 --- a/arch/arm/dts/rk3399-puma.dtsi +++ b/arch/arm/dts/rk3399-puma.dtsi @@ -157,7 +157,7 @@ phy-mode = "rgmii"; pinctrl-names = "default"; pinctrl-0 = <&rgmii_pins>; - snps,reset-gpio = <&gpio3 RK_PC0 GPIO_ACTIVE_HIGH>; + snps,reset-gpio = <&gpio3 RK_PC0 GPIO_ACTIVE_LOW>; snps,reset-active-low; snps,reset-delays-us = <0 10000 50000>; tx_delay = <0x10>;
Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Tabs not spaces, so transform it to the common styling.
Signed-off-by: Heiko Stuebner heiko.stuebner@theobroma-systems.com --- arch/arm/dts/rk3399-puma-u-boot.dtsi | 30 ++++++++++++++-------------- 1 file changed, 15 insertions(+), 15 deletions(-)
diff --git a/arch/arm/dts/rk3399-puma-u-boot.dtsi b/arch/arm/dts/rk3399-puma-u-boot.dtsi index 3ad1139833..ddb5fa6e76 100644 --- a/arch/arm/dts/rk3399-puma-u-boot.dtsi +++ b/arch/arm/dts/rk3399-puma-u-boot.dtsi @@ -2,24 +2,24 @@
#include "rk3399-u-boot.dtsi" / { - config { - u-boot,spl-payload-offset = <0x40000>; /* @ 256KB */ - u-boot,mmc-env-offset = <0x4000>; /* @ 16KB */ - u-boot,efi-partition-entries-offset = <0x200000>; /* 2MB */ - u-boot,boot-led = "module_led"; - sysreset-gpio = <&gpio1 RK_PA6 GPIO_ACTIVE_HIGH>; - }; + config { + u-boot,spl-payload-offset = <0x40000>; /* @ 256KB */ + u-boot,mmc-env-offset = <0x4000>; /* @ 16KB */ + u-boot,efi-partition-entries-offset = <0x200000>; /* 2MB */ + u-boot,boot-led = "module_led"; + sysreset-gpio = <&gpio1 RK_PA6 GPIO_ACTIVE_HIGH>; + };
- chosen { - stdout-path = "serial0:115200n8"; - u-boot,spl-boot-order = \ + chosen { + stdout-path = "serial0:115200n8"; + u-boot,spl-boot-order = \ "same-as-spl", &norflash, &sdhci, &sdmmc; - }; + };
- aliases { - spi0 = &spi1; - spi1 = &spi5; - }; + aliases { + spi0 = &spi1; + spi1 = &spi5; + };
/* * The Qseven BIOS_DISABLE signal on the RK3399-Q7 keeps the on-module
So far the puma dts files only just included the main puma dtsi without handling the actual baseboard and rk3399-puma.dtsi was very much detached from the variant in the mainline Linux kernel.
Recent changes resulted in a strange situation with nonworking puma boards.
Commit ab800e5a6f28 ("arm: dts: rockchip: puma: move U-Boot specific bits to u-boot.dtsi") moved the sdram include from rk3399-puma-ddrX.dts to new files rk3399-puma-ddrx-u-boot.dtsi which were never included anywhere though.
Commit 167efc2c7a46 ("arm64: dts: rk3399: Sync v5.7-rc1 from Linux") replaced the rk3399-puma.dtsi nearly completely, but in the kernel it definitly depends on a baseboard dts to actually enable peripherals like sd-slot, uarts, etc.
So to untagle this and bring the whole thing more in line with mainline Linux, bring the rk3399-puma-haikou.dts over as well, drop the separate DDR-option devicetrees and instead replace them with a puma Kconfig option to select and include the needed DDR variant.
Signed-off-by: Heiko Stuebner heiko.stuebner@theobroma-systems.com --- arch/arm/dts/Makefile | 4 +- arch/arm/dts/rk3399-puma-ddr1333-u-boot.dtsi | 4 - arch/arm/dts/rk3399-puma-ddr1333.dts | 8 - arch/arm/dts/rk3399-puma-ddr1600-u-boot.dtsi | 4 - arch/arm/dts/rk3399-puma-ddr1600.dts | 9 - arch/arm/dts/rk3399-puma-ddr1866-u-boot.dtsi | 4 - arch/arm/dts/rk3399-puma-ddr1866.dts | 8 - arch/arm/dts/rk3399-puma-haikou.dts | 272 +++++++++++++++++++ arch/arm/dts/rk3399-puma-u-boot.dtsi | 11 + board/theobroma-systems/puma_rk3399/Kconfig | 15 + configs/puma-rk3399_defconfig | 2 +- 11 files changed, 300 insertions(+), 41 deletions(-) delete mode 100644 arch/arm/dts/rk3399-puma-ddr1333-u-boot.dtsi delete mode 100644 arch/arm/dts/rk3399-puma-ddr1333.dts delete mode 100644 arch/arm/dts/rk3399-puma-ddr1600-u-boot.dtsi delete mode 100644 arch/arm/dts/rk3399-puma-ddr1600.dts delete mode 100644 arch/arm/dts/rk3399-puma-ddr1866-u-boot.dtsi delete mode 100644 arch/arm/dts/rk3399-puma-ddr1866.dts create mode 100644 arch/arm/dts/rk3399-puma-haikou.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index c6af87cf5e..a66bdb439d 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -130,9 +130,7 @@ dtb-$(CONFIG_ROCKCHIP_RK3399) += \ rk3399-nanopi-neo4.dtb \ rk3399-orangepi.dtb \ rk3399-pinebook-pro.dtb \ - rk3399-puma-ddr1333.dtb \ - rk3399-puma-ddr1600.dtb \ - rk3399-puma-ddr1866.dtb \ + rk3399-puma-haikou.dtb \ rk3399-roc-pc.dtb \ rk3399-roc-pc-mezzanine.dtb \ rk3399-rock-pi-4.dtb \ diff --git a/arch/arm/dts/rk3399-puma-ddr1333-u-boot.dtsi b/arch/arm/dts/rk3399-puma-ddr1333-u-boot.dtsi deleted file mode 100644 index 39d3927f49..0000000000 --- a/arch/arm/dts/rk3399-puma-ddr1333-u-boot.dtsi +++ /dev/null @@ -1,4 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ - -#include "rk3399-puma-u-boot.dtsi" -#include "rk3399-sdram-ddr3-1333.dtsi" diff --git a/arch/arm/dts/rk3399-puma-ddr1333.dts b/arch/arm/dts/rk3399-puma-ddr1333.dts deleted file mode 100644 index 80f27699f4..0000000000 --- a/arch/arm/dts/rk3399-puma-ddr1333.dts +++ /dev/null @@ -1,8 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ OR X11 -/* - * (C) Copyright 2017 Theobroma Systems Design und Consulting GmbH - */ - -/dts-v1/; - -#include "rk3399-puma.dtsi" diff --git a/arch/arm/dts/rk3399-puma-ddr1600-u-boot.dtsi b/arch/arm/dts/rk3399-puma-ddr1600-u-boot.dtsi deleted file mode 100644 index be58311dc4..0000000000 --- a/arch/arm/dts/rk3399-puma-ddr1600-u-boot.dtsi +++ /dev/null @@ -1,4 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ - -#include "rk3399-puma-u-boot.dtsi" -#include "rk3399-sdram-ddr3-1600.dtsi" diff --git a/arch/arm/dts/rk3399-puma-ddr1600.dts b/arch/arm/dts/rk3399-puma-ddr1600.dts deleted file mode 100644 index cb76b0165c..0000000000 --- a/arch/arm/dts/rk3399-puma-ddr1600.dts +++ /dev/null @@ -1,9 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ OR X11 -/* - * (C) Copyright 2017 Theobroma Systems Design und Consulting GmbH - */ - -/dts-v1/; - -#include "rk3399-puma.dtsi" -#include "rk3399-u-boot.dtsi" diff --git a/arch/arm/dts/rk3399-puma-ddr1866-u-boot.dtsi b/arch/arm/dts/rk3399-puma-ddr1866-u-boot.dtsi deleted file mode 100644 index 48da076329..0000000000 --- a/arch/arm/dts/rk3399-puma-ddr1866-u-boot.dtsi +++ /dev/null @@ -1,4 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ - -#include "rk3399-puma-u-boot.dtsi" -#include "rk3399-sdram-ddr3-1866.dtsi" diff --git a/arch/arm/dts/rk3399-puma-ddr1866.dts b/arch/arm/dts/rk3399-puma-ddr1866.dts deleted file mode 100644 index 80f27699f4..0000000000 --- a/arch/arm/dts/rk3399-puma-ddr1866.dts +++ /dev/null @@ -1,8 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ OR X11 -/* - * (C) Copyright 2017 Theobroma Systems Design und Consulting GmbH - */ - -/dts-v1/; - -#include "rk3399-puma.dtsi" diff --git a/arch/arm/dts/rk3399-puma-haikou.dts b/arch/arm/dts/rk3399-puma-haikou.dts new file mode 100644 index 0000000000..f23ec02783 --- /dev/null +++ b/arch/arm/dts/rk3399-puma-haikou.dts @@ -0,0 +1,272 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2017 Theobroma Systems Design und Consulting GmbH + */ + +/dts-v1/; +#include "rk3399-puma.dtsi" +#include "rk3399-puma-u-boot.dtsi" + +/ { + model = "Theobroma Systems RK3399-Q7 SoM"; + compatible = "tsd,rk3399-puma-haikou", "rockchip,rk3399"; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + leds { + pinctrl-0 = <&led_pin_module>, <&led_sd_haikou>; + + sd-card-led { + label = "sd_card_led"; + gpios = <&gpio1 RK_PA2 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "mmc0"; + }; + }; + + i2s0-sound { + compatible = "simple-audio-card"; + simple-audio-card,format = "i2s"; + simple-audio-card,name = "Haikou,I2S-codec"; + simple-audio-card,mclk-fs = <512>; + + simple-audio-card,codec { + clocks = <&sgtl5000_clk>; + sound-dai = <&sgtl5000>; + }; + + simple-audio-card,cpu { + bitclock-master; + frame-master; + sound-dai = <&i2s0>; + }; + }; + + sgtl5000_clk: sgtl5000-oscillator { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <24576000>; + }; + + dc_12v: dc-12v { + compatible = "regulator-fixed"; + regulator-name = "dc_12v"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + }; + + vcc3v3_baseboard: vcc3v3-baseboard { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3_baseboard"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&dc_12v>; + }; + + vcc5v0_baseboard: vcc5v0-baseboard { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_baseboard"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&dc_12v>; + }; + + vcc5v0_otg: vcc5v0-otg-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio0 RK_PA2 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&otg_vbus_drv>; + regulator-name = "vcc5v0_otg"; + regulator-always-on; + }; + + vdda_codec: vdda-codec { + compatible = "regulator-fixed"; + regulator-name = "vdda_codec"; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vcc5v0_baseboard>; + }; + + vddd_codec: vddd-codec { + compatible = "regulator-fixed"; + regulator-name = "vddd_codec"; + regulator-boot-on; + regulator-min-microvolt = <1600000>; + regulator-max-microvolt = <1600000>; + vin-supply = <&vcc5v0_baseboard>; + }; +}; + +&hdmi { + ddc-i2c-bus = <&i2c3>; + status = "okay"; +}; + +&i2c1 { + status = "okay"; + clock-frequency = <400000>; +}; + +&i2c2 { + status = "okay"; + clock-frequency = <400000>; +}; + +&i2c3 { + i2c-scl-rising-time-ns = <450>; + i2c-scl-falling-time-ns = <15>; + status = "okay"; +}; + +&i2c4 { + status = "okay"; + clock-frequency = <400000>; + + sgtl5000: codec@a { + compatible = "fsl,sgtl5000"; + reg = <0x0a>; + clocks = <&sgtl5000_clk>; + #sound-dai-cells = <0>; + VDDA-supply = <&vdda_codec>; + VDDIO-supply = <&vdda_codec>; + VDDD-supply = <&vddd_codec>; + status = "okay"; + }; +}; + +&i2c6 { + status = "okay"; + clock-frequency = <400000>; +}; + +&pcie_phy { + status = "okay"; +}; + +&pcie0 { + ep-gpios = <&gpio4 RK_PC6 GPIO_ACTIVE_HIGH>; + num-lanes = <4>; + pinctrl-names = "default"; + pinctrl-0 = <&pcie_clkreqn_cpm>; + status = "okay"; +}; + +&pinctrl { + pinctrl-names = "default"; + pinctrl-0 = <&haikou_pin_hog>; + + hog { + haikou_pin_hog: haikou-pin-hog { + rockchip,pins = + /* LID_BTN */ + <0 RK_PA4 RK_FUNC_GPIO &pcfg_pull_up>, + /* BATLOW# */ + <0 RK_PB2 RK_FUNC_GPIO &pcfg_pull_up>, + /* SLP_BTN# */ + <0 RK_PB3 RK_FUNC_GPIO &pcfg_pull_up>, + /* BIOS_DISABLE# */ + <0 RK_PB1 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + leds { + led_sd_haikou: led-sd-gpio { + rockchip,pins = + <1 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + usb2 { + otg_vbus_drv: otg-vbus-drv { + rockchip,pins = + <0 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; +}; + +&pwm0 { + status = "okay"; +}; + +&sdmmc { + bus-width = <4>; + cap-mmc-highspeed; + cap-sd-highspeed; + cd-gpios = <&gpio0 RK_PA7 GPIO_ACTIVE_LOW>; + disable-wp; + max-frequency = <150000000>; + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd &sdmmc_bus4>; + vmmc-supply = <&vcc3v3_baseboard>; + status = "okay"; +}; + +&spi5 { + status = "okay"; +}; + +&tcphy0 { + status = "okay"; +}; + +&u2phy0 { + status = "okay"; +}; + +&usbdrd3_0 { + status = "okay"; +}; + +&usbdrd_dwc3_0 { + dr_mode = "otg"; + status = "okay"; +}; + +&u2phy0_host { + phy-supply = <&vcc5v0_otg>; + status = "okay"; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_xfer &uart0_cts &uart0_rts>; + status = "okay"; +}; + +&uart2 { + status = "okay"; +}; + +&usb_host0_ehci { + status = "okay"; +}; + +&usb_host0_ohci { + status = "okay"; +}; + +&vopb { + status = "okay"; +}; + +&vopb_mmu { + status = "okay"; +}; + +&vopl { + status = "okay"; +}; + +&vopl_mmu { + status = "okay"; +}; diff --git a/arch/arm/dts/rk3399-puma-u-boot.dtsi b/arch/arm/dts/rk3399-puma-u-boot.dtsi index ddb5fa6e76..29846c4b00 100644 --- a/arch/arm/dts/rk3399-puma-u-boot.dtsi +++ b/arch/arm/dts/rk3399-puma-u-boot.dtsi @@ -1,6 +1,17 @@ // SPDX-License-Identifier: GPL-2.0+
#include "rk3399-u-boot.dtsi" + +#ifdef CONFIG_TARGET_PUMA_RK3399_RAM_DDR3_1333 +#include "rk3399-sdram-ddr3-1333.dtsi" +#endif +#ifdef CONFIG_TARGET_PUMA_RK3399_RAM_DDR3_1600 +#include "rk3399-sdram-ddr3-1600.dtsi" +#endif +#ifdef CONFIG_TARGET_PUMA_RK3399_RAM_DDR3_1866 +#include "rk3399-sdram-ddr3-1866.dtsi" +#endif + / { config { u-boot,spl-payload-offset = <0x40000>; /* @ 256KB */ diff --git a/board/theobroma-systems/puma_rk3399/Kconfig b/board/theobroma-systems/puma_rk3399/Kconfig index 9e23252754..e82623a170 100644 --- a/board/theobroma-systems/puma_rk3399/Kconfig +++ b/board/theobroma-systems/puma_rk3399/Kconfig @@ -18,4 +18,19 @@ config ENV_SIZE config ENV_OFFSET default 0x3fc000 if ENV_IS_IN_SPI_FLASH
+choice + prompt "Theobroma Systems RK3399-Q7 DDR Option" + default TARGET_PUMA_RK3399_RAM_DDR3_1333 + +config TARGET_PUMA_RK3399_RAM_DDR3_1333 + bool "DDR3-1333MHz" + +config TARGET_PUMA_RK3399_RAM_DDR3_1600 + bool "DDR3-1600MHz" + +config TARGET_PUMA_RK3399_RAM_DDR3_1866 + bool "DDR3-1866MHz" + +endchoice + endif diff --git a/configs/puma-rk3399_defconfig b/configs/puma-rk3399_defconfig index a148832b83..47a60930b6 100644 --- a/configs/puma-rk3399_defconfig +++ b/configs/puma-rk3399_defconfig @@ -39,7 +39,7 @@ CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_LIVE=y -CONFIG_DEFAULT_DEVICE_TREE="rk3399-puma-ddr1600" +CONFIG_DEFAULT_DEVICE_TREE="rk3399-puma-haikou" CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y
The commit moving puma to the generic cpuid/macaddr helpers used 7 spaces as indentation, so correct that by moving to the required tabs.
Fixes: fa177ff0208b ("board: puma: Use rockchip_* helpers to setup cpuid and macaddr") Signed-off-by: Heiko Stuebner heiko.stuebner@theobroma-systems.com --- .../puma_rk3399/puma-rk3399.c | 32 +++++++++---------- 1 file changed, 16 insertions(+), 16 deletions(-)
diff --git a/board/theobroma-systems/puma_rk3399/puma-rk3399.c b/board/theobroma-systems/puma_rk3399/puma-rk3399.c index f7f08ae617..65bb2ad6f2 100644 --- a/board/theobroma-systems/puma_rk3399/puma-rk3399.c +++ b/board/theobroma-systems/puma_rk3399/puma-rk3399.c @@ -114,22 +114,22 @@ static int setup_boottargets(void)
int misc_init_r(void) { - const u32 cpuid_offset = 0x7; - const u32 cpuid_length = 0x10; - u8 cpuid[cpuid_length]; - int ret; - - ret = rockchip_cpuid_from_efuse(cpuid_offset, cpuid_length, cpuid); - if (ret) - return ret; - - ret = rockchip_cpuid_set(cpuid, cpuid_length); - if (ret) - return ret; - - ret = rockchip_setup_macaddr(); - if (ret) - return ret; + const u32 cpuid_offset = 0x7; + const u32 cpuid_length = 0x10; + u8 cpuid[cpuid_length]; + int ret; + + ret = rockchip_cpuid_from_efuse(cpuid_offset, cpuid_length, cpuid); + if (ret) + return ret; + + ret = rockchip_cpuid_set(cpuid, cpuid_length); + if (ret) + return ret; + + ret = rockchip_setup_macaddr(); + if (ret) + return ret;
setup_iodomain(); setup_boottargets();
Right now puma-u-boot can fit everything into SPL but that may overflow easily for example with more extensive debug options.
By adding CONFIG_TPL and removing the CONFIG_SPL_TEXT_BASE it is easy to enable a TPL build as well. Only obstacle is the usb-specific handling for the puma regulator, so make this conditional on actual usb options being enabled in SPL and U-Boot proper.
Signed-off-by: Heiko Stuebner heiko.stuebner@theobroma-systems.com --- board/theobroma-systems/puma_rk3399/puma-rk3399.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/board/theobroma-systems/puma_rk3399/puma-rk3399.c b/board/theobroma-systems/puma_rk3399/puma-rk3399.c index 65bb2ad6f2..31ac27c6f5 100644 --- a/board/theobroma-systems/puma_rk3399/puma-rk3399.c +++ b/board/theobroma-systems/puma_rk3399/puma-rk3399.c @@ -153,6 +153,9 @@ void get_board_serial(struct tag_serialnr *serialnr) } #endif
+#if !defined(CONFIG_TPL_BUILD) && \ + (defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_USB_HOST_SUPPORT)) || \ + (!defined(CONFIG_SPL_BUILD) && defined(CONFIG_USB)) /** * Switch power at an external regulator (for our root hub). * @@ -219,3 +222,4 @@ void usb_hub_reset_devices(struct usb_hub_device *hub, int port) */ board_usb_port_power_set(ctrl, port, true); } +#endif
The introduction of the puma-specific generator was mainly a way to split the pmu firmware from the ATF binary and not having to distribute that 4GB (sparse) image that was created before moving to the bl31.elf as base.
Looking at the publically available repository for that separate pmu firmware https://git.theobroma-systems.com/rk3399-cortex-m0.git/ there is also no activity for 3 years and apart from some build customizations no other changes were done.
And even then, if changes need to be made, this can very well also happen in the atf context itself, so there is no real need to diverge from the established build procedure and we can just go back to using the main make_fit_atf.py script.
Signed-off-by: Heiko Stuebner heiko.stuebner@theobroma-systems.com --- .../puma_rk3399/fit_spl_atf.sh | 94 ------------------- configs/puma-rk3399_defconfig | 1 - 2 files changed, 95 deletions(-) delete mode 100755 board/theobroma-systems/puma_rk3399/fit_spl_atf.sh
diff --git a/board/theobroma-systems/puma_rk3399/fit_spl_atf.sh b/board/theobroma-systems/puma_rk3399/fit_spl_atf.sh deleted file mode 100755 index c9396577a9..0000000000 --- a/board/theobroma-systems/puma_rk3399/fit_spl_atf.sh +++ /dev/null @@ -1,94 +0,0 @@ -#!/bin/sh -# -# SPDX-License-Identifier: GPL-2.0+ -# -# Copyright (C) 2019 Jagan Teki jagan@amarulasolutions.com -# -# Based on the board/sunxi/mksunxi_fit_atf.sh -# -# Script to generate FIT image source for 64-bit puma boards with -# U-Boot proper, ATF, PMU firmware and devicetree. -# -# usage: $0 <dt_name> [<dt_name> [<dt_name] ...] - -[ -z "$BL31" ] && BL31="bl31.bin" - -if [ ! -f $BL31 ]; then - echo "WARNING: BL31 file $BL31 NOT found, resulting binary is non-functional" >&2 - echo "Please read Building section in doc/README.rockchip" >&2 - BL31=/dev/null -fi - -[ -z "$PMUM0" ] && PMUM0="rk3399m0.bin" - -if [ ! -f $PMUM0 ]; then - echo "WARNING: PMUM0 file $PMUM0 NOT found, resulting binary is non-functional" >&2 - echo "Please read Building section in doc/README.rockchip" >&2 - PMUM0=/dev/null -fi - -cat << __HEADER_EOF -/* SPDX-License-Identifier: GPL-2.0+ OR X11 */ -/* - * Copyright (C) 2017 Theobroma Systems Design und Consulting GmbH - * - * Minimal dts for a SPL FIT image payload. - */ - -/dts-v1/; - -/ { - description = "FIT image with U-Boot proper, ATF bl31, M0 Firmware, DTB"; - #address-cells = <1>; - - images { - uboot { - description = "U-Boot (64-bit)"; - data = /incbin/("u-boot-nodtb.bin"); - type = "standalone"; - arch = "arm64"; - compression = "none"; - load = <0x4a000000>; - }; - atf { - description = "ARM Trusted Firmware"; - data = /incbin/("$BL31"); - type = "firmware"; - arch = "arm64"; - os = "arm-trusted-firmware"; - compression = "none"; - load = <0x1000>; - entry = <0x1000>; - }; - pmu { - description = "Cortex-M0 firmware"; - data = /incbin/("$PMUM0"); - type = "pmu-firmware"; - compression = "none"; - load = <0x180000>; - }; - fdt { - description = "RK3399-Q7 (Puma) flat device-tree"; - data = /incbin/("$1"); - type = "flat_dt"; - compression = "none"; - }; -__HEADER_EOF - -cat << __CONF_HEADER_EOF - }; - - configurations { - default = "conf"; - conf { - description = "Theobroma Systems RK3399-Q7 (Puma) SoM"; - firmware = "atf"; - loadables = "uboot", "pmu"; - fdt = "fdt"; - }; -__CONF_HEADER_EOF - -cat << __ITS_EOF - }; -}; -__ITS_EOF diff --git a/configs/puma-rk3399_defconfig b/configs/puma-rk3399_defconfig index 47a60930b6..31d4eb3471 100644 --- a/configs/puma-rk3399_defconfig +++ b/configs/puma-rk3399_defconfig @@ -14,7 +14,6 @@ CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_SPL_TEXT_BASE=0xff8c2000 CONFIG_DEBUG_UART=y -CONFIG_SPL_FIT_GENERATOR="board/theobroma-systems/puma_rk3399/fit_spl_atf.sh" CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-puma-haikou.dtb" CONFIG_MISC_INIT_R=y CONFIG_DISPLAY_BOARDINFO_LATE=y
Hi Heiko,
Could you use 'rockchip' instead of 'board' as prefix in the subject?
Thanks,
- Kever
Heiko Stuebner
Kever Yang
Philipp Tomsich
