[U-Boot-Users] MPC8548CDS pre-eTSEC 3 and 4 patch
Guys,
So, before Andy can put the PHYs of eTSEC 3 and 4 into RGMII mode on 8548CDS systems, you have to add them to the port first.
This patch must be applied _before_ Andy Flemings patch posted just a couple hours ago with no subject line.
Thanks, jdl
* Patch by Jon Loeliger, 23-May-2005 Add eTSEC 3 and 4 to MPC8548CDS board.
Index: include/configs/MPC8548CDS.h =================================================================== RCS file: /cm/vault/u-boot/u-boot/include/configs/MPC8548CDS.h,v retrieving revision 1.1.4.2 retrieving revision 1.1.4.3 diff -u -r1.1.4.2 -r1.1.4.3 --- include/configs/MPC8548CDS.h 6 May 2005 19:47:20 -0000 1.1.4.2 +++ include/configs/MPC8548CDS.h 12 May 2005 19:57:14 -0000 1.1.4.3 @@ -370,13 +370,22 @@ #define CONFIG_MII 1 /* MII PHY management */ #define CONFIG_MPC85XX_TSEC1 1 #define CONFIG_MPC85XX_TSEC2 1 +#define CONFIG_MPC85XX_TSEC3 1 +#define CONFIG_MPC85XX_TSEC4 1 #undef CONFIG_MPC85XX_FEC + #define TSEC1_PHY_ADDR 0 #define TSEC2_PHY_ADDR 1 +#define TSEC3_PHY_ADDR 2 +#define TSEC4_PHY_ADDR 3 #define FEC_PHY_ADDR 3 + #define TSEC1_PHYIDX 0 #define TSEC2_PHYIDX 0 +#define TSEC3_PHYIDX 0 +#define TSEC4_PHYIDX 0 #define FEC_PHYIDX 0 + #define CONFIG_ETHPRIME "MOTO ENET0"
#endif /* CONFIG_TSEC_ENET */ Index: net/eth.c =================================================================== RCS file: /cm/vault/u-boot/u-boot/net/eth.c,v retrieving revision 1.1.1.2.2.4 retrieving revision 1.1.1.2.2.5 diff -u -r1.1.1.2.2.4 -r1.1.1.2.2.5 --- net/eth.c 1 Feb 2005 19:17:25 -0000 1.1.1.2.2.4 +++ net/eth.c 12 May 2005 19:57:14 -0000 1.1.1.2.2.5 @@ -162,6 +162,13 @@ #endif #if defined(CONFIG_MPC85XX_FEC) tsec_initialize(bis, 2); +#else +# if defined(CONFIG_MPC85XX_TSEC3) + tsec_initialize(bis, 2); +# endif +# if defined(CONFIG_MPC85XX_TSEC4) + tsec_initialize(bis, 3); +# endif #endif #if defined(CONFIG_AU1X00) au1x00_enet_initialize(bis); Index: cpu/mpc85xx/tsec.c =================================================================== RCS file: /cm/vault/u-boot/u-boot/cpu/mpc85xx/tsec.c,v retrieving revision 1.1.1.2.2.10 retrieving revision 1.1.1.2.2.11 diff -u -r1.1.1.2.2.10 -r1.1.1.2.2.11 --- cpu/mpc85xx/tsec.c 5 May 2005 21:33:52 -0000 1.1.1.2.2.10 +++ cpu/mpc85xx/tsec.c 12 May 2005 19:57:13 -0000 1.1.1.2.2.11 @@ -82,11 +82,20 @@ #ifdef CONFIG_MPC85XX_FEC {FEC_PHY_ADDR, 0, FEC_PHYIDX}, #else +# ifdef CONFIG_MPC85XX_TSEC3 + {TSEC3_PHY_ADDR, 1, TSEC3_PHYIDX}, +# else { 0, 0, 0}, +# endif +# ifdef CONFIG_MPC85XX_TSEC4 + {TSEC4_PHY_ADDR, 1, TSEC4_PHYIDX}, +# else + { 0, 0, 0}, +# endif #endif };
-#define MAXCONTROLLERS 3 +#define MAXCONTROLLERS (4)
static int relocated = 0;
Jon Loeliger
