[PATCH] tools/mkeficapsule: correct printf codes
uint64_t is defined as unsigned long long on 32-bit ARM. Use PRIX64 for printing uint64_t.
This avoid a build failure on 32-bit systems:
tools/mkeficapsule.c: In function 'dump_capsule_auth_header': tools/mkeficapsule.c:694:66: warning: format '%lX' expects argument of type 'long unsigned int', but argument 2 has type 'uint64_t' {aka 'long long unsigned int'} [-Wformat=] 694 | printf("EFI_FIRMWARE_IMAGE_AUTH.MONOTONIC_COUNT\t\t: %08lX\n", | ~~~~^ | | | long unsigned int | %08llX
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- v2: use PRIX64 to print uint64_t --- tools/mkeficapsule.c | 7 ++++--- 1 file changed, 4 insertions(+), 3 deletions(-)
diff --git a/tools/mkeficapsule.c b/tools/mkeficapsule.c index f28008a0829..1b53151d41a 100644 --- a/tools/mkeficapsule.c +++ b/tools/mkeficapsule.c @@ -5,6 +5,7 @@ */
#include <getopt.h> +#include <inttypes.h> #include <pe.h> #include <stdbool.h> #include <stdint.h> @@ -691,7 +692,7 @@ static uint32_t dump_fmp_payload_header( static void dump_capsule_auth_header( struct efi_firmware_image_authentication *capsule_auth_hdr) { - printf("EFI_FIRMWARE_IMAGE_AUTH.MONOTONIC_COUNT\t\t: %08lX\n", + printf("EFI_FIRMWARE_IMAGE_AUTH.MONOTONIC_COUNT\t\t: %08" PRIX64 "\n", capsule_auth_hdr->monotonic_count); printf("EFI_FIRMWARE_IMAGE_AUTH.AUTH_INFO.HDR.dwLENGTH\t: %08X\n", capsule_auth_hdr->auth_info.hdr.dwLength); @@ -724,9 +725,9 @@ static void dump_fmp_capsule_image_header( image_hdr->update_image_size); printf("FMP_CAPSULE_IMAGE_HDR.UPDATE_VENDOR_CODE_SIZE\t: %08X\n", image_hdr->update_vendor_code_size); - printf("FMP_CAPSULE_IMAGE_HDR.UPDATE_HARDWARE_INSTANCE\t: %08lX\n", + printf("FMP_CAPSULE_IMAGE_HDR.UPDATE_HARDWARE_INSTANCE\t: %08" PRIX64 "\n", image_hdr->update_hardware_instance); - printf("FMP_CAPSULE_IMAGE_HDR.IMAGE_CAPSULE_SUPPORT\t: %08lX\n", + printf("FMP_CAPSULE_IMAGE_HDR.IMAGE_CAPSULE_SUPPORT\t: %08" PRIX64 "\n", image_hdr->image_capsule_support);
printf("--------\n");
Thanks Heinrich
On Wed, 14 Aug 2024 at 15:33, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
printf("FMP_CAPSULE_IMAGE_HDR.IMAGE_CAPSULE_SUPPORT\t: %08" PRIX64 "\n", image_hdr->image_capsule_support); printf("--------\n");
-- 2.45.2
Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org
From: Heinrich Schuchardt heinrich.schuchardt@canonical.com Date: Wed, 14 Aug 2024 14:33:44 +0200
FWIW, on OpenBSD uint64_t is always "unsigned long long" even on 64-bit architectures. So this should get rid of some warnings for us as well.
Personally I prefer the casting approach of v1 over PRIX64, but the latter is probably slightly more portable.
Reviewed-by: Mark Kettenis kettenis@openbsd.org
- printf("EFI_FIRMWARE_IMAGE_AUTH.MONOTONIC_COUNT\t\t: %08" PRIX64 "\n", capsule_auth_hdr->monotonic_count); printf("EFI_FIRMWARE_IMAGE_AUTH.AUTH_INFO.HDR.dwLENGTH\t: %08X\n", capsule_auth_hdr->auth_info.hdr.dwLength);
- printf("FMP_CAPSULE_IMAGE_HDR.UPDATE_HARDWARE_INSTANCE\t: %08" PRIX64 "\n", image_hdr->update_hardware_instance);
-- 2.45.2
Ilias Apalodimas
Mark Kettenis
